[Mapbender-commits] r2418 - branches/2.5/http/php
svn_mapbender at osgeo.org
Fri Apr 25 05:51:33 EDT 2008
Author: verenadiewald
Date: 2008-04-25 05:51:32 -0400 (Fri, 25 Apr 2008)
New Revision: 2418
branches/2.5/http/php/mod_zoomCoords_en.php
some bug fixes: highlighting only if coords are set, target problem because of validateSession (replaced e_target[0] with e_target)
Modified: branches/2.5/http/php/mod_zoomCoords_en.php
--- branches/2.5/http/php/mod_zoomCoords_en.php 2008-04-23 20:31:28 UTC (rev 2417)
+++ branches/2.5/http/php/mod_zoomCoords_en.php 2008-04-25 09:51:32 UTC (rev 2418)
@@ -81,7 +81,7 @@
<?php
echo '<script type="text/javascript">';
-echo "var mod_zoomCoords_target = '".$e_target[0]."';";
+echo "var mod_zoomCoords_target = '".$e_target."';";
echo "var target = mod_zoomCoords_target.split(',');";
@@ -104,14 +104,14 @@
var valid = true;
/* if(parseFloat(coordx) < 5.88 || parseFloat(coordx) > 15){
- alert("Eingabe unzul�ssig!");
+ alert("Eingabe unzulässig!");
document.form1.X.select();
document.form1.X.focus();
valid = false;
return false;
if(parseFloat(coordy) < 46.62 || parseFloat(coordy) > 55.71){
document.form1.Y.select();
document.form1.Y.focus();
valid = false;
@@ -128,20 +128,21 @@
function highlight(x, y){
- x=x.replace(",",".");
- y=y.replace(",",".");
- document.form1.X.value=x;
- document.form1.Y.value=y;
- if (isNaN(x)==true || isNaN(y)==true){
- else{
- parent.mb_showHighlight(target[0],x,y);
- parent.mb_showHighlight(target[1],x,y);
+ if(x!='' && y!=''){
+ x=x.replace(",",".");
+ y=y.replace(",",".");
+ document.form1.X.value=x;
+ document.form1.Y.value=y;
+ if (isNaN(x)==true || isNaN(y)==true){
+ else{
+ parent.mb_showHighlight(target[0],x,y);
+ parent.mb_showHighlight(target[1],x,y);
function hideHighlight(){
@@ -171,7 +172,7 @@
echo "<span class='labely'>Y-Coordinate:</span>";
echo "<input class='textx' type='text' name='X'>";
echo "<input class='texty' type='text' name='Y'>";
- echo "<input class='send' type='button' value='ok' onclick='zoomCoordinate();' onmouseover='highlight(document.form1.X.value, document.form1.Y.value)' onmouseout='hideHighlight(document.form1.X.value, document.form1.Y.value)' >";
+ echo "<input class='send' type='button' value='ok' onclick='zoomCoordinate();' onmouseover='highlight(document.form1.X.value, document.form1.Y.value)' onmouseout='if(document.form1.X.value !=\"\" && document.form1.Y.value !=\"\"){hideHighlight(document.form1.X.value, document.form1.Y.value);}' >";
</form>
More information about the Mapbender_commits
