[Mapbender-commits] r2649 - trunk/mapbender/conf
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Jul 11 04:14:12 EDT 2008
Author: verenadiewald
Date: 2008-07-11 04:14:12 -0400 (Fri, 11 Jul 2008)
New Revision: 2649
Added:
   trunk/mapbender/conf/wfs_additional_spatial_search.conf
additional conf file for spatialRequest integrated in wfs gazetteer
Added: trunk/mapbender/conf/wfs_additional_spatial_search.conf
--- trunk/mapbender/conf/wfs_additional_spatial_search.conf	                        (rev 0)
+++ trunk/mapbender/conf/wfs_additional_spatial_search.conf	2008-07-11 08:14:12 UTC (rev 2649)
@@ -0,0 +1,37 @@
+ * definition of buttons for spatialRequest
+ * [@param {integer} status show this button (value is 1 or 0)
+ * [@param {string} img image for the button
+ * [@param {string} title for the button
+ * [@param {string} filteroption type of filter for search (values: "intersects" or "within"), used for buttons buttonRectangle and buttonPolygon
+var buttonRectangle = {"status":1,"img":"select_rectangle_off.png","title":"Rechteckauswahl","filteroption":"intersects"};
+var buttonPolygon = {"status":1,"img":"select_polygon_off.png","title":"Vieleckauswahl","filteroption":"intersects"};
+var buttonPoint = {"status":1, "img":"select_point_off.png","title":"Punktauswahl"};
+var buttonExtent = {"status":1,"img":"select_extent_off.png","title":"Auswahl Kartenrahmen"};
+var spatialRequestIsSetMessage = "Gebiet eingegrenzt, bitte OK klicken!";
+var clearFilterButtonLabel = "Neu";
+var buttonWfs_imgdir = "../img/button_gray/";
+var buttonWfs_zIndex = 10;
+var generalHighlightZIndex = 90;
+var generalHighlightLineWidth = 2;
+var wfsResultModulePath = "php/";
+var wfsResultModuleFilename = "mod_wfs_result.php";
+var searchPopupTitle = "Suchergebnisse";
+var searchPopupWidth = 985;
+var searchPopupHeight =300;
+var searchPopupX = 220;
+var searchPopupY = 575;
+var detailPopupTitle = "Details";
+var detailPopupWidth = 350;
+var detailPopupHeight = 200;
+var detailPopupX = 840;
+var detailPopupY = 575;
More information about the Mapbender_commits mailing list
