[Mapbender-commits] r2055 - branches/2.5/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Feb 1 11:21:01 EST 2008
Author: christoph
Date: 2008-02-01 11:21:00 -0500 (Fri, 01 Feb 2008)
New Revision: 2055
   branches/2.5/http/php/mod_editGuiWms.php
merged w/ SLD branch
Modified: branches/2.5/http/php/mod_editGuiWms.php
--- branches/2.5/http/php/mod_editGuiWms.php	2008-02-01 16:19:49 UTC (rev 2054)
+++ branches/2.5/http/php/mod_editGuiWms.php	2008-02-01 16:21:00 UTC (rev 2055)
@@ -258,18 +258,18 @@
    if(isset($this_gui_wms_epsg)){
       $sql = "UPDATE gui_wms set gui_wms_epsg = $1, gui_wms_mapformat = $2, ";
       $sql .= "gui_wms_featureinfoformat = $3, gui_wms_exceptionformat = $4, ";
-      $sql .= "gui_wms_visible = $5 ";
-      $sql .= "WHERE fkey_gui_id = $6 AND fkey_wms_id = $7";
-		$v = array($this_gui_wms_epsg,$this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui,$this_wms);
-		$t = array('s','s','s','s','i','s','i');
+      $sql .= "gui_wms_visible = $5, gui_wms_sldurl = $6 ";
+      $sql .= "WHERE fkey_gui_id = $7 AND fkey_wms_id = $8";
+		$v = array($this_gui_wms_epsg,$this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_sldurl,$this_gui,$this_wms);
+		$t = array('s','s','s','s','i','s','s','i');
 		$res = db_prep_query($sql,$v,$t);
    else{
 		$sql = "UPDATE gui_wms set gui_wms_mapformat = $1, ";
 		$sql .= "gui_wms_featureinfoformat = $2, gui_wms_exceptionformat = $3, ";
-		$sql .= "gui_wms_visible = $4 ";
-		$sql .= "WHERE fkey_gui_id = $5 AND fkey_wms_id = $6";
-		$v = array($this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui,$this_wms);
+		$sql .= "gui_wms_visible = $4, gui_wms_sldurl = $5 ";
+		$sql .= "WHERE fkey_gui_id = $6 AND fkey_wms_id = $7";
+		$v = array($this_gui_wms_mapformat,$this_gui_wms_featureinfoformat,$this_gui_wms_exceptionformat,$this_gui_wms_visible,$this_gui_wms_sldurl,$this_gui,$this_wms);
 		$t = array('s','s','s','i','s','i');
@@ -392,6 +392,7 @@
    $gui_wms_exceptionformat[$cnt_gw] = $row["gui_wms_exceptionformat"];
    $gui_wms_epsg[$cnt_gw] = $row["gui_wms_epsg"];
    $gui_wms_visible[$cnt_gw] = $row["gui_wms_visible"];
+   $gui_wms_sldurl[$cnt_gw] = $row["gui_wms_sldurl"]; # sld url
    $cnt_gw++;
 #wms
@@ -406,6 +407,7 @@
    $wms_title[$cnt_w] = $row["wms_title"];
    $wms_abstract[$cnt_w] = $row["wms_abstract"];
    $wms_getcapabilities[$cnt_w] = $row["wms_getcapabilities"];
+   $wms_supportsld[$cnt_w] = $row["wms_supportsld"];  # Buttons zum sld support anzeigen?
    $cnt_w++;
 #wms_format
@@ -420,9 +422,10 @@
    $cnt_wf++;
 #gui_layer
-$sql_gl = "SELECT * FROM layer AS l, gui_layer AS gl WHERE l.layer_id = gl.fkey_layer_id AND gl.gui_layer_wms_id = $1 AND gl.fkey_gui_id = $2 ORDER BY l.layer_pos";
-$v = array($wmsList,$guiList);
-$t = array('i','s');
+$sql_gl = "SELECT l.*, gl.*, sld.sld_user_layer_id, sld.use_sld FROM layer AS l, gui_layer AS gl left outer join sld_user_layer AS sld on sld.fkey_layer_id = gl.fkey_layer_id WHERE l.layer_id = gl.fkey_layer_id AND gl.gui_layer_wms_id = $1 AND gl.fkey_gui_id = $2 AND (sld.fkey_gui_id = $2 or sld.fkey_gui_id is NULL) AND (sld.fkey_mb_user_id = $3 or sld.fkey_mb_user_id is NULL) ORDER BY l.layer_pos";
+$v = array($wmsList,$guiList,$mb_user_id);
+$t = array('i','s','i');
 $res_gl = db_prep_query($sql_gl,$v,$t);
 $gui_layer_status = array();
 $gui_layer_selectable = array();
@@ -434,6 +437,7 @@
 $gui_layer_priority = array();
 $gui_layer_style = array();
 $gui_layer_wfs_featuretype = array();
+$layer_maxscale = array();
 $layer_id = array();
 $layer_parent = array();
 $layer_name = array();
@@ -441,6 +445,8 @@
 $layer_queryable = array();
 $layer_minscale = array();
+$sld_user_layer_id = array();
+$use_sld = array();
 while($row = db_fetch_array($res_gl)){
 	array_push($gui_layer_status, $row["gui_layer_status"]);
 	array_push($gui_layer_selectable, $row["gui_layer_selectable"]);
@@ -459,6 +465,8 @@
 	array_push($layer_queryable, $row["layer_queryable"]);
 	array_push($layer_minscale, $row["layer_minscale"]);
 	array_push($layer_maxscale, $row["layer_maxscale"]);
+	array_push($sld_user_layer_id, $row["sld_user_layer_id"]);
+	array_push($use_sld, $row["use_sld"]);
 #layer_epsg
@@ -564,11 +572,25 @@
 echo "</tr>";
+# sld support
+if($wms_supportsld[0]) {
+		echo "<tr>";
+		echo "<td>SLD-URL: </td><td>";
+		echo "<input type='text' class='myText' name='this_gui_wms_sldurl' title='".$gui_wms_sldurl[0]."' value='".$gui_wms_sldurl[0]."'>";
+		#echo "<a href='' onclick='return window.open(\"editor-start.php\");'><img src='sld_editor.png' border=0></a>";
+		#$layer_names = implode(",", $layer_name);
+        echo " <a href='".$gui_wms_sldurl[0]."' target='_new'>SLD laden/anzeigen</a>";
+		echo "</td>";
+	echo "</tr>";
+} else {
+	echo "<input type='hidden' value='' name='this_gui_wms_sldurl'>";
 echo "</table><br>";
 echo "<table border='1' cellpadding='1'>";
+		echo "<tr>";
-		echo "<tr>";
                 echo "<td>Nr.</td>";
                 echo "<td>ID</td>";
                 echo "<td>" . toImage('Parent') . "</td>";
@@ -583,7 +605,8 @@
                 echo "<td>" . toImage('maxScale 1:') . "</td>";
                 echo "<td>" . toImage('Style') . "</td>";
                 echo "<td>" . toImage('Prio') . "</td>";
-                echo "<td>" . toImage('setWFS') . "</td>";
+                echo "<td>" . toImage('setWFS') . "</td>";
+                if($wms_supportsld[0]) {echo "<td>" . toImage('SLD') . "</td>";}
         echo "</tr>";
 #echo "<tr><td>Nr.</td><td>ID</td><td>Parent</td><td>Name</td><td>Title</td><td>on/off</td><td>sel</td><td>sel_default</td><td>info</td><td>info_default</td><td>minScale 1:</td><td>maxScale 1:</td><td>Prio</td><td>setWFS</td></tr>";
@@ -677,7 +700,19 @@
 		echo "'>";
-	echo "</td>";
+	echo "</td>";
+		echo "<td>";
+		if ($i > 0) {
+			echo "<input class='button3' name='gui_layer_sld' type='button' onclick='window.open(\"../sld/sld_main.php?".SID."&gui_id=".$guiList."&wms_id=".$wms_id[0]."&layer_name=".$layer_name[$i]."\");' value='";
+			if ($sld_user_layer_id[$i] != "")
+				echo "sld:".$sld_user_layer_id[$i]."(".$use_sld[$i].")";
+			else
+				echo "SLD";
+			echo "'>";
+		echo "</td>";
  echo "</tr>\n";
  if($i == 0){ echo "<tr><td colspan='14'><hr></td></tr>";}
More information about the Mapbender_commits mailing list
