[Mapbender-commits] r2392 -
branches/2.5/resources/db/postgresql/utf8
svn_mapbender at osgeo.org
Fri Apr 18 04:17:12 EDT 2008
Author: christoph
Date: 2008-04-18 04:17:11 -0400 (Fri, 18 Apr 2008)
New Revision: 2392
branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql
removed duplicate german translation
Modified: branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql
--- branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql 2008-04-16 14:52:59 UTC (rev 2391)
+++ branches/2.5/resources/db/postgresql/utf8/pgsql_data.sql 2008-04-18 08:17:11 UTC (rev 2392)
@@ -8199,62 +8199,7 @@
--- TOC entry 1881 (class 0 OID 5377305)
--- Dependencies: 1288
--- Data for Name: translations; Type: TABLE DATA; Schema: public; Owner: postgres
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (1, 'de', 'Pan', 'Ausschnitt verschieben');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (2, 'de', 'Display complete map', 'gesamte Karte anzeigen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (3, 'de', 'Zoom in', 'In die Karte hineinzoomen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (4, 'de', 'Zoom out', 'Aus der Karte herauszoomen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (5, 'de', 'Back', 'Zurück');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (6, 'de', 'Forward', 'Nach vorne');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (7, 'de', 'Coordinates', 'Koordinaten anzeigen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (8, 'de', 'Zoom by rectangle', 'Ausschnitt wählen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (9, 'de', 'Redraw', 'Neu laden oder Tastatur: Leertaste');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (10, 'de', 'Query', 'Datenabfrage');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (11, 'de', 'Logout', 'Abmelden');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (12, 'de', 'WMS preferences', 'WMS Einstellungen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (13, 'de', 'Adding WMS from filtered list', 'WMS von gefilteter Liste hinzufügen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (14, 'de', 'Set map center', 'Kartenmittelpunkt setzen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (15, 'de', 'Help', 'Hilfe');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (16, 'de', 'Show WMS infos', 'Anzeige von WMS Informationen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (17, 'de', 'Save workspace as web map context document', 'Ansicht als Web Map Context Dokument speichern');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (18, 'de', 'Resize Mapsize', 'Bildschirmgröße anpassen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (19, 'de', 'Rubber', 'Skizze löschen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (20, 'de', 'Get Area', 'Fläche berechnen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (21, 'de', 'Close Polygon', 'Polygon schliessen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (22, 'de', 'Move back to your GUI list', 'Zurück zur GUI Liste');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (23, 'de', 'Legend', 'Legende');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (24, 'de', 'Print', 'Druck');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (25, 'de', 'Imprint', 'Impressum');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (26, 'de', 'Maps', 'Karten');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (27, 'de', 'Search', 'Suche');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (28, 'de', 'Meetingpoint', 'Treffpunkt');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (29, 'de', 'Metadatasearch', 'Metadatensuche');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (30, 'de', 'Adding WMS', 'WMS hinzufügen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (31, 'de', 'Adding WMS from List', 'WMS aus Liste hinzufügen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (32, 'de', 'Info', 'Info');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (33, 'de', 'Change Projection', 'Projektion ändern');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (34, 'de', 'Copyright', 'Copyright');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (35, 'de', 'Digitize', 'Digitalisierung');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (36, 'de', 'Overview', 'Übersichtskarte');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (37, 'de', 'Drag Mapsize', 'Karte vergrößern');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (38, 'de', 'Mapframe', 'Kartenfenster');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (39, 'de', 'Navigation Frame', 'Navigationsfenster');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (40, 'de', 'Scale Select', 'Auswahl des Maßstabes');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (41, 'de', 'Scale Text', 'Maßstab per Texteingabe');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (42, 'de', 'Scalebar', 'Maßstabsleiste');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (43, 'de', 'Set Background', 'Hintegrundkarte auswählen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (44, 'de', 'Zoom to Coordinates', 'Zu den Koordinaten zoomen');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (45, 'de', 'Change Password', 'Passwort ändern');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (46, 'de', 'Load a web map context document', 'laden eines Web Map Context Dokumentes');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (47, 'de ', 'Logo', 'Logo');
-INSERT INTO translations (trs_id, locale, msgid, msgstr) VALUES (48, 'de', 'Measure distance', 'Streckenabschnittsmessung');
-- TOC entry 1882 (class 0 OID 5377313)
-- Dependencies: 1290
More information about the Mapbender_commits
