[Mapbender-commits] r2034 - branches/2.5/http/classes
svn_mapbender at osgeo.org
Tue Jan 29 07:38:26 EST 2008
Author: christoph
Date: 2008-01-29 07:38:26 -0500 (Tue, 29 Jan 2008)
New Revision: 2034
branches/2.5/http/classes/class_wmc.php
included class_point.php
Modified: branches/2.5/http/classes/class_wmc.php
--- branches/2.5/http/classes/class_wmc.php 2008-01-29 09:12:47 UTC (rev 2033)
+++ branches/2.5/http/classes/class_wmc.php 2008-01-29 12:38:26 UTC (rev 2034)
@@ -20,6 +20,7 @@
require_once(dirname(__FILE__) . "/../classes/class_wms.php");
require_once(dirname(__FILE__) . "/../classes/class_mb_exception.php");
require_once(dirname(__FILE__) . "/../classes/class_layer_monitor.php");
+require_once(dirname(__FILE__) . "/../classes/class_point.php");
require_once(dirname(__FILE__) . "/../classes/class_bbox.php");
require_once(dirname(__FILE__) . "/../extensions/JSON.php");
@@ -668,7 +669,7 @@
$sql = "SELECT wmc FROM mb_user_wmc WHERE wmc_id = $1";
$v = array($wmc_id);
$t = array("i");
- $res = db_prep_query($sql);
+ $res = db_prep_query($sql, $v, $t);
$wmc = db_fetch_row($res);
$this->createObjFromWMC_xml($wmc[0]);
$this->monitoringIsOn = true;
More information about the Mapbender_commits
