[Mapbender-commits] r2275 - branches/2.5/http/frames
    svn_mapbender at osgeo.org
    Thu Mar 20 07:01:25 EDT 2008
Author: christoph
Date: 2008-03-20 07:01:25 -0400 (Thu, 20 Mar 2008)
New Revision: 2275
   branches/2.5/http/frames/index.php
added gui_id to parameter list of iframe src
Modified: branches/2.5/http/frames/index.php
--- branches/2.5/http/frames/index.php	2008-03-20 10:13:35 UTC (rev 2274)
+++ branches/2.5/http/frames/index.php	2008-03-20 11:01:25 UTC (rev 2275)
@@ -125,7 +125,9 @@
 				else {
 	      			echo "?";
-      			echo "e_id_css=".db_result($res,$i,"e_id")."&e_id=".db_result($res,$i,"e_id")."&e_target=".db_result($res,$i,"e_target")."'";
+      			echo "e_id_css=".db_result($res,$i,"e_id")."&e_id=".db_result($res,$i,"e_id") .
+					"&e_target=".db_result($res,$i,"e_target").
+					"&" . $urlParameters . "'";
 		else{
 			echo " src = '".preg_replace($pattern,$replacement,db_result($res,$i,"e_src"))."'";
More information about the Mapbender_commits
