[Mapbender-commits] r2851 - branches/nimix_dev/http/javascripts
svn_mapbender at osgeo.org
Mon Aug 18 10:31:43 EDT 2008
Author: nimix
Date: 2008-08-18 10:31:43 -0400 (Mon, 18 Aug 2008)
New Revision: 2851
Added:
branches/nimix_dev/http/javascripts/map_obj.js
Removed:
branches/nimix_dev/http/javascripts/mod_addWMSfromList.php
branches/nimix_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php
branches/nimix_dev/http/javascripts/mod_addWMSgeneralFunctions.js
branches/nimix_dev/http/javascripts/mod_adminNavigation.js
branches/nimix_dev/http/javascripts/mod_box1.js
merge
Deleted: branches/nimix_dev/http/javascripts/map_obj.js
--- branches/nimix_dev/http/javascripts/map_obj.js 2008-08-18 14:22:50 UTC (rev 2850)
+++ branches/nimix_dev/http/javascripts/map_obj.js 2008-08-18 14:31:43 UTC (rev 2851)
@@ -1,776 +0,0 @@
-* $Id$
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-//global variables
-var wms = [];
-var wms_layer_count = 0;
- * global function to add wms to the wms-object
- * @param {String} wms_id the unique id of the wms
- * @param {String} wms_version the version assumed from capabilities
- * @param {String} wms_title the title of the wms
- * @param {String} wms_abstract the abstract of the wms
- * @param {String} wms_getmap the url for map requests
- * @param {String} wms_getfeatureinfo the url for featureInof requests
- * @param {String} wms_getlegendurl the url for legend requests
- * @param {String} wms_filter a filter (deprecated)
- * @param {String} gui_wms_mapformat the image-format in the actual gui
- * @param {String} gui_wms_featureinfoformat the current format for featureInfos
- * @param {String} gui_wms_exceptionformat the exceptionformat for map requests
- * @param {String} gui_wms_epsg the current srs
- * @param {Integer} gui_wms_visible the visibility of this service
- * @param {Integer} gui_wms_opacity the initial display opacity in percent
- * @param {String} gui_wms_sldurl url to an actual sld
-function add_wms(
- wms_id,
- wms_version,
- wms_title,
- wms_abstract,
- wms_getmap,
- wms_getfeatureinfo,
- wms_getlegendurl,
- wms_filter,
- gui_wms_mapformat,
- gui_wms_featureinfoformat,
- gui_wms_exceptionformat,
- gui_wms_epsg,
- gui_wms_visible,
- gui_wms_opacity,
- gui_wms_sldurl){
- wms[wms.length] = new wms_const(
- wms_id,
- wms_version,
- wms_title,
- wms_abstract,
- wms_getmap,
- wms_getlegendurl,
- wms_filter,
- gui_wms_epsg,
- parseInt(gui_wms_visible, 10),
- parseInt(gui_wms_opacity),
- gui_wms_sldurl);
- wms_layer[wms.length - 1] = [];
- * @class A class representing the wms
- * @constructor
- * @param {String} gui_wms_visible the visibility of this service
-function wms_const(
- wms_id,
- wms_version,
- wms_title,
- wms_abstract,
- wms_getmap,
- wms_getlegendurl,
- wms_filter,
- gui_wms_epsg,
- gui_wms_visible,
- gui_wms_opacity,
- gui_wms_sldurl){
- if (!wms_id) {
- var id_ok = false;
- while (id_ok === false) {
- wms_id = "a"+Math.round(10000*Math.random());
- id_ok = true;
- for (var i=0; i < wms.length && id_ok === true; i++) {
- if (wms_id == wms[i].wms_id) {
- id_ok = false;
- this.wms_id = wms_id;
- this.wms_version = wms_version;
- this.wms_title = wms_title;
- this.wms_abstract = wms_abstract;
- this.wms_getmap = wms_getmap;
- this.wms_getfeatureinfo = wms_getfeatureinfo;
- this.wms_getlegendurl = wms_getlegendurl;
- this.wms_filter = wms_filter;
- this.data_type = [];
- this.data_format = [];
- this.objLayer = [];
- this.gui_wms_mapformat = gui_wms_mapformat;
- this.gui_wms_featureinfoformat = gui_wms_featureinfoformat;
- this.gui_wms_exceptionformat = gui_wms_exceptionformat;
- this.gui_wms_epsg = gui_wms_epsg;
- this.gui_wms_visible = gui_wms_visible;
- this.gui_epsg = [];
- this.gui_minx = [];
- this.gui_miny = [];
- this.gui_maxx = [];
- this.gui_maxy = [];
- // opacity version
- this.gui_wms_mapopacity = gui_wms_opacity/100;
- // sld version
- this.gui_wms_sldurl = gui_wms_sldurl;
- * rephrases the mapRequest
- * @param {Object} mapObj the mapbender mapObject of the wms
- * @return mapRequest, i.e. onlineresource + params
- * @type String
-wms_const.prototype.getMapRequest = function(mapObj){
- //check visible layers first
- var layers = this.getLayers(mapObj);
- if(!layers){
- return false;
- var rq = this.wms_getmap;
- rq += mb_getConjunctionCharacter(this.wms_getmap);
- if(this.wms_version === "1.0.0"){
- rq += "WMTVER=" + this.wms_version + "&REQUEST=map";
- else{
- rq += "VERSION=" + this.wms_version + "&REQUEST=getMap&SERVICE=WMS";
- rq += "&LAYERS=" + layers.join(",");
- rq += "&WIDTH=" + mapObj.getWidth();
- rq += "&HEIGHT=" + mapObj.getHeight();
- rq += "&SRS=" + mapObj.getSRS();
- rq += "&BBOX=" + mapObj.getExtent();
- rq += "&STYLES=" + this.getLayerstyles(mapObj).join(",");
- rq += "&FORMAT=" + this.gui_wms_mapformat;
- rq += "&EXCEPTIONS=" + this.gui_wms_exceptionformat;
- //Todo: error occurs:
- //var throwNotice = new Mb_notice("getMapRequest: " + rq);
- //window.console.log("getMapRequest: " + rq);
- return rq;
- * rephrases the featureInfoRequest
- * @param {Point} clickPoint map-click position {@link Point}
- * @return featureInfoRequest, onlineresource + params
- * @type string
-wms_const.prototype.getFeatureInfoRequest = function(mapObj, clickPoint){
- //check layers and querylayers first
- var querylayers = this.getQuerylayers(mapObj);
- if(!layers || !querylayers){
- return false;
- var rq = this.wms_getfeatureinfo;
- rq += mb_getConjunctionCharacter(this.wms_getfeatureinfo);
- rq += "WMTVER=" + this.wms_version + "&REQUEST=feature_info";
- else{
- rq += "VERSION=" + this.wms_version + "&REQUEST=GetFeatureInfo&SERVICE=WMS";
- rq += "&QUERY_LAYERS=" + querylayers.join(",");
- rq += "&INFO_FORMAT=" + this.gui_wms_featureinfoformat;
- rq += "&EXCEPTIONS=application/vnd.ogc.se_xml";
- rq += "&X=" + clickPoint.x;
- rq += "&Y=" + clickPoint.y;
- //console.log(rq);
- return rq;
- * sets Opacity of WMS
- * @param {Integer} new opacity percentage value
-wms_const.prototype.setOpacity = function(opacity){
- //calc new opacity
- this.gui_wms_mapopacity = parseInt(opacity)/100;
- if(this.gui_wms_mapopacity>1||isNaN(this.gui_wms_mapopacity))
- this.gui_wms_mapopacity=1;
- if(this.gui_wms_mapopacity<0)
- this.gui_wms_mapopacity=0;
- if (this.gui_wms_visible > 0) {
- //get div id
- var divId = null;
- for (var i=0; i < wms.length; i++) {
- if (this.wms_id == wms[i].wms_id) {
- var divId = 'div_'+i;
- break;
- if(!divId)
- return;
- //TODO: check if mapframe1 is the right mapframe
- wmsImage = parent.mapframe1.document.getElementById(divId);
- if (wmsImage != null) {
- wmsImage.style.opacity = this.gui_wms_mapopacity;
- wmsImage.style.MozOpacity = this.gui_wms_mapopacity;
- wmsImage.style.KhtmlOpacity = this.gui_wms_mapopacity;
- wmsImage.style.filter = "alpha(opacity=" + this.gui_wms_mapopacity*100 + ")";
- * get all visible layers
- * @return array of layernames
- * @type string[]
-wms_const.prototype.getLayers = function(mapObj){
- try {
- //visibility of the wms
- var wmsIsVisible = (this.gui_wms_visible > 0);
- if(!wmsIsVisible){
- return false;
- visibleLayers = [];
- for(var i=0; i< this.objLayer.length; i++){
- var isVisible = (this.objLayer[i].gui_layer_visible === 1);
- var hasNoChildren = (!this.objLayer[i].has_childs);
- if (isVisible && hasNoChildren){
- if(this.objLayer[i].checkScale(mapObj)){
- //console.log("checkLayer: " + this.objLayer[i].layer_name);
- visibleLayers.push(this.objLayer[i].layer_name);
- if(visibleLayers.length === 0){
- return false;
- return visibleLayers;
- catch (e) {
- alert(e);
- * get the actual style of all visible layers
- * @return commaseparated list of actual layerstyles
- * @type string
-wms_const.prototype.getLayerstyles = function(mapObj){
- var layerstyles = '';
- var styles = [];
- if(layers){
- for(i = 0; i < layers.length; i++){
- var style = this.getCurrentStyleByLayerName(layers[i]);
- if(!style){
- style = '';
- styles.push(style);
- return styles;
- return false;
- * check if layer is parentLayer
- * @param layername
- * @return the parent value of the given layer
- * @type integer
-wms_const.prototype.checkLayerParentByLayerName = function(layername){
- if(this.objLayer[i].layer_name == layername){
- return this.objLayer[i].layer_parent;
- * get the title of the current layer
- * @return the title of the given layer
- * @type string
-wms_const.prototype.getTitleByLayerName = function(layername){
- return this.objLayer[i].layer_title;
- * get the current style of the layer
- * @return the stylename of the given layer
- * @type string
-wms_const.prototype.getCurrentStyleByLayerName = function(layername){
- if(this.objLayer[i].gui_layer_style === '' || this.objLayer[i].gui_layer_style === null){
- return false;
- else{
- return this.objLayer[i].gui_layer_style;
- * get the legendurl of the gui layer style
- * @param stylename
- * @return the legendurl of the given style
- * @type string
-wms_const.prototype.getLegendUrlByGuiLayerStyle = function(layername,guiLayerStyle){
- if(this.objLayer[i].layer_style.length === 0){
- return false;
- for(var k=0; k< this.objLayer[i].layer_style.length; k++){
- if(this.objLayer[i].layer_style[k].name == guiLayerStyle){
- var legendUrl = this.objLayer[i].layer_style[k].legendurl;
- if (this.gui_wms_sldurl !== "") {
- legendUrl += "&SLD="+escape(this.gui_wms_sldurl);
- if(legendUrl !=='' && legendUrl !== null && typeof(legendUrl) != 'undefined'){
- return legendUrl;
- else {
- return false;
- return false;
- * get all querylayers
- * @type string[]
-wms_const.prototype.getQuerylayers = function(){
- queryLayers = [];
- if(this.objLayer[i].gui_layer_querylayer === 1 && ! this.objLayer[i].has_childs ){
- queryLayers.push(this.objLayer[i].layer_name);
- if(queryLayers.length === 0){
- return false;
- return queryLayers;
- * get a layer Object by layer_pos
- * @param int payer_pos layer_pos of layer you want to get
- * @return object layer
-wms_const.prototype.getLayerByLayerPos = function(layer_pos){
- for(var i=0;i<this.objLayer.length;i++){
- if(this.objLayer[i].layer_pos == layer_pos) {
- return this.objLayer[i];
- return null;
- * get the state of sublayers from a specified layer
- * @param int layer_id of the parent layer
- * @param String type "visible" or "querylayer"
- * @return int -1 if state differs else the state
-wms_const.prototype.getSublayerState = function(layer_id, type){
- var i;
- var state=-1,value;
- for(i = 0; i < this.objLayer.length; i++){
- if(this.objLayer[i].layer_id==layer_id) {
- break;
- //go throught sublayers
- for(var j = i+1; j < this.objLayer.length; j++){
- if(this.objLayer[i].parent_layer == this.objLayer[j].parent_layer) {
- break;
- if(type == "visible") {
- value = this.objLayer[j].gui_layer_visible;
- else if(type == "querylayer") {
- value = this.objLayer[j].gui_layer_querylayer;
- if(state == -1) {
- state = value;
- if(state != value) {
- return -1;
- return state;
- * handle change of visibility / quaryability of a layer
- * @param string layer_name of layer to handle
- * @param string type of change ("visible" or "querylayer")
- * @param int value of the change
-wms_const.prototype.handleLayer = function(layer_name, type, value){
- var i;
- if(this.objLayer[i].layer_name==layer_name) {
- break;
- //Set visibility/queryability of Layer and Sublayers
- for(var j = i; j < this.objLayer.length; j++){
- if (i != j && this.objLayer[i].layer_parent >= this.objLayer[j].layer_parent) {
- break;
- this.objLayer[j].gui_layer_visible = parseInt(value, 10);
- else if(type=="querylayer") {
- this.objLayer[j].gui_layer_querylayer = parseInt(value, 10);
- //Update visibility/queryability of parent layer
- var parentLayer = this.getLayerByLayerPos(this.objLayer[i].layer_parent);
- if(parentLayer){
- var state = this.getSublayerState(parentLayer.layer_id, type);
- if(state!=-1){
- this.objLayer[j].gui_layer_visible = state;
- this.objLayer[j].gui_layer_querylayer = state;
- * move a layer (with his sublayers) up or down
- * @param int layerId layer_id of layer to move
- * @param boolean moveUp true to move up or false to move down
- * @return boolean success
-wms_const.prototype.moveLayer = function(layerId, moveUp){
- var iLayer=-1;
- var i;
- //find layer to move
- for(i=0;i<this.objLayer.length;i++){
- if(this.objLayer[i].layer_id==layerId){
- iLayer=i;
- break;
- if(iLayer==-1) {
- return false;
- var upperLayer = -1;
- var lowerLayer = -1;
- //find layer to swap position with
- var parentLayer = this.objLayer[iLayer].layer_parent;
- if(moveUp){
- lowerLayer = iLayer;
- //find previous layer on same level
- for(i=iLayer-1;i>0;i--){
- if(parentLayer == this.objLayer[i].layer_parent){
- upperLayer = i;
- break;
- if(upperLayer == -1){
- //alert("The Layer you selected is already on top of parent Layer/WMS");
- return false;
- else{
- upperLayer = iLayer;
- //find next layer on same level
- for(i=iLayer+1;i<this.objLayer.length;i++){
- lowerLayer = i;
- break;
- if(lowerLayer == -1){
- //alert("The Layer you selected is already on bottom of parent Layer/WMS");
- return false;
- //calc number of layers to move down
- var layersDown = lowerLayer - upperLayer;
- //get number of layers to move up
- for(i=lowerLayer+1; i<this.objLayer.length; i++){
- break;
- var layersUp = i - lowerLayer;
- //do moving
- var temp = [];
- for(i=0;i<layersDown+layersUp;i++){
- temp[temp.length]=this.objLayer[upperLayer+i];
- for(i=0;i<layersUp;i++){
- this.objLayer[upperLayer+i]=temp[i+layersDown];
- for(i=0;i<layersDown;i++){
- this.objLayer[upperLayer+layersUp+i]=temp[i];
- return true;
-function wms_add_data_type_format(datatype,dataformat){
- var insertDataFormat = true;
- for (var i = 0 ; i < wms[wms.length-1].data_type.length ; i ++) {
- if (wms[wms.length-1].data_type[i] == datatype && wms[wms.length-1].data_format[i] == dataformat) {
- insertDataFormat = false;
- if (insertDataFormat === true) {
- wms[wms.length-1].data_type[wms[wms.length-1].data_type.length] = datatype;
- wms[wms.length-1].data_format[wms[wms.length-1].data_format.length] = dataformat;
-function wms_addSRS(epsg,minx,miny,maxx,maxy){
- wms[wms.length-1].gui_epsg[wms[wms.length-1].gui_epsg.length] = epsg;
- wms[wms.length-1].gui_minx[wms[wms.length-1].gui_minx.length] = minx;
- wms[wms.length-1].gui_miny[wms[wms.length-1].gui_miny.length] = miny;
- wms[wms.length-1].gui_maxx[wms[wms.length-1].gui_maxx.length] = maxx;
- wms[wms.length-1].gui_maxy[wms[wms.length-1].gui_maxy.length] = maxy;
-function wms_addLayerStyle(styleName, styleTitle, count, layerCount, styleLegendUrl, styleLegendUrlFormat){
- var currentLayer = wms[wms.length-1].objLayer[layerCount];
- if (currentLayer) {
- currentLayer.layer_style[count] = {};
- currentLayer.layer_style[count].name = styleName;
- currentLayer.layer_style[count].title = styleTitle;
- currentLayer.layer_style[count].legendurl = styleLegendUrl;
- currentLayer.layer_style[count].legendurlformat = styleLegendUrlFormat;
-//TODO: add layerstyle handling....
-//layer
-function wms_add_layer(
- layer_parent,
- layer_uid,
- layer_name,
- layer_title,
- layer_dataurl_href,
- layer_pos,
- layer_queryable,
- layer_minscale,
- layer_maxscale,
- layer_metadataurl,
- gui_layer_wms_id,
- gui_layer_status,
- gui_layer_style,
- gui_layer_selectable,
- gui_layer_visible,
- gui_layer_queryable,
- gui_layer_querylayer,
- gui_layer_minscale,
- gui_layer_maxscale,
- gui_layer_wfs_featuretype){
- wms[wms.length-1].objLayer[wms[wms.length-1].objLayer.length] = new wms_layer(
- layer_parent,
- layer_uid,
- layer_name,
- layer_title,
- layer_pos,
- layer_queryable,
- layer_minscale,
- layer_maxscale,
- gui_layer_wms_id,
- gui_layer_status,
- gui_layer_style,
- parseInt(gui_layer_selectable, 10),
- parseInt(gui_layer_visible, 10),
- parseInt(gui_layer_queryable, 10),
- parseInt(gui_layer_querylayer, 10),
- parseInt(gui_layer_minscale, 10),
- parseInt(gui_layer_maxscale, 10),
- gui_layer_wfs_featuretype );
- var parentLayer = wms[wms.length-1].getLayerByLayerPos(parseInt(layer_parent, 10));
- if(parentLayer) {
- parentLayer.has_childs = true;
-function layer_addEpsg(epsg,minx,miny,maxx,maxy){
- var j = wms[wms.length-1].objLayer.length-1;
- var k = wms[wms.length-1].objLayer[j].layer_epsg.length;
- var currentLayer = wms[wms.length-1].objLayer[j];
- currentLayer.layer_epsg[k]={};
- currentLayer.layer_epsg[k].epsg = epsg;
- currentLayer.layer_epsg[k].minx = minx;
- currentLayer.layer_epsg[k].miny = miny;
- currentLayer.layer_epsg[k].maxx = maxx;
- currentLayer.layer_epsg[k].maxy = maxy;
-function wms_layer(
- layer_parent,
- wms_layer_uid,
- layer_name,
- layer_title,
- layer_pos,
- layer_queryable,
- layer_minscale,
- layer_maxscale,
- gui_layer_wms_id,
- gui_layer_status,
- gui_layer_style,
- this.layer_id = wms_layer_count;
- this.layer_uid = wms_layer_uid;
- this.layer_parent = layer_parent;
- this.layer_name = layer_name;
- this.layer_title = layer_title;
- this.layer_dataurl_href = layer_dataurl_href;
- this.layer_pos = layer_pos;
- this.layer_queryable = layer_queryable;
- this.layer_minscale = layer_minscale;
- this.layer_maxscale = layer_maxscale;
- this.layer_metadataurl = layer_metadataurl;
- this.layer_epsg = [];
- this.gui_layer_wms_id = gui_layer_wms_id;
- this.gui_layer_status = gui_layer_status;
- this.gui_layer_selectable = gui_layer_selectable;
- this.gui_layer_visible = gui_layer_visible;
- this.gui_layer_queryable = gui_layer_queryable;
- this.gui_layer_querylayer = gui_layer_querylayer;
- this.gui_layer_minscale = gui_layer_minscale;
- this.gui_layer_maxscale = gui_layer_maxscale;
- this.gui_layer_style = gui_layer_style;
- this.gui_layer_wfs_featuretype = gui_layer_wfs_featuretype;
- this.gui_layer_style = null;
- this.has_childs = false;
- this.layer_style = [];
- wms_layer_count++;
- * check the scale of the layer
- * @param Object mapObj the mapbender mapObject of the layer
- * @return boolean if the layer is in scale or not
- * @type boolean
-wms_layer.prototype.checkScale = function(mapObj){
- var minScale = parseInt(this.gui_layer_minscale, 10);
- var maxScale = parseInt(this.gui_layer_maxscale, 10);
- var currentScale = parseInt(mapObj.getScale(), 10);
- if(minScale === 0 && maxScale === 0){
- return true;
- if(minScale > currentScale || (maxScale !== 0 && maxScale < currentScale)) {
- return false;
- return true;
- * set visibility of the layer
- * @param boolean visible visibility on/off
-wms_layer.prototype.setVisible = function(visible){
- this.gui_layer_visible = parseInt(visible, 10);
- //console.log("setVisible(%i) for Layer %s",visible, this.layer_name);
- * set queryability of the layer
- * @param boolean queryable queryability on/off
-wms_layer.prototype.setQueryable = function(queryable){
- this.gui_layer_querylayer = parseInt(queryable, 10);
- //console.log("setQueryable(%i) for Layer %s",queryable, this.layer_name);
\ No newline at end of file
Copied: branches/nimix_dev/http/javascripts/map_obj.js (from rev 2653, trunk/mapbender/http/javascripts/map_obj.js)
--- branches/nimix_dev/http/javascripts/map_obj.js (rev 0)
@@ -0,0 +1,404 @@
+* $Id: map_obj.js 2517 2008-06-19 16:40:00Z christoph $
+* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
+* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
+var mb_mapObj = [];
+function mb_mapObj_const(frameName, elementName, width, height, wms_index){
+ this.width = width;
+ this.height = height;
+ this.frameName = frameName;
+ this.elementName = elementName;
+ this.layers = [];
+ this.styles = [];
+ this.querylayers = [];
+ this.geom = "";
+ this.gml = "";
+ this.wms = [];
+ // Add pointers to WMS objects which are in this map.
+ // If wms_index is set (=map is overview), only this
+ // WMS is being pointed to.
+ var index = 0;
+ for(var i=0; i < wms.length; i++){
+ var isValidWms = (wms_index === null) || (wms_index == i);
+ if (isValidWms) {
+ this.wms[index] = wms[i];
+ this.wms[index].mapURL = false;
+ index++;
+ // set list of visible layers, active querylayers
+ // and styles for each WMS in this map
+ var cnt_layers;
+ var cnt_querylayers;
+ var styles;
+ var layers;
+ var querylayers = "";
+ for(i=0; i< this.wms.length; i++){
+ cnt_layers = 0;
+ cnt_querylayers = 0;
+ styles = "";
+ layers = "";
+ querylayers = "";
+ for(var ii=0; ii<this.wms[i].objLayer.length; ii++){
+ // layer is visible and not root layer
+ if(this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii>0){
+ if(cnt_layers > 0){
+ layers += ","; styles += ",";
+ layers += wms[i].objLayer[ii].layer_name;
+ styles += "";
+ cnt_layers++;
+ // layer is queryable and not root layer
+ if(this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
+ if(cnt_querylayers > 0){
+ querylayers += ",";
+ querylayers += wms[i].objLayer[ii].layer_name;
+ cnt_querylayers++;
+ this.layers[i] = layers;
+ this.styles[i] = styles;
+ this.querylayers[i] = querylayers;
+ this.epsg = wms[0].gui_wms_epsg;
+ this.extent = setExtent(this.width,this.height,this.epsg);
+ this.mapURL = [];
+ var styleTag = window.frames[this.frameName].document.getElementById(this.elementName).style;
+ styleTag.width = this.width;
+ styleTag.height = this.height;
+ * get the width of the mapObj
+ * @member mb_mapObj_const
+ * @return width of the mapObj
+ * @type integer
+ this.getWidth = function(){
+ return parseInt(this.width, 10);
+ * set the width of the mapObj
+ * @param {integer} widht the width of the mapObj
+ this.setWidth = function(width){
+ this.width = parseInt(width, 10);
+ * get the height of the mapObj
+ * @type integer
+ this.getHeight = function(){
+ return parseInt(this.height, 10);
+ * set the height of the mapObj
+ * @param {integer} height the height of the mapObj
+ this.setHeight = function(height){
+ this.height = parseInt(height, 10);
+ * get the extent of the mapObj
+ * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
+ * @type string
+ this.getExtent = function(){
+ return this.extent;
+ * get the extent as minx, maxx, miny, maxy
+ * @return extent and additional informations of the mapObj
+ * @type Object
+ this.getExtentInfos = function(){
+ var c = this.getExtent().split(",");
+ var ext = new Extent(c[0],c[1],c[2],c[3]);
+ return ext;
+ * converts the extent of the mapobject so that the maximum extent will be displayed
+ this.calculateExtent = function(ext){
+ var relation_px_x = this.getWidth() / this.getHeight();
+ var relation_px_y = this.getHeight() / this.getWidth();
+ var relation_bbox_x = ext.extentx / ext.extenty;
+ if(relation_bbox_x <= relation_px_x){
+ ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
+ ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
+ if(relation_bbox_x > relation_px_x){
+ ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
+ ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
+ this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
+ * zoom the map with a zoomfactor and optional to x,y coords
+ * @param {boolean} in_ in = true, out = false
+ * @param {float} factor the zoomfactor 1 equals 100%
+ * @param {float} x center to x-position
+ * @param {float} y center to y-position
+ this.zoom = function(in_, factor, x, y){
+ factor = parseFloat(factor);
+ if (!in_) {
+ factor = 1 / factor;
+ var extent = this.getExtentInfos();
+ var distx = extent.maxx - extent.minx;
+ var disty = extent.maxy - extent.miny;
+ if(x && y){
+ var centerx = parseFloat(x);
+ var centery = parseFloat(y);
+ else{
+ var centerx = extent.minx + distx/2;
+ var centery = extent.miny + disty/2;
+ var new_distx = distx / factor;
+ var new_disty = disty / factor;
+ var minx = centerx - new_distx / 2;
+ var miny = centery - new_disty / 2;
+ var maxx = centerx + new_distx / 2;
+ var maxy = centery + new_disty / 2;
+ this.setExtent(minx,miny,maxx,maxy);
+ //Todo:
+ //setMapRequest!
+ * set the extent of the wms
+ this.setExtent = function(minx,miny,maxx,maxy){
+ this.extent = String(minx)+","+String(miny)+","+String(maxx)+","+String(maxy);
+ * get the srs of the mapObj
+ * @return srs as epsg:number
+ * @type string
+ this.getSRS = function(){
+ return this.epsg;
+ * get all mapRequests
+ * @return array of mapRequests of this map object
+ * @type string[]
+ this.getMapRequests = function(){
+ var allRequests = [];
+ //loop through all wms to get the mapRequests
+ for(var i=0; i<this.wms.length; i++){
+ var currentRequest = this.wms[i].getMapRequest(this);
+ if(currentRequest){
+ allRequests.push(currentRequest);
+ if(allRequests.length > 0){
+ return allRequests;
+ return false;
+ * Return the map URL of the WMS at index i
+ * @param {Object} currentWmsIndex
+ this.getMapUrl = function (i, ii) {
+ var currentWms = this.wms[ii];
+ var validLayers = currentWms.getLayers(this);
+ var layerNames = validLayers.join(",");
+ url = currentWms.wms_getmap;
+ url += mb_getConjunctionCharacter(currentWms.wms_getmap);
+ if (currentWms.wms_version == "1.0.0") {
+ url += "WMTVER=" + currentWms.wms_version + "&REQUEST=map&";
+ else {
+ url += "VERSION=" + currentWms.wms_version + "&REQUEST=GetMap&SERVICE=WMS&";
+ url += "LAYERS=" + layerNames + "&";
+ url += "STYLES=";
+ var layer = layerNames.split(",");
+ for (var j = 0; j < layer.length; j++){
+ if (j > 0) {
+ url += ",";
+ if (currentWms.getCurrentStyleByLayerName(layer[j]) !== false) {
+ url += currentWms.getCurrentStyleByLayerName(layer[j]);
+ url += "&";
+ url += "SRS=" + this.epsg + "&";
+ url += "BBOX=" + this.extent + "&";
+ url += "WIDTH=" + this.width + "&";
+ url += "HEIGHT=" + this.height + "&";
+ url += "FORMAT=" + currentWms.gui_wms_mapformat + "&";
+ url += "BGCOLOR=0xffffff&";
+ if (currentWms.gui_wms_mapformat.search(/gif/i)>-1 ||
+ currentWms.gui_wms_mapformat.search(/png/i)>-1) {
+ url += "TRANSPARENT=TRUE&";
+ url += "EXCEPTIONS=" + currentWms.gui_wms_exceptionformat + "&";
+ // add vendor-specific
+ for (var v = 0; v < mb_vendorSpecific.length; v++) {
+ var vendorSpecificString = eval(mb_vendorSpecific[v]);
+ // if eval doesn't evaluate a function, the result is undefined.
+ // Sometimes it is necessary not to evaluate a function, for
+ // example if you want to change a variable from the current
+ // scope (see mod_addSLD.php)
+ if (typeof(vendorSpecificString) != "undefined") {
+ url += vendorSpecificString + "&";
+ // add Filter
+ if (currentWms.wms_filter !== ""){
+ url += "&SLD=" + currentWms.wms_filter +"?id="+ mb_styleID + "&";
+ // add sld
+ if(currentWms.gui_wms_sldurl !== ""){
+ url += "&SLD=" + escape(currentWms.gui_wms_sldurl) + "&";
+ return url;
+ * get all featureInfoRequests
+ * @param float x the x-value of the click position in pixel
+ * @param float y the y-value of the click position in pixel
+ * @return array of all featureInfoRequests of this map object
+ * @type string[]
+ this.getFeatureInfoRequests = function(clickPoint){
+ //loop through all wms to get the FeatureInfoRequests
+ var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
+ return false;
+ * calculation of the mapscale
+ * @return scale
+ * @type integer
+ this.getScale = function(){
+ var scale;
+ var bbox = this.extent.split(",");
+ var xtenty;
+ if(this.epsg=="EPSG:4326"){
+ var pxLenx = (parseFloat(bbox[2])-parseFloat(bbox[0]))/this.width;
+ var pxLeny = (parseFloat(bbox[3])-parseFloat(bbox[1]))/this.height;
+ var lat_from = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2)*Math.PI)/180;
+ var lat_to = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2+pxLeny)*Math.PI)/180;
+ var lon_from = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2)*Math.PI)/180;
+ var lon_to = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2+pxLeny)*Math.PI)/180;
+ var dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));
+ scale = (dist/Math.SQRT2) * (mb_resolution * 100);
+ }else{
+ xtenty = parseFloat(bbox[3]) - parseFloat(bbox[1]);
+ scale = (xtenty / this.height) * (mb_resolution * 100);
+ return Math.round(scale);
+ * move a wms or layer
+ * @param int wms_id id of wms to move
+ * @param int layer_id id of layer to move
+ * @return true of successful
+ * @type boolean
+ this.move = function(wms_id, layer_id, moveUp){
+ var i,j;
+ for(i=0;i<this.wms.length;i++){
+ if (wms_id == this.wms[i].wms_id) {
+ break;
+ //check if only one wms is affected?
+ if (layer_id && layer_id != this.wms[i].objLayer[0].layer_id) {
+ return this.wms[i].moveLayer(layer_id, moveUp);
+ //else swap wms
+ j = i + (moveUp?-1:1);
+ if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length)) {
+ return false;
+ upper = this.wms[i];
+ this.wms[i] = this.wms[j];
+ this.wms[j] = upper;
+ var upperLayers = this.layers[i];
+ var upperStyles = this.styles[i];
+ var upperQuerylayers = this.querylayers[i];
+ this.layers[i] = this.layers[j];
+ this.styles[i] = this.styles[j];
+ this.querylayers[i] = this.querylayers[j];
+ this.layers[j] = upperLayers;
+ this.styles[j] = upperStyles;
+ this.querylayers[j] = upperQuerylayers;
+ return true;
+ eventAfterMapObjectConstruction.trigger();
Modified: branches/nimix_dev/http/javascripts/mod_addWMSfromList.php
--- branches/nimix_dev/http/javascripts/mod_addWMSfromList.php 2008-08-18 14:22:50 UTC (rev 2850)
+++ branches/nimix_dev/http/javascripts/mod_addWMSfromList.php 2008-08-18 14:31:43 UTC (rev 2851)
@@ -53,6 +53,10 @@
+function mod_addWMSfromDB(gui_id, wms_id) {
+ window.opener.mod_addWMSById_load(gui_id, wms_id);
</script>
@@ -145,7 +149,7 @@
/*get allocated wms from allocated gui ********************************************************************************************/
/*get allocated wms-Abstract and wms-Capabilities from allocated gui ********************************************************************************************/
-$sql_wms = "SELECT DISTINCT wms_title, wms_abstract, wms_getcapabilities,wms_version FROM wms WHERE wms_id IN (";
+$sql_wms = "SELECT DISTINCT wms_id, wms_title, wms_abstract, wms_getcapabilities,wms_version FROM wms WHERE wms_id IN (";
$v = $fkey_wms_id;
$t = array();
for ($i = 1; $i <= count($fkey_wms_id); $i++){
@@ -160,6 +164,7 @@
$res_wms = db_prep_query($sql_wms, $v, $t);
while($row = db_fetch_array($res_wms)){
+ $wms_id[$cnt_wms] = $row["wms_id"];
$wms_title[$cnt_wms] = $row["wms_title"];
$wms_abstract[$cnt_wms] = $row["wms_abstract"];
$wms_getcapabilities[$cnt_wms] = $row["wms_getcapabilities"];
@@ -179,8 +184,8 @@
echo " <tbody >";
for($i=0; $i<$cnt_wms; $i++){
echo "<tr class='Farbe' onmouseover='this.style.backgroundColor = \"#F08080\"' onmouseout='this.style.backgroundColor = \"#ffffff\"'>";
- echo "<td><div id ='id_".$wms_title[$i]."' class='even' name ='name_".$wms_title[$i]."' style='cursor:pointer' onclick = 'mod_addWMS(\"".$wms_getcapabilities[$i]."\",\"".$wms_version[$i]."\")'>".$wms_title[$i]."</div></td>";
- echo "<td><div id ='id_".$wms_abstract[$i]."' class='even' name ='name_".$wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMS(\"".$wms_getcapabilities[$i]."\",\"".$wms_version[$i]."\")'>".$wms_abstract[$i]."</div></td>";
+ echo "<td><div id ='id_".$wms_title[$i]."' class='even' name ='name_".$wms_title[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromDB(\"\",\"".$wms_id[$i]."\")'>".$wms_title[$i]."</div></td>";
+ echo "<td><div id ='id_".$wms_abstract[$i]."' class='even' name ='name_".$wms_abstract[$i]."' style='cursor:pointer' onclick = 'mod_addWMSfromDB(\"\",\"".$wms_id[$i]."\")'>".$wms_abstract[$i]."</div></td>";
echo "</tr>";
echo " </tbody>";
Modified: branches/nimix_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php
--- branches/nimix_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php 2008-08-18 14:22:50 UTC (rev 2850)
+++ branches/nimix_dev/http/javascripts/mod_addWMSfromfilteredList_ajax.php 2008-08-18 14:31:43 UTC (rev 2851)
@@ -302,7 +302,8 @@
var onClick = "mod_addWMSfromDB('" + wmsArray[i].guiId + "', '" + wmsArray[i].id + "')";
else {
- var onClick = "mod_addWMSfromfilteredList('" + wmsArray[i].getCapabilitiesUrl + "', '" + wmsArray[i].version + "')";
+ var onClick = "mod_addWMSfromDB('" + guiId + "', '" + wmsArray[i].id + "')";
+// var onClick = "mod_addWMSfromfilteredList('" + wmsArray[i].getCapabilitiesUrl + "', '" + wmsArray[i].version + "')";
addRow("resultTableBody", wmsArray[i].title, wmsArray[i].abstract, onClick);
Modified: branches/nimix_dev/http/javascripts/mod_addWMSgeneralFunctions.js
--- branches/nimix_dev/http/javascripts/mod_addWMSgeneralFunctions.js 2008-08-18 14:22:50 UTC (rev 2850)
+++ branches/nimix_dev/http/javascripts/mod_addWMSgeneralFunctions.js 2008-08-18 14:31:43 UTC (rev 2851)
@@ -1,3 +1,24 @@
+function mb_mapObjaddWMS(obj){
+ var cnt_layers = 0;
+ var cnt_querylayers = 0;
+ var styles = "";
+ var layers = "";
+ var ind = getMapObjIndexByName(obj);
+ //is the id valid?
+ for( var i=0; i<(wms.length-1); i++){
+ if(parseInt(wms[i].wms_id, 10) >= parseInt(wms[wms.length-1].wms_id, 10)){
+ wms[wms.length-1].wms_id = parseInt(mb_mapObj[ind].wms[i].wms_id, 10) + 1;
+ mb_mapObj[ind].wms[mb_mapObj[ind].wms.length] = wms[wms.length-1];
+ mb_mapObj[ind].layers[mb_mapObj[ind].layers.length] = layers;
+ mb_mapObj[ind].styles[mb_mapObj[ind].styles.length] = styles;
+ mb_mapObj[ind].querylayers[mb_mapObj[ind].querylayers.length] = querylayers;
+ mb_execloadWmsSubFunctions();
+ return true;
function mod_addWMS_load(caps){
window.frames['loadData'].document.location.href = "../php/mod_createJSObjFromXML.php?caps=" + encodeURIComponent(caps);
Modified: branches/nimix_dev/http/javascripts/mod_adminNavigation.js
--- branches/nimix_dev/http/javascripts/mod_adminNavigation.js 2008-08-18 14:22:50 UTC (rev 2850)
+++ branches/nimix_dev/http/javascripts/mod_adminNavigation.js 2008-08-18 14:31:43 UTC (rev 2851)
@@ -1,4 +1,5 @@
function mod_adminNavigation_init(){
+ eventInit.trigger();
for (var i=0; i< document.getElementsByTagName("a").length; i++){
document.getElementsByTagName("a")[i].onclick = new Function("mod_adminNavigation(this)");
Modified: branches/nimix_dev/http/javascripts/mod_box1.js
--- branches/nimix_dev/http/javascripts/mod_box1.js 2008-08-18 14:22:50 UTC (rev 2850)
+++ branches/nimix_dev/http/javascripts/mod_box1.js 2008-08-18 14:31:43 UTC (rev 2851)
@@ -8,18 +8,22 @@
var mb_isBF = false;
var mb_zF = false;
+var mb_offset_top = 0;
+var mb_offset_right = 0;
+var mb_offset_bottom = 0;
+var mb_offset_left = 0;
function mod_box_start(e){
mb_isActive = true;
mb_getMousePos(e,mb_isBF);
mb_start_x = clickX;
- mb_start_y = clickY
+ mb_start_y = clickY;
mb_end_x = mb_start_x+1;
mb_end_y = mb_start_y+1;
mb_offset_left = mb_start_x;
mb_offset_top = mb_start_y;
mb_offset_bottom = mb_start_y;
- mb_offset_right = mb_start_x
+ mb_offset_right = mb_start_x;
mb_drawBox(mb_start_x,mb_start_y,mb_end_x,mb_end_y);
return false;
@@ -117,7 +121,7 @@
var maxy = y2;
// area or clickpoint ?
- var ret = new Array();
+ var ret = [];
if((maxx - minx) > 3 && (miny - maxy) > 3){
var posMin = makeClickPos2RealWorldPos(mb_isBF,minx,miny);
var posMax = makeClickPos2RealWorldPos(mb_isBF,maxx,maxy);
More information about the Mapbender_commits
