[Mapbender-commits] r1942 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org
Thu Jan 3 10:02:48 EST 2008
Author: christoph
Date: 2008-01-03 10:02:48 -0500 (Thu, 03 Jan 2008)
New Revision: 1942
trunk/mapbender/http/classes/class_administration.php
changed some comments, according to phpdoc
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php 2007-12-21 16:10:40 UTC (rev 1941)
+++ trunk/mapbender/http/classes/class_administration.php 2008-01-03 15:02:48 UTC (rev 1942)
@@ -48,13 +48,13 @@
* sends an email via php mailer
- * @param <string> an email address for the "From"-field
- * @param <string> the displayed name for the "From"-field
- * @param <string> an email address for the "To"-field
- * @param <string> the text to be set as "Subject"
- * @param <string> the text of the emails body
- * @param <string> a reference to an error string
+ * @param string an email address for the "From"-field
+ * @param string the displayed name for the "From"-field
+ * @param string an email address for the "To"-field
+ * @param string the text to be set as "Subject"
+ * @param string the text of the emails body
+ * @param string a reference to an error string
function sendEmail($fromAddr, $fromName, $toAddr, $toName, $subject, $body, &$error_msg ){
@@ -111,7 +111,7 @@
* returns a random password with numbers and chars both lowercase and uppercase (0-9a-zA-Z)
- * @return <string> the new password
+ * @return string the new password
function getRandomPassword() {
@@ -137,8 +137,8 @@
* returns the name of a mapbender user which owns the GUI identified by the passed over gui_id.
- * @param <string> the gui_id
- * @return <integer> the user id of the owner
+ * @param string the gui_id
+ * @return integer the user id of the owner
function getOwnerByGui($gui_id){
$sql = "(SELECT mb_user.mb_user_id";
@@ -197,8 +197,8 @@
* returns the name of the user for the given userid.
- * @param <integer> the userid
- * @return the name if one row is found or false if none is foundd
+ * @param integer the userid
+ * @return string the name if one row is found or false if none is foundd
function getUserNameByUserId($userid){
$sql = "SELECT mb_user_name FROM mb_user ";
@@ -223,8 +223,8 @@
* returns one or more userids from the given email or false,
* if there is no record in the database matching the given email
- * @param <string> the email
- * @return <mixed> returns an array of userids or false when no records matches
+ * @param string the email
+ * @return mixed an array of userids or false when no records matches
function getUserIdByEmail($email){
$sql = "SELECT mb_user_id FROM mb_user ";
@@ -251,8 +251,9 @@
* this wms are selected. Afterwards for each of the guis the owners are
* selected and stored within an array.
- * @param <integer> the wms_id
- * @return <mixed> an array of user ids which use the wms in their guis (both for persona or group ownership)
+ * @param integer the wms_id
+ * @return mixed an array of user ids which use the wms in their guis
+ * (both for persona or group ownership)
function getOwnerByWms($wms_id){
// first get guis which deploy this wms.
@@ -320,8 +321,8 @@
* tests whether a gui with the passed gui_id exits and returns true or false.
- * @param <string> the gui_id to test
- * @return <boolean> Does a Gui with the passed over gui_id exist?
+ * @param string the gui_id to test
+ * @return boolean Does a Gui with the passed over gui_id exist?
function guiExists($id){
$sql = "SELECT * FROM gui WHERE gui_id = $1 ";
@@ -338,11 +339,12 @@
- * deletes a WMC entry specified by wmc_id and user_id
+ * deletes a {@link http://www.mapbender.org/index.php/WMC WMC} entry specified by wmc_id and user_id
- * @param <integer> the user_id
- * @param <string> the wmc_id
- * @return <boolean> Did the query run succesfull? This does not necessarily mean that an entry was deleted.
+ * @param integer the user_id
+ * @param string the wmc_id
+ * @return boolean Did the query run succesfull? This does not necessarily mean that
+ * an entry was deleted.
function deleteWmc($wmc_id, $user_id){
$sql = "DELETE FROM mb_user_wmc ";
@@ -361,9 +363,9 @@
* inserts a gui with the specified gui_id, after checking the uniqueness of teh gui id.
- * @uses guiExists
- * @param <string> the name and id of the gui to insert.
- * @return <boolean> could the gui be inserted?
+ * @uses administration::guiExists()
+ * @param string $guiId the name and id of the gui to insert.
+ * @return boolean could the gui be inserted?
function insertGui($guiId) {
if (!$this->guiExists($guiId)) {
@@ -381,8 +383,9 @@
* deletes links between user and guis in gui_mb_user for a certain gui.
- * @param <string> the gui name
- * @return <boolean> could the sql be executed without errors. This does not necessarily mean, that entries were deleted
+ * @param string the gui name
+ * @return boolean could the sql be executed without errors. This does not
+ * necessarily mean, that entries were deleted
function delAllUsersOfGui($guiId) {
$sql = "DELETE FROM gui_mb_user WHERE fkey_gui_id = $1 ";
@@ -400,8 +403,8 @@
* returns an array of WMS for a given user id
* @uses getGuisByOwner
- * @param <integer> the user id
- * @return <array> wms ids for the user
+ * @param integer $user_id the user id
+ * @return integer[] wms ids for the user
function getWmsByOwner($user_id){
$gui_list = $this->getGuisByOwner($user_id,true);
@@ -410,8 +413,8 @@
* returns an array of WMS where the owner is the user with the passed user_id
+ * @param integer the user id
+ * @return array wms ids for the user
function getWmsByWmsOwner($user_id){
$sql = "SELECT wms_id FROM wms WHERE wms_owner = $1";
@@ -428,8 +431,8 @@
* returns an array of user which are associated with a wms
- * @param <integer> the wms id
- * @return <array> user_ids for the wms
+ * @param integer the wms id
+ * @return array user_ids for the wms
function getUserByWms($wms_id){
$sql = "SELECT fkey_gui_id FROM gui_wms WHERE fkey_wms_id = $1 GROUP BY fkey_gui_id";
@@ -481,8 +484,8 @@
* selects the WMS-title for a given wms id.
- * @return <string|boolean> either the title of the wms as string or false when none exists
+ * @return string|boolean either the title of the wms as string or false when none exists
function getWmsTitleByWmsId($id){
$sql = "SELECT wms_title FROM wms WHERE wms_id = $1 GROUP BY wms_title";
@@ -496,8 +499,8 @@
* selects the Layer-title for a given layer id.
function getLayerTitleByLayerId($id){
$sql = "SELECT layer_title FROM layer WHERE layer_id = $1 GROUP BY layer_title";
@@ -511,8 +514,8 @@
* selects the WMC for a given wmc_id.
- * @return <string|boolean> either the wmc as string or false when none exists
+ * @return string|boolean either the wmc as string or false when none exists
function getWmcById($id){
$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1 ";
@@ -530,8 +533,8 @@
* resets the login count of a given user to 0
- * @return <boolean> could the login count be reseted?
+ * @return boolean could the login count be reseted?
function resetLoginCount($userId) {
// TODO: isn't mb_user_login_count a integer?
@@ -874,6 +877,7 @@
return $url;
function getModulPermission($userID,$guiID,$elementID){
$g = $this->getGuisByPermission($userID,true);
if(in_array($guiID,$g)){
@@ -892,6 +896,7 @@
return false;
function getLayerPermission($wms_id, $layer_name, $user_id){
$layer_id = $this->getLayerIdByLayerName($wms_id,$layer_name);
$array_guis = $this->getGuisByPermission($user_id,true);
@@ -917,6 +922,7 @@
return false;
function getWmsPermission($wms_id, $user_id) {
$v = array();
@@ -941,6 +947,7 @@
return false;
function getLayerIdByLayerName($wms_id, $layer_name){
$sql = "SELECT layer_id FROM layer WHERE ";
$sql .= "fkey_wms_id = $1 AND layer_name = $2";
@@ -954,6 +961,7 @@
return false;
function getWmsIdByWmsGetmap($getmap) {
$sql = "SELECT wms_id FROM wms WHERE ";
$sql .= "wms_getmap LIKE $1 LIMIT 1";
@@ -1019,8 +1027,8 @@
* identifies the Featureservices where the current user is owner
- * @param integer userid the user-ID of the current user
- * @return integer[] the IDs of the featureservices
+ * @param integer userid the user-ID of the current user
+ * @return integer[] the IDs of the featureservices
function getWfsByOwner($userid){
$sql = "SELECT wfs_id FROM wfs WHERE wfs_owner = $1";
@@ -1036,8 +1044,8 @@
/** identifies the Conf-FeatureServices where the current user is owner
- * @return integer[] the IDs of the wfs_conf-table
+ * @return integer[] the IDs of the wfs_conf-table
function getWfsConfByPermission($userid){
More information about the Mapbender_commits
