[Mapbender-commits] r2161 - branches/2.4.5/http/php
svn_mapbender at osgeo.org
Mon Mar 3 09:29:08 EST 2008
Author: greq
Date: 2008-03-03 09:29:08 -0500 (Mon, 03 Mar 2008)
New Revision: 2161
Removed:
branches/2.4.5/http/php/download.php
no more needed, function direct in php-file
Deleted: branches/2.4.5/http/php/download.php
--- branches/2.4.5/http/php/download.php 2008-03-03 14:24:20 UTC (rev 2160)
+++ branches/2.4.5/http/php/download.php 2008-03-03 14:29:08 UTC (rev 2161)
@@ -1,72 +0,0 @@
-<?php
-#$Id$
-# http://www.mapbender.org/ExportMapimage
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-ob_start();
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-$download = array();
-$download["dir"] = TMPDIR;
-$download["file"] = trim($_REQUEST["download"]);
-if(!(bool)$download["file"]) {
- die("No filename given.");
-if((int)strpos($download["file"],"..") !== 0) {
- die("Illegal filename given.");
-$img = $download["dir"]."/".$download["file"];
-if(!file_exists($img) || !is_readable($img)) {
- die("An error occured.");
-$now_date = date("Ymd_His");
-switch(substr($download["file"],-4)) {
- case ".png":
- $filename = "map_export__".$now_date.".png";
- header('Content-Type: image/png');
- break;
- case "jpeg":
- $filename = "map_export__".$now_date.".jpeg";
- header('Content-Type: image/jpeg');
- break;
- case ".tif";
- $filename = "map_export__".$now_date.".tif";
- header('Content-Type: image/tif');
- break;
- default:
-header("Content-Disposition: attachment; filename=\"".$filename."\"");
-readfile(implode($download));
\ No newline at end of file
More information about the Mapbender_commits
