[Mapbender-commits] r3210 - branches/beck_dev/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Mon Nov 10 08:43:49 EST 2008
Author: beck
Date: 2008-11-10 08:43:49 -0500 (Mon, 10 Nov 2008)
New Revision: 3210
Added:
   branches/beck_dev/http/javascripts/tooltip.php
   branches/beck_dev/http/javascripts/tooltip24.php
   branches/beck_dev/http/javascripts/popup.js
Modified: branches/beck_dev/http/javascripts/popup.js
--- branches/beck_dev/http/javascripts/popup.js	2008-11-10 13:43:12 UTC (rev 3209)
+++ branches/beck_dev/http/javascripts/popup.js	2008-11-10 13:43:49 UTC (rev 3210)
@@ -4,7 +4,7 @@
 * License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
 //http://www.mapbender.org/index.php/popup
-var popup_count = 1;
+var popup_count = 0;
 var popup_top = 150;
@@ -37,7 +37,6 @@
  *  resizeable: allow user to change the size default:true
  *  dragable: allow user to move the window default:true
  *  balloon: balloon popup from top, left (disables resizeable and dragable)
- *  modal: create modal popup default:false
  * @param {String} html the "body" of the popup, can also be "url:http://foo.de" to display a website
  * @param {Number} width width of the popup
@@ -55,8 +54,8 @@
 			break;
-	this.id="popup"+String(++popup_top);
+	this.id="popup"+String(create_pos);
 	//Set defaults
 	defaults = {
 		left:25*create_pos,
@@ -66,13 +65,13 @@
 		frameName:this.id,
 	if(typeof(title)!='object'){
 		this.options = defaults;
 		//Set vars
 		if(posx)this.options.left=posx;
-		if(posy)this.options.top=posy;
+		if(posy)this.options.top=posx;
 		if(width)this.options.width=width;
 		if(height)this.options.height=height;
 		if(title)this.options.title=title;
@@ -88,8 +87,6 @@
 	else
 		this.options=$.extend(defaults, title);
-	this.id = this.options.id;
 	popup_count++;
 	//create dom popup
@@ -116,7 +113,6 @@
 mb_popup.prototype.hide = function(){
 	$("#"+this.id).hide();
 	$("#balloon_"+this.id).hide();
-	$("#modal_mouse_catcher").remove();
@@ -125,7 +121,6 @@
 mb_popup.prototype.destroy = function(){
 	$("#"+this.id).remove();
 	$("#balloon_"+this.id).remove();
@@ -195,43 +190,10 @@
 mb_popup.prototype.setHtml = function(htmll){
 	this.options.url=null;
 	this.options.html=htmll;
-	$("#"+this.id+" .Content").html('<div class="scrollDiv">'+htmll+'</div>');
+	$("#"+this.id+" .jqmnContent").html(htmll);
- * behaves like document.open(); (clear popup)
-mb_popup.prototype.open = function(){
-	oDoc = this.getDocument();
-	if(oDoc!=null){
-		return oDoc.open();
-	this.setHtml("");
- * behaves like document.write(); (appends content to the popup)
- * @param {String} text or html to write into the document
-mb_popup.prototype.write = function(str){
-	if(oDoc!=null){
-		return oDoc.write(str);
-	this.setHtml(this.options.html+str);
- * behaves like document.close(); (finish loading state if popup is an iframe)
-mb_popup.prototype.close = function(){
-	if(oDoc!=null){
-		return oDoc.close();
  * sets the url of the content
  * @param {String} url new url of the popup
@@ -239,24 +201,14 @@
 mb_popup.prototype.setUrl = function(url){
 	this.options.url=url;
 	this.options.html=null;
-	if(oDoc){
-		oDoc.location.href = url;
+	try{
+		eval("window.frames."+this.options.frameName+".location = \""+url+"\"");
+	}catch(e){
+		$("#"+this.id+" .jqmnContent").html('<iframe src="'+url+'"></iframe>');
-	else{
-		$("#"+this.id+" .Content").html('<iframe src="'+url+'"></iframe>');
- * reposition
-mb_popup.prototype.reposition =function(){
-//TODO
  * gets the visible state of the popup window
  * @return visible state of the popup
  * @type Boolean
@@ -266,34 +218,6 @@
- * (re) set Some Options of the popup Window and rerender it
- * @param options object that contains the new options
-mb_popup.prototype.set = function(options){
-	this.destroy();
-	this.options=$.extend(this.options, options);
-	this.show();
- * get the DOM document of the client iframe
- * @return DOM document or null if the popup doesn't contain an iframe
-mb_popup.prototype.getDocument = function(){
-	iFrame = $("#"+this.id+" iframe")[0];
-	try{
-		//try to load contentWindow first since not every browser
-		//supports contentDocument (or gives the window instead)
-		oDoc = iFrame.contentWindow || iFrame.contentDocument;
-		if (oDoc.document) {
-	        oDoc = oDoc.document;
-    	return oDoc;
-	catch(e){return null;}
  * get Scroll position
 function getScrollPos() {
@@ -315,8 +239,6 @@
 	return scrOf;
 (function($){
 	$.fn.mbPopup = function(options){
 		//default settings
@@ -329,72 +251,82 @@
 			minTop:"document",minLeft:"document",
 			maxRight:false,maxBottom:false,
 			dragable:true,resizeable:true,balloon:false,
-			style:null,destroy:true,modal:false,
+			style:null,destroy:true,
 			closeCallback:null
 		//override defaults
 		settings=$.extend(defaults,options)
-		this.settings = settings;
 		//add Styles
-		this.addClass("mbPopup");
+		this.addClass("jqmNotice");
-		//append additions styles
-		if(settings.style)
-			this.css(settings.style);
 		//automated settings for balloon popup
 		if(settings.balloon){
-			$("body").append("<div id='balloon_"+settings.id+"' class='balloonBL' style='visibility:hidden;'>");
+			var dim = getScrollPos();
+			bubble_height = 80;
+			bubble_width = 100;
 			settings.resizeable = false;
 			settings.dragable = false;
+			settings.hotSpotY=settings.top;
+			settings.hotSpotX=settings.left;
+			position = 0;
+			console ={};
+			console.log = function(){};
+			if(settings.hotSpotY-settings.height-bubble_height-parseInt(this.css("border-top-width"))<dim.Y){
+				//bubble on top
+				settings.top = settings.hotSpotY+bubble_height-parseInt(this.css("border-top-width"));
+			else{
+				//bubble on bottom
+				settings.top = settings.hotSpotY-settings.height-bubble_height+(top.ie?parseInt(this.css("border-bottom-width")):-parseInt(this.css("border-top-width")));
+				position+=2;
+			if(settings.hotSpotX+settings.width+parseInt(this.css("border-left-width"))+parseInt(this.css("border-right-width"))>(dim.X+dim.wW)){
+				//bubble on right
+				settings.left = settings.hotSpotX-parseInt(this.css("border-left-width"))-parseInt(this.css("border-right-width"))-settings.width;
+				position++;
+			else{
+				//bubble on left
+				settings.left = settings.hotSpotX-parseInt(this.css("border-left-width"));
-		//calculate positioning (mainly needed for balloon style)
-		pos = $.mbPopupFn.calcPositioning(settings, this);
-		//set balloon arm position
-		if(settings.balloon){
-			$("#balloon_"+settings.id).attr("class", "balloon"+(pos.position>=2?"B":"T")+(pos.position%2?"R":"L"))
-				.css({"z-index":(popup_top),visibility:"visible",left:String(pos.bX)+"px",top:String(pos.bY)+"px"});
-			settings.left = pos.pX;
-			settings.top = pos.pY;
+			$("body").append("<div id='balloon_"+settings.id+"' class='balloon"+(position>=2?"B":"T")+(position%2?"R":"L")+"' style='z-index:"+(popup_top++)+";left:"+(settings.hotSpotX-(position%2?bubble_width:0))+"px;top:"+(settings.hotSpotY-(position>=2?bubble_height:0))+"px'>");
-		//fix IE width and height by adding the padding values
-		if($.browser.msie){
-			settings.width = pos.pW;
-			settings.height = pos.pH;
-		//Set dimensions
-		this.css({top:String(settings.top)+"px",
-			left:String(settings.left)+"px",
-			width:String(settings.width)+"px",
-			height:String(settings.height)+"px",
+		this.css({top:settings.top+"px",
+			left:settings.left+"px",
+			width:settings.width+"px",
+			height:settings.height+"px",
 			opacity:settings.opacity
+		if(settings.style)
+			this.css(settings.style);
 		//Insert content
 		if(settings.url)
 			html = ('<iframe name="'+settings.frameName+'" src="'+settings.url+'"></iframe>');
 		else
 			html = ('<div class="scrollDiv">'+settings.html+'</div>');
-		this.html('<div class="Title Drag"><h1>'+settings.title+'</h1></div><div class="Content">'+html+'</div><img src="../img/close_icon.png" class="Close" alt="close" />'+(settings.resizeable?'<div class="Resize" />':''));
+		this.html('<div class="jqmnTitle jqDrag"><h1>'+settings.title+'</h1></div><div class="jqmnContent">'+html+'</div><img src="../img/close_icon.png" class="jqmClose" alt="close" />'+(settings.resizeable?'<div class="jqResize" />':''));
 		var data = {El:this,fY:settings.minTop,fX:settings.minLeft,tX:settings.maxRight,tY:settings.maxBottom,
 			fW:settings.minWidth,tW:settings.maxWidth,fH:settings.minHeight,tH:settings.maxHeight,
 			destroy:settings.destroy,opacity:settings.opacity,moveOpacity:settings.moveOpacity,close:settings.closeCallback}
 		//Make window Dragable
 		if(settings.dragable)
-			$(".Drag", this).bind('mousedown',data,function(event){
+			$(".jqDrag", this).bind('mousedown',data,function(event){
 				//set to top
 				event.data.El.css("z-index",popup_top++);
 				event.data.El.css('opacity',event.data.moveOpacity)
 				//create helper div to steal mouse events
-				$("body").append("<div style=\"position:absolute;top:0px;left:0px;width:"+$().width()+"px;height:"+$().height()+"px;z-index:"+(popup_top+2)+($.browser.msie?";background:url(../img/transparent.gif)":"")+"\" id=\"mouse_catcher\"></div>");
+				$("body").append("<div style=\"position:absolute;top:0px;left:0px;width:"+$().width()+"px;height:"+$().height()+"px;z-index:"+(popup_top+2)+(top.ie?";background:url(../img/transparent.gif)":"")+"\" id=\"mouse_catcher\"></div>");
 				$("iframe", event.data.El).hide();
 				//Parse setiings of min and max position
@@ -406,12 +338,12 @@
 		//Make Window resizable
 		if(settings.resizeable)
-			$(".Resize", this).bind('mousedown',data,function(event){
+			$(".jqResize", this).bind('mousedown',data,function(event){
 				//set to top
-				event.data.El.css('opacity',event.data.moveOpacity)
+				event.data.El.css('opacity',0.8)
@@ -422,10 +354,9 @@
 		//closeButton
-		this.closePopup = function(event){
+		$(".jqmClose", this).bind('click',data, function(event){
 			if(event.data.close)
 				event.data.close();
 			if(event.data.destroy){
 				event.data.El.slideUp('slow', function(){$(this).remove();});
 				$("#balloon_"+event.data.El.attr("id")).remove();
@@ -434,15 +365,8 @@
 				event.data.El.slideUp('slow');
 				$("#balloon_"+event.data.El.attr("id")).fadeOut();
-		$(".Close", this).bind('click',data, this.closePopup);
-		//create div to make window modal
-		if(settings.modal){
-			$("body").append("<div style=\"position:absolute;top:0px;left:0px;width:"+$().width()+"px;height:"+$().height()+"px;z-index:"+(popup_top-1)+($.browser.msie?";background:url(../img/transparent.gif)":"")+"\" id=\"modal_mouse_catcher\"></div>");
-			$("#modal_mouse_catcher").bind('click',data, this.closePopup);
 		//raise on click
 		this.click(function(){this.style.zIndex=popup_top++;$("#balloon_"+this.id).css("z-index", popup_top++);});
 		$("#balloon_"+settings.id).click(function(){$("#"+this.id.substr(8)).css("z-index", popup_top++);this.style.zIndex=popup_top++;});
@@ -518,42 +442,6 @@
 			if(ret.tX)ret.tX-=bd.X;
 			if(ret.tY)ret.tY-=bd.Y;
 			return ret;
-		calcPositioning:function(settings, el){
-			var dim = getScrollPos();
-			pos = {};
-			pos.pH = settings.height + (parseInt(el.css("padding-top"))+parseInt(el.css("padding-bottom")));
-			pos.pW = settings.width + (parseInt(el.css("padding-left"))+parseInt(el.css("padding-right")));
-				pos.bH = $("#balloon_"+settings.id).height();
-				pos.bW = $("#balloon_"+settings.id).width();
-				pos.position = 0;
-				if(settings.top-pos.pH-pos.bH-parseInt(el.css("border-top-width"))<dim.Y){
-					//bubble on top
-					pos.pY = settings.top+pos.bH-parseInt(el.css("border-top-width"));
-				else{
-					//bubble on bottom
-					pos.pY = settings.top-pos.pH-pos.bH+($.browser.msie?parseInt(el.css("border-bottom-width")):-parseInt(el.css("border-top-width")));
-					pos.position+=2;
-				if(settings.left+pos.pW+parseInt(el.css("border-left-width"))+parseInt(el.css("border-right-width"))>(dim.X+dim.wW)){
-					//bubble on right
-					pos.pX = settings.left-parseInt(el.css("border-left-width"))-parseInt(el.css("border-right-width"))-pos.pW;
-					pos.position++;
-				else{
-					//bubble on left
-					pos.pX = settings.left-parseInt(el.css("border-left-width"));
-				pos.bX=(settings.left-(pos.position%2?pos.bW:0));
-				pos.bY=(settings.top-(pos.position>=2?pos.bH:0));
-			return pos;
Added: branches/beck_dev/http/javascripts/tooltip.php
--- branches/beck_dev/http/javascripts/tooltip.php	                        (rev 0)
+++ branches/beck_dev/http/javascripts/tooltip.php	2008-11-10 13:43:49 UTC (rev 3210)
@@ -0,0 +1,272 @@
+<?php
+# $Id: mod_toggleModule.php 2238 2008-03-13 14:24:56Z christoph $
+# http://www.mapbender.org/index.php/mod_toggleModule.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../php/mb_validatePermission.php");
+$wfs_conf_filename = "wfs_default.conf";
+include '../include/dyn_php.php';
+$fname = dirname(__FILE__) . "/../../conf/" . $wfs_conf_filename;
+if (file_exists($fname)) {
+	include($fname);
+else {
+	$e = new mb_exception("tooltip.php: Configuration file " . $wfs_conf_filename . " not found.");
+echo "var tooltipTarget ='".$e_target[0]."';";
+include '../include/dyn_js.php';
+var mb_wfs_tolerance = 20;
+var tooltipTime = 500;
+var mouseMoves=0;
+var tooltipWin=null;
+var point;
+var numberOfFinishedAjaxCalls = 0;
+buttonWfs_toDigitize_on ="0";
+function mod_tooltipInit(){
+	$(window.frames["mapframe1"].document).mousemove(function(event){
+		mod_tooltip_run();
+		mb_getMousePos(event,"mapframe1");
+	}).mouseout(function(){mouseMoves=0;});
+mb_registerInitFunctions("mod_tooltipInit();");
+function mod_tooltip_run(){
+	if(tooltipWin&&tooltipWin.isVisible())
+		tooltipWin.destroy();
+	mouseMoves++;
+	setTimeout("if(mouseMoves=="+mouseMoves+")requestWfs();",tooltipTime);
+function showWMSBalloon(){
+	x=clickX+parseInt(document.getElementById("mapframe1").style.left);
+	y=clickY+parseInt(document.getElementById("mapframe1").style.top);
+	var ind = getMapObjIndexByName("mapframe1");
+	req = mb_mapObj[ind].getFeatureInfoRequests({x:clickX,y:clickY});
+	if(req)
+		tooltipWin = new mb_popup({url:req[0],title:"Feature Info",width:270,height:200,balloon:true,left:x,top:y});
+	tooltipWin.show();
+function showWFSBalloon(geom){
+	x=point.x+parseInt(document.getElementById("mapframe1").style.left);
+	y=point.y+parseInt(document.getElementById("mapframe1").style.top);
+	tooltipWin = new mb_popup({title:searchPopupTitle,html:createListOfGeometries(),width:270,height:150,balloon:true,left:x,top:y});
+function requestWfs(){
+	point = new Point(clickX, clickY);
+	var db_wfs_conf_id = [];
+	js_wfs_conf_id = [];
+	_geomArray = new GeometryArray();
+	wfs_config = window.frames["wfs_conf"].get_wfs_conf();
+	for (var i=0; i<mb_mapObj[ind].wms.length; i++){
+		for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
+			var o = mb_mapObj[ind].wms[i].objLayer[ii];
+			if(o.gui_layer_wfs_featuretype != '' && o.gui_layer_querylayer == '1'){
+				if(o.checkScale(mb_mapObj[ind]))
+					db_wfs_conf_id[db_wfs_conf_id.length] = o.gui_layer_wfs_featuretype;
+	for(var i=0; i<db_wfs_conf_id.length; i++){
+		for(var ii=0; ii<wfs_config.length; ii++){
+			if(wfs_config[ii]['wfs_conf_id'] == db_wfs_conf_id[i])  js_wfs_conf_id[js_wfs_conf_id.length] = ii;
+	numberOfAjaxCalls_ =  js_wfs_conf_id.length;
+	var buffer = mb_wfs_tolerance/2;
+	var mapPosXAddPix = clickX + buffer;
+	var mapPosYAddPix = clickY + buffer;
+	var mapPosXRemovePix = clickX - buffer;
+	var mapPosYRemovePix = clickY - buffer;
+	var realWorld1 = makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYRemovePix);
+	var realWorld2 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
+	var realWorld3 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
+	var realWorld4 = makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYAddPix);
+	for(var i=0; i<js_wfs_conf_id.length; i++){
+		var url = wfs_config[js_wfs_conf_id[i]]['wfs_getfeature'];
+		param = "service=wfs&request=getFeature&version=1.0.0&typename="+ wfs_config[js_wfs_conf_id[i]]['featuretype_name']+"&filter=";
+		var filter = "<ogc:Filter xmlns:ogc='http://ogc.org' xmlns:gml='http://www.opengis.net/gml'>";
+		filter += "<Intersects><ogc:PropertyName>";
+		for(var j=0; j<wfs_config[js_wfs_conf_id[i]]['element'].length; j++){
+			if(wfs_config[js_wfs_conf_id[i]]['element'][j]['f_geom'] == 1){
+				filter += wfs_config[js_wfs_conf_id[i]]['element'][j]['element_name'];
+		filter += "</ogc:PropertyName><gml:Polygon srsName='4326'><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>";
+		filter += realWorld1[0] + "," + realWorld1[1] + " " + realWorld2[0] + "," + realWorld2[1] +  " ";
+		filter += realWorld3[0] + "," + realWorld3[1] + " " + realWorld4[0] + "," + realWorld4[1] + " " + realWorld1[0] + "," + realWorld1[1];
+		filter += "</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></Intersects></ogc:Filter>";
+		url += param;
+		mb_get_geom_(url, filter, i, wfs_config[js_wfs_conf_id[i]]['featuretype_name'], js_wfs_conf_id[i], db_wfs_conf_id[i]);
+	return true;
+function mb_get_geom_(url, filter, index, typename, js_wfs_conf_id, db_wfs_conf_id) {
+	mb_ajax_post("../" + wfsResultModulePath + wfsResultModuleFilename,{'url':url,'filter':filter,'typename':typename,'js_wfs_conf_id':js_wfs_conf_id, 'db_wfs_conf_id':db_wfs_conf_id},function(js_code,status){
+		if (js_code) {
+			eval(js_code);
+		if (typeof(geom) == "undefined") {
+			var geom = new GeometryArray();
+		checkIfAllAjaxCallsFinished_(geom);
+function checkIfAllAjaxCallsFinished_ (geom) {
+	numberOfFinishedAjaxCalls++;
+	if (typeof(geom) == 'object'){
+		_geomArray.union(geom);
+	if (numberOfFinishedAjaxCalls == numberOfAjaxCalls_) {
+		numberOfFinishedAjaxCalls = 0;
+		if(_geomArray.count()>0)
+			showWFSBalloon(_geomArray);
+function createListOfGeometries(){
+	if(_geomArray.count()>0){
+		var listOfGeom = "<table style='background-color:#EEEEEE;'>\n";
+		if (_geomArray.count() > 0) {
+			if(buttonWfs_toDigitize_on==1){
+				listOfGeom += "<tr><td style='color:black;font-size:12px;'>edit all</td>\n";
+				listOfGeom += "<td><img title='edit all' src='"+buttonWfs_toDigitize_src+"'  style='cursor:pointer' onclick='appendGeometryArrayToDigitize(_geomArray);'></img>";
+				listOfGeom += "</td>\n</tr>\n";
+				listOfGeom += "<tr>\n<td>&nbsp;</td>\n</tr>\n";
+			for (var i = 0 ; i < _geomArray.count(); i ++) {
+				if (_geomArray.get(i).get(-1).isComplete()) {
+					listOfGeom += "\t<tr>\n\t\t<td style = 'color:blue;font-size:12px;cursor:pointer;'\n";
+					listOfGeom += "\t\t\t onmouseover='mb_wfs_perform(\"over\",_geomArray.get("+i+"));' ";
+					listOfGeom += " onmouseout='mb_wfs_perform(\"out\",_geomArray.get("+i+"))' ";
+					listOfGeom += " onclick='mb_wfs_perform(\"click\",_geomArray.get("+i+"));' ";
+					var geomName = getListTitle(_geomArray.get(i));
+					//if (_geomArray.get(i).geomType == geomType.polygon) {geomName += "(polygon)";}
+					//else if (_geomArray.get(i).geomType == geomType.line) {geomName += "(line)";}
+					//else if (_geomArray.get(i).geomType == geomType.point) {geomName += "(point)";}
+					listOfGeom += ">" + geomName +"</td>";
+						listOfGeom += "<td><img title='edit geometry object' src='"+buttonWfs_toDigitize_src+"'  style='cursor:pointer' onclick='appendGeometryToDigitize("+i+");'></img></td>";
+					listOfGeom += "\t\t</tr>\n";
+		listOfGeom += "</table>\n";
+		return listOfGeom;
+	else{
+		geometryIndex = 0;
+		wfsConf = get_complete_wfs_conf();
+		var wfsConfIndex = _geomArray.get(0).wfs_conf;
+		var currentWfsConf = wfsConf[wfsConfIndex];
+		var resultHtml = "";
+		resultHtml += "<table style='background-color:#EEEEEE;'>\n";
+		for (var i = 0 ; i <currentWfsConf.element.length; i ++) {
+		    if(currentWfsConf.element[i].f_show_detail==1){
+		    	if( _geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name)!=false){
+					//console.log(currentWfsConf.element[i].element_name+"---"+currentWfsConf.element[i].f_respos);
+					resultHtml +="<tr><td>\n";
+					resultHtml += currentWfsConf.element[i].f_label;
+					resultHtml +="</td>\n";
+					resultHtml += "<td>\n";
+					var elementVal = _geomArray.get(geometryIndex).e.getElementValueByName(currentWfsConf.element[i].element_name);
+					if(currentWfsConf.element[i].f_form_element_html.indexOf("href")!=-1){
+						var setUrl = currentWfsConf.element[i].f_form_element_html.replace(/href\s*=\s*['|"]\s*['|"]/, "href='"+elementVal+"' target='_blank'");
+						if(setUrl.match(/><\/a>/)){
+							var newLink	=	setUrl.replace(/><\/a>/, ">"+elementVal+"</a>");
+						else{
+							var newLink = setUrl;
+						if(openLinkFromSearch=='1'){
+							window.open(elementVal, elementVal,"width=500, height=400,left=100,top=100,scrollbars=yes");
+						resultHtml +=  newLink;
+					else{
+						resultHtml += elementVal;
+					resultHtml += "</td></tr>\n";
+		resultHtml += "</table>\n";
+		return resultHtml;
+function isValidWfsConfIndex (wfsConf, wfsConfIndex) {
+	return (typeof(wfsConfIndex) == "number" && wfsConfIndex >=0 && wfsConfIndex < wfsConf.length);
+function Numsort (a, b) {
+  return a - b;
+function getListTitle (geom) {
+	wfsConfId = geom.wfs_conf;
+	wfsConf = window.frames["wfs_conf"].get_wfs_conf();
+	if (isValidWfsConfIndex(wfsConf, wfsConfId)) {
+		var resultArray = [];
+		var resultName = "";
+		for (var i = 0 ; i < wfsConf[wfsConfId]['element'].length ; i++) {
+			if (wfsConf[wfsConfId]['element'][i]['f_show'] == 1 && geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) !=false) {
+				var pos = wfsConf[wfsConfId]['element'][i]['f_respos'];
+				if (typeof(resultArray[pos]) != "undefined") {
+					resultArray[pos] += " " + geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']);
+				else {
+					resultArray[pos] = geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']);
+				resultName += geom.e.getElementValueByName(wfsConf[wfsConfId]['element'][i]['element_name']) + " ";
+		resultArray.sort(Numsort);
+		var resultName = resultArray.join(" ");
+		if (resultName == "") {
+			resultName = wfsConf[wfsConfId]['g_label'];
+		return resultName;
+	else {
+		return msgObj.digitizeDefaultGeometryName;
Added: branches/beck_dev/http/javascripts/tooltip24.php
--- branches/beck_dev/http/javascripts/tooltip24.php	                        (rev 0)
+++ branches/beck_dev/http/javascripts/tooltip24.php	2008-11-10 13:43:49 UTC (rev 3210)
@@ -0,0 +1,278 @@
+<?php
+	include($fname);
+else {
+var mouseMoves=0;
+var point;
+	mouseMoves++;
+	if(req)
+		str_LayerStyles=mb_checkScale("mapframe1",ind,i);
+		arr_layers = str_LayerStyles[0].split(",");
+				for(iii=0;iii<arr_layers.length;iii++){
+					if(o.layer_name == arr_layers[iii]){
+						break;
+		url += param;
+	return true;
+		if (js_code) {
+			eval(js_code);
+	else{
+						else{
+					else{
+  return a - b;
+				else {
+	else {
More information about the Mapbender_commits mailing list
