[Mapbender-commits] r2206 - branches/2.5/http/html
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Mar 7 07:49:17 EST 2008
Author: nimix
Date: 2008-03-07 07:49:17 -0500 (Fri, 07 Mar 2008)
New Revision: 2206
   branches/2.5/http/html/mod_treefolder2.php
add tooltip for wms and layer title
Modified: branches/2.5/http/html/mod_treefolder2.php
--- branches/2.5/http/html/mod_treefolder2.php	2008-03-06 16:33:33 UTC (rev 2205)
+++ branches/2.5/http/html/mod_treefolder2.php	2008-03-07 12:49:17 UTC (rev 2206)
@@ -17,11 +17,8 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
 $gui_id = $_SESSION["mb_user_gui"];
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 3.2//EN">
 <HTML>
@@ -499,7 +496,7 @@
 								controls=null;
 								if(switchwms=='true')controls='<INPUT type="checkbox" checked onclick="handleSelectedWMS(\''+arrNodes[0][0]+'|'+parent.mb_mapObj[i].wms[ii].wms_id+'\');" />';
 								if(wmsbuttons == 'true'&&metadatalink == 'true')controls+='<a href="'+'javascript:openwindow(\'../php/mod_layerMetadata.php?id='+temp.layer_uid+'\');'+'"><img src="'+imagedir+'/info.png" /></a>';
-								addNode(arrNodes[0][0],[parent.mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"../php/mod_layerMetadata.php?id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,,,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
+								addNode(arrNodes[0][0],[parent.mb_mapObj[i].wms[ii].wms_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"../php/mod_layerMetadata.php?id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,,temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
 								parentObj = arrNodes[0][0]+"|"+parent.mb_mapObj[i].wms[ii].wms_id;
 							if(parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent && (handlesublayer=="true"||parent.mb_mapObj[i].wms[ii].objLayer[iii].layer_parent=="0")){
@@ -535,7 +532,7 @@
 									controls='<input type="checkbox" '+(temp.layer_name==""?'style="display:none;" ':"")+((temp.gui_layer_visible=='1')?'checked ':'')+(temp.gui_layer_selectable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','visible',this.checked?1:0);handleSelection('"+parentObj+parentLayer+"|"+temp.layer_id+"');updateParent('"+parentObj+parentLayer+"');"+((ficheckbox == 'false')?"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0)":"")+"\" />";
 									if(ficheckbox == 'true')controls+='<input type="checkbox" '+(temp.gui_layer_querylayer=='1'?'checked ':'')+(temp.gui_layer_queryable!='1'?'disabled ':'')+"onclick=\"handleSelectedLayer('"+mod_treeGDE_map+"','"+parent.mb_mapObj[i].wms[ii].wms_id+"','"+temp.layer_name+"','querylayer',this.checked?1:0);checkChildren('"+parentObj+parentLayer+"|"+temp.layer_id+"', 1, this.checked?1:0)\" />";
-									addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"../php/mod_layerMetadata.php?id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?'menu.png':null),,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
+									addNode(parentObj + parentLayer, [temp.layer_id,[temp.layer_title,((metadatalink=='true'&&wmsbuttons != 'true')?('javascript:openwindow(\"../php/mod_layerMetadata.php?id='+temp.layer_uid+'\");'):"javascript:select("+i+","+ii+","+iii+");"),,((c_menu!='[]'&&temp.layer_name!="")?'menu.png':null),temp.layer_title,eval(c_menu),controls,[i,ii,iii]]],false,false,reverse=="true");
More information about the Mapbender_commits mailing list
