[Mapbender-commits] r3182 - in branches/print_dev/http/extensions:
. fpdf fpdf/decoders fpdf/font fpdf/font/makefont
svn_mapbender at osgeo.org
Wed Nov 5 09:02:01 EST 2008
Author: mschulz
Date: 2008-11-05 09:02:01 -0500 (Wed, 05 Nov 2008)
New Revision: 3182
Added:
branches/print_dev/http/extensions/fpdf/
branches/print_dev/http/extensions/fpdf/decoders/
branches/print_dev/http/extensions/fpdf/decoders/ASCII85Decode.php
branches/print_dev/http/extensions/fpdf/decoders/LZWDecode.php
branches/print_dev/http/extensions/fpdf/font/
branches/print_dev/http/extensions/fpdf/font/courier.php
branches/print_dev/http/extensions/fpdf/font/desktop.ini
branches/print_dev/http/extensions/fpdf/font/helvetica.php
branches/print_dev/http/extensions/fpdf/font/helveticab.php
branches/print_dev/http/extensions/fpdf/font/helveticabi.php
branches/print_dev/http/extensions/fpdf/font/helveticai.php
branches/print_dev/http/extensions/fpdf/font/makefont/
branches/print_dev/http/extensions/fpdf/font/makefont/cp1250.map
branches/print_dev/http/extensions/fpdf/font/makefont/cp1251.map
branches/print_dev/http/extensions/fpdf/font/makefont/cp1252.map
branches/print_dev/http/extensions/fpdf/font/makefont/cp1253.map
branches/print_dev/http/extensions/fpdf/font/makefont/cp1254.map
branches/print_dev/http/extensions/fpdf/font/makefont/cp1255.map
branches/print_dev/http/extensions/fpdf/font/makefont/cp1257.map
branches/print_dev/http/extensions/fpdf/font/makefont/cp1258.map
branches/print_dev/http/extensions/fpdf/font/makefont/cp874.map
branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-1.map
branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-11.map
branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-15.map
branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-16.map
branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-2.map
branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-4.map
branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-5.map
branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-7.map
branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-9.map
branches/print_dev/http/extensions/fpdf/font/makefont/koi8-r.map
branches/print_dev/http/extensions/fpdf/font/makefont/koi8-u.map
branches/print_dev/http/extensions/fpdf/font/makefont/makefont.php
branches/print_dev/http/extensions/fpdf/font/symbol.php
branches/print_dev/http/extensions/fpdf/font/times.php
branches/print_dev/http/extensions/fpdf/font/timesb.php
branches/print_dev/http/extensions/fpdf/font/timesbi.php
branches/print_dev/http/extensions/fpdf/font/timesi.php
branches/print_dev/http/extensions/fpdf/font/zapfdingbats.php
branches/print_dev/http/extensions/fpdf/fpdf.php
branches/print_dev/http/extensions/fpdf/fpdf_tpl.php
branches/print_dev/http/extensions/fpdf/fpdi.php
branches/print_dev/http/extensions/fpdf/fpdi2tcpdf_bridge.php
branches/print_dev/http/extensions/fpdf/fpdi_pdf_parser.php
branches/print_dev/http/extensions/fpdf/license.txt
branches/print_dev/http/extensions/fpdf/pdf_context.php
branches/print_dev/http/extensions/fpdf/pdf_parser.php
branches/print_dev/http/extensions/fpdf/wrapper_functions.php
added fpdf/fpdi libs for pdf generation
Added: branches/print_dev/http/extensions/fpdf/decoders/ASCII85Decode.php
--- branches/print_dev/http/extensions/fpdf/decoders/ASCII85Decode.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/decoders/ASCII85Decode.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,95 @@
+<?php
+// FPDI - Version 1.2.1
+// Copyright 2004-2008 Setasign - Jan Slabon
+// Licensed under the Apache License, Version 2.0 (the "License");
+// you may not use this file except in compliance with the License.
+// You may obtain a copy of the License at
+// http://www.apache.org/licenses/LICENSE-2.0
+// Unless required by applicable law or agreed to in writing, software
+// distributed under the License is distributed on an "AS IS" BASIS,
+// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+// See the License for the specific language governing permissions and
+// limitations under the License.
+if (!defined("ORD_z"))
+ define("ORD_z",ord('z'));
+if (!defined("ORD_exclmark"))
+ define("ORD_exclmark", ord('!'));
+if (!defined("ORD_u"))
+ define("ORD_u", ord("u"));
+if (!defined("ORD_tilde"))
+ define("ORD_tilde", ord('~'));
+class ASCII85Decode {
+ function ASCII85Decode(&$fpdi) {
+ $this->fpdi =& $fpdi;
+ function decode($in) {
+ $out = "";
+ $state = 0;
+ $chn = null;
+ $l = strlen($in);
+ for ($k = 0; $k < $l; ++$k) {
+ $ch = ord($in[$k]) & 0xff;
+ if ($ch == ORD_tilde) {
+ break;
+ if (preg_match("/^\s$/",chr($ch))) {
+ continue;
+ if ($ch == ORD_z && $state == 0) {
+ $out .= chr(0).chr(0).chr(0).chr(0);
+ continue;
+ if ($ch < ORD_exclmark || $ch > ORD_u) {
+ $this->fpdi->error("Illegal character in ASCII85Decode.");
+ $chn[$state++] = $ch - ORD_exclmark;
+ if ($state == 5) {
+ $state = 0;
+ $r = 0;
+ for ($j = 0; $j < 5; ++$j)
+ $r = $r * 85 + $chn[$j];
+ $out .= chr($r >> 24);
+ $out .= chr($r >> 16);
+ $out .= chr($r >> 8);
+ $out .= chr($r);
+ $r = 0;
+ if ($state == 1)
+ $this->fpdi->error("Illegal length in ASCII85Decode.");
+ if ($state == 2) {
+ $r = $chn[0] * 85 * 85 * 85 * 85 + ($chn[1]+1) * 85 * 85 * 85;
+ else if ($state == 3) {
+ $r = $chn[0] * 85 * 85 * 85 * 85 + $chn[1] * 85 * 85 * 85 + ($chn[2]+1) * 85 * 85;
+ else if ($state == 4) {
+ $r = $chn[0] * 85 * 85 * 85 * 85 + $chn[1] * 85 * 85 * 85 + $chn[2] * 85 * 85 + ($chn[3]+1) * 85 ;
+ return $out;
\ No newline at end of file
Added: branches/print_dev/http/extensions/fpdf/decoders/LZWDecode.php
--- branches/print_dev/http/extensions/fpdf/decoders/LZWDecode.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/decoders/LZWDecode.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,147 @@
+<?php
+class LZWDecode {
+ var $sTable = array();
+ var $data = null;
+ var $tIdx;
+ var $bitsToGet = 9;
+ var $bytePointer;
+ var $bitPointer;
+ var $nextData = 0;
+ var $nextBits = 0;
+ var $andTable = array(511, 1023, 2047, 4095);
+ function LZWDecode(&$fpdi) {
+ * Method to decode LZW compressed data.
+ * @param string data The compressed data.
+ function decode($data) {
+ if($data[0] == 0x00 && $data[1] == 0x01) {
+ $this->fpdi->error("LZW flavour not supported.");
+ $this->initsTable();
+ $this->data = $data;
+ // Initialize pointers
+ $this->bytePointer = 0;
+ $this->bitPointer = 0;
+ $this->nextData = 0;
+ $this->nextBits = 0;
+ $oldCode = 0;
+ $string = "";
+ $uncompData = "";
+ while (($code = $this->getNextCode()) != 257) {
+ if ($code == 256) {
+ $code = $this->getNextCode();
+ if ($code == 257) {
+ break;
+ $uncompData .= $this->sTable[$code];
+ $oldCode = $code;
+ } else {
+ if ($code < $this->tIdx) {
+ $string = $this->sTable[$code];
+ $uncompData .= $string;
+ $this->addStringToTable($this->sTable[$oldCode], $string[0]);
+ $oldCode = $code;
+ } else {
+ $string = $this->sTable[$oldCode];
+ $string = $string.$string[0];
+ $this->addStringToTable($string);
+ $oldCode = $code;
+ return $uncompData;
+ * Initialize the string table.
+ function initsTable() {
+ $this->sTable = array();
+ for ($i = 0; $i < 256; $i++)
+ $this->sTable[$i] = chr($i);
+ $this->tIdx = 258;
+ $this->bitsToGet = 9;
+ * Add a new string to the string table.
+ function addStringToTable ($oldString, $newString="") {
+ $string = $oldString.$newString;
+ // Add this new String to the table
+ $this->sTable[$this->tIdx++] = $string;
+ if ($this->tIdx == 511) {
+ $this->bitsToGet = 10;
+ } else if ($this->tIdx == 1023) {
+ $this->bitsToGet = 11;
+ } else if ($this->tIdx == 2047) {
+ $this->bitsToGet = 12;
+ // Returns the next 9, 10, 11 or 12 bits
+ function getNextCode() {
+ if ($this->bytePointer == strlen($this->data))
+ return 257;
+ $this->nextData = ($this->nextData << 8) | (ord($this->data[$this->bytePointer++]) & 0xff);
+ $this->nextBits += 8;
+ if ($this->nextBits < $this->bitsToGet) {
+ $code = ($this->nextData >> ($this->nextBits - $this->bitsToGet)) & $this->andTable[$this->bitsToGet-9];
+ $this->nextBits -= $this->bitsToGet;
+ return $code;
Added: branches/print_dev/http/extensions/fpdf/font/courier.php
--- branches/print_dev/http/extensions/fpdf/font/courier.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/courier.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,7 @@
+<?php
+for($i=0;$i<=255;$i++)
+ $fpdf_charwidths['courier'][chr($i)]=600;
+$fpdf_charwidths['courierB']=$fpdf_charwidths['courier'];
+$fpdf_charwidths['courierI']=$fpdf_charwidths['courier'];
+$fpdf_charwidths['courierBI']=$fpdf_charwidths['courier'];
Added: branches/print_dev/http/extensions/fpdf/font/desktop.ini
--- branches/print_dev/http/extensions/fpdf/font/desktop.ini (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/desktop.ini 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,4 @@
+[ViewState]
+Mode=
+Vid=
+FolderType=NotSpecified
Added: branches/print_dev/http/extensions/fpdf/font/helvetica.php
--- branches/print_dev/http/extensions/fpdf/font/helvetica.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/helvetica.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['helvetica']=array(
+ chr(0)=>278,chr(1)=>278,chr(2)=>278,chr(3)=>278,chr(4)=>278,chr(5)=>278,chr(6)=>278,chr(7)=>278,chr(8)=>278,chr(9)=>278,chr(10)=>278,chr(11)=>278,chr(12)=>278,chr(13)=>278,chr(14)=>278,chr(15)=>278,chr(16)=>278,chr(17)=>278,chr(18)=>278,chr(19)=>278,chr(20)=>278,chr(21)=>278,
+ chr(22)=>278,chr(23)=>278,chr(24)=>278,chr(25)=>278,chr(26)=>278,chr(27)=>278,chr(28)=>278,chr(29)=>278,chr(30)=>278,chr(31)=>278,' '=>278,'!'=>278,'"'=>355,'#'=>556,'$'=>556,'%'=>889,'&'=>667,'\''=>191,'('=>333,')'=>333,'*'=>389,'+'=>584,
+ ','=>278,'-'=>333,'.'=>278,'/'=>278,'0'=>556,'1'=>556,'2'=>556,'3'=>556,'4'=>556,'5'=>556,'6'=>556,'7'=>556,'8'=>556,'9'=>556,':'=>278,';'=>278,'<'=>584,'='=>584,'>'=>584,'?'=>556,'@'=>1015,'A'=>667,
+ 'B'=>667,'C'=>722,'D'=>722,'E'=>667,'F'=>611,'G'=>778,'H'=>722,'I'=>278,'J'=>500,'K'=>667,'L'=>556,'M'=>833,'N'=>722,'O'=>778,'P'=>667,'Q'=>778,'R'=>722,'S'=>667,'T'=>611,'U'=>722,'V'=>667,'W'=>944,
+ 'X'=>667,'Y'=>667,'Z'=>611,'['=>278,'\\'=>278,']'=>278,'^'=>469,'_'=>556,'`'=>333,'a'=>556,'b'=>556,'c'=>500,'d'=>556,'e'=>556,'f'=>278,'g'=>556,'h'=>556,'i'=>222,'j'=>222,'k'=>500,'l'=>222,'m'=>833,
+ 'n'=>556,'o'=>556,'p'=>556,'q'=>556,'r'=>333,'s'=>500,'t'=>278,'u'=>556,'v'=>500,'w'=>722,'x'=>500,'y'=>500,'z'=>500,'{'=>334,'|'=>260,'}'=>334,'~'=>584,chr(127)=>350,chr(128)=>556,chr(129)=>350,chr(130)=>222,chr(131)=>556,
+ chr(132)=>333,chr(133)=>1000,chr(134)=>556,chr(135)=>556,chr(136)=>333,chr(137)=>1000,chr(138)=>667,chr(139)=>333,chr(140)=>1000,chr(141)=>350,chr(142)=>611,chr(143)=>350,chr(144)=>350,chr(145)=>222,chr(146)=>222,chr(147)=>333,chr(148)=>333,chr(149)=>350,chr(150)=>556,chr(151)=>1000,chr(152)=>333,chr(153)=>1000,
+ chr(154)=>500,chr(155)=>333,chr(156)=>944,chr(157)=>350,chr(158)=>500,chr(159)=>667,chr(160)=>278,chr(161)=>333,chr(162)=>556,chr(163)=>556,chr(164)=>556,chr(165)=>556,chr(166)=>260,chr(167)=>556,chr(168)=>333,chr(169)=>737,chr(170)=>370,chr(171)=>556,chr(172)=>584,chr(173)=>333,chr(174)=>737,chr(175)=>333,
+ chr(176)=>400,chr(177)=>584,chr(178)=>333,chr(179)=>333,chr(180)=>333,chr(181)=>556,chr(182)=>537,chr(183)=>278,chr(184)=>333,chr(185)=>333,chr(186)=>365,chr(187)=>556,chr(188)=>834,chr(189)=>834,chr(190)=>834,chr(191)=>611,chr(192)=>667,chr(193)=>667,chr(194)=>667,chr(195)=>667,chr(196)=>667,chr(197)=>667,
+ chr(198)=>1000,chr(199)=>722,chr(200)=>667,chr(201)=>667,chr(202)=>667,chr(203)=>667,chr(204)=>278,chr(205)=>278,chr(206)=>278,chr(207)=>278,chr(208)=>722,chr(209)=>722,chr(210)=>778,chr(211)=>778,chr(212)=>778,chr(213)=>778,chr(214)=>778,chr(215)=>584,chr(216)=>778,chr(217)=>722,chr(218)=>722,chr(219)=>722,
+ chr(220)=>722,chr(221)=>667,chr(222)=>667,chr(223)=>611,chr(224)=>556,chr(225)=>556,chr(226)=>556,chr(227)=>556,chr(228)=>556,chr(229)=>556,chr(230)=>889,chr(231)=>500,chr(232)=>556,chr(233)=>556,chr(234)=>556,chr(235)=>556,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>556,chr(241)=>556,
+ chr(242)=>556,chr(243)=>556,chr(244)=>556,chr(245)=>556,chr(246)=>556,chr(247)=>584,chr(248)=>611,chr(249)=>556,chr(250)=>556,chr(251)=>556,chr(252)=>556,chr(253)=>500,chr(254)=>556,chr(255)=>500);
Added: branches/print_dev/http/extensions/fpdf/font/helveticab.php
--- branches/print_dev/http/extensions/fpdf/font/helveticab.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/helveticab.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['helveticaB']=array(
+ chr(22)=>278,chr(23)=>278,chr(24)=>278,chr(25)=>278,chr(26)=>278,chr(27)=>278,chr(28)=>278,chr(29)=>278,chr(30)=>278,chr(31)=>278,' '=>278,'!'=>333,'"'=>474,'#'=>556,'$'=>556,'%'=>889,'&'=>722,'\''=>238,'('=>333,')'=>333,'*'=>389,'+'=>584,
+ ','=>278,'-'=>333,'.'=>278,'/'=>278,'0'=>556,'1'=>556,'2'=>556,'3'=>556,'4'=>556,'5'=>556,'6'=>556,'7'=>556,'8'=>556,'9'=>556,':'=>333,';'=>333,'<'=>584,'='=>584,'>'=>584,'?'=>611,'@'=>975,'A'=>722,
+ 'B'=>722,'C'=>722,'D'=>722,'E'=>667,'F'=>611,'G'=>778,'H'=>722,'I'=>278,'J'=>556,'K'=>722,'L'=>611,'M'=>833,'N'=>722,'O'=>778,'P'=>667,'Q'=>778,'R'=>722,'S'=>667,'T'=>611,'U'=>722,'V'=>667,'W'=>944,
+ 'X'=>667,'Y'=>667,'Z'=>611,'['=>333,'\\'=>278,']'=>333,'^'=>584,'_'=>556,'`'=>333,'a'=>556,'b'=>611,'c'=>556,'d'=>611,'e'=>556,'f'=>333,'g'=>611,'h'=>611,'i'=>278,'j'=>278,'k'=>556,'l'=>278,'m'=>889,
+ 'n'=>611,'o'=>611,'p'=>611,'q'=>611,'r'=>389,'s'=>556,'t'=>333,'u'=>611,'v'=>556,'w'=>778,'x'=>556,'y'=>556,'z'=>500,'{'=>389,'|'=>280,'}'=>389,'~'=>584,chr(127)=>350,chr(128)=>556,chr(129)=>350,chr(130)=>278,chr(131)=>556,
+ chr(132)=>500,chr(133)=>1000,chr(134)=>556,chr(135)=>556,chr(136)=>333,chr(137)=>1000,chr(138)=>667,chr(139)=>333,chr(140)=>1000,chr(141)=>350,chr(142)=>611,chr(143)=>350,chr(144)=>350,chr(145)=>278,chr(146)=>278,chr(147)=>500,chr(148)=>500,chr(149)=>350,chr(150)=>556,chr(151)=>1000,chr(152)=>333,chr(153)=>1000,
+ chr(154)=>556,chr(155)=>333,chr(156)=>944,chr(157)=>350,chr(158)=>500,chr(159)=>667,chr(160)=>278,chr(161)=>333,chr(162)=>556,chr(163)=>556,chr(164)=>556,chr(165)=>556,chr(166)=>280,chr(167)=>556,chr(168)=>333,chr(169)=>737,chr(170)=>370,chr(171)=>556,chr(172)=>584,chr(173)=>333,chr(174)=>737,chr(175)=>333,
+ chr(176)=>400,chr(177)=>584,chr(178)=>333,chr(179)=>333,chr(180)=>333,chr(181)=>611,chr(182)=>556,chr(183)=>278,chr(184)=>333,chr(185)=>333,chr(186)=>365,chr(187)=>556,chr(188)=>834,chr(189)=>834,chr(190)=>834,chr(191)=>611,chr(192)=>722,chr(193)=>722,chr(194)=>722,chr(195)=>722,chr(196)=>722,chr(197)=>722,
+ chr(220)=>722,chr(221)=>667,chr(222)=>667,chr(223)=>611,chr(224)=>556,chr(225)=>556,chr(226)=>556,chr(227)=>556,chr(228)=>556,chr(229)=>556,chr(230)=>889,chr(231)=>556,chr(232)=>556,chr(233)=>556,chr(234)=>556,chr(235)=>556,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>611,chr(241)=>611,
+ chr(242)=>611,chr(243)=>611,chr(244)=>611,chr(245)=>611,chr(246)=>611,chr(247)=>584,chr(248)=>611,chr(249)=>611,chr(250)=>611,chr(251)=>611,chr(252)=>611,chr(253)=>556,chr(254)=>611,chr(255)=>556);
Added: branches/print_dev/http/extensions/fpdf/font/helveticabi.php
--- branches/print_dev/http/extensions/fpdf/font/helveticabi.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/helveticabi.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['helveticaBI']=array(
Added: branches/print_dev/http/extensions/fpdf/font/helveticai.php
--- branches/print_dev/http/extensions/fpdf/font/helveticai.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/helveticai.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['helveticaI']=array(
Added: branches/print_dev/http/extensions/fpdf/font/makefont/cp1250.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/cp1250.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/cp1250.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,251 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!22 U+0022 quotedbl
+!23 U+0023 numbersign
+!24 U+0024 dollar
+!25 U+0025 percent
+!26 U+0026 ampersand
+!27 U+0027 quotesingle
+!28 U+0028 parenleft
+!29 U+0029 parenright
+!2A U+002A asterisk
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3B U+003B semicolon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!3F U+003F question
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!5B U+005B bracketleft
+!5C U+005C backslash
+!5D U+005D bracketright
+!5E U+005E asciicircum
+!5F U+005F underscore
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7B U+007B braceleft
+!7C U+007C bar
+!7D U+007D braceright
+!7E U+007E asciitilde
+!7F U+007F .notdef
+!80 U+20AC Euro
+!82 U+201A quotesinglbase
+!84 U+201E quotedblbase
+!85 U+2026 ellipsis
+!86 U+2020 dagger
+!87 U+2021 daggerdbl
+!89 U+2030 perthousand
+!8A U+0160 Scaron
+!8B U+2039 guilsinglleft
+!8C U+015A Sacute
+!8D U+0164 Tcaron
+!8E U+017D Zcaron
+!8F U+0179 Zacute
+!91 U+2018 quoteleft
+!92 U+2019 quoteright
+!93 U+201C quotedblleft
+!94 U+201D quotedblright
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!99 U+2122 trademark
+!9A U+0161 scaron
+!9B U+203A guilsinglright
+!9C U+015B sacute
+!9D U+0165 tcaron
+!9E U+017E zcaron
+!9F U+017A zacute
+!A0 U+00A0 space
+!A1 U+02C7 caron
+!A2 U+02D8 breve
+!A3 U+0141 Lslash
+!A4 U+00A4 currency
+!A5 U+0104 Aogonek
+!A6 U+00A6 brokenbar
+!A7 U+00A7 section
+!A8 U+00A8 dieresis
+!A9 U+00A9 copyright
+!AA U+015E Scedilla
+!AB U+00AB guillemotleft
+!AC U+00AC logicalnot
+!AD U+00AD hyphen
+!AE U+00AE registered
+!AF U+017B Zdotaccent
+!B0 U+00B0 degree
+!B1 U+00B1 plusminus
+!B2 U+02DB ogonek
+!B3 U+0142 lslash
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B6 U+00B6 paragraph
+!B7 U+00B7 periodcentered
+!B8 U+00B8 cedilla
+!B9 U+0105 aogonek
+!BA U+015F scedilla
+!BB U+00BB guillemotright
+!BC U+013D Lcaron
+!BD U+02DD hungarumlaut
+!BE U+013E lcaron
+!BF U+017C zdotaccent
+!C0 U+0154 Racute
+!C1 U+00C1 Aacute
+!C2 U+00C2 Acircumflex
+!C3 U+0102 Abreve
+!C4 U+00C4 Adieresis
+!C5 U+0139 Lacute
+!C6 U+0106 Cacute
+!C7 U+00C7 Ccedilla
+!C8 U+010C Ccaron
+!C9 U+00C9 Eacute
+!CA U+0118 Eogonek
+!CB U+00CB Edieresis
+!CC U+011A Ecaron
+!CD U+00CD Iacute
+!CE U+00CE Icircumflex
+!CF U+010E Dcaron
+!D0 U+0110 Dcroat
+!D1 U+0143 Nacute
+!D2 U+0147 Ncaron
+!D3 U+00D3 Oacute
+!D4 U+00D4 Ocircumflex
+!D5 U+0150 Ohungarumlaut
+!D6 U+00D6 Odieresis
+!D7 U+00D7 multiply
+!D8 U+0158 Rcaron
+!D9 U+016E Uring
+!DA U+00DA Uacute
+!DB U+0170 Uhungarumlaut
+!DC U+00DC Udieresis
+!DD U+00DD Yacute
+!DE U+0162 Tcommaaccent
+!DF U+00DF germandbls
+!E0 U+0155 racute
+!E1 U+00E1 aacute
+!E2 U+00E2 acircumflex
+!E3 U+0103 abreve
+!E4 U+00E4 adieresis
+!E5 U+013A lacute
+!E6 U+0107 cacute
+!E7 U+00E7 ccedilla
+!E8 U+010D ccaron
+!E9 U+00E9 eacute
+!EA U+0119 eogonek
+!EB U+00EB edieresis
+!EC U+011B ecaron
+!ED U+00ED iacute
+!EE U+00EE icircumflex
+!EF U+010F dcaron
+!F0 U+0111 dcroat
+!F1 U+0144 nacute
+!F2 U+0148 ncaron
+!F3 U+00F3 oacute
+!F4 U+00F4 ocircumflex
+!F5 U+0151 ohungarumlaut
+!F6 U+00F6 odieresis
+!F7 U+00F7 divide
+!F8 U+0159 rcaron
+!F9 U+016F uring
+!FA U+00FA uacute
+!FB U+0171 uhungarumlaut
+!FC U+00FC udieresis
+!FD U+00FD yacute
+!FE U+0163 tcommaaccent
+!FF U+02D9 dotaccent
Added: branches/print_dev/http/extensions/fpdf/font/makefont/cp1251.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/cp1251.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/cp1251.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,255 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0402 afii10051
+!81 U+0403 afii10052
+!83 U+0453 afii10100
+!86 U+2020 dagger
+!88 U+20AC Euro
+!8A U+0409 afii10058
+!8C U+040A afii10059
+!8D U+040C afii10061
+!8E U+040B afii10060
+!8F U+040F afii10145
+!90 U+0452 afii10099
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!9A U+0459 afii10106
+!9C U+045A afii10107
+!9D U+045C afii10109
+!9E U+045B afii10108
+!9F U+045F afii10193
+!A0 U+00A0 space
+!A1 U+040E afii10062
+!A2 U+045E afii10110
+!A3 U+0408 afii10057
+!A5 U+0490 afii10050
+!A7 U+00A7 section
+!A8 U+0401 afii10023
+!AA U+0404 afii10053
+!AD U+00AD hyphen
+!AF U+0407 afii10056
+!B0 U+00B0 degree
+!B2 U+0406 afii10055
+!B3 U+0456 afii10103
+!B4 U+0491 afii10098
+!B5 U+00B5 mu
+!B8 U+0451 afii10071
+!B9 U+2116 afii61352
+!BA U+0454 afii10101
+!BC U+0458 afii10105
+!BD U+0405 afii10054
+!BE U+0455 afii10102
+!BF U+0457 afii10104
+!C0 U+0410 afii10017
+!C1 U+0411 afii10018
+!C2 U+0412 afii10019
+!C3 U+0413 afii10020
+!C4 U+0414 afii10021
+!C5 U+0415 afii10022
+!C6 U+0416 afii10024
+!C7 U+0417 afii10025
+!C8 U+0418 afii10026
+!C9 U+0419 afii10027
+!CA U+041A afii10028
+!CB U+041B afii10029
+!CC U+041C afii10030
+!CD U+041D afii10031
+!CE U+041E afii10032
+!CF U+041F afii10033
+!D0 U+0420 afii10034
+!D1 U+0421 afii10035
+!D2 U+0422 afii10036
+!D3 U+0423 afii10037
+!D4 U+0424 afii10038
+!D5 U+0425 afii10039
+!D6 U+0426 afii10040
+!D7 U+0427 afii10041
+!D8 U+0428 afii10042
+!D9 U+0429 afii10043
+!DA U+042A afii10044
+!DB U+042B afii10045
+!DC U+042C afii10046
+!DD U+042D afii10047
+!DE U+042E afii10048
+!DF U+042F afii10049
+!E0 U+0430 afii10065
+!E1 U+0431 afii10066
+!E2 U+0432 afii10067
+!E3 U+0433 afii10068
+!E4 U+0434 afii10069
+!E5 U+0435 afii10070
+!E6 U+0436 afii10072
+!E7 U+0437 afii10073
+!E8 U+0438 afii10074
+!E9 U+0439 afii10075
+!EA U+043A afii10076
+!EB U+043B afii10077
+!EC U+043C afii10078
+!ED U+043D afii10079
+!EE U+043E afii10080
+!EF U+043F afii10081
+!F0 U+0440 afii10082
+!F1 U+0441 afii10083
+!F2 U+0442 afii10084
+!F3 U+0443 afii10085
+!F4 U+0444 afii10086
+!F5 U+0445 afii10087
+!F6 U+0446 afii10088
+!F7 U+0447 afii10089
+!F8 U+0448 afii10090
+!F9 U+0449 afii10091
+!FA U+044A afii10092
+!FB U+044B afii10093
+!FC U+044C afii10094
+!FD U+044D afii10095
+!FE U+044E afii10096
+!FF U+044F afii10097
Added: branches/print_dev/http/extensions/fpdf/font/makefont/cp1252.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/cp1252.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/cp1252.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,251 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!83 U+0192 florin
+!86 U+2020 dagger
+!88 U+02C6 circumflex
+!8A U+0160 Scaron
+!8C U+0152 OE
+!8E U+017D Zcaron
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!98 U+02DC tilde
+!9A U+0161 scaron
+!9C U+0153 oe
+!9E U+017E zcaron
+!9F U+0178 Ydieresis
+!A0 U+00A0 space
+!A1 U+00A1 exclamdown
+!A2 U+00A2 cent
+!A3 U+00A3 sterling
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AA U+00AA ordfeminine
+!AD U+00AD hyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B2 U+00B2 twosuperior
+!B3 U+00B3 threesuperior
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B8 U+00B8 cedilla
+!B9 U+00B9 onesuperior
+!BA U+00BA ordmasculine
+!BC U+00BC onequarter
+!BD U+00BD onehalf
+!BE U+00BE threequarters
+!BF U+00BF questiondown
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+00C3 Atilde
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CA U+00CA Ecircumflex
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!CF U+00CF Idieresis
+!D0 U+00D0 Eth
+!D1 U+00D1 Ntilde
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D5 U+00D5 Otilde
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DB U+00DB Ucircumflex
+!DD U+00DD Yacute
+!DE U+00DE Thorn
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+00E3 atilde
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EA U+00EA ecircumflex
+!EC U+00EC igrave
+!ED U+00ED iacute
+!EF U+00EF idieresis
+!F0 U+00F0 eth
+!F1 U+00F1 ntilde
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FB U+00FB ucircumflex
+!FD U+00FD yacute
+!FE U+00FE thorn
+!FF U+00FF ydieresis
Added: branches/print_dev/http/extensions/fpdf/font/makefont/cp1253.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/cp1253.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/cp1253.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,239 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!83 U+0192 florin
+!86 U+2020 dagger
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!A0 U+00A0 space
+!A1 U+0385 dieresistonos
+!A2 U+0386 Alphatonos
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AD U+00AD hyphen
+!AF U+2015 afii00208
+!B0 U+00B0 degree
+!B4 U+0384 tonos
+!B5 U+00B5 mu
+!B8 U+0388 Epsilontonos
+!B9 U+0389 Etatonos
+!BA U+038A Iotatonos
+!BC U+038C Omicrontonos
+!BD U+00BD onehalf
+!BE U+038E Upsilontonos
+!BF U+038F Omegatonos
+!C0 U+0390 iotadieresistonos
+!C1 U+0391 Alpha
+!C2 U+0392 Beta
+!C3 U+0393 Gamma
+!C4 U+0394 Delta
+!C5 U+0395 Epsilon
+!C6 U+0396 Zeta
+!C7 U+0397 Eta
+!C8 U+0398 Theta
+!C9 U+0399 Iota
+!CA U+039A Kappa
+!CB U+039B Lambda
+!CC U+039C Mu
+!CD U+039D Nu
+!CE U+039E Xi
+!CF U+039F Omicron
+!D0 U+03A0 Pi
+!D1 U+03A1 Rho
+!D3 U+03A3 Sigma
+!D4 U+03A4 Tau
+!D5 U+03A5 Upsilon
+!D6 U+03A6 Phi
+!D7 U+03A7 Chi
+!D8 U+03A8 Psi
+!D9 U+03A9 Omega
+!DA U+03AA Iotadieresis
+!DB U+03AB Upsilondieresis
+!DC U+03AC alphatonos
+!DD U+03AD epsilontonos
+!DE U+03AE etatonos
+!DF U+03AF iotatonos
+!E0 U+03B0 upsilondieresistonos
+!E1 U+03B1 alpha
+!E2 U+03B2 beta
+!E3 U+03B3 gamma
+!E4 U+03B4 delta
+!E5 U+03B5 epsilon
+!E6 U+03B6 zeta
+!E7 U+03B7 eta
+!E8 U+03B8 theta
+!E9 U+03B9 iota
+!EA U+03BA kappa
+!EB U+03BB lambda
+!EC U+03BC mu
+!ED U+03BD nu
+!EE U+03BE xi
+!EF U+03BF omicron
+!F0 U+03C0 pi
+!F1 U+03C1 rho
+!F2 U+03C2 sigma1
+!F3 U+03C3 sigma
+!F4 U+03C4 tau
+!F5 U+03C5 upsilon
+!F6 U+03C6 phi
+!F7 U+03C7 chi
+!F8 U+03C8 psi
+!F9 U+03C9 omega
+!FA U+03CA iotadieresis
+!FB U+03CB upsilondieresis
+!FC U+03CC omicrontonos
+!FD U+03CD upsilontonos
+!FE U+03CE omegatonos
Added: branches/print_dev/http/extensions/fpdf/font/makefont/cp1254.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/cp1254.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/cp1254.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,249 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!83 U+0192 florin
+!86 U+2020 dagger
+!8A U+0160 Scaron
+!8C U+0152 OE
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!98 U+02DC tilde
+!9A U+0161 scaron
+!9C U+0153 oe
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AD U+00AD hyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B8 U+00B8 cedilla
+!BD U+00BD onehalf
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+00C3 Atilde
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!D0 U+011E Gbreve
+!D1 U+00D1 Ntilde
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D5 U+00D5 Otilde
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DD U+0130 Idotaccent
+!DE U+015E Scedilla
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+00E3 atilde
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EC U+00EC igrave
+!ED U+00ED iacute
+!F0 U+011F gbreve
+!F1 U+00F1 ntilde
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FD U+0131 dotlessi
+!FE U+015F scedilla
Added: branches/print_dev/http/extensions/fpdf/font/makefont/cp1255.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/cp1255.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/cp1255.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,233 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!83 U+0192 florin
+!86 U+2020 dagger
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!98 U+02DC tilde
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A4 U+20AA afii57636
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AA U+00D7 multiply
+!AD U+00AD sfthyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B7 U+00B7 middot
+!B8 U+00B8 cedilla
+!BA U+00F7 divide
+!BD U+00BD onehalf
+!C0 U+05B0 afii57799
+!C1 U+05B1 afii57801
+!C2 U+05B2 afii57800
+!C3 U+05B3 afii57802
+!C4 U+05B4 afii57793
+!C5 U+05B5 afii57794
+!C6 U+05B6 afii57795
+!C7 U+05B7 afii57798
+!C8 U+05B8 afii57797
+!C9 U+05B9 afii57806
+!CB U+05BB afii57796
+!CC U+05BC afii57807
+!CD U+05BD afii57839
+!CE U+05BE afii57645
+!CF U+05BF afii57841
+!D0 U+05C0 afii57842
+!D1 U+05C1 afii57804
+!D2 U+05C2 afii57803
+!D3 U+05C3 afii57658
+!D4 U+05F0 afii57716
+!D5 U+05F1 afii57717
+!D6 U+05F2 afii57718
+!D7 U+05F3 gereshhebrew
+!D8 U+05F4 gershayimhebrew
+!E0 U+05D0 afii57664
+!E1 U+05D1 afii57665
+!E2 U+05D2 afii57666
+!E3 U+05D3 afii57667
+!E4 U+05D4 afii57668
+!E5 U+05D5 afii57669
+!E6 U+05D6 afii57670
+!E7 U+05D7 afii57671
+!E8 U+05D8 afii57672
+!E9 U+05D9 afii57673
+!EA U+05DA afii57674
+!EB U+05DB afii57675
+!EC U+05DC afii57676
+!ED U+05DD afii57677
+!EE U+05DE afii57678
+!EF U+05DF afii57679
+!F0 U+05E0 afii57680
+!F1 U+05E1 afii57681
+!F2 U+05E2 afii57682
+!F3 U+05E3 afii57683
+!F4 U+05E4 afii57684
+!F5 U+05E5 afii57685
+!F6 U+05E6 afii57686
+!F7 U+05E7 afii57687
+!F8 U+05E8 afii57688
+!F9 U+05E9 afii57689
+!FA U+05EA afii57690
+!FD U+200E afii299
+!FE U+200F afii300
Added: branches/print_dev/http/extensions/fpdf/font/makefont/cp1257.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/cp1257.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/cp1257.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,244 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!86 U+2020 dagger
+!8D U+00A8 dieresis
+!8E U+02C7 caron
+!8F U+00B8 cedilla
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!9D U+00AF macron
+!9E U+02DB ogonek
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A7 U+00A7 section
+!A8 U+00D8 Oslash
+!AA U+0156 Rcommaaccent
+!AD U+00AD hyphen
+!AF U+00C6 AE
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B8 U+00F8 oslash
+!BA U+0157 rcommaaccent
+!BD U+00BD onehalf
+!BF U+00E6 ae
+!C0 U+0104 Aogonek
+!C1 U+012E Iogonek
+!C2 U+0100 Amacron
+!C3 U+0106 Cacute
+!C5 U+00C5 Aring
+!C6 U+0118 Eogonek
+!C7 U+0112 Emacron
+!C8 U+010C Ccaron
+!C9 U+00C9 Eacute
+!CA U+0179 Zacute
+!CB U+0116 Edotaccent
+!CC U+0122 Gcommaaccent
+!CD U+0136 Kcommaaccent
+!CE U+012A Imacron
+!CF U+013B Lcommaaccent
+!D0 U+0160 Scaron
+!D1 U+0143 Nacute
+!D2 U+0145 Ncommaaccent
+!D3 U+00D3 Oacute
+!D4 U+014C Omacron
+!D5 U+00D5 Otilde
+!D8 U+0172 Uogonek
+!D9 U+0141 Lslash
+!DA U+015A Sacute
+!DB U+016A Umacron
+!DD U+017B Zdotaccent
+!DE U+017D Zcaron
+!E0 U+0105 aogonek
+!E1 U+012F iogonek
+!E2 U+0101 amacron
+!E3 U+0107 cacute
+!E5 U+00E5 aring
+!E6 U+0119 eogonek
+!E7 U+0113 emacron
+!E8 U+010D ccaron
+!E9 U+00E9 eacute
+!EA U+017A zacute
+!EB U+0117 edotaccent
+!EC U+0123 gcommaaccent
+!ED U+0137 kcommaaccent
+!EE U+012B imacron
+!EF U+013C lcommaaccent
+!F0 U+0161 scaron
+!F1 U+0144 nacute
+!F2 U+0146 ncommaaccent
+!F3 U+00F3 oacute
+!F4 U+014D omacron
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+0173 uogonek
+!F9 U+0142 lslash
+!FA U+015B sacute
+!FB U+016B umacron
+!FD U+017C zdotaccent
+!FE U+017E zcaron
Added: branches/print_dev/http/extensions/fpdf/font/makefont/cp1258.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/cp1258.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/cp1258.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,247 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!83 U+0192 florin
+!86 U+2020 dagger
+!8C U+0152 OE
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!98 U+02DC tilde
+!9C U+0153 oe
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AD U+00AD hyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B8 U+00B8 cedilla
+!BD U+00BD onehalf
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+0102 Abreve
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CC U+0300 gravecomb
+!CD U+00CD Iacute
+!D0 U+0110 Dcroat
+!D1 U+00D1 Ntilde
+!D2 U+0309 hookabovecomb
+!D3 U+00D3 Oacute
+!D5 U+01A0 Ohorn
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DD U+01AF Uhorn
+!DE U+0303 tildecomb
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+0103 abreve
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EC U+0301 acutecomb
+!ED U+00ED iacute
+!F0 U+0111 dcroat
+!F1 U+00F1 ntilde
+!F2 U+0323 dotbelowcomb
+!F3 U+00F3 oacute
+!F5 U+01A1 ohorn
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FD U+01B0 uhorn
+!FE U+20AB dong
Added: branches/print_dev/http/extensions/fpdf/font/makefont/cp874.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/cp874.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/cp874.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,225 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+20AC Euro
+!95 U+2022 bullet
+!96 U+2013 endash
+!97 U+2014 emdash
+!A0 U+00A0 space
+!A1 U+0E01 kokaithai
+!A2 U+0E02 khokhaithai
+!A3 U+0E03 khokhuatthai
+!A4 U+0E04 khokhwaithai
+!A5 U+0E05 khokhonthai
+!A6 U+0E06 khorakhangthai
+!A7 U+0E07 ngonguthai
+!A8 U+0E08 chochanthai
+!A9 U+0E09 chochingthai
+!AA U+0E0A chochangthai
+!AB U+0E0B sosothai
+!AC U+0E0C chochoethai
+!AD U+0E0D yoyingthai
+!AE U+0E0E dochadathai
+!AF U+0E0F topatakthai
+!B0 U+0E10 thothanthai
+!B1 U+0E11 thonangmonthothai
+!B2 U+0E12 thophuthaothai
+!B3 U+0E13 nonenthai
+!B4 U+0E14 dodekthai
+!B5 U+0E15 totaothai
+!B6 U+0E16 thothungthai
+!B7 U+0E17 thothahanthai
+!B8 U+0E18 thothongthai
+!B9 U+0E19 nonuthai
+!BA U+0E1A bobaimaithai
+!BB U+0E1B poplathai
+!BC U+0E1C phophungthai
+!BD U+0E1D fofathai
+!BE U+0E1E phophanthai
+!BF U+0E1F fofanthai
+!C0 U+0E20 phosamphaothai
+!C1 U+0E21 momathai
+!C2 U+0E22 yoyakthai
+!C3 U+0E23 roruathai
+!C4 U+0E24 ruthai
+!C5 U+0E25 lolingthai
+!C6 U+0E26 luthai
+!C7 U+0E27 wowaenthai
+!C8 U+0E28 sosalathai
+!C9 U+0E29 sorusithai
+!CA U+0E2A sosuathai
+!CB U+0E2B hohipthai
+!CC U+0E2C lochulathai
+!CD U+0E2D oangthai
+!CE U+0E2E honokhukthai
+!CF U+0E2F paiyannoithai
+!D0 U+0E30 saraathai
+!D1 U+0E31 maihanakatthai
+!D2 U+0E32 saraaathai
+!D3 U+0E33 saraamthai
+!D4 U+0E34 saraithai
+!D5 U+0E35 saraiithai
+!D6 U+0E36 sarauethai
+!D7 U+0E37 saraueethai
+!D8 U+0E38 sarauthai
+!D9 U+0E39 sarauuthai
+!DA U+0E3A phinthuthai
+!DF U+0E3F bahtthai
+!E0 U+0E40 saraethai
+!E1 U+0E41 saraaethai
+!E2 U+0E42 saraothai
+!E3 U+0E43 saraaimaimuanthai
+!E4 U+0E44 saraaimaimalaithai
+!E5 U+0E45 lakkhangyaothai
+!E6 U+0E46 maiyamokthai
+!E7 U+0E47 maitaikhuthai
+!E8 U+0E48 maiekthai
+!E9 U+0E49 maithothai
+!EA U+0E4A maitrithai
+!EB U+0E4B maichattawathai
+!EC U+0E4C thanthakhatthai
+!ED U+0E4D nikhahitthai
+!EE U+0E4E yamakkanthai
+!EF U+0E4F fongmanthai
+!F0 U+0E50 zerothai
+!F1 U+0E51 onethai
+!F2 U+0E52 twothai
+!F3 U+0E53 threethai
+!F4 U+0E54 fourthai
+!F5 U+0E55 fivethai
+!F6 U+0E56 sixthai
+!F7 U+0E57 seventhai
+!F8 U+0E58 eightthai
+!F9 U+0E59 ninethai
+!FA U+0E5A angkhankhuthai
+!FB U+0E5B khomutthai
Added: branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-1.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-1.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-1.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AD U+00AD hyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B8 U+00B8 cedilla
+!BD U+00BD onehalf
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+00C3 Atilde
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!D0 U+00D0 Eth
+!D1 U+00D1 Ntilde
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D5 U+00D5 Otilde
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DD U+00DD Yacute
+!DE U+00DE Thorn
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+00E3 atilde
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EC U+00EC igrave
+!ED U+00ED iacute
+!F0 U+00F0 eth
+!F1 U+00F1 ntilde
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FD U+00FD yacute
+!FE U+00FE thorn
Added: branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-11.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-11.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-11.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,248 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!C4 U+0E24 ruthai
+!C6 U+0E26 luthai
+!F1 U+0E51 onethai
+!F2 U+0E52 twothai
+!F6 U+0E56 sixthai
Added: branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-15.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-15.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-15.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A4 U+20AC Euro
+!A5 U+00A5 yen
+!A6 U+0160 Scaron
+!A7 U+00A7 section
+!A8 U+0161 scaron
+!AD U+00AD hyphen
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+017D Zcaron
+!B5 U+00B5 mu
+!B8 U+017E zcaron
+!BC U+0152 OE
+!BD U+0153 oe
+!BE U+0178 Ydieresis
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+00C3 Atilde
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!D0 U+00D0 Eth
+!D1 U+00D1 Ntilde
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D5 U+00D5 Otilde
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DD U+00DD Yacute
+!DE U+00DE Thorn
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+00E3 atilde
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EC U+00EC igrave
+!ED U+00ED iacute
+!F0 U+00F0 eth
+!F1 U+00F1 ntilde
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FD U+00FD yacute
+!FE U+00FE thorn
Added: branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-16.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-16.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-16.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A1 U+0104 Aogonek
+!A2 U+0105 aogonek
+!A3 U+0141 Lslash
+!A4 U+20AC Euro
+!A5 U+201E quotedblbase
+!A6 U+0160 Scaron
+!A7 U+00A7 section
+!A8 U+0161 scaron
+!AA U+0218 Scommaaccent
+!AC U+0179 Zacute
+!AD U+00AD hyphen
+!AE U+017A zacute
+!B0 U+00B0 degree
+!B2 U+010C Ccaron
+!B3 U+0142 lslash
+!B4 U+017D Zcaron
+!B5 U+201D quotedblright
+!B8 U+017E zcaron
+!B9 U+010D ccaron
+!BA U+0219 scommaaccent
+!BC U+0152 OE
+!BD U+0153 oe
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C3 U+0102 Abreve
+!C5 U+0106 Cacute
+!C6 U+00C6 AE
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!D0 U+0110 Dcroat
+!D1 U+0143 Nacute
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D7 U+015A Sacute
+!D8 U+0170 Uhungarumlaut
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DD U+0118 Eogonek
+!DE U+021A Tcommaaccent
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E3 U+0103 abreve
+!E5 U+0107 cacute
+!E6 U+00E6 ae
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EC U+00EC igrave
+!ED U+00ED iacute
+!F0 U+0111 dcroat
+!F1 U+0144 nacute
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F7 U+015B sacute
+!F8 U+0171 uhungarumlaut
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FD U+0119 eogonek
+!FE U+021B tcommaaccent
Added: branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-2.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-2.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-2.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A1 U+0104 Aogonek
+!A2 U+02D8 breve
+!A3 U+0141 Lslash
+!A5 U+013D Lcaron
+!A6 U+015A Sacute
+!A7 U+00A7 section
+!A9 U+0160 Scaron
+!AB U+0164 Tcaron
+!AC U+0179 Zacute
+!AD U+00AD hyphen
+!AE U+017D Zcaron
+!B0 U+00B0 degree
+!B1 U+0105 aogonek
+!B2 U+02DB ogonek
+!B3 U+0142 lslash
+!B4 U+00B4 acute
+!B5 U+013E lcaron
+!B6 U+015B sacute
+!B7 U+02C7 caron
+!B8 U+00B8 cedilla
+!B9 U+0161 scaron
+!BB U+0165 tcaron
+!BC U+017A zacute
+!BE U+017E zcaron
+!C0 U+0154 Racute
+!C1 U+00C1 Aacute
+!C3 U+0102 Abreve
+!C5 U+0139 Lacute
+!C6 U+0106 Cacute
+!C8 U+010C Ccaron
+!C9 U+00C9 Eacute
+!CA U+0118 Eogonek
+!CC U+011A Ecaron
+!CD U+00CD Iacute
+!CF U+010E Dcaron
+!D0 U+0110 Dcroat
+!D1 U+0143 Nacute
+!D2 U+0147 Ncaron
+!D3 U+00D3 Oacute
+!D8 U+0158 Rcaron
+!D9 U+016E Uring
+!DA U+00DA Uacute
+!DD U+00DD Yacute
+!E0 U+0155 racute
+!E1 U+00E1 aacute
+!E3 U+0103 abreve
+!E5 U+013A lacute
+!E6 U+0107 cacute
+!E8 U+010D ccaron
+!E9 U+00E9 eacute
+!EA U+0119 eogonek
+!EC U+011B ecaron
+!ED U+00ED iacute
+!EF U+010F dcaron
+!F0 U+0111 dcroat
+!F1 U+0144 nacute
+!F2 U+0148 ncaron
+!F3 U+00F3 oacute
+!F7 U+00F7 divide
+!F8 U+0159 rcaron
+!F9 U+016F uring
+!FA U+00FA uacute
+!FD U+00FD yacute
Added: branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-4.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-4.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-4.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A1 U+0104 Aogonek
+!A2 U+0138 kgreenlandic
+!A3 U+0156 Rcommaaccent
+!A5 U+0128 Itilde
+!A6 U+013B Lcommaaccent
+!A7 U+00A7 section
+!A9 U+0160 Scaron
+!AA U+0112 Emacron
+!AB U+0122 Gcommaaccent
+!AC U+0166 Tbar
+!AD U+00AD hyphen
+!AE U+017D Zcaron
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B1 U+0105 aogonek
+!B2 U+02DB ogonek
+!B3 U+0157 rcommaaccent
+!B4 U+00B4 acute
+!B5 U+0129 itilde
+!B6 U+013C lcommaaccent
+!B7 U+02C7 caron
+!B8 U+00B8 cedilla
+!B9 U+0161 scaron
+!BA U+0113 emacron
+!BB U+0123 gcommaaccent
+!BC U+0167 tbar
+!BD U+014A Eng
+!BE U+017E zcaron
+!BF U+014B eng
+!C0 U+0100 Amacron
+!C1 U+00C1 Aacute
+!C3 U+00C3 Atilde
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C7 U+012E Iogonek
+!C8 U+010C Ccaron
+!C9 U+00C9 Eacute
+!CA U+0118 Eogonek
+!CC U+0116 Edotaccent
+!CD U+00CD Iacute
+!CF U+012A Imacron
+!D0 U+0110 Dcroat
+!D1 U+0145 Ncommaaccent
+!D2 U+014C Omacron
+!D3 U+0136 Kcommaaccent
+!D5 U+00D5 Otilde
+!D8 U+00D8 Oslash
+!D9 U+0172 Uogonek
+!DA U+00DA Uacute
+!DD U+0168 Utilde
+!DE U+016A Umacron
+!E0 U+0101 amacron
+!E1 U+00E1 aacute
+!E3 U+00E3 atilde
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E7 U+012F iogonek
+!E8 U+010D ccaron
+!E9 U+00E9 eacute
+!EA U+0119 eogonek
+!EC U+0117 edotaccent
+!ED U+00ED iacute
+!EF U+012B imacron
+!F0 U+0111 dcroat
+!F1 U+0146 ncommaaccent
+!F2 U+014D omacron
+!F3 U+0137 kcommaaccent
+!F5 U+00F5 otilde
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+0173 uogonek
+!FA U+00FA uacute
+!FD U+0169 utilde
+!FE U+016B umacron
Added: branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-5.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-5.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-5.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A1 U+0401 afii10023
+!A2 U+0402 afii10051
+!A3 U+0403 afii10052
+!A4 U+0404 afii10053
+!A5 U+0405 afii10054
+!A6 U+0406 afii10055
+!A7 U+0407 afii10056
+!A8 U+0408 afii10057
+!A9 U+0409 afii10058
+!AA U+040A afii10059
+!AB U+040B afii10060
+!AC U+040C afii10061
+!AD U+00AD hyphen
+!AE U+040E afii10062
+!AF U+040F afii10145
+!B0 U+0410 afii10017
+!B1 U+0411 afii10018
+!B2 U+0412 afii10019
+!B3 U+0413 afii10020
+!B4 U+0414 afii10021
+!B5 U+0415 afii10022
+!B6 U+0416 afii10024
+!B7 U+0417 afii10025
+!B8 U+0418 afii10026
+!B9 U+0419 afii10027
+!BA U+041A afii10028
+!BB U+041B afii10029
+!BC U+041C afii10030
+!BD U+041D afii10031
+!BE U+041E afii10032
+!BF U+041F afii10033
+!C0 U+0420 afii10034
+!C1 U+0421 afii10035
+!C2 U+0422 afii10036
+!C3 U+0423 afii10037
+!C4 U+0424 afii10038
+!C5 U+0425 afii10039
+!C6 U+0426 afii10040
+!C7 U+0427 afii10041
+!C8 U+0428 afii10042
+!C9 U+0429 afii10043
+!CA U+042A afii10044
+!CB U+042B afii10045
+!CC U+042C afii10046
+!CD U+042D afii10047
+!CE U+042E afii10048
+!CF U+042F afii10049
+!D0 U+0430 afii10065
+!D1 U+0431 afii10066
+!D2 U+0432 afii10067
+!D3 U+0433 afii10068
+!D4 U+0434 afii10069
+!D5 U+0435 afii10070
+!D6 U+0436 afii10072
+!D7 U+0437 afii10073
+!D8 U+0438 afii10074
+!D9 U+0439 afii10075
+!DA U+043A afii10076
+!DB U+043B afii10077
+!DC U+043C afii10078
+!DD U+043D afii10079
+!DE U+043E afii10080
+!DF U+043F afii10081
+!E0 U+0440 afii10082
+!E1 U+0441 afii10083
+!E2 U+0442 afii10084
+!E3 U+0443 afii10085
+!E4 U+0444 afii10086
+!E5 U+0445 afii10087
+!E6 U+0446 afii10088
+!E7 U+0447 afii10089
+!E8 U+0448 afii10090
+!E9 U+0449 afii10091
+!EA U+044A afii10092
+!EB U+044B afii10093
+!EC U+044C afii10094
+!ED U+044D afii10095
+!EE U+044E afii10096
+!EF U+044F afii10097
+!F0 U+2116 afii61352
+!F1 U+0451 afii10071
+!F2 U+0452 afii10099
+!F3 U+0453 afii10100
+!F4 U+0454 afii10101
+!F5 U+0455 afii10102
+!F6 U+0456 afii10103
+!F7 U+0457 afii10104
+!F8 U+0458 afii10105
+!F9 U+0459 afii10106
+!FA U+045A afii10107
+!FB U+045B afii10108
+!FC U+045C afii10109
+!FD U+00A7 section
+!FE U+045E afii10110
+!FF U+045F afii10193
Added: branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-7.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-7.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-7.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,250 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!22 U+0022 quotedbl
+!23 U+0023 numbersign
+!24 U+0024 dollar
+!25 U+0025 percent
+!26 U+0026 ampersand
+!27 U+0027 quotesingle
+!28 U+0028 parenleft
+!29 U+0029 parenright
+!2A U+002A asterisk
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3B U+003B semicolon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!3F U+003F question
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!5B U+005B bracketleft
+!5C U+005C backslash
+!5D U+005D bracketright
+!5E U+005E asciicircum
+!5F U+005F underscore
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7B U+007B braceleft
+!7C U+007C bar
+!7D U+007D braceright
+!7E U+007E asciitilde
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A1 U+2018 quoteleft
+!A2 U+2019 quoteright
+!A6 U+00A6 brokenbar
+!A7 U+00A7 section
+!A8 U+00A8 dieresis
+!A9 U+00A9 copyright
+!AB U+00AB guillemotleft
+!AC U+00AC logicalnot
+!AD U+00AD hyphen
+!B0 U+00B0 degree
+!B1 U+00B1 plusminus
+!B4 U+0384 tonos
+!B5 U+0385 dieresistonos
+!B6 U+0386 Alphatonos
+!B7 U+00B7 periodcentered
+!BB U+00BB guillemotright
+!BD U+00BD onehalf
+!C1 U+0391 Alpha
+!C2 U+0392 Beta
+!C3 U+0393 Gamma
+!C4 U+0394 Delta
+!C5 U+0395 Epsilon
+!C6 U+0396 Zeta
+!C7 U+0397 Eta
+!C8 U+0398 Theta
+!C9 U+0399 Iota
+!CA U+039A Kappa
+!CB U+039B Lambda
+!CC U+039C Mu
+!CD U+039D Nu
+!CE U+039E Xi
+!CF U+039F Omicron
+!D0 U+03A0 Pi
+!D1 U+03A1 Rho
+!D3 U+03A3 Sigma
+!D4 U+03A4 Tau
+!D5 U+03A5 Upsilon
+!D6 U+03A6 Phi
+!D7 U+03A7 Chi
+!D8 U+03A8 Psi
+!D9 U+03A9 Omega
+!E1 U+03B1 alpha
+!E2 U+03B2 beta
+!E3 U+03B3 gamma
+!E4 U+03B4 delta
+!E5 U+03B5 epsilon
+!E6 U+03B6 zeta
+!E7 U+03B7 eta
+!E8 U+03B8 theta
+!E9 U+03B9 iota
+!EA U+03BA kappa
+!EB U+03BB lambda
+!EC U+03BC mu
+!ED U+03BD nu
+!EE U+03BE xi
+!EF U+03BF omicron
+!F0 U+03C0 pi
+!F1 U+03C1 rho
+!F2 U+03C2 sigma1
+!F3 U+03C3 sigma
+!F4 U+03C4 tau
+!F5 U+03C5 upsilon
+!F6 U+03C6 phi
+!F7 U+03C7 chi
+!F8 U+03C8 psi
+!F9 U+03C9 omega
Added: branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-9.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-9.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/iso-8859-9.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+0080 .notdef
+!81 U+0081 .notdef
+!82 U+0082 .notdef
+!83 U+0083 .notdef
+!84 U+0084 .notdef
+!85 U+0085 .notdef
+!86 U+0086 .notdef
+!87 U+0087 .notdef
+!88 U+0088 .notdef
+!89 U+0089 .notdef
+!8A U+008A .notdef
+!8B U+008B .notdef
+!8C U+008C .notdef
+!8D U+008D .notdef
+!8E U+008E .notdef
+!8F U+008F .notdef
+!90 U+0090 .notdef
+!91 U+0091 .notdef
+!92 U+0092 .notdef
+!93 U+0093 .notdef
+!94 U+0094 .notdef
+!95 U+0095 .notdef
+!96 U+0096 .notdef
+!97 U+0097 .notdef
+!98 U+0098 .notdef
+!99 U+0099 .notdef
+!9A U+009A .notdef
+!9B U+009B .notdef
+!9C U+009C .notdef
+!9D U+009D .notdef
+!9E U+009E .notdef
+!9F U+009F .notdef
+!A0 U+00A0 space
+!A2 U+00A2 cent
+!A4 U+00A4 currency
+!A5 U+00A5 yen
+!A7 U+00A7 section
+!AD U+00AD hyphen
+!AE U+00AE registered
+!AF U+00AF macron
+!B0 U+00B0 degree
+!B4 U+00B4 acute
+!B5 U+00B5 mu
+!B6 U+00B6 paragraph
+!B8 U+00B8 cedilla
+!BD U+00BD onehalf
+!C0 U+00C0 Agrave
+!C1 U+00C1 Aacute
+!C2 U+00C2 Acircumflex
+!C3 U+00C3 Atilde
+!C4 U+00C4 Adieresis
+!C5 U+00C5 Aring
+!C6 U+00C6 AE
+!C7 U+00C7 Ccedilla
+!C8 U+00C8 Egrave
+!C9 U+00C9 Eacute
+!CB U+00CB Edieresis
+!CC U+00CC Igrave
+!CD U+00CD Iacute
+!CE U+00CE Icircumflex
+!D0 U+011E Gbreve
+!D1 U+00D1 Ntilde
+!D2 U+00D2 Ograve
+!D3 U+00D3 Oacute
+!D4 U+00D4 Ocircumflex
+!D5 U+00D5 Otilde
+!D6 U+00D6 Odieresis
+!D7 U+00D7 multiply
+!D8 U+00D8 Oslash
+!D9 U+00D9 Ugrave
+!DA U+00DA Uacute
+!DC U+00DC Udieresis
+!DF U+00DF germandbls
+!E0 U+00E0 agrave
+!E1 U+00E1 aacute
+!E2 U+00E2 acircumflex
+!E3 U+00E3 atilde
+!E4 U+00E4 adieresis
+!E5 U+00E5 aring
+!E6 U+00E6 ae
+!E7 U+00E7 ccedilla
+!E8 U+00E8 egrave
+!E9 U+00E9 eacute
+!EB U+00EB edieresis
+!EC U+00EC igrave
+!ED U+00ED iacute
+!EE U+00EE icircumflex
+!F0 U+011F gbreve
+!F1 U+00F1 ntilde
+!F2 U+00F2 ograve
+!F3 U+00F3 oacute
+!F4 U+00F4 ocircumflex
+!F5 U+00F5 otilde
+!F6 U+00F6 odieresis
+!F7 U+00F7 divide
+!F8 U+00F8 oslash
+!F9 U+00F9 ugrave
+!FA U+00FA uacute
+!FC U+00FC udieresis
Added: branches/print_dev/http/extensions/fpdf/font/makefont/koi8-r.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/koi8-r.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/koi8-r.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!80 U+2500 SF100000
+!81 U+2502 SF110000
+!82 U+250C SF010000
+!83 U+2510 SF030000
+!84 U+2514 SF020000
+!85 U+2518 SF040000
+!86 U+251C SF080000
+!87 U+2524 SF090000
+!88 U+252C SF060000
+!89 U+2534 SF070000
+!8A U+253C SF050000
+!8B U+2580 upblock
+!8C U+2584 dnblock
+!8D U+2588 block
+!8E U+258C lfblock
+!8F U+2590 rtblock
+!90 U+2591 ltshade
+!91 U+2592 shade
+!92 U+2593 dkshade
+!93 U+2320 integraltp
+!94 U+25A0 filledbox
+!95 U+2219 periodcentered
+!96 U+221A radical
+!97 U+2248 approxequal
+!98 U+2264 lessequal
+!99 U+2265 greaterequal
+!9A U+00A0 space
+!9B U+2321 integralbt
+!9C U+00B0 degree
+!9D U+00B2 twosuperior
+!9E U+00B7 periodcentered
+!9F U+00F7 divide
+!A0 U+2550 SF430000
+!A1 U+2551 SF240000
+!A2 U+2552 SF510000
+!A3 U+0451 afii10071
+!A4 U+2553 SF520000
+!A5 U+2554 SF390000
+!A6 U+2555 SF220000
+!A7 U+2556 SF210000
+!A8 U+2557 SF250000
+!A9 U+2558 SF500000
+!AA U+2559 SF490000
+!AB U+255A SF380000
+!AC U+255B SF280000
+!AD U+255C SF270000
+!AE U+255D SF260000
+!AF U+255E SF360000
+!B0 U+255F SF370000
+!B1 U+2560 SF420000
+!B2 U+2561 SF190000
+!B3 U+0401 afii10023
+!B4 U+2562 SF200000
+!B5 U+2563 SF230000
+!B6 U+2564 SF470000
+!B7 U+2565 SF480000
+!B8 U+2566 SF410000
+!B9 U+2567 SF450000
+!BA U+2568 SF460000
+!BB U+2569 SF400000
+!BC U+256A SF540000
+!BD U+256B SF530000
+!BE U+256C SF440000
+!BF U+00A9 copyright
+!C0 U+044E afii10096
+!C1 U+0430 afii10065
+!C2 U+0431 afii10066
+!C3 U+0446 afii10088
+!C4 U+0434 afii10069
+!C5 U+0435 afii10070
+!C6 U+0444 afii10086
+!C7 U+0433 afii10068
+!C8 U+0445 afii10087
+!C9 U+0438 afii10074
+!CA U+0439 afii10075
+!CB U+043A afii10076
+!CC U+043B afii10077
+!CD U+043C afii10078
+!CE U+043D afii10079
+!CF U+043E afii10080
+!D0 U+043F afii10081
+!D1 U+044F afii10097
+!D2 U+0440 afii10082
+!D3 U+0441 afii10083
+!D4 U+0442 afii10084
+!D5 U+0443 afii10085
+!D7 U+0432 afii10067
+!D8 U+044C afii10094
+!D9 U+044B afii10093
+!DA U+0437 afii10073
+!DB U+0448 afii10090
+!DC U+044D afii10095
+!DD U+0449 afii10091
+!DE U+0447 afii10089
+!DF U+044A afii10092
+!E0 U+042E afii10048
+!E1 U+0410 afii10017
+!E2 U+0411 afii10018
+!E3 U+0426 afii10040
+!E4 U+0414 afii10021
+!E5 U+0415 afii10022
+!E6 U+0424 afii10038
+!E7 U+0413 afii10020
+!E8 U+0425 afii10039
+!E9 U+0418 afii10026
+!EA U+0419 afii10027
+!EB U+041A afii10028
+!EC U+041B afii10029
+!ED U+041C afii10030
+!EE U+041D afii10031
+!EF U+041E afii10032
+!F0 U+041F afii10033
+!F1 U+042F afii10049
+!F2 U+0420 afii10034
+!F3 U+0421 afii10035
+!F4 U+0422 afii10036
+!F5 U+0423 afii10037
+!F6 U+0416 afii10024
+!F7 U+0412 afii10019
+!F8 U+042C afii10046
+!F9 U+042B afii10045
+!FA U+0417 afii10025
+!FB U+0428 afii10042
+!FC U+042D afii10047
+!FD U+0429 afii10043
+!FE U+0427 afii10041
+!FF U+042A afii10044
Added: branches/print_dev/http/extensions/fpdf/font/makefont/koi8-u.map
--- branches/print_dev/http/extensions/fpdf/font/makefont/koi8-u.map (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/koi8-u.map 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,256 @@
+!00 U+0000 .notdef
+!01 U+0001 .notdef
+!02 U+0002 .notdef
+!03 U+0003 .notdef
+!04 U+0004 .notdef
+!05 U+0005 .notdef
+!06 U+0006 .notdef
+!07 U+0007 .notdef
+!08 U+0008 .notdef
+!09 U+0009 .notdef
+!0A U+000A .notdef
+!0B U+000B .notdef
+!0C U+000C .notdef
+!0D U+000D .notdef
+!0E U+000E .notdef
+!0F U+000F .notdef
+!10 U+0010 .notdef
+!11 U+0011 .notdef
+!12 U+0012 .notdef
+!13 U+0013 .notdef
+!14 U+0014 .notdef
+!15 U+0015 .notdef
+!16 U+0016 .notdef
+!17 U+0017 .notdef
+!18 U+0018 .notdef
+!19 U+0019 .notdef
+!1A U+001A .notdef
+!1B U+001B .notdef
+!1C U+001C .notdef
+!1D U+001D .notdef
+!1E U+001E .notdef
+!1F U+001F .notdef
+!20 U+0020 space
+!21 U+0021 exclam
+!24 U+0024 dollar
+!25 U+0025 percent
+!2B U+002B plus
+!2C U+002C comma
+!2D U+002D hyphen
+!2E U+002E period
+!2F U+002F slash
+!30 U+0030 zero
+!31 U+0031 one
+!32 U+0032 two
+!33 U+0033 three
+!34 U+0034 four
+!35 U+0035 five
+!36 U+0036 six
+!37 U+0037 seven
+!38 U+0038 eight
+!39 U+0039 nine
+!3A U+003A colon
+!3C U+003C less
+!3D U+003D equal
+!3E U+003E greater
+!40 U+0040 at
+!41 U+0041 A
+!42 U+0042 B
+!43 U+0043 C
+!44 U+0044 D
+!45 U+0045 E
+!46 U+0046 F
+!47 U+0047 G
+!48 U+0048 H
+!49 U+0049 I
+!4A U+004A J
+!4B U+004B K
+!4C U+004C L
+!4D U+004D M
+!4E U+004E N
+!4F U+004F O
+!50 U+0050 P
+!51 U+0051 Q
+!52 U+0052 R
+!53 U+0053 S
+!54 U+0054 T
+!55 U+0055 U
+!56 U+0056 V
+!57 U+0057 W
+!58 U+0058 X
+!59 U+0059 Y
+!5A U+005A Z
+!60 U+0060 grave
+!61 U+0061 a
+!62 U+0062 b
+!63 U+0063 c
+!64 U+0064 d
+!65 U+0065 e
+!66 U+0066 f
+!67 U+0067 g
+!68 U+0068 h
+!69 U+0069 i
+!6A U+006A j
+!6B U+006B k
+!6C U+006C l
+!6D U+006D m
+!6E U+006E n
+!6F U+006F o
+!70 U+0070 p
+!71 U+0071 q
+!72 U+0072 r
+!73 U+0073 s
+!74 U+0074 t
+!75 U+0075 u
+!76 U+0076 v
+!77 U+0077 w
+!78 U+0078 x
+!79 U+0079 y
+!7A U+007A z
+!7C U+007C bar
+!7F U+007F .notdef
+!8B U+2580 upblock
+!8C U+2584 dnblock
+!8D U+2588 block
+!8E U+258C lfblock
+!8F U+2590 rtblock
+!90 U+2591 ltshade
+!91 U+2592 shade
+!92 U+2593 dkshade
+!95 U+2022 bullet
+!96 U+221A radical
+!9A U+00A0 space
+!9C U+00B0 degree
+!9F U+00F7 divide
+!A4 U+0454 afii10101
+!A6 U+0456 afii10103
+!A7 U+0457 afii10104
+!AD U+0491 afii10098
+!B4 U+0404 afii10053
+!B6 U+0406 afii10055
+!B7 U+0407 afii10056
+!BD U+0490 afii10050
Added: branches/print_dev/http/extensions/fpdf/font/makefont/makefont.php
--- branches/print_dev/http/extensions/fpdf/font/makefont/makefont.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/makefont/makefont.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,419 @@
+<?php
+* Utility to generate font definition files *
+* Version: 1.14 *
+* Date: 2008-08-03 *
+* Author: Olivier PLATHEY *
+function ReadMap($enc)
+ //Read a map file
+ $file=dirname(__FILE__).'/'.strtolower($enc).'.map';
+ $a=file($file);
+ if(empty($a))
+ die('<b>Error:</b> encoding not found: '.$enc);
+ $cc2gn=array();
+ foreach($a as $l)
+ if($l[0]=='!')
+ $e=preg_split('/[ \\t]+/',rtrim($l));
+ $cc=hexdec(substr($e[0],1));
+ $gn=$e[2];
+ $cc2gn[$cc]=$gn;
+ for($i=0;$i<=255;$i++)
+ if(!isset($cc2gn[$i]))
+ $cc2gn[$i]='.notdef';
+ return $cc2gn;
+function ReadAFM($file, &$map)
+ //Read a font metric file
+ $a=file($file);
+ if(empty($a))
+ die('File not found');
+ $widths=array();
+ $fm=array();
+ $fix=array('Edot'=>'Edotaccent','edot'=>'edotaccent','Idot'=>'Idotaccent','Zdot'=>'Zdotaccent','zdot'=>'zdotaccent',
+ 'Odblacute'=>'Ohungarumlaut','odblacute'=>'ohungarumlaut','Udblacute'=>'Uhungarumlaut','udblacute'=>'uhungarumlaut',
+ 'Gcedilla'=>'Gcommaaccent','gcedilla'=>'gcommaaccent','Kcedilla'=>'Kcommaaccent','kcedilla'=>'kcommaaccent',
+ 'Lcedilla'=>'Lcommaaccent','lcedilla'=>'lcommaaccent','Ncedilla'=>'Ncommaaccent','ncedilla'=>'ncommaaccent',
+ 'Rcedilla'=>'Rcommaaccent','rcedilla'=>'rcommaaccent','Scedilla'=>'Scommaaccent','scedilla'=>'scommaaccent',
+ 'Tcedilla'=>'Tcommaaccent','tcedilla'=>'tcommaaccent','Dslash'=>'Dcroat','dslash'=>'dcroat','Dmacron'=>'Dcroat','dmacron'=>'dcroat',
+ 'combininggraveaccent'=>'gravecomb','combininghookabove'=>'hookabovecomb','combiningtildeaccent'=>'tildecomb',
+ 'combiningacuteaccent'=>'acutecomb','combiningdotbelow'=>'dotbelowcomb','dongsign'=>'dong');
+ foreach($a as $l)
+ $e=explode(' ',rtrim($l));
+ if(count($e)<2)
+ continue;
+ $code=$e[0];
+ $param=$e[1];
+ if($code=='C')
+ //Character metrics
+ $cc=(int)$e[1];
+ $w=$e[4];
+ $gn=$e[7];
+ if(substr($gn,-4)=='20AC')
+ $gn='Euro';
+ if(isset($fix[$gn]))
+ //Fix incorrect glyph name
+ foreach($map as $c=>$n)
+ if($n==$fix[$gn])
+ $map[$c]=$gn;
+ if(empty($map))
+ //Symbolic font: use built-in encoding
+ $widths[$cc]=$w;
+ else
+ $widths[$gn]=$w;
+ if($gn=='X')
+ $fm['CapXHeight']=$e[13];
+ if($gn=='.notdef')
+ $fm['MissingWidth']=$w;
+ elseif($code=='FontName')
+ $fm['FontName']=$param;
+ elseif($code=='Weight')
+ $fm['Weight']=$param;
+ elseif($code=='ItalicAngle')
+ $fm['ItalicAngle']=(double)$param;
+ elseif($code=='Ascender')
+ $fm['Ascender']=(int)$param;
+ elseif($code=='Descender')
+ $fm['Descender']=(int)$param;
+ elseif($code=='UnderlineThickness')
+ $fm['UnderlineThickness']=(int)$param;
+ elseif($code=='UnderlinePosition')
+ $fm['UnderlinePosition']=(int)$param;
+ elseif($code=='IsFixedPitch')
+ $fm['IsFixedPitch']=($param=='true');
+ elseif($code=='FontBBox')
+ $fm['FontBBox']=array($e[1],$e[2],$e[3],$e[4]);
+ elseif($code=='CapHeight')
+ $fm['CapHeight']=(int)$param;
+ elseif($code=='StdVW')
+ $fm['StdVW']=(int)$param;
+ if(!isset($fm['FontName']))
+ die('FontName not found');
+ if(!empty($map))
+ if(!isset($widths['.notdef']))
+ $widths['.notdef']=600;
+ if(!isset($widths['Delta']) && isset($widths['increment']))
+ $widths['Delta']=$widths['increment'];
+ //Order widths according to map
+ if(!isset($widths[$map[$i]]))
+ echo '<b>Warning:</b> character '.$map[$i].' is missing<br>';
+ $widths[$i]=$widths['.notdef'];
+ else
+ $widths[$i]=$widths[$map[$i]];
+ $fm['Widths']=$widths;
+ return $fm;
+function MakeFontDescriptor($fm, $symbolic)
+ //Ascent
+ $asc=(isset($fm['Ascender']) ? $fm['Ascender'] : 1000);
+ $fd="array('Ascent'=>".$asc;
+ //Descent
+ $desc=(isset($fm['Descender']) ? $fm['Descender'] : -200);
+ $fd.=",'Descent'=>".$desc;
+ //CapHeight
+ if(isset($fm['CapHeight']))
+ $ch=$fm['CapHeight'];
+ elseif(isset($fm['CapXHeight']))
+ $ch=$fm['CapXHeight'];
+ else
+ $ch=$asc;
+ $fd.=",'CapHeight'=>".$ch;
+ //Flags
+ $flags=0;
+ if(isset($fm['IsFixedPitch']) && $fm['IsFixedPitch'])
+ $flags+=1<<0;
+ if($symbolic)
+ $flags+=1<<2;
+ if(!$symbolic)
+ $flags+=1<<5;
+ if(isset($fm['ItalicAngle']) && $fm['ItalicAngle']!=0)
+ $flags+=1<<6;
+ $fd.=",'Flags'=>".$flags;
+ //FontBBox
+ if(isset($fm['FontBBox']))
+ $fbb=$fm['FontBBox'];
+ else
+ $fbb=array(0,$desc-100,1000,$asc+100);
+ $fd.=",'FontBBox'=>'[".$fbb[0].' '.$fbb[1].' '.$fbb[2].' '.$fbb[3]."]'";
+ //ItalicAngle
+ $ia=(isset($fm['ItalicAngle']) ? $fm['ItalicAngle'] : 0);
+ $fd.=",'ItalicAngle'=>".$ia;
+ //StemV
+ if(isset($fm['StdVW']))
+ $stemv=$fm['StdVW'];
+ elseif(isset($fm['Weight']) && preg_match('/bold|black/i',$fm['Weight']))
+ $stemv=120;
+ else
+ $stemv=70;
+ $fd.=",'StemV'=>".$stemv;
+ //MissingWidth
+ if(isset($fm['MissingWidth']))
+ $fd.=",'MissingWidth'=>".$fm['MissingWidth'];
+ $fd.=')';
+ return $fd;
+function MakeWidthArray($fm)
+ //Make character width array
+ $s="array(\n\t";
+ $cw=$fm['Widths'];
+ if(chr($i)=="'")
+ $s.="'\\''";
+ elseif(chr($i)=="\\")
+ $s.="'\\\\'";
+ elseif($i>=32 && $i<=126)
+ $s.="'".chr($i)."'";
+ else
+ $s.="chr($i)";
+ $s.='=>'.$fm['Widths'][$i];
+ if($i<255)
+ $s.=',';
+ if(($i+1)%22==0)
+ $s.="\n\t";
+ $s.=')';
+ return $s;
+function MakeFontEncoding($map)
+ //Build differences from reference encoding
+ $ref=ReadMap('cp1252');
+ $s='';
+ $last=0;
+ for($i=32;$i<=255;$i++)
+ if($map[$i]!=$ref[$i])
+ if($i!=$last+1)
+ $s.=$i.' ';
+ $last=$i;
+ $s.='/'.$map[$i].' ';
+ return rtrim($s);
+function SaveToFile($file, $s, $mode)
+ $f=fopen($file,'w'.$mode);
+ if(!$f)
+ die('Can\'t write to file '.$file);
+ fwrite($f,$s,strlen($s));
+ fclose($f);
+function ReadShort($f)
+ $a=unpack('n1n',fread($f,2));
+ return $a['n'];
+function ReadLong($f)
+ $a=unpack('N1N',fread($f,4));
+ return $a['N'];
+function CheckTTF($file)
+ //Check if font license allows embedding
+ $f=fopen($file,'rb');
+ if(!$f)
+ die('<b>Error:</b> Can\'t open '.$file);
+ //Extract number of tables
+ fseek($f,4,SEEK_CUR);
+ $nb=ReadShort($f);
+ fseek($f,6,SEEK_CUR);
+ //Seek OS/2 table
+ $found=false;
+ for($i=0;$i<$nb;$i++)
+ if(fread($f,4)=='OS/2')
+ $found=true;
+ break;
+ fseek($f,12,SEEK_CUR);
+ if(!$found)
+ fclose($f);
+ return;
+ $offset=ReadLong($f);
+ fseek($f,$offset,SEEK_SET);
+ //Extract fsType flags
+ fseek($f,8,SEEK_CUR);
+ $fsType=ReadShort($f);
+ $rl=($fsType & 0x02)!=0;
+ $pp=($fsType & 0x04)!=0;
+ $e=($fsType & 0x08)!=0;
+ fclose($f);
+ if($rl && !$pp && !$e)
+ echo '<b>Warning:</b> font license does not allow embedding';
+* fontfile: path to TTF file (or empty string if not to be embedded) *
+* afmfile: path to AFM file *
+* enc: font encoding (or empty string for symbolic fonts) *
+* patch: optional patch for encoding *
+* type: font type if fontfile is empty *
+function MakeFont($fontfile, $afmfile, $enc='cp1252', $patch=array(), $type='TrueType')
+ //Generate a font definition file
+ if(get_magic_quotes_runtime())
+ @set_magic_quotes_runtime(0);
+ ini_set('auto_detect_line_endings','1');
+ if($enc)
+ $map=ReadMap($enc);
+ foreach($patch as $cc=>$gn)
+ $map[$cc]=$gn;
+ else
+ $map=array();
+ if(!file_exists($afmfile))
+ die('<b>Error:</b> AFM file not found: '.$afmfile);
+ $fm=ReadAFM($afmfile,$map);
+ if($enc)
+ $diff=MakeFontEncoding($map);
+ else
+ $diff='';
+ $fd=MakeFontDescriptor($fm,empty($map));
+ //Find font type
+ if($fontfile)
+ $ext=strtolower(substr($fontfile,-3));
+ if($ext=='ttf')
+ $type='TrueType';
+ elseif($ext=='pfb')
+ $type='Type1';
+ else
+ die('<b>Error:</b> unrecognized font file extension: '.$ext);
+ else
+ if($type!='TrueType' && $type!='Type1')
+ die('<b>Error:</b> incorrect font type: '.$type);
+ //Start generation
+ $s='<?php'."\n";
+ $s.='$type=\''.$type."';\n";
+ $s.='$name=\''.$fm['FontName']."';\n";
+ $s.='$desc='.$fd.";\n";
+ if(!isset($fm['UnderlinePosition']))
+ $fm['UnderlinePosition']=-100;
+ if(!isset($fm['UnderlineThickness']))
+ $fm['UnderlineThickness']=50;
+ $s.='$up='.$fm['UnderlinePosition'].";\n";
+ $s.='$ut='.$fm['UnderlineThickness'].";\n";
+ $w=MakeWidthArray($fm);
+ $s.='$cw='.$w.";\n";
+ $s.='$enc=\''.$enc."';\n";
+ $s.='$diff=\''.$diff."';\n";
+ $basename=substr(basename($afmfile),0,-4);
+ if($fontfile)
+ //Embedded font
+ if(!file_exists($fontfile))
+ die('<b>Error:</b> font file not found: '.$fontfile);
+ if($type=='TrueType')
+ CheckTTF($fontfile);
+ $f=fopen($fontfile,'rb');
+ if(!$f)
+ die('<b>Error:</b> Can\'t open '.$fontfile);
+ $file=fread($f,filesize($fontfile));
+ fclose($f);
+ if($type=='Type1')
+ //Find first two sections and discard third one
+ $header=(ord($file[0])==128);
+ if($header)
+ //Strip first binary header
+ $file=substr($file,6);
+ $pos=strpos($file,'eexec');
+ if(!$pos)
+ die('<b>Error:</b> font file does not seem to be valid Type1');
+ $size1=$pos+6;
+ if($header && ord($file[$size1])==128)
+ //Strip second binary header
+ $file=substr($file,0,$size1).substr($file,$size1+6);
+ $pos=strpos($file,'00000000');
+ if(!$pos)
+ $size2=$pos-$size1;
+ $file=substr($file,0,$size1+$size2);
+ if(function_exists('gzcompress'))
+ $cmp=$basename.'.z';
+ SaveToFile($cmp,gzcompress($file),'b');
+ $s.='$file=\''.$cmp."';\n";
+ echo 'Font file compressed ('.$cmp.')<br>';
+ else
+ $s.='$file=\''.basename($fontfile)."';\n";
+ echo '<b>Notice:</b> font file could not be compressed (zlib extension not available)<br>';
+ $s.='$size1='.$size1.";\n";
+ $s.='$size2='.$size2.";\n";
+ else
+ $s.='$originalsize='.filesize($fontfile).";\n";
+ else
+ //Not embedded font
+ $s.='$file='."'';\n";
+ $s.="?>\n";
+ SaveToFile($basename.'.php',$s,'t');
+ echo 'Font definition file generated ('.$basename.'.php'.')<br>';
Added: branches/print_dev/http/extensions/fpdf/font/symbol.php
--- branches/print_dev/http/extensions/fpdf/font/symbol.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/symbol.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['symbol']=array(
+ chr(0)=>250,chr(1)=>250,chr(2)=>250,chr(3)=>250,chr(4)=>250,chr(5)=>250,chr(6)=>250,chr(7)=>250,chr(8)=>250,chr(9)=>250,chr(10)=>250,chr(11)=>250,chr(12)=>250,chr(13)=>250,chr(14)=>250,chr(15)=>250,chr(16)=>250,chr(17)=>250,chr(18)=>250,chr(19)=>250,chr(20)=>250,chr(21)=>250,
+ chr(22)=>250,chr(23)=>250,chr(24)=>250,chr(25)=>250,chr(26)=>250,chr(27)=>250,chr(28)=>250,chr(29)=>250,chr(30)=>250,chr(31)=>250,' '=>250,'!'=>333,'"'=>713,'#'=>500,'$'=>549,'%'=>833,'&'=>778,'\''=>439,'('=>333,')'=>333,'*'=>500,'+'=>549,
+ ','=>250,'-'=>549,'.'=>250,'/'=>278,'0'=>500,'1'=>500,'2'=>500,'3'=>500,'4'=>500,'5'=>500,'6'=>500,'7'=>500,'8'=>500,'9'=>500,':'=>278,';'=>278,'<'=>549,'='=>549,'>'=>549,'?'=>444,'@'=>549,'A'=>722,
+ 'B'=>667,'C'=>722,'D'=>612,'E'=>611,'F'=>763,'G'=>603,'H'=>722,'I'=>333,'J'=>631,'K'=>722,'L'=>686,'M'=>889,'N'=>722,'O'=>722,'P'=>768,'Q'=>741,'R'=>556,'S'=>592,'T'=>611,'U'=>690,'V'=>439,'W'=>768,
+ 'X'=>645,'Y'=>795,'Z'=>611,'['=>333,'\\'=>863,']'=>333,'^'=>658,'_'=>500,'`'=>500,'a'=>631,'b'=>549,'c'=>549,'d'=>494,'e'=>439,'f'=>521,'g'=>411,'h'=>603,'i'=>329,'j'=>603,'k'=>549,'l'=>549,'m'=>576,
+ 'n'=>521,'o'=>549,'p'=>549,'q'=>521,'r'=>549,'s'=>603,'t'=>439,'u'=>576,'v'=>713,'w'=>686,'x'=>493,'y'=>686,'z'=>494,'{'=>480,'|'=>200,'}'=>480,'~'=>549,chr(127)=>0,chr(128)=>0,chr(129)=>0,chr(130)=>0,chr(131)=>0,
+ chr(132)=>0,chr(133)=>0,chr(134)=>0,chr(135)=>0,chr(136)=>0,chr(137)=>0,chr(138)=>0,chr(139)=>0,chr(140)=>0,chr(141)=>0,chr(142)=>0,chr(143)=>0,chr(144)=>0,chr(145)=>0,chr(146)=>0,chr(147)=>0,chr(148)=>0,chr(149)=>0,chr(150)=>0,chr(151)=>0,chr(152)=>0,chr(153)=>0,
+ chr(154)=>0,chr(155)=>0,chr(156)=>0,chr(157)=>0,chr(158)=>0,chr(159)=>0,chr(160)=>750,chr(161)=>620,chr(162)=>247,chr(163)=>549,chr(164)=>167,chr(165)=>713,chr(166)=>500,chr(167)=>753,chr(168)=>753,chr(169)=>753,chr(170)=>753,chr(171)=>1042,chr(172)=>987,chr(173)=>603,chr(174)=>987,chr(175)=>603,
+ chr(176)=>400,chr(177)=>549,chr(178)=>411,chr(179)=>549,chr(180)=>549,chr(181)=>713,chr(182)=>494,chr(183)=>460,chr(184)=>549,chr(185)=>549,chr(186)=>549,chr(187)=>549,chr(188)=>1000,chr(189)=>603,chr(190)=>1000,chr(191)=>658,chr(192)=>823,chr(193)=>686,chr(194)=>795,chr(195)=>987,chr(196)=>768,chr(197)=>768,
+ chr(198)=>823,chr(199)=>768,chr(200)=>768,chr(201)=>713,chr(202)=>713,chr(203)=>713,chr(204)=>713,chr(205)=>713,chr(206)=>713,chr(207)=>713,chr(208)=>768,chr(209)=>713,chr(210)=>790,chr(211)=>790,chr(212)=>890,chr(213)=>823,chr(214)=>549,chr(215)=>250,chr(216)=>713,chr(217)=>603,chr(218)=>603,chr(219)=>1042,
+ chr(220)=>987,chr(221)=>603,chr(222)=>987,chr(223)=>603,chr(224)=>494,chr(225)=>329,chr(226)=>790,chr(227)=>790,chr(228)=>786,chr(229)=>713,chr(230)=>384,chr(231)=>384,chr(232)=>384,chr(233)=>384,chr(234)=>384,chr(235)=>384,chr(236)=>494,chr(237)=>494,chr(238)=>494,chr(239)=>494,chr(240)=>0,chr(241)=>329,
+ chr(242)=>274,chr(243)=>686,chr(244)=>686,chr(245)=>686,chr(246)=>384,chr(247)=>384,chr(248)=>384,chr(249)=>384,chr(250)=>384,chr(251)=>384,chr(252)=>494,chr(253)=>494,chr(254)=>494,chr(255)=>0);
Added: branches/print_dev/http/extensions/fpdf/font/times.php
--- branches/print_dev/http/extensions/fpdf/font/times.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/times.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['times']=array(
+ chr(22)=>250,chr(23)=>250,chr(24)=>250,chr(25)=>250,chr(26)=>250,chr(27)=>250,chr(28)=>250,chr(29)=>250,chr(30)=>250,chr(31)=>250,' '=>250,'!'=>333,'"'=>408,'#'=>500,'$'=>500,'%'=>833,'&'=>778,'\''=>180,'('=>333,')'=>333,'*'=>500,'+'=>564,
+ ','=>250,'-'=>333,'.'=>250,'/'=>278,'0'=>500,'1'=>500,'2'=>500,'3'=>500,'4'=>500,'5'=>500,'6'=>500,'7'=>500,'8'=>500,'9'=>500,':'=>278,';'=>278,'<'=>564,'='=>564,'>'=>564,'?'=>444,'@'=>921,'A'=>722,
+ 'B'=>667,'C'=>667,'D'=>722,'E'=>611,'F'=>556,'G'=>722,'H'=>722,'I'=>333,'J'=>389,'K'=>722,'L'=>611,'M'=>889,'N'=>722,'O'=>722,'P'=>556,'Q'=>722,'R'=>667,'S'=>556,'T'=>611,'U'=>722,'V'=>722,'W'=>944,
+ 'X'=>722,'Y'=>722,'Z'=>611,'['=>333,'\\'=>278,']'=>333,'^'=>469,'_'=>500,'`'=>333,'a'=>444,'b'=>500,'c'=>444,'d'=>500,'e'=>444,'f'=>333,'g'=>500,'h'=>500,'i'=>278,'j'=>278,'k'=>500,'l'=>278,'m'=>778,
+ 'n'=>500,'o'=>500,'p'=>500,'q'=>500,'r'=>333,'s'=>389,'t'=>278,'u'=>500,'v'=>500,'w'=>722,'x'=>500,'y'=>500,'z'=>444,'{'=>480,'|'=>200,'}'=>480,'~'=>541,chr(127)=>350,chr(128)=>500,chr(129)=>350,chr(130)=>333,chr(131)=>500,
+ chr(132)=>444,chr(133)=>1000,chr(134)=>500,chr(135)=>500,chr(136)=>333,chr(137)=>1000,chr(138)=>556,chr(139)=>333,chr(140)=>889,chr(141)=>350,chr(142)=>611,chr(143)=>350,chr(144)=>350,chr(145)=>333,chr(146)=>333,chr(147)=>444,chr(148)=>444,chr(149)=>350,chr(150)=>500,chr(151)=>1000,chr(152)=>333,chr(153)=>980,
+ chr(154)=>389,chr(155)=>333,chr(156)=>722,chr(157)=>350,chr(158)=>444,chr(159)=>722,chr(160)=>250,chr(161)=>333,chr(162)=>500,chr(163)=>500,chr(164)=>500,chr(165)=>500,chr(166)=>200,chr(167)=>500,chr(168)=>333,chr(169)=>760,chr(170)=>276,chr(171)=>500,chr(172)=>564,chr(173)=>333,chr(174)=>760,chr(175)=>333,
+ chr(176)=>400,chr(177)=>564,chr(178)=>300,chr(179)=>300,chr(180)=>333,chr(181)=>500,chr(182)=>453,chr(183)=>250,chr(184)=>333,chr(185)=>300,chr(186)=>310,chr(187)=>500,chr(188)=>750,chr(189)=>750,chr(190)=>750,chr(191)=>444,chr(192)=>722,chr(193)=>722,chr(194)=>722,chr(195)=>722,chr(196)=>722,chr(197)=>722,
+ chr(198)=>889,chr(199)=>667,chr(200)=>611,chr(201)=>611,chr(202)=>611,chr(203)=>611,chr(204)=>333,chr(205)=>333,chr(206)=>333,chr(207)=>333,chr(208)=>722,chr(209)=>722,chr(210)=>722,chr(211)=>722,chr(212)=>722,chr(213)=>722,chr(214)=>722,chr(215)=>564,chr(216)=>722,chr(217)=>722,chr(218)=>722,chr(219)=>722,
+ chr(220)=>722,chr(221)=>722,chr(222)=>556,chr(223)=>500,chr(224)=>444,chr(225)=>444,chr(226)=>444,chr(227)=>444,chr(228)=>444,chr(229)=>444,chr(230)=>667,chr(231)=>444,chr(232)=>444,chr(233)=>444,chr(234)=>444,chr(235)=>444,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>500,chr(241)=>500,
+ chr(242)=>500,chr(243)=>500,chr(244)=>500,chr(245)=>500,chr(246)=>500,chr(247)=>564,chr(248)=>500,chr(249)=>500,chr(250)=>500,chr(251)=>500,chr(252)=>500,chr(253)=>500,chr(254)=>500,chr(255)=>500);
Added: branches/print_dev/http/extensions/fpdf/font/timesb.php
--- branches/print_dev/http/extensions/fpdf/font/timesb.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/timesb.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['timesB']=array(
+ chr(22)=>250,chr(23)=>250,chr(24)=>250,chr(25)=>250,chr(26)=>250,chr(27)=>250,chr(28)=>250,chr(29)=>250,chr(30)=>250,chr(31)=>250,' '=>250,'!'=>333,'"'=>555,'#'=>500,'$'=>500,'%'=>1000,'&'=>833,'\''=>278,'('=>333,')'=>333,'*'=>500,'+'=>570,
+ ','=>250,'-'=>333,'.'=>250,'/'=>278,'0'=>500,'1'=>500,'2'=>500,'3'=>500,'4'=>500,'5'=>500,'6'=>500,'7'=>500,'8'=>500,'9'=>500,':'=>333,';'=>333,'<'=>570,'='=>570,'>'=>570,'?'=>500,'@'=>930,'A'=>722,
+ 'B'=>667,'C'=>722,'D'=>722,'E'=>667,'F'=>611,'G'=>778,'H'=>778,'I'=>389,'J'=>500,'K'=>778,'L'=>667,'M'=>944,'N'=>722,'O'=>778,'P'=>611,'Q'=>778,'R'=>722,'S'=>556,'T'=>667,'U'=>722,'V'=>722,'W'=>1000,
+ 'X'=>722,'Y'=>722,'Z'=>667,'['=>333,'\\'=>278,']'=>333,'^'=>581,'_'=>500,'`'=>333,'a'=>500,'b'=>556,'c'=>444,'d'=>556,'e'=>444,'f'=>333,'g'=>500,'h'=>556,'i'=>278,'j'=>333,'k'=>556,'l'=>278,'m'=>833,
+ 'n'=>556,'o'=>500,'p'=>556,'q'=>556,'r'=>444,'s'=>389,'t'=>333,'u'=>556,'v'=>500,'w'=>722,'x'=>500,'y'=>500,'z'=>444,'{'=>394,'|'=>220,'}'=>394,'~'=>520,chr(127)=>350,chr(128)=>500,chr(129)=>350,chr(130)=>333,chr(131)=>500,
+ chr(132)=>500,chr(133)=>1000,chr(134)=>500,chr(135)=>500,chr(136)=>333,chr(137)=>1000,chr(138)=>556,chr(139)=>333,chr(140)=>1000,chr(141)=>350,chr(142)=>667,chr(143)=>350,chr(144)=>350,chr(145)=>333,chr(146)=>333,chr(147)=>500,chr(148)=>500,chr(149)=>350,chr(150)=>500,chr(151)=>1000,chr(152)=>333,chr(153)=>1000,
+ chr(154)=>389,chr(155)=>333,chr(156)=>722,chr(157)=>350,chr(158)=>444,chr(159)=>722,chr(160)=>250,chr(161)=>333,chr(162)=>500,chr(163)=>500,chr(164)=>500,chr(165)=>500,chr(166)=>220,chr(167)=>500,chr(168)=>333,chr(169)=>747,chr(170)=>300,chr(171)=>500,chr(172)=>570,chr(173)=>333,chr(174)=>747,chr(175)=>333,
+ chr(176)=>400,chr(177)=>570,chr(178)=>300,chr(179)=>300,chr(180)=>333,chr(181)=>556,chr(182)=>540,chr(183)=>250,chr(184)=>333,chr(185)=>300,chr(186)=>330,chr(187)=>500,chr(188)=>750,chr(189)=>750,chr(190)=>750,chr(191)=>500,chr(192)=>722,chr(193)=>722,chr(194)=>722,chr(195)=>722,chr(196)=>722,chr(197)=>722,
+ chr(198)=>1000,chr(199)=>722,chr(200)=>667,chr(201)=>667,chr(202)=>667,chr(203)=>667,chr(204)=>389,chr(205)=>389,chr(206)=>389,chr(207)=>389,chr(208)=>722,chr(209)=>722,chr(210)=>778,chr(211)=>778,chr(212)=>778,chr(213)=>778,chr(214)=>778,chr(215)=>570,chr(216)=>778,chr(217)=>722,chr(218)=>722,chr(219)=>722,
+ chr(220)=>722,chr(221)=>722,chr(222)=>611,chr(223)=>556,chr(224)=>500,chr(225)=>500,chr(226)=>500,chr(227)=>500,chr(228)=>500,chr(229)=>500,chr(230)=>722,chr(231)=>444,chr(232)=>444,chr(233)=>444,chr(234)=>444,chr(235)=>444,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>500,chr(241)=>556,
+ chr(242)=>500,chr(243)=>500,chr(244)=>500,chr(245)=>500,chr(246)=>500,chr(247)=>570,chr(248)=>500,chr(249)=>556,chr(250)=>556,chr(251)=>556,chr(252)=>556,chr(253)=>500,chr(254)=>556,chr(255)=>500);
Added: branches/print_dev/http/extensions/fpdf/font/timesbi.php
--- branches/print_dev/http/extensions/fpdf/font/timesbi.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/timesbi.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['timesBI']=array(
+ chr(22)=>250,chr(23)=>250,chr(24)=>250,chr(25)=>250,chr(26)=>250,chr(27)=>250,chr(28)=>250,chr(29)=>250,chr(30)=>250,chr(31)=>250,' '=>250,'!'=>389,'"'=>555,'#'=>500,'$'=>500,'%'=>833,'&'=>778,'\''=>278,'('=>333,')'=>333,'*'=>500,'+'=>570,
+ ','=>250,'-'=>333,'.'=>250,'/'=>278,'0'=>500,'1'=>500,'2'=>500,'3'=>500,'4'=>500,'5'=>500,'6'=>500,'7'=>500,'8'=>500,'9'=>500,':'=>333,';'=>333,'<'=>570,'='=>570,'>'=>570,'?'=>500,'@'=>832,'A'=>667,
+ 'B'=>667,'C'=>667,'D'=>722,'E'=>667,'F'=>667,'G'=>722,'H'=>778,'I'=>389,'J'=>500,'K'=>667,'L'=>611,'M'=>889,'N'=>722,'O'=>722,'P'=>611,'Q'=>722,'R'=>667,'S'=>556,'T'=>611,'U'=>722,'V'=>667,'W'=>889,
+ 'X'=>667,'Y'=>611,'Z'=>611,'['=>333,'\\'=>278,']'=>333,'^'=>570,'_'=>500,'`'=>333,'a'=>500,'b'=>500,'c'=>444,'d'=>500,'e'=>444,'f'=>333,'g'=>500,'h'=>556,'i'=>278,'j'=>278,'k'=>500,'l'=>278,'m'=>778,
+ 'n'=>556,'o'=>500,'p'=>500,'q'=>500,'r'=>389,'s'=>389,'t'=>278,'u'=>556,'v'=>444,'w'=>667,'x'=>500,'y'=>444,'z'=>389,'{'=>348,'|'=>220,'}'=>348,'~'=>570,chr(127)=>350,chr(128)=>500,chr(129)=>350,chr(130)=>333,chr(131)=>500,
+ chr(132)=>500,chr(133)=>1000,chr(134)=>500,chr(135)=>500,chr(136)=>333,chr(137)=>1000,chr(138)=>556,chr(139)=>333,chr(140)=>944,chr(141)=>350,chr(142)=>611,chr(143)=>350,chr(144)=>350,chr(145)=>333,chr(146)=>333,chr(147)=>500,chr(148)=>500,chr(149)=>350,chr(150)=>500,chr(151)=>1000,chr(152)=>333,chr(153)=>1000,
+ chr(154)=>389,chr(155)=>333,chr(156)=>722,chr(157)=>350,chr(158)=>389,chr(159)=>611,chr(160)=>250,chr(161)=>389,chr(162)=>500,chr(163)=>500,chr(164)=>500,chr(165)=>500,chr(166)=>220,chr(167)=>500,chr(168)=>333,chr(169)=>747,chr(170)=>266,chr(171)=>500,chr(172)=>606,chr(173)=>333,chr(174)=>747,chr(175)=>333,
+ chr(176)=>400,chr(177)=>570,chr(178)=>300,chr(179)=>300,chr(180)=>333,chr(181)=>576,chr(182)=>500,chr(183)=>250,chr(184)=>333,chr(185)=>300,chr(186)=>300,chr(187)=>500,chr(188)=>750,chr(189)=>750,chr(190)=>750,chr(191)=>500,chr(192)=>667,chr(193)=>667,chr(194)=>667,chr(195)=>667,chr(196)=>667,chr(197)=>667,
+ chr(198)=>944,chr(199)=>667,chr(200)=>667,chr(201)=>667,chr(202)=>667,chr(203)=>667,chr(204)=>389,chr(205)=>389,chr(206)=>389,chr(207)=>389,chr(208)=>722,chr(209)=>722,chr(210)=>722,chr(211)=>722,chr(212)=>722,chr(213)=>722,chr(214)=>722,chr(215)=>570,chr(216)=>722,chr(217)=>722,chr(218)=>722,chr(219)=>722,
+ chr(220)=>722,chr(221)=>611,chr(222)=>611,chr(223)=>500,chr(224)=>500,chr(225)=>500,chr(226)=>500,chr(227)=>500,chr(228)=>500,chr(229)=>500,chr(230)=>722,chr(231)=>444,chr(232)=>444,chr(233)=>444,chr(234)=>444,chr(235)=>444,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>500,chr(241)=>556,
+ chr(242)=>500,chr(243)=>500,chr(244)=>500,chr(245)=>500,chr(246)=>500,chr(247)=>570,chr(248)=>500,chr(249)=>556,chr(250)=>556,chr(251)=>556,chr(252)=>556,chr(253)=>444,chr(254)=>500,chr(255)=>444);
Added: branches/print_dev/http/extensions/fpdf/font/timesi.php
--- branches/print_dev/http/extensions/fpdf/font/timesi.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/timesi.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['timesI']=array(
+ chr(22)=>250,chr(23)=>250,chr(24)=>250,chr(25)=>250,chr(26)=>250,chr(27)=>250,chr(28)=>250,chr(29)=>250,chr(30)=>250,chr(31)=>250,' '=>250,'!'=>333,'"'=>420,'#'=>500,'$'=>500,'%'=>833,'&'=>778,'\''=>214,'('=>333,')'=>333,'*'=>500,'+'=>675,
+ ','=>250,'-'=>333,'.'=>250,'/'=>278,'0'=>500,'1'=>500,'2'=>500,'3'=>500,'4'=>500,'5'=>500,'6'=>500,'7'=>500,'8'=>500,'9'=>500,':'=>333,';'=>333,'<'=>675,'='=>675,'>'=>675,'?'=>500,'@'=>920,'A'=>611,
+ 'B'=>611,'C'=>667,'D'=>722,'E'=>611,'F'=>611,'G'=>722,'H'=>722,'I'=>333,'J'=>444,'K'=>667,'L'=>556,'M'=>833,'N'=>667,'O'=>722,'P'=>611,'Q'=>722,'R'=>611,'S'=>500,'T'=>556,'U'=>722,'V'=>611,'W'=>833,
+ 'X'=>611,'Y'=>556,'Z'=>556,'['=>389,'\\'=>278,']'=>389,'^'=>422,'_'=>500,'`'=>333,'a'=>500,'b'=>500,'c'=>444,'d'=>500,'e'=>444,'f'=>278,'g'=>500,'h'=>500,'i'=>278,'j'=>278,'k'=>444,'l'=>278,'m'=>722,
+ 'n'=>500,'o'=>500,'p'=>500,'q'=>500,'r'=>389,'s'=>389,'t'=>278,'u'=>500,'v'=>444,'w'=>667,'x'=>444,'y'=>444,'z'=>389,'{'=>400,'|'=>275,'}'=>400,'~'=>541,chr(127)=>350,chr(128)=>500,chr(129)=>350,chr(130)=>333,chr(131)=>500,
+ chr(132)=>556,chr(133)=>889,chr(134)=>500,chr(135)=>500,chr(136)=>333,chr(137)=>1000,chr(138)=>500,chr(139)=>333,chr(140)=>944,chr(141)=>350,chr(142)=>556,chr(143)=>350,chr(144)=>350,chr(145)=>333,chr(146)=>333,chr(147)=>556,chr(148)=>556,chr(149)=>350,chr(150)=>500,chr(151)=>889,chr(152)=>333,chr(153)=>980,
+ chr(154)=>389,chr(155)=>333,chr(156)=>667,chr(157)=>350,chr(158)=>389,chr(159)=>556,chr(160)=>250,chr(161)=>389,chr(162)=>500,chr(163)=>500,chr(164)=>500,chr(165)=>500,chr(166)=>275,chr(167)=>500,chr(168)=>333,chr(169)=>760,chr(170)=>276,chr(171)=>500,chr(172)=>675,chr(173)=>333,chr(174)=>760,chr(175)=>333,
+ chr(176)=>400,chr(177)=>675,chr(178)=>300,chr(179)=>300,chr(180)=>333,chr(181)=>500,chr(182)=>523,chr(183)=>250,chr(184)=>333,chr(185)=>300,chr(186)=>310,chr(187)=>500,chr(188)=>750,chr(189)=>750,chr(190)=>750,chr(191)=>500,chr(192)=>611,chr(193)=>611,chr(194)=>611,chr(195)=>611,chr(196)=>611,chr(197)=>611,
+ chr(198)=>889,chr(199)=>667,chr(200)=>611,chr(201)=>611,chr(202)=>611,chr(203)=>611,chr(204)=>333,chr(205)=>333,chr(206)=>333,chr(207)=>333,chr(208)=>722,chr(209)=>667,chr(210)=>722,chr(211)=>722,chr(212)=>722,chr(213)=>722,chr(214)=>722,chr(215)=>675,chr(216)=>722,chr(217)=>722,chr(218)=>722,chr(219)=>722,
+ chr(220)=>722,chr(221)=>556,chr(222)=>611,chr(223)=>500,chr(224)=>500,chr(225)=>500,chr(226)=>500,chr(227)=>500,chr(228)=>500,chr(229)=>500,chr(230)=>667,chr(231)=>444,chr(232)=>444,chr(233)=>444,chr(234)=>444,chr(235)=>444,chr(236)=>278,chr(237)=>278,chr(238)=>278,chr(239)=>278,chr(240)=>500,chr(241)=>500,
+ chr(242)=>500,chr(243)=>500,chr(244)=>500,chr(245)=>500,chr(246)=>500,chr(247)=>675,chr(248)=>500,chr(249)=>500,chr(250)=>500,chr(251)=>500,chr(252)=>500,chr(253)=>444,chr(254)=>500,chr(255)=>444);
Added: branches/print_dev/http/extensions/fpdf/font/zapfdingbats.php
--- branches/print_dev/http/extensions/fpdf/font/zapfdingbats.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/font/zapfdingbats.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,15 @@
+<?php
+$fpdf_charwidths['zapfdingbats']=array(
+ chr(0)=>0,chr(1)=>0,chr(2)=>0,chr(3)=>0,chr(4)=>0,chr(5)=>0,chr(6)=>0,chr(7)=>0,chr(8)=>0,chr(9)=>0,chr(10)=>0,chr(11)=>0,chr(12)=>0,chr(13)=>0,chr(14)=>0,chr(15)=>0,chr(16)=>0,chr(17)=>0,chr(18)=>0,chr(19)=>0,chr(20)=>0,chr(21)=>0,
+ chr(22)=>0,chr(23)=>0,chr(24)=>0,chr(25)=>0,chr(26)=>0,chr(27)=>0,chr(28)=>0,chr(29)=>0,chr(30)=>0,chr(31)=>0,' '=>278,'!'=>974,'"'=>961,'#'=>974,'$'=>980,'%'=>719,'&'=>789,'\''=>790,'('=>791,')'=>690,'*'=>960,'+'=>939,
+ ','=>549,'-'=>855,'.'=>911,'/'=>933,'0'=>911,'1'=>945,'2'=>974,'3'=>755,'4'=>846,'5'=>762,'6'=>761,'7'=>571,'8'=>677,'9'=>763,':'=>760,';'=>759,'<'=>754,'='=>494,'>'=>552,'?'=>537,'@'=>577,'A'=>692,
+ 'B'=>786,'C'=>788,'D'=>788,'E'=>790,'F'=>793,'G'=>794,'H'=>816,'I'=>823,'J'=>789,'K'=>841,'L'=>823,'M'=>833,'N'=>816,'O'=>831,'P'=>923,'Q'=>744,'R'=>723,'S'=>749,'T'=>790,'U'=>792,'V'=>695,'W'=>776,
+ 'X'=>768,'Y'=>792,'Z'=>759,'['=>707,'\\'=>708,']'=>682,'^'=>701,'_'=>826,'`'=>815,'a'=>789,'b'=>789,'c'=>707,'d'=>687,'e'=>696,'f'=>689,'g'=>786,'h'=>787,'i'=>713,'j'=>791,'k'=>785,'l'=>791,'m'=>873,
+ 'n'=>761,'o'=>762,'p'=>762,'q'=>759,'r'=>759,'s'=>892,'t'=>892,'u'=>788,'v'=>784,'w'=>438,'x'=>138,'y'=>277,'z'=>415,'{'=>392,'|'=>392,'}'=>668,'~'=>668,chr(127)=>0,chr(128)=>390,chr(129)=>390,chr(130)=>317,chr(131)=>317,
+ chr(132)=>276,chr(133)=>276,chr(134)=>509,chr(135)=>509,chr(136)=>410,chr(137)=>410,chr(138)=>234,chr(139)=>234,chr(140)=>334,chr(141)=>334,chr(142)=>0,chr(143)=>0,chr(144)=>0,chr(145)=>0,chr(146)=>0,chr(147)=>0,chr(148)=>0,chr(149)=>0,chr(150)=>0,chr(151)=>0,chr(152)=>0,chr(153)=>0,
+ chr(154)=>0,chr(155)=>0,chr(156)=>0,chr(157)=>0,chr(158)=>0,chr(159)=>0,chr(160)=>0,chr(161)=>732,chr(162)=>544,chr(163)=>544,chr(164)=>910,chr(165)=>667,chr(166)=>760,chr(167)=>760,chr(168)=>776,chr(169)=>595,chr(170)=>694,chr(171)=>626,chr(172)=>788,chr(173)=>788,chr(174)=>788,chr(175)=>788,
+ chr(176)=>788,chr(177)=>788,chr(178)=>788,chr(179)=>788,chr(180)=>788,chr(181)=>788,chr(182)=>788,chr(183)=>788,chr(184)=>788,chr(185)=>788,chr(186)=>788,chr(187)=>788,chr(188)=>788,chr(189)=>788,chr(190)=>788,chr(191)=>788,chr(192)=>788,chr(193)=>788,chr(194)=>788,chr(195)=>788,chr(196)=>788,chr(197)=>788,
+ chr(198)=>788,chr(199)=>788,chr(200)=>788,chr(201)=>788,chr(202)=>788,chr(203)=>788,chr(204)=>788,chr(205)=>788,chr(206)=>788,chr(207)=>788,chr(208)=>788,chr(209)=>788,chr(210)=>788,chr(211)=>788,chr(212)=>894,chr(213)=>838,chr(214)=>1016,chr(215)=>458,chr(216)=>748,chr(217)=>924,chr(218)=>748,chr(219)=>918,
+ chr(220)=>927,chr(221)=>928,chr(222)=>928,chr(223)=>834,chr(224)=>873,chr(225)=>828,chr(226)=>924,chr(227)=>924,chr(228)=>917,chr(229)=>930,chr(230)=>931,chr(231)=>463,chr(232)=>883,chr(233)=>836,chr(234)=>836,chr(235)=>867,chr(236)=>867,chr(237)=>696,chr(238)=>696,chr(239)=>874,chr(240)=>0,chr(241)=>874,
+ chr(242)=>760,chr(243)=>946,chr(244)=>771,chr(245)=>865,chr(246)=>771,chr(247)=>888,chr(248)=>967,chr(249)=>888,chr(250)=>831,chr(251)=>873,chr(252)=>927,chr(253)=>970,chr(254)=>918,chr(255)=>0);
Added: branches/print_dev/http/extensions/fpdf/fpdf.php
--- branches/print_dev/http/extensions/fpdf/fpdf.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/fpdf.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,1732 @@
+<?php
+* FPDF *
+* Version: 1.6 *
+define('FPDF_VERSION','1.6');
+class FPDF
+var $page; //current page number
+var $n; //current object number
+var $offsets; //array of object offsets
+var $buffer; //buffer holding in-memory PDF
+var $pages; //array containing pages
+var $state; //current document state
+var $compress; //compression flag
+var $k; //scale factor (number of points in user unit)
+var $DefOrientation; //default orientation
+var $CurOrientation; //current orientation
+var $PageFormats; //available page formats
+var $DefPageFormat; //default page format
+var $CurPageFormat; //current page format
+var $PageSizes; //array storing non-default page sizes
+var $wPt,$hPt; //dimensions of current page in points
+var $w,$h; //dimensions of current page in user unit
+var $lMargin; //left margin
+var $tMargin; //top margin
+var $rMargin; //right margin
+var $bMargin; //page break margin
+var $cMargin; //cell margin
+var $x,$y; //current position in user unit
+var $lasth; //height of last printed cell
+var $LineWidth; //line width in user unit
+var $CoreFonts; //array of standard font names
+var $fonts; //array of used fonts
+var $FontFiles; //array of font files
+var $diffs; //array of encoding differences
+var $FontFamily; //current font family
+var $FontStyle; //current font style
+var $underline; //underlining flag
+var $CurrentFont; //current font info
+var $FontSizePt; //current font size in points
+var $FontSize; //current font size in user unit
+var $DrawColor; //commands for drawing color
+var $FillColor; //commands for filling color
+var $TextColor; //commands for text color
+var $ColorFlag; //indicates whether fill and text colors are different
+var $ws; //word spacing
+var $images; //array of used images
+var $PageLinks; //array of links in pages
+var $links; //array of internal links
+var $AutoPageBreak; //automatic page breaking
+var $PageBreakTrigger; //threshold used to trigger page breaks
+var $InHeader; //flag set when processing header
+var $InFooter; //flag set when processing footer
+var $ZoomMode; //zoom display mode
+var $LayoutMode; //layout display mode
+var $title; //title
+var $subject; //subject
+var $author; //author
+var $keywords; //keywords
+var $creator; //creator
+var $AliasNbPages; //alias for total number of pages
+var $PDFVersion; //PDF version number
+* Public methods *
+function FPDF($orientation='P', $unit='mm', $format='A4')
+ //Some checks
+ $this->_dochecks();
+ //Initialization of properties
+ $this->page=0;
+ $this->n=2;
+ $this->buffer='';
+ $this->pages=array();
+ $this->PageSizes=array();
+ $this->state=0;
+ $this->fonts=array();
+ $this->FontFiles=array();
+ $this->diffs=array();
+ $this->images=array();
+ $this->links=array();
+ $this->InHeader=false;
+ $this->InFooter=false;
+ $this->lasth=0;
+ $this->FontFamily='';
+ $this->FontStyle='';
+ $this->FontSizePt=12;
+ $this->underline=false;
+ $this->DrawColor='0 G';
+ $this->FillColor='0 g';
+ $this->TextColor='0 g';
+ $this->ColorFlag=false;
+ $this->ws=0;
+ //Standard fonts
+ $this->CoreFonts=array('courier'=>'Courier', 'courierB'=>'Courier-Bold', 'courierI'=>'Courier-Oblique', 'courierBI'=>'Courier-BoldOblique',
+ 'helvetica'=>'Helvetica', 'helveticaB'=>'Helvetica-Bold', 'helveticaI'=>'Helvetica-Oblique', 'helveticaBI'=>'Helvetica-BoldOblique',
+ 'times'=>'Times-Roman', 'timesB'=>'Times-Bold', 'timesI'=>'Times-Italic', 'timesBI'=>'Times-BoldItalic',
+ 'symbol'=>'Symbol', 'zapfdingbats'=>'ZapfDingbats');
+ //Scale factor
+ if($unit=='pt')
+ $this->k=1;
+ elseif($unit=='mm')
+ $this->k=72/25.4;
+ elseif($unit=='cm')
+ $this->k=72/2.54;
+ elseif($unit=='in')
+ $this->k=72;
+ else
+ $this->Error('Incorrect unit: '.$unit);
+ //Page format
+ $this->PageFormats=array('a3'=>array(841.89,1190.55), 'a4'=>array(595.28,841.89), 'a5'=>array(420.94,595.28),
+ 'letter'=>array(612,792), 'legal'=>array(612,1008));
+ if(is_string($format))
+ $format=$this->_getpageformat($format);
+ $this->DefPageFormat=$format;
+ $this->CurPageFormat=$format;
+ //Page orientation
+ $orientation=strtolower($orientation);
+ if($orientation=='p' || $orientation=='portrait')
+ $this->DefOrientation='P';
+ $this->w=$this->DefPageFormat[0];
+ $this->h=$this->DefPageFormat[1];
+ elseif($orientation=='l' || $orientation=='landscape')
+ $this->DefOrientation='L';
+ $this->w=$this->DefPageFormat[1];
+ $this->h=$this->DefPageFormat[0];
+ else
+ $this->Error('Incorrect orientation: '.$orientation);
+ $this->CurOrientation=$this->DefOrientation;
+ $this->wPt=$this->w*$this->k;
+ $this->hPt=$this->h*$this->k;
+ //Page margins (1 cm)
+ $margin=28.35/$this->k;
+ $this->SetMargins($margin,$margin);
+ //Interior cell margin (1 mm)
+ $this->cMargin=$margin/10;
+ //Line width (0.2 mm)
+ $this->LineWidth=.567/$this->k;
+ //Automatic page break
+ $this->SetAutoPageBreak(true,2*$margin);
+ //Full width display mode
+ $this->SetDisplayMode('fullwidth');
+ //Enable compression
+ $this->SetCompression(true);
+ //Set default PDF version number
+ $this->PDFVersion='1.3';
+function SetMargins($left, $top, $right=null)
+ //Set left, top and right margins
+ $this->lMargin=$left;
+ $this->tMargin=$top;
+ if($right===null)
+ $right=$left;
+ $this->rMargin=$right;
+function SetLeftMargin($margin)
+ //Set left margin
+ $this->lMargin=$margin;
+ if($this->page>0 && $this->x<$margin)
+ $this->x=$margin;
+function SetTopMargin($margin)
+ //Set top margin
+ $this->tMargin=$margin;
+function SetRightMargin($margin)
+ //Set right margin
+ $this->rMargin=$margin;
+function SetAutoPageBreak($auto, $margin=0)
+ //Set auto page break mode and triggering margin
+ $this->AutoPageBreak=$auto;
+ $this->bMargin=$margin;
+ $this->PageBreakTrigger=$this->h-$margin;
+function SetDisplayMode($zoom, $layout='continuous')
+ //Set display mode in viewer
+ if($zoom=='fullpage' || $zoom=='fullwidth' || $zoom=='real' || $zoom=='default' || !is_string($zoom))
+ $this->ZoomMode=$zoom;
+ else
+ $this->Error('Incorrect zoom display mode: '.$zoom);
+ if($layout=='single' || $layout=='continuous' || $layout=='two' || $layout=='default')
+ $this->LayoutMode=$layout;
+ else
+ $this->Error('Incorrect layout display mode: '.$layout);
+function SetCompression($compress)
+ //Set page compression
+ $this->compress=$compress;
+ else
+ $this->compress=false;
+function SetTitle($title, $isUTF8=false)
+ //Title of document
+ if($isUTF8)
+ $title=$this->_UTF8toUTF16($title);
+ $this->title=$title;
+function SetSubject($subject, $isUTF8=false)
+ //Subject of document
+ if($isUTF8)
+ $subject=$this->_UTF8toUTF16($subject);
+ $this->subject=$subject;
+function SetAuthor($author, $isUTF8=false)
+ //Author of document
+ if($isUTF8)
+ $author=$this->_UTF8toUTF16($author);
+ $this->author=$author;
+function SetKeywords($keywords, $isUTF8=false)
+ //Keywords of document
+ if($isUTF8)
+ $keywords=$this->_UTF8toUTF16($keywords);
+ $this->keywords=$keywords;
+function SetCreator($creator, $isUTF8=false)
+ //Creator of document
+ if($isUTF8)
+ $creator=$this->_UTF8toUTF16($creator);
+ $this->creator=$creator;
+function AliasNbPages($alias='{nb}')
+ //Define an alias for total number of pages
+ $this->AliasNbPages=$alias;
+function Error($msg)
+ //Fatal error
+ die('<b>FPDF error:</b> '.$msg);
+function Open()
+ //Begin document
+ $this->state=1;
+function Close()
+ //Terminate document
+ if($this->state==3)
+ return;
+ if($this->page==0)
+ $this->AddPage();
+ //Page footer
+ $this->InFooter=true;
+ $this->Footer();
+ //Close page
+ $this->_endpage();
+ //Close document
+ $this->_enddoc();
+function AddPage($orientation='', $format='')
+ //Start a new page
+ if($this->state==0)
+ $this->Open();
+ $family=$this->FontFamily;
+ $style=$this->FontStyle.($this->underline ? 'U' : '');
+ $size=$this->FontSizePt;
+ $lw=$this->LineWidth;
+ $dc=$this->DrawColor;
+ $fc=$this->FillColor;
+ $tc=$this->TextColor;
+ $cf=$this->ColorFlag;
+ if($this->page>0)
+ //Page footer
+ $this->Footer();
+ //Close page
+ //Start new page
+ $this->_beginpage($orientation,$format);
+ //Set line cap style to square
+ $this->_out('2 J');
+ //Set line width
+ $this->LineWidth=$lw;
+ $this->_out(sprintf('%.2F w',$lw*$this->k));
+ //Set font
+ if($family)
+ $this->SetFont($family,$style,$size);
+ //Set colors
+ $this->DrawColor=$dc;
+ if($dc!='0 G')
+ $this->_out($dc);
+ $this->FillColor=$fc;
+ if($fc!='0 g')
+ $this->_out($fc);
+ $this->TextColor=$tc;
+ $this->ColorFlag=$cf;
+ //Page header
+ $this->InHeader=true;
+ $this->Header();
+ //Restore line width
+ if($this->LineWidth!=$lw)
+ //Restore font
+ if($family)
+ //Restore colors
+ if($this->DrawColor!=$dc)
+ $this->_out($dc);
+ if($this->FillColor!=$fc)
+ $this->_out($fc);
+function Header()
+ //To be implemented in your own inherited class
+function Footer()
+function PageNo()
+ //Get current page number
+ return $this->page;
+function SetDrawColor($r, $g=null, $b=null)
+ //Set color for all stroking operations
+ if(($r==0 && $g==0 && $b==0) || $g===null)
+ $this->DrawColor=sprintf('%.3F G',$r/255);
+ else
+ $this->DrawColor=sprintf('%.3F %.3F %.3F RG',$r/255,$g/255,$b/255);
+ if($this->page>0)
+ $this->_out($this->DrawColor);
+function SetFillColor($r, $g=null, $b=null)
+ //Set color for all filling operations
+ $this->FillColor=sprintf('%.3F g',$r/255);
+ else
+ $this->FillColor=sprintf('%.3F %.3F %.3F rg',$r/255,$g/255,$b/255);
+ $this->ColorFlag=($this->FillColor!=$this->TextColor);
+ if($this->page>0)
+ $this->_out($this->FillColor);
+function SetTextColor($r, $g=null, $b=null)
+ //Set color for text
+ $this->TextColor=sprintf('%.3F g',$r/255);
+ else
+ $this->TextColor=sprintf('%.3F %.3F %.3F rg',$r/255,$g/255,$b/255);
+function GetStringWidth($s)
+ //Get width of a string in the current font
+ $s=(string)$s;
+ $cw=&$this->CurrentFont['cw'];
+ $w=0;
+ $l=strlen($s);
+ for($i=0;$i<$l;$i++)
+ $w+=$cw[$s[$i]];
+ return $w*$this->FontSize/1000;
+function SetLineWidth($width)
+ //Set line width
+ $this->LineWidth=$width;
+ if($this->page>0)
+ $this->_out(sprintf('%.2F w',$width*$this->k));
+function Line($x1, $y1, $x2, $y2)
+ //Draw a line
+ $this->_out(sprintf('%.2F %.2F m %.2F %.2F l S',$x1*$this->k,($this->h-$y1)*$this->k,$x2*$this->k,($this->h-$y2)*$this->k));
+function Rect($x, $y, $w, $h, $style='')
+ //Draw a rectangle
+ if($style=='F')
+ $op='f';
+ elseif($style=='FD' || $style=='DF')
+ $op='B';
+ else
+ $op='S';
+ $this->_out(sprintf('%.2F %.2F %.2F %.2F re %s',$x*$this->k,($this->h-$y)*$this->k,$w*$this->k,-$h*$this->k,$op));
+function AddFont($family, $style='', $file='')
+ //Add a TrueType or Type1 font
+ $family=strtolower($family);
+ if($file=='')
+ $file=str_replace(' ','',$family).strtolower($style).'.php';
+ if($family=='arial')
+ $family='helvetica';
+ $style=strtoupper($style);
+ if($style=='IB')
+ $style='BI';
+ $fontkey=$family.$style;
+ if(isset($this->fonts[$fontkey]))
+ return;
+ include($this->_getfontpath().$file);
+ if(!isset($name))
+ $this->Error('Could not include font definition file');
+ $i=count($this->fonts)+1;
+ $this->fonts[$fontkey]=array('i'=>$i, 'type'=>$type, 'name'=>$name, 'desc'=>$desc, 'up'=>$up, 'ut'=>$ut, 'cw'=>$cw, 'enc'=>$enc, 'file'=>$file);
+ if($diff)
+ //Search existing encodings
+ $d=0;
+ $nb=count($this->diffs);
+ for($i=1;$i<=$nb;$i++)
+ if($this->diffs[$i]==$diff)
+ $d=$i;
+ break;
+ if($d==0)
+ $d=$nb+1;
+ $this->diffs[$d]=$diff;
+ $this->fonts[$fontkey]['diff']=$d;
+ if($file)
+ $this->FontFiles[$file]=array('length1'=>$originalsize);
+ else
+ $this->FontFiles[$file]=array('length1'=>$size1, 'length2'=>$size2);
+function SetFont($family, $style='', $size=0)
+ //Select a font; size given in points
+ global $fpdf_charwidths;
+ if($family=='')
+ elseif($family=='symbol' || $family=='zapfdingbats')
+ $style='';
+ if(strpos($style,'U')!==false)
+ $this->underline=true;
+ $style=str_replace('U','',$style);
+ else
+ if($style=='IB')
+ $style='BI';
+ if($size==0)
+ //Test if font is already selected
+ if($this->FontFamily==$family && $this->FontStyle==$style && $this->FontSizePt==$size)
+ return;
+ //Test if used for the first time
+ if(!isset($this->fonts[$fontkey]))
+ //Check if one of the standard fonts
+ if(isset($this->CoreFonts[$fontkey]))
+ if(!isset($fpdf_charwidths[$fontkey]))
+ //Load metric file
+ $file=$family;
+ if($family=='times' || $family=='helvetica')
+ $file.=strtolower($style);
+ include($this->_getfontpath().$file.'.php');
+ $this->Error('Could not include font metric file');
+ $name=$this->CoreFonts[$fontkey];
+ $cw=$fpdf_charwidths[$fontkey];
+ $this->fonts[$fontkey]=array('i'=>$i, 'type'=>'core', 'name'=>$name, 'up'=>-100, 'ut'=>50, 'cw'=>$cw);
+ else
+ $this->Error('Undefined font: '.$family.' '.$style);
+ //Select it
+ $this->FontFamily=$family;
+ $this->FontStyle=$style;
+ $this->FontSizePt=$size;
+ $this->FontSize=$size/$this->k;
+ $this->CurrentFont=&$this->fonts[$fontkey];
+ if($this->page>0)
+ $this->_out(sprintf('BT /F%d %.2F Tf ET',$this->CurrentFont['i'],$this->FontSizePt));
+function SetFontSize($size)
+ //Set font size in points
+ if($this->FontSizePt==$size)
+ return;
+ if($this->page>0)
+function AddLink()
+ //Create a new internal link
+ $n=count($this->links)+1;
+ $this->links[$n]=array(0, 0);
+ return $n;
+function SetLink($link, $y=0, $page=-1)
+ //Set destination of internal link
+ if($y==-1)
+ $y=$this->y;
+ if($page==-1)
+ $page=$this->page;
+ $this->links[$link]=array($page, $y);
+function Link($x, $y, $w, $h, $link)
+ //Put a link on the page
+ $this->PageLinks[$this->page][]=array($x*$this->k, $this->hPt-$y*$this->k, $w*$this->k, $h*$this->k, $link);
+function Text($x, $y, $txt)
+ //Output a string
+ $s=sprintf('BT %.2F %.2F Td (%s) Tj ET',$x*$this->k,($this->h-$y)*$this->k,$this->_escape($txt));
+ if($this->underline && $txt!='')
+ $s.=' '.$this->_dounderline($x,$y,$txt);
+ if($this->ColorFlag)
+ $s='q '.$this->TextColor.' '.$s.' Q';
+ $this->_out($s);
+function AcceptPageBreak()
+ //Accept automatic page break or not
+ return $this->AutoPageBreak;
+function Cell($w, $h=0, $txt='', $border=0, $ln=0, $align='', $fill=false, $link='')
+ //Output a cell
+ $k=$this->k;
+ if($this->y+$h>$this->PageBreakTrigger && !$this->InHeader && !$this->InFooter && $this->AcceptPageBreak())
+ $x=$this->x;
+ $ws=$this->ws;
+ if($ws>0)
+ $this->ws=0;
+ $this->_out('0 Tw');
+ $this->AddPage($this->CurOrientation,$this->CurPageFormat);
+ $this->x=$x;
+ if($ws>0)
+ $this->ws=$ws;
+ $this->_out(sprintf('%.3F Tw',$ws*$k));
+ if($w==0)
+ $w=$this->w-$this->rMargin-$this->x;
+ $s='';
+ if($fill || $border==1)
+ if($fill)
+ $op=($border==1) ? 'B' : 'f';
+ else
+ $op='S';
+ $s=sprintf('%.2F %.2F %.2F %.2F re %s ',$this->x*$k,($this->h-$this->y)*$k,$w*$k,-$h*$k,$op);
+ if(is_string($border))
+ $x=$this->x;
+ $y=$this->y;
+ if(strpos($border,'L')!==false)
+ $s.=sprintf('%.2F %.2F m %.2F %.2F l S ',$x*$k,($this->h-$y)*$k,$x*$k,($this->h-($y+$h))*$k);
+ if(strpos($border,'T')!==false)
+ $s.=sprintf('%.2F %.2F m %.2F %.2F l S ',$x*$k,($this->h-$y)*$k,($x+$w)*$k,($this->h-$y)*$k);
+ if(strpos($border,'R')!==false)
+ $s.=sprintf('%.2F %.2F m %.2F %.2F l S ',($x+$w)*$k,($this->h-$y)*$k,($x+$w)*$k,($this->h-($y+$h))*$k);
+ if(strpos($border,'B')!==false)
+ $s.=sprintf('%.2F %.2F m %.2F %.2F l S ',$x*$k,($this->h-($y+$h))*$k,($x+$w)*$k,($this->h-($y+$h))*$k);
+ if($txt!=='')
+ if($align=='R')
+ $dx=$w-$this->cMargin-$this->GetStringWidth($txt);
+ elseif($align=='C')
+ $dx=($w-$this->GetStringWidth($txt))/2;
+ else
+ $dx=$this->cMargin;
+ $s.='q '.$this->TextColor.' ';
+ $txt2=str_replace(')','\\)',str_replace('(','\\(',str_replace('\\','\\\\',$txt)));
+ $s.=sprintf('BT %.2F %.2F Td (%s) Tj ET',($this->x+$dx)*$k,($this->h-($this->y+.5*$h+.3*$this->FontSize))*$k,$txt2);
+ if($this->underline)
+ $s.=' '.$this->_dounderline($this->x+$dx,$this->y+.5*$h+.3*$this->FontSize,$txt);
+ $s.=' Q';
+ if($link)
+ $this->Link($this->x+$dx,$this->y+.5*$h-.5*$this->FontSize,$this->GetStringWidth($txt),$this->FontSize,$link);
+ if($s)
+ $this->_out($s);
+ $this->lasth=$h;
+ if($ln>0)
+ //Go to next line
+ $this->y+=$h;
+ if($ln==1)
+ $this->x=$this->lMargin;
+ else
+ $this->x+=$w;
+function MultiCell($w, $h, $txt, $border=0, $align='J', $fill=false)
+ //Output text with automatic or explicit line breaks
+ if($w==0)
+ $wmax=($w-2*$this->cMargin)*1000/$this->FontSize;
+ $s=str_replace("\r",'',$txt);
+ $nb=strlen($s);
+ if($nb>0 && $s[$nb-1]=="\n")
+ $nb--;
+ $b=0;
+ if($border)
+ if($border==1)
+ $border='LTRB';
+ $b='LRT';
+ $b2='LR';
+ else
+ $b2='';
+ $b2.='L';
+ $b2.='R';
+ $b=(strpos($border,'T')!==false) ? $b2.'T' : $b2;
+ $sep=-1;
+ $i=0;
+ $j=0;
+ $l=0;
+ $ns=0;
+ $nl=1;
+ while($i<$nb)
+ //Get next character
+ $c=$s[$i];
+ if($c=="\n")
+ //Explicit line break
+ if($this->ws>0)
+ $this->ws=0;
+ $this->Cell($w,$h,substr($s,$j,$i-$j),$b,2,$align,$fill);
+ $i++;
+ $sep=-1;
+ $j=$i;
+ $l=0;
+ $ns=0;
+ $nl++;
+ if($border && $nl==2)
+ $b=$b2;
+ continue;
+ if($c==' ')
+ $sep=$i;
+ $ls=$l;
+ $ns++;
+ $l+=$cw[$c];
+ if($l>$wmax)
+ //Automatic line break
+ if($sep==-1)
+ if($i==$j)
+ $i++;
+ if($this->ws>0)
+ $this->ws=0;
+ else
+ if($align=='J')
+ $this->ws=($ns>1) ? ($wmax-$ls)/1000*$this->FontSize/($ns-1) : 0;
+ $this->_out(sprintf('%.3F Tw',$this->ws*$this->k));
+ $this->Cell($w,$h,substr($s,$j,$sep-$j),$b,2,$align,$fill);
+ $i=$sep+1;
+ $sep=-1;
+ $j=$i;
+ $l=0;
+ $ns=0;
+ $nl++;
+ $b=$b2;
+ else
+ $i++;
+ //Last chunk
+ if($this->ws>0)
+ $this->ws=0;
+ if($border && strpos($border,'B')!==false)
+ $b.='B';
+function Write($h, $txt, $link='')
+ //Output text in flowing mode
+ $nb=strlen($s);
+ $sep=-1;
+ $i=0;
+ $j=0;
+ $l=0;
+ $nl=1;
+ while($i<$nb)
+ $c=$s[$i];
+ if($c=="\n")
+ $this->Cell($w,$h,substr($s,$j,$i-$j),0,2,'',0,$link);
+ $i++;
+ $sep=-1;
+ $j=$i;
+ $l=0;
+ if($nl==1)
+ $nl++;
+ continue;
+ if($c==' ')
+ $sep=$i;
+ $l+=$cw[$c];
+ if($l>$wmax)
+ if($sep==-1)
+ if($this->x>$this->lMargin)
+ //Move to next line
+ $this->y+=$h;
+ $i++;
+ $nl++;
+ continue;
+ if($i==$j)
+ $i++;
+ else
+ $this->Cell($w,$h,substr($s,$j,$sep-$j),0,2,'',0,$link);
+ $i=$sep+1;
+ $sep=-1;
+ $j=$i;
+ $l=0;
+ if($nl==1)
+ $nl++;
+ else
+ $i++;
+ //Last chunk
+ if($i!=$j)
+ $this->Cell($l/1000*$this->FontSize,$h,substr($s,$j),0,0,'',0,$link);
+function Ln($h=null)
+ //Line feed; default value is last cell height
+ if($h===null)
+ $this->y+=$this->lasth;
+ else
+ $this->y+=$h;
+function Image($file, $x=null, $y=null, $w=0, $h=0, $type='', $link='')
+ //Put an image on the page
+ if(!isset($this->images[$file]))
+ //First use of this image, get info
+ if($type=='')
+ $pos=strrpos($file,'.');
+ if(!$pos)
+ $this->Error('Image file has no extension and no type was specified: '.$file);
+ $type=substr($file,$pos+1);
+ $type=strtolower($type);
+ if($type=='jpeg')
+ $type='jpg';
+ $mtd='_parse'.$type;
+ if(!method_exists($this,$mtd))
+ $this->Error('Unsupported image type: '.$type);
+ $info=$this->$mtd($file);
+ $info['i']=count($this->images)+1;
+ $this->images[$file]=$info;
+ else
+ $info=$this->images[$file];
+ //Automatic width and height calculation if needed
+ if($w==0 && $h==0)
+ //Put image at 72 dpi
+ $w=$info['w']/$this->k;
+ $h=$info['h']/$this->k;
+ elseif($w==0)
+ $w=$h*$info['w']/$info['h'];
+ elseif($h==0)
+ $h=$w*$info['h']/$info['w'];
+ //Flowing mode
+ if($y===null)
+ $x2=$this->x;
+ $this->x=$x2;
+ $y=$this->y;
+ $this->y+=$h;
+ if($x===null)
+ $x=$this->x;
+ $this->_out(sprintf('q %.2F 0 0 %.2F %.2F %.2F cm /I%d Do Q',$w*$this->k,$h*$this->k,$x*$this->k,($this->h-($y+$h))*$this->k,$info['i']));
+ if($link)
+ $this->Link($x,$y,$w,$h,$link);
+function GetX()
+ //Get x position
+ return $this->x;
+function SetX($x)
+ //Set x position
+ if($x>=0)
+ $this->x=$x;
+ else
+ $this->x=$this->w+$x;
+function GetY()
+ //Get y position
+ return $this->y;
+function SetY($y)
+ //Set y position and reset x
+ if($y>=0)
+ $this->y=$y;
+ else
+ $this->y=$this->h+$y;
+function SetXY($x, $y)
+ //Set x and y positions
+ $this->SetY($y);
+ $this->SetX($x);
+function Output($name='', $dest='')
+ //Output PDF to some destination
+ if($this->state<3)
+ $this->Close();
+ $dest=strtoupper($dest);
+ if($dest=='')
+ if($name=='')
+ $name='doc.pdf';
+ $dest='I';
+ else
+ $dest='F';
+ switch($dest)
+ case 'I':
+ //Send to standard output
+ if(ob_get_length())
+ $this->Error('Some data has already been output, can\'t send PDF file');
+ if(php_sapi_name()!='cli')
+ //We send to a browser
+ header('Content-Type: application/pdf');
+ if(headers_sent())
+ header('Content-Length: '.strlen($this->buffer));
+ header('Content-Disposition: inline; filename="'.$name.'"');
+ header('Cache-Control: private, max-age=0, must-revalidate');
+ header('Pragma: public');
+ ini_set('zlib.output_compression','0');
+ echo $this->buffer;
+ break;
+ case 'D':
+ //Download file
+ header('Content-Type: application/x-download');
+ header('Content-Disposition: attachment; filename="'.$name.'"');
+ break;
+ case 'F':
+ //Save to local file
+ $f=fopen($name,'wb');
+ if(!$f)
+ $this->Error('Unable to create output file: '.$name);
+ fwrite($f,$this->buffer,strlen($this->buffer));
+ fclose($f);
+ break;
+ case 'S':
+ //Return as a string
+ return $this->buffer;
+ default:
+ $this->Error('Incorrect output destination: '.$dest);
+ return '';
+* Protected methods *
+function _dochecks()
+ //Check availability of %F
+ if(sprintf('%.1F',1.0)!='1.0')
+ $this->Error('This version of PHP is not supported');
+ //Check mbstring overloading
+ if(ini_get('mbstring.func_overload') & 2)
+ $this->Error('mbstring overloading must be disabled');
+ //Disable runtime magic quotes
+function _getpageformat($format)
+ $format=strtolower($format);
+ if(!isset($this->PageFormats[$format]))
+ $this->Error('Unknown page format: '.$format);
+ $a=$this->PageFormats[$format];
+ return array($a[0]/$this->k, $a[1]/$this->k);
+function _getfontpath()
+ if(!defined('FPDF_FONTPATH') && is_dir(dirname(__FILE__).'/font'))
+ define('FPDF_FONTPATH',dirname(__FILE__).'/font/');
+ return defined('FPDF_FONTPATH') ? FPDF_FONTPATH : '';
+function _beginpage($orientation, $format)
+ $this->page++;
+ $this->pages[$this->page]='';
+ $this->state=2;
+ $this->y=$this->tMargin;
+ //Check page size
+ if($orientation=='')
+ $orientation=$this->DefOrientation;
+ else
+ $orientation=strtoupper($orientation[0]);
+ if($format=='')
+ $format=$this->DefPageFormat;
+ else
+ if($orientation!=$this->CurOrientation || $format[0]!=$this->CurPageFormat[0] || $format[1]!=$this->CurPageFormat[1])
+ //New size
+ if($orientation=='P')
+ $this->w=$format[0];
+ $this->h=$format[1];
+ else
+ $this->w=$format[1];
+ $this->h=$format[0];
+ $this->PageBreakTrigger=$this->h-$this->bMargin;
+ $this->CurOrientation=$orientation;
+ if($orientation!=$this->DefOrientation || $format[0]!=$this->DefPageFormat[0] || $format[1]!=$this->DefPageFormat[1])
+ $this->PageSizes[$this->page]=array($this->wPt, $this->hPt);
+function _endpage()
+ $this->state=1;
+function _escape($s)
+ //Escape special characters in strings
+ $s=str_replace('\\','\\\\',$s);
+ $s=str_replace('(','\\(',$s);
+ $s=str_replace(')','\\)',$s);
+ $s=str_replace("\r",'\\r',$s);
+ return $s;
+function _textstring($s)
+ //Format a text string
+ return '('.$this->_escape($s).')';
+function _UTF8toUTF16($s)
+ //Convert UTF-8 to UTF-16BE with BOM
+ $res="\xFE\xFF";
+ $nb=strlen($s);
+ $i=0;
+ while($i<$nb)
+ $c1=ord($s[$i++]);
+ if($c1>=224)
+ //3-byte character
+ $c2=ord($s[$i++]);
+ $c3=ord($s[$i++]);
+ $res.=chr((($c1 & 0x0F)<<4) + (($c2 & 0x3C)>>2));
+ $res.=chr((($c2 & 0x03)<<6) + ($c3 & 0x3F));
+ elseif($c1>=192)
+ //2-byte character
+ $res.=chr(($c1 & 0x1C)>>2);
+ $res.=chr((($c1 & 0x03)<<6) + ($c2 & 0x3F));
+ else
+ //Single-byte character
+ $res.="\0".chr($c1);
+ return $res;
+function _dounderline($x, $y, $txt)
+ //Underline text
+ $up=$this->CurrentFont['up'];
+ $ut=$this->CurrentFont['ut'];
+ $w=$this->GetStringWidth($txt)+$this->ws*substr_count($txt,' ');
+ return sprintf('%.2F %.2F %.2F %.2F re f',$x*$this->k,($this->h-($y-$up/1000*$this->FontSize))*$this->k,$w*$this->k,-$ut/1000*$this->FontSizePt);
+function _parsejpg($file)
+ //Extract info from a JPEG file
+ $a=GetImageSize($file);
+ if(!$a)
+ $this->Error('Missing or incorrect image file: '.$file);
+ if($a[2]!=2)
+ $this->Error('Not a JPEG file: '.$file);
+ if(!isset($a['channels']) || $a['channels']==3)
+ $colspace='DeviceRGB';
+ elseif($a['channels']==4)
+ $colspace='DeviceCMYK';
+ else
+ $colspace='DeviceGray';
+ $bpc=isset($a['bits']) ? $a['bits'] : 8;
+ //Read whole file
+ $data='';
+ while(!feof($f))
+ $data.=fread($f,8192);
+ fclose($f);
+ return array('w'=>$a[0], 'h'=>$a[1], 'cs'=>$colspace, 'bpc'=>$bpc, 'f'=>'DCTDecode', 'data'=>$data);
+function _parsepng($file)
+ //Extract info from a PNG file
+ if(!$f)
+ $this->Error('Can\'t open image file: '.$file);
+ //Check signature
+ if($this->_readstream($f,8)!=chr(137).'PNG'.chr(13).chr(10).chr(26).chr(10))
+ $this->Error('Not a PNG file: '.$file);
+ //Read header chunk
+ $this->_readstream($f,4);
+ if($this->_readstream($f,4)!='IHDR')
+ $this->Error('Incorrect PNG file: '.$file);
+ $w=$this->_readint($f);
+ $h=$this->_readint($f);
+ $bpc=ord($this->_readstream($f,1));
+ if($bpc>8)
+ $this->Error('16-bit depth not supported: '.$file);
+ $ct=ord($this->_readstream($f,1));
+ if($ct==0)
+ elseif($ct==2)
+ elseif($ct==3)
+ $colspace='Indexed';
+ else
+ $this->Error('Alpha channel not supported: '.$file);
+ if(ord($this->_readstream($f,1))!=0)
+ $this->Error('Unknown compression method: '.$file);
+ $this->Error('Unknown filter method: '.$file);
+ $this->Error('Interlacing not supported: '.$file);
+ $parms='/DecodeParms <</Predictor 15 /Colors '.($ct==2 ? 3 : 1).' /BitsPerComponent '.$bpc.' /Columns '.$w.'>>';
+ //Scan chunks looking for palette, transparency and image data
+ $pal='';
+ $trns='';
+ $data='';
+ do
+ $n=$this->_readint($f);
+ $type=$this->_readstream($f,4);
+ if($type=='PLTE')
+ //Read palette
+ $pal=$this->_readstream($f,$n);
+ elseif($type=='tRNS')
+ //Read transparency info
+ $t=$this->_readstream($f,$n);
+ if($ct==0)
+ $trns=array(ord(substr($t,1,1)));
+ elseif($ct==2)
+ $trns=array(ord(substr($t,1,1)), ord(substr($t,3,1)), ord(substr($t,5,1)));
+ else
+ $pos=strpos($t,chr(0));
+ if($pos!==false)
+ $trns=array($pos);
+ elseif($type=='IDAT')
+ //Read image data block
+ $data.=$this->_readstream($f,$n);
+ elseif($type=='IEND')
+ break;
+ else
+ $this->_readstream($f,$n+4);
+ while($n);
+ if($colspace=='Indexed' && empty($pal))
+ $this->Error('Missing palette in '.$file);
+ fclose($f);
+ return array('w'=>$w, 'h'=>$h, 'cs'=>$colspace, 'bpc'=>$bpc, 'f'=>'FlateDecode', 'parms'=>$parms, 'pal'=>$pal, 'trns'=>$trns, 'data'=>$data);
+function _readstream($f, $n)
+ //Read n bytes from stream
+ $res='';
+ while($n>0 && !feof($f))
+ $s=fread($f,$n);
+ if($s===false)
+ $this->Error('Error while reading stream');
+ $n-=strlen($s);
+ $res.=$s;
+ if($n>0)
+ $this->Error('Unexpected end of stream');
+ return $res;
+function _readint($f)
+ //Read a 4-byte integer from stream
+ $a=unpack('Ni',$this->_readstream($f,4));
+ return $a['i'];
+function _parsegif($file)
+ //Extract info from a GIF file (via PNG conversion)
+ if(!function_exists('imagepng'))
+ $this->Error('GD extension is required for GIF support');
+ if(!function_exists('imagecreatefromgif'))
+ $this->Error('GD has no GIF read support');
+ $im=imagecreatefromgif($file);
+ if(!$im)
+ imageinterlace($im,0);
+ $tmp=tempnam('.','gif');
+ if(!$tmp)
+ $this->Error('Unable to create a temporary file');
+ if(!imagepng($im,$tmp))
+ $this->Error('Error while saving to temporary file');
+ imagedestroy($im);
+ $info=$this->_parsepng($tmp);
+ unlink($tmp);
+ return $info;
+function _newobj()
+ //Begin a new object
+ $this->n++;
+ $this->offsets[$this->n]=strlen($this->buffer);
+ $this->_out($this->n.' 0 obj');
+function _putstream($s)
+ $this->_out('stream');
+ $this->_out($s);
+ $this->_out('endstream');
+function _out($s)
+ //Add a line to the document
+ if($this->state==2)
+ $this->pages[$this->page].=$s."\n";
+ else
+ $this->buffer.=$s."\n";
+function _putpages()
+ $nb=$this->page;
+ if(!empty($this->AliasNbPages))
+ //Replace number of pages
+ for($n=1;$n<=$nb;$n++)
+ $this->pages[$n]=str_replace($this->AliasNbPages,$nb,$this->pages[$n]);
+ if($this->DefOrientation=='P')
+ $wPt=$this->DefPageFormat[0]*$this->k;
+ $hPt=$this->DefPageFormat[1]*$this->k;
+ else
+ $wPt=$this->DefPageFormat[1]*$this->k;
+ $hPt=$this->DefPageFormat[0]*$this->k;
+ $filter=($this->compress) ? '/Filter /FlateDecode ' : '';
+ //Page
+ $this->_newobj();
+ $this->_out('<</Type /Page');
+ $this->_out('/Parent 1 0 R');
+ if(isset($this->PageSizes[$n]))
+ $this->_out(sprintf('/MediaBox [0 0 %.2F %.2F]',$this->PageSizes[$n][0],$this->PageSizes[$n][1]));
+ $this->_out('/Resources 2 0 R');
+ if(isset($this->PageLinks[$n]))
+ //Links
+ $annots='/Annots [';
+ foreach($this->PageLinks[$n] as $pl)
+ $rect=sprintf('%.2F %.2F %.2F %.2F',$pl[0],$pl[1],$pl[0]+$pl[2],$pl[1]-$pl[3]);
+ $annots.='<</Type /Annot /Subtype /Link /Rect ['.$rect.'] /Border [0 0 0] ';
+ if(is_string($pl[4]))
+ $annots.='/A <</S /URI /URI '.$this->_textstring($pl[4]).'>>>>';
+ else
+ $l=$this->links[$pl[4]];
+ $h=isset($this->PageSizes[$l[0]]) ? $this->PageSizes[$l[0]][1] : $hPt;
+ $annots.=sprintf('/Dest [%d 0 R /XYZ 0 %.2F null]>>',1+2*$l[0],$h-$l[1]*$this->k);
+ $this->_out($annots.']');
+ $this->_out('/Contents '.($this->n+1).' 0 R>>');
+ $this->_out('endobj');
+ //Page content
+ $p=($this->compress) ? gzcompress($this->pages[$n]) : $this->pages[$n];
+ $this->_newobj();
+ $this->_out('<<'.$filter.'/Length '.strlen($p).'>>');
+ $this->_putstream($p);
+ //Pages root
+ $this->offsets[1]=strlen($this->buffer);
+ $this->_out('1 0 obj');
+ $this->_out('<</Type /Pages');
+ $kids='/Kids [';
+ $kids.=(3+2*$i).' 0 R ';
+ $this->_out($kids.']');
+ $this->_out('/Count '.$nb);
+ $this->_out(sprintf('/MediaBox [0 0 %.2F %.2F]',$wPt,$hPt));
+ $this->_out('>>');
+function _putfonts()
+ $nf=$this->n;
+ foreach($this->diffs as $diff)
+ //Encodings
+ $this->_newobj();
+ $this->_out('<</Type /Encoding /BaseEncoding /WinAnsiEncoding /Differences ['.$diff.']>>');
+ foreach($this->FontFiles as $file=>$info)
+ //Font file embedding
+ $this->_newobj();
+ $this->FontFiles[$file]['n']=$this->n;
+ $font='';
+ $f=fopen($this->_getfontpath().$file,'rb',1);
+ if(!$f)
+ $this->Error('Font file not found');
+ while(!feof($f))
+ $font.=fread($f,8192);
+ fclose($f);
+ $compressed=(substr($file,-2)=='.z');
+ if(!$compressed && isset($info['length2']))
+ $header=(ord($font[0])==128);
+ if($header)
+ $font=substr($font,6);
+ if($header && ord($font[$info['length1']])==128)
+ $font=substr($font,0,$info['length1']).substr($font,$info['length1']+6);
+ $this->_out('<</Length '.strlen($font));
+ if($compressed)
+ $this->_out('/Filter /FlateDecode');
+ $this->_out('/Length1 '.$info['length1']);
+ if(isset($info['length2']))
+ $this->_out('/Length2 '.$info['length2'].' /Length3 0');
+ $this->_putstream($font);
+ foreach($this->fonts as $k=>$font)
+ //Font objects
+ $this->fonts[$k]['n']=$this->n+1;
+ $type=$font['type'];
+ $name=$font['name'];
+ if($type=='core')
+ //Standard font
+ $this->_newobj();
+ $this->_out('<</Type /Font');
+ $this->_out('/BaseFont /'.$name);
+ $this->_out('/Subtype /Type1');
+ if($name!='Symbol' && $name!='ZapfDingbats')
+ $this->_out('/Encoding /WinAnsiEncoding');
+ elseif($type=='Type1' || $type=='TrueType')
+ //Additional Type1 or TrueType font
+ $this->_newobj();
+ $this->_out('/Subtype /'.$type);
+ $this->_out('/FirstChar 32 /LastChar 255');
+ $this->_out('/Widths '.($this->n+1).' 0 R');
+ $this->_out('/FontDescriptor '.($this->n+2).' 0 R');
+ if($font['enc'])
+ if(isset($font['diff']))
+ $this->_out('/Encoding '.($nf+$font['diff']).' 0 R');
+ else
+ //Widths
+ $this->_newobj();
+ $cw=&$font['cw'];
+ $s='[';
+ $s.=$cw[chr($i)].' ';
+ $this->_out($s.']');
+ //Descriptor
+ $this->_newobj();
+ $s='<</Type /FontDescriptor /FontName /'.$name;
+ foreach($font['desc'] as $k=>$v)
+ $s.=' /'.$k.' '.$v;
+ $file=$font['file'];
+ if($file)
+ $s.=' /FontFile'.($type=='Type1' ? '' : '2').' '.$this->FontFiles[$file]['n'].' 0 R';
+ $this->_out($s.'>>');
+ else
+ //Allow for additional types
+ $mtd='_put'.strtolower($type);
+ $this->Error('Unsupported font type: '.$type);
+ $this->$mtd($font);
+function _putimages()
+ reset($this->images);
+ while(list($file,$info)=each($this->images))
+ $this->_newobj();
+ $this->images[$file]['n']=$this->n;
+ $this->_out('<</Type /XObject');
+ $this->_out('/Subtype /Image');
+ $this->_out('/Width '.$info['w']);
+ $this->_out('/Height '.$info['h']);
+ if($info['cs']=='Indexed')
+ $this->_out('/ColorSpace [/Indexed /DeviceRGB '.(strlen($info['pal'])/3-1).' '.($this->n+1).' 0 R]');
+ else
+ $this->_out('/ColorSpace /'.$info['cs']);
+ if($info['cs']=='DeviceCMYK')
+ $this->_out('/Decode [1 0 1 0 1 0 1 0]');
+ $this->_out('/BitsPerComponent '.$info['bpc']);
+ if(isset($info['f']))
+ $this->_out('/Filter /'.$info['f']);
+ if(isset($info['parms']))
+ $this->_out($info['parms']);
+ if(isset($info['trns']) && is_array($info['trns']))
+ $trns='';
+ for($i=0;$i<count($info['trns']);$i++)
+ $trns.=$info['trns'][$i].' '.$info['trns'][$i].' ';
+ $this->_out('/Mask ['.$trns.']');
+ $this->_out('/Length '.strlen($info['data']).'>>');
+ $this->_putstream($info['data']);
+ unset($this->images[$file]['data']);
+ //Palette
+ $this->_newobj();
+ $pal=($this->compress) ? gzcompress($info['pal']) : $info['pal'];
+ $this->_out('<<'.$filter.'/Length '.strlen($pal).'>>');
+ $this->_putstream($pal);
+function _putxobjectdict()
+ foreach($this->images as $image)
+ $this->_out('/I'.$image['i'].' '.$image['n'].' 0 R');
+function _putresourcedict()
+ $this->_out('/ProcSet [/PDF /Text /ImageB /ImageC /ImageI]');
+ $this->_out('/Font <<');
+ foreach($this->fonts as $font)
+ $this->_out('/F'.$font['i'].' '.$font['n'].' 0 R');
+ $this->_out('/XObject <<');
+ $this->_putxobjectdict();
+function _putresources()
+ $this->_putfonts();
+ $this->_putimages();
+ //Resource dictionary
+ $this->offsets[2]=strlen($this->buffer);
+ $this->_out('2 0 obj');
+ $this->_out('<<');
+ $this->_putresourcedict();
+function _putinfo()
+ $this->_out('/Producer '.$this->_textstring('FPDF '.FPDF_VERSION));
+ if(!empty($this->title))
+ $this->_out('/Title '.$this->_textstring($this->title));
+ if(!empty($this->subject))
+ $this->_out('/Subject '.$this->_textstring($this->subject));
+ if(!empty($this->author))
+ $this->_out('/Author '.$this->_textstring($this->author));
+ if(!empty($this->keywords))
+ $this->_out('/Keywords '.$this->_textstring($this->keywords));
+ if(!empty($this->creator))
+ $this->_out('/Creator '.$this->_textstring($this->creator));
+ $this->_out('/CreationDate '.$this->_textstring('D:'. at date('YmdHis')));
+function _putcatalog()
+ $this->_out('/Type /Catalog');
+ $this->_out('/Pages 1 0 R');
+ if($this->ZoomMode=='fullpage')
+ $this->_out('/OpenAction [3 0 R /Fit]');
+ elseif($this->ZoomMode=='fullwidth')
+ $this->_out('/OpenAction [3 0 R /FitH null]');
+ elseif($this->ZoomMode=='real')
+ $this->_out('/OpenAction [3 0 R /XYZ null null 1]');
+ elseif(!is_string($this->ZoomMode))
+ $this->_out('/OpenAction [3 0 R /XYZ null null '.($this->ZoomMode/100).']');
+ if($this->LayoutMode=='single')
+ $this->_out('/PageLayout /SinglePage');
+ elseif($this->LayoutMode=='continuous')
+ $this->_out('/PageLayout /OneColumn');
+ elseif($this->LayoutMode=='two')
+ $this->_out('/PageLayout /TwoColumnLeft');
+function _putheader()
+ $this->_out('%PDF-'.$this->PDFVersion);
+function _puttrailer()
+ $this->_out('/Size '.($this->n+1));
+ $this->_out('/Root '.$this->n.' 0 R');
+ $this->_out('/Info '.($this->n-1).' 0 R');
+function _enddoc()
+ $this->_putheader();
+ $this->_putpages();
+ $this->_putresources();
+ //Info
+ $this->_newobj();
+ $this->_putinfo();
+ //Catalog
+ $this->_newobj();
+ $this->_putcatalog();
+ //Cross-ref
+ $o=strlen($this->buffer);
+ $this->_out('xref');
+ $this->_out('0 '.($this->n+1));
+ $this->_out('0000000000 65535 f ');
+ for($i=1;$i<=$this->n;$i++)
+ $this->_out(sprintf('%010d 00000 n ',$this->offsets[$i]));
+ //Trailer
+ $this->_out('trailer');
+ $this->_puttrailer();
+ $this->_out('startxref');
+ $this->_out($o);
+ $this->_out('%%EOF');
+ $this->state=3;
+//End of class
+//Handle special IE contype request
+if(isset($_SERVER['HTTP_USER_AGENT']) && $_SERVER['HTTP_USER_AGENT']=='contype')
+ exit;
Added: branches/print_dev/http/extensions/fpdf/fpdf_tpl.php
--- branches/print_dev/http/extensions/fpdf/fpdf_tpl.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/fpdf_tpl.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,397 @@
+<?php
+// FPDF_TPL - Version 1.1.2
+// Copyright 2004-2008 Setasign - Jan Slabon
+// Licensed under the Apache License, Version 2.0 (the "License");
+// you may not use this file except in compliance with the License.
+// You may obtain a copy of the License at
+// http://www.apache.org/licenses/LICENSE-2.0
+// Unless required by applicable law or agreed to in writing, software
+// distributed under the License is distributed on an "AS IS" BASIS,
+// WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
+// See the License for the specific language governing permissions and
+// limitations under the License.
+class FPDF_TPL extends FPDF {
+ * Array of Tpl-Data
+ * @var array
+ var $tpls = array();
+ * Current Template-ID
+ * @var int
+ var $tpl = 0;
+ * "In Template"-Flag
+ * @var boolean
+ var $_intpl = false;
+ * Nameprefix of Templates used in Resources-Dictonary
+ * @var string A String defining the Prefix used as Template-Object-Names. Have to beginn with an /
+ var $tplprefix = "/TPL";
+ * Resources used By Templates and Pages
+ * @var array
+ var $_res = array();
+ * Start a Template
+ * This method starts a template. You can give own coordinates to build an own sized
+ * Template. Pay attention, that the margins are adapted to the new templatesize.
+ * If you want to write outside the template, for example to build a clipped Template,
+ * you have to set the Margins and "Cursor"-Position manual after beginTemplate-Call.
+ * If no parameter is given, the template uses the current page-size.
+ * The Method returns an ID of the current Template. This ID is used later for using this template.
+ * Warning: A created Template is used in PDF at all events. Still if you don't use it after creation!
+ * @param int $x The x-coordinate given in user-unit
+ * @param int $y The y-coordinate given in user-unit
+ * @param int $w The width given in user-unit
+ * @param int $h The height given in user-unit
+ * @return int The ID of new created Template
+ function beginTemplate($x=null, $y=null, $w=null, $h=null) {
+ if ($this->page <= 0)
+ $this->error("You have to add a page to fpdf first!");
+ if ($x == null)
+ $x = 0;
+ if ($y == null)
+ $y = 0;
+ if ($w == null)
+ $w = $this->w;
+ if ($h == null)
+ $h = $this->h;
+ // Save settings
+ $this->tpl++;
+ $tpl =& $this->tpls[$this->tpl];
+ $tpl = array(
+ 'o_x' => $this->x,
+ 'o_y' => $this->y,
+ 'o_AutoPageBreak' => $this->AutoPageBreak,
+ 'o_bMargin' => $this->bMargin,
+ 'o_tMargin' => $this->tMargin,
+ 'o_lMargin' => $this->lMargin,
+ 'o_rMargin' => $this->rMargin,
+ 'o_h' => $this->h,
+ 'o_w' => $this->w,
+ 'buffer' => '',
+ 'x' => $x,
+ 'y' => $y,
+ 'w' => $w,
+ 'h' => $h
+ $this->SetAutoPageBreak(false);
+ // Define own high and width to calculate possitions correct
+ $this->h = $h;
+ $this->w = $w;
+ $this->_intpl = true;
+ $this->SetXY($x+$this->lMargin, $y+$this->tMargin);
+ $this->SetRightMargin($this->w-$w+$this->rMargin);
+ return $this->tpl;
+ * End Template
+ * This method ends a template and reset initiated variables on beginTemplate.
+ * @return mixed If a template is opened, the ID is returned. If not a false is returned.
+ function endTemplate() {
+ if ($this->_intpl) {
+ $this->_intpl = false;
+ $this->SetXY($tpl['o_x'], $tpl['o_y']);
+ $this->tMargin = $tpl['o_tMargin'];
+ $this->lMargin = $tpl['o_lMargin'];
+ $this->rMargin = $tpl['o_rMargin'];
+ $this->h = $tpl['o_h'];
+ $this->w = $tpl['o_w'];
+ $this->SetAutoPageBreak($tpl['o_AutoPageBreak'], $tpl['o_bMargin']);
+ } else {
+ return false;
+ * Use a Template in current Page or other Template
+ * You can use a template in a page or in another template.
+ * You can give the used template a new size like you use the Image()-method.
+ * All parameters are optional. The width or height is calculated automaticaly
+ * if one is given. If no parameter is given the origin size as defined in
+ * beginTemplate() is used.
+ * The calculated or used width and height are returned as an array.
+ * @param int $tplidx A valid template-Id
+ * @param int $_x The x-position
+ * @param int $_y The y-position
+ * @param int $_w The new width of the template
+ * @param int $_h The new height of the template
+ * @retrun array The height and width of the template
+ function useTemplate($tplidx, $_x=null, $_y=null, $_w=0, $_h=0) {
+ if (!isset($this->tpls[$tplidx]))
+ $this->error("Template does not exist!");
+ $this->_res['tpl'][$this->tpl]['tpls'][$tplidx] =& $this->tpls[$tplidx];
+ $tpl =& $this->tpls[$tplidx];
+ $x = $tpl['x'];
+ $y = $tpl['y'];
+ $w = $tpl['w'];
+ $h = $tpl['h'];
+ if ($_x == null)
+ $_x = $x;
+ if ($_y == null)
+ $_y = $y;
+ $wh = $this->getTemplateSize($tplidx, $_w, $_h);
+ $_w = $wh['w'];
+ $_h = $wh['h'];
+ $this->_out(sprintf("q %.4f 0 0 %.4f %.2f %.2f cm", ($_w/$w), ($_h/$h), $_x*$this->k, ($this->h-($_y+$_h))*$this->k)); // Translate
+ $this->_out($this->tplprefix.$tplidx." Do Q");
+ return array("w" => $_w, "h" => $_h);
+ * Get The calculated Size of a Template
+ * If one size is given, this method calculates the other one.
+ * @param int $_w The width of the template
+ * @param int $_h The height of the template
+ * @return array The height and width of the template
+ function getTemplateSize($tplidx, $_w=0, $_h=0) {
+ if (!$this->tpls[$tplidx])
+ return false;
+ $w = $tpl['w'];
+ $h = $tpl['h'];
+ if ($_w == 0 and $_h == 0) {
+ $_w = $w;
+ $_h = $h;
+ if($_w==0)
+ $_w = $_h*$w/$h;
+ if($_h==0)
+ $_h = $_w*$h/$w;
+ * See FPDF-Documentation ;-)
+ function SetFont($family, $style='', $size=0) {
+ * force the resetting of font changes in a template
+ $this->FontFamily = '';
+ parent::SetFont($family, $style, $size);
+ $fontkey = $this->FontFamily.$this->FontStyle;
+ $this->_res['tpl'][$this->tpl]['fonts'][$fontkey] =& $this->fonts[$fontkey];
+ } else {
+ $this->_res['page'][$this->page]['fonts'][$fontkey] =& $this->fonts[$fontkey];
+ * See FPDF/TCPDF-Documentation ;-)
+ function Image($file, $x, $y, $w=0, $h=0, $type='', $link='', $align='', $resize=false, $dpi=300) {
+ if (!is_subclass_of($this, 'TCPDF') && func_num_args() > 7) {
+ $this->Error('More than 7 arguments for the Image method are only available in TCPDF.');
+ parent::Image($file, $x, $y, $w, $h, $type, $link, $align, $resize, $dpi);
+ $this->_res['tpl'][$this->tpl]['images'][$file] =& $this->images[$file];
+ } else {
+ $this->_res['page'][$this->page]['images'][$file] =& $this->images[$file];
+ * AddPage is not available when you're "in" a template.
+ function AddPage($orientation='', $format='') {
+ $this->Error('Adding pages in templates isn\'t possible!');
+ parent::AddPage($orientation, $format);
+ * Preserve adding Links in Templates ...won't work
+ function Link($x, $y, $w, $h, $link) {
+ $this->Error('Using links in templates aren\'t possible!');
+ parent::Link($x, $y, $w, $h, $link);
+ function AddLink() {
+ $this->Error('Adding links in templates aren\'t possible!');
+ return parent::AddLink();
+ function SetLink($link, $y=0, $page=-1) {
+ $this->Error('Setting links in templates aren\'t possible!');
+ parent::SetLink($link, $y, $page);
+ * Private Method that writes the form xobjects
+ function _putformxobjects() {
+ reset($this->tpls);
+ foreach($this->tpls AS $tplidx => $tpl) {
+ $p=($this->compress) ? gzcompress($tpl['buffer']) : $tpl['buffer'];
+ $this->_newobj();
+ $this->tpls[$tplidx]['n'] = $this->n;
+ $this->_out('<<'.$filter.'/Type /XObject');
+ $this->_out('/Subtype /Form');
+ $this->_out('/FormType 1');
+ $this->_out(sprintf('/BBox [%.2f %.2f %.2f %.2f]',$tpl['x']*$this->k, ($tpl['h']-$tpl['y'])*$this->k, $tpl['w']*$this->k, ($tpl['h']-$tpl['y']-$tpl['h'])*$this->k));
+ $this->_out('/Resources ');
+ $this->_out('<</ProcSet [/PDF /Text /ImageB /ImageC /ImageI]');
+ if (isset($this->_res['tpl'][$tplidx]['fonts']) && count($this->_res['tpl'][$tplidx]['fonts'])) {
+ foreach($this->_res['tpl'][$tplidx]['fonts'] as $font)
+ if(isset($this->_res['tpl'][$tplidx]['images']) && count($this->_res['tpl'][$tplidx]['images']) ||
+ isset($this->_res['tpl'][$tplidx]['tpls']) && count($this->_res['tpl'][$tplidx]['tpls']))
+ if (isset($this->_res['tpl'][$tplidx]['images']) && count($this->_res['tpl'][$tplidx]['images'])) {
+ foreach($this->_res['tpl'][$tplidx]['images'] as $image)
+ if (isset($this->_res['tpl'][$tplidx]['tpls']) && count($this->_res['tpl'][$tplidx]['tpls'])) {
+ foreach($this->_res['tpl'][$tplidx]['tpls'] as $i => $tpl)
+ $this->_out($this->tplprefix.$i.' '.$tpl['n'].' 0 R');
+ $this->_out('/Length '.strlen($p).' >>');
+ * Private Method
+ function _putresources() {
+ if (!is_subclass_of($this, 'TCPDF')) {
+ $this->_putformxobjects();
+ } else {
+ $this->_putextgstates();
+ $this->_putocg();
+ $this->_putshaders();
+ $this->_putjavascript();
+ $this->_putbookmarks();
+ // encryption
+ if ($this->encrypted) {
+ $this->_newobj();
+ $this->enc_obj_id = $this->n;
+ $this->_putencryption();
+ function _putxobjectdict() {
+ parent::_putxobjectdict();
+ if (count($this->tpls)) {
+ foreach($this->tpls as $tplidx => $tpl) {
+ $this->_out($this->tplprefix.$tplidx.' '.$tpl['n'].' 0 R');
+ * Private Method
+ function _out($s) {
+ if ($this->state==2 && $this->_intpl) {
+ $this->tpls[$this->tpl]['buffer'] .= $s."\n";
+ } else {
+ parent::_out($s);
Added: branches/print_dev/http/extensions/fpdf/fpdi.php
--- branches/print_dev/http/extensions/fpdf/fpdi.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/fpdi.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,500 @@
+<?php
+// FPDI - Version 1.2.1
+define('FPDI_VERSION','1.2.1');
+// Check for TCPDF and remap TCPDF to FPDF
+if (class_exists('TCPDF')) {
+ require_once('fpdi2tcpdf_bridge.php');
+require_once("fpdf_tpl.php");
+require_once("fpdi_pdf_parser.php");
+class FPDI extends FPDF_TPL {
+ * Actual filename
+ * @var string
+ var $current_filename;
+ * Parser-Objects
+ * @var array
+ var $parsers;
+ * Current parser
+ * @var object
+ var $current_parser;
+ * object stack
+ * @var array
+ var $_obj_stack;
+ * done object stack
+ * @var array
+ var $_don_obj_stack;
+ * Current Object Id.
+ * @var integer
+ var $_current_obj_id;
+ * The name of the last imported page box
+ * @var string
+ var $lastUsedPageBox;
+ var $_importedPages = array();
+ * Set a source-file
+ * @param string $filename a valid filename
+ * @return int number of available pages
+ function setSourceFile($filename) {
+ $this->current_filename = $filename;
+ $fn =& $this->current_filename;
+ if (!isset($this->parsers[$fn]))
+ $this->parsers[$fn] =& new fpdi_pdf_parser($fn,$this);
+ $this->current_parser =& $this->parsers[$fn];
+ return $this->parsers[$fn]->getPageCount();
+ * Import a page
+ * @param int $pageno pagenumber
+ * @return int Index of imported page - to use with fpdf_tpl::useTemplate()
+ function importPage($pageno, $boxName='/CropBox') {
+ return $this->error("Please import the desired pages before creating a new template.");
+ // check if page already imported
+ $pageKey = $fn.((int)$pageno).$boxName;
+ if (isset($this->_importedPages[$pageKey]))
+ return $this->_importedPages[$pageKey];
+ $parser =& $this->parsers[$fn];
+ $parser->setPageno($pageno);
+ $this->tpl++;
+ $this->tpls[$this->tpl] = array();
+ $tpl['parser'] =& $parser;
+ $tpl['resources'] = $parser->getPageResources();
+ $tpl['buffer'] = $parser->getContent();
+ if (!in_array($boxName, $parser->availableBoxes))
+ return $this->Error(sprintf("Unknown box: %s", $boxName));
+ $pageboxes = $parser->getPageBoxes($pageno);
+ * MediaBox
+ * CropBox: Default -> MediaBox
+ * BleedBox: Default -> CropBox
+ * TrimBox: Default -> CropBox
+ * ArtBox: Default -> CropBox
+ if (!isset($pageboxes[$boxName]) && ($boxName == "/BleedBox" || $boxName == "/TrimBox" || $boxName == "/ArtBox"))
+ $boxName = "/CropBox";
+ if (!isset($pageboxes[$boxName]) && $boxName == "/CropBox")
+ $boxName = "/MediaBox";
+ if (!isset($pageboxes[$boxName]))
+ return false;
+ $this->lastUsedPageBox = $boxName;
+ $box = $pageboxes[$boxName];
+ $tpl['box'] = $box;
+ // To build an array that can be used by PDF_TPL::useTemplate()
+ $this->tpls[$this->tpl] = array_merge($this->tpls[$this->tpl],$box);
+ // An imported page will start at 0,0 everytime. Translation will be set in _putformxobjects()
+ $tpl['x'] = 0;
+ $tpl['y'] = 0;
+ $page =& $parser->pages[$parser->pageno];
+ // fix for rotated pages
+ $rotation = $parser->getPageRotation($pageno);
+ if (isset($rotation[1]) && ($angle = $rotation[1] % 360) != 0) {
+ $steps = $angle / 90;
+ $_w = $tpl['w'];
+ $_h = $tpl['h'];
+ $tpl['w'] = $steps % 2 == 0 ? $_w : $_h;
+ $tpl['h'] = $steps % 2 == 0 ? $_h : $_w;
+ if ($steps % 2 != 0) {
+ $x = $y = ($steps == 1 || $steps == -3) ? $tpl['h'] : $tpl['w'];
+ } else {
+ $x = $tpl['w'];
+ $y = $tpl['h'];
+ $cx=($x/2+$tpl['box']['x'])*$this->k;
+ $cy=($y/2+$tpl['box']['y'])*$this->k;
+ $angle*=-1;
+ $angle*=M_PI/180;
+ $c=cos($angle);
+ $s=sin($angle);
+ $tpl['buffer'] = sprintf('q %.5f %.5f %.5f %.5f %.2f %.2f cm 1 0 0 1 %.2f %.2f cm %s Q',$c,$s,-$s,$c,$cx,$cy,-$cx,-$cy, $tpl['buffer']);
+ $this->_importedPages[$pageKey] = $this->tpl;
+ function getLastUsedPageBox() {
+ return $this->lastUsedPageBox;
+ $this->_out('q 0 J 1 w 0 j 0 G 0 g'); // reset standard values
+ $s = parent::useTemplate($tplidx, $_x, $_y, $_w, $_h);
+ $this->_out('Q');
+ return $s;
+ * Private method, that rebuilds all needed objects of source files
+ function _putimportedobjects() {
+ if (is_array($this->parsers) && count($this->parsers) > 0) {
+ foreach($this->parsers AS $filename => $p) {
+ $this->current_parser =& $this->parsers[$filename];
+ if (isset($this->_obj_stack[$filename]) && is_array($this->_obj_stack[$filename])) {
+ while($n = key($this->_obj_stack[$filename])) {
+ $nObj = $this->current_parser->pdf_resolve_object($this->current_parser->c,$this->_obj_stack[$filename][$n][1]);
+ $this->_newobj($this->_obj_stack[$filename][$n][0]);
+ if ($nObj[0] == PDF_TYPE_STREAM) {
+ $this->pdf_write_value ($nObj);
+ } else {
+ $this->pdf_write_value ($nObj[1]);
+ $this->_obj_stack[$filename][$n] = null; // free memory
+ unset($this->_obj_stack[$filename][$n]);
+ reset($this->_obj_stack[$filename]);
+ * Put resources
+ $this->_putimportedobjects();
+ } else { // TCPDF - Part
+ $this->_putocg();
+ // encryption
+ $this->_newobj();
+ $this->_newobj();
+ $cN = $this->n; // TCPDF/Protection: rem current "n"
+ ($tpl['x'] + (isset($tpl['box']['x'])?$tpl['box']['x']:0))*$this->k,
+ ($tpl['h'] + (isset($tpl['box']['y'])?$tpl['box']['y']:0) - $tpl['y'])*$this->k,
+ ($tpl['w'] + (isset($tpl['box']['x'])?$tpl['box']['x']:0))*$this->k,
+ ($tpl['h'] + (isset($tpl['box']['y'])?$tpl['box']['y']:0) - $tpl['y']-$tpl['h'])*$this->k)
+ if (isset($tpl['box']))
+ $this->_out(sprintf('/Matrix [1 0 0 1 %.5f %.5f]',-$tpl['box']['x']*$this->k, -$tpl['box']['y']*$this->k));
+ if (isset($tpl['resources'])) {
+ $this->current_parser =& $tpl['parser'];
+ $this->pdf_write_value($tpl['resources']); // "n" will be changed
+ } else {
+ $nN = $this->n; // TCPDF: rem new "n"
+ $this->n = $cN; // TCPDF: reset to current "n"
+ $this->n = $nN; // TCPDF: reset to new "n"
+ * Rewritten to handle existing own defined objects
+ function _newobj($obj_id=false,$onlynewobj=false) {
+ if (!$obj_id) {
+ $obj_id = ++$this->n;
+ if (!$onlynewobj) {
+ $this->offsets[$obj_id] = strlen($this->buffer);
+ $this->_out($obj_id.' 0 obj');
+ $this->_current_obj_id = $obj_id; // for later use with encryption
+ * Writes a value
+ * Needed to rebuild the source document
+ * @param mixed $value A PDF-Value. Structure of values see cases in this method
+ function pdf_write_value(&$value)
+ if (is_subclass_of($this, 'TCPDF')) {
+ parent::pdf_write_value($value);
+ switch ($value[0]) {
+ case PDF_TYPE_NUMERIC :
+ case PDF_TYPE_TOKEN :
+ case PDF_TYPE_REAL :
+ // A numeric value or a token.
+ // Simply output them
+ $this->_out($value[1]." ", false);
+ break;
+ case PDF_TYPE_ARRAY :
+ // An array. Output the proper
+ // structure and move on.
+ $this->_out("[",false);
+ for ($i = 0; $i < count($value[1]); $i++) {
+ $this->pdf_write_value($value[1][$i]);
+ $this->_out("]");
+ break;
+ case PDF_TYPE_DICTIONARY :
+ // A dictionary.
+ $this->_out("<<",false);
+ reset ($value[1]);
+ while (list($k, $v) = each($value[1])) {
+ $this->_out($k . " ",false);
+ $this->pdf_write_value($v);
+ $this->_out(">>");
+ break;
+ case PDF_TYPE_OBJREF :
+ // An indirect object reference
+ // Fill the object stack if needed
+ $cpfn =& $this->current_parser->filename;
+ if (!isset($this->_don_obj_stack[$cpfn][$value[1]])) {
+ $this->_newobj(false,true);
+ $this->_obj_stack[$cpfn][$value[1]] = array($this->n, $value);
+ $this->_don_obj_stack[$cpfn][$value[1]] = array($this->n, $value); // Value is maybee obsolete!!!
+ $objid = $this->_don_obj_stack[$cpfn][$value[1]][0];
+ $this->_out("{$objid} 0 R");
+ break;
+ case PDF_TYPE_STRING :
+ // A string.
+ $this->_out('('.$value[1].')');
+ break;
+ case PDF_TYPE_STREAM :
+ // A stream. First, output the
+ // stream dictionary, then the
+ // stream data itself.
+ $this->pdf_write_value($value[1]);
+ $this->_out("stream");
+ $this->_out($value[2][1]);
+ $this->_out("endstream");
+ break;
+ case PDF_TYPE_HEX :
+ $this->_out("<".$value[1].">");
+ break;
+ case PDF_TYPE_BOOLEAN :
+ $this->_out($value[1] ? 'true ' : 'false ', false);
+ break;
+ case PDF_TYPE_NULL :
+ // The null object.
+ $this->_out("null");
+ break;
+ * Modified so not each call will add a newline to the output.
+ function _out($s, $ln=true) {
+ if ($this->state==2) {
+ if (!$this->_intpl) {
+ if (is_subclass_of($this, 'TCPDF') && isset($this->footerlen[$this->page]) AND ($this->footerlen[$this->page] > 0)) {
+ // puts data before page footer
+ $page = substr($this->pages[$this->page], 0, -$this->footerlen[$this->page]);
+ $footer = substr($this->pages[$this->page], -$this->footerlen[$this->page]);
+ $this->pages[$this->page] = $page." ".$s."\n".$footer;
+ } else {
+ $this->pages[$this->page] .= $s.($ln == true ? "\n" : '');
+ } else
+ $this->tpls[$this->tpl]['buffer'] .= $s.($ln == true ? "\n" : '');
+ } else {
+ $this->buffer.=$s.($ln == true ? "\n" : '');
+ * rewritten to close opened parsers
+ function _enddoc() {
+ parent::_enddoc();
+ $this->_closeParsers();
+ * close all files opened by parsers
+ function _closeParsers() {
+ if ($this->state > 2 && count($this->parsers) > 0) {
+ foreach ($this->parsers as $k => $_){
+ $this->parsers[$k]->closeFile();
+ $this->parsers[$k] = null;
+ unset($this->parsers[$k]);
+ return true;
+ return false;
\ No newline at end of file
Added: branches/print_dev/http/extensions/fpdf/fpdi2tcpdf_bridge.php
--- branches/print_dev/http/extensions/fpdf/fpdi2tcpdf_bridge.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/fpdi2tcpdf_bridge.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,134 @@
+<?php
+ * This class is used as a bridge between TCPDF and FPDI
+ * and will create the possibility to use both FPDF and TCPDF
+ * via one FPDI version.
+ * We'll simply remap TCPDF to FPDF again.
+ * It'll be loaded and extended by FPDF_TPL.
+class FPDF extends TCPDF {
+ * Missing in TCPDF
+ * @var string
+ var $padding;
+ function __get($name) {
+ switch ($name) {
+ case 'PDFVersion':
+ return $this->PDFVersion;
+ case 'k':
+ return $this->k;
+ case 'lastUsedPageBox':
+ default:
+ // Error handling
+ $this->Error('Cannot access protected property '.get_class($this).':$'.$name.' / Undefined property: '.get_class($this).'::$'.$name);
+ function __set($name, $value) {
+ switch ($name) {
+ $this->PDFVersion = $value;
+ break;
+ default:
+ // Error handling
+ * Encryption of imported data by FPDI
+ * @param array $value
+ function pdf_write_value(&$value) {
+ $value[1] = $this->_unescape($value[1]);
+ $value[1] = $this->_RC4($this->_objectkey($this->_current_obj_id), $value[1]);
+ $value[1] = $this->_escape($value[1]);
+ break;
+ $value[2][1] = $this->_RC4($this->_objectkey($this->_current_obj_id), $value[2][1]);
+ break;
+ $value[1] = $this->hex2str($value[1]);
+ // remake hexstring of encrypted string
+ $value[1] = $this->str2hex($value[1]);
+ break;
+ * Unescapes a PDF string
+ * @param string $s
+ * @return string
+ function _unescape($s) {
+ return strtr($s, array(
+ '\\f' => chr(0x0C),
+ '\\b' => chr(0x08),
+ '\\t' => chr(0x09),
+ '\\r' => chr(0x0D),
+ '\\n' => chr(0x0A),
+ * Hexadecimal to string
+ * @param string $hex
+ * @return string
+ function hex2str($hex) {
+ return pack("H*", str_replace(array("\r", "\n", " "), "", $hex));
+ * String to hexadecimal
+ * @param string $str
+ * @return string
+ function str2hex($str) {
+ return current(unpack("H*", $str));
Added: branches/print_dev/http/extensions/fpdf/fpdi_pdf_parser.php
--- branches/print_dev/http/extensions/fpdf/fpdi_pdf_parser.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/fpdi_pdf_parser.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,380 @@
+<?php
+require_once("pdf_parser.php");
+class fpdi_pdf_parser extends pdf_parser {
+ * Pages
+ * Index beginns at 0
+ * @var array
+ var $pages;
+ * Page count
+ * @var integer
+ var $page_count;
+ * actual page number
+ * @var integer
+ var $pageno;
+ * PDF Version of imported Document
+ * @var string
+ var $pdfVersion;
+ * FPDI Reference
+ * @var object
+ var $fpdi;
+ * Available BoxTypes
+ * @var array
+ var $availableBoxes = array("/MediaBox","/CropBox","/BleedBox","/TrimBox","/ArtBox");
+ * Constructor
+ * @param string $filename Source-Filename
+ * @param object $fpdi Object of type fpdi
+ function fpdi_pdf_parser($filename,&$fpdi) {
+ $this->fpdi =& $fpdi;
+ $this->filename = $filename;
+ parent::pdf_parser($filename);
+ // resolve Pages-Dictonary
+ $pages = $this->pdf_resolve_object($this->c, $this->root[1][1]['/Pages']);
+ // Read pages
+ $this->read_pages($this->c, $pages, $this->pages);
+ // count pages;
+ $this->page_count = count($this->pages);
+ * Overwrite parent::error()
+ * @param string $msg Error-Message
+ function error($msg) {
+ $this->fpdi->error($msg);
+ * Get pagecount from sourcefile
+ * @return int
+ function getPageCount() {
+ return $this->page_count;
+ * Set pageno
+ * @param int $pageno Pagenumber to use
+ function setPageno($pageno) {
+ $pageno = ((int) $pageno) - 1;
+ if ($pageno < 0 || $pageno >= $this->getPageCount()) {
+ $this->fpdi->error("Pagenumber is wrong!");
+ $this->pageno = $pageno;
+ * Get page-resources from current page
+ * @return array
+ function getPageResources() {
+ return $this->_getPageResources($this->pages[$this->pageno]);
+ * Get page-resources from /Page
+ * @param array $obj Array of pdf-data
+ function _getPageResources ($obj) { // $obj = /Page
+ $obj = $this->pdf_resolve_object($this->c, $obj);
+ // If the current object has a resources
+ // dictionary associated with it, we use
+ // it. Otherwise, we move back to its
+ // parent object.
+ if (isset ($obj[1][1]['/Resources'])) {
+ $res = $this->pdf_resolve_object($this->c, $obj[1][1]['/Resources']);
+ if ($res[0] == PDF_TYPE_OBJECT)
+ return $res[1];
+ return $res;
+ } else {
+ if (!isset ($obj[1][1]['/Parent'])) {
+ return false;
+ } else {
+ $res = $this->_getPageResources($obj[1][1]['/Parent']);
+ return $res[1];
+ return $res;
+ * Get content of current page
+ * If more /Contents is an array, the streams are concated
+ * @return string
+ function getContent() {
+ $buffer = "";
+ if (isset($this->pages[$this->pageno][1][1]['/Contents'])) {
+ $contents = $this->_getPageContent($this->pages[$this->pageno][1][1]['/Contents']);
+ foreach($contents AS $tmp_content) {
+ $buffer .= $this->_rebuildContentStream($tmp_content).' ';
+ return $buffer;
+ * Resolve all content-objects
+ * @param array $content_ref
+ * @return array
+ function _getPageContent($content_ref) {
+ $contents = array();
+ if ($content_ref[0] == PDF_TYPE_OBJREF) {
+ $content = $this->pdf_resolve_object($this->c, $content_ref);
+ if ($content[1][0] == PDF_TYPE_ARRAY) {
+ $contents = $this->_getPageContent($content[1]);
+ } else {
+ $contents[] = $content;
+ } else if ($content_ref[0] == PDF_TYPE_ARRAY) {
+ foreach ($content_ref[1] AS $tmp_content_ref) {
+ $contents = array_merge($contents,$this->_getPageContent($tmp_content_ref));
+ return $contents;
+ * Rebuild content-streams
+ * @return string
+ function _rebuildContentStream($obj) {
+ $filters = array();
+ if (isset($obj[1][1]['/Filter'])) {
+ $_filter = $obj[1][1]['/Filter'];
+ if ($_filter[0] == PDF_TYPE_TOKEN) {
+ $filters[] = $_filter;
+ } else if ($_filter[0] == PDF_TYPE_ARRAY) {
+ $filters = $_filter[1];
+ $stream = $obj[2][1];
+ foreach ($filters AS $_filter) {
+ switch ($_filter[1]) {
+ case "/FlateDecode":
+ if (function_exists('gzuncompress')) {
+ $stream = (strlen($stream) > 0) ? @gzuncompress($stream) : '';
+ } else {
+ $this->fpdi->error(sprintf("To handle %s filter, please compile php with zlib support.",$_filter[1]));
+ if ($stream === false) {
+ $this->fpdi->error("Error while decompressing stream.");
+ break;
+ case null:
+ $stream = $stream;
+ break;
+ default:
+ if (preg_match("/^\/[a-z85]*$/i", $_filter[1], $filterName) && @include_once('decoders'.$_filter[1].'.php')) {
+ $filterName = substr($_filter[1],1);
+ if (class_exists($filterName)) {
+ $decoder =& new $filterName($this->fpdi);
+ $stream = $decoder->decode(trim($stream));
+ } else {
+ $this->fpdi->error(sprintf("Unsupported Filter: %s",$_filter[1]));
+ } else {
+ return $stream;
+ * Get a Box from a page
+ * Arrayformat is same as used by fpdf_tpl
+ * @param array $page a /Page
+ * @param string $box_index Type of Box @see $availableBoxes
+ * @return array
+ function getPageBox($page, $box_index) {
+ $page = $this->pdf_resolve_object($this->c,$page);
+ $box = null;
+ if (isset($page[1][1][$box_index]))
+ $box =& $page[1][1][$box_index];
+ if (!is_null($box) && $box[0] == PDF_TYPE_OBJREF) {
+ $tmp_box = $this->pdf_resolve_object($this->c,$box);
+ $box = $tmp_box[1];
+ if (!is_null($box) && $box[0] == PDF_TYPE_ARRAY) {
+ $b =& $box[1];
+ return array("x" => $b[0][1]/$this->fpdi->k,
+ "y" => $b[1][1]/$this->fpdi->k,
+ "w" => abs($b[0][1]-$b[2][1])/$this->fpdi->k,
+ "h" => abs($b[1][1]-$b[3][1])/$this->fpdi->k);
+ } else if (!isset ($page[1][1]['/Parent'])) {
+ return false;
+ } else {
+ return $this->getPageBox($this->pdf_resolve_object($this->c, $page[1][1]['/Parent']), $box_index);
+ function getPageBoxes($pageno) {
+ return $this->_getPageBoxes($this->pages[$pageno-1]);
+ * Get all Boxes from /Page
+ * @param array a /Page
+ * @return array
+ function _getPageBoxes($page) {
+ $boxes = array();
+ foreach($this->availableBoxes AS $box) {
+ if ($_box = $this->getPageBox($page,$box)) {
+ $boxes[$box] = $_box;
+ return $boxes;
+ * Get the page rotation by pageno
+ * @param integer $pageno
+ * @return array
+ function getPageRotation($pageno) {
+ return $this->_getPageRotation($this->pages[$pageno-1]);
+ function _getPageRotation ($obj) { // $obj = /Page
+ if (isset ($obj[1][1]['/Rotate'])) {
+ $res = $this->pdf_resolve_object($this->c, $obj[1][1]['/Rotate']);
+ return $res[1];
+ return $res;
+ } else {
+ return false;
+ } else {
+ $res = $this->_getPageRotation($obj[1][1]['/Parent']);
+ return $res[1];
+ return $res;
+ * Read all /Page(es)
+ * @param object pdf_context
+ * @param array /Pages
+ * @param array the result-array
+ function read_pages (&$c, &$pages, &$result) {
+ // Get the kids dictionary
+ $kids = $this->pdf_resolve_object ($c, $pages[1][1]['/Kids']);
+ if (!is_array($kids))
+ $this->fpdi->Error("Cannot find /Kids in current /Page-Dictionary");
+ foreach ($kids[1] as $v) {
+ $pg = $this->pdf_resolve_object ($c, $v);
+ if ($pg[1][1]['/Type'][1] === '/Pages') {
+ // If one of the kids is an embedded
+ // /Pages array, resolve it as well.
+ $this->read_pages ($c, $pg, $result);
+ } else {
+ $result[] = $pg;
+ * Get PDF-Version
+ * And reset the PDF Version used in FPDI if needed
+ function getPDFVersion() {
+ parent::getPDFVersion();
+ $this->fpdi->PDFVersion = max($this->fpdi->PDFVersion, $this->pdfVersion);
Added: branches/print_dev/http/extensions/fpdf/license.txt
--- branches/print_dev/http/extensions/fpdf/license.txt (rev 0)
+++ branches/print_dev/http/extensions/fpdf/license.txt 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,6 @@
+Permission is hereby granted, free of charge, to any person obtaining a copy
+of this software to use, copy, modify, distribute, sublicense, and/or sell
+copies of the software, and to permit persons to whom the software is furnished
+to do so.
+THE SOFTWARE IS PROVIDED "AS IS", WITHOUT WARRANTY OF ANY KIND, EXPRESS OR IMPLIED.
Added: branches/print_dev/http/extensions/fpdf/pdf_context.php
--- branches/print_dev/http/extensions/fpdf/pdf_context.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/pdf_context.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,82 @@
+<?php
+class pdf_context {
+ var $file;
+ var $buffer;
+ var $offset;
+ var $length;
+ var $stack;
+ // Constructor
+ function pdf_context($f) {
+ $this->file = $f;
+ $this->reset();
+ // Optionally move the file
+ // pointer to a new location
+ // and reset the buffered data
+ function reset($pos = null, $l = 100) {
+ if (!is_null ($pos)) {
+ fseek ($this->file, $pos);
+ $this->buffer = $l > 0 ? fread($this->file, $l) : '';
+ $this->length = strlen($this->buffer);
+ if ($this->length < $l)
+ $this->increase_length($l - $this->length);
+ $this->offset = 0;
+ $this->stack = array();
+ // Make sure that there is at least one
+ // character beyond the current offset in
+ // the buffer to prevent the tokenizer
+ // from attempting to access data that does
+ // not exist
+ function ensure_content() {
+ if ($this->offset >= $this->length - 1) {
+ return $this->increase_length();
+ } else {
+ return true;
+ // Forcefully read more data into the buffer
+ function increase_length($l=100) {
+ if (feof($this->file)) {
+ return false;
+ } else {
+ $totalLength = $this->length + $l;
+ do {
+ $this->buffer .= fread($this->file, $totalLength-$this->length);
+ } while ((($this->length = strlen($this->buffer)) != $totalLength) && !feof($this->file));
+ return true;
Added: branches/print_dev/http/extensions/fpdf/pdf_parser.php
--- branches/print_dev/http/extensions/fpdf/pdf_parser.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/pdf_parser.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,690 @@
+<?php
+if (!defined ('PDF_TYPE_NULL'))
+ define ('PDF_TYPE_NULL', 0);
+if (!defined ('PDF_TYPE_NUMERIC'))
+ define ('PDF_TYPE_NUMERIC', 1);
+if (!defined ('PDF_TYPE_TOKEN'))
+ define ('PDF_TYPE_TOKEN', 2);
+if (!defined ('PDF_TYPE_HEX'))
+ define ('PDF_TYPE_HEX', 3);
+if (!defined ('PDF_TYPE_STRING'))
+ define ('PDF_TYPE_STRING', 4);
+if (!defined ('PDF_TYPE_DICTIONARY'))
+ define ('PDF_TYPE_DICTIONARY', 5);
+if (!defined ('PDF_TYPE_ARRAY'))
+ define ('PDF_TYPE_ARRAY', 6);
+if (!defined ('PDF_TYPE_OBJDEC'))
+ define ('PDF_TYPE_OBJDEC', 7);
+if (!defined ('PDF_TYPE_OBJREF'))
+ define ('PDF_TYPE_OBJREF', 8);
+if (!defined ('PDF_TYPE_OBJECT'))
+ define ('PDF_TYPE_OBJECT', 9);
+if (!defined ('PDF_TYPE_STREAM'))
+ define ('PDF_TYPE_STREAM', 10);
+if (!defined ('PDF_TYPE_BOOLEAN'))
+ define ('PDF_TYPE_BOOLEAN', 11);
+if (!defined ('PDF_TYPE_REAL'))
+ define ('PDF_TYPE_REAL', 12);
+require_once("pdf_context.php");
+require_once("wrapper_functions.php");
+class pdf_parser {
+ * Filename
+ * @var string
+ var $filename;
+ * File resource
+ * @var resource
+ var $f;
+ * PDF Context
+ * @var object pdf_context-Instance
+ var $c;
+ * xref-Data
+ * @var array
+ var $xref;
+ * root-Object
+ * @var array
+ var $root;
+ * PDF version of the loaded document
+ * @var string
+ var $pdfVersion;
+ * Constructor
+ function pdf_parser($filename) {
+ $this->f = @fopen($this->filename, "rb");
+ if (!$this->f)
+ $this->error(sprintf("Cannot open %s !", $filename));
+ $this->getPDFVersion();
+ $this->c =& new pdf_context($this->f);
+ // Read xref-Data
+ $this->pdf_read_xref($this->xref, $this->pdf_find_xref());
+ // Check for Encryption
+ $this->getEncryption();
+ // Read root
+ $this->pdf_read_root();
+ * Close the opened file
+ function closeFile() {
+ if (isset($this->f)) {
+ fclose($this->f);
+ unset($this->f);
+ * Print Error and die
+ die("<b>PDF-Parser Error:</b> ".$msg);
+ * Check Trailer for Encryption
+ function getEncryption() {
+ if (isset($this->xref['trailer'][1]['/Encrypt'])) {
+ $this->error("File is encrypted!");
+ * Find/Return /Root
+ * @return array
+ function pdf_find_root() {
+ if ($this->xref['trailer'][1]['/Root'][0] != PDF_TYPE_OBJREF) {
+ $this->error("Wrong Type of Root-Element! Must be an indirect reference");
+ return $this->xref['trailer'][1]['/Root'];
+ * Read the /Root
+ function pdf_read_root() {
+ // read root
+ $this->root = $this->pdf_resolve_object($this->c, $this->pdf_find_root());
+ * Get PDF-Version
+ fseek($this->f, 0);
+ preg_match("/\d\.\d/",fread($this->f,16),$m);
+ if (isset($m[0]))
+ $this->pdfVersion = $m[0];
+ return $this->pdfVersion;
+ * Find the xref-Table
+ function pdf_find_xref() {
+ $toRead = 1500;
+ $stat = fseek ($this->f, -$toRead, SEEK_END);
+ if ($stat === -1) {
+ fseek ($this->f, 0);
+ $data = fread($this->f, $toRead);
+ $pos = strlen($data) - strpos(strrev($data), strrev('startxref'));
+ $data = substr($data, $pos);
+ if (!preg_match('/\s*(\d+).*$/s', $data, $matches)) {
+ $this->error("Unable to find pointer to xref table");
+ return (int) $matches[1];
+ * Read xref-table
+ * @param array $result Array of xref-table
+ * @param integer $offset of xref-table
+ function pdf_read_xref(&$result, $offset) {
+ fseek($this->f, $o_pos = $offset-20); // set some bytes backwards to fetch errorious docs
+ $data = fread($this->f, 100);
+ $xrefPos = strpos($data, 'xref');
+ if ($xrefPos === false) {
+ $this->error('Unable to find xref table.');
+ if (!isset($result['xref_location'])) {
+ $result['xref_location'] = $o_pos+$xrefPos;
+ $result['max_object'] = 0;
+ $cylces = -1;
+ $bytesPerCycle = 100;
+ fseek($this->f, $o_pos = $o_pos+$xrefPos+4); // set the handle directly after the "xref"-keyword
+ $data = fread($this->f, $bytesPerCycle);
+ while (($trailerPos = strpos($data, 'trailer', max($bytesPerCycle*$cylces++, 0))) === false && !feof($this->f)) {
+ $data .= fread($this->f, $bytesPerCycle);
+ if ($trailerPos === false) {
+ $this->error('Trailer keyword not found after xref table');
+ $data = substr($data, 0, $trailerPos);
+ // get Line-Ending
+ preg_match_all("/(\r\n|\n|\r)/", substr($data, 0, 100), $m); // check the first 100 bytes for linebreaks
+ $differentLineEndings = count(array_unique($m[0]));
+ if ($differentLineEndings > 1) {
+ $lines = preg_split("/(\r\n|\n|\r)/", $data, -1, PREG_SPLIT_NO_EMPTY);
+ } else {
+ $lines = explode($m[0][1], $data);
+ $data = $differentLineEndings = $m = null;
+ unset($data, $differentLineEndings, $m);
+ $linesCount = count($lines);
+ $start = 1;
+ for ($i = 0; $i < $linesCount; $i++) {
+ $line = trim($lines[$i]);
+ if ($line) {
+ $pieces = explode(" ", $line);
+ $c = count($pieces);
+ switch($c) {
+ case 2:
+ $start = (int)$pieces[0];
+ $end = $start+(int)$pieces[1];
+ if ($end > $result['max_object'])
+ $result['max_object'] = $end;
+ break;
+ case 3:
+ if (!isset($result['xref'][$start]))
+ $result['xref'][$start] = array();
+ if (!array_key_exists($gen = (int) $pieces[1], $result['xref'][$start])) {
+ $result['xref'][$start][$gen] = $pieces[2] == 'n' ? (int) $pieces[0] : null;
+ $start++;
+ break;
+ default:
+ $this->error('Unexpected data in xref table');
+ $lines = $pieces = $line = $start = $end = $gen = null;
+ unset($lines, $pieces, $line, $start, $end, $gen);
+ fseek($this->f, $o_pos+$trailerPos+7);
+ $c =& new pdf_context($this->f);
+ $trailer = $this->pdf_read_value($c);
+ $c = null;
+ unset($c);
+ if (!isset($result['trailer'])) {
+ $result['trailer'] = $trailer;
+ if (isset($trailer[1]['/Prev'])) {
+ $this->pdf_read_xref($result, $trailer[1]['/Prev'][1]);
+ $trailer = null;
+ unset($trailer);
+ return true;
+ * Reads an Value
+ * @param object $c pdf_context
+ * @param string $token a Token
+ * @return mixed
+ function pdf_read_value(&$c, $token = null) {
+ if (is_null($token)) {
+ $token = $this->pdf_read_token($c);
+ if ($token === false) {
+ return false;
+ switch ($token) {
+ case '<':
+ // This is a hex string.
+ // Read the value, then the terminator
+ $pos = $c->offset;
+ while(1) {
+ $match = strpos ($c->buffer, '>', $pos);
+ // If you can't find it, try
+ // reading more data from the stream
+ if ($match === false) {
+ if (!$c->increase_length()) {
+ return false;
+ } else {
+ continue;
+ $result = substr ($c->buffer, $c->offset, $match - $c->offset);
+ $c->offset = $match + 1;
+ return array (PDF_TYPE_HEX, $result);
+ break;
+ case '<<':
+ // This is a dictionary.
+ $result = array();
+ // Recurse into this function until we reach
+ // the end of the dictionary.
+ while (($key = $this->pdf_read_token($c)) !== '>>') {
+ if ($key === false) {
+ return false;
+ if (($value = $this->pdf_read_value($c)) === false) {
+ return false;
+ $result[$key] = $value;
+ return array (PDF_TYPE_DICTIONARY, $result);
+ case '[':
+ // This is an array.
+ // the end of the array.
+ while (($token = $this->pdf_read_token($c)) !== ']') {
+ return false;
+ if (($value = $this->pdf_read_value($c, $token)) === false) {
+ return false;
+ $result[] = $value;
+ return array (PDF_TYPE_ARRAY, $result);
+ case '(' :
+ // This is a string
+ $openBrackets = 1;
+ do {
+ for (; $openBrackets != 0 && $pos < $c->length; $pos++) {
+ switch (ord($c->buffer[$pos])) {
+ case 0x28: // '('
+ $openBrackets++;
+ break;
+ case 0x29: // ')'
+ $openBrackets--;
+ break;
+ case 0x5C: // backslash
+ $pos++;
+ } while($openBrackets != 0 && $c->increase_length());
+ $result = substr($c->buffer, $c->offset, $pos - $c->offset - 1);
+ $c->offset = $pos;
+ return array (PDF_TYPE_STRING, $result);
+ case "stream":
+ $o_pos = ftell($c->file)-strlen($c->buffer);
+ $o_offset = $c->offset;
+ $c->reset($startpos = $o_pos + $o_offset);
+ $e = 0; // ensure line breaks in front of the stream
+ if ($c->buffer[0] == chr(10) || $c->buffer[0] == chr(13))
+ $e++;
+ if ($c->buffer[1] == chr(10) && $c->buffer[0] != chr(10))
+ $e++;
+ if ($this->actual_obj[1][1]['/Length'][0] == PDF_TYPE_OBJREF) {
+ $tmp_c =& new pdf_context($this->f);
+ $tmp_length = $this->pdf_resolve_object($tmp_c,$this->actual_obj[1][1]['/Length']);
+ $length = $tmp_length[1][1];
+ } else {
+ $length = $this->actual_obj[1][1]['/Length'][1];
+ if ($length > 0) {
+ $c->reset($startpos+$e,$length);
+ $v = $c->buffer;
+ } else {
+ $v = '';
+ $c->reset($startpos+$e+$length+9); // 9 = strlen("endstream")
+ return array(PDF_TYPE_STREAM, $v);
+ case '%':
+ // this is a comment - just jump over it
+ while(1) {
+ // PHP 4.3.3 required
+ #$match = preg_match("/(\r\n|\r|\n)/", $c->buffer, $m, PREG_OFFSET_CAPTURE, $pos);
+ // alternative
+ $match = preg_match("/(\r\n|\r|\n)/", substr($c->buffer, $pos), $m);
+ return false;
+ } else {
+ continue;
+ #$c->offset = $m[0][1]+strlen($m[0][0]);
+ // alternative
+ $c->offset = strpos($c->buffer, $m[0], $pos)+strlen($m[0]);
+ return $this->pdf_read_value($c);
+ default :
+ if (is_numeric ($token)) {
+ // A numeric token. Make sure that
+ // it is not part of something else.
+ if (($tok2 = $this->pdf_read_token ($c)) !== false) {
+ if (is_numeric ($tok2)) {
+ // Two numeric tokens in a row.
+ // In this case, we're probably in
+ // front of either an object reference
+ // or an object specification.
+ // Determine the case and return the data
+ if (($tok3 = $this->pdf_read_token ($c)) !== false) {
+ switch ($tok3) {
+ case 'obj' :
+ return array (PDF_TYPE_OBJDEC, (int) $token, (int) $tok2);
+ case 'R' :
+ return array (PDF_TYPE_OBJREF, (int) $token, (int) $tok2);
+ // If we get to this point, that numeric value up
+ // there was just a numeric value. Push the extra
+ // tokens back into the stack and return the value.
+ array_push ($c->stack, $tok3);
+ array_push ($c->stack, $tok2);
+ if ($token === (string)((int)$token))
+ return array (PDF_TYPE_NUMERIC, (int)$token);
+ else
+ return array (PDF_TYPE_REAL, (float)$token);
+ } else if ($token == 'true' || $token == 'false') {
+ return array (PDF_TYPE_BOOLEAN, $token == 'true');
+ } else {
+ // Just a token. Return it.
+ return array (PDF_TYPE_TOKEN, $token);
+ * Resolve an object
+ * @param array $obj_spec The object-data
+ * @param boolean $encapsulate Must set to true, cause the parsing and fpdi use this method only without this para
+ function pdf_resolve_object(&$c, $obj_spec, $encapsulate = true) {
+ // Exit if we get invalid data
+ if (!is_array($obj_spec)) {
+ return false;
+ if ($obj_spec[0] == PDF_TYPE_OBJREF) {
+ // This is a reference, resolve it
+ if (isset($this->xref['xref'][$obj_spec[1]][$obj_spec[2]])) {
+ // Save current file position
+ // This is needed if you want to resolve
+ // references while you're reading another object
+ // (e.g.: if you need to determine the length
+ // of a stream)
+ $old_pos = ftell($c->file);
+ // Reposition the file pointer and
+ // load the object header.
+ $c->reset($this->xref['xref'][$obj_spec[1]][$obj_spec[2]]);
+ $header = $this->pdf_read_value($c,null,true);
+ if ($header[0] != PDF_TYPE_OBJDEC || $header[1] != $obj_spec[1] || $header[2] != $obj_spec[2]) {
+ $this->error("Unable to find object ({$obj_spec[1]}, {$obj_spec[2]}) at expected location");
+ // If we're being asked to store all the information
+ // about the object, we add the object ID and generation
+ // number for later use
+ $this->actual_obj =& $result;
+ if ($encapsulate) {
+ $result = array (
+ PDF_TYPE_OBJECT,
+ 'obj' => $obj_spec[1],
+ 'gen' => $obj_spec[2]
+ } else {
+ // Now simply read the object data until
+ // we encounter an end-of-object marker
+ while(1) {
+ $value = $this->pdf_read_value($c);
+ if ($value === false || count($result) > 4) {
+ // in this case the parser coudn't find an endobj so we break here
+ break;
+ if ($value[0] == PDF_TYPE_TOKEN && $value[1] === 'endobj') {
+ break;
+ $c->reset($old_pos);
+ if (isset($result[2][0]) && $result[2][0] == PDF_TYPE_STREAM) {
+ $result[0] = PDF_TYPE_STREAM;
+ return $result;
+ } else {
+ return $obj_spec;
+ * Reads a token from the file
+ * @return mixed
+ function pdf_read_token(&$c)
+ // If there is a token available
+ // on the stack, pop it out and
+ // return it.
+ if (count($c->stack)) {
+ return array_pop($c->stack);
+ // Strip away any whitespace
+ do {
+ if (!$c->ensure_content()) {
+ return false;
+ $c->offset += _strspn($c->buffer, " \n\r\t", $c->offset);
+ } while ($c->offset >= $c->length - 1);
+ // Get the first character in the stream
+ $char = $c->buffer[$c->offset++];
+ switch ($char) {
+ case '[' :
+ case ']' :
+ case '(' :
+ case ')' :
+ // This is either an array or literal string
+ // delimiter, Return it
+ return $char;
+ case '<' :
+ case '>' :
+ // This could either be a hex string or
+ // dictionary delimiter. Determine the
+ // appropriate case and return the token
+ if ($c->buffer[$c->offset] == $char) {
+ return false;
+ $c->offset++;
+ return $char . $char;
+ } else {
+ return $char;
+ default :
+ // This is "another" type of token (probably
+ // a dictionary entry or a numeric value)
+ // Find the end and return it.
+ return false;
+ while(1) {
+ // Determine the length of the token
+ $pos = _strcspn($c->buffer, " []<>()\r\n\t/", $c->offset);
+ if ($c->offset + $pos <= $c->length - 1) {
+ break;
+ } else {
+ // If the script reaches this point,
+ // the token may span beyond the end
+ // of the current buffer. Therefore,
+ // we increase the size of the buffer
+ // and try again--just to be safe.
+ $c->increase_length();
+ $result = substr($c->buffer, $c->offset - 1, $pos + 1);
+ $c->offset += $pos;
+ return $result;
Added: branches/print_dev/http/extensions/fpdf/wrapper_functions.php
--- branches/print_dev/http/extensions/fpdf/wrapper_functions.php (rev 0)
+++ branches/print_dev/http/extensions/fpdf/wrapper_functions.php 2008-11-05 14:02:01 UTC (rev 3182)
@@ -0,0 +1,70 @@
+<?php
+if (!defined("PHP_VER_LOWER43"))
+ define("PHP_VER_LOWER43", version_compare(PHP_VERSION, "4.3", "<"));
+ * ensure that strspn works correct if php-version < 4.3
+function _strspn($str1, $str2, $start=null, $length=null) {
+ $numargs = func_num_args();
+ if (PHP_VER_LOWER43 == 1) {
+ if (isset($length)) {
+ $str1 = substr($str1, $start, $length);
+ } else {
+ $str1 = substr($str1, $start);
+ if ($numargs == 2 || PHP_VER_LOWER43 == 1) {
+ return strspn($str1, $str2);
+ } else if ($numargs == 3) {
+ return strspn($str1, $str2, $start);
+ } else {
+ return strspn($str1, $str2, $start, $length);
+ * ensure that strcspn works correct if php-version < 4.3
+function _strcspn($str1, $str2, $start=null, $length=null) {
+ } else {
+ return strcspn($str1, $str2);
+ return strcspn($str1, $str2, $start);
+ } else {
+ return strcspn($str1, $str2, $start, $length);
More information about the Mapbender_commits
