[Mapbender-commits] r2550 - trunk/mapbender/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Jun 23 12:49:14 EDT 2008
Author: christoph
Date: 2008-06-23 12:49:13 -0400 (Mon, 23 Jun 2008)
New Revision: 2550
Removed:
   trunk/mapbender/http/javascripts/core.js
   trunk/mapbender/http/javascripts/event.js
   trunk/mapbender/http/javascripts/style.js
Deleted: trunk/mapbender/http/javascripts/core.js
--- trunk/mapbender/http/javascripts/core.js	2008-06-23 16:48:01 UTC (rev 2549)
+++ trunk/mapbender/http/javascripts/core.js	2008-06-23 16:49:13 UTC (rev 2550)
@@ -1,170 +0,0 @@
-var currentWmcExtensionData = {};
-var restoredWmcExtensionData = {};
-//var mb_MapRequestSubFunctions = [];
-//var mb_MapRequestPreFunctions = [];
-//var mb_MapObjectSubFunctions = [];
-//var mb_GetScalePreFunctions = [];
-//var mb_FeatureInfoPreFunctions = [];
-//var mb_loadWmsSubFunctions = [];
-//var mb_InitFunctions = [];
-var mb_WfsReadSubFunctions = [];
-var mb_WfsWriteSubFunctions = [];
-var mb_l10nFunctions = [];
- * Triggered after a map is requested.
-var eventAfterMapRequest = new MapbenderEvent();
- * Triggered before a map is requested.
-var eventBeforeMapRequest = new MapbenderEvent();
- * Triggered before the scale is calculated.
-var eventBeforeGetScale = new MapbenderEvent();
- * Triggered before a feature info is requested.
-var eventBeforeFeatureInfo = new MapbenderEvent();
- * Triggered after a WMS has been loaded.
-var eventAfterLoadWMS = new MapbenderEvent();
- * Triggered when Mapbender is loaded and after the map object has been initialised.
-var eventInit = new MapbenderEvent();
- * Initializes the map object. Triggered when Mapbender is loaded.
-var eventInitMap = new MapbenderEvent();
- * Switches the locale. Triggered by module switch_locale or onload(?)
-var eventLocalize = new MapbenderEvent();
- * Triggered after the map object has been created.
-var eventAfterMapObjectConstruction = new MapbenderEvent(); // possibly obsolete!
- * deprecated wrapped function
- * @deprecated
-function mb_registerInitFunctions(stringFunction){
-//	mb_InitFunctions[mb_InitFunctions.length] = stringFunction;
-	eventInit.register(stringFunction);
- * @deprecated
-function mb_registerPreFunctions(stringFunction){
-//	mb_MapRequestPreFunctions[mb_MapRequestPreFunctions.length] = stringFunction;
-	eventBeforeMapRequest.register(stringFunction);
- * @deprecated
-function mb_registerFeatureInfoPreFunctions(stringFunction){
-//	mb_FeatureInfoPreFunctions[mb_FeatureInfoPreFunctions.length] = stringFunction;
-	eventBeforeFeatureInfo.register(stringFunction);
- * @deprecated
-function mb_registerSubFunctions(stringFunction){
-//	mb_MapRequestSubFunctions[mb_MapRequestSubFunctions.length] = stringFunction;
-	eventAfterMapRequest.register(stringFunction);
- * @deprecated
-function mb_registerMapObjectSubFunctions(stringFunction){
-//	mb_MapObjectSubFunctions[mb_MapObjectSubFunctions.length] = stringFunction;
-	eventAfterMapObjectConstruction.register(stringFunction);
- * @deprecated
-function mb_registerGetScalePreFunctions(stringFunction){
-//	mb_GetScalePreFunctions[mb_GetScalePreFunctions.length] = stringFunction;
-	eventBeforeGetScale.register(stringFunction);
- * @deprecated
-function mb_registerloadWmsSubFunctions(stringFunction){
-//	mb_loadWmsSubFunctions[mb_loadWmsSubFunctions.length] = stringFunction;
-	eventAfterLoadWMS.register(stringFunction);
- * @deprecated
-function mb_registerWfsReadSubFunctions(stringFunction){
-	mb_WfsReadSubFunctions[mb_WfsReadSubFunctions.length] = stringFunction;
- * @deprecated
-function mb_registerWfsWriteSubFunctions(stringFunction){
-	mb_WfsWriteSubFunctions[mb_WfsWriteSubFunctions.length] = stringFunction;
- * @deprecated
-function mb_registerL10nFunctions(stringFunction) {
-	eventLocalize.register(stringFunction)
-//	mb_l10nFunctions[mb_l10nFunctions.length] = stringFunction;
-var mb_PanSubElements = [];
-function mb_registerPanSubElement(elName){
-	var ind = mb_PanSubElements.length;
-	mb_PanSubElements[ind] = elName;
-var mb_vendorSpecific = [];
-function mb_registerVendorSpecific(stringFunction){
-	mb_vendorSpecific[mb_vendorSpecific.length] = stringFunction;
- * deprecated function for writing content within a tag via innerHTML
- * @deprecated
-function writeTag(frameName, elName, tagSource) {
-  if(frameName && frameName !== ""){
-     window.frames[frameName].document.getElementById(elName).innerHTML = tagSource;
-  else if(!frameName || frameName === ""){
-       document.getElementById(elName).innerHTML = tagSource;
\ No newline at end of file
Deleted: trunk/mapbender/http/javascripts/event.js
--- trunk/mapbender/http/javascripts/event.js	2008-06-23 16:48:01 UTC (rev 2549)
+++ trunk/mapbender/http/javascripts/event.js	2008-06-23 16:49:13 UTC (rev 2550)
@@ -1,193 +0,0 @@
- * An event. What happens, when the event occurs, depends on which functions have been
- * registered with the event.
- * usage:
- * // create a new Event
- * var eventAfterMapRequest = new MapbenderEvent();
- * // register a function with that event
- * eventAfterMapRequest.register(function () {
- * // trigger the event
- * eventAfterMapRequest.trigger();
-var MapbenderEvent = function () {
-	// public methods
-	 * A function that needs to be executed, when the event occurs, has to be
-	 * registered via this function.
-	this.register = function(aFunction) {
-		var mpbnFunction = new MapbenderFunction(aFunction);
-		functionArray.push(mpbnFunction);
-	 * Exclude a previously registered function from the event
-	this.unregister = function(aFunction) {
-		for (var i = 0, len = functionArray.length; i < len; i++) {
-			if (functionArray[i].getFunction() === aFunction) {
-				for (var j = i + 1; j < len; j++) {
-					functionArray[j-1] = functionArray[j];
-				delete functionArray[len - 1];
-				len = len - 1;
-		functionArray.length = len;
-	 * Checks if a function is already registered with this event
-	this.isRegistered = function (aFunction) {
-				return true;
-		return false;
-	 * This function triggers the event
-	this.trigger = function(properties, booleanOperator) {
-		if (!(functionArray.length > 0)) {
-			return true;
-		// check arguments
-		// properties
-		if (typeof(properties) != "object") {
-			// maybe properties is missing, and so
-			// properties represents booleanOperator
-			if (typeof(booleanOperator) == "undefined") {
-				booleanOperator = properties;
-				properties = undefined;
-			else {
-//				var e = new Mb_exception("MapbenderEvent.trigger: invalid properties: %s", properties);
-		// booleanOperator
-		if (typeof(booleanOperator) == "string") {
-			if (booleanOperator != "AND" && booleanOperator != "OR") {
-//				var e = new Mb_exception("MapbenderEvent.trigger: invalid booleanOperator: %s", booleanOperator);
-		else if (typeof(booleanOperator) != "undefined") {
-//			var e = new Mb_exception("MapbenderEvent.trigger: invalid booleanOperator, must be a string, but is %s", typeof(booleanOperator));
-		var result;
-		// the optional boolean operator allows to combine the return values of the functions
-		// into a single result value.
-		switch (booleanOperator) {
-			case "AND":
-				result = true;
-				break;
-			case "OR":
-				result = false;
-				break;
-			default:
-				result = true;
-				break;
-		if (log) {
-			var e = new Mb_notice("functions (after sort): " + functionArray.join(","));
-		for (var i = 0; i < functionArray.length; i++) {
-			// executes the function at position i
-			// and determines the return value based on the (optional) boolean operator
-				case "AND":
-					result = result && functionArray[i].execute(properties);
-					break;
-				case "OR":
-					result = result || functionArray[i].execute(properties);
-					break;
-				default:
-					result = functionArray[i].execute(properties);
-					break;
-		return result;
-	this.getProperties = function () {
-		return propertiesObj;
-	// private
-	 * these functions will be executed once the event is triggered
-	var functionArray = [];
-	var propertiesObj;
-	var log = false;
- * A MapbenderFunction is a function with a priority.
-var MapbenderFunction = function (aFunction) {
-	// public
-	 * Returns the function itself
-	this.getFunction = function () {
-		return func;
-	 * Executes the function
-	this.execute = function (argumentObj) {
-		if (typeof(aFunction) == "function") {
-			return func(argumentObj);
-		// this branch is for backwards compatibility with the
-		// pre-2.5 event system that is based on strings.
-		else {
-			var argumentNames = [];
-			var argumentValues = [];
-			for (var i in argumentObj) {
-				if (typeof(argumentObj[i]) == "number" || typeof(argumentObj[i]) == "boolean") {
-					argumentNames.push(i);
-					argumentValues.push(argumentObj[i]);
-				else if (typeof(argumentObj[i]) == "string") {
-					argumentValues.push("'" + argumentObj[i] + "'");
-			var str = "";
-			str += "(function (" + argumentNames.join(", ") + ") {";
-			str += "return " + aFunction;
-			str += "}";
-			str += "(" + argumentValues.join(", ") + "));";
-			var returnValue = eval(str);
-			return returnValue;
-	// private
-	var func = aFunction;
Deleted: trunk/mapbender/http/javascripts/style.js
--- trunk/mapbender/http/javascripts/style.js	2008-06-23 16:48:01 UTC (rev 2549)
+++ trunk/mapbender/http/javascripts/style.js	2008-06-23 16:49:13 UTC (rev 2550)
@@ -1,54 +0,0 @@
- * creates a style tag in the head of the document.
-var StyleTag = function() {
-	 * Creates the style tag in the head of the document. Something like a constructor.
-	var createStyleTag = function() {
-		// TODO: Internet Explorer routine seems a little buggy
-		if (top.ie) {
-			// create a Style Sheet object (IE only)
-			//styleSheetObj=document.createStyleSheet();
-			// get the DOM node of the style sheet object, set the type
-			//styleObj=styleSheetObj.owningElement || styleSheetObj.ownerNode;
-			//styleObj.setAttribute("type","text/css");
-			// alternative way for IE: take existing styleSheet with index 0 instead of creating a new one
-			styleSheetObj=document.styleSheets[0];
-		else {
-			// create the style node, set the style
-			styleObj=document.createElement("style");
-			styleObj.setAttribute("type","text/css");
-			// append the node to the head
-			document.getElementsByTagName("head")[0].appendChild(styleObj);
-	 * Adds a class className with the CSS in cssString
-	this.addClass = function(className,cssString) {
-		if (top.ie) {
-			//add new style declaration to chosen styleSheet
-			var cssRules = cssString.split(";");
-			for (i=0; i<cssRules.length-1; i++){
-				styleSheetObj.addRule("."+className,cssRules[i]);
-		else {
-			// insert the content via createTextNode
-			styleObj.appendChild(document.createTextNode("."+className+"{\n\t"+cssString+"\n}\n"));
-	var styleObj;
-	var styleSheetObj; //IE only...
-	createStyleTag();
More information about the Mapbender_commits mailing list
