[Mapbender-commits] r3266 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org
Mon Dec 1 10:25:27 EST 2008
Author: christoph
Date: 2008-12-01 10:25:26 -0500 (Mon, 01 Dec 2008)
New Revision: 3266
Added:
trunk/mapbender/http/javascripts/wfs.php
Removed:
trunk/mapbender/http/javascripts/wfs.js
http://trac.osgeo.org/mapbender/ticket/336
Deleted: trunk/mapbender/http/javascripts/wfs.js
--- trunk/mapbender/http/javascripts/wfs.js 2008-11-28 15:06:18 UTC (rev 3265)
+++ trunk/mapbender/http/javascripts/wfs.js 2008-12-01 15:25:26 UTC (rev 3266)
@@ -1,532 +0,0 @@
-// --- usemap (begin) --------------------------------------------------------------------------------------------
-function mod_usemap(wfs_name) {
- if (wfs_name == "") {
- usemap = "";
- var ind = getMapObjIndexByName(mb_wfs_target);
- var myImg = window.frames[mb_wfs_target].document.getElementById("um_img").style;
- myImg.width = mb_mapObj[ind].width;
- myImg.height = mb_mapObj[ind].height;
- for (var i = 0 ; i < mb_wfs_fetch.count() ; i ++) {
- if (mb_wfs_fetch.get(i).wfs_conf == wfs_name || wfs_name == "") {
- if (mb_wfs_fetch.get(i).geomType == geomType.polygon) {
- usemap += mod_usemap_polygon(i);
- else if (mb_wfs_fetch.get(i).geomType == geomType.point) {
- usemap += mod_usemap_circle(i);
- else if (mb_wfs_fetch.get(i).geomType == geomType.line) {
- usemap += mod_usemap_line(i);
- writeUsemap(usemap);
-function mod_usemap_circle(ind){
- var str = "";
- var coord = "";
- var title = "";
- for (var i = 0 ; i < mb_wfs_fetch.get(ind).e.count(); i++) {
- if (i>0) title += " ";
- title += mb_wfs_fetch.get(ind).e.getName(i) + ": " + mb_wfs_fetch.get(ind).e.getValue(i);
- for (var i = 0 ; i < mb_wfs_fetch.get(ind).count() ; i ++) {
- var p = mb_wfs_fetch.getPoint(ind, i, 0);
- var pos = realToMap(mb_wfs_target,p);
- coord += pos.x + ", " + pos.y;
- str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
- str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='circle' coords='";
- str += coord + ", " + mod_usemap_radius + "' href='#'>";
- return str;
-function mod_usemap_line_calculate (aGeometry, j, orientation, cnt) {
- var coord = "";
- var p1 = realToMap(mb_wfs_targets[0],aGeometry.get(j));
- var p2 = realToMap(mb_wfs_targets[0],aGeometry.get(j+orientation));
- var vec = p2.minus(p1);
- if (vec.x != 0 || vec.y != 0) {
- var n_vec;
- if (vec.x != 0) {
- if (vec.x > 0) n_vec = new Point((-vec.y)/vec.x, -1);
- else n_vec = new Point(vec.y/vec.x, 1);
- else {
- if (vec.y > 0) n_vec = new Point(1,0);
- else n_vec = new Point(-1,0);
- n_vec = n_vec.times(mod_usemap_line_tolerance).dividedBy(n_vec.dist(new Point(0,0)))
- lp = new Point(p1.x + n_vec.x, p1.y - n_vec.y);
- if (cnt > 0) coord += ", ";
- coord += parseInt(lp.x) + ", " + parseInt(lp.y);
- coord += ", " + parseInt(lp.x+vec.x) + ", " + parseInt(lp.y+vec.y);
- return coord;
-function mod_usemap_line(ind){
- var str = "";
- var title = "";
- var coord = "";
- var cnt = 0;
- for (var j = 0 ; j < mb_wfs_fetch.getGeometry(ind,i).count() - 1 ; j ++) {
- var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, 1, cnt);
- if (result != "") {
- coord += result;
- cnt++;
- for (var j = (mb_wfs_fetch.getGeometry(ind,i).count() - 1) ; j > 0 ; j--) {
- var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, -1, cnt);
- coord += result;
- cnt++;
- if (coord != "") {
- str += "<AREA title='"+title+"'";
- str += "onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
- str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' ";
- str += "shape='poly' coords='";
- str += coord + "' href='#'>";
- else {
- //display circle
- var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind,i,0));
- str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
- return str;
-function mod_usemap_polygon(ind){
- var str = "";
- var coord = "";
- var title = "";
- var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, 0));
- for (var j = 1 ; j < mb_wfs_fetch.getGeometry(ind,i).count() ; j ++) {
- pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, j));
- coord += ", " + pos.x + ", " + pos.y;
- str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='poly' coords='";
- return str;
-function writeUsemap(str) {
- writeTag(mb_wfs_targets[0], 'um', str);
-// --- usemap (end) ----------------------------------------------------------------------------------------------
-var highlight_tag_id = "wfs_highlight_tag";
-var mb_wfs_fetched = [];
-var mb_wfs_target = "mapframe1";
-var mb_wfs_objwin = null;
-var mb_wfs_objwin_left = 800;
-var mb_wfs_objwin_top = 200;
-var mb_wfs_objwin_width = 200;
-var mb_wfs_objwin_height = 200;
-var mb_wfs_targets = new Array("mapframe1","overview");
-var mb_wfs_fillColor = "#ff0000";
-var usemap = "";
-var mod_usemap_radius = 10;
-var mod_usemap_line_tolerance = 5;
-var useCheckboxForHighlighting = false;
-var mb_wfs_fetch = new GeometryArray();
-var highlight;
-try {if(generalHighlightZIndex){}}catch(e) {generalHighlightZIndex = 90;}
-try {if(generalHighlightLineWidth){}}catch(e) {generalHighlightLineWidth = 2;}
-try {if(useUsemap){}}catch(e) {useUsemap = 0;}
-mb_registerInitFunctions('initHighlight()');
-function initHighlight() {
- var styleObj = {"position":"absolute", "top":"0px", "left":"0px", "z-index":generalHighlightZIndex};
- highlight = new Highlight(mb_wfs_targets, highlight_tag_id, styleObj, generalHighlightLineWidth);
-try {if(displayWfsResultList){}}catch(e) {displayWfsResultList = 0;};
-if (displayWfsResultList == 1) {
- //mb_registerWfsReadSubFunctions(function(geom){mb_wfs_listMember(geom)});
-if (parseInt(useUsemap) == 1) {
- mb_registerSubFunctions('mod_usemap("")');
-if (useCheckboxForHighlighting) {
- eventInit.register(function() {
- mb_registerSubFunctions('highlight.paint()');
-if (useExtentIsSet()) {
- mb_registerSubFunctions("mb_setwfsrequest_extent()");
-function mb_setwfsrequest_extent() {
- if (useExtentIsSet()) {
- var ind = getMapObjIndexByName(mb_wfs_targets[0]);
- var pos_a = makeClickPos2RealWorldPos(mb_wfs_targets[0],0,0);
- var pos_b = makeClickPos2RealWorldPos(mb_wfs_targets[0],mb_mapObj[ind].width,mb_mapObj[ind].height);
- var x = [];
- var y = [];
- x[0] = pos_a[0];
- x[1] = pos_b[0];
- y[0] = pos_a[1];
- y[1] = pos_b[1];
- mb_setwfsrequest(mb_wfs_targets[0],'rectangle',x,y);
-function mb_wfs_listMember(geomArray){
- mb_wfs_fetch.union(geomArray);
- var wfs_conf = get_complete_wfs_conf();
- var str = "<table>";
- for(var i=0; i<mb_wfs_fetch.count(); i++){
- var t = wfs_conf[mb_wfs_fetch.get(i).wfs_conf];
- for(var j=0; j<t['element'].length; j++){
- if(t['element'][j]['f_show'] > 0){
- var k = mb_wfs_fetch.get(i).e.getElementIndexByName(t['element'][j]['element_name']);
- //alert(k);
- if(k != -1){
- str += "<tr><td>";
- if (useCheckboxForHighlighting) {
- str += "<input type=checkbox id=highlightCheckbox" + i + " onChange='highlightGeometry(" + i + ")'></td><td>";
- str += "<div";
- if (!useCheckboxForHighlighting) {
- str += " onmouseover='mb_wfs_perform(\"over\",mb_wfs_fetch.get("+i+"))' ";
- str += " onmouseout='mb_wfs_perform(\"out\",mb_wfs_fetch.get("+i+"))' ";
- str += " onclick='mb_wfs_perform(\"click\",mb_wfs_fetch.get("+i+"))' ";
- str += ">" + mb_wfs_fetch.get(i).e.getValue(k)+ "</div></td></tr>";
- str += "</table>";
- mb_wfs_objwin.innerHTML = str;
-// if (parseInt(useUsemap) == 1) mod_usemap(wfs_name);
-function mb_wfs_reset(){
- mb_wfs_fetch = new parent.GeometryArray();
- usemap = "";
- if(mb_wfs_objwin == null){
- var iframe=document.createElement('div');
- iframe.setAttribute("style","position:absolute;left:"+mb_wfs_objwin_left+"px;top:"+mb_wfs_objwin_top+"px;width:"+mb_wfs_objwin_width+"px;height:"+mb_wfs_objwin_height+"px");
- mb_wfs_objwin = document.body.appendChild(iframe);
- mb_wfs_objwin.id = "mb_wfs_objwin";
- mb_wfs_objwin.name = "mb_wfs_objwin";
- mb_wfs_objwin.style.position = 'absolute';
- mb_wfs_objwin.style.left = mb_wfs_objwin_left+"px";
- mb_wfs_objwin.style.top = mb_wfs_objwin_top+"px";
- mb_wfs_objwin.style.width = mb_wfs_objwin_width+"px";
- mb_wfs_objwin.style.height = mb_wfs_objwin_height+"px";
- for(var i=0; i<mb_wfsreq; i++){
- if(document.getElementById("mb_wfs_win_"+mb_wfsreq)){
- document.removeChild("mb_wfs_win_"+mb_wfsreq);
- mb_wfsreq = 0;
- return true;
-function get_complete_wfs_conf() {
- var wfs_conf = window.frames["wfs_conf"].get_wfs_conf();
- return wfs_conf;
-function highlightGeometry(i) {
- var id = "highlightCheckbox"+i;
- if (document.getElementById(id).checked) {
- highlight.add(mb_wfs_fetch.get(i), '#00ff00');
- highlight.paint();
- else {
- highlight.del(mb_wfs_fetch.get(i), '#00ff00');
-function mb_wfs_perform(type,m){
- if(type=='over') {
- highlight.add(m, '#ff0000');
- else if (type == 'out') {
- highlight.del(m, '#ff0000');
- else
- if (type == 'click') {
- var tmp = m.getBBox();
- if (m.geomType == geomType.point) {
- var b = 1;
- else {
- var b = 0;
- if (typeof(m.wfs_conf) != "undefined") {
- b = parseFloat(wfs_conf[m.wfs_conf]['g_buffer']);
- var buffer = new Point(b, b);
- var bbox_ll = tmp[0].minus(buffer);
- var bbox_ru = tmp[1].plus(buffer);
- mb_calcExtent(mb_wfs_targets[0], bbox_ll, bbox_ru);
- zoom(mb_wfs_targets[0], 'true', 1.0);
-function get_wfs_str(myconf, d, m, type, fid) {
- var featureTypeArray = myconf['featuretype_name'].split(':')
- var featureNS = featureTypeArray[0];
- var str = '<wfs:Transaction version="1.0.0" service="WFS" ';
- var ns_gml = false; var ns_ogc = false; var ns_xsi = false; var ns_wfs = false; var ns_featureNS = false;
- for (var q = 0 ; q < myconf['namespaces'].length ; q++) {
- if (myconf['namespaces'][q]['name'] == "gml"){
- ns_gml = true;
- str += 'xmlns:' + myconf['namespaces'][q]['name'] + '="' + myconf['namespaces'][q]['location'] + '" ';
- } else if (myconf['namespaces'][q]['name'] == "ogc") {
- ns_ogc = true;
- } else if (myconf['namespaces'][q]['name'] == "xsi") {
- ns_xsi = true;
- } else if (myconf['namespaces'][q]['name'] == "wfs") {
- ns_wfs = true;
- } else if (myconf['namespaces'][q]['name'] == featureNS) {
- ns_featureNS = true;
- strForSchemaLocation = myconf['namespaces'][q]['location'];
- if (ns_gml == false) str += 'xmlns:gml="http://www.opengis.net/gml" ';
- if (ns_ogc == false) str += 'xmlns:ogc="http://www.opengis.net/ogc" ';
- if (ns_xsi == false) str += 'xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" ';
- if (ns_featureNS == false) str += 'xmlns:"+featureNS+"="http://www.someserver.com/"+featureNS+"" ';
- if (ns_wfs == false) str += 'xmlns:wfs="http://www.opengis.net/wfs" ';
- str += 'xsi:schemaLocation="http://www.opengis.net/wfs';
- str += ' http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd';
- str += ' ' + strForSchemaLocation;
- str += ' '+ myconf['wfs_describefeaturetype'];
- //str += mb_getConjunctionCharacter(myconf['wfs_describefeaturetype']);
- //str += 'typename=' + myconf['featuretype_name'];
- str += '">';
- // ---------------------------------------- SAVE -------------------------------------------------
- if (type == "save") {
- str += '<wfs:Insert><'+ myconf['featuretype_name']+'>';
- for(var i=0; i<d.get(m).e.count(); i++){
- if(d.get(m).e.getValue(i) != "" && d.get(m).e.getName(i) != "fid"){
- var tmp = d.get(m).e.getName(i);
- str += '<' + tmp + '>' + d.get(m).e.getValue(i) + '</' + tmp + '>';
- for(var j=0; j<myconf['element'].length; j++){
- if(myconf['element'][j]['f_geom'] == 1){
- var el_geom = myconf['element'][j]['element_name'];
- str += '<' + el_geom + '>';
- if(d.get(m).geomType == geomType.point){
- str += '<gml:Point srsName="' + myconf['featuretype_srs'] + '">';
- str += '<gml:coordinates>';
- str += d.getPoint(m,0,0).x + "," + d.getPoint(m,0,0).y;
- str += '</gml:coordinates>';
- str += '</gml:Point>';
- if(d.get(m).geomType == geomType.line){
- str += '<gml:MultiLineString srsName="' + myconf['featuretype_srs'] + '">';
- str += '<gml:lineStringMember><gml:LineString><gml:coordinates>';
- for(var k=0; k<d.getGeometry(m,0).count(); k++){
- if(k>0) str += " ";
- str += d.getPoint(m,0,k).x + "," + d.getPoint(m,0,k).y;
- str += '</gml:coordinates></gml:LineString></gml:lineStringMember>';
- str += '</gml:MultiLineString>';
- if(d.get(m).geomType == geomType.polygon){
- str += '<gml:MultiPolygon srsName="' + myconf['featuretype_srs'] + '">';
- for (var k = 0; k < d.get(m).count(); k++) {
- str += '<gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>';
- for(var l = 0; l < d.getGeometry(m, k).count(); l++){
- if (l > 0) {
- str += " ";
- str += d.getPoint(m,k,l).x + "," + d.getPoint(m,k,l).y;
- str += '</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>';
- if (d.getGeometry(m, k).innerRings) {
- for(var ii = 0; ii < d.getGeometry(m, k).innerRings.count(); ii++){
- str += '<gml:innerBoundaryIs><gml:LinearRing><gml:coordinates>';
- for(var l = 0; l < d.getGeometry(m, k).innerRings.get(ii).count(); l++){
- if (l > 0) {
- str += " ";
- str += d.getPoint(m,k,ii,l).x + "," + d.getPoint(m,k,ii,l).y;
- str += '</gml:coordinates></gml:LinearRing></gml:innerBoundaryIs>';
- str += '</gml:Polygon></gml:polygonMember>';
- str += '</gml:MultiPolygon>';
- str += '</' + el_geom + '></'+ myconf['featuretype_name']+'></wfs:Insert>';
- // --------------------------------------- UPDATE ------------------------------------------------
- else if (type == "update") {
- str += '<wfs:Update typeName="'+ myconf['featuretype_name']+'">';
- str += '<wfs:Property>';
- str += '<wfs:Name>'+d.get(m).e.getName(i)+'</wfs:Name>';
- str += '<wfs:Value>'+d.get(m).e.getValue(i)+'</wfs:Value>';
- str += '</wfs:Property>';
- str += '<wfs:Property><wfs:Name>' + el_geom + '</wfs:Name><wfs:Value>';
- str += '<gml:Point srsName="' + myconf['featuretype_srs'] + '"><gml:coordinates>';
- str += '</gml:coordinates></gml:Point>';
- for (var l = 0; l < d.get(m).count(); l++) {
- for(var k=0; k<d.getGeometry(m,l).count(); k++){
- str += d.getPoint(m,l,k).x + "," + d.getPoint(m,l,k).y;
- if (d.getGeometry(m, l).innerRings) {
- for(var ii = 0; ii < d.getGeometry(m, l).innerRings.count(); ii++){
- for(var p = 0; p < d.getGeometry(m, l).innerRings.get(ii).count(); p++){
- if (p > 0) {
- str += " ";
- str += d.getPoint(m,l,ii,p).x + "," + d.getPoint(m,l,ii,p).y;
- str += '</wfs:Value></wfs:Property>';
- str += '<ogc:Filter><ogc:FeatureId fid="'+fid+'"/></ogc:Filter>';
- str += '</wfs:Update>';
- // --------------------------------------- DELETE ------------------------------------------------
- else if (type == "delete") {
- str += '<wfs:Delete typeName="'+ myconf['featuretype_name']+'">';
- str += '</wfs:Delete>';
- str += '</wfs:Transaction>';
- return str;
Added: trunk/mapbender/http/javascripts/wfs.php
--- trunk/mapbender/http/javascripts/wfs.php (rev 0)
+++ trunk/mapbender/http/javascripts/wfs.php 2008-12-01 15:25:26 UTC (rev 3266)
@@ -0,0 +1,552 @@
+<?php
+# $Id$
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
+// --- usemap (begin) --------------------------------------------------------------------------------------------
+function mod_usemap(wfs_name) {
+ if (wfs_name == "") {
+ usemap = "";
+ var ind = getMapObjIndexByName(mb_wfs_targets[0]);
+ var myImg = window.frames[mb_wfs_targets[0]].document.getElementById("um_img").style;
+ myImg.width = mb_mapObj[ind].width;
+ myImg.height = mb_mapObj[ind].height;
+ for (var i = 0 ; i < mb_wfs_fetch.count() ; i ++) {
+ if (mb_wfs_fetch.get(i).wfs_conf == wfs_name || wfs_name == "") {
+ if (mb_wfs_fetch.get(i).geomType == geomType.polygon) {
+ usemap += mod_usemap_polygon(i);
+ else if (mb_wfs_fetch.get(i).geomType == geomType.point) {
+ usemap += mod_usemap_circle(i);
+ else if (mb_wfs_fetch.get(i).geomType == geomType.line) {
+ usemap += mod_usemap_line(i);
+ writeUsemap(usemap);
+function mod_usemap_circle(ind){
+ var str = "";
+ var coord = "";
+ var title = "";
+ for (var i = 0 ; i < mb_wfs_fetch.get(ind).e.count(); i++) {
+ if (i>0) title += " ";
+ title += mb_wfs_fetch.get(ind).e.getName(i) + ": " + mb_wfs_fetch.get(ind).e.getValue(i);
+ for (var i = 0 ; i < mb_wfs_fetch.get(ind).count() ; i ++) {
+ var p = mb_wfs_fetch.getPoint(ind, i, 0);
+ var pos = realToMap(mb_wfs_targets[0],p);
+ coord += pos.x + ", " + pos.y;
+ str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
+ str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='circle' coords='";
+ str += coord + ", " + mod_usemap_radius + "' href='#'>";
+ return str;
+function mod_usemap_line_calculate (aGeometry, j, orientation, cnt) {
+ var coord = "";
+ var p1 = realToMap(mb_wfs_targets[0],aGeometry.get(j));
+ var p2 = realToMap(mb_wfs_targets[0],aGeometry.get(j+orientation));
+ var vec = p2.minus(p1);
+ if (vec.x != 0 || vec.y != 0) {
+ var n_vec;
+ if (vec.x != 0) {
+ if (vec.x > 0) n_vec = new Point((-vec.y)/vec.x, -1);
+ else n_vec = new Point(vec.y/vec.x, 1);
+ else {
+ if (vec.y > 0) n_vec = new Point(1,0);
+ else n_vec = new Point(-1,0);
+ n_vec = n_vec.times(mod_usemap_line_tolerance).dividedBy(n_vec.dist(new Point(0,0)))
+ lp = new Point(p1.x + n_vec.x, p1.y - n_vec.y);
+ if (cnt > 0) coord += ", ";
+ coord += parseInt(lp.x) + ", " + parseInt(lp.y);
+ coord += ", " + parseInt(lp.x+vec.x) + ", " + parseInt(lp.y+vec.y);
+ return coord;
+function mod_usemap_line(ind){
+ var str = "";
+ var title = "";
+ var coord = "";
+ var cnt = 0;
+ for (var j = 0 ; j < mb_wfs_fetch.getGeometry(ind,i).count() - 1 ; j ++) {
+ var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, 1, cnt);
+ if (result != "") {
+ coord += result;
+ cnt++;
+ for (var j = (mb_wfs_fetch.getGeometry(ind,i).count() - 1) ; j > 0 ; j--) {
+ var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, -1, cnt);
+ coord += result;
+ cnt++;
+ if (coord != "") {
+ str += "<AREA title='"+title+"'";
+ str += "onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
+ str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' ";
+ str += "shape='poly' coords='";
+ str += coord + "' href='#'>";
+ else {
+ //display circle
+ var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind,i,0));
+ str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
+ return str;
+function mod_usemap_polygon(ind){
+ var str = "";
+ var coord = "";
+ var title = "";
+ var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, 0));
+ for (var j = 1 ; j < mb_wfs_fetch.getGeometry(ind,i).count() ; j ++) {
+ pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, j));
+ coord += ", " + pos.x + ", " + pos.y;
+ str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='poly' coords='";
+ return str;
+function writeUsemap(str) {
+ writeTag(mb_wfs_targets[0], 'um', str);
+// --- usemap (end) ----------------------------------------------------------------------------------------------
+var highlight_tag_id = "wfs_highlight_tag";
+var mb_wfs_fetched = [];
+var mb_wfs_objwin = null;
+var mb_wfs_objwin_left = 800;
+var mb_wfs_objwin_top = 200;
+var mb_wfs_objwin_width = 200;
+var mb_wfs_objwin_height = 200;
+var mb_wfs_targetString = "<?php echo implode(",", $e_target); ?>";
+var mb_wfs_targets = mb_wfs_targetString.split(",");
+var mb_wfs_fillColor = "#ff0000";
+var usemap = "";
+var mod_usemap_radius = 10;
+var mod_usemap_line_tolerance = 5;
+var useCheckboxForHighlighting = false;
+var mb_wfs_fetch = new GeometryArray();
+var highlight;
+try {if(generalHighlightZIndex){}}catch(e) {generalHighlightZIndex = 90;}
+try {if(generalHighlightLineWidth){}}catch(e) {generalHighlightLineWidth = 2;}
+try {if(useUsemap){}}catch(e) {useUsemap = 0;}
+mb_registerInitFunctions('initHighlight()');
+function initHighlight() {
+ var styleObj = {"position":"absolute", "top":"0px", "left":"0px", "z-index":generalHighlightZIndex};
+ highlight = new Highlight(mb_wfs_targets, highlight_tag_id, styleObj, generalHighlightLineWidth);
+try {if(displayWfsResultList){}}catch(e) {displayWfsResultList = 0;};
+if (displayWfsResultList == 1) {
+ //mb_registerWfsReadSubFunctions(function(geom){mb_wfs_listMember(geom)});
+if (parseInt(useUsemap) == 1) {
+ mb_registerSubFunctions('mod_usemap("")');
+if (useCheckboxForHighlighting) {
+ eventInit.register(function() {
+ mb_registerSubFunctions('highlight.paint()');
+if (useExtentIsSet()) {
+ mb_registerSubFunctions("mb_setwfsrequest_extent()");
+function mb_setwfsrequest_extent() {
+ if (useExtentIsSet()) {
+ var pos_a = makeClickPos2RealWorldPos(mb_wfs_targets[0],0,0);
+ var pos_b = makeClickPos2RealWorldPos(mb_wfs_targets[0],mb_mapObj[ind].width,mb_mapObj[ind].height);
+ var x = [];
+ var y = [];
+ x[0] = pos_a[0];
+ x[1] = pos_b[0];
+ y[0] = pos_a[1];
+ y[1] = pos_b[1];
+ mb_setwfsrequest(mb_wfs_targets[0],'rectangle',x,y);
+function mb_wfs_listMember(geomArray){
+ mb_wfs_fetch.union(geomArray);
+ var wfs_conf = get_complete_wfs_conf();
+ var str = "<table>";
+ for(var i=0; i<mb_wfs_fetch.count(); i++){
+ var t = wfs_conf[mb_wfs_fetch.get(i).wfs_conf];
+ for(var j=0; j<t['element'].length; j++){
+ if(t['element'][j]['f_show'] > 0){
+ var k = mb_wfs_fetch.get(i).e.getElementIndexByName(t['element'][j]['element_name']);
+ //alert(k);
+ if(k != -1){
+ str += "<tr><td>";
+ if (useCheckboxForHighlighting) {
+ str += "<input type=checkbox id=highlightCheckbox" + i + " onChange='highlightGeometry(" + i + ")'></td><td>";
+ str += "<div";
+ if (!useCheckboxForHighlighting) {
+ str += " onmouseover='mb_wfs_perform(\"over\",mb_wfs_fetch.get("+i+"))' ";
+ str += " onmouseout='mb_wfs_perform(\"out\",mb_wfs_fetch.get("+i+"))' ";
+ str += " onclick='mb_wfs_perform(\"click\",mb_wfs_fetch.get("+i+"))' ";
+ str += ">" + mb_wfs_fetch.get(i).e.getValue(k)+ "</div></td></tr>";
+ str += "</table>";
+ mb_wfs_objwin.innerHTML = str;
+// if (parseInt(useUsemap) == 1) mod_usemap(wfs_name);
+function mb_wfs_reset(){
+ mb_wfs_fetch = new parent.GeometryArray();
+ usemap = "";
+ if(mb_wfs_objwin == null){
+ var iframe=document.createElement('div');
+ iframe.setAttribute("style","position:absolute;left:"+mb_wfs_objwin_left+"px;top:"+mb_wfs_objwin_top+"px;width:"+mb_wfs_objwin_width+"px;height:"+mb_wfs_objwin_height+"px");
+ mb_wfs_objwin = document.body.appendChild(iframe);
+ mb_wfs_objwin.id = "mb_wfs_objwin";
+ mb_wfs_objwin.name = "mb_wfs_objwin";
+ mb_wfs_objwin.style.position = 'absolute';
+ mb_wfs_objwin.style.left = mb_wfs_objwin_left+"px";
+ mb_wfs_objwin.style.top = mb_wfs_objwin_top+"px";
+ mb_wfs_objwin.style.width = mb_wfs_objwin_width+"px";
+ mb_wfs_objwin.style.height = mb_wfs_objwin_height+"px";
+ for(var i=0; i<mb_wfsreq; i++){
+ if(document.getElementById("mb_wfs_win_"+mb_wfsreq)){
+ document.removeChild("mb_wfs_win_"+mb_wfsreq);
+ mb_wfsreq = 0;
+ return true;
+function get_complete_wfs_conf() {
+ var wfs_conf = window.frames["wfs_conf"].get_wfs_conf();
+ return wfs_conf;
+function highlightGeometry(i) {
+ var id = "highlightCheckbox"+i;
+ if (document.getElementById(id).checked) {
+ highlight.add(mb_wfs_fetch.get(i), '#00ff00');
+ highlight.paint();
+ else {
+ highlight.del(mb_wfs_fetch.get(i), '#00ff00');
+function mb_wfs_perform(type,m){
+ if(type=='over') {
+ highlight.add(m, '#ff0000');
+ else if (type == 'out') {
+ highlight.del(m, '#ff0000');
+ else
+ if (type == 'click') {
+ var tmp = m.getBBox();
+ if (m.geomType == geomType.point) {
+ var b = 1;
+ else {
+ var b = 0;
+ if (typeof(m.wfs_conf) != "undefined") {
+ b = parseFloat(wfs_conf[m.wfs_conf]['g_buffer']);
+ var buffer = new Point(b, b);
+ var bbox_ll = tmp[0].minus(buffer);
+ var bbox_ru = tmp[1].plus(buffer);
+ mb_calcExtent(mb_wfs_targets[0], bbox_ll, bbox_ru);
+ zoom(mb_wfs_targets[0], 'true', 1.0);
+function get_wfs_str(myconf, d, m, type, fid) {
+ var featureTypeArray = myconf['featuretype_name'].split(':')
+ var featureNS = featureTypeArray[0];
+ var str = '<wfs:Transaction version="1.0.0" service="WFS" ';
+ var ns_gml = false; var ns_ogc = false; var ns_xsi = false; var ns_wfs = false; var ns_featureNS = false;
+ for (var q = 0 ; q < myconf['namespaces'].length ; q++) {
+ if (myconf['namespaces'][q]['name'] == "gml"){
+ ns_gml = true;
+ str += 'xmlns:' + myconf['namespaces'][q]['name'] + '="' + myconf['namespaces'][q]['location'] + '" ';
+ } else if (myconf['namespaces'][q]['name'] == "ogc") {
+ ns_ogc = true;
+ } else if (myconf['namespaces'][q]['name'] == "xsi") {
+ ns_xsi = true;
+ } else if (myconf['namespaces'][q]['name'] == "wfs") {
+ ns_wfs = true;
+ } else if (myconf['namespaces'][q]['name'] == featureNS) {
+ ns_featureNS = true;
+ strForSchemaLocation = myconf['namespaces'][q]['location'];
+ if (ns_gml == false) str += 'xmlns:gml="http://www.opengis.net/gml" ';
+ if (ns_ogc == false) str += 'xmlns:ogc="http://www.opengis.net/ogc" ';
+ if (ns_xsi == false) str += 'xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" ';
+ if (ns_featureNS == false) str += 'xmlns:"+featureNS+"="http://www.someserver.com/"+featureNS+"" ';
+ if (ns_wfs == false) str += 'xmlns:wfs="http://www.opengis.net/wfs" ';
+ str += 'xsi:schemaLocation="http://www.opengis.net/wfs';
+ str += ' http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd';
+ str += ' ' + strForSchemaLocation;
+ str += ' '+ myconf['wfs_describefeaturetype'];
+ //str += mb_getConjunctionCharacter(myconf['wfs_describefeaturetype']);
+ //str += 'typename=' + myconf['featuretype_name'];
+ str += '">';
+ // ---------------------------------------- SAVE -------------------------------------------------
+ if (type == "save") {
+ str += '<wfs:Insert><'+ myconf['featuretype_name']+'>';
+ for(var i=0; i<d.get(m).e.count(); i++){
+ if(d.get(m).e.getValue(i) != "" && d.get(m).e.getName(i) != "fid"){
+ var tmp = d.get(m).e.getName(i);
+ str += '<' + tmp + '>' + d.get(m).e.getValue(i) + '</' + tmp + '>';
+ for(var j=0; j<myconf['element'].length; j++){
+ if(myconf['element'][j]['f_geom'] == 1){
+ var el_geom = myconf['element'][j]['element_name'];
+ str += '<' + el_geom + '>';
+ if(d.get(m).geomType == geomType.point){
+ str += '<gml:Point srsName="' + myconf['featuretype_srs'] + '">';
+ str += '<gml:coordinates>';
+ str += d.getPoint(m,0,0).x + "," + d.getPoint(m,0,0).y;
+ str += '</gml:coordinates>';
+ str += '</gml:Point>';
+ if(d.get(m).geomType == geomType.line){
+ str += '<gml:MultiLineString srsName="' + myconf['featuretype_srs'] + '">';
+ str += '<gml:lineStringMember><gml:LineString><gml:coordinates>';
+ for(var k=0; k<d.getGeometry(m,0).count(); k++){
+ if(k>0) str += " ";
+ str += d.getPoint(m,0,k).x + "," + d.getPoint(m,0,k).y;
+ str += '</gml:coordinates></gml:LineString></gml:lineStringMember>';
+ str += '</gml:MultiLineString>';
+ if(d.get(m).geomType == geomType.polygon){
+ str += '<gml:MultiPolygon srsName="' + myconf['featuretype_srs'] + '">';
+ for (var k = 0; k < d.get(m).count(); k++) {
+ str += '<gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>';
+ for(var l = 0; l < d.getGeometry(m, k).count(); l++){
+ if (l > 0) {
+ str += " ";
+ str += d.getPoint(m,k,l).x + "," + d.getPoint(m,k,l).y;
+ str += '</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>';
+ if (d.getGeometry(m, k).innerRings) {
+ for(var ii = 0; ii < d.getGeometry(m, k).innerRings.count(); ii++){
+ str += '<gml:innerBoundaryIs><gml:LinearRing><gml:coordinates>';
+ for(var l = 0; l < d.getGeometry(m, k).innerRings.get(ii).count(); l++){
+ if (l > 0) {
+ str += " ";
+ str += d.getPoint(m,k,ii,l).x + "," + d.getPoint(m,k,ii,l).y;
+ str += '</gml:coordinates></gml:LinearRing></gml:innerBoundaryIs>';
+ str += '</gml:Polygon></gml:polygonMember>';
+ str += '</gml:MultiPolygon>';
+ str += '</' + el_geom + '></'+ myconf['featuretype_name']+'></wfs:Insert>';
+ // --------------------------------------- UPDATE ------------------------------------------------
+ else if (type == "update") {
+ str += '<wfs:Update typeName="'+ myconf['featuretype_name']+'">';
+ str += '<wfs:Property>';
+ str += '<wfs:Name>'+d.get(m).e.getName(i)+'</wfs:Name>';
+ str += '<wfs:Value>'+d.get(m).e.getValue(i)+'</wfs:Value>';
+ str += '</wfs:Property>';
+ str += '<wfs:Property><wfs:Name>' + el_geom + '</wfs:Name><wfs:Value>';
+ str += '<gml:Point srsName="' + myconf['featuretype_srs'] + '"><gml:coordinates>';
+ str += '</gml:coordinates></gml:Point>';
+ for (var l = 0; l < d.get(m).count(); l++) {
+ for(var k=0; k<d.getGeometry(m,l).count(); k++){
+ str += d.getPoint(m,l,k).x + "," + d.getPoint(m,l,k).y;
+ if (d.getGeometry(m, l).innerRings) {
+ for(var ii = 0; ii < d.getGeometry(m, l).innerRings.count(); ii++){
+ for(var p = 0; p < d.getGeometry(m, l).innerRings.get(ii).count(); p++){
+ if (p > 0) {
+ str += " ";
+ str += d.getPoint(m,l,ii,p).x + "," + d.getPoint(m,l,ii,p).y;
+ str += '</wfs:Value></wfs:Property>';
+ str += '<ogc:Filter><ogc:FeatureId fid="'+fid+'"/></ogc:Filter>';
+ str += '</wfs:Update>';
+ // --------------------------------------- DELETE ------------------------------------------------
+ else if (type == "delete") {
+ str += '<wfs:Delete typeName="'+ myconf['featuretype_name']+'">';
+ str += '</wfs:Delete>';
+ str += '</wfs:Transaction>';
+ return str;
More information about the Mapbender_commits
