[Mapbender-commits] r3284 - branches/beck_dev/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Dec 9 08:16:34 EST 2008
Author: beck
Date: 2008-12-09 08:16:34 -0500 (Tue, 09 Dec 2008)
New Revision: 3284
   branches/beck_dev/http/javascripts/mod_mapCookie.php
Modified: branches/beck_dev/http/javascripts/mod_mapCookie.php
--- branches/beck_dev/http/javascripts/mod_mapCookie.php	2008-12-09 12:11:19 UTC (rev 3283)
+++ branches/beck_dev/http/javascripts/mod_mapCookie.php	2008-12-09 13:16:34 UTC (rev 3284)
@@ -20,8 +20,26 @@
 require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
 echo "var mod_mapCookie_target = '".trim($e_target[0])."';";
+$sql  = "SELECT * FROM gui_element_vars ";
+$sql .= "WHERE fkey_gui_id = $1 ";
+$sql .= "AND fkey_e_id = $2";
+$v = array($_SESSION["mb_user_gui"],"mapCookie");
+$t = array("s","s");
+$result = db_prep_query($sql,$v,$t);
+$row    = db_fetch_array($result);
+echo "var mod_mapCookie_cookieLifetime = ".(int)trim(row["cookieLifetime"]).";";
+echo "var mod_mapCookie_cookieName     = '".trim(row["cookieName"])."';";
+var mod_mapCookie_cookieLifetime = 7;			// Cookie lifetime in days
+var mod_mapCookie_cookieName     = 'stored_map_state';	// Cookie name
 eventInit.register(restoreMapState);
 eventInit.register(triggerUnload);
@@ -34,11 +52,13 @@
 	var cookieData      = document.cookie.split(';');
 	for(var i = 0; i < cookieData.length; i++) {
-		if(!cookieData[i].match(/stored_map_state/)) {
+		var cookieName = new RegExp(mod_mapCookie_cookieName);
+		if(!cookieData[i].match(cookieName)) {
 			continue;
-		var storedMapState = eval('(' + cookieData[i].replace(/stored_map_state=/,'') + ')');
+		var storedMapState = eval('(' + cookieData[i].replace(mod_mapCookie_cookieName + '=','') + ')');
 		currentMapState.extent = storedMapState.extent;
 		currentMapState.epsg   = storedMapState.epsg;
@@ -50,7 +70,7 @@
 	var cookieExpires   = new Date();
 	var cookieData      = {}
-	cookieExpires.setTime(cookieExpires.getTime() + (24 * 60 * 60 * 1000));
+	cookieExpires.setTime(cookieExpires.getTime() + (mod_mapCookie_cookieLifetime * 24 * 60 * 60 * 1000));
 	cookieData.extent = currentMapState.extent;
 	cookieData.epsg   = currentMapState.epsg;
More information about the Mapbender_commits mailing list
