[Mapbender-commits] r3360 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Fri Dec 19 08:28:10 EST 2008
Author: christoph
Date: 2008-12-19 08:28:10 -0500 (Fri, 19 Dec 2008)
New Revision: 3360
trunk/mapbender/http/classes/class_locale.php
http://trac.osgeo.org/mapbender/ticket/359
Modified: trunk/mapbender/http/classes/class_locale.php
--- trunk/mapbender/http/classes/class_locale.php 2008-12-19 13:24:19 UTC (rev 3359)
+++ trunk/mapbender/http/classes/class_locale.php 2008-12-19 13:28:10 UTC (rev 3360)
@@ -27,120 +27,124 @@
class Mb_locale {
- var $knownLanguages = null;
- var $systemLocales = null;
- var $browserLanguages = null;
- var $os = null;
- var $name = null;
- var $defaultLanguage = "en";
- var $status = "No locale set.";
+ var $knownLanguages = null;
+ var $systemLocales = null;
+ var $browserLanguages = null;
+ var $os = null;
+ var $name = null;
+ var $defaultLanguage = "en";
+ var $status = "No locale set.";
- function Mb_locale($languageId) {
- if (!$languageId) {
- $languageId = LANGUAGE;
- $e = new Mb_notice("class_locale: setting locale to " . $languageId);
- if (USE_I18N) {
- if (!$this->setCurrentLocale($languageId)) {
- $e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
- else {
- $this->setCurrentLocale($this->defaultLanguage);
+ function Mb_locale($languageId) {
+ if (!$languageId) {
+ $languageId = LANGUAGE;
+ $e = new Mb_notice("class_locale: setting locale to " . $languageId);
+ if (USE_I18N) {
+ if (!$this->setCurrentLocale($languageId)) {
+ $e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
+ else {
+ $this->setCurrentLocale($this->defaultLanguage);
- * Get the current locale, evaluating GET/POST variables, browser languages
- * and a default locale (in that preference)
- * @returns current locale
- function setCurrentLocale($languageId) {
+ * Get the current locale, evaluating GET/POST variables, browser languages
+ * and a default locale (in that preference)
+ * @returns current locale
+ function setCurrentLocale($languageId) {
- // try to set the locale to $languageId
- if ($this->checkAndSetLocale($languageId)) {
- return true;
- else {
- $e = new Mb_notice("class_locale: no input parameter specified.");
+ // try to set the locale to $languageId
+ if ($this->checkAndSetLocale($languageId)) {
+ return true;
+ else {
+ $e = new Mb_notice("class_locale: no input parameter specified.");
+ // determine the browser setting and try to set locale according to that
+ if ($this->browserLanguage == null) {
+ $this->setBrowserLanguages();
+ foreach ($this->browserLanguages as $lang) {
+ $e = new Mb_notice("trying browser setting " . $lang);
+ if ($this->checkAndSetLocale($lang)) {
+ return true;
+ // set to default language
+ $e = new Mb_notice("trying default language " . $this->defaultLanguage);
+ return $this->checkAndSetLocale($this->defaultLanguage);
- // determine the browser setting and try to set locale according to that
- if ($this->browserLanguage == null) {
- $this->setBrowserLanguages();
- foreach ($this->browserLanguages as $lang) {
- $e = new Mb_notice("trying browser setting " . $lang);
- if ($this->checkAndSetLocale($lang)) {
- return true;
+ * checks if a locale is available; if yes, it is set via setlocale
+ * @returns true if the the locale is set successfully; otherwise false
+ function checkAndSetLocale($languageId) {
+ if ($this->os == null) {
+ $this->os = $this->guessHostOS();
+ if (!USE_I18N || ($this->os != null && isset($languageId))) {
+ if ($this->isKnownLanguage($languageId)) {
+ if ($this->systemLocales == null) {
+ $this->setSystemLocales();
+ $locale = $this->systemLocales[$this->knownLanguages[$languageId]][$this->os];
+ $selectedLocale = setlocale(LC_MESSAGES, $locale);
- // set to default language
- $e = new Mb_notice("trying default language " . $this->defaultLanguage);
- return $this->checkAndSetLocale($this->defaultLanguage);
+ if ($selectedLocale) {
+ $this->name = $selectedLocale;
+ $_SESSION["mb_lang"] = $languageId;
+ $_SESSION["mb_locale"] = $this->name;
+ $e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
- * checks if a locale is available; if yes, it is set via setlocale
- * @returns true if the the locale is set successfully; otherwise false
- function checkAndSetLocale($languageId) {
- if ($this->os == null) {
- $this->os = $this->guessHostOS();
+ // from http://de3.php.net/manual/de/function.gettext.php
+ $path = bindtextdomain("Mapbender", dirname(__FILE__)."/../../resources/locale/");
+ $enc = bind_textdomain_codeset("Mapbender", "UTF-8");
+ $dom = textdomain("Mapbender");
+ return true;
+ $e = new Mb_notice("locale " . $locale . " not found.");
+ return false;
- if (!USE_I18N || ($this->os != null && isset($languageId))) {
- if ($this->isKnownLanguage($languageId)) {
+ * Guess the operating system which on which this code is running
+ * multiple methods are tested for reliably guessing the os
+ * @private
+ * @returns string with os name
+ function guessHostOS(){
+ if (strncasecmp(php_uname(), 'Windows', 7) == 0) {
+ return 'windows';
+ else if (strncasecmp(php_uname(), 'Linux', 5) == 0) {
+ return 'linux';
+ else if (strncasecmp(php_uname(), 'OpenBSD', 7) == 0) {
+ return 'bsd';
+ else if (strncasecmp(php_uname(), 'FreeBSD', 7) == 0) {
+ return 'bsd';
+ new mb_exception('unknown platform: could not interpret uname. php_uname() returned '. php_uname().'. Please report to MB developers');
+ return null;
- if ($this->systemLocales == null) {
- $this->setSystemLocales();
- $locale = $this->systemLocales[$this->knownLanguages[$languageId]][$this->os];
- $selectedLocale = setlocale(LC_MESSAGES, $locale);
- if ($selectedLocale) {
- $this->name = $selectedLocale;
- $_SESSION["mb_lang"] = $languageId;
- $_SESSION["mb_locale"] = $this->name;
- $e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
- // from http://de3.php.net/manual/de/function.gettext.php
- $path = bindtextdomain("Mapbender", dirname(__FILE__)."/../../resources/locale/");
- $enc = bind_textdomain_codeset("Mapbender", "UTF-8");
- $dom = textdomain("Mapbender");
- return true;
- $e = new Mb_notice("locale " . $locale . " not found.");
- return false;
- * Guess the operating system which on which this code is running
- * multiple methods are tested for reliably guessing the os
- * @private
- * @returns string with os name
- function guessHostOS(){
- if (strncasecmp(php_uname(), 'Windows', 7) == 0)
- return 'windows';
- else if (strncasecmp(php_uname(), 'Linux', 5) == 0)
- return 'linux';
- else if (strncasecmp(php_uname(), 'OpenBSD', 7) == 0)
- return 'bsd';
- else if (strncasecmp(php_uname(), 'FreeBSD', 7) == 0)
- return 'bsd';
- else {
- throw new Mb_exception('unknown platform: could not interpret uname. php_uname() returned '. php_uname().'. Please report to MB developers');
- return null;
* checks if a language is supported
* @returns true if the language is supported; otherwise false
@@ -164,40 +168,54 @@
* determines the available Locales on this system
function setSystemLocales() {
- $this->systemLocales['it_IT'] = array('linux' => 'it_IT.utf8',
+ $this->systemLocales['it_IT'] = array(
+ 'linux' => 'it_IT.utf8',
'windows' => 'Italian_Italy.1252',
'bsd' => 'it_IT',
'posix' => 'it_IT');
- $this->systemLocales['de_DE'] = array('linux' => 'de_DE.utf8',
+ $this->systemLocales['de_DE'] = array(
+ 'linux' => 'de_DE.utf8',
'windows' => 'German_Germany.1252',
'bsd' => 'de_DE',
'posix' => 'de_DE');
- $this->systemLocales['en_US'] = array('linux' => 'en_US.utf8',
+ $this->systemLocales['en_US'] = array(
+ 'linux' => 'en_US.utf8',
'windows' => 'English_United States.1252',
'bsd' => 'en_US',
'posix' => 'en_US');
+ $this->systemLocales['bg_BG'] = array(
+ 'linux' => 'bg_BG.utf8',
+ 'windows' => 'Bulgarian_Bulgaria.1251',
+ 'bsd' => 'bg_BG',
+ 'posix' => 'bg_BG');
+ $this->systemLocales['el_GR'] = array(
+ 'linux' => 'el_GR.utf8',
+ 'windows' => 'Greek_Greece.1253',
+ 'bsd' => 'el_GR',
+ 'posix' => 'el_GR');
* set the known languages
function setKnownLanguages() {
- $this->knownLanguages = array('en_US' => 'en_US',
- 'en' => 'en_US',
- 'de_DE' => 'de_DE',
- 'de' => 'de_DE',
- 'bg_BG' => 'bg_BG',
- 'bg' => 'bg_BG',
- 'es_ES' => 'es_ES',
- 'es' => 'es_ES',
- 'nl_NL' => 'nl_NL',
- 'nl' => 'nl_NL',
- 'fr_FR' => 'fr_FR',
- 'fr' => 'fr_FR',
- 'gr_GR' => 'gr_GR',
- 'gr' => 'gr_GR',
- 'it_IT' => 'it_IT',
- 'it' => 'it_IT');
+ $this->knownLanguages = array(
+ 'en_US' => 'en_US',
+ 'en' => 'en_US',
+ 'de_DE' => 'de_DE',
+ 'de' => 'de_DE',
+ 'bg_BG' => 'bg_BG',
+ 'bg' => 'bg_BG',
+ 'es_ES' => 'es_ES',
+ 'es' => 'es_ES',
+ 'nl_NL' => 'nl_NL',
+ 'nl' => 'nl_NL',
+ 'fr_FR' => 'fr_FR',
+ 'fr' => 'fr_FR',
+ 'el_GR' => 'el_GR',
+ 'gr' => 'el_GR',
+ 'it_IT' => 'it_IT',
+ 'it' => 'it_IT');
More information about the Mapbender_commits
