[Mapbender-commits] r3191 - trunk/mapbender/http/php
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Thu Nov 6 10:27:22 EST 2008
Author: christoph
Date: 2008-11-06 10:27:22 -0500 (Thu, 06 Nov 2008)
New Revision: 3191
   trunk/mapbender/http/php/mod_map1.php
http://trac.osgeo.org/mapbender/ticket/319
Modified: trunk/mapbender/http/php/mod_map1.php
--- trunk/mapbender/http/php/mod_map1.php	2008-11-06 15:19:35 UTC (rev 3190)
+++ trunk/mapbender/http/php/mod_map1.php	2008-11-06 15:27:22 UTC (rev 3191)
@@ -68,21 +68,24 @@
 	parent.eventInitMap.register(function init_mod_map1(){
 		parent.mb_registerMapObj('mapframe1', 'maps', null,mod_map1_width, mod_map1_height);
-		parent.$(document, window.frames['mapframe1']).mousewheel(function (event, delta) {
-			if (sum_delta == 0) {
-				mapTimeout = setTimeout(function () {
-						lastScrollPositionX=event.pageX;
-						lastScrollPositionY=event.pageY;
-						mousewheelZoom();
-					100);
-			sum_delta = sum_delta + (delta);
-			var currentTime = new Date();
-			lastTimestamp = currentTime.getTime();
+		if (!parent.$.browser.msie) {
-			return false;
+			parent.$(document, window.frames['mapframe1']).mousewheel(function (event, delta) {
+				if (sum_delta == 0) {
+					mapTimeout = setTimeout(function () {
+							lastScrollPositionX=event.pageX;
+							lastScrollPositionY=event.pageY;
+							mousewheelZoom();
+						100);
+				sum_delta = sum_delta + (delta);
+				var currentTime = new Date();
+				lastTimestamp = currentTime.getTime();
+				return false;
@@ -95,10 +98,10 @@
 		var pos = parent.makeClickPos2RealWorldPos("mapframe1", lastScrollPositionX, lastScrollPositionY);
 		if (sum_delta > 0) {
-			parent.zoom("mapframe1", true, Math.pow(parent.mapbender.zoomMousewheel, sum_delta), pos[0],pos[1]);
+			parent.zoom("mapframe1", true, Math.pow(parent.Mapbender.zoomMousewheel, sum_delta), pos[0],pos[1]);
 		else {
-			parent.zoom("mapframe1", false, Math.pow(parent.mapbender.zoomMousewheel, -sum_delta), pos[0], pos[1]);
+			parent.zoom("mapframe1", false, Math.pow(parent.Mapbender.zoomMousewheel, -sum_delta), pos[0], pos[1]);
 		var newPosX =  parent.parent.mb_mapObj[ind].width - lastScrollPositionX;
More information about the Mapbender_commits mailing list
