[Mapbender-commits] r2123 - branches/2.5/resources/db/postgresql
svn_mapbender at osgeo.org
Wed Feb 20 08:37:50 EST 2008
Author: astrid_emde
Date: 2008-02-20 08:37:50 -0500 (Wed, 20 Feb 2008)
New Revision: 2123
branches/2.5/resources/db/postgresql/pgsql_serial_set_sequences.sql
new select for sld_user_layer.sld_user_layer_id
Modified: branches/2.5/resources/db/postgresql/pgsql_serial_set_sequences.sql
--- branches/2.5/resources/db/postgresql/pgsql_serial_set_sequences.sql 2008-02-20 13:34:27 UTC (rev 2122)
+++ branches/2.5/resources/db/postgresql/pgsql_serial_set_sequences.sql 2008-02-20 13:37:50 UTC (rev 2123)
@@ -29,3 +29,6 @@
-- new sequences from Mapbender version 2.5
SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('translations', 'trs_id'), (Select max(trs_id) from translations), true);
SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('gui_kml', 'kml_id'), (Select max(kml_id) from gui_kml), true);
+SELECT pg_catalog.setval(pg_catalog.pg_get_serial_sequence('sld_user_layer', 'sld_user_layer_id'), (Select max(sld_user_layer_id) from sld_user_layer), true);
More information about the Mapbender_commits
