[Mapbender-commits] r2096 - branches/2.5/http/javascripts
svn_mapbender at osgeo.org
Tue Feb 19 08:37:57 EST 2008
Author: christoph
Date: 2008-02-19 08:37:57 -0500 (Tue, 19 Feb 2008)
New Revision: 2096
branches/2.5/http/javascripts/map.js
jslinted
Modified: branches/2.5/http/javascripts/map.js
--- branches/2.5/http/javascripts/map.js 2008-02-18 14:18:16 UTC (rev 2095)
+++ branches/2.5/http/javascripts/map.js 2008-02-19 13:37:57 UTC (rev 2096)
@@ -90,7 +90,7 @@
var mb_security_proxy = "http://wms1.ccgis.de/mapbender/tools/security_proxy.php?mb_ows_security_proxy=";
-var mb_trans = new Image;
+var mb_trans = new Image();
mb_trans.src = "../img/transparent.gif";
/*END OF GLOBALS*/
@@ -209,7 +209,7 @@
* @type integer
this.getWidth = function(){
- return parseInt(this.width);
+ return parseInt(this.width, 10);
@@ -218,7 +218,7 @@
* @param {integer} widht the width of the mapObj
this.setWidth = function(width){
- this.width = parseInt(width);
+ this.width = parseInt(width, 10);
@@ -229,7 +229,7 @@
* @type integer
this.getHeight = function(){
- return parseInt(this.height);
+ return parseInt(this.height, 10);
@@ -238,7 +238,7 @@
* @param {integer} height the height of the mapObj
this.setHeight = function(height){
- this.height = parseInt(height);
+ this.height = parseInt(height, 10);
@@ -322,14 +322,14 @@
this.setExtent(minx,miny,maxx,maxy);
//Todo:
//setMapRequest!
* set the extent of the wms
this.setExtent = function(minx,miny,maxx,maxy){
this.extent = String(minx)+","+String(miny)+","+String(maxx)+","+String(maxy);
* get the srs of the mapObj
@@ -444,18 +444,21 @@
this.move = function(wms_id, layer_id, moveUp){
var i,j;
for(i=0;i<this.wms.length;i++){
- if(wms_id==this.wms[i].wms_id)
+ if (wms_id == this.wms[i].wms_id) {
break;
//check if only one wms is affected?
- if(layer_id&&layer_id!=this.wms[i].objLayer[0].layer_id)
+ if (layer_id && layer_id != this.wms[i].objLayer[0].layer_id) {
return this.wms[i].moveLayer(layer_id, moveUp);
//else swap wms
j = i + (moveUp?-1:1);
- if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length))
+ if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length)) {
return false;
upper = this.wms[i];
this.wms[i] = this.wms[j];
@@ -471,7 +474,7 @@
this.querylayers[j] = upperQuerylayers;
return true;
eventAfterMapObjectConstruction.trigger();
@@ -511,13 +514,17 @@
if (fromIndex > toIndex) {
for (var i = fromIndex; i > toIndex ; i--) {
var result = mb_swapWmsByIndex(mapObj_ind, i-1, i);
- if (result == true) changed = true;
+ if (result === true) {
+ changed = true;
else {
for (var i = fromIndex; i < toIndex ; i++) {
var result = mb_swapWmsByIndex(mapObj_ind, i, i+1);
+ changed = true;
return changed;
@@ -579,8 +586,8 @@
var ind = getMapObjIndexByName(obj);
//is the id valid?
for( var i=0; i<(wms.length-1); i++){
- if(parseInt(wms[i].wms_id) >= parseInt(wms[wms.length-1].wms_id)){
- wms[wms.length-1].wms_id = parseInt(mb_mapObj[ind].wms[i].wms_id) + 1;
+ if(parseInt(wms[i].wms_id, 10) >= parseInt(wms[wms.length-1].wms_id, 10)){
+ wms[wms.length-1].wms_id = parseInt(mb_mapObj[ind].wms[i].wms_id, 10) + 1;
mb_mapObj[ind].wms[mb_mapObj[ind].wms.length] = wms[wms.length-1];
@@ -616,7 +623,7 @@
new_layerarray[new_layerarray.length] = mb_mapObj[objind].layers[i];
new_querylayerarray[new_querylayerarray.length] = mb_mapObj[objind].querylayers[i];
new_stylesarray[new_stylesarray.length] = mb_mapObj[objind].styles[i];
- new_mapURLarray[new_mapURLarray.length] = mb_mapObj[objind].mapURL[i]
+ new_mapURLarray[new_mapURLarray.length] = mb_mapObj[objind].mapURL[i];
else {
wms_ID = mb_mapObj[objind].wms[i].wms_id;
@@ -692,7 +699,7 @@
//disable Layer which are out of scale
var validLayers = mb_checkScale(frameName,i,ii);
var layerNames = validLayers.toString();
- if(mb_mapObj[i].layers[ii] != "" && validLayers != ''){
+ if(mb_mapObj[i].layers[ii] !== "" && validLayers !== ''){
var newMapURL = "";
if (mb_mapObj[i].wms[ii].gui_wms_mapopacity != 1) {
@@ -725,7 +732,7 @@
if(j>0){
newMapURL += ",";
- if(mb_mapObj[i].wms[ii].getCurrentStyleByLayerName(layer[j])==false){
+ if(mb_mapObj[i].wms[ii].getCurrentStyleByLayerName(layer[j]) === false){
newMapURL += "";
else{
@@ -756,14 +763,14 @@
// add Filter
- if(mb_mapObj[i].wms[ii].wms_filter != ""){
+ if(mb_mapObj[i].wms[ii].wms_filter !== ""){
var tmp = mb_mapObj[i].wms[ii].wms_filter +"?id="+ mb_styleID;
var temp = "&SLD=" + tmp+ "&";
newMapURL += temp;
// add sld
- if(mb_mapObj[i].wms[ii].gui_wms_sldurl != ""){
+ if(mb_mapObj[i].wms[ii].gui_wms_sldurl !== ""){
//alert(mb_mapObj[i].wms[ii].gui_wms_sldurl);
var temp = "&SLD=" + escape(mb_mapObj[i].wms[ii].gui_wms_sldurl) + "&";
newMapURL += temp;
@@ -835,7 +842,7 @@
if(j>0){
newMapURL += ",";
+ if(mb_mapObj[i].wms[ii].getCurrentStyleByLayerName(layer[j])===false){
newMapURL += "";
else{
@@ -865,21 +872,21 @@
// add Filter
//prompt("",tmp);;
newMapURL += temp;
// add sld
newMapURL += temp;
//prompt("",newMapURL);
- if(mb_mapObj[i].layers[ii] != "" && layerNames!=''){
+ if(mb_mapObj[i].layers[ii] !== "" && layerNames!==''){
newMapRequest += newMapURL;
mb_mapObj[i].mapURL[ii] = newMapURL;
mb_mapObj[i].wms[ii].mapURL = newMapURL;
@@ -951,9 +958,9 @@
var minscaleOK = false;
var maxscaleOK = false;
if(thisLayer[ii] == myLayername){
- if(myMinscale == 0 || thisScale >= myMinscale){minscaleOK = true;}
- if(myMaxscale == 0 || thisScale <= myMaxscale){maxscaleOK = true;}
- if(maxscaleOK == true && minscaleOK == true ){
+ if(myMinscale === 0 || thisScale >= myMinscale){minscaleOK = true;}
+ if(myMaxscale === 0 || thisScale <= myMaxscale){maxscaleOK = true;}
+ if(maxscaleOK === true && minscaleOK === true ){
if(cnt_layer > 0){str_layer += ","; }//str_styles += ","; str_titles += ",";str_parent += ","; str_legendurls += ",";}
str_layer += thisLayer[ii];
cnt_layer++;
@@ -1002,7 +1009,7 @@
requestParams += "X=" + x + "&";
requestParams += "Y=" + y;
- if(mb_mapObj[i].querylayers[ii] != "" && mb_mapObj[i].layers[ii] != ""){
+ if(mb_mapObj[i].querylayers[ii] !== "" && mb_mapObj[i].layers[ii] !== ""){
validation = true;
//add vendor-specific
@@ -1016,15 +1023,15 @@
if(document.getElementById("FeatureInfoRedirect") && validation){
newfeatureInfoRequest += requestParams;
if(path){
- window.frames["FeatureInfoRedirect"].document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr;
+ window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr;
else{
- window.frames["FeatureInfoRedirect"].document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = newfeatureInfoRequest;
+ window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = newfeatureInfoRequest;
cnt_fi++;
else if(path && validation){
- newfeatureInfoRequest += requestParams
+ newfeatureInfoRequest += requestParams;
try{
var p = new mb_popup("Feature Info","url:"+path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr,300,400);
p.show();
@@ -1036,7 +1043,7 @@
else if(validation){
try{
- var p = new mb_popup("Feature Info","url:"+newfeatureInfoRequest,300,400);
+ var p = new mb_popup("Feature Info","url:"+newfeatureInfoRequest,300,400);
p.show();
catch(e){
@@ -1047,7 +1054,9 @@
- if(cnt_fi == 0){alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));}
+ if(cnt_fi === 0){
+ alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
@@ -1172,12 +1181,12 @@
for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
if(mb_mapObj[ind].wms[i].wms_id == array_wms[j] && mb_mapObj[ind].wms[i].objLayer[ii].layer_name == array_layer[j]){
if(type == "visible"){
- mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible = parseInt(status);
+ mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible = parseInt(status, 10);
//alert(mb_mapObj[ind].wms[i].objLayer[ii].layer_name);
check = true;
if(type == "querylayer" && (mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == "1" || mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == 1)){
- mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer = parseInt(status);
+ mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer = parseInt(status, 10);
@@ -1186,7 +1195,7 @@
* hier noch checken, welche wms sich geaendert haben und disctinct eine singleRequest aufrufen:
- if(check == true){
+ if(check === true){
if(mb_mapObj[ind].wms[i].gui_wms_visible == 1){
setSingleMapRequest(mapObj,mb_mapObj[ind].wms[i].wms_id);
@@ -1200,8 +1209,8 @@
function makeClickPos2RealWorldPos(frameName, myClickX, myClickY) {
var ind = getMapObjIndexByName(frameName);
- var width = parseInt(mb_mapObj[ind].width);
- var height = parseInt(mb_mapObj[ind].height);
+ var width = parseInt(mb_mapObj[ind].width, 10);
+ var height = parseInt(mb_mapObj[ind].height, 10);
var arrayBBox = mb_mapObj[ind].extent.split(",");
var minX = parseFloat(arrayBBox[0]);
var minY = parseFloat(arrayBBox[1]);
@@ -1227,7 +1236,7 @@
var posY = parseFloat(maxY - (myClickY / height) * xtenty);
posX = Math.round(posX * roundx)/roundx;
posY = Math.round(posY * roundy)/roundy;
- return new Array(posX, posY);
+ return [posX, posY];
function makeRealWorld2mapPos(frameName,rw_posx, rw_posy){
@@ -1242,7 +1251,7 @@
function mb_arrangeElement(frameName, elName, left, top) {
- if(frameName != ""){
+ if(frameName !== ""){
window.frames[frameName].document.getElementById(elName).style.top = top;
window.frames[frameName].document.getElementById(elName).style.left = left;
@@ -1274,7 +1283,7 @@
clickY = e.pageY;
- var pos = new Array(clickX,clickY);
+ var pos = [clickX,clickY];
return pos;
// function for object-identification
@@ -1353,7 +1362,7 @@
function mb_repaintScale(frameName, x, y, scale){
- if(x == null && y == null){
+ if(x === null && y === null){
x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
@@ -1478,21 +1487,21 @@
var t = mb_mapObj[objInd].wms[wmsInd];
var pos = mb_getlayerposbyname(objInd, wmsInd,lname);
var l = [];
- l["name"] = [];
- l["title"] = [];
- l["legendurl"] = [];
+ l.name = [];
+ l.title = [];
+ l.legendurl = [];
for(var i=0; i < t.objLayer.length; i++){
if(t.objLayer[i].layer_parent == pos){
- l["name"][l["name"].length] = t.objLayer[i].layer_name;
- l["title"][l["title"].length] = t.objLayer[i].layer_title;
+ l.name[l.name.length] = t.objLayer[i].layer_name;
+ l.title[l.title.length] = t.objLayer[i].layer_title;
if(t.objLayer[i].layer_style.length>0){
- l["legendurl"][l["legendurl"].length] = t.objLayer[i].layer_style[0]["legendurl"] ;
+ l.legendurl[l.legendurl.length] = t.objLayer[i].layer_style[0].legendurl;
}else{
- l["legendurl"][l["legendurl"].length] = 0 ;
+ l.legendurl[l.legendurl.length] = 0 ;
- if(l["name"].length > 0){
+ if(l.name.length > 0){
return l;
else{
@@ -1557,7 +1566,7 @@
return newString;
* @private
@@ -1574,7 +1583,7 @@
* @private
@@ -1686,7 +1695,7 @@
* class for exception logging
@@ -1792,15 +1801,15 @@
function mb_regButton_frame(wii, frameName, param){
var ind = mb_button.length;
mb_button[ind] = new mb_conButton(wii, ind);
- if (frameName == null) {
- if (param == null) {
+ if (frameName === null) {
+ if (param === null) {
eval(wii+"("+ind+")");
else {
eval(wii+"("+ind+", "+param+")");
- else if (param == null) {
+ else if (param === null) {
eval("window.frames['" + frameName + "']."+wii+"("+ind+")");
else {
@@ -1808,10 +1817,16 @@
mb_button[ind].prev = mb_button[ind].src;
mb_button[ind].src = mb_button[ind].img_off;
- mb_button[ind].onmouseover = new Function("mb_button_over("+ind+")");
- mb_button[ind].onmouseout = new Function("mb_button_out("+ind+")");
- mb_button[ind].onclick = new Function("mb_button_click("+ind+")");
- if (frameName==null) {
+ mb_button[ind].onmouseover = function () {
+ mb_button_over(ind);
+ mb_button[ind].onmouseout = function(){
+ mb_button_out(ind);
+ mb_button[ind].onclick = function(){
+ mb_button_click(ind);
mb_button[ind].frameName = "";
else {
@@ -1828,7 +1843,7 @@
return true;
function mb_button_over(ind){
- if(mb_button[ind].status == 0){
+ if(mb_button[ind].status === 0){
mb_button[ind].src = mb_button[ind].img_over;
@@ -1838,12 +1853,12 @@
function mb_button_click(ind){
var mbStatus = mb_button[ind].status;
- if(mbStatus == 0){
+ if(mbStatus === 0){
mb_disableButton(mb_button[ind].elName);
mb_button[ind].prev = mb_button[ind].img_on;
mb_button[ind].src = mb_button[ind].img_on;
mb_button[ind].status = 1;
- if (mb_button[ind].frameName != "") {
+ if (mb_button[ind].frameName !== "") {
window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).go();
else {
@@ -1854,7 +1869,7 @@
mb_button[ind].prev = mb_button[ind].img_off;
mb_button[ind].status = 0;
window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).stop();
else {
@@ -1866,7 +1881,7 @@
for(var i=0; i<mb_button.length; i++){
if(mb_button[i].elName != elName && mb_button[i].status == 1){
mb_button[i].status = 0;
- if (mb_button[i].frameName != "") {
+ if (mb_button[i].frameName !== "") {
window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).stop();
@@ -1884,7 +1899,7 @@
if(mb_button[i].elName == elName && mb_button[i].status == 1){
//alert(mb_button[i].elName);
@@ -1904,7 +1919,7 @@
for(var j=0; j<obj.length; j++){
// console.log("%s %s", mb_button[i].elName, obj[j].id);
if (mb_button[i].elName == obj[j].id) {
window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).title = obj[j].title;
else {
@@ -1929,7 +1944,7 @@
function cloneObject(obj) {
- if (typeof obj !== 'object' || obj == null) {
+ if (typeof obj !== 'object' || obj === null) {
return obj;
var c = obj instanceof Array ? [] : {};
@@ -1994,10 +2009,10 @@
* empties this {@link List}
this.empty = function() {
- while (this.list != null && this.count() > 0) {
+ while (this.list !== null && this.count() > 0) {
this.list.pop();
* @param {Integer} i index
@@ -2080,14 +2095,14 @@
var oldElement;
var newElement;
var prefix;
- if(frameName && frameName != ""){
+ if(frameName && frameName !== ""){
prefix = window.frames[frameName].document;
- else if(!frameName || frameName == ""){
+ else if(!frameName || frameName === ""){
prefix = document;
oldElement = prefix.getElementById(elementId);
- if (oldElement == null) {
+ if (oldElement === null) {
newElement = prefix.createElement(tagName);
newElement = prefix.getElementsByTagName(appendAtTagName)[0].appendChild(newElement);
More information about the Mapbender_commits
