[Mapbender-commits] r3287 - branches/beck_dev/http/javascripts
svn_mapbender at osgeo.org
Thu Dec 11 01:45:13 EST 2008
Author: beck
Date: 2008-12-11 01:45:13 -0500 (Thu, 11 Dec 2008)
New Revision: 3287
branches/beck_dev/http/javascripts/mod_mapCookie.php
Modified: branches/beck_dev/http/javascripts/mod_mapCookie.php
--- branches/beck_dev/http/javascripts/mod_mapCookie.php 2008-12-10 13:51:28 UTC (rev 3286)
+++ branches/beck_dev/http/javascripts/mod_mapCookie.php 2008-12-11 06:45:13 UTC (rev 3287)
@@ -20,21 +20,6 @@
require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
echo "var mod_mapCookie_target = '".trim($e_target[0])."';";
-$sql = "SELECT var_name,var_value ";
-$sql .= "FROM gui_element_vars ";
-$sql .= "WHERE fkey_gui_id = $1 ";
-$sql .= "AND fkey_e_id = $2";
-$v = array($_SESSION["mb_user_gui"],"mapCookie");
-$t = array("s","s");
-$result = db_prep_query($sql,$v,$t);
-while($row = db_fetch_array($result)) {
- echo "var mod_mapCookie_".trim($row["var_name"])." = '".trim($row["var_value"])."';";
var mod_mapCookie_cookieLifetime = 7;
More information about the Mapbender_commits
