[Mapbender-commits] r2120 - in branches/2.4.5/http: php tools
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Feb 20 07:42:58 EST 2008
Author: christoph
Date: 2008-02-20 07:42:58 -0500 (Wed, 20 Feb 2008)
New Revision: 2120
Added:
   branches/2.4.5/http/tools/mod_monitorCapabilities_main.php
   branches/2.4.5/http/tools/mod_monitorCapabilities_read.php
   branches/2.4.5/http/tools/mod_monitorCapabilities_read_single.php
   branches/2.4.5/http/tools/mod_monitorCapabilities_write.php
Removed:
   branches/2.4.5/http/php/mod_monitorCapabilities_main.php
   branches/2.4.5/http/php/mod_monitorCapabilities_read.php
   branches/2.4.5/http/php/mod_monitorCapabilities_read_single.php
   branches/2.4.5/http/php/mod_monitorCapabilities_write.php
monitoring moved from php to tools
Deleted: branches/2.4.5/http/php/mod_monitorCapabilities_main.php
--- branches/2.4.5/http/php/mod_monitorCapabilities_main.php	2008-02-20 11:31:02 UTC (rev 2119)
+++ branches/2.4.5/http/php/mod_monitorCapabilities_main.php	2008-02-20 12:42:58 UTC (rev 2120)
@@ -1,198 +0,0 @@
-<?php
-# $Id: mod_monitorCapabilities.php 371 2006-05-31 12:45:24Z christoph $
-# http://www.mapbender.org/index.php/Monitor_Capabilities
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-//require_once("../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-//session_start();
-//import_request_variables("PG");
-require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
-$admin = new administration();
-//$user = "root";
-$user = "";
-$gui = "";
-$cl = 0;
-function getConjunctionCharacter($onlineresource){
-	if(strstr($onlineresource, "?")) {
-		$lastChar = substr($onlineresource,strlen($onlineresource)-1, 1);
-		if ($lastChar == "?" || $lastChar == "&") {return "";}
-		else{return "&";}
-	else {return "?";}
-// retrieve username and gui_id
-if ($_REQUEST['user']) {
-	$cl = 0;
-	//browser
-	echo "browser";
-	$user = $_REQUEST['user'];
-	$gui = $_REQUEST['gui'];
-elseif ($_SERVER["argv"][1]) {
-	$cl = 1;
-	//command line
-	$p1 = $_SERVER["argv"][1];
-	$p2 = $_SERVER["argv"][2];
-	if (substr($p1, 0,5) == "user:") {
-		$user = substr($p1, 5);
-		if (substr($p2, 0,4) == "gui:") {
-			$gui = substr($p2, 4);
-else {
-	echo "Please specify a username!\n";die();
-$userid = $admin->getUserIdByUserName($user);
-if ($userid) {
-	$ownguis = $admin->getGuisByOwner($userid,true);
-	if ($gui) {
-		if (!$admin->guiExists($gui)) {
-			echo "GUI " . $gui . " doesn't exist.\n"; die();
-		elseif (in_array($gui, $ownguis)) {
-			$ownguis = array($gui);
-		else {
-			echo "User " . $user . " is not owner of GUI " . $gui . ".\n"; die();
-else {
-	echo $user . " is not a valid username.\n";	die();
-$wms_id_own = $admin->getWmsByOwnGuis($ownguis);
-// initialise monitoring processes
-echo "Starting monitoring cycle...\n\n";
-if ($cl == 0) echo "<br/><br/>";
-echo "WMS services are requested for availability.\n";
-if ($cl == 0) echo "<br/>";
-echo "Capabilities documents are requested and all changes synchronized with the database cache.\n\n";
-$time = strval(time()-2);
-for ($k=0; $k<count($wms_id_own); $k++) {
-	$sql = "SELECT wms_upload_url FROM wms WHERE wms_id = $1";
-	$v = array($wms_id_own[$k]);
-	$t = array('i');
-	$res = db_prep_query($sql,$v,$t);
-	$someArray = db_fetch_row($res);
-	$url = $someArray[0];
-	if (!$upload_url || $upload_url == "") {
-		$sql = "SELECT wms_version, wms_getcapabilities FROM wms WHERE wms_id = $1";
-		$t = array('i');
-		$version = $someArray[0];
-		$capabilities = $someArray[1];
-		if ($version == "1.0.0" ) {
-			$url = $capabilities . getConjunctionCharacter($capabilities) . "REQUEST=capabilities&WMTVER=1.0.0";
-		else {
-			$url = $capabilities . getConjunctionCharacter($capabilities) . "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=" . $version;
-	$sql = "INSERT INTO mb_monitor (upload_id, fkey_wms_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated) ";
-	$sql .= "VALUES ($1, $2, $3, $4, $5, $6, $7, $8)";
-	$v = array($time,$wms_id_own[$k],"-2","Monitoring is still in progress...", time(),time(),$url,"0");
-	$t = array('s', 'i', 's', 's', 's', 's', 's', 's');
-	if (intval(AUTO_UPDATE)) {
-		$exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 1 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
-	else {
-		$exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 0 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
-	exec($exec);
-echo "Monitoring Cycle completed (total: " . count($wms_id_own) . " wms).\n\n";
-set_time_limit(2*TIME_LIMIT);
-// wait until all monitoring processes are finished
-echo "please wait " . TIME_LIMIT . " seconds for the monitoring to finish...\n\n";
-sleep(TIME_LIMIT);
-$sql = "SELECT fkey_wms_id, status, status_comment, timestamp_begin, timestamp_end, upload_url FROM mb_monitor WHERE upload_id = $1";
-$v = array($time);
-$t = array('i');
-$res = db_prep_query($sql,$v,$t);
-$cnt=0;
-while ($row = db_fetch_array($res)) {
-	$status[$cnt] = intval(db_result($res,$cnt,"status"));
-	$wms_id[$cnt] = db_result($res,$cnt,"fkey_wms_id");
-	$comment[$cnt] = db_result($res,$cnt,"status_comment");
-	$upload_url[$cnt] = db_result($res,$cnt,"upload_url");
-	$timestamp_begin[$cnt] = db_result($res,0,"timestamp_begin");
-	$timestamp_end[$cnt] = db_result($res,0,"timestamp_end");
-	$cnt++;
-$body = "";
-for ($i=0; $i<$cnt; $i++) {
-	// if monitoring is still in progress and time limit has expired, update database
-	if ($status[$i] == -2 && intval(time())-intval($timestamp_begin[$i]) > intval(TIME_LIMIT)) {
-		$comment[$i] = "Monitoring process timed out.";
-		$status[$i] = -1;
-		$new_sql = "UPDATE mb_monitor SET status = '-1', status_comment = 'Monitoring process timed out.', timestamp_end = $1 WHERE fkey_wms_id = $2 AND upload_id = $3";
-		$new_v = array((intval($upload_id[$i])+intval(TIME_LIMIT)), $wms_id[$i], $time);
-		$new_t = array('s', 'i', 's');
-		$new_res = db_prep_query($new_sql,$new_v,$new_t);
-	// compose mail message
-	echo $wms_id[$i] . ": status " . $status[$i] . "\n";
-	if ($cl == 0) echo "<br/><br/>";
-	if ($status[$i] == -1) {
-		$body .= $admin->getWmsTitleByWmsId($wms_id[$i]) . " (" . $wms_id[$i] . "): " . $comment[$i] . "\n\n";
-// Send an email to the user
-if ($body) {
-	$error_msg = "";
-	if ($admin->getEmailByUserId($userid)) {
-		$admin->sendEmail(MAILADMIN, MAILADMINNAME, $admin->getEmailByUserId($userid), $user, "WMS monitor report " . date("F j, Y, G:i:s", $time), utf8_decode($body), &$error_msg);
-	else {
-		$error_msg = "Email address of user '" . $admin->getUserNameByUserId($userid) . "' unknown!\n";
-	if ($error_msg) {
-		echo "\n ERROR: " . $error_msg;
Deleted: branches/2.4.5/http/php/mod_monitorCapabilities_read.php
--- branches/2.4.5/http/php/mod_monitorCapabilities_read.php	2008-02-20 11:31:02 UTC (rev 2119)
+++ branches/2.4.5/http/php/mod_monitorCapabilities_read.php	2008-02-20 12:42:58 UTC (rev 2120)
@@ -1,219 +0,0 @@
-<?php
-# $Id: mod_monitorCapabilities_read.php 76 2006-08-15 12:25:34Z heuser $
-#require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-session_start();
-import_request_variables("PG");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-</head>
-<body>
-<?php
-// update selected wms
-for ($i=0; $i < $_POST['cbs']; $i++) {
-	$upd_wmsid = intval($_POST['cb'.$i]);
-	if ($upd_wmsid) {
-		$now = time();
-		$sql = "UPDATE mb_monitor SET status = '-2', status_comment = 'Monitoring is still in progress...', timestamp_begin = $1, timestamp_end = $2 WHERE upload_id = $3 AND fkey_wms_id = $4";
-		$v = array($now, $now, $_POST['upl_id'.$i], $upd_wmsid);
-		$t = array('s', 's', 's', 'i');
-		$exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$upd_wmsid." ".$_POST['upl_id'.$i]." 1 > output.txt &";
-		exec($exec);
-$sql = "SELECT DISTINCT fkey_wms_id FROM mb_monitor";
-$res = db_prep_query($sql, array(), array());
-$cnt = 0;
-$wms = array();
-while(db_fetch_row($res)){
-	$wms[$cnt] = db_result($res,$cnt,"fkey_wms_id");
-	$cnt++;
-$status = array();
-$upload_id = array();
-for ($i=0; $i<count($wms); $i++) {
-	$wms_id[$wms[$i]] = $wms[$i];
-	// get upload id
-	$sql = "SELECT MAX(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1";
-	$v = array($wms[$i]);
-	$t = array('i');
-	$upload_id[$wms[$i]] = db_result($res,0,0);
-	$sql = "SELECT AVG(timestamp_begin), AVG(timestamp_end) FROM mb_monitor WHERE fkey_wms_id = $1 AND NOT status = '-1' AND NOT status = '-2'";
-	$t = array('i');
-	if (db_result($res,0,1) == 0 && db_result($res,0,0) == 0) {
-		$avg_response_time[$wms[$i]] = NULL;
-	else {
-		$avg_response_time[$wms[$i]] = round(db_result($res,0,1)-db_result($res,0,0), 1);
-	$sql = "SELECT status, status_comment, timestamp_begin, timestamp_end, upload_url, updated FROM mb_monitor ";
-	$sql .= "WHERE upload_id = $1 AND fkey_wms_id = $2 ORDER BY status, status_comment, timestamp_end, fkey_wms_id";
-	$v = array($upload_id[$wms[$i]], $wms_id[$wms[$i]]);
-	$t = array('s', 'i');
-	$status[$wms[$i]] = intval(db_result($res,0,"status"));
-	$comment[$wms[$i]] = db_result($res,0,"status_comment");
-	$timestamp_begin[$wms[$i]] = db_result($res,0,"timestamp_begin");
-	$timestamp_end[$wms[$i]] = db_result($res,0,"timestamp_end");
-	$upload_url[$wms[$i]] = db_result($res,0,"upload_url");
-	$updated[$wms[$i]] = db_result($res,0,"updated");
- 	if ($status[$wms[$i]] == -2 && intval(time())-intval($timestamp_begin[$wms[$i]]) > intval(TIME_LIMIT)) {
-		$comment[$wms[$i]] = "Monitoring process timed out.";
-		$new_v = array((intval($upload_id[$wms[$i]])+intval(TIME_LIMIT)), $wms_id[$wms[$i]], $upload_id[$wms[$i]]);
-	$sql = "SELECT COUNT(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1 AND NOT status = '-2'";
-	$t = array('i');
-	$res = db_prep_query($sql, $v, $t);
-	$total[$wms[$i]] = db_result($res, 0, 0);
-	$sql = "SELECT COUNT(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1 AND status = '-1'";
-	$t = array('i');
-	$fail = db_result($res, 0, 0);
-	$percentage[$wms[$i]] = 100 - round(100*floatval($fail)/floatval($total[$wms[$i]]), 1);
-$newArray = $status;
-if ($_GET['sortby']) {
-	if ($_GET['sortby'] == "wms") {
-		$newArray = $wms_id;
-		asort($newArray);
-	elseif ($_GET['sortby'] == "status") {
-		$newArray = $status;
-		asort($newArray);
-	elseif ($_GET['sortby'] == "avgresp") {
-		$newArray = $avg_response_time;
-		asort($newArray);
-	elseif ($_GET['sortby'] == "avail") {
-		$newArray = $percentage;
-		arsort($newArray);
-	elseif ($_GET['sortby'] == "last") {
-		$newArray = $upload_id;
-$str = "<span style='font-size:30'>monitoring results</span><hr><br>\n";
-$str .= "<form name = 'form1' method='post' action='".$PHP_SELF."?sortby=".$_GET['sortby']."'>\n\t";
-$str .= "\n\t<input type=submit value='update selected WMS'>\n";
-$str .= "\n\t<input type=button onclick=\"self.location.href='".$PHP_SELF."?sortby=".$_GET['sortby']."'\" value='refresh'>\n<br/><br/>\n	";
-$str .= "<table cellpadding=10 cellspacing=0 border=0>";
-$str .= "<tr bgcolor='#dddddd'><th></th><th align='left'><a href='".$PHP_SELF."?sortby=wms'>wms</a></th>";
-$str .= "<th align='left' colspan = 2><a href='".$PHP_SELF."?sortby=status'>current status</a></th>";
-$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avgresp'>avg. response time</a></th>";
-$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avail'>overall availability</a></th><th></th></tr>";
-$cnt = 0;
-foreach ($newArray as $k => $value) {
-	$img = "stop.bmp";
-	if ($status[$k]==0) $img = "wait.bmp";
-	elseif ($status[$k]==1) $img = "go.bmp";
-	if ($updated[$k] == "0" && $status[$k] == 0) $fill = "checked"; else $fill = "disabled";
-	if (fmod($cnt, 2) == 1) {
-		$str .= "\n\t\t<tr bgcolor='#e6e6e6'>";
-	else {
-		$str .= "\n\t\t<tr bgcolor='#f0f0f0'>";
-	$str .= "\n\t\t\t<td><input name='cb".$cnt."' value='" . $wms_id[$k] . "' type=checkbox ".$fill." /><input type=hidden name='upl_id".$cnt."' value='".$upload_id[$k]."'></td>";
-	$str .= "\n\t\t\t<td valign='top'><b>" . $wms_id[$k] . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id[$k]) . "</td>";
-	$str .= "\n\t\t\t<td valign='top'><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
-	$str .= "\n\t\t\t<td valign='top'>" . $comment[$k] . "<br><div style='font-size:12'>".date("F j, Y, G:i:s", $upload_id[$k])."</div></td>";
-	$str .= "\n\t\t\t<td valign='top' align = 'left'>";
-	if ($avg_response_time[$k] == NULL) {
-		$str .= "n/a";
-	else {
-		$str .= $avg_response_time[$k] . " s";
-	$str .= "</td>";
-	$str .= "\n\t\t\t<td valign='top'><b>" . $percentage[$k] . " %</b>&nbsp;&nbsp;<span style='font-size:12'>(" . $total[$k] . " cycles)</span><br>";
-	$str .= "<table bgcolor='black' border=1 cellspacing=1 cellpadding=0><tr>";
-	$val = $percentage[$k];
-	for ($i=0; $i<10; $i++) {
-		if ($val>=10) {
-			$str .= "<td height=10 width='10' bgcolor='red'></td>";
-			$val-=10;
-		elseif($val>0){
-			$str .= "<td height=10 width='" . round($val) . "' bgcolor='red'></td>";
-			if (round($val) < 10) {
-				$str .= "<td height=10 width='" . (9-round($val)) . "' bgcolor='white'></td>";
-			$val=-1;
-		else {
-			$str .= "<td height=10 width='10' bgcolor='white'></td>";
-	$str .= "</tr></table></td>";
-#	$str .= "\n\t\t\t<td><a href='output_".$wms_id[$k]."_".$max.".txt' target=_blank>log</a></td>";
-	$str .= "\n\t\t<td><input type=button value='details' onclick=\"var newWindow = window.open('../php/mod_monitorCapabilities_read_single.php?wmsid=".$wms_id[$k]."','wms','width=500,height=700,scrollbars');newWindow.href.location='test.php'\"></td></tr>";
-	$cnt++;
-$str .= "\n\t</table>\n\t<br/><input type=hidden name=cbs value='".$cnt."'>\n</form>";
-echo $str;
-</body></html>
\ No newline at end of file
Deleted: branches/2.4.5/http/php/mod_monitorCapabilities_read_single.php
--- branches/2.4.5/http/php/mod_monitorCapabilities_read_single.php	2008-02-20 11:31:02 UTC (rev 2119)
+++ branches/2.4.5/http/php/mod_monitorCapabilities_read_single.php	2008-02-20 12:42:58 UTC (rev 2120)
@@ -1,102 +0,0 @@
-<?php
-# $Id: mod_monitorCapabilities_read_single.php 76 2006-08-15 12:25:34Z heuser $
-session_start();
-<html>
-<head>
-<?php
-</head>
-<body>
-<?php
-if ($_GET['wmsid']) {
-	$wms_id = intval($_GET['wmsid']);
-else {
-	echo "Invalid WMS ID.";
-	die;
-$sql = "SELECT upload_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated FROM mb_monitor ";
-$sql .= "WHERE fkey_wms_id = $1 AND NOT status = '-2' ORDER BY upload_id DESC";
-$v = array($wms_id);
-$t = array('i');
-$cnt=0;
-	$upload_id[$cnt] = db_result($res,$cnt,"upload_id");
-	$timestamp_begin = db_result($res,$cnt,"timestamp_begin");
-	$timestamp_end = db_result($res,$cnt,"timestamp_end");
-	if ($status[$cnt] == '0' || $status[$cnt] == '1') {
-		$response_time[$cnt] = strval($timestamp_end-$timestamp_begin) . " s";
-	else {
-		$response_time[$cnt] = "n/a";
-	$cnt++;
-$str .= "<b>" . $wms_id . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id) . "<br><br><br>\n";
-$str .= "<tr bgcolor='#dddddd'><th align='left'>date</th><th align='left' colspan = 2>status</th><th align='center'>response time</th></tr>";
-for ($k=0; $k<count($upload_id); $k++) {
-	if (fmod($k, 2) == 1) {
-	else {
-	$str .= "\n\t\t\t<td>".date("F j, Y, G:i:s", $upload_id[$k])."</td>";
-	$str .= "\n\t\t\t<td><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
-	$str .= "\n\t\t\t<td>" . $comment[$k] . "</td>";
-	$str .= "\n\t\t\t<td align='center'>" . $response_time[$k] . "</td>";
-$str .= "\n\t</table>\n\t";
-echo $str;
-</body></html>
Deleted: branches/2.4.5/http/php/mod_monitorCapabilities_write.php
--- branches/2.4.5/http/php/mod_monitorCapabilities_write.php	2008-02-20 11:31:02 UTC (rev 2119)
+++ branches/2.4.5/http/php/mod_monitorCapabilities_write.php	2008-02-20 12:42:58 UTC (rev 2120)
@@ -1,128 +0,0 @@
-<?php
-# $Id: mod_monitorCapabilities_write.php 76 2006-08-15 12:25:34Z heuser $
-//require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-require_once(dirname(__FILE__)."/../classes/class_wms.php");
-session_start();
-if ($_SERVER["argc"] != 4) {
-	echo "Insufficient arguments! Monitoring aborted.";
-	die();
-$wmsId = $_SERVER["argv"][1];
-$upload_id = $_SERVER["argv"][2];
-$auto_update = intval($_SERVER["argv"][3]);
-// get the uploadURL
-$sql = "SELECT upload_url FROM mb_monitor WHERE fkey_wms_id = $1 AND upload_id = $2";
-$v = array($wmsId, $upload_id);
-$t = array('i', 's');
-$someArray = db_fetch_row($res);
-$myURL = $someArray[0];
-// get the capabilities doc
-$sql = "SELECT wms_getcapabilities_doc FROM wms WHERE wms_id = $1";
-$v = array($wmsId);
-$t = array('i');
-$capabilities_doc = $someArray[0];
-$comment = "";
-$updated = "0";
-$result = -1;
-set_time_limit(TIME_LIMIT);
-if ($myURL) {
-	$remoteWms = new wms();
-	$remoteWms->createObjFromXML($myURL);
-	$now = time();
-	$remoteXml = $remoteWms->wms_getcapabilities_doc;
-	// compare the capabilities XML documents
-	$localXml = $capabilities_doc;
-	if (!$remoteXml) {
-		$result = -1;
-		$comment = "Connection failed.";
-	elseif (!$localXml) {
-		$result = 0;
-	else {
-		if ($localXml == $remoteXml) {
-			$result = 1;
-			$comment = "WMS is stable.";
-		else {
-			$result = 0;
-	if ($result == 0) {
-		$mywms = new wms();
-		if ($mywms->createObjFromXML($myURL)) {
-			if ($auto_update) {
-				$mywms->updateObjInDB($wmsId);
-				$updated = "1";
-				$comment = "WMS has been updated.";
-			else {
-				$comment = "WMS is not up to date.";
-		else {
-			$result = -1;
-			$comment = "Invalid getCapabilities request/document or service exception.";
-else {
-	$result = -1;
-	$comment = "Invalid upload URL.";
-	$now = time();
-echo "wmsid: " . $wmsId . "\nupload_id: " . $upload_id . "\n";
-echo "autoupdate: " . $auto_update . "\n";
-echo "result: " . $result . "\ncomment: " . $comment . "\n";
-echo "timestamp: " . $now . " (".date("F j, Y, G:i:s",$now).")\n";
-echo "getCapabilities URL: " . $myURL . "\nupdated: " . $updated . "\n\n";
-echo "-------------------------------------------------------------------\n";
-echo "remote XML:\n\n" . $remoteXml . "\n\n";
-echo "local XML:\n\n" . $localXml . "\n\n";
-$sql = "UPDATE mb_monitor SET updated = $1, status = $2, status_comment = $3, upload_url = $4, timestamp_end = $5 WHERE upload_id = $6 AND fkey_wms_id = $7";
-$v = array($updated, $result, $comment, $myURL, $now, $upload_id, $wmsId);
-$t = array('s', 's', 's', 's', 's', 's', 'i');
Copied: branches/2.4.5/http/tools/mod_monitorCapabilities_main.php (from rev 2117, branches/2.4.5/http/php/mod_monitorCapabilities_main.php)
--- branches/2.4.5/http/tools/mod_monitorCapabilities_main.php	                        (rev 0)
+++ branches/2.4.5/http/tools/mod_monitorCapabilities_main.php	2008-02-20 12:42:58 UTC (rev 2120)
@@ -0,0 +1,198 @@
+<?php
+# $Id: mod_monitorCapabilities.php 371 2006-05-31 12:45:24Z christoph $
+# http://www.mapbender.org/index.php/Monitor_Capabilities
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+//require_once("../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+//session_start();
+//import_request_variables("PG");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
+$con = db_connect($DBSERVER,$OWNER,$PW);
+db_select_db(DB,$con);
+$admin = new administration();
+//$user = "root";
+$user = "";
+$gui = "";
+$cl = 0;
+function getConjunctionCharacter($onlineresource){
+	if(strstr($onlineresource, "?")) {
+		$lastChar = substr($onlineresource,strlen($onlineresource)-1, 1);
+		if ($lastChar == "?" || $lastChar == "&") {return "";}
+		else{return "&";}
+	else {return "?";}
+// retrieve username and gui_id
+if ($_REQUEST['user']) {
+	$cl = 0;
+	//browser
+	echo "browser";
+	$user = $_REQUEST['user'];
+	$gui = $_REQUEST['gui'];
+elseif ($_SERVER["argv"][1]) {
+	$cl = 1;
+	//command line
+	$p1 = $_SERVER["argv"][1];
+	$p2 = $_SERVER["argv"][2];
+	if (substr($p1, 0,5) == "user:") {
+		$user = substr($p1, 5);
+		if (substr($p2, 0,4) == "gui:") {
+			$gui = substr($p2, 4);
+else {
+	echo "Please specify a username!\n";die();
+$userid = $admin->getUserIdByUserName($user);
+if ($userid) {
+	$ownguis = $admin->getGuisByOwner($userid,true);
+	if ($gui) {
+		if (!$admin->guiExists($gui)) {
+			echo "GUI " . $gui . " doesn't exist.\n"; die();
+		elseif (in_array($gui, $ownguis)) {
+			$ownguis = array($gui);
+		else {
+			echo "User " . $user . " is not owner of GUI " . $gui . ".\n"; die();
+else {
+	echo $user . " is not a valid username.\n";	die();
+$wms_id_own = $admin->getWmsByOwnGuis($ownguis);
+// initialise monitoring processes
+echo "Starting monitoring cycle...\n\n";
+if ($cl == 0) echo "<br/><br/>";
+echo "WMS services are requested for availability.\n";
+if ($cl == 0) echo "<br/>";
+echo "Capabilities documents are requested and all changes synchronized with the database cache.\n\n";
+$time = strval(time()-2);
+for ($k=0; $k<count($wms_id_own); $k++) {
+	$sql = "SELECT wms_upload_url FROM wms WHERE wms_id = $1";
+	$v = array($wms_id_own[$k]);
+	$t = array('i');
+	$res = db_prep_query($sql,$v,$t);
+	$someArray = db_fetch_row($res);
+	$url = $someArray[0];
+	if (!$upload_url || $upload_url == "") {
+		$sql = "SELECT wms_version, wms_getcapabilities FROM wms WHERE wms_id = $1";
+		$t = array('i');
+		$version = $someArray[0];
+		$capabilities = $someArray[1];
+		if ($version == "1.0.0" ) {
+			$url = $capabilities . getConjunctionCharacter($capabilities) . "REQUEST=capabilities&WMTVER=1.0.0";
+		else {
+			$url = $capabilities . getConjunctionCharacter($capabilities) . "REQUEST=GetCapabilities&SERVICE=WMS&VERSION=" . $version;
+	$sql = "INSERT INTO mb_monitor (upload_id, fkey_wms_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated) ";
+	$sql .= "VALUES ($1, $2, $3, $4, $5, $6, $7, $8)";
+	$v = array($time,$wms_id_own[$k],"-2","Monitoring is still in progress...", time(),time(),$url,"0");
+	$t = array('s', 'i', 's', 's', 's', 's', 's', 's');
+	if (intval(AUTO_UPDATE)) {
+		$exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 1 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
+	else {
+		$exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$wms_id_own[$k]." ".$time." 0 > ../tmp/output_".$time."_".$wms_id_own[$k].".txt &";
+	exec($exec);
+echo "Monitoring Cycle completed (total: " . count($wms_id_own) . " wms).\n\n";
+set_time_limit(2*TIME_LIMIT);
+// wait until all monitoring processes are finished
+echo "please wait " . TIME_LIMIT . " seconds for the monitoring to finish...\n\n";
+sleep(TIME_LIMIT);
+$sql = "SELECT fkey_wms_id, status, status_comment, timestamp_begin, timestamp_end, upload_url FROM mb_monitor WHERE upload_id = $1";
+$v = array($time);
+$t = array('i');
+$res = db_prep_query($sql,$v,$t);
+$cnt=0;
+while ($row = db_fetch_array($res)) {
+	$status[$cnt] = intval(db_result($res,$cnt,"status"));
+	$wms_id[$cnt] = db_result($res,$cnt,"fkey_wms_id");
+	$comment[$cnt] = db_result($res,$cnt,"status_comment");
+	$upload_url[$cnt] = db_result($res,$cnt,"upload_url");
+	$timestamp_begin[$cnt] = db_result($res,0,"timestamp_begin");
+	$timestamp_end[$cnt] = db_result($res,0,"timestamp_end");
+	$cnt++;
+$body = "";
+for ($i=0; $i<$cnt; $i++) {
+	// if monitoring is still in progress and time limit has expired, update database
+	if ($status[$i] == -2 && intval(time())-intval($timestamp_begin[$i]) > intval(TIME_LIMIT)) {
+		$comment[$i] = "Monitoring process timed out.";
+		$status[$i] = -1;
+		$new_sql = "UPDATE mb_monitor SET status = '-1', status_comment = 'Monitoring process timed out.', timestamp_end = $1 WHERE fkey_wms_id = $2 AND upload_id = $3";
+		$new_v = array((intval($upload_id[$i])+intval(TIME_LIMIT)), $wms_id[$i], $time);
+		$new_t = array('s', 'i', 's');
+		$new_res = db_prep_query($new_sql,$new_v,$new_t);
+	// compose mail message
+	echo $wms_id[$i] . ": status " . $status[$i] . "\n";
+	if ($cl == 0) echo "<br/><br/>";
+	if ($status[$i] == -1) {
+		$body .= $admin->getWmsTitleByWmsId($wms_id[$i]) . " (" . $wms_id[$i] . "): " . $comment[$i] . "\n\n";
+// Send an email to the user
+if ($body) {
+	$error_msg = "";
+	if ($admin->getEmailByUserId($userid)) {
+		$admin->sendEmail(MAILADMIN, MAILADMINNAME, $admin->getEmailByUserId($userid), $user, "WMS monitor report " . date("F j, Y, G:i:s", $time), utf8_decode($body), &$error_msg);
+	else {
+		$error_msg = "Email address of user '" . $admin->getUserNameByUserId($userid) . "' unknown!\n";
+	if ($error_msg) {
+		echo "\n ERROR: " . $error_msg;
Copied: branches/2.4.5/http/tools/mod_monitorCapabilities_read.php (from rev 2117, branches/2.4.5/http/php/mod_monitorCapabilities_read.php)
--- branches/2.4.5/http/tools/mod_monitorCapabilities_read.php	                        (rev 0)
+++ branches/2.4.5/http/tools/mod_monitorCapabilities_read.php	2008-02-20 12:42:58 UTC (rev 2120)
@@ -0,0 +1,219 @@
+<?php
+# $Id: mod_monitorCapabilities_read.php 76 2006-08-15 12:25:34Z heuser $
+#require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+session_start();
+import_request_variables("PG");
+<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
+<html>
+<head>
+<meta http-equiv="cache-control" content="no-cache">
+<meta http-equiv="pragma" content="no-cache">
+<meta http-equiv="expires" content="0">
+<?php
+echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
+</head>
+<body>
+<?php
+// update selected wms
+for ($i=0; $i < $_POST['cbs']; $i++) {
+	$upd_wmsid = intval($_POST['cb'.$i]);
+	if ($upd_wmsid) {
+		$now = time();
+		$sql = "UPDATE mb_monitor SET status = '-2', status_comment = 'Monitoring is still in progress...', timestamp_begin = $1, timestamp_end = $2 WHERE upload_id = $3 AND fkey_wms_id = $4";
+		$v = array($now, $now, $_POST['upl_id'.$i], $upd_wmsid);
+		$t = array('s', 's', 's', 'i');
+		$exec = PHP_PATH . "php mod_monitorCapabilities_write.php ".$upd_wmsid." ".$_POST['upl_id'.$i]." 1 > output.txt &";
+		exec($exec);
+$sql = "SELECT DISTINCT fkey_wms_id FROM mb_monitor";
+$res = db_prep_query($sql, array(), array());
+$cnt = 0;
+$wms = array();
+while(db_fetch_row($res)){
+	$wms[$cnt] = db_result($res,$cnt,"fkey_wms_id");
+	$cnt++;
+$status = array();
+$upload_id = array();
+for ($i=0; $i<count($wms); $i++) {
+	$wms_id[$wms[$i]] = $wms[$i];
+	// get upload id
+	$sql = "SELECT MAX(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1";
+	$v = array($wms[$i]);
+	$t = array('i');
+	$upload_id[$wms[$i]] = db_result($res,0,0);
+	$sql = "SELECT AVG(timestamp_begin), AVG(timestamp_end) FROM mb_monitor WHERE fkey_wms_id = $1 AND NOT status = '-1' AND NOT status = '-2'";
+	$t = array('i');
+	if (db_result($res,0,1) == 0 && db_result($res,0,0) == 0) {
+		$avg_response_time[$wms[$i]] = NULL;
+	else {
+		$avg_response_time[$wms[$i]] = round(db_result($res,0,1)-db_result($res,0,0), 1);
+	$sql = "SELECT status, status_comment, timestamp_begin, timestamp_end, upload_url, updated FROM mb_monitor ";
+	$sql .= "WHERE upload_id = $1 AND fkey_wms_id = $2 ORDER BY status, status_comment, timestamp_end, fkey_wms_id";
+	$v = array($upload_id[$wms[$i]], $wms_id[$wms[$i]]);
+	$t = array('s', 'i');
+	$status[$wms[$i]] = intval(db_result($res,0,"status"));
+	$comment[$wms[$i]] = db_result($res,0,"status_comment");
+	$timestamp_begin[$wms[$i]] = db_result($res,0,"timestamp_begin");
+	$timestamp_end[$wms[$i]] = db_result($res,0,"timestamp_end");
+	$upload_url[$wms[$i]] = db_result($res,0,"upload_url");
+	$updated[$wms[$i]] = db_result($res,0,"updated");
+ 	if ($status[$wms[$i]] == -2 && intval(time())-intval($timestamp_begin[$wms[$i]]) > intval(TIME_LIMIT)) {
+		$comment[$wms[$i]] = "Monitoring process timed out.";
+		$new_v = array((intval($upload_id[$wms[$i]])+intval(TIME_LIMIT)), $wms_id[$wms[$i]], $upload_id[$wms[$i]]);
+	$sql = "SELECT COUNT(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1 AND NOT status = '-2'";
+	$t = array('i');
+	$res = db_prep_query($sql, $v, $t);
+	$total[$wms[$i]] = db_result($res, 0, 0);
+	$sql = "SELECT COUNT(upload_id) FROM mb_monitor WHERE fkey_wms_id = $1 AND status = '-1'";
+	$t = array('i');
+	$fail = db_result($res, 0, 0);
+	$percentage[$wms[$i]] = 100 - round(100*floatval($fail)/floatval($total[$wms[$i]]), 1);
+$newArray = $status;
+if ($_GET['sortby']) {
+	if ($_GET['sortby'] == "wms") {
+		$newArray = $wms_id;
+		asort($newArray);
+	elseif ($_GET['sortby'] == "status") {
+		$newArray = $status;
+		asort($newArray);
+	elseif ($_GET['sortby'] == "avgresp") {
+		$newArray = $avg_response_time;
+		asort($newArray);
+	elseif ($_GET['sortby'] == "avail") {
+		$newArray = $percentage;
+		arsort($newArray);
+	elseif ($_GET['sortby'] == "last") {
+		$newArray = $upload_id;
+$str = "<span style='font-size:30'>monitoring results</span><hr><br>\n";
+$str .= "<form name = 'form1' method='post' action='".$PHP_SELF."?sortby=".$_GET['sortby']."'>\n\t";
+$str .= "\n\t<input type=submit value='update selected WMS'>\n";
+$str .= "\n\t<input type=button onclick=\"self.location.href='".$PHP_SELF."?sortby=".$_GET['sortby']."'\" value='refresh'>\n<br/><br/>\n	";
+$str .= "<table cellpadding=10 cellspacing=0 border=0>";
+$str .= "<tr bgcolor='#dddddd'><th></th><th align='left'><a href='".$PHP_SELF."?sortby=wms'>wms</a></th>";
+$str .= "<th align='left' colspan = 2><a href='".$PHP_SELF."?sortby=status'>current status</a></th>";
+$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avgresp'>avg. response time</a></th>";
+$str .= "<th align='left'><a href='".$PHP_SELF."?sortby=avail'>overall availability</a></th><th></th></tr>";
+$cnt = 0;
+foreach ($newArray as $k => $value) {
+	$img = "stop.bmp";
+	if ($status[$k]==0) $img = "wait.bmp";
+	elseif ($status[$k]==1) $img = "go.bmp";
+	if ($updated[$k] == "0" && $status[$k] == 0) $fill = "checked"; else $fill = "disabled";
+	if (fmod($cnt, 2) == 1) {
+		$str .= "\n\t\t<tr bgcolor='#e6e6e6'>";
+	else {
+		$str .= "\n\t\t<tr bgcolor='#f0f0f0'>";
+	$str .= "\n\t\t\t<td><input name='cb".$cnt."' value='" . $wms_id[$k] . "' type=checkbox ".$fill." /><input type=hidden name='upl_id".$cnt."' value='".$upload_id[$k]."'></td>";
+	$str .= "\n\t\t\t<td valign='top'><b>" . $wms_id[$k] . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id[$k]) . "</td>";
+	$str .= "\n\t\t\t<td valign='top'><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
+	$str .= "\n\t\t\t<td valign='top'>" . $comment[$k] . "<br><div style='font-size:12'>".date("F j, Y, G:i:s", $upload_id[$k])."</div></td>";
+	$str .= "\n\t\t\t<td valign='top' align = 'left'>";
+	if ($avg_response_time[$k] == NULL) {
+		$str .= "n/a";
+	else {
+		$str .= $avg_response_time[$k] . " s";
+	$str .= "</td>";
+	$str .= "\n\t\t\t<td valign='top'><b>" . $percentage[$k] . " %</b>&nbsp;&nbsp;<span style='font-size:12'>(" . $total[$k] . " cycles)</span><br>";
+	$str .= "<table bgcolor='black' border=1 cellspacing=1 cellpadding=0><tr>";
+	$val = $percentage[$k];
+	for ($i=0; $i<10; $i++) {
+		if ($val>=10) {
+			$str .= "<td height=10 width='10' bgcolor='red'></td>";
+			$val-=10;
+		elseif($val>0){
+			$str .= "<td height=10 width='" . round($val) . "' bgcolor='red'></td>";
+			if (round($val) < 10) {
+				$str .= "<td height=10 width='" . (9-round($val)) . "' bgcolor='white'></td>";
+			$val=-1;
+		else {
+			$str .= "<td height=10 width='10' bgcolor='white'></td>";
+	$str .= "</tr></table></td>";
+#	$str .= "\n\t\t\t<td><a href='output_".$wms_id[$k]."_".$max.".txt' target=_blank>log</a></td>";
+	$str .= "\n\t\t<td><input type=button value='details' onclick=\"var newWindow = window.open('../php/mod_monitorCapabilities_read_single.php?wmsid=".$wms_id[$k]."','wms','width=500,height=700,scrollbars');newWindow.href.location='test.php'\"></td></tr>";
+	$cnt++;
+$str .= "\n\t</table>\n\t<br/><input type=hidden name=cbs value='".$cnt."'>\n</form>";
+echo $str;
+</body></html>
Copied: branches/2.4.5/http/tools/mod_monitorCapabilities_read_single.php (from rev 2117, branches/2.4.5/http/php/mod_monitorCapabilities_read_single.php)
--- branches/2.4.5/http/tools/mod_monitorCapabilities_read_single.php	                        (rev 0)
+++ branches/2.4.5/http/tools/mod_monitorCapabilities_read_single.php	2008-02-20 12:42:58 UTC (rev 2120)
@@ -0,0 +1,102 @@
+<?php
+# $Id: mod_monitorCapabilities_read_single.php 76 2006-08-15 12:25:34Z heuser $
+session_start();
+<html>
+<head>
+<?php
+</head>
+<body>
+<?php
+if ($_GET['wmsid']) {
+	$wms_id = intval($_GET['wmsid']);
+else {
+	echo "Invalid WMS ID.";
+	die;
+$sql = "SELECT upload_id, status, status_comment, timestamp_begin, timestamp_end, upload_url, updated FROM mb_monitor ";
+$sql .= "WHERE fkey_wms_id = $1 AND NOT status = '-2' ORDER BY upload_id DESC";
+$v = array($wms_id);
+$t = array('i');
+$cnt=0;
+	$upload_id[$cnt] = db_result($res,$cnt,"upload_id");
+	$timestamp_begin = db_result($res,$cnt,"timestamp_begin");
+	$timestamp_end = db_result($res,$cnt,"timestamp_end");
+	if ($status[$cnt] == '0' || $status[$cnt] == '1') {
+		$response_time[$cnt] = strval($timestamp_end-$timestamp_begin) . " s";
+	else {
+		$response_time[$cnt] = "n/a";
+	$cnt++;
+$str .= "<b>" . $wms_id . "</b><br>" . $admin->getWmsTitleByWmsId($wms_id) . "<br><br><br>\n";
+$str .= "<tr bgcolor='#dddddd'><th align='left'>date</th><th align='left' colspan = 2>status</th><th align='center'>response time</th></tr>";
+for ($k=0; $k<count($upload_id); $k++) {
+	if (fmod($k, 2) == 1) {
+	else {
+	$str .= "\n\t\t\t<td>".date("F j, Y, G:i:s", $upload_id[$k])."</td>";
+	$str .= "\n\t\t\t<td><a href='".$upload_url[$k]."' target=_blank><img title='Connect to service' border=0 src = '../img/trafficlights/". $img. "'></a></td>";
+	$str .= "\n\t\t\t<td>" . $comment[$k] . "</td>";
+	$str .= "\n\t\t\t<td align='center'>" . $response_time[$k] . "</td>";
+$str .= "\n\t</table>\n\t";
+echo $str;
+</body></html>
Copied: branches/2.4.5/http/tools/mod_monitorCapabilities_write.php (from rev 2117, branches/2.4.5/http/php/mod_monitorCapabilities_write.php)
--- branches/2.4.5/http/tools/mod_monitorCapabilities_write.php	                        (rev 0)
+++ branches/2.4.5/http/tools/mod_monitorCapabilities_write.php	2008-02-20 12:42:58 UTC (rev 2120)
@@ -0,0 +1,128 @@
+<?php
+# $Id: mod_monitorCapabilities_write.php 76 2006-08-15 12:25:34Z heuser $
+//require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+require_once(dirname(__FILE__)."/../classes/class_wms.php");
+session_start();
+if ($_SERVER["argc"] != 4) {
+	echo "Insufficient arguments! Monitoring aborted.";
+	die();
+$wmsId = $_SERVER["argv"][1];
+$upload_id = $_SERVER["argv"][2];
+$auto_update = intval($_SERVER["argv"][3]);
+// get the uploadURL
+$sql = "SELECT upload_url FROM mb_monitor WHERE fkey_wms_id = $1 AND upload_id = $2";
+$v = array($wmsId, $upload_id);
+$t = array('i', 's');
+$someArray = db_fetch_row($res);
+$myURL = $someArray[0];
+// get the capabilities doc
+$sql = "SELECT wms_getcapabilities_doc FROM wms WHERE wms_id = $1";
+$v = array($wmsId);
+$t = array('i');
+$capabilities_doc = $someArray[0];
+$comment = "";
+$updated = "0";
+$result = -1;
+set_time_limit(TIME_LIMIT);
+if ($myURL) {
+	$remoteWms = new wms();
+	$remoteWms->createObjFromXML($myURL);
+	$now = time();
+	$remoteXml = $remoteWms->wms_getcapabilities_doc;
+	// compare the capabilities XML documents
+	$localXml = $capabilities_doc;
+	if (!$remoteXml) {
+		$result = -1;
+		$comment = "Connection failed.";
+	elseif (!$localXml) {
+		$result = 0;
+	else {
+		if ($localXml == $remoteXml) {
+			$result = 1;
+			$comment = "WMS is stable.";
+		else {
+			$result = 0;
+	if ($result == 0) {
+		$mywms = new wms();
+		if ($mywms->createObjFromXML($myURL)) {
+			if ($auto_update) {
+				$mywms->updateObjInDB($wmsId);
+				$updated = "1";
+				$comment = "WMS has been updated.";
+			else {
+				$comment = "WMS is not up to date.";
+		else {
+			$result = -1;
+			$comment = "Invalid getCapabilities request/document or service exception.";
+else {
+	$result = -1;
+	$comment = "Invalid upload URL.";
+	$now = time();
+echo "wmsid: " . $wmsId . "\nupload_id: " . $upload_id . "\n";
+echo "autoupdate: " . $auto_update . "\n";
+echo "result: " . $result . "\ncomment: " . $comment . "\n";
+echo "timestamp: " . $now . " (".date("F j, Y, G:i:s",$now).")\n";
+echo "getCapabilities URL: " . $myURL . "\nupdated: " . $updated . "\n\n";
+echo "-------------------------------------------------------------------\n";
+echo "remote XML:\n\n" . $remoteXml . "\n\n";
+echo "local XML:\n\n" . $localXml . "\n\n";
+$sql = "UPDATE mb_monitor SET updated = $1, status = $2, status_comment = $3, upload_url = $4, timestamp_end = $5 WHERE upload_id = $6 AND fkey_wms_id = $7";
+$v = array($updated, $result, $comment, $myURL, $now, $upload_id, $wmsId);
+$t = array('s', 's', 's', 's', 's', 's', 'i');
More information about the Mapbender_commits mailing list
