[Mapbender-commits] r2061 - branches/2.5/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Tue Feb 5 10:00:27 EST 2008
Author: verenadiewald
Date: 2008-02-05 10:00:27 -0500 (Tue, 05 Feb 2008)
New Revision: 2061
   branches/2.5/http/classes/class_gml2.php
removed some mb_exceptions from testing
Modified: branches/2.5/http/classes/class_gml2.php
--- branches/2.5/http/classes/class_gml2.php	2008-02-05 14:59:08 UTC (rev 2060)
+++ branches/2.5/http/classes/class_gml2.php	2008-02-05 15:00:27 UTC (rev 2061)
@@ -1,787 +1,784 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_gml2.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once("class_mb_exception.php");
-require_once("class_connector.php");
-require_once("../../conf/mapbender.conf");
-class gml2 {
-	var $geomtype_point = 'Point';
-	var $geomtype_polygon = 'Polygon';
-	var $geomtype_line = 'LineString';
-	var $geomtype_multipolygon = 'MultiPolygon';
-	var $geomtype_multiline = 'MultiLine';
-	var $geometries = array();
-	var $member = -1;
-	var $geomtype = array();
-	var $keys = array();
-	var $values = array();
-	var $geometry = array();
-	var $bbox = array();
-	var $doc;
-	function gml2(){
-		$this->geometries = array($this->geomtype_point, $this->geomtype_polygon, $this->geomtype_line, $this->geomtype_multipolygon, $this->geomtype_multiline);
-	function getGml($req){
-		$x = new connector($req);
-		return $x->file;
-	function parseFile($req){
-		#$data = implode("",file($req));
-		$data = $x->file;
-		$data = $this->removeWhiteSpace($data);
-		$this->parseXML($data);
-	function parseXML($data) {
-		$this->doc = $data;
-		return $this->toGeoJSON();
-	function removeWhiteSpace ($string) {
-		return preg_replace("/\>(\s)+\</", "><", trim($string));
-	function sepNameSpace($s){
-		$c = mb_strpos($s,":");
-		if($c>0){
-			return mb_substr($s,$c+1);
-		else{
-			return $s;
-	function toGeoJSON () {
-		$gmlDoc = new SimpleXMLElement($this->doc);
-		$gmlDoc->registerXPathNamespace('xls', 'http://www.opengis.net/xls');
-		$gmlDoc->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
-		// build feature collection
-		$featureCollection = new FeatureCollection();
-		// segments of the featzreCollection
-		$gmlFeatureMembers = $gmlDoc->xpath("//gml:featureMember");
-		$cnt=0;
-		foreach ($gmlFeatureMembers as $gmlFeatureMember) {
-			$featureMember_dom = dom_import_simplexml($gmlFeatureMember);
-			$feature = new Feature();
-			$feature->parse($featureMember_dom);
-			if (isset($feature->geometry)) {
-				$featureCollection->addFeature($feature);
-			$cnt++;
-		return $featureCollection->toGeoJSON();
-	 * Exports the file to SHP.
-	 * @param string $filenamePrefix the filename without an ending like .shp
-	function toShape ($filenamePrefix) {
-		$unique = TMPDIR . "/" . $filenamePrefix;
-		$fShape = $unique.".shp";
-		$fGml = $unique.".gml";
-//		$pathOgr = '/appserver/postgresql/templates/postgresql824/bin/ogr2ogr';
-		$pathOgr = '/usr/bin/ogr2ogr';
-		$w = $this->toFile($fGml);
- 		$exec = $pathOgr.' -f "ESRI Shapefile" "'.$fShape.'" '.$fGml;
- 		exec($exec);
- 		$exec = 'zip -j '.$unique.' '.$unique.'.shp '.$unique.'.dbf '.$unique.'.shx '.$unique.'.gfs '.$unique.'.gml ';
- 		exec($exec);
-		$exec = 'rm -f '.$unique.' '.$unique.'.shp '.$unique.'.dbf '.$unique.'.shx '.$unique.'.gfs '.$unique.'.gml';
-		exec($exec);
-		$exec = 'chmod 777 '.$unique.'.*';
-		exec($exec);
-		//echo "<a href='../tmp/".$unique.".zip'>Download ".$prefix."<a>";
-	 * Writes a file containing the GML.
-	 * @param string $path the path to the file.
-	 * @return bool true if the file could be saved; else false.
-	function toFile ($file) {
-		$handle = fopen($file, "w");
-		if (!$handle) {
-			$e = new mb_exception("class_gml2.php: Filehandler error (" . $file . ").");
-			return false;
-		if (!fwrite($handle,$this->__toString())) {
-			$e = new mb_exception("class_gml2.php: Could not write file (" . $file . ").");
-			fclose($handle);
-			return false;
-		fclose($handle);
-		return true;
-	function __toString () {
-		return $this->doc;
-	 * @deprecated
-	function parsegml($req){
-		$this->parse_xml($x->file);
-	 * @deprecated
-	function parse_xml($data){
-		$section = false;
-		$geom = false;
-		$boundedBy = false;
-		$coordinates = false;
-		$el = -1;
-		$parser = xml_parser_create(CHARSET);
-		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
-		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
-		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
-		xml_parse_into_struct($parser,$data,$values,$tags);
-		$code = xml_get_error_code ($parser);
-		if ($code) {
-			$line = xml_get_current_line_number($parser);
-			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
-		xml_parser_free($parser);
-		foreach ($values as $element) {
-			$e = new mb_exception($element[tag]);
-			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("boundedBy") && $element[type] == "open"){
-				$boundedBy = true;
-			if ($boundedBy) {
-				if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")){
-					$this->bbox = explode(",", str_replace(",,","",str_replace(" ",",",trim($element[value]))));
-					$boundedBy=false;
-			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "open"){
-				$this->member++;
-				$this->keys[$this->member] = array();
-				$this->value[$this->member] = array();
-				$this->geometry[$this->member] = array();
-				$section = true;
-				$cnt_geom = 0;
-			if($section == true){
-				if( in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "open"){
-					$geom = true;
-					$this->geomtype[$this->member] = $this->sepNameSpace($element[tag]);
-				else if(in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "close"){
-					$cnt_geom++;
-					$geom = false;
-				if($geom == true){
-					if (strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")) {
-						$this->geometry[$this->member][$cnt_geom] =  str_replace(",,","",str_replace(" ",",",trim($element[value])));
-						$coordinates = true;
-						// XXX: Increment counter to get all geometries of a feature member,
-						// comment it out to only show first geometry of featuremember
-						$cnt_geom++;
-					else if (!$coordinates && trim($element[value])) {
-						$coords = str_replace(",,","",str_replace(" ",",",trim($element[value])));
-						$tmp_array = explode(",", $coords);
-						if (count($tmp_array > 1)) {
-							$this->geometry[$this->member][$cnt_geom] =  $coords;
-							$cnt_geom++;
-				else if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "close"){
-					$section = false;
-					$el = -1;
-				else{
-					$el++;
-					$this->values[$this->member][$el] = $element[value];
-					$this->keys[$this->member][$el] = $element[tag];
-	 * @deprecated
-	function getMemberCount(){
-		return ($this->member+1);
-	 * @deprecated
-	function getValueBySeparatedKey($memberCount,$keyName){
-		for($i=0; $i<count($this->keys[$memberCount]); $i++){
-			if($this->sepNameSpace($this->keys[$memberCount][$i]) == $keyName){
-				return $this->values[$memberCount][$i];
-	 * @deprecated
-	function getValueByKey($memberCount,$keyName){
-			if($this->keys[$memberCount][$i] == $keyName){
-	 * @deprecated
-	function getXfromMemberAsString($memberCount,$geomCount){
-		$t = explode(",",$this->geometry[$memberCount][$geomCount]);
-		$x = array();
-		for($i=0; $i<(count($t)-1); $i=$i+2){
-			array_push($x,$t[$i]);
-		return implode(",",$x);
-	 * @deprecated
-	function getYfromMemberAsString($memberCount,$geomCount){
-		$y = array();
-		for($i=1; $i<=(count($t)-1); $i=$i+2){
-			array_push($y,$t[$i]);
-		return implode(",",$y);
-	 * @deprecated
-	function getGeometriesFromMember($memberCount){
-		return $this->geometry[$memberCount];
-	 * @deprecated
-	function getGeometryTypeFromMember($memberCount){
-		return 	$this->geomtype[$memberCount];
-	 * @deprecated
-	function exportGeometriesToJS ($isInFrame) {
-		$prefix = "";
-		if ($isInFrame == true) {
-			$prefix = "parent.";
-		$js = "";
-		$js .= "var geom = new ".$prefix."GeometryArray();\n";
-		for ($i=0; $i<count($this->geometry); $i++) {
-			$js .= $this->exportMemberToJS($i, $isInFrame);
-			$js .= "geom.addCopy(q);\n";
-		return $js;
-	 * @deprecated
-	function exportMemberToJS ($i, $isInFrame) {
-		$prefix = "";
-		$js = "";
-		if ($this->getGeometryTypeFromMember($i) == $this->geomtype_point) {
-			$js .= "var current_geomtype = ".$prefix."geomType.point;\n";
-		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_line || $this->getGeometryTypeFromMember($i) == $this->geomtype_multiline) {
-			$js .= "var current_geomtype = ".$prefix."geomType.line;\n";
-		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_polygon || $this->getGeometryTypeFromMember($i) == $this->geomtype_multipolygon) {
-			$js .= "var current_geomtype = ".$prefix."geomType.polygon;\n";
-		else die("unknown geometry type: '".$this->getGeometryTypeFromMember($i)."'");
-		$js .= "var q = new ".$prefix."MultiGeometry(current_geomtype);\n";
-		for ($j=0; $j<count($this->geometry[$i]); $j++) {
-			$js .= "q.addGeometry(current_geomtype);\n";
-			$x_array = explode(",", $this->getXfromMemberAsString($i, $j));
-			$y_array = explode(",", $this->getYfromMemberAsString($i, $j));
-			for ($k=0; $k<count($x_array); $k++) {
-				$js .= "q.get(-1).addPointByCoordinates(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));\n";
-				//$js .= "alert(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));";
-			$js .= "q.get(-1).close();\n";
-//		$js .= "alert(q);\n";
-		return $js;
-class FeatureCollection {
-	var $type = "FeatureCollection";
-	var $featureArray = array();
-	public function __construct() {
-	public function addFeature ($aFeature) {
-		array_push($this->featureArray, $aFeature);
-	public function toGeoJSON () {
-		$str = "";
-		$len = count($this->featureArray);
-		if ($len > 0) {
-			$str .= "{\"type\": \"FeatureCollection\", \"features\": [";
-			for ($i=0; $i < $len; $i++) {
-				if ($i > 0) {
-					$str .= ",";
-				$str .= $this->featureArray[$i]->toGeoJSON();
-			$str .= "]}";
-		return $str;
-class Feature {
-	var $type = "Feature";
-	var $fid;
-	var $geometry = false;
-	var $properties = array();
-		list($ns,$FeaturePropertyName) = split(":",$s);
-		$nodeName = array('ns' => $ns, 'value' => $FeaturePropertyName);
-		return $nodeName;
-	public function parse($domNode) {
-		$currentSibling = $domNode->firstChild;
-		$this->fid = $currentSibling->getAttribute("fid");
-		$currentSibling = $currentSibling->firstChild;
-		while ($currentSibling) {
-			$name = $currentSibling->nodeName;
-			$value = $currentSibling->nodeValue;
-			$namespace = $this->sepNameSpace($name);
-			$ns = $namespace['ns'];
-			$columnName = $namespace['value'];
-$e = new mb_exception($ns.":the_geom");
-			if ($name==$ns.":the_geom"){
-				$e = new mb_exception("in if");
-				$geomNode = $currentSibling->firstChild;
-					$geomType = $geomNode->nodeName;
-//					echo "geomtype: " . $geomType . "<br>";
-					switch ($geomType) {
-						case "gml:Polygon" :
-							$this->geometry = new GMLPolygon();
-							$this->geometry->parsePolygon($geomNode);
-							break;
-						case "gml:LineString" :
-							$this->geometry = new GMLLine();
-							$this->geometry->parseLine($geomNode);
-							break;
-						case "gml:Point" :
-						$e = new mb_exception("in point");
-							$this->geometry = new GMLPoint();
-							$this->geometry->parsePoint($geomNode);
-#							$this->properties["Mapbender:icon"] = "../img/sy_star.png";
-							break;
-						case "gml:MultiLineString" :
-							$this->geometry = new GMLMultiLine();
-							$this->geometry->parseMultiLine($geomNode);
-//							$this->properties["Mapbender:icon"] = "../img/sy_star.png";
-							break;
-						case "gml:MultiPolygon" :
-							$this->geometry = new GMLMultiPolygon();
-							$this->geometry->parseMultiPolygon($geomNode);
-							break;
-			} else {
-					$this->properties[$columnName] = $value;
-			$currentSibling = $currentSibling->nextSibling;
-		$str = "";
-		$str .= "{\"type\":\"Feature\", \"id\":\"".$this->fid."\", \"geometry\": ";
-		if ($this->geometry) {
-			$str .= $this->geometry->toGeoJSON();
-		else {
-			$str .= "\"\"";
-		$str .= ", \"properties\": {";
-		$cnt = 0;
-		foreach ($this->properties as $key => $value) {
-			if ($cnt > 0) {
-				$str .= ",";
-			$str .= "\"" . $key . "\":\"" . $value . "\"";
-			$cnt ++;
-		$str .= "}";
-		$str .= "}";
-		return $str;
-class GMLLine {
-	var $pointArray = array();
-	public function parseLine ($domNode) {
-			foreach(explode(' ',$currentSibling->nodeValue) as $cords){
-				list($x,$y,$z) = explode(',',$cords);
-				$this->addPoint($x, $y);
-	private function addPoint ($x, $y) {
-		array_push($this->pointArray, array("x" => $x, "y" => $y));
-		$numberOfPoints = count($this->pointArray);
-		$str = "";
-		if ($numberOfPoints > 0) {
-			$str .= "{\"type\": \"LineString\", \"coordinates\":[";
-			for ($i=0; $i < $numberOfPoints; $i++) {
-				if ($i > 0) {
-					$str .= ",";
-				$str .= "[".$this->pointArray[$i]["x"].",".$this->pointArray[$i]["y"]."]";
-			$str .= "]}";
-		else {
-			$e = new mb_exception("GMLLine: toGeoJSON: this point is null.");
-		return $str;
-class GMLPoint {
-	var $point;
-	public function parsePoint ($domNode) {
-			list($x, $y, $z) = explode(",", $currentSibling->nodeValue);
-			$this->setPoint($x, $y);
-	private function setPoint ($x, $y) {
-#		echo "x: " . $x . " y: " . $y . "\n";
-		$this->point = array("x" => $x, "y" => $y);
-		$str = "";
-		if ($this->point) {
-			$str .= "{\"type\": \"Point\", \"coordinates\":";
-			$str .= "[".$this->point["x"].",".$this->point["y"]."]";
-			$str .= "}";
-		else {
-			$e = new mb_exception("GMLPoint: toGeoJSON: this point is null.");
-		return $str;
-class GMLPolygon {
-	public function parsePolygon ($domNode) {
-		$simpleXMLNode = simplexml_import_dom($domNode);
-		$simpleXMLNode->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
-		$allCoords = $simpleXMLNode->xpath("gml:outerBoundaryIs/gml:LinearRing/gml:coordinates");
-		$cnt=0;
-		foreach ($allCoords as $Coords) {
-			$coordsDom = dom_import_simplexml($Coords);
-//			$name = $coordsDom->nodeName;
-//			$value = $coordsDom->nodeValue;
-//			echo "===> name: ".$name. ", Value: ".$value."<br>";
-			foreach(explode(' ',$coordsDom->nodeValue) as $pointCoords){
-				list($x,$y,$z) = explode(',',$pointCoords);
-			$cnt++;
-		$str = "";
-			$str .= "{\"type\": \"Polygon\", \"coordinates\":[[";
-				if ($i > 0) {
-					$str .= ",";
-			$str .= "]]}";
-		else {
-			$e = new mb_exception("GMLPolygon: toGeoJSON: this point is null.");
-		return $str;
-class GMLMultiLine {
-	var $lineArray = array();
-	public function parseMultiLine ($domNode) {
-		$allCoords = $simpleXMLNode->xpath("gml:lineStringMember/gml:LineString/gml:coordinates");
-		$cnt=0;
-			$this->lineArray[$cnt] = array();
-				$this->addPoint($x, $y, $cnt);
-			$cnt++;
-	private function addPoint ($x, $y, $i) {
-		array_push($this->lineArray[$i], array("x" => $x, "y" => $y));
-		$numberlineArray = count($this->lineArray);
-		$str = "";
-		if ($numberlineArray > 0) {
-			$str .= "{\"type\": \"MultiLineString\", \"coordinates\":[";
-			for ($cnt =0; $cnt < $numberlineArray; $cnt++){
-				if ($cnt > 0) {
-						$str .= ",";
-					$str .="[";
-				for ($i=0; $i < count($this->lineArray[$cnt]); $i++) {
-					if ($i > 0) {
-						$str .= ",";
-					$str .= "[".$this->lineArray[$cnt][$i]["x"].",".$this->lineArray[$cnt][$i]["y"]."]";
-				$str .="]";
-			$str .= "]}";
-		else {
-			$e = new mb_exception("GMLMultiLine: toGeoJSON: this multiLine is null.");
-		return $str;
-class GMLMultiPolygon {
-	var $polygonArray = array();
-	public function parseMultiPolygon ($domNode) {
-//		echo $domNode->nodeName."<br>";
-		$allCoords = $simpleXMLNode->xpath("gml:polygonMember/gml:Polygon/gml:outerBoundaryIs/gml:LinearRing/gml:coordinates");
-		$cnt=0;
-			$this->polygonArray[$cnt] = array();
-			$cnt++;
-		array_push($this->polygonArray[$i], array("x" => $x, "y" => $y));
-		$numberPolygonArray = count($this->polygonArray);
-		$str = "";
-		if ($numberPolygonArray > 0) {
-			$str .= "{\"type\": \"MultiPolygon\", \"coordinates\":[";
-			for ($cnt =0; $cnt < $numberPolygonArray; $cnt++){
-				if ($cnt > 0) {
-						$str .= ",";
-					$str .="[";
-				for ($i=0; $i < count($this->polygonArray[$cnt]); $i++) {
-					if ($i > 0) {
-						$str .= ",";
-					$str .= "[".$this->polygonArray[$cnt][$i]["x"].",".$this->polygonArray[$cnt][$i]["y"]."]";
-				$str .="]";
-			$str .= "]}";
-		else {
-			$e = new mb_exception("GMLMultiPolygon: toGeoJSON: this multiLine is null.");
-		return $str;
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_gml2.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once("class_mb_exception.php");
+require_once("class_connector.php");
+require_once("../../conf/mapbender.conf");
+class gml2 {
+	var $geomtype_point = 'Point';
+	var $geomtype_polygon = 'Polygon';
+	var $geomtype_line = 'LineString';
+	var $geomtype_multipolygon = 'MultiPolygon';
+	var $geomtype_multiline = 'MultiLine';
+	var $geometries = array();
+	var $member = -1;
+	var $geomtype = array();
+	var $keys = array();
+	var $values = array();
+	var $geometry = array();
+	var $bbox = array();
+	var $doc;
+	function gml2(){
+		$this->geometries = array($this->geomtype_point, $this->geomtype_polygon, $this->geomtype_line, $this->geomtype_multipolygon, $this->geomtype_multiline);
+	function getGml($req){
+		$x = new connector($req);
+		return $x->file;
+	function parseFile($req){
+		#$data = implode("",file($req));
+		$data = $x->file;
+		$data = $this->removeWhiteSpace($data);
+		$this->parseXML($data);
+	function parseXML($data) {
+		$this->doc = $data;
+		return $this->toGeoJSON();
+	function removeWhiteSpace ($string) {
+		return preg_replace("/\>(\s)+\</", "><", trim($string));
+	function sepNameSpace($s){
+		$c = mb_strpos($s,":");
+		if($c>0){
+			return mb_substr($s,$c+1);
+		else{
+			return $s;
+	function toGeoJSON () {
+		$gmlDoc = new SimpleXMLElement($this->doc);
+		$gmlDoc->registerXPathNamespace('xls', 'http://www.opengis.net/xls');
+		$gmlDoc->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
+		// build feature collection
+		$featureCollection = new FeatureCollection();
+		// segments of the featzreCollection
+		$gmlFeatureMembers = $gmlDoc->xpath("//gml:featureMember");
+		$cnt=0;
+		foreach ($gmlFeatureMembers as $gmlFeatureMember) {
+			$featureMember_dom = dom_import_simplexml($gmlFeatureMember);
+			$feature = new Feature();
+			$feature->parse($featureMember_dom);
+			if (isset($feature->geometry)) {
+				$featureCollection->addFeature($feature);
+			$cnt++;
+		return $featureCollection->toGeoJSON();
+	 * Exports the file to SHP.
+	 * @param string $filenamePrefix the filename without an ending like .shp
+	function toShape ($filenamePrefix) {
+		$unique = TMPDIR . "/" . $filenamePrefix;
+		$fShape = $unique.".shp";
+		$fGml = $unique.".gml";
+//		$pathOgr = '/appserver/postgresql/templates/postgresql824/bin/ogr2ogr';
+		$pathOgr = '/usr/bin/ogr2ogr';
+		$w = $this->toFile($fGml);
+ 		$exec = $pathOgr.' -f "ESRI Shapefile" "'.$fShape.'" '.$fGml;
+ 		exec($exec);
+ 		$exec = 'zip -j '.$unique.' '.$unique.'.shp '.$unique.'.dbf '.$unique.'.shx '.$unique.'.gfs '.$unique.'.gml ';
+ 		exec($exec);
+		$exec = 'rm -f '.$unique.' '.$unique.'.shp '.$unique.'.dbf '.$unique.'.shx '.$unique.'.gfs '.$unique.'.gml';
+		exec($exec);
+		$exec = 'chmod 777 '.$unique.'.*';
+		exec($exec);
+		//echo "<a href='../tmp/".$unique.".zip'>Download ".$prefix."<a>";
+	 * Writes a file containing the GML.
+	 * @param string $path the path to the file.
+	 * @return bool true if the file could be saved; else false.
+	function toFile ($file) {
+		$handle = fopen($file, "w");
+		if (!$handle) {
+			$e = new mb_exception("class_gml2.php: Filehandler error (" . $file . ").");
+			return false;
+		if (!fwrite($handle,$this->__toString())) {
+			$e = new mb_exception("class_gml2.php: Could not write file (" . $file . ").");
+			fclose($handle);
+			return false;
+		fclose($handle);
+		return true;
+	function __toString () {
+		return $this->doc;
+	 * @deprecated
+	function parsegml($req){
+		$this->parse_xml($x->file);
+	 * @deprecated
+	function parse_xml($data){
+		$section = false;
+		$geom = false;
+		$boundedBy = false;
+		$coordinates = false;
+		$el = -1;
+		$parser = xml_parser_create(CHARSET);
+		xml_parser_set_option($parser,XML_OPTION_CASE_FOLDING,0);
+		xml_parser_set_option($parser,XML_OPTION_SKIP_WHITE,1);
+		xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
+		xml_parse_into_struct($parser,$data,$values,$tags);
+		$code = xml_get_error_code ($parser);
+		if ($code) {
+			$line = xml_get_current_line_number($parser);
+			$mb_exception = new mb_exception(xml_error_string($code) .  " in line " . $line);
+		xml_parser_free($parser);
+		foreach ($values as $element) {
+			$e = new mb_exception($element[tag]);
+			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("boundedBy") && $element[type] == "open"){
+				$boundedBy = true;
+			if ($boundedBy) {
+				if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")){
+					$this->bbox = explode(",", str_replace(",,","",str_replace(" ",",",trim($element[value]))));
+					$boundedBy=false;
+			if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "open"){
+				$this->member++;
+				$this->keys[$this->member] = array();
+				$this->value[$this->member] = array();
+				$this->geometry[$this->member] = array();
+				$section = true;
+				$cnt_geom = 0;
+			if($section == true){
+				if( in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "open"){
+					$geom = true;
+					$this->geomtype[$this->member] = $this->sepNameSpace($element[tag]);
+				else if(in_array($this->sepNameSpace($element[tag]),$this->geometries) && $element[type] == "close"){
+					$cnt_geom++;
+					$geom = false;
+				if($geom == true){
+					if (strtoupper($this->sepNameSpace($element[tag])) == strtoupper("coordinates")) {
+						$this->geometry[$this->member][$cnt_geom] =  str_replace(",,","",str_replace(" ",",",trim($element[value])));
+						$coordinates = true;
+						// XXX: Increment counter to get all geometries of a feature member,
+						// comment it out to only show first geometry of featuremember
+						$cnt_geom++;
+					else if (!$coordinates && trim($element[value])) {
+						$coords = str_replace(",,","",str_replace(" ",",",trim($element[value])));
+						$tmp_array = explode(",", $coords);
+						if (count($tmp_array > 1)) {
+							$this->geometry[$this->member][$cnt_geom] =  $coords;
+							$cnt_geom++;
+				else if(strtoupper($this->sepNameSpace($element[tag])) == strtoupper("featureMember") && $element[type] == "close"){
+					$section = false;
+					$el = -1;
+				else{
+					$el++;
+					$this->values[$this->member][$el] = $element[value];
+					$this->keys[$this->member][$el] = $element[tag];
+	 * @deprecated
+	function getMemberCount(){
+		return ($this->member+1);
+	 * @deprecated
+	function getValueBySeparatedKey($memberCount,$keyName){
+		for($i=0; $i<count($this->keys[$memberCount]); $i++){
+			if($this->sepNameSpace($this->keys[$memberCount][$i]) == $keyName){
+				return $this->values[$memberCount][$i];
+	 * @deprecated
+	function getValueByKey($memberCount,$keyName){
+			if($this->keys[$memberCount][$i] == $keyName){
+	 * @deprecated
+	function getXfromMemberAsString($memberCount,$geomCount){
+		$t = explode(",",$this->geometry[$memberCount][$geomCount]);
+		$x = array();
+		for($i=0; $i<(count($t)-1); $i=$i+2){
+			array_push($x,$t[$i]);
+		return implode(",",$x);
+	 * @deprecated
+	function getYfromMemberAsString($memberCount,$geomCount){
+		$y = array();
+		for($i=1; $i<=(count($t)-1); $i=$i+2){
+			array_push($y,$t[$i]);
+		return implode(",",$y);
+	 * @deprecated
+	function getGeometriesFromMember($memberCount){
+		return $this->geometry[$memberCount];
+	 * @deprecated
+	function getGeometryTypeFromMember($memberCount){
+		return 	$this->geomtype[$memberCount];
+	 * @deprecated
+	function exportGeometriesToJS ($isInFrame) {
+		$prefix = "";
+		if ($isInFrame == true) {
+			$prefix = "parent.";
+		$js = "";
+		$js .= "var geom = new ".$prefix."GeometryArray();\n";
+		for ($i=0; $i<count($this->geometry); $i++) {
+			$js .= $this->exportMemberToJS($i, $isInFrame);
+			$js .= "geom.addCopy(q);\n";
+		return $js;
+	 * @deprecated
+	function exportMemberToJS ($i, $isInFrame) {
+		$prefix = "";
+		$js = "";
+		if ($this->getGeometryTypeFromMember($i) == $this->geomtype_point) {
+			$js .= "var current_geomtype = ".$prefix."geomType.point;\n";
+		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_line || $this->getGeometryTypeFromMember($i) == $this->geomtype_multiline) {
+			$js .= "var current_geomtype = ".$prefix."geomType.line;\n";
+		elseif ($this->getGeometryTypeFromMember($i) == $this->geomtype_polygon || $this->getGeometryTypeFromMember($i) == $this->geomtype_multipolygon) {
+			$js .= "var current_geomtype = ".$prefix."geomType.polygon;\n";
+		else die("unknown geometry type: '".$this->getGeometryTypeFromMember($i)."'");
+		$js .= "var q = new ".$prefix."MultiGeometry(current_geomtype);\n";
+		for ($j=0; $j<count($this->geometry[$i]); $j++) {
+			$js .= "q.addGeometry(current_geomtype);\n";
+			$x_array = explode(",", $this->getXfromMemberAsString($i, $j));
+			$y_array = explode(",", $this->getYfromMemberAsString($i, $j));
+			for ($k=0; $k<count($x_array); $k++) {
+				$js .= "q.get(-1).addPointByCoordinates(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));\n";
+				//$js .= "alert(parseFloat(".$x_array[$k]."), parseFloat(".$y_array[$k]."));";
+			$js .= "q.get(-1).close();\n";
+//		$js .= "alert(q);\n";
+		return $js;
+class FeatureCollection {
+	var $type = "FeatureCollection";
+	var $featureArray = array();
+	public function __construct() {
+	public function addFeature ($aFeature) {
+		array_push($this->featureArray, $aFeature);
+	public function toGeoJSON () {
+		$str = "";
+		$len = count($this->featureArray);
+		if ($len > 0) {
+			$str .= "{\"type\": \"FeatureCollection\", \"features\": [";
+			for ($i=0; $i < $len; $i++) {
+				if ($i > 0) {
+					$str .= ",";
+				$str .= $this->featureArray[$i]->toGeoJSON();
+			$str .= "]}";
+		return $str;
+class Feature {
+	var $type = "Feature";
+	var $fid;
+	var $geometry = false;
+	var $properties = array();
+		list($ns,$FeaturePropertyName) = split(":",$s);
+		$nodeName = array('ns' => $ns, 'value' => $FeaturePropertyName);
+		return $nodeName;
+	public function parse($domNode) {
+		$currentSibling = $domNode->firstChild;
+		$this->fid = $currentSibling->getAttribute("fid");
+		$currentSibling = $currentSibling->firstChild;
+		while ($currentSibling) {
+			$name = $currentSibling->nodeName;
+			$value = $currentSibling->nodeValue;
+			$namespace = $this->sepNameSpace($name);
+			$ns = $namespace['ns'];
+			$columnName = $namespace['value'];
+			if ($name==$ns.":the_geom"){
+				$geomNode = $currentSibling->firstChild;
+					$geomType = $geomNode->nodeName;
+//					echo "geomtype: " . $geomType . "<br>";
+					switch ($geomType) {
+						case "gml:Polygon" :
+							$this->geometry = new GMLPolygon();
+							$this->geometry->parsePolygon($geomNode);
+							break;
+						case "gml:LineString" :
+							$this->geometry = new GMLLine();
+							$this->geometry->parseLine($geomNode);
+							break;
+						case "gml:Point" :
+							$this->geometry = new GMLPoint();
+							$this->geometry->parsePoint($geomNode);
+#							$this->properties["Mapbender:icon"] = "../img/sy_star.png";
+							break;
+						case "gml:MultiLineString" :
+							$this->geometry = new GMLMultiLine();
+							$this->geometry->parseMultiLine($geomNode);
+//							$this->properties["Mapbender:icon"] = "../img/sy_star.png";
+							break;
+						case "gml:MultiPolygon" :
+							$this->geometry = new GMLMultiPolygon();
+							$this->geometry->parseMultiPolygon($geomNode);
+							break;
+			} else {
+					$this->properties[$columnName] = $value;
+			$currentSibling = $currentSibling->nextSibling;
+		$str = "";
+		$str .= "{\"type\":\"Feature\", \"id\":\"".$this->fid."\", \"geometry\": ";
+		if ($this->geometry) {
+			$str .= $this->geometry->toGeoJSON();
+		else {
+			$str .= "\"\"";
+		$str .= ", \"properties\": {";
+		$cnt = 0;
+		foreach ($this->properties as $key => $value) {
+			if ($cnt > 0) {
+				$str .= ",";
+			$str .= "\"" . $key . "\":\"" . $value . "\"";
+			$cnt ++;
+		$str .= "}";
+		$str .= "}";
+		return $str;
+class GMLLine {
+	var $pointArray = array();
+	public function parseLine ($domNode) {
+			foreach(explode(' ',$currentSibling->nodeValue) as $cords){
+				list($x,$y,$z) = explode(',',$cords);
+				$this->addPoint($x, $y);
+	private function addPoint ($x, $y) {
+		array_push($this->pointArray, array("x" => $x, "y" => $y));
+		$numberOfPoints = count($this->pointArray);
+		$str = "";
+		if ($numberOfPoints > 0) {
+			$str .= "{\"type\": \"LineString\", \"coordinates\":[";
+			for ($i=0; $i < $numberOfPoints; $i++) {
+				if ($i > 0) {
+					$str .= ",";
+				$str .= "[".$this->pointArray[$i]["x"].",".$this->pointArray[$i]["y"]."]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLLine: toGeoJSON: this point is null.");
+		return $str;
+class GMLPoint {
+	var $point;
+	public function parsePoint ($domNode) {
+			list($x, $y, $z) = explode(",", $currentSibling->nodeValue);
+			$this->setPoint($x, $y);
+	private function setPoint ($x, $y) {
+#		echo "x: " . $x . " y: " . $y . "\n";
+		$this->point = array("x" => $x, "y" => $y);
+		$str = "";
+		if ($this->point) {
+			$str .= "{\"type\": \"Point\", \"coordinates\":";
+			$str .= "[".$this->point["x"].",".$this->point["y"]."]";
+			$str .= "}";
+		else {
+			$e = new mb_exception("GMLPoint: toGeoJSON: this point is null.");
+		return $str;
+class GMLPolygon {
+	public function parsePolygon ($domNode) {
+		$simpleXMLNode = simplexml_import_dom($domNode);
+		$simpleXMLNode->registerXPathNamespace('gml', 'http://www.opengis.net/gml');
+		$allCoords = $simpleXMLNode->xpath("gml:outerBoundaryIs/gml:LinearRing/gml:coordinates");
+		$cnt=0;
+		foreach ($allCoords as $Coords) {
+			$coordsDom = dom_import_simplexml($Coords);
+//			$name = $coordsDom->nodeName;
+//			$value = $coordsDom->nodeValue;
+//			echo "===> name: ".$name. ", Value: ".$value."<br>";
+			foreach(explode(' ',$coordsDom->nodeValue) as $pointCoords){
+				list($x,$y,$z) = explode(',',$pointCoords);
+			$cnt++;
+		$str = "";
+			$str .= "{\"type\": \"Polygon\", \"coordinates\":[[";
+				if ($i > 0) {
+					$str .= ",";
+			$str .= "]]}";
+		else {
+			$e = new mb_exception("GMLPolygon: toGeoJSON: this point is null.");
+		return $str;
+class GMLMultiLine {
+	var $lineArray = array();
+	public function parseMultiLine ($domNode) {
+		$allCoords = $simpleXMLNode->xpath("gml:lineStringMember/gml:LineString/gml:coordinates");
+		$cnt=0;
+			$this->lineArray[$cnt] = array();
+				$this->addPoint($x, $y, $cnt);
+			$cnt++;
+	private function addPoint ($x, $y, $i) {
+		array_push($this->lineArray[$i], array("x" => $x, "y" => $y));
+		$numberlineArray = count($this->lineArray);
+		$str = "";
+		if ($numberlineArray > 0) {
+			$str .= "{\"type\": \"MultiLineString\", \"coordinates\":[";
+			for ($cnt =0; $cnt < $numberlineArray; $cnt++){
+				if ($cnt > 0) {
+						$str .= ",";
+					$str .="[";
+				for ($i=0; $i < count($this->lineArray[$cnt]); $i++) {
+					if ($i > 0) {
+						$str .= ",";
+					$str .= "[".$this->lineArray[$cnt][$i]["x"].",".$this->lineArray[$cnt][$i]["y"]."]";
+				$str .="]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLMultiLine: toGeoJSON: this multiLine is null.");
+		return $str;
+class GMLMultiPolygon {
+	var $polygonArray = array();
+	public function parseMultiPolygon ($domNode) {
+//		echo $domNode->nodeName."<br>";
+		$allCoords = $simpleXMLNode->xpath("gml:polygonMember/gml:Polygon/gml:outerBoundaryIs/gml:LinearRing/gml:coordinates");
+		$cnt=0;
+			$this->polygonArray[$cnt] = array();
+			$cnt++;
+		array_push($this->polygonArray[$i], array("x" => $x, "y" => $y));
+		$numberPolygonArray = count($this->polygonArray);
+		$str = "";
+		if ($numberPolygonArray > 0) {
+			$str .= "{\"type\": \"MultiPolygon\", \"coordinates\":[";
+			for ($cnt =0; $cnt < $numberPolygonArray; $cnt++){
+				if ($cnt > 0) {
+						$str .= ",";
+					$str .="[";
+				for ($i=0; $i < count($this->polygonArray[$cnt]); $i++) {
+					if ($i > 0) {
+						$str .= ",";
+					$str .= "[".$this->polygonArray[$cnt][$i]["x"].",".$this->polygonArray[$cnt][$i]["y"]."]";
+				$str .="]";
+			$str .= "]}";
+		else {
+			$e = new mb_exception("GMLMultiPolygon: toGeoJSON: this multiLine is null.");
+		return $str;
\ No newline at end of file
More information about the Mapbender_commits mailing list
