[Mapbender-commits] r2195 - branches/2.5/http/php
svn_mapbender at osgeo.org
Thu Mar 6 09:02:17 EST 2008
Author: christoph
Date: 2008-03-06 09:02:17 -0500 (Thu, 06 Mar 2008)
New Revision: 2195
branches/2.5/http/php/mb_validatePermission.php
branches/2.5/http/php/mb_validateSession.php
branches/2.5/http/php/mod_owsproxy_conf.php
new security module
Modified: branches/2.5/http/php/mb_validatePermission.php
--- branches/2.5/http/php/mb_validatePermission.php 2008-03-06 13:35:20 UTC (rev 2194)
+++ branches/2.5/http/php/mb_validatePermission.php 2008-03-06 14:02:17 UTC (rev 2195)
@@ -20,15 +20,65 @@
require(dirname(__FILE__)."/../php/mb_validateSession.php");
require_once(dirname(__FILE__)."/../classes/class_administration.php");
-$n = new administration();
-$m = $n->getModulPermission($_SESSION["mb_user_id"], $gui_id, $e_id);
+$admin = new administration();
-if (!$m) {
- $msg = "User " . $_SESSION["mb_user_id"] . "is not allowed to access ".
+// check if GUI id and element id are set
+$msg = "missing in " . $_SERVER["PHP_SELF"];
+if (!isset($gui_id)) {
+ $e = new mb_exception("GUI id " . $msg);
+ die();
+if (!isset($e_id)) {
+ $e = new mb_exception("Element id " . $msg);
+ die();
+// check if the user is allowed to access this module
+$isAllowed = $admin->getModulPermission($_SESSION["mb_user_id"], $gui_id, $e_id);
+// if the module is an iframe, also check if the filename matches the
+// filename of the GUI element with the given e_id
+// (if PHP_SELF is "map.php", we trust the script.)
+if (!preg_match("/^.*\/javascripts\/map\.php$/", $_SERVER["PHP_SELF"])) {
+ $isCorrectScript = true;
+ $sql = "SELECT e_element FROM gui_element WHERE e_id = $1 AND fkey_gui_id = $2";
+ $v = array($e_id, $gui_id);
+ $t = array("s", "s");
+ $res = db_prep_query($sql, $v, $t);
+ while ($row = db_fetch_array($res)) {
+ if (!$admin->checkModulePermission_new($_SESSION["mb_user_id"], $_SERVER["PHP_SELF"], $row["e_element"])) {
+ $isCorrectScript = false;
+ break;
+// $e = new mb_notice($e_id . ": isAllowed: " . $isAllowed . ", isCorrectScript: " . $isCorrectScript);
+ $isAllowed = $isAllowed && $isCorrectScript;
+// If the user is not allowed to access the module, return to the login screen.
+if (!$isAllowed) {
+ $msg = "mb_validatePermission.php: User " . $_SESSION["mb_user_id"] . " is not allowed to access ".
"module " . $e_id;
$e = new mb_exception($msg);
header("Location: ".LOGIN);
- exit;
die();
+$e = new mb_notice("mb_validatePermission.php: checking file " . $_SERVER["PHP_SELF"] . "...permission valid.");
+// delete global variables
+unset($admin, $isAllowed, $e, $isCorrectScript, $msg, $myGuisArray);
\ No newline at end of file
Modified: branches/2.5/http/php/mb_validateSession.php
--- branches/2.5/http/php/mb_validateSession.php 2008-03-06 13:35:20 UTC (rev 2194)
+++ branches/2.5/http/php/mb_validateSession.php 2008-03-06 14:02:17 UTC (rev 2195)
@@ -21,44 +21,48 @@
require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
require_once(dirname(__FILE__)."/../classes/class_mb_exception.php");
// establish database connection
-$con = db_connect($DBSERVER,$OWNER,$PW);
-db_select_db(DB,$con);
+$con = db_connect($DBSERVER, $OWNER, $PW);
+db_select_db(DB, $con);
+$e = new mb_notice("mb_validateSession.php: checking file " . $_SERVER["PHP_SELF"]);
// check if user data is valid; if not, return to login screen
-if (!isset($_SESSION["mb_user_id"]) || !isset($_SESSION["mb_user_ip"]) ||
+if (!isset($_SESSION["mb_user_id"]) ||
+ !isset($_SESSION["mb_user_ip"]) ||
$_SESSION['mb_user_ip'] != $_SERVER['REMOTE_ADDR']) {
- $e = new mb_exception("Invalid user: " . $_SESSION["mb_user_id"]);
- header("Location: ".LOGIN);
- exit;
- die();
+ $e = new mb_exception("mb_validateSession.php: Invalid user: " . $_SESSION["mb_user_id"]);
+ header("Location: " . LOGIN);
+ die();
-// check if GUI ID is set; if not, return to login screen
-if (!isset($gui_id)) {
- if (isset($_REQUEST["guiID"])) {
+// set the global var gui_id
+if (!$gui_id) {
+ $e = new mb_notice("gui id not set");
+ if ($_REQUEST["guiID"]) {
+ $e = new mb_notice("gui id set to guiID");
$gui_id = $_REQUEST["guiID"];
- elseif (isset($_REQUEST["gui_id"])) {
+ elseif ($_REQUEST["gui_id"]) {
+ $e = new mb_notice("gui id set to gui_id");
$gui_id = $_REQUEST["gui_id"];
else {
- $e = new mb_exception("gui_id not set in module: " . $e_id);
- die();
+ $e = new mb_notice("mb_validateSession.php: gui_id not set in script: " . $_SERVER["PHP_SELF"]);
-// check if user is allowed to access current GUI;
-// if not, return to login screen
-if (!in_array($gui_id, $_SESSION["mb_user_guis"])) {
- exit;
- die();
-// check if element ID is set
-if (!isset($e_id)) {
+// set the global var e_id
+if (!$e_id) {
if (isset($_REQUEST["elementID"])) {
$e_id = $_REQUEST["elementID"];
@@ -66,12 +70,21 @@
$e_id = $_REQUEST["e_id"];
else {
- $e = new mb_exception("e_id not set in script: " . $PHP_SELF);
- die();
+ $e = new mb_notice("mb_validateSession.php: e_id not set in script: " . $_SERVER["PHP_SELF"]);
// set variables used for form targets or links
-$urlParameters = SID . "&guiID=" . $gui_id . "&elementID=" . $e_id;
-$self = $PHP_SELF . "?" . $urlParameters;
+$urlParameters = SID;
+if (isset($gui_id)) {
+ $urlParameters .= "&guiID=" . $gui_id;
+if (isset($e_id)) {
+ $urlParameters .= "&elementID=" . $e_id;
+$self = $_SERVER["PHP_SELF"] . "?" . $urlParameters;
+$e = new mb_notice("mb_validateSession.php: GUI: " . $gui_id . ", checking file " . $_SERVER["PHP_SELF"] . "...session valid.");
Modified: branches/2.5/http/php/mod_owsproxy_conf.php
--- branches/2.5/http/php/mod_owsproxy_conf.php 2008-03-06 13:35:20 UTC (rev 2194)
+++ branches/2.5/http/php/mod_owsproxy_conf.php 2008-03-06 14:02:17 UTC (rev 2195)
@@ -17,8 +17,8 @@
# along with this program; if not, write to the Free Software
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-include(dirname(__FILE__)."/../php/mb_validatePermission.php");
-include(dirname(__FILE__)."/../classes/class_administration.php");
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+require_once(dirname(__FILE__)."/../classes/class_administration.php");
$ownwms = $admin->getWmsByOwner($_SESSION["mb_user_id"]);
if(isset($_REQUEST["wms_id"]) && isset($_REQUEST["status"])){
More information about the Mapbender_commits
