[Mapbender-commits] r2518 -
branches/beck_dev/mapbender/http/extensions
svn_mapbender at osgeo.org
Thu Jun 19 12:46:26 EDT 2008
Author: christoph
Date: 2008-06-19 12:46:26 -0400 (Thu, 19 Jun 2008)
New Revision: 2518
Removed:
branches/beck_dev/mapbender/http/extensions/jquery.mousewheel.min.js
Deleted: branches/beck_dev/mapbender/http/extensions/jquery.mousewheel.min.js
--- branches/beck_dev/mapbender/http/extensions/jquery.mousewheel.min.js 2008-06-19 16:40:00 UTC (rev 2517)
+++ branches/beck_dev/mapbender/http/extensions/jquery.mousewheel.min.js 2008-06-19 16:46:26 UTC (rev 2518)
@@ -1,16 +0,0 @@
-/* Copyright (c) 2006 Brandon Aaron (brandon.aaron at gmail.com || http://brandonaaron.net)
- * Dual licensed under the MIT (http://www.opensource.org/licenses/mit-license.php)
- * and GPL (http://www.opensource.org/licenses/gpl-license.php) licenses.
- * Thanks to: http://adomas.org/javascript-mouse-wheel/ for some pointers.
- * Thanks to: Mathias Bank(http://www.mathias-bank.de) for a scope bug fix.
- * $LastChangedDate: 2007-12-14 23:57:10 -0600 (Fri, 14 Dec 2007) $
- * $Rev: 4163 $
- * Version: 3.0
- * Requires: $ 1.2.2+
-(function($){$.event.special.mousewheel={setup:function(){var handler=$.event.special.mousewheel.handler;if($.browser.mozilla)$(this).bind('mousemove.mousewheel',function(event){$.data(this,'mwcursorposdata',{pageX:event.pageX,pageY:event.pageY,clientX:event.clientX,clientY:event.clientY});});if(this.addEventListener)this.addEventListener(($.browser.mozilla?'DOMMouseScroll':'mousewheel'),handler,false);else
-this.onmousewheel=handler;},teardown:function(){var handler=$.event.special.mousewheel.handler;$(this).unbind('mousemove.mousewheel');if(this.removeEventListener)this.removeEventListener(($.browser.mozilla?'DOMMouseScroll':'mousewheel'),handler,false);else
-this.onmousewheel=function(){};$.removeData(this,'mwcursorposdata');},handler:function(event){var args=Array.prototype.slice.call(arguments,1);event=$.event.fix(event||window.event);$.extend(event,$.data(this,'mwcursorposdata')||{});var delta=0,returnValue=true;if(event.wheelDelta)delta=event.wheelDelta/120;if(event.detail)delta=-event.detail/3;if($.browser.opera)delta=-event.wheelDelta;event.data=event.data||{};event.type="mousewheel";args.unshift(delta);args.unshift(event);return $.event.handle.apply(this,args);}};$.fn.extend({mousewheel:function(fn){return fn?this.bind("mousewheel",fn):this.trigger("mousewheel");},unmousewheel:function(fn){return this.unbind("mousewheel",fn);}});})(jQuery);
\ No newline at end of file
More information about the Mapbender_commits
