[Mapbender-commits] r2263 - branches/nimix_dev/http/javascripts
svn_mapbender at osgeo.org
Tue Mar 18 04:45:54 EDT 2008
Author: nimix
Date: 2008-03-18 04:45:54 -0400 (Tue, 18 Mar 2008)
New Revision: 2263
branches/nimix_dev/http/javascripts/map.js
branches/nimix_dev/http/javascripts/map_obj.js
fix grouped layer bugs
Modified: branches/nimix_dev/http/javascripts/map.js
--- branches/nimix_dev/http/javascripts/map.js 2008-03-18 08:45:01 UTC (rev 2262)
+++ branches/nimix_dev/http/javascripts/map.js 2008-03-18 08:45:54 UTC (rev 2263)
@@ -927,10 +927,10 @@
querylayers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
cnt_querylayers++;
- mb_mapObj[ind].layers[i] = layers;
- mb_mapObj[ind].querylayers[i] = querylayers;
- mb_mapObj[ind].styles[i] = styles;
+ mb_mapObj[ind].layers[i] = layers;
+ mb_mapObj[ind].querylayers[i] = querylayers;
+ mb_mapObj[ind].styles[i] = styles;
@@ -950,7 +950,7 @@
if(thisLayer[ii] == myLayername){
if(myMinscale === 0 || thisScale >= myMinscale){minscaleOK = true;}
if(myMaxscale === 0 || thisScale <= myMaxscale){maxscaleOK = true;}
- if(maxscaleOK === true && minscaleOK === true ){
+ if(maxscaleOK === true && minscaleOK === true && !mb_mapObj[mObj].wms[wmsObj].objLayer[i].has_childs){
if(cnt_layer > 0){str_layer += ","; }//str_styles += ","; str_titles += ",";str_parent += ","; str_legendurls += ",";}
str_layer += thisLayer[ii];
cnt_layer++;
Modified: branches/nimix_dev/http/javascripts/map_obj.js
--- branches/nimix_dev/http/javascripts/map_obj.js 2008-03-18 08:45:01 UTC (rev 2262)
+++ branches/nimix_dev/http/javascripts/map_obj.js 2008-03-18 08:45:54 UTC (rev 2263)
@@ -487,7 +487,7 @@
//Set visibility/queryability of Layer and Sublayers
for(var j = i; j < this.objLayer.length; j++){
- if (i != j && this.objLayer[i].layer_parent == this.objLayer[j].layer_parent) {
+ if (i != j && this.objLayer[i].layer_parent >= this.objLayer[j].layer_parent) {
break;
if(type == "visible") {
@@ -509,7 +509,7 @@
else if(type=="querylayer") {
this.objLayer[j].gui_layer_querylayer = state;
More information about the Mapbender_commits
