[Mapbender-commits] r3331 - branches/astroidex_25/http/php
    svn_mapbender at osgeo.org
    Mon Dec 15 19:13:13 EST 2008
Author: astrid_emde
Date: 2008-12-15 19:13:13 -0500 (Mon, 15 Dec 2008)
New Revision: 3331
Added:
   branches/astroidex_25/http/php/mod_createCategory.php
for admin-Gui to add a categroy
Added: branches/astroidex_25/http/php/mod_createCategory.php
--- branches/astroidex_25/http/php/mod_createCategory.php	                        (rev 0)
+++ branches/astroidex_25/http/php/mod_createCategory.php	2008-12-16 00:13:13 UTC (rev 3331)
@@ -0,0 +1,134 @@
+<?php
+# $Id: mod_createCategory.php 2280 2008-03-20 13:00:14Z christoph $
+# http://www.mapbender.org/index.php/Administration
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+import_request_variables("PG");
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+<title>New Category</title>
+<?php include '../include/dyn_css.php'; ?>
+<?php
+if(isset($newCategory) && $newCategory != ""){
+  $sql = "SELECT category_name FROM gui_category WHERE category_name = $1";
+  $v = array($newCategory);
+  $t = array('s');
+  $res = db_prep_query($sql,$v,$t);
+  if(db_fetch_row($res)){
+     echo "<script type='text/javascript'>";
+     echo "alert('Error: Category already exists!');";
+     echo "</script>";
+  else{
+	$sql = "INSERT INTO gui_category (category_name,category_description) ";
+	$sql .= "VALUES($1, $2)";
+	$v = array($newCategory,$newDesc);
+	$t = array('s','s');
+#$sql = "INSERT INTO gui_mb_user (fkey_gui_id,fkey_mb_user_id,mb_user_type) ";
+#$sql .= "VALUES($1, $2, $3)";
+#$v = array($newCategory,$_SESSION["mb_user_id"], 'owner');
+#$t = array('s','i','s');
+#$res = db_prep_query($sql,$v,$t);
+#require_once(dirname(__FILE__)."/mb_getCategroies.php");
+#$arrayGUIs = mb_getGUIs( $_SESSION["mb_user_id"]);
+#$_SESSION["mb_user_guis"] = $arrayGUIs;
+	$categoryCreated=true;
+<script type="text/javascript">
+function setFocus(){
+	document.form1.newCategory.focus();
+function validate(){
+	if(document.form1.newCategory.value == ""){
+		alert("<?php echo _mb("Please enter a category name!")?>");
+		return;
+	else if(document.form1.newDesc.value == ""){
+		alert("<?php echo _mb("Please enter a category description!")?>");
+		document.form1.newDesc.focus();
+		return;
+	else{
+		document.form1.submit();
+</script>
+</head>
+<body onload='setFocus()'>
+<form name='form1' action="<?php echo $self; ?>" method="POST">
+<?php
+	$v = array();
+	$t = array();
+	$c = 1;
+	$sql = "SELECT * from gui_category";
+	$sql .= " order by lower(category_name);";
+	$count=0;
+	while($row = db_fetch_array($res)){
+		$category_name[$count]= $row["category_name"];
+		$category_description[$count]=$row["category_description"];
+		$count++;
+	echo "<p\n";
+	echo "<div class= 'guiList1_text'>"._mb("existing Categories").":</div>\n";
+	echo "<select class='categoryList' size='14' name='categoryList' onchange='setCategory(this.value)'>\n";
+	for ($i=0; $i<count($category_name);$i++){
+		echo "<option value='".$category_name[$i]."' ";
+		echo ">".$category_name[$i]. " - ".$category_description[$i]."</option>\n";
+	echo "</select>\n";
+	echo "</p\n";
+<table>
+<tr><td><?php echo _mb("Category Name"); ?>: </td><td><input type='text' name='newCategory'></td></tr>
+<tr><td><?php echo _mb("Description"); ?>: </td><td><input type='text' name='newDesc'></td></tr>
+<tr><td></td><td><input type='button' onclick='validate()' value="<?php echo _mb("new"); ?>"></td></tr>
+</table>
+<?php
+	if ($categoryCreated==true){
+		echo "<p class = 'categroyList'>";
+		echo "<b>".$newCategory."</b> - "._mb("The Category has been created successfully.");
+		echo "<p>";
+		}else{
+			echo"error";
+</form>
+</body>
+</html>
\ No newline at end of file
More information about the Mapbender_commits
