[Mapbender-commits] r2395 - in branches/2.5/http: classes
extensions javascripts php
svn_mapbender at osgeo.org
Fri Apr 18 10:46:52 EDT 2008
Author: christoph
Date: 2008-04-18 10:46:52 -0400 (Fri, 18 Apr 2008)
New Revision: 2395
Added:
branches/2.5/http/classes/class_json.php
branches/2.5/http/classes/class_gml2.php
branches/2.5/http/classes/class_kml_ows.php
branches/2.5/http/classes/class_kml_parser_ows.php
branches/2.5/http/classes/class_wfs_conf.php
branches/2.5/http/classes/class_wmc.php
branches/2.5/http/extensions/geom2wfst.php
branches/2.5/http/javascripts/mod_tab.php
branches/2.5/http/php/mod_addWMSfromfilteredList_server.php
branches/2.5/http/php/mod_button_tooltips.php
branches/2.5/http/php/mod_digitize_messages.php
branches/2.5/http/php/mod_gazetteerMetadata_search.php
branches/2.5/http/php/mod_gazetteerSQL_server.php
branches/2.5/http/php/mod_insertWmcIntoDb.php
branches/2.5/http/php/mod_tab_messages.php
branches/2.5/http/php/mod_wfsSpatialRequest_messages.php
branches/2.5/http/php/mod_wfs_gazetteer_server.php
branches/2.5/http/php/mod_wfs_server.php
http://trac.osgeo.org/mapbender/ticket/201
Modified: branches/2.5/http/classes/class_gml2.php
--- branches/2.5/http/classes/class_gml2.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/classes/class_gml2.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -18,7 +18,7 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once("class_mb_exception.php");
require_once("class_connector.php");
-require_once("../extensions/JSON.php");
+require_once("../classes/class_json.php");
require_once("../../conf/mapbender.conf");
class gml2 {
var $geomtype_point = 'Point';
@@ -500,7 +500,7 @@
$cnt ++;
- $json = new Services_JSON();
+ $json = new Mapbender_JSON();
$str .= $json->encode($prop);
$str .= "}";
Added: branches/2.5/http/classes/class_json.php
--- branches/2.5/http/classes/class_json.php (rev 0)
+++ branches/2.5/http/classes/class_json.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -0,0 +1,81 @@
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/JSON
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+mb_internal_encoding("UTF-8");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
+define("JSON_PEAR", "json_pear");
+define("JSON_NATIVE", "json_native");
+if (!function_exists("json_encode")) {
+ require_once(dirname(__FILE__)."/../classes/class_json.php");
+ * A wrapper class for PHP JSON encoding/decoding.
+ * Uses native PHP functions if available.
+ * @class
+class Mapbender_JSON {
+ * Either JSON_PEAR or JSON_NATIVE
+ private $library = JSON_PEAR;
+ * Determines which JSON lib to use.
+ * @constructor
+ public function __construct(){
+ if (function_exists("json_encode")) {
+ $this->library = JSON_NATIVE;
+ * Encodes an object to JSON
+ public function encode($anObject) {
+ if ($this->library == JSON_PEAR) {
+ $pear = new Mapbender_JSON();
+ $e = new mb_notice("using PEAR JSON");
+ return $pear->encode($anObject);
+ $e = new mb_notice("using native JSON");
+ return json_encode($anObject);
+ * Decodes a JSON string
+ public function decode($aString) {
+ return $pear->decode($aString);
+ return json_decode($aString);
\ No newline at end of file
Property changes on: branches/2.5/http/classes/class_json.php
___________________________________________________________________
+ HeadURL Id LastChangedBy LastChangedDate LastChangedRevision
Modified: branches/2.5/http/classes/class_kml_ows.php
--- branches/2.5/http/classes/class_kml_ows.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/classes/class_kml_ows.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -21,7 +21,7 @@
-require_once(dirname(__FILE__)."/../extensions/JSON.php");
+require_once(dirname(__FILE__)."/../classes/class_json.php");
require_once(dirname(__FILE__)."/../classes/class_point.php");
@@ -233,7 +233,7 @@
$kmlDoc_DOM->loadXML($kmlFromDb);
//load the geoJSON
$geoObj = $json->decode($geoJSON);
// construct an array that holds all metadata of the placemark
@@ -384,7 +384,7 @@
private function updateGeometry ($currentNode, $geometry) {
$currentNode_SimpleXML = simplexml_import_dom($currentNode);
$currentTypeXml = mb_strtoupper($currentNode->nodeName);
Modified: branches/2.5/http/classes/class_kml_parser_ows.php
--- branches/2.5/http/classes/class_kml_parser_ows.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/classes/class_kml_parser_ows.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -17,7 +17,7 @@
require_once(dirname(__FILE__)."/../classes/class_kml_polygon.php");
@@ -39,7 +39,7 @@
public function parseGeoJSON ($geoJSON, $kmlId) {
// $e = new mb_notice("GEOJSON: " . $geoJSON);
$geometryFromGeoJSON = $json->decode($geoJSON);
$id = 0;
Modified: branches/2.5/http/classes/class_wfs_conf.php
--- branches/2.5/http/classes/class_wfs_conf.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/classes/class_wfs_conf.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -20,7 +20,7 @@
require_once(dirname(__FILE__)."/class_mb_exception.php");
require_once(dirname(__FILE__)."/class_user.php");
require_once(dirname(__FILE__)."/class_administration.php");
class WfsConf {
var $confArray = array();
@@ -33,7 +33,7 @@
function __toString () {
return $json->encode($this->confArray);
Modified: branches/2.5/http/classes/class_wmc.php
--- branches/2.5/http/classes/class_wmc.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/classes/class_wmc.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -22,7 +22,7 @@
require_once(dirname(__FILE__) . "/../classes/class_layer_monitor.php");
require_once(dirname(__FILE__) . "/../classes/class_point.php");
require_once(dirname(__FILE__) . "/../classes/class_bbox.php");
-require_once(dirname(__FILE__) . "/../extensions/JSON.php");
+require_once(dirname(__FILE__) . "/../classes/class_json.php");
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
@@ -1090,7 +1090,7 @@
// general extension
if (count($this->wmc_general_extension) > 0) {
$wmc_string .= $target . "restoredWmcExtensionData = " . $json->encode($this->wmc_general_extension) . ";\n";
Modified: branches/2.5/http/extensions/geom2wfst.php
--- branches/2.5/http/extensions/geom2wfst.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/extensions/geom2wfst.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -27,7 +27,7 @@
require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
function isValidVarName ($varname) {
if (preg_match("/[\$]{1}_[a-z]+\[\"[a-z_]+\"\]/i", $varname) != 0) {
@@ -155,6 +155,6 @@
$notice = new mb_notice("response:".$response);
header("Content-Type:application/x-json");
-$json = new Services_JSON();
+$json = new Mapbender_JSON();
echo $json->encode($resObj);
Modified: branches/2.5/http/javascripts/mod_tab.php
--- branches/2.5/http/javascripts/mod_tab.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/javascripts/mod_tab.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -20,7 +20,7 @@
/********** Configuration*************************************************/
require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
include(dirname(__FILE__)."/../include/dyn_js.php");
$tab_ids = array();
@@ -37,7 +37,7 @@
echo "tab_titles[" . $i . "] = '" . $row["e_title"] . "';\n";
$output = $json->encode($tab_ids);
echo "var tab_ids = " . $output . ";";
Modified: branches/2.5/http/php/mod_addWMSfromfilteredList_server.php
--- branches/2.5/http/php/mod_addWMSfromfilteredList_server.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/php/mod_addWMSfromfilteredList_server.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -20,7 +20,7 @@
require_once(dirname(__FILE__)."/../classes/class_wms.php");
require_once(dirname(__FILE__)."/../classes/class_administration.php");
$userId = $_SESSION["mb_user_id"];
$command = $_GET["command"];
@@ -129,7 +129,7 @@
$output = $json->encode($resultObj);
echo $output;
Modified: branches/2.5/http/php/mod_button_tooltips.php
--- branches/2.5/http/php/mod_button_tooltips.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/php/mod_button_tooltips.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -18,7 +18,7 @@
$buttonObj = array();
@@ -31,7 +31,7 @@
array_push($buttonObj, array("id" => $row["e_id"], "title" => $row["e_title"]));
$output = $json->encode($buttonObj);
header("Content-type:text/plain; charset=utf-8");
Modified: branches/2.5/http/php/mod_digitize_messages.php
--- branches/2.5/http/php/mod_digitize_messages.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/php/mod_digitize_messages.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -18,7 +18,7 @@
$e = new mb_notice("locale: " . $_SESSION["mb_locale"] . "; lang: " . $_SESSION["mb_lang"]);
$e = new mb_notice(setlocale(LC_ALL, $_SESSION["mb_locale"]));
@@ -67,7 +67,7 @@
$msg_obj["measureTagLabelTotal"] = _mb("Total: ");
$msg_obj["digitizeDefaultGeometryName"] = _mb("new");
$output = $json->encode($msg_obj);
header("Content-type:application/x-json; charset=utf-8");
Modified: branches/2.5/http/php/mod_gazetteerMetadata_search.php
--- branches/2.5/http/php/mod_gazetteerMetadata_search.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/php/mod_gazetteerMetadata_search.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -1,7 +1,7 @@
<?php
$user_id = $_SESSION["mb_user_id"];
$query = $_REQUEST["search"];
@@ -69,7 +69,7 @@
array_push($obj, array('wms_getcapabilities' => $row['wms_getcapabilities'], 'wms_version' => $row['wms_version'], 'layer_name' => $row['layer_name'], 'layer_id' => $row['layer_id'], 'title' => $row['layer_title']));
$output = $json->encode($obj);
echo $output;
Modified: branches/2.5/http/php/mod_gazetteerSQL_server.php
--- branches/2.5/http/php/mod_gazetteerSQL_server.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/php/mod_gazetteerSQL_server.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -1,6 +1,6 @@
<?php
require_once(dirname(__FILE__)."/../../conf/gazetteerSQL.conf");
$con = pg_connect($connstring);
@@ -193,7 +193,7 @@
$e = new mb_exception("unknown command: " . $command);
echo $output;
Modified: branches/2.5/http/php/mod_insertWmcIntoDb.php
--- branches/2.5/http/php/mod_insertWmcIntoDb.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/php/mod_insertWmcIntoDb.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -20,9 +20,9 @@
require_once(dirname(__FILE__)."/../classes/class_wmc.php");
$mapObject = $json->decode(stripslashes($_POST["mapObject"]));
$save_in_session = $_POST["saveInSession"];
Modified: branches/2.5/http/php/mod_tab_messages.php
--- branches/2.5/http/php/mod_tab_messages.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/php/mod_tab_messages.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -18,7 +18,7 @@
@@ -38,7 +38,7 @@
Modified: branches/2.5/http/php/mod_wfsSpatialRequest_messages.php
--- branches/2.5/http/php/mod_wfsSpatialRequest_messages.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/php/mod_wfsSpatialRequest_messages.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -18,7 +18,7 @@
setlocale(LC_ALL, $_SESSION["mb_locale"]);
@@ -34,7 +34,7 @@
$msg_obj["buttonLabelDialogue"] = _mb("open dialogue form");
$msg_obj["errorMessageInvalidExtent"] = _mb("Invalid box!");
Modified: branches/2.5/http/php/mod_wfs_gazetteer_server.php
--- branches/2.5/http/php/mod_wfs_gazetteer_server.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/php/mod_wfs_gazetteer_server.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -19,7 +19,7 @@
require_once(dirname(__FILE__)."/../classes/class_gml2.php");
require_once(dirname(__FILE__)."/../classes/class_wfs_conf.php");
Modified: branches/2.5/http/php/mod_wfs_server.php
--- branches/2.5/http/php/mod_wfs_server.php 2008-04-18 08:54:22 UTC (rev 2394)
+++ branches/2.5/http/php/mod_wfs_server.php 2008-04-18 14:46:52 UTC (rev 2395)
@@ -2,9 +2,9 @@
require_once(dirname(__FILE__)."/../classes/class_wfs.php");
$obj = $json->decode(stripslashes($_REQUEST['obj']));
//workflow:
More information about the Mapbender_commits
