[Mapbender-commits] r3305 - branches/beck_dev/http/javascripts
svn_mapbender at osgeo.org
Mon Dec 15 02:11:47 EST 2008
Author: beck
Date: 2008-12-15 02:11:39 -0500 (Mon, 15 Dec 2008)
New Revision: 3305
Added:
branches/beck_dev/http/javascripts/wfsFilter.js
Added: branches/beck_dev/http/javascripts/wfsFilter.js
--- branches/beck_dev/http/javascripts/wfsFilter.js (rev 0)
+++ branches/beck_dev/http/javascripts/wfsFilter.js 2008-12-15 07:11:39 UTC (rev 3305)
@@ -0,0 +1,236 @@
+function WfsFilter () {
+ this.operators = [
+ "operator":"==",
+ "wfsOpenTag":"PropertyIsEqualTo",
+ "wfsCloseTag":"PropertyIsEqualTo"
+ "operator":">=",
+ "wfsOpenTag":"PropertyIsGreaterThanOrEqualTo",
+ "wfsCloseTag":"PropertyIsGreaterThanOrEqualTo"
+ "operator":"<=",
+ "wfsOpenTag":"PropertyIsLessThanOrEqualTo",
+ "wfsCloseTag":"PropertyIsLessThanOrEqualTo"
+ "operator":">>",
+ "wfsOpenTag":"PropertyIsGreaterThan",
+ "wfsCloseTag":"PropertyIsGreaterThan"
+ "operator":"<<",
+ "wfsOpenTag":"PropertyIsLessThan",
+ "wfsCloseTag":"PropertyIsLessThan"
+ "operator":"<>",
+ "wfsOpenTag":"PropertyIsNotEqualTo",
+ "wfsCloseTag":"PropertyIsNotEqualTo"
+ "operator":"LIKE",
+ "wfsOpenTag":"PropertyIsLike wildCard='*' singleChar='.' escape='!'",
+ "wfsCloseTag":"PropertyIsLike"
+ var conditionToString = function (condition, operator){
+ var splitParam = condition.split(operator);
+ var columnName = trim(splitParam[0]);
+ var columnValue = trim(splitParam[1]);
+ if (operator == 'LIKE') {
+ columnValue = "*"+ columnValue +"*";
+ for (var i = 0 ; i < that.operators.length ; i++) {
+ if (that.operators[i].operator == operator){
+ // add condition: Property
+ var condString = '<'+that.operators[i].wfsOpenTag+'>' +
+ '<PropertyName>'+columnName+'</PropertyName>' +
+ '<Literal>'+columnValue+'</Literal>' +
+ '</'+that.operators[i].wfsCloseTag+'>';
+ // add condition: Property is not null
+ '<ogc:Not><ogc:PropertyIsNull>' +
+ '<ogc:PropertyName>'+columnName+'</ogc:PropertyName>' +
+ '</ogc:PropertyIsNull></ogc:Not>';
+ return condString;
+ return "";
+ var getOperatorFromCondition = function (aCondition) {
+ for (var j = 0; j < that.operators.length; j++) {
+ if (aCondition.match(that.operators[j].operator)) {
+ return that.operators[j].operator;
+ return false;
+ * parse the filter from the HTML form,
+ * @param {String} filter like "[usertype]<>3 AND [firstname]==Emil"
+ this.parse = function (filter) {
+ if (filter !== '') {
+ filter = filter.replace(/\[/g,"");
+ filter = filter.replace(/\]/g,"");
+ var condArray = filter.split(' AND ');
+ var wfsCond = [];
+ for (var i = 0 ; i < condArray.length ; i++) {
+ var currentOperator = getOperatorFromCondition(condArray[i]);
+ if (!currentOperator) {
+ return false;
+ wfsCond.push(conditionToString(condArray[i], currentOperator));
+ conditionArray = conditionArray.concat(wfsCond);
+ return true;
+ this.addSpatial = function (spatialRequestGeom, geometryColumn, filteroption, srs, target) {
+ if(typeof(spatialRequestGeom) != "undefined"){
+ var spatialRequestFilter = "";
+ if(spatialRequestGeom.geomType == geomType.polygon){
+ spatialRequestFilter += "<" + filteroption + "><ogc:PropertyName>" +
+ geometryColumn + "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\">" +
+ "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+ for(var k=0; k<spatialRequestGeom.count(); k++){
+ if (k > 0) {
+ spatialRequestFilter += " ";
+ spatialRequestFilter += spatialRequestGeom.get(k).x+","+spatialRequestGeom.get(k).y;
+ spatialRequestFilter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>";
+ spatialRequestFilter += "</gml:Polygon></" + filteroption + ">";
+ else if(spatialRequestGeom.geomType == geomType.line){
+ var rectangle = [];
+ rectangle = spatialRequestGeom.getBBox();
+ "<gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>" +
+ rectangle[0].x+","+rectangle[0].y + " " +
+ rectangle[0].x+","+rectangle[1].y + " " +
+ rectangle[1].x+","+rectangle[1].y + " " +
+ rectangle[1].x+","+rectangle[0].y + " " +
+ "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs>" +
+ "</gml:Polygon></" + filteroption + ">";
+ else if(spatialRequestGeom.geomType == geomType.point){
+ var tmp = spatialRequestGeom.get(0);
+ var mapPos = makeRealWorld2mapPos(target,tmp.x, tmp.y);
+ var buffer = mb_wfs_tolerance/2;
+ var realWorld1 = makeClickPos2RealWorldPos(target,mapPos[0]-buffer,mapPos[1]-buffer);
+ var realWorld2 = makeClickPos2RealWorldPos(target,mapPos[0]+buffer,mapPos[1]-buffer);
+ var realWorld3 = makeClickPos2RealWorldPos(target,mapPos[0]+buffer,mapPos[1]+buffer);
+ var realWorld4 = makeClickPos2RealWorldPos(target,mapPos[0]-buffer,mapPos[1]+buffer);
+ spatialRequestFilter += "<Intersects><ogc:PropertyName>";
+ spatialRequestFilter += geometryColumn;
+ spatialRequestFilter += "</ogc:PropertyName><gml:Polygon srsName=\""+srs+"\"><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+ spatialRequestFilter += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] + " ";
+ spatialRequestFilter += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
+ spatialRequestFilter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects>";
+ spatialRequestFilter += "<ogc:Not><ogc:PropertyIsNull>";
+ spatialRequestFilter += "<ogc:PropertyName>" + geometryColumn + "</ogc:PropertyName>";
+ spatialRequestFilter += "</ogc:PropertyIsNull></ogc:Not>";
+ conditionArray.push(spatialRequestFilter);
+ this.addPreConfigured = function (propName, propValueArray, toUpper, operator) {
+ var orConditions = "";
+ for (var j=0; j < propValueArray.length; j++) {
+ if (operator == 'greater_than' || operator == 'less_than' || operator == 'equal') {
+ if(propValueArray[j]!=''){
+ var tag;
+ if (operator == 'greater_than') {
+ tag = "PropertyIsGreaterThan";
+ else if (operator == 'less_than') {
+ tag = "PropertyIsLessThan";
+ else if (operator == 'equal') {
+ tag = "PropertyIsEqualTo";
+ orConditions += "<ogc:" + tag + ">";
+ orConditions += "<ogc:PropertyName>" + propName + "</ogc:PropertyName>";
+ orConditions += "<ogc:Literal>";
+ if (toUpper == 1) {
+ propValueArray[j] = propValueArray[j].toUpperCase();
+ orConditions += propValueArray[j] + "</ogc:Literal></ogc:" + tag + ">";
+ else {
+ var leftSide = "";
+ var rightSide = "*";
+ if (operator != 'rightside') {
+ leftSide = "*";
+ orConditions += "<ogc:PropertyIsLike wildCard='*' singleChar='.' escape='!'>";
+ orConditions += "<ogc:Literal>" + leftSide;
+ if (toUpper == 1){
+ orConditions += propValueArray[j] + rightSide;
+ orConditions += "</ogc:Literal></ogc:PropertyIsLike>";
+ orConditions += "<ogc:Not><ogc:PropertyIsNull>";
+ orConditions += "</ogc:PropertyIsNull></ogc:Not>";
+ if(propValueArray.length > 1){
+ orConditions = "<Or>" + orConditions + "</Or>";
+ this.add(orConditions);
+ this.add = function (aFilterString) {
+ conditionArray.push(aFilterString);
+ this.toString = function () {
+ var str = "";
+ str += "<ogc:Filter xmlns:ogc='http://www.opengis.net/ogc' ";
+ str += "xmlns:gml='http://www.opengis.net/gml'>";
+ if (conditionArray.length > 1) {
+ str += "<And>" + conditionArray.join("") + "</And>";
+ else {
+ str += conditionArray.join("");
+ str += "</ogc:Filter>";
+ return str;
+ var conditionArray = [];
+ var that = this;
More information about the Mapbender_commits
