[Mapbender-commits] r2175 - branches/2.4.5/http/php
svn_mapbender at osgeo.org
Wed Mar 5 10:29:03 EST 2008
Author: christoph
Date: 2008-03-05 10:29:03 -0500 (Wed, 05 Mar 2008)
New Revision: 2175
branches/2.4.5/http/php/mb_validatePermission.php
branches/2.4.5/http/php/mb_validateSession.php
added more security checks
set some global vars
Modified: branches/2.4.5/http/php/mb_validatePermission.php
--- branches/2.4.5/http/php/mb_validatePermission.php 2008-03-05 15:27:48 UTC (rev 2174)
+++ branches/2.4.5/http/php/mb_validatePermission.php 2008-03-05 15:29:03 UTC (rev 2175)
@@ -20,12 +20,65 @@
require(dirname(__FILE__)."/../php/mb_validateSession.php");
require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$n = new administration();
-$m = $n->getModulPermission($_SESSION["mb_user_id"],$_REQUEST["guiID"],$_REQUEST["elementID"]) ||
- $n->getModulPermission($_SESSION["mb_user_id"],$_REQUEST["gui_id"],$_REQUEST["elementID"]);
-if($m == false){
+$admin = new administration();
+// check if GUI id and element id are set
+$msg = "missing in " . $_SERVER["PHP_SELF"];
+if (!isset($gui_id)) {
+ $e = new mb_exception("GUI id " . $msg);
+ die();
+if (!isset($e_id)) {
+ $e = new mb_exception("Element id " . $msg);
+ die();
+// check if the user is allowed to access this module
+$isAllowed = $admin->getModulPermission($_SESSION["mb_user_id"], $gui_id, $e_id);
+// if the module is an iframe, also check if the filename matches the
+// filename of the GUI element with the given e_id
+// (if PHP_SELF is "map.php", we trust the script.)
+if (!preg_match("/^.*\/javascripts\/map\.php$/", $_SERVER["PHP_SELF"])) {
+ $isCorrectScript = true;
+ $sql = "SELECT e_element FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
+ $v = array($e_id, $gui_id);
+ $t = array("s", "s");
+ $res = db_prep_query($sql, $v, $t);
+ while ($row = db_fetch_array($res)) {
+ if (!$admin->checkModulePermission_new($_SESSION["mb_user_id"], $_SERVER["PHP_SELF"], $row["e_element"])) {
+ $isCorrectScript = false;
+ break;
+// $e = new mb_notice($e_id . ": isAllowed: " . $isAllowed . ", isCorrectScript: " . $isCorrectScript);
+ $isAllowed = $isAllowed && $isCorrectScript;
+// If the user is not allowed to access the module, return to the login screen.
+if (!$isAllowed) {
+ $msg = "mb_validatePermission.php: User " . $_SESSION["mb_user_id"] . " is not allowed to access ".
+ "module " . $e_id;
+ $e = new mb_exception($msg);
header("Location: ".LOGIN);
- exit;
die();
+$e = new mb_notice("mb_validatePermission.php: checking file " . $_SERVER["PHP_SELF"] . "...permission valid.");
+// delete global variables
+unset($admin, $isAllowed, $e, $isCorrectScript, $msg, $myGuisArray);
\ No newline at end of file
Modified: branches/2.4.5/http/php/mb_validateSession.php
--- branches/2.4.5/http/php/mb_validateSession.php 2008-03-05 15:27:48 UTC (rev 2174)
+++ branches/2.4.5/http/php/mb_validateSession.php 2008-03-05 15:29:03 UTC (rev 2175)
@@ -19,22 +19,72 @@
session_start();
require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
+require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
-$urlParameters = SID . "&guiID=" . $_REQUEST["guiID"] . "&elementID=" . $_REQUEST["elementID"];
-$self = $PHP_SELF . "?" . $urlParameters;
+// establish database connection
+$con = db_connect($DBSERVER, $OWNER, $PW);
+db_select_db(DB, $con);
-if(!isset($_SESSION["mb_user_id"]) || !isset($_SESSION["mb_user_ip"]) || $_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']){
- header("Location: ".LOGIN);
- exit;
- die();
+$e = new mb_notice("mb_validateSession.php: checking file " . $_SERVER["PHP_SELF"]);
+// check if user data is valid; if not, return to login screen
+if (!isset($_SESSION["mb_user_id"]) ||
+ !isset($_SESSION["mb_user_ip"]) ||
+ $_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']) {
+ $e = new mb_exception("mb_validateSession.php: Invalid user: " . $_SESSION["mb_user_id"]);
+ header("Location: " . LOGIN);
+ die();
-if(isset($_REQUEST["gui_id"]) || isset($_REQUEST["guiID"])){
- if( !in_array($_REQUEST["gui_id"],$_SESSION["mb_user_guis"]) &&
- !in_array($_REQUEST["guiID"],$_SESSION["mb_user_guis"])){
- exit;
- die();
+// set the global var gui_id
+if (!$gui_id) {
+ $e = new mb_notice("gui id not set");
+ if ($_REQUEST["guiID"]) {
+ $e = new mb_notice("gui id set to guiID");
+ $gui_id = $_REQUEST["guiID"];
+ elseif ($_REQUEST["gui_id"]) {
+ $e = new mb_notice("gui id set to gui_id");
+ $gui_id = $_REQUEST["gui_id"];
+ else {
+ $e = new mb_notice("mb_validateSession.php: gui_id not set in script: " . $_SERVER["PHP_SELF"]);
+// set the global var e_id
+if (!$e_id) {
+ if (isset($_REQUEST["elementID"])) {
+ $e_id = $_REQUEST["elementID"];
+ elseif (isset($_REQUEST["e_id"])) {
+ $e_id = $_REQUEST["e_id"];
+ else {
+ $e = new mb_notice("mb_validateSession.php: e_id not set in script: " . $_SERVER["PHP_SELF"]);
+// set variables used for form targets or links
+$urlParameters = SID;
+if (isset($gui_id)) {
+ $urlParameters .= "&guiID=" . $gui_id;
+if (isset($e_id)) {
+ $urlParameters .= "&elementID=" . $e_id;
+$self = $_SERVER["PHP_SELF"] . "?" . $urlParameters;
+$e = new mb_notice("mb_validateSession.php: GUI: " . $gui_id . ", checking file " . $_SERVER["PHP_SELF"] . "...session valid.");
More information about the Mapbender_commits
