[Mapbender-commits] r2218 - branches/2.4.5/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Mar 10 09:45:59 EDT 2008
Author: christoph
Date: 2008-03-10 09:45:59 -0400 (Mon, 10 Mar 2008)
New Revision: 2218
   branches/2.4.5/http/php/mod_filteredWms_layer_topic.php
   branches/2.4.5/http/php/mod_filteredWms_topic.php
deactivated modules as they are not used in Mapbender
Modified: branches/2.4.5/http/php/mod_filteredWms_layer_topic.php
--- branches/2.4.5/http/php/mod_filteredWms_layer_topic.php	2008-03-08 16:16:20 UTC (rev 2217)
+++ branches/2.4.5/http/php/mod_filteredWms_layer_topic.php	2008-03-10 13:45:59 UTC (rev 2218)
@@ -17,211 +17,13 @@
 # along with this program; if not, write to the Free Software
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-require_once(dirname(__FILE__)."/mb_validatePermission.php");
-require_once("../classes/class_administration.php");
-$logged_user_name = $_SESSION["mb_user_name"];
-$logged_user_id = $_SESSION["mb_user_id"];
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
 <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
 <html>
 <meta http-equiv="Content-Type" content="text/html; charset=<?php echo CHARSET;?>">
 <title>Administration</title>
-<?php
-include '../include/dyn_css.php';
-<script language="JavaScript">
-function validate(wert){
-	if(document.forms[0]["selected_wms"].selectedIndex == -1){
-		document.getElementsByName("selected_wms")[0].style.backgroundColor = '#ff0000';
-		return;
-	}else if(document.forms[0]["selected_layer"].selectedIndex == -1){
-		document.getElementsByName("selected_layer")[0].style.backgroundColor = '#ff0000';
-		return;
-	}else{
-		if(wert == "remove"){
-			if(document.forms[0]["remove_topic[]"].selectedIndex == -1){
-				document.getElementsByName("remove_topic[]")[0].style.backgroundColor = '#ff0000';
-				return;
-			document.form1.remove.value = 'true';
-			document.form1.submit();
-		if(wert == "insert"){
-			if(document.forms[0]["selected_topic[]"].selectedIndex == -1){
-				document.getElementsByName("selected_topic[]")[0].style.backgroundColor = '#ff0000';
-				return;
-			document.form1.insert.value = 'true';
-</script>
 </head>
 <body>
-<?php
-$fieldHeight = 20;
-$language_suffix = "en";
-//FIXME: there seems to be an error in dyn_css.php concerning php vars.
-if ($language == "'de'") {
-	$language_suffix = "de";
-$admin = new administration();
-$own_gui_id_array = $admin->getGuisByOwner($logged_user_id,true);
-$own_wms_id_array = array();
-$sql = "SELECT wms_id FROM wms WHERE wms_owner = $1";
-$v = array($logged_user_id);
-$t = array('i');
-$res = db_prep_query($sql,$v,$t);
-while($row = db_fetch_array($res)){
-	array_push($own_wms_id_array,$row['wms_id']);
-$own_layer_id_array = $admin->getLayerByWms($selected_wms);
-/*handle remove, update and insert*****************************************************************/
-if($insert){
-	if(count($selected_topic) > 0){
-		for($i=0; $i<count($selected_topic); $i++){
-			$exists = false;
-			$sql_insert = "SELECT * FROM layer_md_topic_category WHERE fkey_layer_id = $1 and fkey_md_topic_category_id = $2";
-			$v = array($selected_layer,$selected_topic[$i]);
-			$t = array('i','i');
-			$res_insert = db_prep_query($sql_insert,$v,$t);
-			while(db_fetch_row($res_insert)){$exists = true;}
-			if($exists == false){
-				$sql_insert = "INSERT INTO layer_md_topic_category (fkey_layer_id, fkey_md_topic_category_id) VALUES($1, $2)";
-if($remove){
-	if(count($remove_topic)>0){
-		for($i=0; $i<count($remove_topic); $i++){
-			$sql_remove = "DELETE FROM layer_md_topic_category WHERE fkey_md_topic_category_id = $1 and fkey_layer_id = $2";
-			$v = array($remove_topic[$i],$selected_layer);
-			$t = array('i','s');
-			db_prep_query($sql_remove,$v,$t);
-if (!isset($selected_layer)) {
-	if (count($own_layer_id_array) > 0) {
-		$selected_layer = $own_layer_id_array[0];
-$topic_id_layer = array();
-if (isset($selected_layer)) {
-	/*get all topics from selected layer*****************************************************************/
-	if ($language_suffix == "de") {
-		$sql_layer_topic = "SELECT t.md_topic_category_id, t.md_topic_category_code_de ";
-		$sql_layer_topic .= "FROM layer_md_topic_category as w, md_topic_category as t WHERE w.fkey_layer_id = $1 AND w.fkey_md_topic_category_id = t.md_topic_category_id ";
-		$sql_layer_topic .= "ORDER BY t.md_topic_category_code_de";
-	else {
-		$sql_layer_topic = "SELECT t.md_topic_category_id, t.md_topic_category_code_en ";
-		$sql_layer_topic .= "ORDER BY t.md_topic_category_code_en";
-	$v = array($selected_layer);
-	$t = array('s');
-	$res_layer_topic = db_prep_query($sql_layer_topic,$v,$t);
-	while($row = db_fetch_array($res_layer_topic)){
-		array_push($topic_id_layer, $row["md_topic_category_id"]);
-		array_push($topic_name_layer, $row["md_topic_category_code_".$language_suffix]);
-/*get all topics **********************************************************************************/
-if ($language_suffix == "de") {
-	$sql_topic = "SELECT * FROM md_topic_category ORDER BY md_topic_category_code_de";
-else {
-	$sql_topic = "SELECT * FROM md_topic_category ORDER BY md_topic_category_code_en";
-$res_topic = db_query($sql_topic);
-$topic_id = array();
-$topic_name = array();
-while($row = db_fetch_array($res_topic)){
-	if (!in_array($row["md_topic_category_id"], $topic_id_layer)) {
-		array_push($topic_id, $row["md_topic_category_id"]);
-		array_push($topic_name, $row["md_topic_category_code_".$language_suffix]);
-/*INSERT HTML*/
-echo "<form name='form1' action='" . $self ."' method='post'>";
-/*insert wms in selectbox*************************************************************************/
-echo "<div class='text1'>WMS: </div>";
-echo "<select style='background:#ffffff' class='select1' name='selected_wms' onChange='submit()' size='10'>";
-for($i=0; $i<count($own_wms_id_array); $i++){
-	echo "<option value='" . $own_wms_id_array[$i] . "' ";
-	if($selected_wms && $selected_wms == $own_wms_id_array[$i]){
-		echo "selected";
-	echo ">" . $admin->getWmsTitleByWmsId($own_wms_id_array[$i]) . "</option>";
-echo "</select>";
-echo "<div class='text2'>Layer: </div>";
-echo "<select style='background:#ffffff' class='select2' name='selected_layer' onChange='submit()' size='10'>";
-for($i=0; $i<count($own_layer_id_array); $i++){
-	echo "<option value='" . $own_layer_id_array[$i] . "' ";
-	if($selected_layer && $selected_layer == $own_layer_id_array[$i]){
-		echo "selected";
-	echo ">" . $admin->getLayerTitleByLayerId($own_layer_id_array[$i]) . "</option>";
-echo "</select>";
-/*insert all groups in selectbox*******************************************************************/
-echo "<div class='text3'>TOPICS:</div><br>";
-echo "<select style='background:#ffffff' class='select3' multiple='multiple' name='selected_topic[]' size='$fieldHeight' >";
-for($i=0; $i<count($topic_id); $i++){
-	echo "<option value='" . $topic_id[$i]  . "'>" . $topic_name[$i]  . "</option>";
-echo "</select>";
-/*Button*******************************************************************************************/
-echo "<div class='button1'><input type='button'  value='==>' onClick='validate(\"insert\")'></div>";
-echo "<input type='hidden' name='insert'>";
-echo "<div class='button2'><input type='button' value='<==' onClick='validate(\"remove\")'></div>";
-echo "<input type='hidden' name='remove'>";
-/*insert wms_topic_dependence and container_group_dependence in selectbox**************************************************/
-echo "<div class='text4'>SELECTED TOPICS:</div>";
-echo "<select style='background:#ffffff' class='select4' multiple='multiple' name='remove_topic[]' size='$fieldHeight' >";
-for ($i=0; $i < count($topic_id_layer); $i++) {
-	echo "<option value='" . $topic_id_layer[$i]  . "'>" . $topic_name_layer[$i]  . "</option>";
-echo "</select>";
-echo "</form>";
-<script type="text/javascript">
-document.forms[0].selected_wms.focus();
-</script>
+This module is still under construction, see <a href='http://www.mapbender.org/Topic_/_Category'>Mapbender Wiki</a>.
 </body>
 </html>
\ No newline at end of file
Modified: branches/2.4.5/http/php/mod_filteredWms_topic.php
--- branches/2.4.5/http/php/mod_filteredWms_topic.php	2008-03-08 16:16:20 UTC (rev 2217)
+++ branches/2.4.5/http/php/mod_filteredWms_topic.php	2008-03-10 13:45:59 UTC (rev 2218)
@@ -16,12 +16,6 @@
 # You should have received a copy of the GNU General Public License
-require_once("../php/mb_validatePermission.php");
-import_request_variables("PG");
 <html>
@@ -29,160 +23,8 @@
 echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<?php
-		return;
-	}else{
-				return;
-				return;
-</script>
 </head>
 <body>
-<?php
-$fieldHeight = 20;
-$own_wms_id_array = $admin->getWmsByOwnGuis($own_gui_id_array);
-$cnt_wms = count($own_wms_id_array);
-if($insert){
-			$exists = false;
-			$sql_insert = "SELECT * FROM wms_md_topic_category WHERE fkey_wms_id = $1 and fkey_md_topic_category_id = $2";
-			$v = array($selected_wms,$selected_topic[$i]);
-				$sql_insert = "INSERT INTO wms_md_topic_category (fkey_wms_id, fkey_md_topic_category_id) VALUES($1, $2)";
-if($remove){
-			$sql_remove = "DELETE FROM wms_md_topic_category WHERE fkey_md_topic_category_id = $1 and fkey_wms_id = $2";
-			$v = array($remove_topic[$i],$selected_wms);
-/*get all topics from selected wms*****************************************************************/
-$sql_wms_topic = "SELECT t.md_topic_category_id, t.md_topic_category_code_".$language_suffix." ";
-$sql_wms_topic .= "FROM wms_md_topic_category as w, md_topic_category as t WHERE w.fkey_wms_id = $1 AND w.fkey_md_topic_category_id = t.md_topic_category_id ";
-$sql_wms_topic .= "ORDER BY t.md_topic_category_code_".$language_suffix;
-if(!$selected_wms){$v = array($own_wms_id_array[0]);}
-if($selected_wms){$v = array($selected_wms);}
-$t = array('s');
-$res_wms_topic = db_prep_query($sql_wms_topic,$v,$t);
-$cnt_wms_topic=0;;
-while($row = db_fetch_array($res_wms_topic)){
-	$topic_id_wms[$cnt_wms_topic] = $row["md_topic_category_id"];
-	$topic_name_wms[$cnt_wms_topic] =  $row["md_topic_category_code_".$language_suffix];
-	$cnt_wms_topic++;
-$sql_topic = "SELECT * FROM md_topic_category ORDER BY md_topic_category_code_" . $language_suffix;
-$cnt_topic = 0;
-	if (!in_array($row["md_topic_category_id"], $topic_id_wms)) {
-		$topic_id[$cnt_topic] = $row["md_topic_category_id"];
-		$topic_name[$cnt_topic] =  $row["md_topic_category_code_".$language_suffix];
-		$cnt_topic++;
-/*INSERT HTML*/
-for($i=0; $i<$cnt_wms; $i++){
-		echo "selected";
-echo "</select>";
-echo "<div class='text2'>TOPICS:</div><br>";
-echo "<select style='background:#ffffff' class='select2' multiple='multiple' name='selected_topic[]' size='$fieldHeight' >";
-for($i=0; $i<$cnt_topic; $i++){
-echo "</select>";
-echo "<div class='text3'>SELECTED TOPICS:</div>";
-echo "<select style='background:#ffffff' class='select3' multiple='multiple' name='remove_topic[]' size='$fieldHeight' >";
-for($i=0; $i<$cnt_wms_topic; $i++){
-	echo "<option value='" . $topic_id_wms[$i]  . "'>" . $topic_name_wms[$i]  . "</option>";
-echo "</select>";
-echo "</form>";
-</script>
 </body>
 </html>
More information about the Mapbender_commits mailing list
