[Mapbender-commits] r2156 - branches/2.5/http/extensions
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Mar 3 03:51:02 EST 2008
Author: christoph
Date: 2008-03-03 03:51:02 -0500 (Mon, 03 Mar 2008)
New Revision: 2156
   branches/2.5/http/extensions/jquery.js
latest version
Modified: branches/2.5/http/extensions/jquery.js
--- branches/2.5/http/extensions/jquery.js	2008-02-29 14:12:03 UTC (rev 2155)
+++ branches/2.5/http/extensions/jquery.js	2008-03-03 08:51:02 UTC (rev 2156)
@@ -1,2245 +1,11 @@
-/* prevent execution of jQuery if included more than once */
-if(typeof window.jQuery == "undefined") {
- * jQuery 1.1.2 - New Wave Javascript
+ * jQuery 1.2.1 - New Wave Javascript
  * Copyright (c) 2007 John Resig (jquery.com)
  * Dual licensed under the MIT (MIT-LICENSE.txt)
  * and GPL (GPL-LICENSE.txt) licenses.
- * $Date: 2007-02-28 12:03:00 -0500 (Wed, 28 Feb 2007) $
- * $Rev: 1465 $
+ * $Date: 2007-09-16 23:42:06 -0400 (Sun, 16 Sep 2007) $
+ * $Rev: 3353 $
-// Global undefined variable
-window.undefined = window.undefined;
-var jQuery = function(a,c) {
-	// If the context is global, return a new object
-	if ( window == this )
-		return new jQuery(a,c);
-	// Make sure that a selection was provided
-	a = a || document;
-	// HANDLE: $(function)
-	// Shortcut for document ready
-	if ( jQuery.isFunction(a) )
-		return new jQuery(document)[ jQuery.fn.ready ? "ready" : "load" ]( a );
-	// Handle HTML strings
-	if ( typeof a  == "string" ) {
-		// HANDLE: $(html) -> $(array)
-		var m = /^[^<]*(<(.|\s)+>)[^>]*$/.exec(a);
-		if ( m )
-			a = jQuery.clean( [ m[1] ] );
-		// HANDLE: $(expr)
-		else
-			return new jQuery( c ).find( a );
-	return this.setArray(
-		// HANDLE: $(array)
-		a.constructor == Array && a ||
-		// HANDLE: $(arraylike)
-		// Watch for when an array-like object is passed as the selector
-		(a.jquery || a.length && a != window && !a.nodeType && a[0] != undefined && a[0].nodeType) && jQuery.makeArray( a ) ||
-		// HANDLE: $(*)
-		[ a ] );
-// Map over the $ in case of overwrite
-if ( typeof $ != "undefined" )
-	jQuery._$ = $;
-// Map the jQuery namespace to the '$' one
-var $ = jQuery;
-jQuery.fn = jQuery.prototype = {
-	jquery: "1.1.2",
-	size: function() {
-		return this.length;
-	length: 0,
-	get: function( num ) {
-		return num == undefined ?
-			// Return a 'clean' array
-			jQuery.makeArray( this ) :
-			// Return just the object
-			this[num];
-	pushStack: function( a ) {
-		var ret = jQuery(a);
-		ret.prevObject = this;
-		return ret;
-	setArray: function( a ) {
-		this.length = 0;
-		[].push.apply( this, a );
-		return this;
-	each: function( fn, args ) {
-		return jQuery.each( this, fn, args );
-	index: function( obj ) {
-		var pos = -1;
-		this.each(function(i){
-			if ( this == obj ) pos = i;
-		return pos;
-	attr: function( key, value, type ) {
-		var obj = key;
-		// Look for the case where we're accessing a style value
-		if ( key.constructor == String )
-			if ( value == undefined )
-				return this.length && jQuery[ type || "attr" ]( this[0], key ) || undefined;
-			else {
-				obj = {};
-				obj[ key ] = value;
-		// Check to see if we're setting style values
-		return this.each(function(index){
-			// Set all the styles
-			for ( var prop in obj )
-				jQuery.attr(
-					type ? this.style : this,
-					prop, jQuery.prop(this, obj[prop], type, index, prop)
-	css: function( key, value ) {
-		return this.attr( key, value, "curCSS" );
-	text: function(e) {
-		if ( typeof e == "string" )
-			return this.empty().append( document.createTextNode( e ) );
-		var t = "";
-		jQuery.each( e || this, function(){
-			jQuery.each( this.childNodes, function(){
-				if ( this.nodeType != 8 )
-					t += this.nodeType != 1 ?
-						this.nodeValue : jQuery.fn.text([ this ]);
-		return t;
-	wrap: function() {
-		// The elements to wrap the target around
-		var a = jQuery.clean(arguments);
-		// Wrap each of the matched elements individually
-		return this.each(function(){
-			// Clone the structure that we're using to wrap
-			var b = a[0].cloneNode(true);
-			// Insert it before the element to be wrapped
-			this.parentNode.insertBefore( b, this );
-			// Find the deepest point in the wrap structure
-			while ( b.firstChild )
-				b = b.firstChild;
-			// Move the matched element to within the wrap structure
-			b.appendChild( this );
-	append: function() {
-		return this.domManip(arguments, true, 1, function(a){
-			this.appendChild( a );
-	prepend: function() {
-		return this.domManip(arguments, true, -1, function(a){
-			this.insertBefore( a, this.firstChild );
-	before: function() {
-		return this.domManip(arguments, false, 1, function(a){
-			this.parentNode.insertBefore( a, this );
-	after: function() {
-		return this.domManip(arguments, false, -1, function(a){
-			this.parentNode.insertBefore( a, this.nextSibling );
-	end: function() {
-		return this.prevObject || jQuery([]);
-	find: function(t) {
-		return this.pushStack( jQuery.map( this, function(a){
-			return jQuery.find(t,a);
-		}), t );
-	clone: function(deep) {
-			var a = a.cloneNode( deep != undefined ? deep : true );
-			a.$events = null; // drop $events expando to avoid firing incorrect events
-			return a;
-	filter: function(t) {
-			jQuery.isFunction( t ) &&
-			jQuery.grep(this, function(el, index){
-				return t.apply(el, [index])
-			jQuery.multiFilter(t,this) );
-	not: function(t) {
-			t.constructor == String &&
-			jQuery.multiFilter(t, this, true) ||
-			jQuery.grep(this, function(a) {
-				return ( t.constructor == Array || t.jquery )
-					? jQuery.inArray( a, t ) < 0
-					: a != t;
-	add: function(t) {
-		return this.pushStack( jQuery.merge(
-			this.get(),
-			t.constructor == String ?
-				jQuery(t).get() :
-				t.length != undefined && (!t.nodeName || t.nodeName == "FORM") ?
-					t : [t] )
-	is: function(expr) {
-		return expr ? jQuery.filter(expr,this).r.length > 0 : false;
-	val: function( val ) {
-		return val == undefined ?
-			( this.length ? this[0].value : null ) :
-			this.attr( "value", val );
-	html: function( val ) {
-			( this.length ? this[0].innerHTML : null ) :
-			this.empty().append( val );
-	domManip: function(args, table, dir, fn){
-		var clone = this.length > 1;
-		var a = jQuery.clean(args);
-		if ( dir < 0 )
-			a.reverse();
-			var obj = this;
-			if ( table && jQuery.nodeName(this, "table") && jQuery.nodeName(a[0], "tr") )
-				obj = this.getElementsByTagName("tbody")[0] || this.appendChild(document.createElement("tbody"));
-			jQuery.each( a, function(){
-				fn.apply( obj, [ clone ? this.cloneNode(true) : this ] );
-jQuery.extend = jQuery.fn.extend = function() {
-	// copy reference to target object
-	var target = arguments[0],
-		a = 1;
-	// extend jQuery itself if only one argument is passed
-	if ( arguments.length == 1 ) {
-		target = this;
-		a = 0;
-	var prop;
-	while (prop = arguments[a++])
-		// Extend the base object
-		for ( var i in prop ) target[i] = prop[i];
-	// Return the modified object
-	return target;
-jQuery.extend({
-	noConflict: function() {
-		if ( jQuery._$ )
-			$ = jQuery._$;
-		return jQuery;
-	// This may seem like some crazy code, but trust me when I say that this
-	// is the only cross-browser way to do this. --John
-	isFunction: function( fn ) {
-		return !!fn && typeof fn != "string" && !fn.nodeName &&
-			typeof fn[0] == "undefined" && /function/i.test( fn + "" );
-	// check if an element is in a XML document
-	isXMLDoc: function(elem) {
-		return elem.tagName && elem.ownerDocument && !elem.ownerDocument.body;
-	nodeName: function( elem, name ) {
-		return elem.nodeName && elem.nodeName.toUpperCase() == name.toUpperCase();
-	// args is for internal usage only
-	each: function( obj, fn, args ) {
-		if ( obj.length == undefined )
-			for ( var i in obj )
-				fn.apply( obj[i], args || [i, obj[i]] );
-		else
-			for ( var i = 0, ol = obj.length; i < ol; i++ )
-				if ( fn.apply( obj[i], args || [i, obj[i]] ) === false ) break;
-		return obj;
-	prop: function(elem, value, type, index, prop){
-			// Handle executable functions
-			if ( jQuery.isFunction( value ) )
-				value = value.call( elem, [index] );
-			// exclude the following css properties to add px
-			var exclude = /z-?index|font-?weight|opacity|zoom|line-?height/i;
-			// Handle passing in a number to a CSS property
-			return value && value.constructor == Number && type == "curCSS" && !exclude.test(prop) ?
-				value + "px" :
-				value;
-	className: {
-		// internal only, use addClass("class")
-		add: function( elem, c ){
-			jQuery.each( c.split(/\s+/), function(i, cur){
-				if ( !jQuery.className.has( elem.className, cur ) )
-					elem.className += ( elem.className ? " " : "" ) + cur;
-		// internal only, use removeClass("class")
-		remove: function( elem, c ){
-			elem.className = c ?
-				jQuery.grep( elem.className.split(/\s+/), function(cur){
-					return !jQuery.className.has( c, cur );
-				}).join(" ") : "";
-		// internal only, use is(".class")
-		has: function( t, c ) {
-			t = t.className || t;
-			// escape regex characters
-			c = c.replace(/([\.\\\+\*\?\[\^\]\$\(\)\{\}\=\!\<\>\|\:])/g, "\\$1");
-			return t && new RegExp("(^|\\s)" + c + "(\\s|$)").test( t );
-	swap: function(e,o,f) {
-		for ( var i in o ) {
-			e.style["old"+i] = e.style[i];
-			e.style[i] = o[i];
-		f.apply( e, [] );
-			e.style[i] = e.style["old"+i];
-	css: function(e,p) {
-		if ( p == "height" || p == "width" ) {
-			var old = {}, oHeight, oWidth, d = ["Top","Bottom","Right","Left"];
-			jQuery.each( d, function(){
-				old["padding" + this] = 0;
-				old["border" + this + "Width"] = 0;
-			jQuery.swap( e, old, function() {
-				if (jQuery.css(e,"display") != "none") {
-					oHeight = e.offsetHeight;
-					oWidth = e.offsetWidth;
-				} else {
-					e = jQuery(e.cloneNode(true))
-						.find(":radio").removeAttr("checked").end()
-						.css({
-							visibility: "hidden", position: "absolute", display: "block", right: "0", left: "0"
-						}).appendTo(e.parentNode)[0];
-					var parPos = jQuery.css(e.parentNode,"position");
-					if ( parPos == "" || parPos == "static" )
-						e.parentNode.style.position = "relative";
-					oHeight = e.clientHeight;
-					oWidth = e.clientWidth;
-						e.parentNode.style.position = "static";
-					e.parentNode.removeChild(e);
-			return p == "height" ? oHeight : oWidth;
-		return jQuery.curCSS( e, p );
-	curCSS: function(elem, prop, force) {
-		var ret;
-		if (prop == "opacity" && jQuery.browser.msie)
-			return jQuery.attr(elem.style, "opacity");
-		if (prop == "float" || prop == "cssFloat")
-		    prop = jQuery.browser.msie ? "styleFloat" : "cssFloat";
-		if (!force && elem.style[prop])
-			ret = elem.style[prop];
-		else if (document.defaultView && document.defaultView.getComputedStyle) {
-			if (prop == "cssFloat" || prop == "styleFloat")
-				prop = "float";
-			prop = prop.replace(/([A-Z])/g,"-$1").toLowerCase();
-			var cur = document.defaultView.getComputedStyle(elem, null);
-			if ( cur )
-				ret = cur.getPropertyValue(prop);
-			else if ( prop == "display" )
-				ret = "none";
-			else
-				jQuery.swap(elem, { display: "block" }, function() {
-				    var c = document.defaultView.getComputedStyle(this, "");
-				    ret = c && c.getPropertyValue(prop) || "";
-		} else if (elem.currentStyle) {
-			var newProp = prop.replace(/\-(\w)/g,function(m,c){return c.toUpperCase();});
-			ret = elem.currentStyle[prop] || elem.currentStyle[newProp];
-		return ret;
-	clean: function(a) {
-		var r = [];
-		jQuery.each( a, function(i,arg){
-			if ( !arg ) return;
-			if ( arg.constructor == Number )
-				arg = arg.toString();
-			 // Convert html string into DOM nodes
-			if ( typeof arg == "string" ) {
-				// Trim whitespace, otherwise indexOf won't work as expected
-				var s = jQuery.trim(arg), div = document.createElement("div"), tb = [];
-				var wrap =
-					 // option or optgroup
-					!s.indexOf("<opt") &&
-					[1, "<select>", "</select>"] ||
-					(!s.indexOf("<thead") || !s.indexOf("<tbody") || !s.indexOf("<tfoot")) &&
-					[1, "<table>", "</table>"] ||
-					!s.indexOf("<tr") &&
-					[2, "<table><tbody>", "</tbody></table>"] ||
-				 	// <thead> matched above
-					(!s.indexOf("<td") || !s.indexOf("<th")) &&
-					[3, "<table><tbody><tr>", "</tr></tbody></table>"] ||
-					[0,"",""];
-				// Go to html and back, then peel off extra wrappers
-				div.innerHTML = wrap[1] + s + wrap[2];
-				// Move to the right depth
-				while ( wrap[0]-- )
-					div = div.firstChild;
-				// Remove IE's autoinserted <tbody> from table fragments
-				if ( jQuery.browser.msie ) {
-					// String was a <table>, *may* have spurious <tbody>
-					if ( !s.indexOf("<table") && s.indexOf("<tbody") < 0 )
-						tb = div.firstChild && div.firstChild.childNodes;
-					// String was a bare <thead> or <tfoot>
-					else if ( wrap[1] == "<table>" && s.indexOf("<tbody") < 0 )
-						tb = div.childNodes;
-					for ( var n = tb.length-1; n >= 0 ; --n )
-						if ( jQuery.nodeName(tb[n], "tbody") && !tb[n].childNodes.length )
-							tb[n].parentNode.removeChild(tb[n]);
-				arg = [];
-				for (var i=0, l=div.childNodes.length; i<l; i++)
-					arg.push(div.childNodes[i]);
-			if ( arg.length === 0 && !jQuery.nodeName(arg, "form") )
-				return;
-			if ( arg[0] == undefined || jQuery.nodeName(arg, "form") )
-				r.push( arg );
-			else
-				r = jQuery.merge( r, arg );
-		return r;
-	attr: function(elem, name, value){
-		var fix = jQuery.isXMLDoc(elem) ? {} : {
-			"for": "htmlFor",
-			"class": "className",
-			"float": jQuery.browser.msie ? "styleFloat" : "cssFloat",
-			cssFloat: jQuery.browser.msie ? "styleFloat" : "cssFloat",
-			innerHTML: "innerHTML",
-			className: "className",
-			value: "value",
-			disabled: "disabled",
-			checked: "checked",
-			readonly: "readOnly",
-			selected: "selected"
-		// IE actually uses filters for opacity ... elem is actually elem.style
-		if ( name == "opacity" && jQuery.browser.msie && value != undefined ) {
-			// IE has trouble with opacity if it does not have layout
-			// Force it by setting the zoom level
-			elem.zoom = 1;
-			// Set the alpha filter to set the opacity
-			return elem.filter = elem.filter.replace(/alpha\([^\)]*\)/gi,"") +
-				( value == 1 ? "" : "alpha(opacity=" + value * 100 + ")" );
-		} else if ( name == "opacity" && jQuery.browser.msie )
-			return elem.filter ?
-				parseFloat( elem.filter.match(/alpha\(opacity=(.*)\)/)[1] ) / 100 : 1;
-		// Mozilla doesn't play well with opacity 1
-		if ( name == "opacity" && jQuery.browser.mozilla && value == 1 )
-			value = 0.9999;
-		// Certain attributes only work when accessed via the old DOM 0 way
-		if ( fix[name] ) {
-			if ( value != undefined ) elem[fix[name]] = value;
-			return elem[fix[name]];
-		} else if ( value == undefined && jQuery.browser.msie && jQuery.nodeName(elem, "form") && (name == "action" || name == "method") )
-			return elem.getAttributeNode(name).nodeValue;
-		// IE elem.getAttribute passes even for style
-		else if ( elem.tagName ) {
-			if ( value != undefined ) elem.setAttribute( name, value );
-			if ( jQuery.browser.msie && /href|src/.test(name) && !jQuery.isXMLDoc(elem) )
-				return elem.getAttribute( name, 2 );
-			return elem.getAttribute( name );
-		// elem is actually elem.style ... set the style
-		} else {
-			name = name.replace(/-([a-z])/ig,function(z,b){return b.toUpperCase();});
-			if ( value != undefined ) elem[name] = value;
-			return elem[name];
-	trim: function(t){
-		return t.replace(/^\s+|\s+$/g, "");
-	makeArray: function( a ) {
-		var r = [];
-		if ( a.constructor != Array )
-			for ( var i = 0, al = a.length; i < al; i++ )
-				r.push( a[i] );
-		else
-			r = a.slice( 0 );
-		return r;
-	inArray: function( b, a ) {
-			if ( a[i] == b )
-				return i;
-		return -1;
-	merge: function(first, second) {
-		var r = [].slice.call( first, 0 );
-		// Now check for duplicates between the two arrays
-		// and only add the unique items
-		for ( var i = 0, sl = second.length; i < sl; i++ )
-			// Check for duplicates
-			if ( jQuery.inArray( second[i], r ) == -1 )
-				// The item is unique, add it
-				first.push( second[i] );
-		return first;
-	grep: function(elems, fn, inv) {
-		// If a string is passed in for the function, make a function
-		// for it (a handy shortcut)
-		if ( typeof fn == "string" )
-			fn = new Function("a","i","return " + fn);
-		var result = [];
-		// Go through the array, only saving the items
-		// that pass the validator function
-		for ( var i = 0, el = elems.length; i < el; i++ )
-			if ( !inv && fn(elems[i],i) || inv && !fn(elems[i],i) )
-				result.push( elems[i] );
-		return result;
-	map: function(elems, fn) {
-			fn = new Function("a","return " + fn);
-		var result = [], r = [];
-		// Go through the array, translating each of the items to their
-		// new value (or values).
-		for ( var i = 0, el = elems.length; i < el; i++ ) {
-			var val = fn(elems[i],i);
-			if ( val !== null && val != undefined ) {
-				if ( val.constructor != Array ) val = [val];
-				result = result.concat( val );
-		var r = result.length ? [ result[0] ] : [];
-		check: for ( var i = 1, rl = result.length; i < rl; i++ ) {
-			for ( var j = 0; j < i; j++ )
-				if ( result[i] == r[j] )
-					continue check;
-			r.push( result[i] );
-		return r;
- * Whether the W3C compliant box model is being used.
- * @property
- * @name $.boxModel
- * @type Boolean
- * @cat JavaScript
-new function() {
-	var b = navigator.userAgent.toLowerCase();
-	// Figure out what browser is being used
-	jQuery.browser = {
-		safari: /webkit/.test(b),
-		opera: /opera/.test(b),
-		msie: /msie/.test(b) && !/opera/.test(b),
-		mozilla: /mozilla/.test(b) && !/(compatible|webkit)/.test(b)
-	// Check to see if the W3C box model is being used
-	jQuery.boxModel = !jQuery.browser.msie || document.compatMode == "CSS1Compat";
-jQuery.each({
-	parent: "a.parentNode",
-	parents: "jQuery.parents(a)",
-	next: "jQuery.nth(a,2,'nextSibling')",
-	prev: "jQuery.nth(a,2,'previousSibling')",
-	siblings: "jQuery.sibling(a.parentNode.firstChild,a)",
-	children: "jQuery.sibling(a.firstChild)"
-}, function(i,n){
-	jQuery.fn[ i ] = function(a) {
-		var ret = jQuery.map(this,n);
-		if ( a && typeof a == "string" )
-			ret = jQuery.multiFilter(a,ret);
-		return this.pushStack( ret );
-jQuery.each({
-	appendTo: "append",
-	prependTo: "prepend",
-	insertBefore: "before",
-	insertAfter: "after"
-}, function(i,n){
-	jQuery.fn[ i ] = function(){
-		var a = arguments;
-			for ( var j = 0, al = a.length; j < al; j++ )
-				jQuery(a[j])[n]( this );
-jQuery.each( {
-	removeAttr: function( key ) {
-		jQuery.attr( this, key, "" );
-		this.removeAttribute( key );
-	addClass: function(c){
-		jQuery.className.add(this,c);
-	removeClass: function(c){
-		jQuery.className.remove(this,c);
-	toggleClass: function( c ){
-		jQuery.className[ jQuery.className.has(this,c) ? "remove" : "add" ](this, c);
-	remove: function(a){
-		if ( !a || jQuery.filter( a, [this] ).r.length )
-			this.parentNode.removeChild( this );
-	empty: function() {
-		while ( this.firstChild )
-			this.removeChild( this.firstChild );
-}, function(i,n){
-	jQuery.fn[ i ] = function() {
-		return this.each( n, arguments );
-jQuery.each( [ "eq", "lt", "gt", "contains" ], function(i,n){
-	jQuery.fn[ n ] = function(num,fn) {
-		return this.filter( ":" + n + "(" + num + ")", fn );
-jQuery.each( [ "height", "width" ], function(i,n){
-	jQuery.fn[ n ] = function(h) {
-		return h == undefined ?
-			( this.length ? jQuery.css( this[0], n ) : null ) :
-			this.css( n, h.constructor == String ? h : h + "px" );
-jQuery.extend({
-	expr: {
-		"": "m[2]=='*'||jQuery.nodeName(a,m[2])",
-		"#": "a.getAttribute('id')==m[2]",
-			// Position Checks
-			lt: "i<m[3]-0",
-			gt: "i>m[3]-0",
-			nth: "m[3]-0==i",
-			eq: "m[3]-0==i",
-			first: "i==0",
-			last: "i==r.length-1",
-			even: "i%2==0",
-			odd: "i%2",
-			// Child Checks
-			"nth-child": "jQuery.nth(a.parentNode.firstChild,m[3],'nextSibling',a)==a",
-			"first-child": "jQuery.nth(a.parentNode.firstChild,1,'nextSibling')==a",
-			"last-child": "jQuery.nth(a.parentNode.lastChild,1,'previousSibling')==a",
-			"only-child": "jQuery.sibling(a.parentNode.firstChild).length==1",
-			// Parent Checks
-			parent: "a.firstChild",
-			empty: "!a.firstChild",
-			// Text Check
-			contains: "jQuery.fn.text.apply([a]).indexOf(m[3])>=0",
-			// Visibility
-			visible: 'a.type!="hidden"&&jQuery.css(a,"display")!="none"&&jQuery.css(a,"visibility")!="hidden"',
-			hidden: 'a.type=="hidden"||jQuery.css(a,"display")=="none"||jQuery.css(a,"visibility")=="hidden"',
-			// Form attributes
-			enabled: "!a.disabled",
-			disabled: "a.disabled",
-			checked: "a.checked",
-			selected: "a.selected||jQuery.attr(a,'selected')",
-			// Form elements
-			text: "a.type=='text'",
-			radio: "a.type=='radio'",
-			checkbox: "a.type=='checkbox'",
-			file: "a.type=='file'",
-			password: "a.type=='password'",
-			submit: "a.type=='submit'",
-			image: "a.type=='image'",
-			reset: "a.type=='reset'",
-			button: 'a.type=="button"||jQuery.nodeName(a,"button")',
-			input: "/input|select|textarea|button/i.test(a.nodeName)"
-		".": "jQuery.className.has(a,m[2])",
-			"=": "z==m[4]",
-			"!=": "z!=m[4]",
-			"^=": "z&&!z.indexOf(m[4])",
-			"$=": "z&&z.substr(z.length - m[4].length,m[4].length)==m[4]",
-			"*=": "z&&z.indexOf(m[4])>=0",
-			"": "z",
-			_resort: function(m){
-				return ["", m[1], m[3], m[2], m[5]];
-			_prefix: "z=a[m[3]];if(!z||/href|src/.test(m[3]))z=jQuery.attr(a,m[3]);"
-		"[": "jQuery.find(m[2],a).length"
-	// The regular expressions that power the parsing engine
-	parse: [
-		// Match: [@value='test'], [@foo]
-		/^\[ *(@)([a-z0-9_-]*) *([!*$^=]*) *('?"?)(.*?)\4 *\]/i,
-		// Match: [div], [div p]
-		/^(\[)\s*(.*?(\[.*?\])?[^[]*?)\s*\]/,
-		// Match: :contains('foo')
-		/^(:)([a-z0-9_-]*)\("?'?(.*?(\(.*?\))?[^(]*?)"?'?\)/i,
-		// Match: :even, :last-chlid
-		/^([:.#]*)([a-z0-9_*-]*)/i
-	token: [
-		/^(\/?\.\.)/, "a.parentNode",
-		/^(>|\/)/, "jQuery.sibling(a.firstChild)",
-		/^(\+)/, "jQuery.nth(a,2,'nextSibling')",
-		/^(~)/, function(a){
-			var s = jQuery.sibling(a.parentNode.firstChild);
-			return s.slice(jQuery.inArray(a,s) + 1);
-	multiFilter: function( expr, elems, not ) {
-		var old, cur = [];
-		while ( expr && expr != old ) {
-			old = expr;
-			var f = jQuery.filter( expr, elems, not );
-			expr = f.t.replace(/^\s*,\s*/, "" );
-			cur = not ? elems = f.r : jQuery.merge( cur, f.r );
-		return cur;
-	find: function( t, context ) {
-		// Quickly handle non-string expressions
-		if ( typeof t != "string" )
-			return [ t ];
-		// Make sure that the context is a DOM Element
-		if ( context && !context.nodeType )
-			context = null;
-		// Set the correct context (if none is provided)
-		context = context || document;
-		// Handle the common XPath // expression
-		if ( !t.indexOf("//") ) {
-			context = context.documentElement;
-			t = t.substr(2,t.length);
-		// And the / root expression
-		} else if ( !t.indexOf("/") ) {
-			t = t.substr(1,t.length);
-			if ( t.indexOf("/") >= 1 )
-				t = t.substr(t.indexOf("/"),t.length);
-		// Initialize the search
-		var ret = [context], done = [], last = null;
-		// Continue while a selector expression exists, and while
-		// we're no longer looping upon ourselves
-		while ( t && last != t ) {
-			var r = [];
-			last = t;
-			t = jQuery.trim(t).replace( /^\/\//i, "" );
-			var foundToken = false;
-			// An attempt at speeding up child selectors that
-			// point to a specific element tag
-			var re = /^[\/>]\s*([a-z0-9*-]+)/i;
-			var m = re.exec(t);
-			if ( m ) {
-				// Perform our own iteration and filter
-				jQuery.each( ret, function(){
-					for ( var c = this.firstChild; c; c = c.nextSibling )
-						if ( c.nodeType == 1 && ( jQuery.nodeName(c, m[1]) || m[1] == "*" ) )
-							r.push( c );
-				ret = r;
-				t = t.replace( re, "" );
-				if ( t.indexOf(" ") == 0 ) continue;
-				foundToken = true;
-			} else {
-				// Look for pre-defined expression tokens
-				for ( var i = 0; i < jQuery.token.length; i += 2 ) {
-					// Attempt to match each, individual, token in
-					// the specified order
-					var re = jQuery.token[i];
-					// If the token match was found
-					if ( m ) {
-						// Map it against the token's handler
-						r = ret = jQuery.map( ret, jQuery.isFunction( jQuery.token[i+1] ) ?
-							jQuery.token[i+1] :
-							function(a){ return eval(jQuery.token[i+1]); });
-						// And remove the token
-						t = jQuery.trim( t.replace( re, "" ) );
-						break;
-			// See if there's still an expression, and that we haven't already
-			// matched a token
-			if ( t && !foundToken ) {
-				// Handle multiple expressions
-				if ( !t.indexOf(",") ) {
-					// Clean the result set
-					if ( ret[0] == context ) ret.shift();
-					// Merge the result sets
-					jQuery.merge( done, ret );
-					// Reset the context
-					r = ret = [context];
-					// Touch up the selector string
-					t = " " + t.substr(1,t.length);
-				} else {
-					// Optomize for the case nodeName#idName
-					var re2 = /^([a-z0-9_-]+)(#)([a-z0-9\\*_-]*)/i;
-					var m = re2.exec(t);
-					// Re-organize the results, so that they're consistent
-					if ( m ) {
-					   m = [ 0, m[2], m[3], m[1] ];
-					} else {
-						// Otherwise, do a traditional filter check for
-						// ID, class, and element selectors
-						re2 = /^([#.]?)([a-z0-9\\*_-]*)/i;
-						m = re2.exec(t);
-					// Try to do a global search by ID, where we can
-					if ( m[1] == "#" && ret[ret.length-1].getElementById ) {
-						// Optimization for HTML document case
-						var oid = ret[ret.length-1].getElementById(m[2]);
-						// Do a quick check for the existence of the actual ID attribute
-						// to avoid selecting by the name attribute in IE
-						if ( jQuery.browser.msie && oid && oid.id != m[2] )
-							oid = jQuery('[@id="'+m[2]+'"]', ret[ret.length-1])[0];
-						// Do a quick check for node name (where applicable) so
-						// that div#foo searches will be really fast
-						ret = r = oid && (!m[3] || jQuery.nodeName(oid, m[3])) ? [oid] : [];
-					} else {
-						// Pre-compile a regular expression to handle class searches
-						if ( m[1] == "." )
-							var rec = new RegExp("(^|\\s)" + m[2] + "(\\s|$)");
-						// We need to find all descendant elements, it is more
-						// efficient to use getAll() when we are already further down
-						// the tree - we try to recognize that here
-							// Grab the tag name being searched for
-							var tag = m[1] != "" || m[0] == "" ? "*" : m[2];
-							// Handle IE7 being really dumb about <object>s
-							if ( jQuery.nodeName(this, "object") && tag == "*" )
-								tag = "param";
-							jQuery.merge( r,
-								m[1] != "" && ret.length != 1 ?
-									jQuery.getAll( this, [], m[1], m[2], rec ) :
-									this.getElementsByTagName( tag )
-						// It's faster to filter by class and be done with it
-						if ( m[1] == "." && ret.length == 1 )
-							r = jQuery.grep( r, function(e) {
-								return rec.test(e.className);
-						// Same with ID filtering
-						if ( m[1] == "#" && ret.length == 1 ) {
-							// Remember, then wipe out, the result set
-							var tmp = r;
-							r = [];
-							// Then try to find the element with the ID
-							jQuery.each( tmp, function(){
-								if ( this.getAttribute("id") == m[2] ) {
-									r = [ this ];
-									return false;
-						ret = r;
-					t = t.replace( re2, "" );
-			// If a selector string still exists
-			if ( t ) {
-				// Attempt to filter it
-				var val = jQuery.filter(t,r);
-				ret = r = val.r;
-				t = jQuery.trim(val.t);
-		// Remove the root context
-		if ( ret && ret[0] == context ) ret.shift();
-		// And combine the results
-		return done;
-	filter: function(t,r,not) {
-		// Look for common filter expressions
-		while ( t && /^[a-z[({<*:.#]/i.test(t) ) {
-			var p = jQuery.parse, m;
-			jQuery.each( p, function(i,re){
-				// Look for, and replace, string-like sequences
-				// and finally build a regexp out of it
-				m = re.exec( t );
-				if ( m ) {
-					// Remove what we just matched
-					t = t.substring( m[0].length );
-					// Re-organize the first match
-					if ( jQuery.expr[ m[1] ]._resort )
-						m = jQuery.expr[ m[1] ]._resort( m );
-					return false;
-			// :not() is a special case that can be optimized by
-			// keeping it out of the expression list
-			if ( m[1] == ":" && m[2] == "not" )
-				r = jQuery.filter(m[3], r, true).r;
-			// Handle classes as a special case (this will help to
-			// improve the speed, as the regexp will only be compiled once)
-			else if ( m[1] == "." ) {
-				var re = new RegExp("(^|\\s)" + m[2] + "(\\s|$)");
-				r = jQuery.grep( r, function(e){
-					return re.test(e.className || "");
-				}, not);
-			// Otherwise, find the expression to execute
-			} else {
-				var f = jQuery.expr[m[1]];
-				if ( typeof f != "string" )
-					f = jQuery.expr[m[1]][m[2]];
-				// Build a custom macro to enclose it
-				eval("f = function(a,i){" +
-					( jQuery.expr[ m[1] ]._prefix || "" ) +
-					"return " + f + "}");
-				// Execute it against the current filter
-				r = jQuery.grep( r, f, not );
-		// Return an array of filtered elements (r)
-		// and the modified expression string (t)
-		return { r: r, t: t };
-	getAll: function( o, r, token, name, re ) {
-		for ( var s = o.firstChild; s; s = s.nextSibling )
-			if ( s.nodeType == 1 ) {
-				var add = true;
-				if ( token == "." )
-					add = s.className && re.test(s.className);
-				else if ( token == "#" )
-					add = s.getAttribute("id") == name;
-				if ( add )
-					r.push( s );
-				if ( token == "#" && r.length ) break;
-				if ( s.firstChild )
-					jQuery.getAll( s, r, token, name, re );
-		return r;
-	parents: function( elem ){
-		var matched = [];
-		var cur = elem.parentNode;
-		while ( cur && cur != document ) {
-			matched.push( cur );
-			cur = cur.parentNode;
-		return matched;
-	nth: function(cur,result,dir,elem){
-		result = result || 1;
-		var num = 0;
-		for ( ; cur; cur = cur[dir] ) {
-			if ( cur.nodeType == 1 ) num++;
-			if ( num == result || result == "even" && num % 2 == 0 && num > 1 && cur == elem ||
-				result == "odd" && num % 2 == 1 && cur == elem ) return cur;
-	sibling: function( n, elem ) {
-		var r = [];
-		for ( ; n; n = n.nextSibling ) {
-			if ( n.nodeType == 1 && (!elem || n != elem) )
-				r.push( n );
-		return r;
- * A number of helper functions used for managing events.
- * Many of the ideas behind this code orignated from
- * Dean Edwards' addEvent library.
-jQuery.event = {
-	// Bind an event to an element
-	// Original by Dean Edwards
-	add: function(element, type, handler, data) {
-		// For whatever reason, IE has trouble passing the window object
-		// around, causing it to be cloned in the process
-		if ( jQuery.browser.msie && element.setInterval != undefined )
-			element = window;
-		// if data is passed, bind to handler
-		if( data )
-			handler.data = data;
-		// Make sure that the function being executed has a unique ID
-		if ( !handler.guid )
-			handler.guid = this.guid++;
-		// Init the element's event structure
-		if (!element.$events)
-			element.$events = {};
-		// Get the current list of functions bound to this event
-		var handlers = element.$events[type];
-		// If it hasn't been initialized yet
-		if (!handlers) {
-			// Init the event handler queue
-			handlers = element.$events[type] = {};
-			// Remember an existing handler, if it's already there
-			if (element["on" + type])
-				handlers[0] = element["on" + type];
-		// Add the function to the element's handler list
-		handlers[handler.guid] = handler;
-		// And bind the global event handler to the element
-		element["on" + type] = this.handle;
-		// Remember the function in a global list (for triggering)
-		if (!this.global[type])
-			this.global[type] = [];
-		this.global[type].push( element );
-	guid: 1,
-	global: {},
-	// Detach an event or set of events from an element
-	remove: function(element, type, handler) {
-		if (element.$events) {
-			var i,j,k;
-			if ( type && type.type ) { // type is actually an event object here
-				handler = type.handler;
-				type    = type.type;
-			if (type && element.$events[type])
-				// remove the given handler for the given type
-				if ( handler )
-					delete element.$events[type][handler.guid];
-				// remove all handlers for the given type
-				else
-					for ( i in element.$events[type] )
-						delete element.$events[type][i];
-			else
-				for ( j in element.$events )
-					this.remove( element, j );
-			// remove event handler if no more handlers exist
-			for ( k in element.$events[type] )
-				if (k) {
-					k = true;
-					break;
-			if (!k) element["on" + type] = null;
-	trigger: function(type, data, element) {
-		// Clone the incoming data, if any
-		data = jQuery.makeArray(data || []);
-		// Handle a global trigger
-		if ( !element )
-			jQuery.each( this.global[type] || [], function(){
-				jQuery.event.trigger( type, data, this );
-		// Handle triggering a single element
-		else {
-			var handler = element["on" + type ], val,
-				fn = jQuery.isFunction( element[ type ] );
-			if ( handler ) {
-				// Pass along a fake event
-				data.unshift( this.fix({ type: type, target: element }) );
-				// Trigger the event
-				if ( (val = handler.apply( element, data )) !== false )
-					this.triggered = true;
-			if ( fn && val !== false )
-				element[ type ]();
-			this.triggered = false;
-	handle: function(event) {
-		// Handle the second event of a trigger and when
-		// an event is called after a page has unloaded
-		if ( typeof jQuery == "undefined" || jQuery.event.triggered ) return;
-		// Empty object is for triggered events with no data
-		event = jQuery.event.fix( event || window.event || {} );
-		// returned undefined or false
-		var returnValue;
-		var c = this.$events[event.type];
-		var args = [].slice.call( arguments, 1 );
-		args.unshift( event );
-		for ( var j in c ) {
-			// Pass in a reference to the handler function itself
-			// So that we can later remove it
-			args[0].handler = c[j];
-			args[0].data = c[j].data;
-			if ( c[j].apply( this, args ) === false ) {
-				event.preventDefault();
-				event.stopPropagation();
-				returnValue = false;
-		// Clean up added properties in IE to prevent memory leak
-		if (jQuery.browser.msie) event.target = event.preventDefault = event.stopPropagation = event.handler = event.data = null;
-		return returnValue;
-	fix: function(event) {
-		// Fix target property, if necessary
-		if ( !event.target && event.srcElement )
-			event.target = event.srcElement;
-		// Calculate pageX/Y if missing and clientX/Y available
-		if ( event.pageX == undefined && event.clientX != undefined ) {
-			var e = document.documentElement, b = document.body;
-			event.pageX = event.clientX + (e.scrollLeft || b.scrollLeft);
-			event.pageY = event.clientY + (e.scrollTop || b.scrollTop);
-		// check if target is a textnode (safari)
-		if (jQuery.browser.safari && event.target.nodeType == 3) {
-			// store a copy of the original event object
-			// and clone because target is read only
-			var originalEvent = event;
-			event = jQuery.extend({}, originalEvent);
-			// get parentnode from textnode
-			event.target = originalEvent.target.parentNode;
-			// add preventDefault and stopPropagation since
-			// they will not work on the clone
-			event.preventDefault = function() {
-				return originalEvent.preventDefault();
-			event.stopPropagation = function() {
-				return originalEvent.stopPropagation();
-		// fix preventDefault and stopPropagation
-		if (!event.preventDefault)
-				this.returnValue = false;
-		if (!event.stopPropagation)
-				this.cancelBubble = true;
-		return event;
-jQuery.fn.extend({
-	bind: function( type, data, fn ) {
-			jQuery.event.add( this, type, fn || data, data );
-	one: function( type, data, fn ) {
-			jQuery.event.add( this, type, function(event) {
-				jQuery(this).unbind(event);
-				return (fn || data).apply( this, arguments);
-			}, data);
-	unbind: function( type, fn ) {
-			jQuery.event.remove( this, type, fn );
-	trigger: function( type, data ) {
-	toggle: function() {
-		// Save reference to arguments for access in closure
-		return this.click(function(e) {
-			// Figure out which function to execute
-			this.lastToggle = this.lastToggle == 0 ? 1 : 0;
-			// Make sure that clicks stop
-			e.preventDefault();
-			// and execute the function
-			return a[this.lastToggle].apply( this, [e] ) || false;
-	hover: function(f,g) {
-		// A private function for handling mouse 'hovering'
-		function handleHover(e) {
-			// Check if mouse(over|out) are still within the same parent element
-			var p = (e.type == "mouseover" ? e.fromElement : e.toElement) || e.relatedTarget;
-			// Traverse up the tree
-			while ( p && p != this ) try { p = p.parentNode } catch(e) { p = this; };
-			// If we actually just moused on to a sub-element, ignore it
-			if ( p == this ) return false;
-			// Execute the right function
-			return (e.type == "mouseover" ? f : g).apply(this, [e]);
-		// Bind the function to the two event listeners
-		return this.mouseover(handleHover).mouseout(handleHover);
-	ready: function(f) {
-		// If the DOM is already ready
-		if ( jQuery.isReady )
-			// Execute the function immediately
-			f.apply( document, [jQuery] );
-		// Otherwise, remember the function for later
-		else {
-			// Add the function to the wait list
-			jQuery.readyList.push( function() { return f.apply(this, [jQuery]) } );
-		return this;
-jQuery.extend({
-	 * All the code that makes DOM Ready work nicely.
-	isReady: false,
-	readyList: [],
-	// Handle when the DOM is ready
-	ready: function() {
-		// Make sure that the DOM is not already loaded
-		if ( !jQuery.isReady ) {
-			// Remember that the DOM is ready
-			jQuery.isReady = true;
-			// If there are functions bound, to execute
-			if ( jQuery.readyList ) {
-				// Execute all of them
-				jQuery.each( jQuery.readyList, function(){
-					this.apply( document );
-				// Reset the list of functions
-				jQuery.readyList = null;
-			// Remove event lisenter to avoid memory leak
-			if ( jQuery.browser.mozilla || jQuery.browser.opera )
-				document.removeEventListener( "DOMContentLoaded", jQuery.ready, false );
-new function(){
-	jQuery.each( ("blur,focus,load,resize,scroll,unload,click,dblclick," +
-		"mousedown,mouseup,mousemove,mouseover,mouseout,change,select," +
-		"submit,keydown,keypress,keyup,error").split(","), function(i,o){
-		// Handle event binding
-		jQuery.fn[o] = function(f){
-			return f ? this.bind(o, f) : this.trigger(o);
-	// If Mozilla is used
-		// Use the handy event callback
-		document.addEventListener( "DOMContentLoaded", jQuery.ready, false );
-	// If IE is used, use the excellent hack by Matthias Miller
-	// http://www.outofhanwell.com/blog/index.php?title=the_window_onload_problem_revisited
-	else if ( jQuery.browser.msie ) {
-		// Only works if you document.write() it
-		document.write("<scr" + "ipt id=__ie_init defer=true " +
-			"src=//:><\/script>");
-		// Use the defer script hack
-		var script = document.getElementById("__ie_init");
-		// script does not exist if jQuery is loaded dynamically
-		if ( script )
-			script.onreadystatechange = function() {
-				if ( this.readyState != "complete" ) return;
-				jQuery.ready();
-		// Clear from memory
-		script = null;
-	// If Safari  is used
-	} else if ( jQuery.browser.safari )
-		// Continually check to see if the document.readyState is valid
-		jQuery.safariTimer = setInterval(function(){
-			// loaded and complete are both valid states
-			if ( document.readyState == "loaded" ||
-				document.readyState == "complete" ) {
-				// If either one are found, remove the timer
-				clearInterval( jQuery.safariTimer );
-				jQuery.safariTimer = null;
-				// and execute any waiting functions
-				jQuery.ready();
-		}, 10);
-	// A fallback to window.onload, that will always work
-	jQuery.event.add( window, "load", jQuery.ready );
-// Clean up after IE to avoid memory leaks
-if (jQuery.browser.msie)
-	jQuery(window).one("unload", function() {
-		var global = jQuery.event.global;
-		for ( var type in global ) {
-			var els = global[type], i = els.length;
-			if ( i && type != 'unload' )
-				do
-					jQuery.event.remove(els[i-1], type);
-				while (--i);
-jQuery.fn.extend({
-	loadIfModified: function( url, params, callback ) {
-		this.load( url, params, callback, 1 );
-	load: function( url, params, callback, ifModified ) {
-		if ( jQuery.isFunction( url ) )
-			return this.bind("load", url);
-		callback = callback || function(){};
-		// Default to a GET request
-		var type = "GET";
-		// If the second parameter was provided
-		if ( params )
-			// If it's a function
-			if ( jQuery.isFunction( params ) ) {
-				// We assume that it's the callback
-				callback = params;
-				params = null;
-			// Otherwise, build a param string
-			} else {
-				params = jQuery.param( params );
-				type = "POST";
-		var self = this;
-		// Request the remote document
-		jQuery.ajax({
-			url: url,
-			type: type,
-			data: params,
-			ifModified: ifModified,
-			complete: function(res, status){
-				if ( status == "success" || !ifModified && status == "notmodified" )
-					// Inject the HTML into all the matched elements
-					self.attr("innerHTML", res.responseText)
-					  // Execute all the scripts inside of the newly-injected HTML
-					  .evalScripts()
-					  // Execute callback
-					  .each( callback, [res.responseText, status, res] );
-				else
-					callback.apply( self, [res.responseText, status, res] );
-		return this;
-	serialize: function() {
-		return jQuery.param( this );
-	evalScripts: function() {
-		return this.find("script").each(function(){
-			if ( this.src )
-				jQuery.getScript( this.src );
-			else
-				jQuery.globalEval( this.text || this.textContent || this.innerHTML || "" );
-		}).end();
-// If IE is used, create a wrapper for the XMLHttpRequest object
-if ( !window.XMLHttpRequest )
-	XMLHttpRequest = function(){
-		return new ActiveXObject("Microsoft.XMLHTTP");
-// Attach a bunch of functions for handling common AJAX events
-jQuery.each( "ajaxStart,ajaxStop,ajaxComplete,ajaxError,ajaxSuccess,ajaxSend".split(","), function(i,o){
-		return this.bind(o, f);
-jQuery.extend({
-	get: function( url, data, callback, type, ifModified ) {
-		// shift arguments if data argument was ommited
-		if ( jQuery.isFunction( data ) ) {
-			callback = data;
-			data = null;
-		return jQuery.ajax({
-			url: url,
-			data: data,
-			success: callback,
-			dataType: type,
-	getIfModified: function( url, data, callback, type ) {
-		return jQuery.get(url, data, callback, type, 1);
-	getScript: function( url, callback ) {
-		return jQuery.get(url, null, callback, "script");
-	getJSON: function( url, data, callback ) {
-		return jQuery.get(url, data, callback, "json");
-	post: function( url, data, callback, type ) {
-			callback = data;
-			data = {};
-			type: "POST",
-			url: url,
-			data: data,
-			dataType: type
-	// timeout (ms)
-	//timeout: 0,
-	ajaxTimeout: function( timeout ) {
-		jQuery.ajaxSettings.timeout = timeout;
-	ajaxSetup: function( settings ) {
-		jQuery.extend( jQuery.ajaxSettings, settings );
-	ajaxSettings: {
-		global: true,
-		type: "GET",
-		timeout: 0,
-		contentType: "application/x-www-form-urlencoded",
-		processData: true,
-		async: true,
-		data: null
-	// Last-Modified header cache for next request
-	lastModified: {},
-	ajax: function( s ) {
-		// TODO introduce global settings, allowing the client to modify them for all requests, not only timeout
-		s = jQuery.extend({}, jQuery.ajaxSettings, s);
-		// if data available
-		if ( s.data ) {
-			// convert data if not already a string
-			if (s.processData && typeof s.data != "string")
-    			s.data = jQuery.param(s.data);
-			// append data to url for get requests
-			if( s.type.toLowerCase() == "get" ) {
-				// "?" + data or "&" + data (in case there are already params)
-				s.url += ((s.url.indexOf("?") > -1) ? "&" : "?") + s.data;
-				// IE likes to send both get and post data, prevent this
-				s.data = null;
-		// Watch for a new set of requests
-		if ( s.global && ! jQuery.active++ )
-			jQuery.event.trigger( "ajaxStart" );
-		var requestDone = false;
-		// Create the request object
-		var xml = new XMLHttpRequest();
-		// Open the socket
-		xml.open(s.type, s.url, s.async);
-		// Set the correct header, if data is being sent
-		if ( s.data )
-			xml.setRequestHeader("Content-Type", s.contentType);
-		// Set the If-Modified-Since header, if ifModified mode.
-		if ( s.ifModified )
-			xml.setRequestHeader("If-Modified-Since",
-				jQuery.lastModified[s.url] || "Thu, 01 Jan 1970 00:00:00 GMT" );
-		// Set header so the called script knows that it's an XMLHttpRequest
-		xml.setRequestHeader("X-Requested-With", "XMLHttpRequest");
-		// Make sure the browser sends the right content length
-		if ( xml.overrideMimeType )
-			xml.setRequestHeader("Connection", "close");
-		// Allow custom headers/mimetypes
-		if( s.beforeSend )
-			s.beforeSend(xml);
-		if ( s.global )
-		    jQuery.event.trigger("ajaxSend", [xml, s]);
-		// Wait for a response to come back
-		var onreadystatechange = function(isTimeout){
-			// The transfer is complete and the data is available, or the request timed out
-			if ( xml && (xml.readyState == 4 || isTimeout == "timeout") ) {
-				requestDone = true;
-				// clear poll interval
-				if (ival) {
-					clearInterval(ival);
-					ival = null;
-				var status;
-				try {
-					status = jQuery.httpSuccess( xml ) && isTimeout != "timeout" ?
-						s.ifModified && jQuery.httpNotModified( xml, s.url ) ? "notmodified" : "success" : "error";
-					// Make sure that the request was successful or notmodified
-					if ( status != "error" ) {
-						// Cache Last-Modified header, if ifModified mode.
-						var modRes;
-						try {
-							modRes = xml.getResponseHeader("Last-Modified");
-						} catch(e) {} // swallow exception thrown by FF if header is not available
-						if ( s.ifModified && modRes )
-							jQuery.lastModified[s.url] = modRes;
-						// process the data (runs the xml through httpData regardless of callback)
-						var data = jQuery.httpData( xml, s.dataType );
-						// If a local callback was specified, fire it and pass it the data
-						if ( s.success )
-							s.success( data, status );
-						// Fire the global callback
-						if( s.global )
-							jQuery.event.trigger( "ajaxSuccess", [xml, s] );
-					} else
-						jQuery.handleError(s, xml, status);
-				} catch(e) {
-					status = "error";
-					jQuery.handleError(s, xml, status, e);
-				// The request was completed
-				if( s.global )
-					jQuery.event.trigger( "ajaxComplete", [xml, s] );
-				// Handle the global AJAX counter
-				if ( s.global && ! --jQuery.active )
-					jQuery.event.trigger( "ajaxStop" );
-				// Process result
-				if ( s.complete )
-					s.complete(xml, status);
-				// Stop memory leaks
-				if(s.async)
-					xml = null;
-		// don't attach the handler to the request, just poll it instead
-		var ival = setInterval(onreadystatechange, 13);
-		// Timeout checker
-		if ( s.timeout > 0 )
-			setTimeout(function(){
-				// Check to see if the request is still happening
-				if ( xml ) {
-					// Cancel the request
-					xml.abort();
-					if( !requestDone )
-						onreadystatechange( "timeout" );
-			}, s.timeout);
-		// Send the data
-		try {
-			xml.send(s.data);
-		} catch(e) {
-			jQuery.handleError(s, xml, null, e);
-		// firefox 1.5 doesn't fire statechange for sync requests
-		if ( !s.async )
-			onreadystatechange();
-		// return XMLHttpRequest to allow aborting the request etc.
-		return xml;
-	handleError: function( s, xml, status, e ) {
-		if ( s.error ) s.error( xml, status, e );
-		if ( s.global )
-			jQuery.event.trigger( "ajaxError", [xml, s, e] );
-	// Counter for holding the number of active queries
-	active: 0,
-	// Determines if an XMLHttpRequest was successful or not
-	httpSuccess: function( r ) {
-		try {
-			return !r.status && location.protocol == "file:" ||
-				( r.status >= 200 && r.status < 300 ) || r.status == 304 ||
-				jQuery.browser.safari && r.status == undefined;
-		} catch(e){}
-		return false;
-	// Determines if an XMLHttpRequest returns NotModified
-	httpNotModified: function( xml, url ) {
-		try {
-			var xmlRes = xml.getResponseHeader("Last-Modified");
-			// Firefox always returns 200. check Last-Modified date
-			return xml.status == 304 || xmlRes == jQuery.lastModified[url] ||
-				jQuery.browser.safari && xml.status == undefined;
-		} catch(e){}
-		return false;
-	/* Get the data out of an XMLHttpRequest.
-	 * Return parsed XML if content-type header is "xml" and type is "xml" or omitted,
-	 * otherwise return plain text.
-	 * (String) data - The type of data that you're expecting back,
-	 * (e.g. "xml", "html", "script")
-	httpData: function( r, type ) {
-		var ct = r.getResponseHeader("content-type");
-		var data = !type && ct && ct.indexOf("xml") >= 0;
-		data = type == "xml" || data ? r.responseXML : r.responseText;
-		// If the type is "script", eval it in global context
-		if ( type == "script" )
-			jQuery.globalEval( data );
-		// Get the JavaScript object, if JSON is used.
-		if ( type == "json" )
-			eval( "data = " + data );
-		// evaluate scripts within html
-		if ( type == "html" )
-			jQuery("<div>").html(data).evalScripts();
-		return data;
-	// Serialize an array of form elements or a set of
-	// key/values into a query string
-	param: function( a ) {
-		var s = [];
-		// If an array was passed in, assume that it is an array
-		// of form elements
-		if ( a.constructor == Array || a.jquery )
-			// Serialize the form elements
-				s.push( encodeURIComponent(this.name) + "=" + encodeURIComponent( this.value ) );
-		// Otherwise, assume that it's an object of key/value pairs
-		else
-			// Serialize the key/values
-			for ( var j in a )
-				// If the value is an array then the key names need to be repeated
-				if ( a[j] && a[j].constructor == Array )
-					jQuery.each( a[j], function(){
-						s.push( encodeURIComponent(j) + "=" + encodeURIComponent( this ) );
-				else
-					s.push( encodeURIComponent(j) + "=" + encodeURIComponent( a[j] ) );
-		// Return the resulting serialization
-		return s.join("&");
-	// evalulates a script in global context
-	// not reliable for safari
-	globalEval: function( data ) {
-		if ( window.execScript )
-			window.execScript( data );
-		else if ( jQuery.browser.safari )
-			// safari doesn't provide a synchronous global eval
-			window.setTimeout( data, 0 );
-		else
-			eval.call( window, data );
-jQuery.fn.extend({
-	show: function(speed,callback){
-		var hidden = this.filter(":hidden");
-		speed ?
-			hidden.animate({
-				height: "show", width: "show", opacity: "show"
-			}, speed, callback) :
-			hidden.each(function(){
-				this.style.display = this.oldblock ? this.oldblock : "";
-				if ( jQuery.css(this,"display") == "none" )
-					this.style.display = "block";
-		return this;
-	hide: function(speed,callback){
-		var visible = this.filter(":visible");
-		speed ?
-			visible.animate({
-				height: "hide", width: "hide", opacity: "hide"
-			visible.each(function(){
-				this.oldblock = this.oldblock || jQuery.css(this,"display");
-				if ( this.oldblock == "none" )
-					this.oldblock = "block";
-				this.style.display = "none";
-		return this;
-	// Save the old toggle function
-	_toggle: jQuery.fn.toggle,
-	toggle: function( fn, fn2 ){
-		var args = arguments;
-		return jQuery.isFunction(fn) && jQuery.isFunction(fn2) ?
-			this._toggle( fn, fn2 ) :
-			this.each(function(){
-				jQuery(this)[ jQuery(this).is(":hidden") ? "show" : "hide" ]
-					.apply( jQuery(this), args );
-	slideDown: function(speed,callback){
-		return this.animate({height: "show"}, speed, callback);
-	slideUp: function(speed,callback){
-		return this.animate({height: "hide"}, speed, callback);
-	slideToggle: function(speed, callback){
-			var state = jQuery(this).is(":hidden") ? "show" : "hide";
-			jQuery(this).animate({height: state}, speed, callback);
-	fadeIn: function(speed, callback){
-		return this.animate({opacity: "show"}, speed, callback);
-	fadeOut: function(speed, callback){
-		return this.animate({opacity: "hide"}, speed, callback);
-	fadeTo: function(speed,to,callback){
-		return this.animate({opacity: to}, speed, callback);
-	animate: function( prop, speed, easing, callback ) {
-		return this.queue(function(){
-			this.curAnim = jQuery.extend({}, prop);
-			var opt = jQuery.speed(speed, easing, callback);
-			for ( var p in prop ) {
-				var e = new jQuery.fx( this, opt, p );
-				if ( prop[p].constructor == Number )
-					e.custom( e.cur(), prop[p] );
-				else
-					e[ prop[p] ]( prop );
-	queue: function(type,fn){
-		if ( !fn ) {
-			fn = type;
-			type = "fx";
-			if ( !this.queue )
-				this.queue = {};
-			if ( !this.queue[type] )
-				this.queue[type] = [];
-			this.queue[type].push( fn );
-			if ( this.queue[type].length == 1 )
-				fn.apply(this);
-jQuery.extend({
-	speed: function(speed, easing, fn) {
-		var opt = speed && speed.constructor == Object ? speed : {
-			complete: fn || !fn && easing ||
-				jQuery.isFunction( speed ) && speed,
-			duration: speed,
-			easing: fn && easing || easing && easing.constructor != Function && easing
-		opt.duration = (opt.duration && opt.duration.constructor == Number ?
-			opt.duration :
-			{ slow: 600, fast: 200 }[opt.duration]) || 400;
-		// Queueing
-		opt.old = opt.complete;
-		opt.complete = function(){
-			jQuery.dequeue(this, "fx");
-			if ( jQuery.isFunction( opt.old ) )
-				opt.old.apply( this );
-		return opt;
-	easing: {},
-	queue: {},
-	dequeue: function(elem,type){
-		type = type || "fx";
-		if ( elem.queue && elem.queue[type] ) {
-			// Remove self
-			elem.queue[type].shift();
-			// Get next function
-			var f = elem.queue[type][0];
-			if ( f ) f.apply( elem );
-	 * I originally wrote fx() as a clone of moo.fx and in the process
-	 * of making it small in size the code became illegible to sane
-	 * people. You've been warned.
-	fx: function( elem, options, prop ){
-		var z = this;
-		// The styles
-		var y = elem.style;
-		// Store display property
-		var oldDisplay = jQuery.css(elem, "display");
-		// Make sure that nothing sneaks out
-		y.overflow = "hidden";
-		// Simple function for setting a style value
-		z.a = function(){
-			if ( options.step )
-				options.step.apply( elem, [ z.now ] );
-			if ( prop == "opacity" )
-				jQuery.attr(y, "opacity", z.now); // Let attr handle opacity
-			else if ( parseInt(z.now) ) // My hate for IE will never die
-				y[prop] = parseInt(z.now) + "px";
-			y.display = "block"; // Set display property to block for animation
-		// Figure out the maximum number to run to
-		z.max = function(){
-			return parseFloat( jQuery.css(elem,prop) );
-		// Get the current size
-		z.cur = function(){
-			var r = parseFloat( jQuery.curCSS(elem, prop) );
-			return r && r > -10000 ? r : z.max();
-		// Start an animation from one number to another
-		z.custom = function(from,to){
-			z.startTime = (new Date()).getTime();
-			z.now = from;
-			z.a();
-			z.timer = setInterval(function(){
-				z.step(from, to);
-			}, 13);
-		// Simple 'show' function
-		z.show = function(){
-			if ( !elem.orig ) elem.orig = {};
-			// Remember where we started, so that we can go back to it later
-			elem.orig[prop] = this.cur();
-			options.show = true;
-			// Begin the animation
-			z.custom(0, elem.orig[prop]);
-			// Stupid IE, look what you made me do
-			if ( prop != "opacity" )
-				y[prop] = "1px";
-		// Simple 'hide' function
-		z.hide = function(){
-			options.hide = true;
-			z.custom(elem.orig[prop], 0);
-		//Simple 'toggle' function
-		z.toggle = function() {
-			if(oldDisplay == "none")  {
-					y[prop] = "1px";
-			} else {
-		// Each step of an animation
-		z.step = function(firstNum, lastNum){
-			var t = (new Date()).getTime();
-			if (t > options.duration + z.startTime) {
-				// Stop the timer
-				clearInterval(z.timer);
-				z.timer = null;
-				z.now = lastNum;
-				z.a();
-				if (elem.curAnim) elem.curAnim[ prop ] = true;
-				var done = true;
-				for ( var i in elem.curAnim )
-					if ( elem.curAnim[i] !== true )
-						done = false;
-				if ( done ) {
-					// Reset the overflow
-					y.overflow = "";
-					// Reset the display
-					y.display = oldDisplay;
-					if (jQuery.css(elem, "display") == "none")
-					// Hide the element if the "hide" operation was done
-					if ( options.hide )
-						y.display = "none";
-					// Reset the properties, if the item has been hidden or shown
-					if ( options.hide || options.show )
-						for ( var p in elem.curAnim )
-							if (p == "opacity")
-								jQuery.attr(y, p, elem.orig[p]);
-							else
-								y[p] = "";
-				// If a callback was provided, execute it
-				if ( done && jQuery.isFunction( options.complete ) )
-					// Execute the complete function
-					options.complete.apply( elem );
-			} else {
-				var n = t - this.startTime;
-				// Figure out where in the animation we are and set the number
-				var p = n / options.duration;
-				// If the easing function exists, then use it
-				z.now = options.easing && jQuery.easing[options.easing] ?
-					jQuery.easing[options.easing](p, n,  firstNum, (lastNum-firstNum), options.duration) :
-					// else use default linear easing
-					((-Math.cos(p*Math.PI)/2) + 0.5) * (lastNum-firstNum) + firstNum;
-				// Perform the next step of the animation
-				z.a();
+eval(function(p,a,c,k,e,r){e=function(c){return(c<a?'':e(parseInt(c/a)))+((c=c%a)>35?String.fromCharCode(c+29):c.toString(36))};if(!''.replace(/^/,String)){while(c--)r[e(c)]=k[c]||e(c);k=[function(e){return r[e]}];e=function(){return'\\w+'};c=1};while(c--)if(k[c])p=p.replace(new RegExp('\\b'+e(c)+'\\b','g'),k[c]);return p}('(G(){9(1m E!="W")H w=E;H E=18.15=G(a,b){I 6 7u E?6.5N(a,b):1u E(a,b)};9(1m $!="W")H D=$;18.$=E;H u=/^[^<]*(<(.|\\s)+>)[^>]*$|^#(\\w+)$/;E.1b=E.3A={5N:G(c,a){c=c||U;9(1m c=="1M"){H m=u.2S(c);9(m&&(m[1]||!a)){9(m[1])c=E.4D([m[1]],a);J{H b=U.3S(m[3]);9(b)9(b.22!=m[3])I E().1Y(c);J{6[0]=b;6.K=1;I 6}J c=[]}}J I 1u E(a).1Y(c)}J 9(E.1n(c))I 1u E(U)[E.1b.2d?"2d":"39"](c);I 6.6v(c.1c==1B&&c||(c.4c||c.K&&c!=18&&!c.1y&&c[0]!=W&&c[0].1y)&&E.2h(c)||[c])},4c:"1.2.1",7Y:G(){I 6.K},K:0,21:G(a){I a==W?E.2h(6):6[a]},2o:G(a){H b=E(a);b.4Y=6;I b},6v:G(a){6.K=0;1B.3A.1a.16(6,a);I 6},N:G(a,b){I E.N(6,a,b)},4I:G(a){H b=-1;6.N(G(i){9(6==a)b=i});I b},1x:G(f,d,e){H c=f;9(f.1c==3X)9(d==W)I 6.K&&E[e||"1x"](6[0],f)||W;J{c={};c[f]=d}I 6.N(G(a){L(H b 1i c)E.1x(e?6.R:6,b,E.1e(6,c[b],e,a,b))})},17:G(b,a){I 6.1x(b,a,"3C")},2g:G(e){9(1m e!="5i"&&e!=S)I 6.4n().3g(U.6F(e));H t="";E.N(e||6,G(){E.N(6.3j,G(){9(6.1y!=8)t+=6.1y!=1?6.6x:E.1b.2g([6])})});I t},5m:G(b){9(6[0])E(b,6[0].3H).6u().3d(6[0]).1X(G(){H a=6;1W(a.1w)a=a.1w;I a}).3g(6);I 6},8m:G(a){I 6.N(G(){E(6).6q().5m(a)})},8d:G(a){I 6.N(G(){E(6).5m(a)})},3g:G(){I 6.3z(1q,Q,1,G(a){6.58(a)})},6j:G(){I 6.3z(1q,Q,-1,G(a){6.3d(a,6.1w)})},6g:G(){I 6.3z(1q,P,1,G(a){6.12.3d(a,6)})},50:G(){I 6.3z(1q,P,-1,G(a){6.12.3d(a,6.2q)})},2D:G(){I 6.4Y||E([])},1Y:G(t){H b=E.1X(6,G(a){I E.1Y(t,a)});I 6.2o(/[^+>] [^+>]/.14(t)||t.1g("..")>-1?E.4V(b):b)},6u:G(e){H f=6.1X(G(){I 6.67?E(6.67)[0]:6.4R(Q)});H d=f.1Y("*").4O().N(G(){9(6[F]!=W)6[F]=S});9(e===Q)6.1Y("*").4O().N(G(i){H c=E.M(6,"2P");L(H a 1i c)L(H b 1i c[a])E.1j.1f(d[i],a,c[a][b],c[a][b].M)});I f},1E:G(t){I 6.2o(E.1n(t)&&E.2W(6,G(b,a){I t.16(b,[a])})||E.3m(t,6))},5V:G(t){I 6.2o(t.1c==3X&&E.3m(t,6,Q)||E.2W(6,G(a){I(t.1c==1B||t.4c)?E.2A(a,t)<0:a!=t}))},1f:G(t){I 6.2o(E.1R(6.21(),t.1c==3X?E(t).21():t.K!=W&&(!t.11||E.11(t,"2Y"))?t:[t]))},3t:G(a){I a?E.3m(a,6).K>0:P},7c:G(a){I 6.3t("."+a)},3i:G(b){9(b==W){9(6.K){H c=6[0];9(E.11(c,"24")){H e=c.4Z,a=[],Y=c.Y,2G=c.O=="24-2G";9(e<0)I S;L(H i=2G?e:0,33=2G?e+1:Y.K;i<33;i++){H d=Y[i];9(d.26){H b=E.V.1h&&!d.9V["1Q"].9L?d.2g:d.1Q;9(2G)I b;a.1a(b)}}I a}J I 6[0].1Q.1p(/\\r/g,"")}}J I 6.N(G(){9(b.1c==1B&&/4k|5j/.14(6.O))6.2Q=(E.2A(6.1Q,b)>=0||E.2A(6.2H,b)>=0);J 9(E.11(6,"24")){H a=b.1c==1B?b:[b];E("9h",6).N(G(){6.26=(E.2A(6.1Q,a)>=0||E.2A(6.2g,a)>=0)});9(!a.K)6.4Z=-1}J 6.1Q=b})},4o:G(a){I a==W?(6.K?6[0].3O:S):6.4n().3g(a)},6H:G(a){I 6.50(a).28()},6E:G(i){I 6.2J(i,i+1)},2J:G(){I 6.2o(1B.3A.2J.16(6,1q))},1X:G(b){I 6.2o(E.1X(6,G(a,i){I b.2O(a,i,a)}))},4O:G(){I 6.1f(6.4Y)},3z:G(f,d,g,e){H c=6.K>1,a;I 6.N(G(){9(!a){a=E.4D(f,6.3H);9(g<0)a.8U()}H b=6;9(d&&E.11(6,"1I")&&E.11(a[0],"4m"))b=6.4l("1K")[0]||6.58(U.5B("1K"));E.N(a,G(){H a=c?6.4R(Q):6;9(!5A(0,a))e.2O(b,a)})})}};G 5A(i,b){H a=E.11(b,"1J");9(a){9(b.3k)E.3G({1d:b.3k,3e:P,1V:"1J"});J E.5f(b.2g||b.6s||b.3O||"");9(b.12)b.12.3b(b)}J 9(b.1y==1)E("1J",b).N(5A);I a}E.1k=E.1b.1k=G(){H c=1q[0]||{},a=1,2c=1q.K,5e=P;9(c.1c==8o){5e=c;c=1q[1]||{}}9(2c==1){c=6;a=0}H b;L(;a<2c;a++)9((b=1q[a])!=S)L(H i 1i b){9(c==b[i])6r;9(5e&&1m b[i]==\'5i\'&&c[i])E.1k(c[i],b[i]);J 9(b[i]!=W)c[i]=b[i]}I c};H F="15"+(1u 3D()).3B(),6p=0,5c={};E.1k({8a:G(a){18.$=D;9(a)18.15=w;I E},1n:G(a){I!!a&&1m a!="1M"&&!a.11&&a.1c!=1B&&/G/i.14(a+"")},4a:G(a){I a.2V&&!a.1G||a.37&&a.3H&&!a.3H.1G},5f:G(a){a=E.36(a);9(a){9(18.6l)18.6l(a);J 9(E.V.1N)18.56(a,0);J 3w.2O(18,a)}},11:G(b,a){I b.11&&b.11.27()==a.27()},1L:{},M:G(c,d,b){c=c==18?5c:c;H a=c[F];9(!a)a=c[F]=++6p;9(d&&!E.1L[a])E.1L[a]={};9(b!=W)E.1L[a][d]=b;I d?E.1L[a][d]:a},30:G(c,b){c=c==18?5c:c;H a=c[F];9(b){9(E.1L[a]){2E E.1L[a][b];b="";L(b 1i E.1L[a])1T;9(!b)E.30(c)}}J{2a{2E c[F]}29(e){9(c.53)c.53(F)}2E E.1L[a]}},N:G(a,b,c){9(c){9(a.K==W)L(H i 1i a)b.16(a[i],c);J L(H i=0,48=a.K;i<48;i++)9(b.16(a[i],c)===P)1T}J{9(a.K==W)L(H i 1i a)b.2O(a[i],i,a[i]);J L(H i=0,48=a.K,3i=a[0];i<48&&b.2O(3i,i,3i)!==P;3i=a[++i]){}}I a},1e:G(c,b,d,e,a){9(E.1n(b))b=b.2O(c,[e]);H f=/z-?4I|7T-?7Q|1r|69|7P-?1H/i;I b&&b.1c==4W&&d=="3C"&&!f.14(a)?b+"2T":b},1o:{1f:G(b,c){E.N((c||"").2l(/\\s+/),G(i,a){9(!E.1o.3K(b.1o,a))b.1o+=(b.1o?" ":"")+a})},28:G(b,c){b.1o=c!=W?E.2W(b.1o.2l(/\\s+/),G(a){I!E.1o.3K(c,a)}).66(" "):""},3K:G(t,c){I E.2A(c,(t.1o||t).3s().2l(/\\s+/))>-1}},2k:G(e,o,f){L(H i 1i o){e.R["3r"+i]=e.R[i];e.R[i]=o[i]}f.16(e,[]);L(H i 1i o)e.R[i]=e.R["3r"+i]},17:G(e,p){9(p=="1H"||p=="2N"){H b={},42,41,d=["7J","7I","7G","7F"];E.N(d,G(){b["7C"+6]=0;b["7B"+6+"5Z"]=0});E.2k(e,b,G(){9(E(e).3t(\':3R\')){42=e.7A;41=e.7w}J{e=E(e.4R(Q)).1Y(":4k").5W("2Q").2D().17({4C:"1P",2X:"4F",19:"2Z",7o:"0",1S:"0"}).5R(e.12)[0];H a=E.17(e.12,"2X")||"3V";9(a=="3V")e.12.R.2X="7g";42=e.7e;41=e.7b;9(a=="3V")e.12.R.2X="3V";e.12.3b(e)}});I p=="1H"?42:41}I E.3C(e,p)},3C:G(h,j,i){H g,2w=[],2k=[];G 3n(a){9(!E.V.1N)I P;H b=U.3o.3Z(a,S);I!b||b.4y("3n")==""}9(j=="1r"&&E.V.1h){g=E.1x(h.R,"1r");I g==""?"1":g}9(j.1t(/4u/i))j=y;9(!i&&h.R[j])g=h.R[j];J 9(U.3o&&U.3o.3Z){9(j.1t(/4u/i))j="4u";j=j.1p(/([A-Z])/g,"-$1").2p();H d=U.3o.3Z(h,S);9(d&&!3n(h))g=d.4y(j);J{L(H a=h;a&&3n(a);a=a.12)2w.4w(a);L(a=0;a<2w.K;a++)9(3n(2w[a])){2k[a]=2w[a].R.19;2w[a].R.19="2Z"}g=j=="19"&&2k[2w.K-1]!=S?"2s":U.3o.3Z(h,S).4y(j)||"";L(a=0;a<2k.K;a++)9(2k[a]!=S)2w[a].R.19=2k[a]}9(j=="1r"&&g=="")g="1"}J 9(h.3Q){H f=j.1p(/\\-(\\w)/g,G(m,c){I c.27()});g=h.3Q[j]||h.3Q[f];9(!/^\\d+(2T)?$/i.14(g)&&/^\\d/.14(g)){H k=h.R.1S;H e=h.4v.1S;h.4v.1S=h.3Q.1S;h.R.1S=g||0;g=h.R.71+"2T";h.R.1S=k;h.4v.1S=e}}I g},4D:G(a,e){H r=[];e=e||U;E.N(a,G(i,d){9(!d)I;9(d.1c==4W)d=d.3s();9(1m d=="1M"){d=d.1p(/(<(\\w+)[^>]*?)\\/>/g,G(m,a,b){I b.1t(/^(70|6Z|6Y|9Q|4t|9N|9K|3a|9G|9E)$/i)?m:a+"></"+b+">"});H s=E.36(d).2p(),1s=e.5B("1s"),2x=[];H c=!s.1g("<9y")&&[1,"<24>","</24>"]||!s.1g("<9w")&&[1,"<6T>","</6T>"]||s.1t(/^<(9u|1K|9t|9r|9p)/)&&[1,"<1I>","</1I>"]||!s.1g("<4m")&&[2,"<1I><1K>","</1K></1I>"]||(!s.1g("<9m")||!s.1g("<9k"))&&[3,"<1I><1K><4m>","</4m></1K></1I>"]||!s.1g("<6Y")&&[2,"<1I><1K></1K><6L>","</6L></1I>"]||E.V.1h&&[1,"1s<1s>","</1s>"]||[0,"",""];1s.3O=c[1]+d+c[2];1W(c[0]--)1s=1s.5p;9(E.V.1h){9(!s.1g("<1I")&&s.1g("<1K")<0)2x=1s.1w&&1s.1w.3j;J 9(c[1]=="<1I>"&&s.1g("<1K")<0)2x=1s.3j;L(H n=2x.K-1;n>=0;--n)9(E.11(2x[n],"1K")&&!2x[n].3j.K)2x[n].12.3b(2x[n]);9(/^\\s/.14(d))1s.3d(e.6F(d.1t(/^\\s*/)[0]),1s.1w)}d=E.2h(1s.3j)}9(0===d.K&&(!E.11(d,"2Y")&&!E.11(d,"24")))I;9(d[0]==W||E.11(d,"2Y")||d.Y)r.1a(d);J r=E.1R(r,d)});I r},1x:G(c,d,a){H e=E.4a(c)?{}:E.5o;9(d=="26"&&E.V.1N)c.12.4Z;9(e[d]){9(a!=W)c[e[d]]=a;I c[e[d]]}J 9(E.V.1h&&d=="R")I E.1x(c.R,"9e",a);J 9(a==W&&E.V.1h&&E.11(c,"2Y")&&(d=="9d"||d=="9a"))I c.97(d).6x;J 9(c.37){9(a!=W){9(d=="O"&&E.11(c,"4t")&&c.12)6G"O 94 93\'t 92 91";c.90(d,a)}9(E.V.1h&&/6C|3k/.14(d)&&!E.4a(c))I c.4p(d,2);I c.4p(d)}J{9(d=="1r"&&E.V.1h){9(a!=W){c.69=1;c.1E=(c.1E||"").1p(/6O\\([^)]*\\)/,"")+(3I(a).3s()=="8S"?"":"6O(1r="+a*6A+")")}I c.1E?(3I(c.1E.1t(/1r=([^)]*)/)[1])/6A).3s():""}d=d.1p(/-([a-z])/8Q,G(z,b){I b.27()});9(a!=W)c[d]=a;I c[d]}},36:G(t){I(t||"").1p(/^\\s+|\\s+$/g,"")},2h:G(a){H r=[];9(1m a!="8P")L(H i=0,2c=a.K;i<2c;i++)r.1a(a[i]);J r=a.2J(0);I r},2A:G(b,a){L(H i=0,2c=a.K;i<2c;i++)9(a[i]==b)I i;I-1},1R:G(a,b){9(E.V.1h){L(H i=0;b[i];i++)9(b[i].1y!=8)a.1a(b[i])}J L(H i=0;b[i];i++)a.1a(b[i]);I a},4V:G(b){H r=[],2f={};2a{L(H i=0,6y=b.K;i<6y;i++){H a=E.M(b[i]);9(!2f[a]){2f[a]=Q;r.1a(b[i])}}}29(e){r=b}I r},2W:G(b,a,c){9(1m a=="1M")a=3w("P||G(a,i){I "+a+"}");H d=[];L(H i=0,4g=b.K;i<4g;i++)9(!c&&a(b[i],i)||c&&!a(b[i],i))d.1a(b[i]);I d},1X:G(c,b){9(1m b=="1M")b=3w("P||G(a){I "+b+"}");H d=[];L(H i=0,4g=c.K;i<4g;i++){H a=b(c[i],i);9(a!==S&&a!=W){9(a.1c!=1B)a=[a];d=d.8M(a)}}I d}});H v=8K.8I.2p();E.V={4s:(v.1t(/.+(?:8F|8E|8C|8B)[\\/: ]([\\d.]+)/)||[])[1],1N:/6w/.14(v),34:/34/.14(v),1h:/1h/.14(v)&&!/34/.14(v),35:/35/.14(v)&&!/(8z|6w)/.14(v)};H y=E.V.1h?"4h":"5h";E.1k({5g:!E.V.1h||U.8y=="8x",4h:E.V.1h?"4h":"5h",5o:{"L":"8w","8v":"1o","4u":y,5h:y,4h:y,3O:"3O",1o:"1o",1Q:"1Q",3c:"3c",2Q:"2Q",8u:"8t",26:"26",8s:"8r"}});E.N({1D:"a.12",8q:"15.4e(a,\'12\')",8p:"15.2I(a,2,\'2q\')",8n:"15.2I(a,2,\'4d\')",8l:"15.4e(a,\'2q\')",8k:"15.4e(a,\'4d\')",8j:"15.5d(a.12.1w,a)",8i:"15.5d(a.1w)",6q:"15.11(a,\'8h\')?a.8f||a.8e.U:15.2h(a.3j)"},G(i,n){E.1b[i]=G(a){H b=E.1X(6,n);9(a&&1m a=="1M")b=E.3m(a,b);I 6.2o(E.4V(b))}});E.N({5R:"3g",8c:"6j",3d:"6g",8b:"50",89:"6H"},G(i,n){E.1b[i]=G(){H a=1q;I 6.N(G(){L(H j=0,2c=a.K;j<2c;j++)E(a[j])[n](6)})}});E.N({5W:G(a){E.1x(6,a,"");6.53(a)},88:G(c){E.1o.1f(6,c)},87:G(c){E.1o.28(6,c)},86:G(c){E.1o[E.1o.3K(6,c)?"28":"1f"](6,c)},28:G(a){9(!a||E.1E(a,[6]).r.K){E.30(6);6.12.3b(6)}},4n:G(){E("*",6).N(G(){E.30(6)});1W(6.1w)6.3b(6.1w)}},G(i,n){E.1b[i]=G(){I 6.N(n,1q)}});E.N(["85","5Z"],G(i,a){H n=a.2p();E.1b[n]=G(h){I 6[0]==18?E.V.1N&&3y["84"+a]||E.5g&&38.33(U.2V["5a"+a],U.1G["5a"+a])||U.1G["5a"+a]:6[0]==U?38.33(U.1G["6n"+a],U.1G["6m"+a]):h==W?(6.K?E.17(6[0],n):S):6.17(n,h.1c==3X?h:h+"2T")}});H C=E.V.1N&&3x(E.V.4s)<83?"(?:[\\\\w*57-]|\\\\\\\\.)":"(?:[\\\\w\\82-\\81*57-]|\\\\\\\\.)",6k=1u 47("^>\\\\s*("+C+"+)"),6i=1u 47("^("+C+"+)(#)("+C+"+)"),6h=1u 47("^([#.]?)("+C+"*)");E.1k({55:{"":"m[2]==\'*\'||15.11(a,m[2])","#":"a.4p(\'22\')==m[2]",":":{80:"i<m[3]-0",7Z:"i>m[3]-0",2I:"m[3]-0==i",6E:"m[3]-0==i",3v:"i==0",3u:"i==r.K-1",6f:"i%2==0",6e:"i%2","3v-46":"a.12.4l(\'*\')[0]==a","3u-46":"15.2I(a.12.5p,1,\'4d\')==a","7X-46":"!15.2I(a.12.5p,2,\'4d\')",1D:"a.1w",4n:"!a.1w",7W:"(a.6s||a.7V||15(a).2g()||\'\').1g(m[3])>=0",3R:\'"1P"!=a.O&&15.17(a,"19")!="2s"&&15.17(a,"4C")!="1P"\',1P:\'"1P"==a.O||15.17(a,"19")=="2s"||15.17(a,"4C")=="1P"\',7U:"!a.3c",3c:"a.3c",2Q:"a.2Q",26:"a.26||15.1x(a,\'26\')",2g:"\'2g\'==a.O",4k:"\'4k\'==a.O",5j:"\'5j\'==a.O",54:"\'54\'==a.O",52:"\'52\'==a.O",51:"\'51\'==a.O",6d:"\'6d\'==a.O",6c:"\'6c\'==a.O",2r:\'"2r"==a.O||15.11(a,"2r")\',4t:"/4t|24|6b|2r/i.14(a.11)",3K:"15.1Y(m[3],a).K",7S:"/h\\\\d/i.14(a.11)",7R:"15.2W(15.32,G(1b){I a==1b.T;}).K"}},6a:[/^(\\[) *@?([\\w-]+) *([!*$^~=]*) *(\'?"?)(.*?)\\4 *\\]/,/^(:)([\\w-]+)\\("?\'?(.*?(\\(.*?\\))?[^(]*?)"?\'?\\)/,1u 47("^([:.#]*)("+C+"+)")],3m:G(a,c,b){H d,2b=[];1W(a&&a!=d){d=a;H f=E.1E(a,c,b);a=f.t.1p(/^\\s*,\\s*/,"");2b=b?c=f.r:E.1R(2b,f.r)}I 2b},1Y:G(t,o){9(1m t!="1M")I[t];9(o&&!o.1y)o=S;o=o||U;H d=[o],2f=[],3u;1W(t&&3u!=t){H r=[];3u=t;t=E.36(t);H l=P;H g=6k;H m=g.2S(t);9(m){H p=m[1].27();L(H i=0;d[i];i++)L(H c=d[i].1w;c;c=c.2q)9(c.1y==1&&(p=="*"||c.11.27()==p.27()))r.1a(c);d=r;t=t.1p(g,"");9(t.1g(" ")==0)6r;l=Q}J{g=/^([>+~])\\s*(\\w*)/i;9((m=g.2S(t))!=S){r=[];H p=m[2],1R={};m=m[1];L(H j=0,31=d.K;j<31;j++){H n=m=="~"||m=="+"?d[j].2q:d[j].1w;L(;n;n=n.2q)9(n.1y==1){H h=E.M(n);9(m=="~"&&1R[h])1T;9(!p||n.11.27()==p.27()){9(m=="~")1R[h]=Q;r.1a(n)}9(m=="+")1T}}d=r;t=E.36(t.1p(g,""));l=Q}}9(t&&!l){9(!t.1g(",")){9(o==d[0])d.44();2f=E.1R(2f,d);r=d=[o];t=" "+t.68(1,t.K)}J{H k=6i;H m=k.2S(t);9(m){m=[0,m[2],m[3],m[1]]}J{k=6h;m=k.2S(t)}m[2]=m[2].1p(/\\\\/g,"");H f=d[d.K-1];9(m[1]=="#"&&f&&f.3S&&!E.4a(f)){H q=f.3S(m[2]);9((E.V.1h||E.V.34)&&q&&1m q.22=="1M"&&q.22!=m[2])q=E(\'[@22="\'+m[2]+\'"]\',f)[0];d=r=q&&(!m[3]||E.11(q,m[3]))?[q]:[]}J{L(H i=0;d[i];i++){H a=m[1]=="#"&&m[3]?m[3]:m[1]!=""||m[0]==""?"*":m[2];9(a=="*"&&d[i].11.2p()=="5i")a="3a";r=E.1R(r,d[i].4l(a))}9(m[1]==".")r=E.4X(r,m[2]);9(m[1]=="#"){H e=[];L(H i=0;r[i];i++)9(r[i].4p("22")==m[2]){e=[r[i]];1T}r=e}d=r}t=t.1p(k,"")}}9(t){H b=E.1E(t,r);d=r=b.r;t=E.36(b.t)}}9(t)d=[];9(d&&o==d[0])d.44();2f=E.1R(2f,d);I 2f},4X:G(r,m,a){m=" "+m+" ";H c=[];L(H i=0;r[i];i++){H b=(" "+r[i].1o+" ").1g(m)>=0;9(!a&&b||a&&!b)c.1a(r[i])}I c},1E:G(t,r,h){H d;1W(t&&t!=d){d=t;H p=E.6a,m;L(H i=0;p[i];i++){m=p[i].2S(t);9(m){t=t.7O(m[0].K);m[2]=m[2].1p(/\\\\/g,"");1T}}9(!m)1T;9(m[1]==":"&&m[2]=="5V")r=E.1E(m[3],r,Q).r;J 9(m[1]==".")r=E.4X(r,m[2],h);J 9(m[1]=="["){H g=[],O=m[3];L(H i=0,31=r.K;i<31;i++){H a=r[i],z=a[E.5o[m[2]]||m[2]];9(z==S||/6C|3k|26/.14(m[2]))z=E.1x(a,m[2])||\'\';9((O==""&&!!z||O=="="&&z==m[5]||O=="!="&&z!=m[5]||O=="^="&&z&&!z.1g(m[5])||O=="$="&&z.68(z.K-m[5].K)==m[5]||(O=="*="||O=="~=")&&z.1g(m[5])>=0)^h)g.1a(a)}r=g}J 9(m[1]==":"&&m[2]=="2I-46"){H e={},g=[],14=/(\\d*)n\\+?(\\d*)/.2S(m[3]=="6f"&&"2n"||m[3]=="6e"&&"2n+1"||!/\\D/.14(m[3])&&"n+"+m[3]||m[3]),3v=(14[1]||1)-0,d=14[2]-0;L(H i=0,31=r.K;i<31;i++){H j=r[i],12=j.12,22=E.M(12);9(!e[22]){H c=1;L(H n=12.1w;n;n=n.2q)9(n.1y==1)n.4U=c++;e[22]=Q}H b=P;9(3v==1){9(d==0||j.4U==d)b=Q}J 9((j.4U+d)%3v==0)b=Q;9(b^h)g.1a(j)}r=g}J{H f=E.55[m[1]];9(1m f!="1M")f=E.55[m[1]][m[2]];f=3w("P||G(a,i){I "+f+"}");r=E.2W(r,f,h)}}I{r:r,t:t}},4e:G(b,c){H d=[];H a=b[c];1W(a&&a!=U){9(a.1y==1)d.1a(a);a=a[c]}I d},2I:G(a,e,c,b){e=e||1;H d=0;L(;a;a=a[c])9(a.1y==1&&++d==e)1T;I a},5d:G(n,a){H r=[];L(;n;n=n.2q){9(n.1y==1&&(!a||n!=a))r.1a(n)}I r}});E.1j={1f:G(g,e,c,h){9(E.V.1h&&g.4j!=W)g=18;9(!c.2u)c.2u=6.2u++;9(h!=W){H d=c;c=G(){I d.16(6,1q)};c.M=h;c.2u=d.2u}H i=e.2l(".");e=i[0];c.O=i[1];H b=E.M(g,"2P")||E.M(g,"2P",{});H f=E.M(g,"2t",G(){H a;9(1m E=="W"||E.1j.4T)I a;a=E.1j.2t.16(g,1q);I a});H j=b[e];9(!j){j=b[e]={};9(g.4S)g.4S(e,f,P);J g.7N("43"+e,f)}j[c.2u]=c;6.1Z[e]=Q},2u:1,1Z:{},28:G(d,c,b){H e=E.M(d,"2P"),2L,4I;9(1m c=="1M"){H a=c.2l(".");c=a[0]}9(e){9(c&&c.O){b=c.4Q;c=c.O}9(!c){L(c 1i e)6.28(d,c)}J 9(e[c]){9(b)2E e[c][b.2u];J L(b 1i e[c])9(!a[1]||e[c][b].O==a[1])2E e[c][b];L(2L 1i e[c])1T;9(!2L){9(d.4P)d.4P(c,E.M(d,"2t"),P);J d.7M("43"+c,E.M(d,"2t"));2L=S;2E e[c]}}L(2L 1i e)1T;9(!2L){E.30(d,"2P");E.30(d,"2t")}}},1F:G(d,b,e,c,f){b=E.2h(b||[]);9(!e){9(6.1Z[d])E("*").1f([18,U]).1F(d,b)}J{H a,2L,1b=E.1n(e[d]||S),4N=!b[0]||!b[0].2M;9(4N)b.4w(6.4M({O:d,2m:e}));b[0].O=d;9(E.1n(E.M(e,"2t")))a=E.M(e,"2t").16(e,b);9(!1b&&e["43"+d]&&e["43"+d].16(e,b)===P)a=P;9(4N)b.44();9(f&&f.16(e,b)===P)a=P;9(1b&&c!==P&&a!==P&&!(E.11(e,\'a\')&&d=="4L")){6.4T=Q;e[d]()}6.4T=P}I a},2t:G(d){H a;d=E.1j.4M(d||18.1j||{});H b=d.O.2l(".");d.O=b[0];H c=E.M(6,"2P")&&E.M(6,"2P")[d.O],3q=1B.3A.2J.2O(1q,1);3q.4w(d);L(H j 1i c){3q[0].4Q=c[j];3q[0].M=c[j].M;9(!b[1]||c[j].O==b[1]){H e=c[j].16(6,3q);9(a!==P)a=e;9(e===P){d.2M();d.3p()}}}9(E.V.1h)d.2m=d.2M=d.3p=d.4Q=d.M=S;I a},4M:G(c){H a=c;c=E.1k({},a);c.2M=G(){9(a.2M)a.2M();a.7L=P};c.3p=G(){9(a.3p)a.3p();a.7K=Q};9(!c.2m&&c.65)c.2m=c.65;9(E.V.1N&&c.2m.1y==3)c.2m=a.2m.12;9(!c.4K&&c.4J)c.4K=c.4J==c.2m?c.7H:c.4J;9(c.64==S&&c.63!=S){H e=U.2V,b=U.1G;c.64=c.63+(e&&e.2R||b.2R||0);c.7E=c.7D+(e&&e.2B||b.2B||0)}9(!c.3Y&&(c.61||c.60))c.3Y=c.61||c.60;9(!c.5F&&c.5D)c.5F=c.5D;9(!c.3Y&&c.2r)c.3Y=(c.2r&1?1:(c.2r&2?3:(c.2r&4?2:0)));I c}};E.1b.1k({3W:G(c,a,b){I c=="5Y"?6.2G(c,a,b):6.N(G(){E.1j.1f(6,c,b||a,b&&a)})},2G:G(d,b,c){I 6.N(G(){E.1j.1f(6,d,G(a){E(6).5X(a);I(c||b).16(6,1q)},c&&b)})},5X:G(a,b){I 6.N(G(){E.1j.28(6,a,b)})},1F:G(c,a,b){I 6.N(G(){E.1j.1F(c,a,6,Q,b)})},7x:G(c,a,b){9(6[0])I E.1j.1F(c,a,6[0],P,b)},25:G(){H a=1q;I 6.4L(G(e){6.4H=0==6.4H?1:0;e.2M();I a[6.4H].16(6,[e])||P})},7v:G(f,g){G 4G(e){H p=e.4K;1W(p&&p!=6)2a{p=p.12}29(e){p=6};9(p==6)I P;I(e.O=="4x"?f:g).16(6,[e])}I 6.4x(4G).5U(4G)},2d:G(f){5T();9(E.3T)f.16(U,[E]);J E.3l.1a(G(){I f.16(6,[E])});I 6}});E.1k({3T:P,3l:[],2d:G(){9(!E.3T){E.3T=Q;9(E.3l){E.N(E.3l,G(){6.16(U)});E.3l=S}9(E.V.35||E.V.34)U.4P("5S",E.2d,P);9(!18.7t.K)E(18).39(G(){E("#4E").28()})}}});E.N(("7s,7r,39,7q,6n,5Y,4L,7p,"+"7n,7m,7l,4x,5U,7k,24,"+"51,7j,7i,7h,3U").2l(","),G(i,o){E.1b[o]=G(f){I f?6.3W(o,f):6.1F(o)}});H x=P;G 5T(){9(x)I;x=Q;9(E.V.35||E.V.34)U.4S("5S",E.2d,P);J 9(E.V.1h){U.7f("<7d"+"7y 22=4E 7z=Q "+"3k=//:><\\/1J>");H a=U.3S("4E");9(a)a.62=G(){9(6.2C!="1l")I;E.2d()};a=S}J 9(E.V.1N)E.4B=4j(G(){9(U.2C=="5Q"||U.2C=="1l"){4A(E.4B);E.4B=S;E.2d()}},10);E.1j.1f(18,"39",E.2d)}E.1b.1k({39:G(g,d,c){9(E.1n(g))I 6.3W("39",g);H e=g.1g(" ");9(e>=0){H i=g.2J(e,g.K);g=g.2J(0,e)}c=c||G(){};H f="4z";9(d)9(E.1n(d)){c=d;d=S}J{d=E.3a(d);f="5P"}H h=6;E.3G({1d:g,O:f,M:d,1l:G(a,b){9(b=="1C"||b=="5O")h.4o(i?E("<1s/>").3g(a.40.1p(/<1J(.|\\s)*?\\/1J>/g,"")).1Y(i):a.40);56(G(){h.N(c,[a.40,b,a])},13)}});I 6},7a:G(){I E.3a(6.5M())},5M:G(){I 6.1X(G(){I E.11(6,"2Y")?E.2h(6.79):6}).1E(G(){I 6.2H&&!6.3c&&(6.2Q||/24|6b/i.14(6.11)||/2g|1P|52/i.14(6.O))}).1X(G(i,c){H b=E(6).3i();I b==S?S:b.1c==1B?E.1X(b,G(a,i){I{2H:c.2H,1Q:a}}):{2H:c.2H,1Q:b}}).21()}});E.N("5L,5K,6t,5J,5I,5H".2l(","),G(i,o){E.1b[o]=G(f){I 6.3W(o,f)}});H B=(1u 3D).3B();E.1k({21:G(d,b,a,c){9(E.1n(b)){a=b;b=S}I E.3G({O:"4z",1d:d,M:b,1C:a,1V:c})},78:G(b,a){I E.21(b,S,a,"1J")},77:G(c,b,a){I E.21(c,b,a,"45")},76:G(d,b,a,c){9(E.1n(b)){a=b;b={}}I E.3G({O:"5P",1d:d,M:b,1C:a,1V:c})},75:G(a){E.1k(E.59,a)},59:{1Z:Q,O:"4z",2z:0,5G:"74/x-73-2Y-72",6o:Q,3e:Q,M:S},49:{},3G:G(s){H f,2y=/=(\\?|%3F)/g,1v,M;s=E.1k(Q,s,E.1k(Q,{},E.59,s));9(s.M&&s.6o&&1m s.M!="1M")s.M=E.3a(s.M);9(s.1V=="4b"){9(s.O.2p()=="21"){9(!s.1d.1t(2y))s.1d+=(s.1d.1t(/\\?/)?"&":"?")+(s.4b||"5E")+"=?"}J 9(!s.M||!s.M.1t(2y))s.M=(s.M?s.M+"&":"")+(s.4b||"5E")+"=?";s.1V="45"}9(s.1V=="45"&&(s.M&&s.M.1t(2y)||s.1d.1t(2y))){f="4b"+B++;9(s.M)s.M=s.M.1p(2y,"="+f);s.1d=s.1d.1p(2y,"="+f);s.1V="1J";18[f]=G(a){M=a;1C();1l();18[f]=W;2a{2E 18[f]}29(e){}}}9(s.1V=="1J"&&s.1L==S)s.1L=P;9(s.1L===P&&s.O.2p()=="21")s.1d+=(s.1d.1t(/\\?/)?"&":"?")+"57="+(1u 3D()).3B();9(s.M&&s.O.2p()=="21"){s.1d+=(s.1d.1t(/\\?/)?"&":"?")+s.M;s.M=S}9(s.1Z&&!E.5b++)E.1j.1F("5L");9(!s.1d.1g("8g")&&s.1V=="1J"){H h=U.4l("9U")[0];H g=U.5B("1J");g.3k=s.1d;9(!f&&(s.1C||s.1l)){H j=P;g.9R=g.62=G(){9(!j&&(!6.2C||6.2C=="5Q"||6.2C=="1l")){j=Q;1C();1l();h.3b(g)}}}h.58(g);I}H k=P;H i=18.6X?1u 6X("9P.9O"):1u 6W();i.9M(s.O,s.1d,s.3e);9(s.M)i.5C("9J-9I",s.5G);9(s.5y)i.5C("9H-5x-9F",E.49[s.1d]||"9D, 9C 9B 9A 5v:5v:5v 9z");i.5C("X-9x-9v","6W");9(s.6U)s.6U(i);9(s.1Z)E.1j.1F("5H",[i,s]);H c=G(a){9(!k&&i&&(i.2C==4||a=="2z")){k=Q;9(d){4A(d);d=S}1v=a=="2z"&&"2z"||!E.6S(i)&&"3U"||s.5y&&E.6R(i,s.1d)&&"5O"||"1C";9(1v=="1C"){2a{M=E.6Q(i,s.1V)}29(e){1v="5k"}}9(1v=="1C"){H b;2a{b=i.5s("6P-5x")}29(e){}9(s.5y&&b)E.49[s.1d]=b;9(!f)1C()}J E.5r(s,i,1v);1l();9(s.3e)i=S}};9(s.3e){H d=4j(c,13);9(s.2z>0)56(G(){9(i){i.9q();9(!k)c("2z")}},s.2z)}2a{i.9o(s.M)}29(e){E.5r(s,i,S,e)}9(!s.3e)c();I i;G 1C(){9(s.1C)s.1C(M,1v);9(s.1Z)E.1j.1F("5I",[i,s])}G 1l(){9(s.1l)s.1l(i,1v);9(s.1Z)E.1j.1F("6t",[i,s]);9(s.1Z&&!--E.5b)E.1j.1F("5K")}},5r:G(s,a,b,e){9(s.3U)s.3U(a,b,e);9(s.1Z)E.1j.1F("5J",[a,s,e])},5b:0,6S:G(r){2a{I!r.1v&&9n.9l=="54:"||(r.1v>=6N&&r.1v<9j)||r.1v==6M||E.V.1N&&r.1v==W}29(e){}I P},6R:G(a,c){2a{H b=a.5s("6P-5x");I a.1v==6M||b==E.49[c]||E.V.1N&&a.1v==W}29(e){}I P},6Q:G(r,b){H c=r.5s("9i-O");H d=b=="6K"||!b&&c&&c.1g("6K")>=0;H a=d?r.9g:r.40;9(d&&a.2V.37=="5k")6G"5k";9(b=="1J")E.5f(a);9(b=="45")a=3w("("+a+")");I a},3a:G(a){H s=[];9(a.1c==1B||a.4c)E.N(a,G(){s.1a(3f(6.2H)+"="+3f(6.1Q))});J L(H j 1i a)9(a[j]&&a[j].1c==1B)E.N(a[j],G(){s.1a(3f(j)+"="+3f(6))});J s.1a(3f(j)+"="+3f(a[j]));I s.66("&").1p(/%20/g,"+")}});E.1b.1k({1A:G(b,a){I b?6.1U({1H:"1A",2N:"1A",1r:"1A"},b,a):6.1E(":1P").N(G(){6.R.19=6.3h?6.3h:"";9(E.17(6,"19")=="2s")6.R.19="2Z"}).2D()},1z:G(b,a){I b?6.1U({1H:"1z",2N:"1z",1r:"1z"},b,a):6.1E(":3R").N(G(){6.3h=6.3h||E.17(6,"19");9(6.3h=="2s")6.3h="2Z";6.R.19="2s"}).2D()},6J:E.1b.25,25:G(a,b){I E.1n(a)&&E.1n(b)?6.6J(a,b):a?6.1U({1H:"25",2N:"25",1r:"25"},a,b):6.N(G(){E(6)[E(6).3t(":1P")?"1A":"1z"]()})},9c:G(b,a){I 6.1U({1H:"1A"},b,a)},9b:G(b,a){I 6.1U({1H:"1z"},b,a)},99:G(b,a){I 6.1U({1H:"25"},b,a)},98:G(b,a){I 6.1U({1r:"1A"},b,a)},96:G(b,a){I 6.1U({1r:"1z"},b,a)},95:G(c,a,b){I 6.1U({1r:a},c,b)},1U:G(k,i,h,g){H j=E.6D(i,h,g);I 6[j.3L===P?"N":"3L"](G(){j=E.1k({},j);H f=E(6).3t(":1P"),3y=6;L(H p 1i k){9(k[p]=="1z"&&f||k[p]=="1A"&&!f)I E.1n(j.1l)&&j.1l.16(6);9(p=="1H"||p=="2N"){j.19=E.17(6,"19");j.2U=6.R.2U}}9(j.2U!=S)6.R.2U="1P";j.3M=E.1k({},k);E.N(k,G(c,a){H e=1u E.2j(3y,j,c);9(/25|1A|1z/.14(a))e[a=="25"?f?"1A":"1z":a](k);J{H b=a.3s().1t(/^([+-]=)?([\\d+-.]+)(.*)$/),1O=e.2b(Q)||0;9(b){H d=3I(b[2]),2i=b[3]||"2T";9(2i!="2T"){3y.R[c]=(d||1)+2i;1O=((d||1)/e.2b(Q))*1O;3y.R[c]=1O+2i}9(b[1])d=((b[1]=="-="?-1:1)*d)+1O;e.3N(1O,d,2i)}J e.3N(1O,a,"")}});I Q})},3L:G(a,b){9(E.1n(a)){b=a;a="2j"}9(!a||(1m a=="1M"&&!b))I A(6[0],a);I 6.N(G(){9(b.1c==1B)A(6,a,b);J{A(6,a).1a(b);9(A(6,a).K==1)b.16(6)}})},9f:G(){H a=E.32;I 6.N(G(){L(H i=0;i<a.K;i++)9(a[i].T==6)a.6I(i--,1)}).5n()}});H A=G(b,c,a){9(!b)I;H q=E.M(b,c+"3L");9(!q||a)q=E.M(b,c+"3L",a?E.2h(a):[]);I q};E.1b.5n=G(a){a=a||"2j";I 6.N(G(){H q=A(6,a);q.44();9(q.K)q[0].16(6)})};E.1k({6D:G(b,a,c){H d=b&&b.1c==8Z?b:{1l:c||!c&&a||E.1n(b)&&b,2e:b,3J:c&&a||a&&a.1c!=8Y&&a};d.2e=(d.2e&&d.2e.1c==4W?d.2e:{8X:8W,8V:6N}[d.2e])||8T;d.3r=d.1l;d.1l=G(){E(6).5n();9(E.1n(d.3r))d.3r.16(6)};I d},3J:{6B:G(p,n,b,a){I b+a*p},5q:G(p,n,b,a){I((-38.9s(p*38.8R)/2)+0.5)*a+b}},32:[],2j:G(b,c,a){6.Y=c;6.T=b;6.1e=a;9(!c.3P)c.3P={}}});E.2j.3A={4r:G(){9(6.Y.2F)6.Y.2F.16(6.T,[6.2v,6]);(E.2j.2F[6.1e]||E.2j.2F.6z)(6);9(6.1e=="1H"||6.1e=="2N")6.T.R.19="2Z"},2b:G(a){9(6.T[6.1e]!=S&&6.T.R[6.1e]==S)I 6.T[6.1e];H r=3I(E.3C(6.T,6.1e,a));I r&&r>-8O?r:3I(E.17(6.T,6.1e))||0},3N:G(c,b,e){6.5u=(1u 3D()).3B();6.1O=c;6.2D=b;6.2i=e||6.2i||"2T";6.2v=6.1O;6.4q=6.4i=0;6.4r();H f=6;G t(){I f.2F()}t.T=6.T;E.32.1a(t);9(E.32.K==1){H d=4j(G(){H a=E.32;L(H i=0;i<a.K;i++)9(!a[i]())a.6I(i--,1);9(!a.K)4A(d)},13)}},1A:G(){6.Y.3P[6.1e]=E.1x(6.T.R,6.1e);6.Y.1A=Q;6.3N(0,6.2b());9(6.1e=="2N"||6.1e=="1H")6.T.R[6.1e]="8N";E(6.T).1A()},1z:G(){6.Y.3P[6.1e]=E.1x(6.T.R,6.1e);6.Y.1z=Q;6.3N(6.2b(),0)},2F:G(){H t=(1u 3D()).3B();9(t>6.Y.2e+6.5u){6.2v=6.2D;6.4q=6.4i=1;6.4r();6.Y.3M[6.1e]=Q;H a=Q;L(H i 1i 6.Y.3M)9(6.Y.3M[i]!==Q)a=P;9(a){9(6.Y.19!=S){6.T.R.2U=6.Y.2U;6.T.R.19=6.Y.19;9(E.17(6.T,"19")=="2s")6.T.R.19="2Z"}9(6.Y.1z)6.T.R.19="2s";9(6.Y.1z||6.Y.1A)L(H p 1i 6.Y.3M)E.1x(6.T.R,p,6.Y.3P[p])}9(a&&E.1n(6.Y.1l))6.Y.1l.16(6.T);I P}J{H n=t-6.5u;6.4i=n/6.Y.2e;6.4q=E.3J[6.Y.3J||(E.3J.5q?"5q":"6B")](6.4i,n,0,1,6.Y.2e);6.2v=6.1O+((6.2D-6.1O)*6.4q);6.4r()}I Q}};E.2j.2F={2R:G(a){a.T.2R=a.2v},2B:G(a){a.T.2B=a.2v},1r:G(a){E.1x(a.T.R,"1r",a.2v)},6z:G(a){a.T.R[a.1e]=a.2v+a.2i}};E.1b.6m=G(){H c=0,3E=0,T=6[0],5t;9(T)8L(E.V){H b=E.17(T,"2X")=="4F",1D=T.12,23=T.23,2K=T.3H,4f=1N&&3x(4s)<8J;9(T.6V){5w=T.6V();1f(5w.1S+38.33(2K.2V.2R,2K.1G.2R),5w.3E+38.33(2K.2V.2B,2K.1G.2B));9(1h){H d=E("4o").17("8H");d=(d=="8G"||E.5g&&3x(4s)>=7)&&2||d;1f(-d,-d)}}J{1f(T.5l,T.5z);1W(23){1f(23.5l,23.5z);9(35&&/^t[d|h]$/i.14(1D.37)||!4f)d(23);9(4f&&!b&&E.17(23,"2X")=="4F")b=Q;23=23.23}1W(1D.37&&!/^1G|4o$/i.14(1D.37)){9(!/^8D|1I-9S.*$/i.14(E.17(1D,"19")))1f(-1D.2R,-1D.2B);9(35&&E.17(1D,"2U")!="3R")d(1D);1D=1D.12}9(4f&&b)1f(-2K.1G.5l,-2K.1G.5z)}5t={3E:3E,1S:c}}I 5t;G d(a){1f(E.17(a,"9T"),E.17(a,"8A"))}G 1f(l,t){c+=3x(l)||0;3E+=3x(t)||0}}})();',62,616,'||||||this|||if|||||||||||||||||||||||||||||||||function|var|return|else|length|for|data|each|type|false|true|style|null|elem|document|browser|undefined||options|||nodeName|parentNode||test|jQuery|apply|css|window|display|push|fn|constructor|url|prop|add|indexOf|msie|in|event|extend|complete|typeof|isFunction|className|replace|arguments|opacity|div|match|new|status|firstChild|attr|nodeType|hide|show|Array|success|parent|filter|trigger|body|height|table|script|tbody|cache|string|safari|start|hidden|value|merge|left|break|animate|dataType|while|map|find|global||get|id|offsetParent|select|toggle|selected|toUpperCase|remove|catch|try|cur|al|ready|duration|done|text|makeArray|unit|fx|swap|split|target||pushStack|toLowerCase|nextSibling|button|none|handle|guid|now|stack|tb|jsre|timeout|inArray|scrollTop|readyState|end|delete|step|one|name|nth|slice|doc|ret|preventDefault|width|call|events|checked|scrollLeft|exec|px|overflow|documentElement|grep|position|form|block|removeData|rl|timers|max|opera|mozilla|trim|tagName|Math|load|param|removeChild|disabled|insertBefore|async|encodeURIComponent|append|oldblock|val|childNodes|src|readyList|multiFilter|color|defaultView|stopPropagation|args|old|toString|is|last|first|eval|parseInt|self|domManip|prototype|getTime|curCSS|Date|top||ajax|ownerDocument|parseFloat|easing|has|queue|curAnim|custom|innerHTML|orig|currentStyle|visible|getElementById|isReady|error|static|bind|String|which|getComputedStyle|responseText|oWidth|oHeight|on|shift|json|child|RegExp|ol|lastModified|isXMLDoc|jsonp|jquery|previousSibling|dir|safari2|el|styleFloat|state|setInterval|radio|getElementsByTagName|tr|empty|html|getAttribute|pos|update|version|input|float|runtimeStyle|unshift|mouseover|getPropertyValue|GET|clearInterval|safariTimer|visibility|clean|__ie_init|absolute|handleHover|lastToggle|index|fromElement|relatedTarget|click|fix|evt|andSelf|removeEventListener|handler|cloneNode|addEventListener|triggered|nodeIndex|unique|Number|classFilter|prevObject|selectedIndex|after|submit|password|removeAttribute|file|expr|setTimeout|_|appendChild|ajaxSettings|client|active|win|sibling|deep|globalEval|boxModel|cssFloat|object|checkbox|parsererror|offsetLeft|wrapAll|dequeue|props|lastChild|swing|handleError|getResponseHeader|results|startTime|00|box|Modified|ifModified|offsetTop|evalScript|createElement|setRequestHeader|ctrlKey|callback|metaKey|contentType|ajaxSend|ajaxSuccess|ajaxError|ajaxStop|ajaxStart|serializeArray|init|notmodified|POST|loaded|appendTo|DOMContentLoaded|bindReady|mouseout|not|removeAttr|unbind|unload|Width|keyCode|charCode|onreadystatechange|clientX|pageX|srcElement|join|outerHTML|substr|zoom|parse|textarea|reset|image|odd|even|before|quickClass|quickID|prepend|quickChild|execScript|offset|scroll|processData|uuid|contents|continue|textContent|ajaxComplete|clone|setArray|webkit|nodeValue|fl|_default|100|linear|href|speed|eq|createTextNode|throw|replaceWith|splice|_toggle|xml|colgroup|304|200|alpha|Last|httpData|httpNotModified|httpSuccess|fieldset|beforeSend|getBoundingClientRect|XMLHttpRequest|ActiveXObject|col|br|abbr|pixelLeft|urlencoded|www|application|ajaxSetup|post|getJSON|getScript|elements|serialize|clientWidth|hasClass|scr|clientHeight|write|relative|keyup|keypress|keydown|change|mousemove|mouseup|mousedown|right|dblclick|resize|focus|blur|frames|instanceof|hover|offsetWidth|triggerHandler|ipt|defer|offsetHeight|border|padding|clientY|pageY|Left|Right|toElement|Bottom|Top|cancelBubble|returnValue|detachEvent|attachEvent|substring|line|weight|animated|header|font|enabled|innerText|contains|only|size|gt|lt|uFFFF|u0128|417|inner|Height|toggleClass|removeClass|addClass|replaceAll|noConflict|insertAfter|prependTo|wrap|contentWindow|contentDocument|http|iframe|children|siblings|prevAll|nextAll|wrapInner|prev|Boolean|next|parents|maxLength|maxlength|readOnly|readonly|class|htmlFor|CSS1Compat|compatMode|compatible|borderTopWidth|ie|ra|inline|it|rv|medium|borderWidth|userAgent|522|navigator|with|concat|1px|10000|array|ig|PI|NaN|400|reverse|fast|600|slow|Function|Object|setAttribute|changed|be|can|property|fadeTo|fadeOut|getAttributeNode|fadeIn|slideToggle|method|slideUp|slideDown|action|cssText|stop|responseXML|option|content|300|th|protocol|td|location|send|cap|abort|colg|cos|tfoot|thead|With|leg|Requested|opt|GMT|1970|Jan|01|Thu|area|Since|hr|If|Type|Content|meta|specified|open|link|XMLHTTP|Microsoft|img|onload|row|borderLeftWidth|head|attributes'.split('|'),0,{}))
\ No newline at end of file
More information about the Mapbender_commits mailing list
