[Mapbender-commits] r2069 - trunk/mapbender/resources/db/update
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Feb 7 07:45:28 EST 2008
Author: verenadiewald
Date: 2008-02-07 07:45:27 -0500 (Thu, 07 Feb 2008)
New Revision: 2069
   trunk/mapbender/resources/db/update/update_mysql_db.sql
added ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
Modified: trunk/mapbender/resources/db/update/update_mysql_db.sql
--- trunk/mapbender/resources/db/update/update_mysql_db.sql	2008-02-07 12:40:36 UTC (rev 2068)
+++ trunk/mapbender/resources/db/update/update_mysql_db.sql	2008-02-07 12:45:27 UTC (rev 2069)
@@ -8,7 +8,9 @@
 -- table wfs_conf_element: change in WFS configuration: access to geometries may now be restricted
  ALTER TABLE wfs_conf_element ADD COLUMN f_auth_varname VARCHAR(50) NULL;
+ ALTER TABLE wfs_conf add COLUMN wfs_conf_description text;
 ALTER TABLE wfs_conf_element ADD COLUMN f_show_detail int4;
+ALTER TABLE wfs_conf_element ADD COLUMN f_operator VARCHAR(50);
 -- table gui_element: new column for translation
More information about the Mapbender_commits mailing list
