[Mapbender-commits] r2177 - branches/2.4.5/http/classes
svn_mapbender at osgeo.org
Wed Mar 5 10:37:16 EST 2008
Author: christoph
Date: 2008-03-05 10:37:16 -0500 (Wed, 05 Mar 2008)
New Revision: 2177
Removed:
branches/2.4.5/http/classes/class_weldMaps2Image.php
feature freeze, rejected
Deleted: branches/2.4.5/http/classes/class_weldMaps2Image.php
--- branches/2.4.5/http/classes/class_weldMaps2Image.php 2008-03-05 15:36:30 UTC (rev 2176)
+++ branches/2.4.5/http/classes/class_weldMaps2Image.php 2008-03-05 15:37:16 UTC (rev 2177)
@@ -1,211 +0,0 @@
-<?php
-# $Id$
-# http://www.mapbender.org/
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/class_stripRequest.php");
-require_once(dirname(__FILE__)."/class_mb_exception.php");
-require_once(dirname(__FILE__)."/class_connector.php");
-include_once(dirname(__FILE__)."/../../conf/mapbender.conf");
- * Class generats Images (jpegs/pngs/geotiff)
- * of Image-URL-Array
- * For geotiff export gdal is necessary
- class weldMaps2Image{
- var $urls = array();
- var $filename;
- function weldMaps2Image($urls, $array_file){
- $this->urls = $urls;
- $this->array_file = $array_file;
- function getImage($imageTyp_imp, $outputKind=''){
- $imageTyp="";
- $imageTyp=$imageTyp_imp;
- if($imageTyp=='jpg'){
- $imageTyp='jpeg';
- if(!$this->urls || $this->urls == ""){
- $e = new mb_exception("weldMaps2Image: no maprequests delivered");
- $obj1 = new stripRequest($this->urls[0]);
- $width = $obj1->get("width");
- $height = $obj1->get("height");
- $wms_srs = $obj1->get("srs");
- $wms_bbox = $obj1->get("bbox");
- $wms_format = $obj1->getFormat();
- $image = imagecreatetruecolor($width, $height );
- $white = ImageColorAllocate($image,255,255,255);
- ImageFilledRectangle($image,0,0,$width,$height,$white);
- for($i=0; $i<count($this->urls); $i++){
- $obj = new stripRequest($this->urls[$i]);
- if($imageTyp=='geotiff'){
- $this->urls[$i] = $obj->setFormat($wms_format);
- } else {
- $this->urls[$i] = $obj->setFormat($imageTyp);
- $this->urls[$i] = $obj->encodeGET();
- $img = $this->loadImage($this->urls[$i]);
- if($img != false){
- imagecopy($image, $img, 0, 0, 0, 0, $width, $height);
- else{
- $e = new mb_exception("weldMaps2Image: unable to load image: " . $this->urls[$i]);
- $filename = $this->array_file['dir']."/";
- $timestamp = time();
- $filenameOnly =$this->array_file['filename'].md5($timestamp);
- if($imageTyp=='png'){
- $filenameOnly .= '.png';
- $filename .= $filenameOnly;
- imagepng($image, $filename);
- $this->downloadLink($filenameOnly);
- } else if($imageTyp=='jpeg'){
- $filenameOnly .= '.jpeg';
- imagejpeg($image, $filename);
- } else if($imageTyp=='geotiff'){
- $filenameOnly .= '.'.$wms_format;
- if ($wms_format=='png'){
- } else if ($wms_format=='jpeg'){
- } else {
- $e = new mb_exception("weldMaps2Image: unable to generate temp-Image for getiff: " . $filename);
- // gdal_translate...
- $wms_bbox = str_replace(',', ' ', $wms_bbox);
- $filename_tif = str_replace($wms_format, 'tif', $filenameOnly);
- $tmp_dir = $this->array_file['dir'];
- $cmd = "gdal_translate -a_srs ".$wms_srs." -a_ullr ".$wms_bbox." ".$tmp_dir.$filenameOnly." ".$tmp_dir.$filename_tif;
- exec($cmd);
- echo "<br>";
- }else {
- function loadImage ($imgurl) {
- $x = new connector($imgurl);
- $im = @imagecreatefromstring($x->file);
- if(!$im){
- $im = false;
- $e = new mb_exception("weldMaps2Image: unable to load image: ".$imgurl);
- return $im;
- function downloadLink($downloadFilename){
- $dwDir = $this->array_file['dir']."/";
- $dwFilename = $downloadFilename;
- if(!(bool)$dwFilename) {
- die("No filename given.");
- if((int)strpos($dwFilename,"..") !== 0) {
- die("Illegal filename given.");
- $img = $dwDir."/".$dwFilename;
- if(!file_exists($img) || !is_readable($img)) {
- die("An error occured.");
- $now_date = date("Ymd_His");
- switch(substr($dwFilename,-4)) {
- case ".png":
- $filename = "map_export__".$now_date.".png";
- header('Content-Type: image/png');
- break;
- case "jpeg":
- $filename = "map_export__".$now_date.".jpeg";
- header('Content-Type: image/jpeg');
- break;
- case ".tif";
- $filename = "map_export__".$now_date.".tif";
- header('Content-Type: image/tif');
- break;
- default:
- if(file_exists($img) && is_file($img)) {
- header("Content-Disposition: attachment; filename=\"".$filename."\"");
- readfile($img);
- } else {
- die('Error: The file '.$img.' does not exist!');
More information about the Mapbender_commits
