[Mapbender-commits] r2053 - branches/2.5/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Feb 1 10:25:17 EST 2008
Author: christoph
Date: 2008-02-01 10:25:17 -0500 (Fri, 01 Feb 2008)
New Revision: 2053
   branches/2.5/http/classes/class_wms.php
merged w/ SLD branch
Modified: branches/2.5/http/classes/class_wms.php
--- branches/2.5/http/classes/class_wms.php	2008-02-01 14:41:57 UTC (rev 2052)
+++ branches/2.5/http/classes/class_wms.php	2008-02-01 15:25:17 UTC (rev 2053)
@@ -59,10 +59,16 @@
 	var $data_format = array();
 	var $objLayer = array();
+	var $wms_supportsld;
+	var $wms_userlayer;
+	var $wms_userstyle;
+	var $wms_remotewfs;
 	var $gui_wms_mapformat;
 	var $gui_wms_featureinfoformat;
 	var $gui_wms_exceptionformat;
 	var $gui_wms_epsg;
+	var $gui_wms_sldurl;
 	var $default_epsg = 0;
 	var $overwrite = true;
@@ -94,8 +100,7 @@
 		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
 		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
 		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-//		xml_parse_into_struct($parser,$this->wms_getcapabilities_doc,$values,$tags);
-		xml_parse_into_struct($parser,$data,$values,$tags);
+		xml_parse_into_struct($parser,$this->wms_getcapabilities_doc,$values,$tags);
 		$code = xml_get_error_code($parser);
 		if ($code) {
@@ -341,7 +346,14 @@
 				$section = "";
+			/* sld section */
+			if(mb_strtoupper($element[tag]) == "USERDEFINEDSYMBOLIZATION" && $element[type] == "complete"){
+				$this->wms_supportsld = $element[attributes]["SupportSLD"];
+				$this->wms_userlayer = $element[attributes]["UserLayer"];
+				$this->wms_userstyle = $element[attributes]["UserStyle"];
+				$this->wms_remotewfs = $element[attributes]["RemoteWFS"];
 			/*layer section*/
 			if(mb_strtoupper($element[tag]) == "LAYER"){
 				$section = "layer";
@@ -599,7 +611,22 @@
 		for($i=0; $i<count($this->objLayer); $i++){
 				$this->objLayer[$i]->layer_pos=$i;
+		/* fill sld variables when empty */
+		if($this->wms_supportsld == ""){
+				$this->wms_supportsld = 0;
+		if($this->wms_userlayer == ""){
+				$this->wms_userlayer = 0;
+		if($this->wms_userstyle == ""){
+				$this->wms_userstyle = 0;
+		if($this->wms_remotewfs == ""){
+				$this->wms_remotewfs = 0;
 	function displayWMS(){
 		echo "<br>id: " . $this->wms_id . " <br>";
 		echo "version: " . $this->wms_version . " <br>";
@@ -614,6 +641,7 @@
 		echo "gui_wms_epsg: " . $this->gui_wms_epsg . " <br>";
 		echo "wms_srs: " . $this->objLayer[0]->wms_srs1 . " <br>";
 		echo "gui_wms_visible: " . $this->gui_wms_visible . " <br>";
+		echo "support_sld: " . $this->wms_supportsld . " <br>";
 		for($i=0; $i<count($this->data_type);$i++){
 			echo $this->data_type[$i]. " -> ".$this->data_format[$i]. "<br>";
@@ -675,7 +703,8 @@
 					"'" . $this->gui_wms_featureinfoformat . "'," .
 					"'" . $this->gui_wms_exceptionformat . "'," .
 					"'" . $this->gui_wms_epsg ."'," .
-					"'" . $this->gui_wms_visible ."" .
+					"'" . $this->gui_wms_visible ."'," .
+					"'" . $this->gui_wms_sldurl ."" .
 			echo $add_wms_string;
@@ -765,7 +794,8 @@
 			$this->gui_wms_featureinfoformat ."','".
 			$this->gui_wms_exceptionformat . "','".
 			$this->gui_wms_epsg ."','".
-			$this->gui_wms_visible ."');\n");
+			$this->gui_wms_visible ."','".
+			$this->gui_wms_sldurl ."');\n");
 		for($i=0;$i<count($this->data_format);$i++){
 			if($parent){
@@ -849,15 +879,17 @@
 		$sql.= "wms_getfeatureinfo, wms_getlegendurl, wms_getcapabilities_doc, wms_upload_url, fees, ";
 		$sql .= "accessconstraints, contactperson, contactposition, contactorganization, address, city, ";
 		$sql .= "stateorprovince, postcode, country, contactvoicetelephone, contactfacsimiletelephone, contactelectronicmailaddress, ";
-		$sql .= "wms_owner,wms_timestamp) ";
-		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24)";
+		$sql .= "wms_owner,wms_timestamp, ";
+		$sql .= "wms_supportsld, wms_userlayer, wms_userstyle, wms_remotewfs) ";
+		$sql .= "VALUES($1,$2,$3,$4,$5,$6,$7,$8,$9,$10,$11,$12,$13,$14,$15,$16,$17,$18,$19,$20,$21,$22,$23,$24,$25,$26,$27,$28)";
 		$v = array($this->wms_version,$this->wms_title,$this->wms_abstract,$this->wms_getcapabilities,
-			$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,"",
+			$this->wms_getmap,$this->wms_getfeatureinfo,$this->wms_getlegendurl,$this->wms_getcapabilities_doc,
 			$this->wms_upload_url,$this->fees,$this->accessconstraints,$this->contactperson,$this->contactposition,
 			$this->contactorganization,$this->address,$this->city,$this->stateorprovince,$this->postcode,$this->country,
 			$this->contactvoicetelephone,$this->contactfacsimiletelephone,$this->contactelectronicmailaddress,
-			$_SESSION['mb_user_id'],strtotime("now"));
-		$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i');
+			$_SESSION['mb_user_id'],strtotime("now"),
+			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs );
+		$t = array('s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','s','i','i','s','s','s','s');
 		$res = db_prep_query($sql,$v,$t);
 		if(!$res){
 			db_rollback();
@@ -1143,7 +1175,6 @@
 					$sql_insertKeyword .= "VALUES ($1)";
 					$v1 = array($k[$j]);
 					$t1 = array('s');
-					echo $k[$j];
 					$res_insertKeyword = db_prep_query($sql_insertKeyword,$v1,$t1);
 					if(!$res_insertKeyword){
 						db_rollback();
@@ -1182,13 +1213,18 @@
 		$sql .= "wms_getcapabilities_doc = $6 ,";
 		$sql .= "wms_upload_url = $7,  ";
 		$sql .= "wms_owner = $8, ";
-		$sql .= "wms_timestamp = $9 ";
-		$sql .= " WHERE wms_id = $10";
+		$sql .= "wms_timestamp = $9, ";
+		$sql .= "wms_supportsld = $10, ";
+		$sql .= "wms_userlayer = $11, ";
+		$sql .= "wms_userstyle = $12, ";
+		$sql .= "wms_remotewfs = $13 ";
+		$sql .= " WHERE wms_id = $14";
 		$v = array($this->wms_version,$this->wms_getcapabilities,
-			$this->wms_getcapabilities_doc,$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),$myWMS);
-		$t = array('s','s','s','s','s','s','s','i','i','i');
+			$this->wms_getcapabilities_doc,$this->wms_upload_url,$_SESSION["mb_user_id"],strtotime("now"),
+			$this->wms_supportsld,$this->wms_userlayer,$this->wms_userstyle,$this->wms_remotewfs,$myWMS);
+		$t = array('s','s','s','s','s','s','s','i','i','s','s','s','s','i');
 		if(!$res){
@@ -1376,7 +1412,7 @@
 		while($row = db_fetch_array($res)){
 			unset($mySubmit);
 			$myGUI[$cnt] = $row["fkey_gui_id"];
 			$sql = "UPDATE gui_wms SET ";
 			$v = array();
 			$t = array();
@@ -1467,7 +1503,7 @@
 	function getCapabilitiesDoc() {
 		return $this->wms_getcapabilities_doc;
 	* creatObjfromDB
@@ -1489,6 +1525,7 @@
 			$this->gui_wms_exceptionformat=$row["gui_wms_exceptionformat"];
 			$this->gui_wms_epsg=$row["gui_wms_epsg"];
 			$this->gui_wms_visible = $row["gui_wms_visible"];
+			$this->gui_wms_sldurl = $row["gui_wms_sldurl"];
 			$sql = "Select * from wms where wms_id = $1 ";
 			$v = array($wms_id);
@@ -1517,6 +1554,10 @@
 				$this->wms_getcapabilities_doc = $row2["wms_getcapabilities_doc"];
 				$this->wms_filter = $row2["wms_filter"];
+				$this->wms_supportsld = $row2["wms_supportsld"];
+				$this->wms_userlayer = $row2["wms_userlayer"];
+				$this->wms_userstyle = $row2["wms_userstyle"];
+				$this->wms_remotewfs = $row2["wms_remotewfs"];
 				$count_wms++;
More information about the Mapbender_commits mailing list
