[Mapbender-commits] r2149 - branches/2.4.5/http/php
svn_mapbender at osgeo.org
Wed Feb 27 07:52:37 EST 2008
Author: astrid_emde
Date: 2008-02-27 07:52:36 -0500 (Wed, 27 Feb 2008)
New Revision: 2149
Added:
branches/2.4.5/http/php/download.php
http://www.mapbender.org/ExportMapimage
download script forimages
Added: branches/2.4.5/http/php/download.php
--- branches/2.4.5/http/php/download.php (rev 0)
+++ branches/2.4.5/http/php/download.php 2008-02-27 12:52:36 UTC (rev 2149)
@@ -0,0 +1,70 @@
+<?php
+#$Id$
+# http://www.mapbender.org/ExportMapimage
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+ob_start();
+require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+$download = array();
+$download["dir"] = TMPDIR;
+$download["file"] = trim($_REQUEST["download"]);
+if(!(bool)$download["file"]) {
+ die("No filename given.");
+if((int)strpos($download["file"],"..") !== 0) {
+ die("Illegal filename given.");
+if(!file_exists(implode($download)) || !is_readable(implode($download))) {
+ die("An error occured.");
+$now_date = date("Ymd_His");
+switch(substr($download["file"],-4)) {
+ case ".png":
+ $filename = "map_export__".$now_date.".png";
+ header('Content-Type: image/png');
+ break;
+ case "jpeg":
+ $filename = "map_export__".$now_date.".jpeg";
+ header('Content-Type: image/jpeg');
+ break;
+ case ".tif";
+ $filename = "map_export__".$now_date.".tif";
+ header('Content-Type: image/tif');
+ break;
+ default:
+header("Content-Disposition: attachment; filename=\"".$filename."\"");
+readfile(implode($download));
\ No newline at end of file
Property changes on: branches/2.4.5/http/php/download.php
___________________________________________________________________
+ HeadURL Id LastChangedBy LastChangedDate LastChangedRevision
More information about the Mapbender_commits
