[Mapbender-commits] r2140 - in branches/2.4.5: http/extensions
http/include http/javascripts http/print
resources/db/postgresql resources/db/update
svn_mapbender at osgeo.org
Fri Feb 22 06:25:05 EST 2008
Author: christoph
Date: 2008-02-22 06:25:05 -0500 (Fri, 22 Feb 2008)
New Revision: 2140
branches/2.4.5/http/extensions/ext_featureInfoTunnel.php
branches/2.4.5/http/extensions/ext_weldMaps.php
branches/2.4.5/http/extensions/geom2wfst.php
branches/2.4.5/http/extensions/markResult.php
branches/2.4.5/http/include/dyn_css.php
branches/2.4.5/http/include/dyn_js.php
branches/2.4.5/http/include/dyn_php.php
branches/2.4.5/http/javascripts/map.php
branches/2.4.5/http/javascripts/mod_addWMS.php
branches/2.4.5/http/javascripts/mod_addWMSfromList.php
branches/2.4.5/http/javascripts/mod_addWMSfromfilteredList.php
branches/2.4.5/http/javascripts/mod_addWMSfromfilteredListDB.php
branches/2.4.5/http/javascripts/mod_addWMSfromfilteredList_ajax.php
branches/2.4.5/http/javascripts/mod_add_vendorspecific.php
branches/2.4.5/http/javascripts/mod_back.php
branches/2.4.5/http/javascripts/mod_center1.php
branches/2.4.5/http/javascripts/mod_coords.php
branches/2.4.5/http/javascripts/mod_coords_div.php
branches/2.4.5/http/javascripts/mod_copyright.php
branches/2.4.5/http/javascripts/mod_dependentDiv.php
branches/2.4.5/http/javascripts/mod_dependentIframe.php
branches/2.4.5/http/javascripts/mod_digitize_tab.php
branches/2.4.5/http/javascripts/mod_displayWmc.php
branches/2.4.5/http/javascripts/mod_dragMapSize.php
branches/2.4.5/http/javascripts/mod_dynamicOverview.php
branches/2.4.5/http/javascripts/mod_embedded_legend.php
branches/2.4.5/http/javascripts/mod_export_image.php
branches/2.4.5/http/javascripts/mod_featureInfo.php
branches/2.4.5/http/javascripts/mod_featureInfoRedirect.php
branches/2.4.5/http/javascripts/mod_featureInfoTunnel.php
branches/2.4.5/http/javascripts/mod_forward.php
branches/2.4.5/http/javascripts/mod_gazetteerSQL_client.php
branches/2.4.5/http/javascripts/mod_getArea.php
branches/2.4.5/http/javascripts/mod_help.php
branches/2.4.5/http/javascripts/mod_highlightPOI.php
branches/2.4.5/http/javascripts/mod_home.php
branches/2.4.5/http/javascripts/mod_initWmc.php
branches/2.4.5/http/javascripts/mod_insertKmlIntoDb.php
branches/2.4.5/http/javascripts/mod_insertLayerPreviewIntoDb.php
branches/2.4.5/http/javascripts/mod_key.php
branches/2.4.5/http/javascripts/mod_legend.php
branches/2.4.5/http/javascripts/mod_loadwmc.php
branches/2.4.5/http/javascripts/mod_measure.php
branches/2.4.5/http/javascripts/mod_navFrame.php
branches/2.4.5/http/javascripts/mod_owsproxy.php
branches/2.4.5/http/javascripts/mod_pan.php
branches/2.4.5/http/javascripts/mod_perimeter.php
branches/2.4.5/http/javascripts/mod_poi.php
branches/2.4.5/http/javascripts/mod_print1.php
branches/2.4.5/http/javascripts/mod_repaint.php
branches/2.4.5/http/javascripts/mod_resize_mapsize.php
branches/2.4.5/http/javascripts/mod_sandclock.php
branches/2.4.5/http/javascripts/mod_sandclock2.php
branches/2.4.5/http/javascripts/mod_saveLayerPreview.php
branches/2.4.5/http/javascripts/mod_saveWmcKml.php
branches/2.4.5/http/javascripts/mod_savewmc.php
branches/2.4.5/http/javascripts/mod_scaleHint.php
branches/2.4.5/http/javascripts/mod_scaleSel.php
branches/2.4.5/http/javascripts/mod_scaleText.php
branches/2.4.5/http/javascripts/mod_scalebar.php
branches/2.4.5/http/javascripts/mod_selArea.php
branches/2.4.5/http/javascripts/mod_selArea1.php
branches/2.4.5/http/javascripts/mod_selectMapsize.php
branches/2.4.5/http/javascripts/mod_setBBOX1.php
branches/2.4.5/http/javascripts/mod_setBackground.php
branches/2.4.5/http/javascripts/mod_setBackground_all.php
branches/2.4.5/http/javascripts/mod_setPOI2Scale.php
branches/2.4.5/http/javascripts/mod_setTimeout.php
branches/2.4.5/http/javascripts/mod_state.php
branches/2.4.5/http/javascripts/mod_tab.php
branches/2.4.5/http/javascripts/mod_toggleModule.php
branches/2.4.5/http/javascripts/mod_usemap.php
branches/2.4.5/http/javascripts/mod_wfs_SpatialRequest.php
branches/2.4.5/http/javascripts/mod_wfs_gazetteer_client.php
branches/2.4.5/http/javascripts/mod_zoomCoords.php
branches/2.4.5/http/javascripts/mod_zoomFull.php
branches/2.4.5/http/javascripts/mod_zoomIn1.php
branches/2.4.5/http/javascripts/mod_zoomOut1.php
branches/2.4.5/http/print/mod_printPDF.php
branches/2.4.5/http/print/mod_printPDF_pdf.php
branches/2.4.5/resources/db/postgresql/pgsql_schema.sql
branches/2.4.5/resources/db/update/update_mysql_db.sql
branches/2.4.5/resources/db/update/update_postgresql_db.sql
added session validating to php scripts
Modified: branches/2.4.5/http/extensions/ext_featureInfoTunnel.php
--- branches/2.4.5/http/extensions/ext_featureInfoTunnel.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/extensions/ext_featureInfoTunnel.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -16,7 +16,7 @@
# You should have received a copy of the GNU General Public License
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
require_once("../classes/class_stripRequest.php");
require_once("../classes/class_connector.php");
$mr = new stripRequest(urldecode($_REQUEST["url"]));
Modified: branches/2.4.5/http/extensions/ext_weldMaps.php
--- branches/2.4.5/http/extensions/ext_weldMaps.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/extensions/ext_weldMaps.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -90,7 +90,7 @@
$bgc = ImageColorAllocate ($im, 255, 255, 255);
$tc = ImageColorAllocate ($im, 0, 0, 0);
ImageFilledRectangle ($im, 0, 0, $map_width, $map_height, $bgc);
- ImageString($im, 1, 5, 5, "Fehler beim Öffnen von: ", $tc);
+ ImageString($im, 1, 5, 5, "Fehler beim �ffnen von: ", $tc);
$chunk = chunk_split(urldecode($imgname), 60, "###");
$array_chunk = explode("###", $chunk);
for($i=0; $i<count($array_chunk); $i++){
@@ -112,7 +112,7 @@
return $newResolution;
-session_start();
$map_urls = explode("###",$_SESSION["mb_print_url"]);
$output = new weldMaps($map_urls, $_SESSION["mb_print_resolution"]);
\ No newline at end of file
Modified: branches/2.4.5/http/extensions/geom2wfst.php
--- branches/2.4.5/http/extensions/geom2wfst.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/extensions/geom2wfst.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -18,7 +18,7 @@
require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
Modified: branches/2.4.5/http/extensions/markResult.php
--- branches/2.4.5/http/extensions/markResult.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/extensions/markResult.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -23,6 +23,8 @@
* $color -> Color of the polygon/line, commasaparated RGB-values
import_request_variables("PG");
$tmpx = array();
$tmpy = array();
Modified: branches/2.4.5/http/include/dyn_css.php
--- branches/2.4.5/http/include/dyn_css.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/include/dyn_css.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
-require_once("../../conf/mapbender.conf");
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
Modified: branches/2.4.5/http/include/dyn_js.php
--- branches/2.4.5/http/include/dyn_js.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/include/dyn_js.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,6 +17,7 @@
if(isset($gui_id))
$sql = "SELECT * FROM gui_element_vars WHERE fkey_e_id = $1 AND fkey_gui_id = $2 and var_type='var'";
Modified: branches/2.4.5/http/include/dyn_php.php
--- branches/2.4.5/http/include/dyn_php.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/include/dyn_php.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,6 +17,8 @@
if(isset($gui_id))
$sql = "SELECT * FROM gui_element_vars WHERE fkey_gui_id = $1 and var_type='php_var'";
Modified: branches/2.4.5/http/javascripts/map.php
--- branches/2.4.5/http/javascripts/map.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/map.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
ob_start();
// see http://trac.osgeo.org/mapbender/ticket/79
ini_set('session.bug_compat_42',0);
Modified: branches/2.4.5/http/javascripts/mod_addWMS.php
--- branches/2.4.5/http/javascripts/mod_addWMS.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_addWMS.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,10 +17,10 @@
$gui_id = $_REQUEST["gui_id"];
$con = db_connect($DBSERVER,$OWNER,$PW);
Modified: branches/2.4.5/http/javascripts/mod_addWMSfromList.php
--- branches/2.4.5/http/javascripts/mod_addWMSfromList.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_addWMSfromList.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,6 @@
Modified: branches/2.4.5/http/javascripts/mod_addWMSfromfilteredList.php
--- branches/2.4.5/http/javascripts/mod_addWMSfromfilteredList.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_addWMSfromfilteredList.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,6 @@
Modified: branches/2.4.5/http/javascripts/mod_addWMSfromfilteredListDB.php
--- branches/2.4.5/http/javascripts/mod_addWMSfromfilteredListDB.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_addWMSfromfilteredListDB.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,6 @@
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
Modified: branches/2.4.5/http/javascripts/mod_addWMSfromfilteredList_ajax.php
--- branches/2.4.5/http/javascripts/mod_addWMSfromfilteredList_ajax.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_addWMSfromfilteredList_ajax.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_add_vendorspecific.php
--- branches/2.4.5/http/javascripts/mod_add_vendorspecific.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_add_vendorspecific.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -18,6 +18,8 @@
mb_registerVendorSpecific("mod_vs_init()");
function mod_vs_init(){
Modified: branches/2.4.5/http/javascripts/mod_back.php
--- branches/2.4.5/http/javascripts/mod_back.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_back.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'back' AND fkey_gui_id = $1 ";
Modified: branches/2.4.5/http/javascripts/mod_center1.php
--- branches/2.4.5/http/javascripts/mod_center1.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_center1.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_coords.php
--- branches/2.4.5/http/javascripts/mod_coords.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_coords.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_coords_div.php
--- branches/2.4.5/http/javascripts/mod_coords_div.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_coords_div.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -16,7 +16,7 @@
Modified: branches/2.4.5/http/javascripts/mod_copyright.php
--- branches/2.4.5/http/javascripts/mod_copyright.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_copyright.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,8 @@
$e_id_css = 'copyright';
include '../include/dyn_js.php';
Modified: branches/2.4.5/http/javascripts/mod_dependentDiv.php
--- branches/2.4.5/http/javascripts/mod_dependentDiv.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_dependentDiv.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_dependentIframe.php
--- branches/2.4.5/http/javascripts/mod_dependentIframe.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_dependentIframe.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,9 @@
$sql = "SELECT e_target FROM gui_element WHERE e_id = 'dependentIframe' AND fkey_gui_id = $1 ";
Modified: branches/2.4.5/http/javascripts/mod_digitize_tab.php
--- branches/2.4.5/http/javascripts/mod_digitize_tab.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_digitize_tab.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,10 +17,8 @@
-session_start();
-require_once("../php/mb_validateSession.php");
$gui_id = $_SESSION["mb_user_gui"];
Modified: branches/2.4.5/http/javascripts/mod_displayWmc.php
--- branches/2.4.5/http/javascripts/mod_displayWmc.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_displayWmc.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -16,7 +16,7 @@
-include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
$wmc_id = $_GET["wmc_id"];
Modified: branches/2.4.5/http/javascripts/mod_dragMapSize.php
--- branches/2.4.5/http/javascripts/mod_dragMapSize.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_dragMapSize.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,9 @@
$sql = "SELECT e_target FROM gui_element WHERE e_id = 'dragMapSize' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_dynamicOverview.php
--- branches/2.4.5/http/javascripts/mod_dynamicOverview.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_dynamicOverview.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -18,7 +18,7 @@
$e_id_css = 'dynamicOverview';
Modified: branches/2.4.5/http/javascripts/mod_embedded_legend.php
--- branches/2.4.5/http/javascripts/mod_embedded_legend.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_embedded_legend.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -16,8 +16,7 @@
-session_start();
<html>
Modified: branches/2.4.5/http/javascripts/mod_export_image.php
--- branches/2.4.5/http/javascripts/mod_export_image.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_export_image.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -16,9 +16,9 @@
-include(dirname(__FILE__)."/../../conf/mapbender.conf");
-session_start();
<html>
@@ -192,7 +192,7 @@
//disablePrinting();
//else{
- // alert("Das Format ist noch nicht ausgewählt.");
+ // alert("Das Format ist noch nicht ausgew�hlt.");
// window.opener.mod_back_set();
@@ -210,7 +210,7 @@
<table border='0'>
<tr>
<td class="text">
- Vergrößerungsfaktor
+ Vergr��erungsfaktor
</td>
</tr>
<tr>
Modified: branches/2.4.5/http/javascripts/mod_featureInfo.php
--- branches/2.4.5/http/javascripts/mod_featureInfo.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_featureInfo.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_featureInfoRedirect.php
--- branches/2.4.5/http/javascripts/mod_featureInfoRedirect.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_featureInfoRedirect.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -16,6 +16,8 @@
Modified: branches/2.4.5/http/javascripts/mod_featureInfoTunnel.php
--- branches/2.4.5/http/javascripts/mod_featureInfoTunnel.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_featureInfoTunnel.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_forward.php
--- branches/2.4.5/http/javascripts/mod_forward.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_forward.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_gazetteerSQL_client.php
--- branches/2.4.5/http/javascripts/mod_gazetteerSQL_client.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_gazetteerSQL_client.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -1,7 +1,5 @@
<?php
-session_start();
$e_id = $_REQUEST["elementID"];
$e_target = explode(",", $_REQUEST["e_target"]);
Modified: branches/2.4.5/http/javascripts/mod_getArea.php
--- branches/2.4.5/http/javascripts/mod_getArea.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_getArea.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_help.php
--- branches/2.4.5/http/javascripts/mod_help.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_help.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,8 @@
Modified: branches/2.4.5/http/javascripts/mod_highlightPOI.php
--- branches/2.4.5/http/javascripts/mod_highlightPOI.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_highlightPOI.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
-include("../../conf/mapbender.conf");
Modified: branches/2.4.5/http/javascripts/mod_home.php
--- branches/2.4.5/http/javascripts/mod_home.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_home.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -15,10 +15,11 @@
function mod_home_init(){
<?php
echo "var url = '".LOGIN."';";
echo "var name = '".urlencode($_SESSION["mb_user_name"])."';";
echo "var pw = '".$_SESSION["mb_user_password"]."';";
Modified: branches/2.4.5/http/javascripts/mod_initWmc.php
--- branches/2.4.5/http/javascripts/mod_initWmc.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_initWmc.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -1,5 +1,6 @@
<?php
-session_start();
if ($_SESSION['mb_myWmc'] && $_SESSION['mb_myWmc_action'] && in_array($_SESSION['mb_myWmc_action'], array("load", "merge", "append"))) {
$action = $_SESSION['mb_myWmc_action'];
$wmc_id = $_SESSION['mb_myWmc'];
Modified: branches/2.4.5/http/javascripts/mod_insertKmlIntoDb.php
--- branches/2.4.5/http/javascripts/mod_insertKmlIntoDb.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_insertKmlIntoDb.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
include("../classes/class_kml.php");
session_start();
Modified: branches/2.4.5/http/javascripts/mod_insertLayerPreviewIntoDb.php
--- branches/2.4.5/http/javascripts/mod_insertLayerPreviewIntoDb.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_insertLayerPreviewIntoDb.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,7 @@
-session_start();
require_once(dirname(__FILE__)."/../classes/class_administration.php");
Modified: branches/2.4.5/http/javascripts/mod_key.php
--- branches/2.4.5/http/javascripts/mod_key.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_key.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_legend.php
--- branches/2.4.5/http/javascripts/mod_legend.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_legend.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -16,8 +16,7 @@
-session_start();
Modified: branches/2.4.5/http/javascripts/mod_loadwmc.php
--- branches/2.4.5/http/javascripts/mod_loadwmc.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_loadwmc.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
require_once(dirname(__FILE__)."/../classes/class_wmc.php");
Modified: branches/2.4.5/http/javascripts/mod_measure.php
--- branches/2.4.5/http/javascripts/mod_measure.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_measure.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_navFrame.php
--- branches/2.4.5/http/javascripts/mod_navFrame.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_navFrame.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,9 @@
Modified: branches/2.4.5/http/javascripts/mod_owsproxy.php
--- branches/2.4.5/http/javascripts/mod_owsproxy.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_owsproxy.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -16,8 +16,6 @@
-session_start();
include(dirname(__FILE__)."/../php/mb_validateSession.php");
include(dirname(__FILE__)."/../classes/class_administration.php");
Modified: branches/2.4.5/http/javascripts/mod_pan.php
--- branches/2.4.5/http/javascripts/mod_pan.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_pan.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'pan1' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_perimeter.php
--- branches/2.4.5/http/javascripts/mod_perimeter.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_perimeter.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_poi.php
--- branches/2.4.5/http/javascripts/mod_poi.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_poi.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -1,6 +1,6 @@
<?php
-session_start();
@@ -110,7 +110,7 @@
function validate(){
if(document.form1.search.value.length < 1){
- alert("Bitte vervollständigen Sie die Angaben!");
+ alert("Bitte vervollst�ndigen Sie die Angaben!");
document.form1.search.focus();
return false;
@@ -219,7 +219,7 @@
$md_fileidentifier[$cnt] = pg_result($res,$cnt,"md_fileidentifier"); # Layername
$layername[$cnt] = pg_result($res,$cnt,"md_fileidentifier"); # Layername in der Mapdatei
$result_title[$cnt] = pg_result($res,$cnt,"\"".$title."\""); # layer_deutsch Ergebnisname
- $search_columns[$cnt] = pg_result($res,$cnt,"search_columns"); # Suchspalten, Trennung über ,
+ $search_columns[$cnt] = pg_result($res,$cnt,"search_columns"); # Suchspalten, Trennung �ber ,
$search_result[$cnt] = pg_result($res,$cnt,"search_result"); # Ergebnisspalte
$search_keywords[$cnt] = pg_result($res,$cnt,"search_keywords"); # Ergebnisspalte
$wms_title[$cnt] = pg_result($res,$cnt,"wms_title"); # WMS tile
Modified: branches/2.4.5/http/javascripts/mod_print1.php
--- branches/2.4.5/http/javascripts/mod_print1.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_print1.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,8 @@
-session_start();
include(dirname(__FILE__)."/../../conf/print.conf");
<html>
@@ -193,7 +192,7 @@
disablePrinting();
else{
- alert("Das Format ist noch nicht ausgewählt.");
+ alert("Das Format ist noch nicht ausgew�hlt.");
Modified: branches/2.4.5/http/javascripts/mod_repaint.php
--- branches/2.4.5/http/javascripts/mod_repaint.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_repaint.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'repaint' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_resize_mapsize.php
--- branches/2.4.5/http/javascripts/mod_resize_mapsize.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_resize_mapsize.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -20,7 +20,7 @@
Modified: branches/2.4.5/http/javascripts/mod_sandclock.php
--- branches/2.4.5/http/javascripts/mod_sandclock.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_sandclock.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,9 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'sandclock' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_sandclock2.php
--- branches/2.4.5/http/javascripts/mod_sandclock2.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_sandclock2.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,9 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'sandclock2' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_saveLayerPreview.php
--- branches/2.4.5/http/javascripts/mod_saveLayerPreview.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_saveLayerPreview.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,8 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'savewmc' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_saveWmcKml.php
--- branches/2.4.5/http/javascripts/mod_saveWmcKml.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_saveWmcKml.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,8 @@
-session_start();
require_once(dirname(__FILE__)."/mod_savewmc.php");
Modified: branches/2.4.5/http/javascripts/mod_savewmc.php
--- branches/2.4.5/http/javascripts/mod_savewmc.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_savewmc.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
Modified: branches/2.4.5/http/javascripts/mod_scaleHint.php
--- branches/2.4.5/http/javascripts/mod_scaleHint.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_scaleHint.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,9 @@
$sql = "SELECT e_target FROM gui_element WHERE e_id = 'setScaleHint' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_scaleSel.php
--- branches/2.4.5/http/javascripts/mod_scaleSel.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_scaleSel.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'scaleSelect' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_scaleText.php
--- branches/2.4.5/http/javascripts/mod_scaleText.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_scaleText.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'scaleText' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_scalebar.php
--- branches/2.4.5/http/javascripts/mod_scalebar.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_scalebar.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'scalebar' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_selArea.php
--- branches/2.4.5/http/javascripts/mod_selArea.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_selArea.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'selArea1' AND fkey_gui_id = '".$gui_id."'";
Modified: branches/2.4.5/http/javascripts/mod_selArea1.php
--- branches/2.4.5/http/javascripts/mod_selArea1.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_selArea1.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,9 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'selArea1' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_selectMapsize.php
--- branches/2.4.5/http/javascripts/mod_selectMapsize.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_selectMapsize.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,9 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'selectMapsize' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_setBBOX1.php
--- branches/2.4.5/http/javascripts/mod_setBBOX1.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_setBBOX1.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
$sql = "SELECT e_target FROM gui_element WHERE e_id = 'setBBOX' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_setBackground.php
--- branches/2.4.5/http/javascripts/mod_setBackground.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_setBackground.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'setBackground' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_setBackground_all.php
--- branches/2.4.5/http/javascripts/mod_setBackground_all.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_setBackground_all.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -18,9 +18,9 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'setBackground_all' AND fkey_gui_id = $1 ";
Modified: branches/2.4.5/http/javascripts/mod_setPOI2Scale.php
--- branches/2.4.5/http/javascripts/mod_setPOI2Scale.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_setPOI2Scale.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,8 +17,8 @@
$sql = "SELECT e_target FROM gui_element WHERE e_id = 'setPOI2Scale' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_setTimeout.php
--- branches/2.4.5/http/javascripts/mod_setTimeout.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_setTimeout.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -18,8 +18,7 @@
-session_start();
$e_id_css = 'timeout';
Modified: branches/2.4.5/http/javascripts/mod_state.php
--- branches/2.4.5/http/javascripts/mod_state.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_state.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,8 @@
-//require(dirname(__FILE__)."/mb_validateSession.php");
Modified: branches/2.4.5/http/javascripts/mod_tab.php
--- branches/2.4.5/http/javascripts/mod_tab.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_tab.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -19,6 +19,7 @@
/********** Configuration*************************************************/
$e_id_css = 'tabs';
include(dirname(__FILE__).'/../include/dyn_js.php');
Modified: branches/2.4.5/http/javascripts/mod_toggleModule.php
--- branches/2.4.5/http/javascripts/mod_toggleModule.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_toggleModule.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,9 @@
$sql = "SELECT e_target FROM gui_element WHERE e_id = 'toggleModule' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_usemap.php
--- branches/2.4.5/http/javascripts/mod_usemap.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_usemap.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -16,6 +16,8 @@
var mod_usemap_target = 'mapframe1';
var mod_usemap_wfs = "<url>";
Modified: branches/2.4.5/http/javascripts/mod_wfs_SpatialRequest.php
--- branches/2.4.5/http/javascripts/mod_wfs_SpatialRequest.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_wfs_SpatialRequest.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,10 +17,8 @@
-session_start();
require_once("../../conf/wfs_default.conf");
Modified: branches/2.4.5/http/javascripts/mod_wfs_gazetteer_client.php
--- branches/2.4.5/http/javascripts/mod_wfs_gazetteer_client.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_wfs_gazetteer_client.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -18,13 +18,12 @@
-session_start();
$target = $_REQUEST["target"];
$e_id_css = $_REQUEST["e_id_css"];
db_select_db($DB,$con);
Modified: branches/2.4.5/http/javascripts/mod_zoomCoords.php
--- branches/2.4.5/http/javascripts/mod_zoomCoords.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_zoomCoords.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -1,10 +1,8 @@
<?php
#$Id$
#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_zoomCoords.php,v 1.10 2006/03/09 08:57:13 uli_rothstein Exp $
-session_start();
-import_request_variables("PG");
+import_request_variables("PG");
Modified: branches/2.4.5/http/javascripts/mod_zoomFull.php
--- branches/2.4.5/http/javascripts/mod_zoomFull.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_zoomFull.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -1,8 +1,8 @@
<?php
#$Id$
#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_zoomFull.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'zoomFull' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_zoomIn1.php
--- branches/2.4.5/http/javascripts/mod_zoomIn1.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_zoomIn1.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,9 +17,8 @@
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'zoomIn1' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/javascripts/mod_zoomOut1.php
--- branches/2.4.5/http/javascripts/mod_zoomOut1.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/javascripts/mod_zoomOut1.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -1,9 +1,9 @@
<?php
#$Id$
#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_zoomOut1.php,v 1.8 2005/09/13 18:16:42 bjoern_heuser Exp $
$sql = "SELECT e_src, e_target FROM gui_element WHERE e_id = 'zoomOut1' AND fkey_gui_id = $1";
Modified: branches/2.4.5/http/print/mod_printPDF.php
--- branches/2.4.5/http/print/mod_printPDF.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/print/mod_printPDF.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -16,7 +16,7 @@
-session_start();
@@ -261,7 +261,7 @@
//overview_url
var ind_overview = pt.getMapObjIndexByName('overview');
- //alert ("länge: " + length+ " - " + ind_overview + name + pt.mb_mapObj[ind_overview].wms.length);
+ //alert ("l�nge: " + length+ " - " + ind_overview + name + pt.mb_mapObj[ind_overview].wms.length);
if(pt.mb_mapObj[ind_overview].mapURL != false ){
document.forms[0].overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
@@ -324,7 +324,7 @@
document.form1.submit();
else{
function valCom(obj){
Modified: branches/2.4.5/http/print/mod_printPDF_pdf.php
--- branches/2.4.5/http/print/mod_printPDF_pdf.php 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/http/print/mod_printPDF_pdf.php 2008-02-22 11:25:05 UTC (rev 2140)
@@ -17,7 +17,7 @@
-#require_once("../php/mb_validateSession.php");
ob_start();
session_start();
ini_set('error_reporting', 'E_ALL & ~ E_NOTICE');
Modified: branches/2.4.5/resources/db/postgresql/pgsql_schema.sql
--- branches/2.4.5/resources/db/postgresql/pgsql_schema.sql 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/resources/db/postgresql/pgsql_schema.sql 2008-02-22 11:25:05 UTC (rev 2140)
@@ -24,7 +24,6 @@
e_pos integer,
e_public integer,
e_comment text,
- e_title character varying(255),
e_element character varying(255) DEFAULT ''::character varying NOT NULL,
e_src character varying(255),
e_attributes text,
@@ -40,7 +39,8 @@
e_mb_mod character varying(50),
e_target character varying(50),
e_requires character varying(50),
- e_url character varying(255)
+ e_url character varying(255),
+ e_title character varying(255)
Modified: branches/2.4.5/resources/db/update/update_mysql_db.sql
--- branches/2.4.5/resources/db/update/update_mysql_db.sql 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/resources/db/update/update_mysql_db.sql 2008-02-22 11:25:05 UTC (rev 2140)
@@ -1,9 +1,8 @@
--- database changes in version 2.4.3
+-- database changes in version 2.4.5
--- table wms_format: http://trac.osgeo.org/mapbender/ticket/53
+-- table gui_element: new column for translation
-ALTER TABLE wms_format CHANGE data_format data_format VARCHAR(100);
+ALTER TABLE gui_element ADD COLUMN e_title VARCHAR(255);
Modified: branches/2.4.5/resources/db/update/update_postgresql_db.sql
--- branches/2.4.5/resources/db/update/update_postgresql_db.sql 2008-02-21 17:13:37 UTC (rev 2139)
+++ branches/2.4.5/resources/db/update/update_postgresql_db.sql 2008-02-22 11:25:05 UTC (rev 2140)
@@ -1,9 +1,9 @@
-ALTER TABLE wms_format ALTER COLUMN data_format TYPE varchar(100);
More information about the Mapbender_commits
