[Mapbender-commits] r2074 - branches/2.5/http/classes
svn_mapbender at osgeo.org
Fri Feb 8 07:56:06 EST 2008
Author: verenadiewald
Date: 2008-02-08 07:56:06 -0500 (Fri, 08 Feb 2008)
New Revision: 2074
branches/2.5/http/classes/class_connector.php
check if it is a xml string in function getHTTP()
Modified: branches/2.5/http/classes/class_connector.php
--- branches/2.5/http/classes/class_connector.php 2008-02-08 12:55:06 UTC (rev 2073)
+++ branches/2.5/http/classes/class_connector.php 2008-02-08 12:56:06 UTC (rev 2074)
@@ -92,7 +92,7 @@
$e = new mb_exception("class_connector.php: invalid http type '" . $value . "'");
break;
case "httpType":
if (in_array(mb_strtoupper($value), array("POST", "GET"))) {
$this->httpType = $value;
@@ -159,8 +159,8 @@
private function getHTTP($url){
if ($this->httpType == "get") {
- return @file_get_contents($url);
+ return @file_get_contents($url);
else {
$urlComponentArray = parse_url($url);
$host = $urlComponentArray["host"];
@@ -169,7 +169,6 @@
$port = 80;
$path = $urlComponentArray["path"];
$buf = '';
$fp = fsockopen($host, $port);
fputs($fp, "POST $path HTTP/".$this->httpVersion . "\r\n");
@@ -180,9 +179,16 @@
fputs($fp, "Content-length: " . strlen($this->httpPostData) . "\r\n");
fputs($fp, "Connection: close\r\n\r\n");
fputs($fp, $this->httpPostData);
+ $xmlstr = false;
while (!feof($fp)) {
- $buf .= fgets($fp,4096);
+ $content = fgets($fp,4096);
+ if( strpos($content, '<?xml') === 0){
+ $xmlstr = true;
+ if($xmlstr == true){
+ $buf .= $content;
fclose($fp);
return $buf;
More information about the Mapbender_commits
