[Mapbender-commits] r1970 - branches/2.5/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Jan 16 06:16:19 EST 2008
Author: christoph
Date: 2008-01-16 06:16:19 -0500 (Wed, 16 Jan 2008)
New Revision: 1970
   branches/2.5/http/classes/class_wmc.php
prepared statements
documentation
Modified: branches/2.5/http/classes/class_wmc.php
--- branches/2.5/http/classes/class_wmc.php	2008-01-16 10:56:53 UTC (rev 1969)
+++ branches/2.5/http/classes/class_wmc.php	2008-01-16 11:16:19 UTC (rev 1970)
@@ -39,6 +39,10 @@
 	if($c>0)return substr($s,$c+1);
 	return $s;
+ * Implementation of a Web Map Context Document, WMC 1.1.0
 class wmc {
 	var $xml;
@@ -136,6 +140,11 @@
 function wmc() {
+ * Saves the current WMC in the log folder.
+ * @return string the filename of the WMC document.
 function saveAsFile() {
 	$filename = "wmc_" . date("Y_m_d_H_i_s") . ".log";
 	$logfile = "../../log/" . $filename;
@@ -151,14 +160,29 @@
 	return $filename;
+ * @return string the title of the WMC.
 function getTitle() {
 	return $this->wmc_title;
+ * @return Integer the number of (unique?) WMS contained in this WMC.
 function getNumberOfWms () {
 	return $this->wmc_wms_count;
+ * Creates a WMC object from a JS map object {@see map.js}
+ * @param object $mapObject a map object
+ * @param integer $user_id the ID of the current user
+ * @param string $generalTitle the desired title of the WMC
+ * @param object $extensionData data exclusive to Mapbender, which will be
+ * 								mapped into the extension part of the WMC
 function createWMCFromObj($mapObject, $user_id, $generalTitle, $extensionData) {
 	$this->wmc_id = $user_id . '_' . time();
@@ -630,19 +654,31 @@
+ * Loads a WMC from the database.
+ * @param integer $wmc_id the ID of the WMC document in the database table "mb_user_wmc"
 function createObjFromWMC_id($wmc_id){
 	global $DBSERVER,$DB,$OWNER,$PW;
 	$con = db_connect($DBSERVER,$OWNER,$PW);
 	db_select_db(DB, $con);
-	$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = '" . $wmc_id . "'";
-	$res = db_query($sql);
+	$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
+	$v = array($wmc_id);
+	$t = array("i");
+	$res = db_prep_query($sql);
 	$wmc = db_fetch_row($res);
 	$this->createObjFromWMC_xml($wmc[0]);
 	$this->monitoringIsOn = true;
+ * Loads a WMC from an actual WMC XML document.
+ * @param string $data the data from the XML file
 function createObjFromWMC_xml($data){
 #	$data = str_replace("&", "&", $data);
@@ -1022,6 +1058,16 @@
 	  //return $verbose;
+	 * Creates JS code manipulating the map and wms objects,
+	 * by this displaying the WMC
+	 * @param string $target the link to the map object, f.e. "parent." or "window.opener."
+	 * @param string $mapObj the name of the map object, f.e. "mapframe1"
+	 * @param string $action "load", "merge" or "append"
+	 * @return string the JS code
 	function createJsObjFromWMC($target, $mapObj, $action){
More information about the Mapbender_commits mailing list
