[Mapbender-commits] r2488 - trunk/mapbender/http/javascripts
    svn_mapbender at osgeo.org
    Mon Jun  9 10:18:22 EDT 2008
Author: christoph
Date: 2008-06-09 10:18:22 -0400 (Mon, 09 Jun 2008)
New Revision: 2488
   trunk/mapbender/http/javascripts/mod_sandclock.php
   trunk/mapbender/http/javascripts/mod_sandclock2.php
bug fix
Modified: trunk/mapbender/http/javascripts/mod_sandclock.php
--- trunk/mapbender/http/javascripts/mod_sandclock.php	2008-06-09 13:05:37 UTC (rev 2487)
+++ trunk/mapbender/http/javascripts/mod_sandclock.php	2008-06-09 14:18:22 UTC (rev 2488)
@@ -31,17 +31,27 @@
 var mod_sandclock_img = new Image();
 mod_sandclock_img.src = mod_sandclock_image;
-mb_registerSubFunctions("mod_sandclock(true,myMapId)");
+mb_registerSubFunctions("mod_sandclock(true,myMapIds)");
-function mod_sandclock(start,myMapId){
+function mod_sandclock(start,myMapIds){
 	var ind = getMapObjIndexByName(mod_sandclock_target);
 	if(start){
 		var temp = "<img src='"+mod_sandclock_img.src+"'>";
 		writeTag(mod_sandclock_target, "sandclock", temp);
 		mb_arrangeElement(mod_sandclock_target, "sandclock", (mb_mapObj[ind].width/2 - 16), (mb_mapObj[ind].height/2 - 16));
-	aktiv = setTimeout("mod_sandclock('','"+myMapId+"')",100);
-	if(window.frames[mod_sandclock_target].document.getElementById(myMapId) && window.frames[mod_sandclock_target].document.getElementById(myMapId).complete){
+	aktiv = setTimeout("mod_sandclock('','"+myMapIds+"')",10);
+	var myMapIdArray = myMapIds.split(",");
+	var complete = true;
+	var myMapId;
+	for (var i = 0; i < myMapIdArray.length && complete; i++) {
+		myMapId = myMapIdArray[i];
+		if(window.frames[mod_sandclock_target].document.getElementById(myMapId) &&
+			!window.frames[mod_sandclock_target].document.getElementById(myMapId).complete) {
+			complete = false;
+	if (complete) {
 		clearTimeout(aktiv);
 		writeTag(mod_sandclock_target, "sandclock", "");
Modified: trunk/mapbender/http/javascripts/mod_sandclock2.php
--- trunk/mapbender/http/javascripts/mod_sandclock2.php	2008-06-09 13:05:37 UTC (rev 2487)
+++ trunk/mapbender/http/javascripts/mod_sandclock2.php	2008-06-09 14:18:22 UTC (rev 2488)
@@ -29,7 +29,7 @@
+function mod_sandclock(start){
 	if(start){
 		mod_sandclock_count = mod_sandclock_maxWait;
@@ -44,7 +44,7 @@
 	// check images:
+	aktiv = setTimeout("mod_sandclock(false)",100);
 	mod_sandclock_count -= 1000;
 	var allMaps = window.frames[mod_sandclock_target].document.getElementsByName("mapimage");
More information about the Mapbender_commits
