[Mapbender-commits] r2401 - branches/2.5/resources/db/postgresql
svn_mapbender at osgeo.org
Mon Apr 21 10:46:47 EDT 2008
Author: christoph
Date: 2008-04-21 10:46:46 -0400 (Mon, 21 Apr 2008)
New Revision: 2401
branches/2.5/resources/db/postgresql/pgsql_schema.sql
create plpgsql only if it is not existent
Modified: branches/2.5/resources/db/postgresql/pgsql_schema.sql
--- branches/2.5/resources/db/postgresql/pgsql_schema.sql 2008-04-21 13:15:21 UTC (rev 2400)
+++ branches/2.5/resources/db/postgresql/pgsql_schema.sql 2008-04-21 14:46:46 UTC (rev 2401)
@@ -2,6 +2,28 @@
-- PostgreSQL database dump Mapbender 2.5
+-- check if plpgsql exists; if yes, install it.
+CREATE OR REPLACE FUNCTION public.create_plpgsql_language ()
+ RETURNS TEXT
+ AS $$
+ CREATE LANGUAGE plpgsql;
+ SELECT 'language plpgsql created'::TEXT;
+LANGUAGE 'sql';
+SELECT CASE WHEN
+ (SELECT true::BOOLEAN
+ FROM pg_language
+ WHERE lanname='plpgsql')
+ THEN
+ (SELECT 'language already installed'::TEXT)
+ ELSE
+ (SELECT public.create_plpgsql_language())
+ END;
+DROP FUNCTION public.create_plpgsql_language ();
+-- function gettext for i18n (requires plpgsql)
CREATE FUNCTION gettext(locale_arg text, string text) RETURNS character varying
AS $$
DECLARE
More information about the Mapbender_commits
