[Mapbender-commits] r2088 - branches/2.5/http/php
    svn_mapbender at osgeo.org
    Fri Feb 15 03:24:39 EST 2008
Author: verenadiewald
Date: 2008-02-15 03:24:37 -0500 (Fri, 15 Feb 2008)
New Revision: 2088
   branches/2.5/http/php/mod_wfs_conf.php
   branches/2.5/http/php/mod_wfs_edit.php
updated code for new wfs conf parameters f_auth_varname etc.
Modified: branches/2.5/http/php/mod_wfs_conf.php
--- branches/2.5/http/php/mod_wfs_conf.php	2008-02-14 14:40:34 UTC (rev 2087)
+++ branches/2.5/http/php/mod_wfs_conf.php	2008-02-15 08:24:37 UTC (rev 2088)
@@ -60,6 +60,14 @@
 function validate(){
 	return true;
+function removeChildNodes(node) {
+	while (node.childNodes.length > 0) {
+		var childNode = node.firstChild;
+		node.removeChild(childNode);
 </script>
 </head>
@@ -90,81 +98,67 @@
         db_select_db($DB,$con);
-        $sql = "INSERT INTO wfs_conf (";
-        $sql .= "wfs_conf_abstract, wfs_conf_description, fkey_wfs_id, ";
-        $sql .= "fkey_featuretype_id, g_label, g_label_id, g_button, ";
-        $sql .= "g_button_id, g_style, g_buffer, g_res_style, g_use_wzgraphics";
-		$sql .= ") VALUES ($1, $2, $3, $4, $5, $6, $7, $8, $9, $10, $11, ";
-        if (!empty($_REQUEST["g_use_wzgraphics"])) {
+        $sql = "INSERT INTO wfs_conf (wfs_conf_abstract,wfs_conf_description,fkey_wfs_id,fkey_featuretype_id,g_label,g_label_id,g_button,g_button_id,g_style,g_buffer,g_res_style,g_use_wzgraphics) VALUES(";
+        $sql .= "'".$_REQUEST["wfs_conf_abstract"]."',";
+        $sql .= "'".$_REQUEST["wfs_conf_description"]."',";
+        $sql .= "'".$_REQUEST["wfs"]."',";
+        $sql .= "'".$_REQUEST["featuretype"]."',";
+        $sql .= "'".$_REQUEST["g_label"]."',";
+        $sql .= "'".$_REQUEST["g_label_id"]."',";
+        $sql .= "'".$_REQUEST["g_button"]."',";
+        $sql .= "'".$_REQUEST["g_button_id"]."',";
+        $sql .= "'".$_REQUEST["g_style"]."',";
+        $sql .= "'".$_REQUEST["g_buffer"]."',";
+        $sql .= "'".$_REQUEST["g_res_style"]."',";
+        if(!empty($_REQUEST["g_use_wzgraphics"])){
 			$sql .= "'1'";
-		else {
-			$sql .= "'0'";
+		}else{$sql .= "'0'";}
         $sql .= "); ";
-		$v = array($_REQUEST["wfs_conf_abstract"], $_REQUEST["wfs_conf_description"], $_REQUEST["wfs"], $_REQUEST["featuretype"], $_REQUEST["g_label"], $_REQUEST["g_label_id"], $_REQUEST["g_button"], $_REQUEST["g_button_id"], $_REQUEST["g_style"], $_REQUEST["g_buffer"], $_REQUEST["g_res_style"]);
-		$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s", "s", "s");
-        $res = db_prep_query($sql, $v, $t);
-        $wfsID = db_insert_id($con,'wfs_conf','wfs_conf_id');
-        for ($i = 0; $i < $_REQUEST["num"]; $i++){
+        $res = db_query($sql);
+        $wfsID = db_insert_id($con,'wfs_conf','wfs_conf_id');
+        for($i=0; $i<$_REQUEST["num"]; $i++){
                 $sql = "INSERT INTO wfs_conf_element (fkey_wfs_conf_id,f_id,f_search,f_pos,f_style_id,f_toupper,f_label,f_label_id,f_show,f_respos,f_edit,f_form_element_html,f_mandatory,f_auth_varname,f_show_detail) VALUES(";
-                $sql .= "$1, $2, ";
-                if (!empty($_REQUEST["f_search".$i])) {
+                $sql .= "'".$wfsID."',";
+                $sql .= "'".$_REQUEST["f_id".$i]."',";
+                if(!empty($_REQUEST["f_search".$i])){
+                	$sql .= "'1',";
+                }else{$sql .= "'0',";}
+                $sql .= "'".$_REQUEST["f_pos".$i]."',";
+                $sql .= "'".$_REQUEST["f_style_id".$i]."',";
+				if(!empty($_REQUEST["f_toupper".$i])){
+                	$sql .= "'1',";
+                $sql .= "'".$_REQUEST["f_label".$i]."',";
+                $sql .= "'".$_REQUEST["f_label_id".$i]."',";
+                if(!empty($_REQUEST["f_show".$i])){
+                	$sql .= "'1',";
+                $sql .= "'".$_REQUEST["f_respos".$i]."'";
+				$sql .= ",";
+                if(!empty($_REQUEST["f_edit".$i])){
+                	$sql .= "'1',";
+                $sql .= "'".$_REQUEST["f_form_element_html".$i]."',";
+                if(!empty($_REQUEST["f_mandatory".$i])){
                 	$sql .= "'1'";
-                else {
-                	$sql .= "'0'";
-                $sql .= ", $3, $4, ";
-				if (!empty($_REQUEST["f_toupper".$i])) {
-                	$sql .= "'1'";
-                else {
-                	$sql .= "'0'";
-                $sql .= ",$5, $6, ";
-                if (!empty($_REQUEST["f_show".$i])) {
-                	$sql .= "'1'";
-                else {
-                	$sql .= "'0',";
-                $sql .= ", $7, ";
-                if (!empty($_REQUEST["f_edit".$i])) {
-                	$sql .= "'1'";
-                else {
-                	$sql .= "'0'";
-                $sql .= ",$8, ";
-                if (!empty($_REQUEST["f_mandatory".$i])) {
-                	$sql .= "'1'";
-                else {
-                	$sql .= "'0'";
-                $sql .= ", $9, ";
-              	if (!empty($_REQUEST["f_show_detail".$i])) {
+                $sql .= ", ";
+                $sql .= "'".$_REQUEST["f_auth_varname".$i];
+				$sql .= "'";
+				$sql .= ", ";
+				if(!empty($_REQUEST["f_show_detail".$i])){
             		$sql .= "'1'";
-                else {
-                	$sql .= "'0'";
-				$sql .= "); ";
+               $sql .= "); ";
-				$v = array($wfsID, $_REQUEST["f_id".$i], $_REQUEST["f_pos".$i], $_REQUEST["f_style_id".$i], $_REQUEST["f_label".$i], $_REQUEST["f_label_id".$i], $_REQUEST["f_respos".$i], $_REQUEST["f_form_element_html".$i], $_REQUEST["f_auth_varname".$i]);
-				$t = array("s", "s", "s", "s", "s", "s", "s", "s", "s");
         if (isset($_REQUEST["f_geom"])) {
-	        $sql = "UPDATE wfs_conf_element SET f_geom = 1 ";
-	        $sql .= "WHERE fkey_wfs_conf_id = $1 AND f_id = $2;";
-	        $v = array($wfsID, $_REQUEST["f_geom"]);
-	        $t = array("i", "i");
+	        $sql = "UPDATE wfs_conf_element SET ";
+	        $sql .= "f_geom = 1";
+	        $sql .= " WHERE fkey_wfs_conf_id = ".$wfsID." AND f_id = ".$_REQUEST["f_geom"].";";
 		echo "<script language='javascript'>";
 		echo "document.location.href = 'mod_wfs_edit.php?gaz=".$wfsID."';";
@@ -275,6 +269,7 @@
                 echo "<td>" . toImage('edit') . "</td>";
                 echo "<td>" . toImage('html') . "</td>";
                 echo "<td>" . toImage('auth') . "</td>";
         echo "</tr>";
         for($i=0; $i<count($aWFS->elements->element_id); $i++){
@@ -293,7 +288,7 @@
                 echo "<td><input name='f_respos".$i."' type='text' size='1' value='0'></td>";
                 echo "<td><input name='f_mandatory".$i."' type='checkbox'></td>";
                 echo "<td><input name='f_edit".$i."' type='checkbox'></td>";
-                echo "<td><textarea name='f_form_element_html".$i."' cols='15' rows='1' ></textarea></td>";
+                echo "<td><textarea name='f_form_element_html".$i."' cols='15' rows='1'></textarea></td>";
                 echo "<td><input name='f_auth_varname".$i."' type='text' size='8' value=''></td>";
                 echo "</tr>";
Modified: branches/2.5/http/php/mod_wfs_edit.php
--- branches/2.5/http/php/mod_wfs_edit.php	2008-02-14 14:40:34 UTC (rev 2087)
+++ branches/2.5/http/php/mod_wfs_edit.php	2008-02-15 08:24:37 UTC (rev 2088)
@@ -41,6 +41,18 @@
 	return true;
+function openwindow(Adresse) {
+	Fenster1 = window.open(Adresse, "GeoPortal Rheinland-Pfalz - Metadaten", "width=500,height=500,left=100,top=100,scrollbars=yes,resizable=no");
+	Fenster1.focus();
 </script>
 </head>
@@ -56,99 +68,92 @@
 $con = db_connect($DBSERVER,$OWNER,$PW);
-if (isset($_REQUEST["save"])) {
+if(isset($_REQUEST["save"])){
         $sql = "UPDATE wfs_conf SET ";
-        $sql .= "wfs_conf_abstract = $1, wfs_conf_description = $2, g_label = $3, ";
-        $sql .= "g_label_id = $4, g_button = $5, g_button_id = $6, g_style = $7, ";
-        $sql .= "g_buffer = $8, g_res_style = $9, g_use_wzgraphics = ";
-        	$sql .= "1";
-        else {
-        	$sql .= "0";
-        $sql .= " WHERE wfs_conf_id = $10;";
+        $sql .= "wfs_conf_abstract = '".$_REQUEST["wfs_conf_abstract"]."',";
+        $sql .= "wfs_conf_description = '".$_REQUEST["wfs_conf_description"]."',";
+        $sql .= "g_label = '".$_REQUEST["g_label"]."',";
+        $sql .= "g_label_id = '".$_REQUEST["g_label_id"]."',";
+        $sql .= "g_button = '".$_REQUEST["g_button"]."',";
+        $sql .= "g_button_id = '".$_REQUEST["g_button_id"]."',";
+        $sql .= "g_style = '".$_REQUEST["g_style"]."',";
+        $sql .= "g_buffer = '".$_REQUEST["g_buffer"]."',";
+        $sql .= "g_res_style = '".$_REQUEST["g_res_style"]."',";
+        $sql .= "g_use_wzgraphics = ";
+        	$sql .= '1';
+        }else{$sql .= '0';}
+        $sql .= " WHERE wfs_conf_id = ".$_REQUEST["gaz"].";";
-        $v = array($_REQUEST["wfs_conf_abstract"], $_REQUEST["wfs_conf_description"], $_REQUEST["g_label"], $_REQUEST["g_label_id"], $_REQUEST["g_button"], $_REQUEST["g_button_id"], $_REQUEST["g_style"], $_REQUEST["g_buffer"], $_REQUEST["g_res_style"], $_REQUEST["gaz"]);
-        $t = array("s", "s", "s", "s", "s", "s", "s", "i", "s", "i");
-	        $v = array($_REQUEST["gaz"], $_REQUEST["f_geom"]);
-	        $t = array("i", "s");
-			$res = db_prep_query($sql);
+	        $sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id = ".$_REQUEST["f_geom"].";";
-			$sql = "UPDATE wfs_conf_element SET f_geom = 0 ";
-	        $sql .= "WHERE fkey_wfs_conf_id = $1 AND f_id <> $2;";
+	        $sql .= "f_geom = 0";
+	        $sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id <>  ".$_REQUEST["f_geom"].";";
 		else {
-	        $sql .= "WHERE fkey_wfs_conf_id = $1;";
-	        $v = array($_REQUEST["gaz"]);
-	        $t = array("i");
+	        $sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"].";";
-                $sql = "UPDATE wfs_conf_element SET f_search = '";
-                	$sql .= "1";
-                else {
-                	$sql .= "0";
-                $sql .= "', f_pos = $1, f_style_id = $2,";
+                $sql .= "f_search = '";
+                	$sql .= '1';
+                $sql .= "',";
+                $sql .= "f_pos = '".$_REQUEST["f_pos".$i]."',";
+                $sql .= "f_style_id = '".$_REQUEST["f_style_id".$i]."',";
                 $sql .= "f_toupper = '" ;
-                	$sql .= "1";
-                else {
-                	$sql .= "0";
-                $sql .= "',f_label = $3, f_label_id = $4,";
+                	$sql .= '1';
+                $sql .= "',";
+                $sql .= "f_label = '".$_REQUEST["f_label".$i]."',";
+                $sql .= "f_label_id = '".$_REQUEST["f_label_id".$i]."',";
                 $sql .= "f_show = '";
-                	$sql .= "1";
-                else {
-                	$sql .= "0";
-				$sql .= "',f_respos = $5,";
+                	$sql .= '1';
+				$sql .= "',";
+                $sql .= "f_respos = '".$_REQUEST["f_respos".$i]."' ";
+				$sql .= ",";
                 $sql .= "f_edit = '";
-                	$sql .= "1";
-                else {
-                	$sql .= "0";
-				$sql .= "', f_form_element_html = $6,";
+                	$sql .= '1';
+				$sql .= "',";
+                $sql .= "f_form_element_html = '".addslashes($_REQUEST["f_form_element_html".$i]);
+				$sql .= "',";
                 $sql .= "f_mandatory = '";
                 	$sql .= "1";
-                else {
-                	$sql .= "0";
-				$sql .= "', f_auth_varname = $7,";
-                $sql .= "f_show_detail = '";
-                	$sql .= "1";
-                else {
-                	$sql .= "0";
-				$sql .= "' WHERE fkey_wfs_conf_id = $8 AND f_id = $9;";
-				$v = array($_REQUEST["f_pos".$i], $_REQUEST["f_style_id".$i], $_REQUEST["f_label".$i], $_REQUEST["f_label_id".$i], $_REQUEST["f_respos".$i], addslashes($_REQUEST["f_form_element_html".$i]), $_REQUEST["f_auth_varname".$i], $_REQUEST["gaz"], $_REQUEST["f_id".$i]);
-				$t = array("s", "s", "s", "s", "s", "s", "s", "i", "s");
+                }else{$sql .= "0";}
+				$sql .= "'";
+                $sql .= ", ";
+                $sql .= "f_auth_varname = '".$_REQUEST["f_auth_varname".$i];
+				$sql .= "'";
+				$sql .= ", ";
+				$sql .= "f_show_detail = '";
+                	$sql .= '1';
+                $sql .= "'";
+				$sql .= " WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." AND f_id = ".$_REQUEST["f_id".$i].";";
@@ -185,13 +190,12 @@
 /* configure elements */
-if (isset($_REQUEST["gaz"])) {
-        $sql = "SELECT * FROM wfs_conf WHERE wfs_conf_id = $1";
-        $t = array("i");
+if(isset($_REQUEST["gaz"])){
+        $sql = "SELECT * FROM wfs_conf WHERE wfs_conf_id = ".$_REQUEST["gaz"];
         if($row = db_fetch_array($res)){
                 echo "<table>";
+                #echo "<tr><td><a onclick='openwindow(this.href); return false' target='_blank' href='../x_geoportal/mod_featuretypeMetadata.php?wfs_conf_id=".$row["wfs_conf_id"]."'>Link zum WFS</a></td></tr>";
                 echo "<tr><td>GazetterID:</td><td>".$row["wfs_conf_id"]."</td></tr>" ;
                 echo "<tr><td>Title:</td><td><input type='text' name='wfs_conf_abstract' value='".$row["wfs_conf_abstract"]."'></td></tr>" ;
                 echo "<tr><td>Description:</td><td><input type='text' name='wfs_conf_description' value='".$row["wfs_conf_description"]."'></td></tr>" ;
@@ -211,10 +215,9 @@
         /* set element options */
         $sql = "SELECT * FROM wfs_conf_element ";
         $sql .= "JOIN wfs_element ON wfs_conf_element.f_id = wfs_element.element_id ";
-        $sql .= "WHERE fkey_wfs_conf_id = $1 ORDER BY f_id";
-		$t = array("i");
+        $sql .= "WHERE fkey_wfs_conf_id = ".$_REQUEST["gaz"]." ORDER BY f_id";
         echo "<table border='1'>";
         echo "<tr valign = bottom>";
@@ -234,6 +237,7 @@
         echo "</tr>";
         $cnt = 0;
         while($row = db_fetch_array($res)){
More information about the Mapbender_commits
