[Mapbender-commits] r2110 - in trunk: . build
svn_mapbender at osgeo.org
Tue Feb 19 13:32:05 EST 2008
Author: christoph
Date: 2008-02-19 13:32:05 -0500 (Tue, 19 Feb 2008)
New Revision: 2110
Added:
trunk/build/
trunk/build/build.sh
trunk/build/jsmin-1.1.0.php
trunk/build/jsmin.php
build script
Added: trunk/build/build.sh
--- trunk/build/build.sh (rev 0)
+++ trunk/build/build.sh 2008-02-19 18:32:05 UTC (rev 2110)
@@ -0,0 +1,99 @@
+#!/bin/bash
+# expecting three input params
+# $1 - the name of the release branch at
+# https://svn.osgeo.org/mapbender/branches, for example 2.4.5
+# $2 - the SVN username for https://svn.osgeo.org/mapbender
+# $3 - the SVN password for https://svn.osgeo.org/mapbender
+#set constants
+# the name of the folder where the build process happens
+TODAY=`date +%Y-%m-%d_%H.%M.%S`
+FOLDER="build_$TODAY"
+# URL to version that is being built
+SVN_URL="https://svn.osgeo.org/mapbender/branches"
+# path to jsdoc.pl
+JSDOC_PATH="JSDoc"
+# path to "javascript" folder in Mapbender
+JS_PATH="http/javascripts"
+# path to "extension" folder in Mapbender
+EXT_PATH="http/extensions"
+# array of javascript files for JSDoc
+JSDOC_F=("$JS_PATH/geometry.js" "$JS_PATH/point.js" "$JS_PATH/map.js" "$JS_PATH/map_obj.js" "$EXT_PATH/wz_jsgraphics.js")
+# array of javascript files for JSMin
+JSMIN_F=("$JS_PATH/geometry.js" "$JS_PATH/point.js" "$JS_PATH/map.js" "$JS_PATH/map_obj.js" "$EXT_PATH/jquery.js" "$EXT_PATH/wz_jsgraphics.js")
+# ACTUAL BUILD BEGINS HERE
+echo "Building Mapbender $1 ... let's see if this works ..."
+# create folder for build
+mkdir $FOLDER 2>/dev/null
+#check out from SVN
+echo "checking out from $SVN_URL/$1 ..."
+svn co -q $SVN_URL/$1 $FOLDER/
+#compile JSDoc
+echo "compiling JSDoc ..."
+for name in ${JSDOC_F[@]}
+do
+ echo "extracting doc from $FOLDER/$name"
+ perl $JSDOC_PATH/jsdoc.pl $FOLDER/$name
+done
+#move JSDoc to folder
+mkdir $FOLDER/documents 2>/dev/null
+mkdir $FOLDER/documents/jsdoc 2>/dev/null
+mv js_docs_out/* $FOLDER/documents/jsdoc/ 2>/dev/null
+rm -rf js_docs_out 2>/dev/null
+#check in JSDOC
+echo "committing JSDoc ..."
+svn add -q $FOLDER/documents/
+svn commit -q -m updated_documentation --username $2 --password $3 $FOLDER/documents/
+#compile PHPDoc
+# (to do)
+#check in PHPDoc
+# (to do)
+# compress JS files
+echo "compressing JS ..."
+for name in ${JSMIN_F[@]}
+do
+ echo "minifying $FOLDER/$name ..."
+ ORIG=$name"_orig"
+ mv $FOLDER/$name $FOLDER/$ORIG 2>/dev/null
+ php5 jsmin.php $FOLDER/$ORIG > $FOLDER/$name
+ rm $FOLDER/$ORIG 2>/dev/null
+done
+# remove SVN metadata
+echo "deleting SVN metadata ..."
+cd $FOLDER 2>/dev/null
+rm -rf `find . -type d -name .svn` 2>/dev/null
+cd .. 2>/dev/null
+# zip build folder
+echo "creating zip file ..."
+ZIP_FILENAME="mapbender_$1_$TODAY.zip"
+zip -rq $ZIP_FILENAME $FOLDER/*
+# remove build folder
+rm -rf $FOLDER 2>/dev/null
\ No newline at end of file
Property changes on: trunk/build/build.sh
___________________________________________________________________
Added: trunk/build/jsmin-1.1.0.php
--- trunk/build/jsmin-1.1.0.php (rev 0)
+++ trunk/build/jsmin-1.1.0.php 2008-02-19 18:32:05 UTC (rev 2110)
@@ -0,0 +1,296 @@
+<?php
+ * jsmin.php - PHP implementation of Douglas Crockford's JSMin.
+ * This is pretty much a direct port of jsmin.c to PHP with just a few
+ * PHP-specific performance tweaks. Also, whereas jsmin.c reads from stdin and
+ * outputs to stdout, this library accepts a string as input and returns another
+ * string as output.
+ * PHP 5 or higher is required.
+ * Permission is hereby granted to use this version of the library under the
+ * same terms as jsmin.c, which has the following license:
+ * Copyright (c) 2002 Douglas Crockford (www.crockford.com)
+ * Permission is hereby granted, free of charge, to any person obtaining a copy of
+ * this software and associated documentation files (the "Software"), to deal in
+ * the Software without restriction, including without limitation the rights to
+ * use, copy, modify, merge, publish, distribute, sublicense, and/or sell copies
+ * of the Software, and to permit persons to whom the Software is furnished to do
+ * so, subject to the following conditions:
+ * The above copyright notice and this permission notice shall be included in all
+ * copies or substantial portions of the Software.
+ * The Software shall be used for Good, not Evil.
+ * THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR
+ * IMPLIED, INCLUDING BUT NOT LIMITED TO THE WARRANTIES OF MERCHANTABILITY,
+ * FITNESS FOR A PARTICULAR PURPOSE AND NONINFRINGEMENT. IN NO EVENT SHALL THE
+ * AUTHORS OR COPYRIGHT HOLDERS BE LIABLE FOR ANY CLAIM, DAMAGES OR OTHER
+ * LIABILITY, WHETHER IN AN ACTION OF CONTRACT, TORT OR OTHERWISE, ARISING FROM,
+ * OUT OF OR IN CONNECTION WITH THE SOFTWARE OR THE USE OR OTHER DEALINGS IN THE
+ * SOFTWARE.
+ * @package JSMin
+ * @author Ryan Grove <ryan at wonko.com>
+ * @copyright 2002 Douglas Crockford <douglas at crockford.com> (jsmin.c)
+ * @copyright 2007 Ryan Grove <ryan at wonko.com> (PHP port)
+ * @license http://opensource.org/licenses/mit-license.php MIT License
+ * @version 1.1.0 (2007-06-01)
+ * @link http://code.google.com/p/jsmin-php/
+class JSMin {
+ const ORD_LF = 10;
+ const ORD_SPACE = 32;
+ protected $a = '';
+ protected $b = '';
+ protected $input = '';
+ protected $inputIndex = 0;
+ protected $inputLength = 0;
+ protected $lookAhead = null;
+ protected $output = array();
+ // -- Public Static Methods --------------------------------------------------
+ public static function minify($js) {
+ $jsmin = new JSMin($js);
+ return $jsmin->min();
+ // -- Public Instance Methods ------------------------------------------------
+ public function __construct($input) {
+ $this->input = str_replace("\r\n", "\n", $input);
+ $this->inputLength = strlen($this->input);
+ // -- Protected Instance Methods ---------------------------------------------
+ protected function action($d) {
+ switch($d) {
+ case 1:
+ $this->output[] = $this->a;
+ case 2:
+ $this->a = $this->b;
+ if ($this->a === "'" || $this->a === '"') {
+ for (;;) {
+ $this->a = $this->get();
+ if ($this->a === $this->b) {
+ break;
+ if (ord($this->a) <= self::ORD_LF) {
+ throw new JSMinException('Unterminated string literal.');
+ if ($this->a === '\\') {
+ case 3:
+ $this->b = $this->next();
+ if ($this->b === '/' && (
+ $this->a === '(' || $this->a === ',' || $this->a === '=' ||
+ $this->a === ':' || $this->a === '[' || $this->a === '!' ||
+ $this->a === '&' || $this->a === '|' || $this->a === '?')) {
+ $this->output[] = $this->b;
+ for (;;) {
+ if ($this->a === '/') {
+ break;
+ elseif ($this->a === '\\') {
+ elseif (ord($this->a) <= self::ORD_LF) {
+ throw new JSMinException('Unterminated regular expression '.
+ 'literal.');
+ protected function get() {
+ $c = $this->lookAhead;
+ $this->lookAhead = null;
+ if ($c === null) {
+ if ($this->inputIndex < $this->inputLength) {
+ $c = $this->input[$this->inputIndex];
+ $this->inputIndex += 1;
+ else {
+ $c = null;
+ if ($c === "\r") {
+ return "\n";
+ if ($c === null || $c === "\n" || ord($c) >= self::ORD_SPACE) {
+ return $c;
+ return ' ';
+ protected function isAlphaNum($c) {
+ return ord($c) > 126 || $c === '\\' || preg_match('/^[\w\$]$/', $c) === 1;
+ protected function min() {
+ $this->a = "\n";
+ $this->action(3);
+ while ($this->a !== null) {
+ switch ($this->a) {
+ case ' ':
+ if ($this->isAlphaNum($this->b)) {
+ $this->action(1);
+ else {
+ $this->action(2);
+ break;
+ case "\n":
+ switch ($this->b) {
+ case '{':
+ case '[':
+ case '(':
+ case '+':
+ case '-':
+ $this->action(1);
+ break;
+ case ' ':
+ $this->action(3);
+ break;
+ default:
+ $this->action(1);
+ else {
+ $this->action(2);
+ break;
+ default:
+ case ' ':
+ if ($this->isAlphaNum($this->a)) {
+ $this->action(1);
+ break;
+ $this->action(3);
+ break;
+ case "\n":
+ case '}':
+ case ']':
+ case ')':
+ case '+':
+ case '-':
+ case '"':
+ case "'":
+ $this->action(1);
+ break;
+ default:
+ $this->action(1);
+ else {
+ $this->action(3);
+ break;
+ default:
+ $this->action(1);
+ break;
+ return implode('', $this->output);
+ protected function next() {
+ $c = $this->get();
+ if ($c === '/') {
+ switch($this->peek()) {
+ case '/':
+ for (;;) {
+ if (ord($c) <= self::ORD_LF) {
+ return $c;
+ case '*':
+ $this->get();
+ for (;;) {
+ switch($this->get()) {
+ case '*':
+ if ($this->peek() === '/') {
+ $this->get();
+ return ' ';
+ break;
+ case null:
+ throw new JSMinException('Unterminated comment.');
+ default:
+ return $c;
+ return $c;
+ protected function peek() {
+ $this->lookAhead = $this->get();
+ return $this->lookAhead;
+// -- Exceptions ---------------------------------------------------------------
+class JSMinException extends Exception {}
Added: trunk/build/jsmin.php
--- trunk/build/jsmin.php (rev 0)
+++ trunk/build/jsmin.php 2008-02-19 18:32:05 UTC (rev 2110)
@@ -0,0 +1,6 @@
+<?php
+require("jsmin-1.1.0.php");
+$file = $_SERVER["argv"][1];
+echo JSMin::minify(file_get_contents($file));
More information about the Mapbender_commits
