[Mapbender-commits] r3220 - trunk/mapbender/http/print
svn_mapbender at osgeo.org
Wed Nov 12 03:43:20 EST 2008
Author: christoph
Date: 2008-11-12 03:43:19 -0500 (Wed, 12 Nov 2008)
New Revision: 3220
trunk/mapbender/http/print/mod_printPDF.php
trunk/mapbender/http/print/mod_printPDF_pdf.php
unfortunately, the file in the repository does not have unix line breaks.
I assume my version is the latest.
Convert line breaks like this before committing
http://www.mapbender.org/Merge#line_breaks
Modified: trunk/mapbender/http/print/mod_printPDF.php
--- trunk/mapbender/http/print/mod_printPDF.php 2008-11-11 14:32:45 UTC (rev 3219)
+++ trunk/mapbender/http/print/mod_printPDF.php 2008-11-12 08:43:19 UTC (rev 3220)
@@ -1,429 +1,403 @@
-<?php
-# $Id: mod_printPDF.php
-# http://www.mapbender.org/index.php/mod_printPDF.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
-session_start();
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Print PDF</title>
-</head>
-<style type="text/css">
-select{
- width:150px;
-input{
- width:150px;
-.mycheck{
- width:15px;
-div{
- font-family : Arial, Helvetica, sans-serif;
- font-size: 12px;
-</style>
-<?php
-//FIXME:
-//setlocale(LC_ALL, "de_DE.utf8");
-require_once(dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
-echo "<script type='text/javascript'>";
-echo "var target = '".$_REQUEST["target"]."';";
-echo "var comment = '".$label_comment."';";
-echo "var comment_length = ".$comment_length.";";
-echo "var label_button = '".$label_button."';";
-echo "var type = '".$type."';";
-echo "</script>";
-<script type="text/javascript">
-var size;
-var format;
-var map_width;
-var map_height;
-if(type=='window'){
- var pt = window.opener;
-else if(type == 'iframe'){
- var pt = parent;
-function mod_legend_print(){
- var mod_legend_target = target;
- var ind = pt.getMapObjIndexByName(mod_legend_target);
- var layers;
- document.forms[0].layers.value = "";
- document.forms[0].wms_id.value = "";
- document.forms[0].wms_title.value = "";
- document.forms[0].legendurl.value = "";
- for(var i=0; i<pt.mb_mapObj[ind].wms.length; i++){
- layers = pt.mb_mapObj[ind].wms[i].getLayers(pt.mb_mapObj[ind]);
- if(layers != "" && layers){
- if(i>0 && document.forms[0].wms_id.value!=''){
- document.forms[0].layers.value += "___";
- document.forms[0].wms_id.value += "___";
- document.forms[0].wms_title.value += "___";
- document.forms[0].legendurl.value += "___";
- document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
- document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
- for(var j=0; j<layers.length; j++){
- var layer = layers[j];
- var title = pt.mb_mapObj[ind].wms[i].getTitleByLayerName(layers[j]);
- var layerStyle = pt.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layers[j]);
- if(layerStyle==false){
- var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"default");
- else{
- var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],layerStyle);
- //---------- legendurl ----------
- tmp_name = "";
- if(j>0){
- document.forms[0].layers.value += ",";
- document.forms[0].layers.value += title;
- if(j>0){
- document.forms[0].legendurl.value += ",";
- if (temp_legendurl!= '' || !temp_legendurl == 'true'){
- document.forms[0].legendurl.value += temp_legendurl;
- }else{
- document.forms[0].legendurl.value +='0';
- else{
- document.forms[0].layers.value += "0";
- document.forms[0].wms_id.value += "0";
- document.forms[0].wms_title.value += "0";
- document.forms[0].legendurl.value += "0";
- }//for
- //alert(document.forms[0].layers.value+"---"+document.forms[0].wms_id.value+"---"+document.forms[0].wms_title.value+"---"+document.forms[0].legendurl.value);
-function validate(){
- size = document.form1.size.options[document.form1.size.selectedIndex].value;
- format = document.form1.format.options[document.form1.format.selectedIndex].value;
- if(size != "" && format != ""){
- var ind = pt.getMapObjIndexByName(target);
- var coord = pt.mb_mapObj[ind].extent.split(",");
- var centerX = parseFloat(coord[0]) + (parseFloat(coord[2]) - parseFloat(coord[0]))/2
- var centerY = parseFloat(coord[1]) + (parseFloat(coord[3]) - parseFloat(coord[1]))/2
- if(size == "A4" && format == "portrait"){
- map_width = <?php echo $a4p_map_width; ?>;
- map_height = <?php echo $a4p_map_height; ?>;
- if(size == "A4" && format == "landscape"){
- map_width = <?php echo $a4l_map_width; ?>;
- map_height = <?php echo $a4l_map_height; ?>;
- if(size == "A3" && format == "portrait"){
- map_width = <?php echo $a3p_map_width; ?>;
- map_height = <?php echo $a3p_map_height; ?>;
- if(size == "A3" && format == "landscape"){
- map_width = <?php echo $a3l_map_width; ?>;
- map_height = <?php echo $a3l_map_height; ?>;
- if(size == "A2" && format == "portrait"){
- map_width = <?php echo $a2p_map_width; ?>;
- map_height = <?php echo $a2p_map_height; ?>;
- if(size == "A2" && format == "landscape"){
- map_width = <?php echo $a2l_map_width; ?>;
- map_height = <?php echo $a2l_map_height; ?>;
- if(size == "A1" && format == "portrait"){
- map_width = <?php echo $a1p_map_width; ?>;
- map_height = <?php echo $a1p_map_height; ?>;
- if(size == "A1" && format == "landscape"){
- map_width = <?php echo $a1l_map_width; ?>;
- map_height = <?php echo $a1l_map_height; ?>;
- if(size == "A0" && format == "portrait"){
- map_width = <?php echo $a0p_map_width; ?>;
- map_height = <?php echo $a0p_map_height; ?>;
- if(size == "A0" && format == "landscape"){
- map_width = <?php echo $a0l_map_width; ?>;
- map_height = <?php echo $a0l_map_height; ?>;
- var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
- var prevscale= pt.mb_getScale(target);
- pt.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," + coord[3];
- pt.mb_mapObj[ind].width = Math.round(map_width);
- pt.mb_mapObj[ind].height = Math.round(map_height);
- pt.document.getElementById(target).style.width = Math.round(map_width);
- pt.document.getElementById(target).style.height = Math.round(map_height);
- pt.window.frames[target].document.getElementById("maps").style.width = Math.round(map_width);
- pt.window.frames[target].document.getElementById("maps").style.height = Math.round(map_height);
- //pt.setMapRequest(target);
- pt.mb_repaintScale(target, null, null, prevscale);
- document.form1.map_url.value = '';
- if(pt.mb_mapObj[ind].wms[i].gui_wms_visible > 0){
- if(pt.mb_mapObj[ind].wms[i].mapURL != false && pt.mb_mapObj[ind].wms[i].mapURL != 'false' && pt.mb_mapObj[ind].wms[i].mapURL != ''){
- if(document.form1.map_url.value != ""){
- document.form1.map_url.value += "___";
- document.form1.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
- //overview_url
- var ind_overview = pt.getMapObjIndexByName('overview');
- //alert ("l�nge: " + length+ " - " + ind_overview + name + pt.mb_mapObj[ind_overview].wms.length);
- if(pt.mb_mapObj[ind_overview].mapURL != false ){
- document.forms[0].overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
-function refreshParams(){
- var f = document.forms[0];
- size = document.getElementById('size').options[document.getElementById('size').selectedIndex].value;
- format = document.getElementById('format').options[document.getElementById('format').selectedIndex].value;
- pt.mb_repaintScale(target, null, null, pt.mb_getScale(target));
- f.map_url.value = '';
- if(f.map_url.value != ""){
- f.map_url.value += "___";
- f.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
- //overview_url
- f.overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
- f.map_scale.value = pt.mb_getScale(target);
- f.epsg.value = pt.mb_mapObj[ind].epsg;
- mod_legend_print();
-function printMap(){
- if(size != "" && (format == "portrait" || format == "landscape")){
- refreshParams();
- if(document.form1.c1.value != comment){
- document.form1.comment1.value = document.form1.c1.value;
- if(document.form1.c2.value != comment){
- document.form1.comment2.value = document.form1.c2.value;
- if(document.form1.mylegendcheckbox.checked == 0){
- document.form1.mylegend.value = 'false';
- }else{
- document.form1.mylegend.value = 'true';
- // write the measured coordinates
- if (pt.mod_measure_RX != undefined && pt.mod_measure_RY != undefined) {
- var tmp_x = '';
- var tmp_y = '';
- for(i = 0; i<pt.mod_measure_RX.length; i++) {
- if(tmp_x != '') {
- tmp_x += ','
- tmp_x += pt.mod_measure_RX[i];
- for(i = 0; i<pt.mod_measure_RY.length; i++) {
- if(tmp_y != '') {
- tmp_y += ','
- tmp_y += pt.mod_measure_RY[i];
- document.forms['form1'].elements['measured_x_values'].value = tmp_x;
- document.forms['form1'].elements['measured_y_values'].value = tmp_y;
- document.form1.submit();
- else{
- alert("<?php echo _("No format selected.")?>");
-function valCom(obj){
- if(obj.value.length > comment_length){
- obj.value = obj.value.substr(0,comment_length);
-</script>
-<body>
-<form name='form1' method='POST' action='../print/mod_printPDF_pdf.php?<?php echo SID; ?>' target="_blank">
-<table border='0'>
-<tr>
- <td>
- <select name='size' onchange='validate()'>
-<?php
- if($a4 == true && $a3 == true){
- echo "<option value=''>".$label_format."</option>";
- if($a4 == true){
- echo "<option value='A4'>".$label_format_a4."</option>";
- if($a3 == true){
- echo "<option value='A3'>".$label_format_a3."</option>";
- if($a2 == true){
- echo "<option value='A2'>".$label_format_a2."</option>";
- if($a1 == true){
- echo "<option value='A1'>".$label_format_a1."</option>";
- if($a0 == true){
- echo "<option value='A0'>".$label_format_a0."</option>";
- </select>
- </td>
-</tr>
-<tr>
- <td>
- <select name='format' onchange='validate()'>
- <option value=''><?php echo $label_orientation; ?></option>
- <option value='portrait'><?php echo $label_portrait; ?></option>
- <option value='landscape'><?php echo $label_landscape; ?></option>
- </select>
- </td>
-</tr>
-<?php
-if($highquality == true){
- echo "<tr>";
- echo "<td>";
- echo "<select name='quality'>";
- echo "<option value='1'>".$label_72dpi."</option>";
- echo "<option value='2'>".$label_288dpi."</option>";
- echo "</select>";
- echo "</td>";
- echo "</tr>";
-<tr>
- <td>
- <input type='text' name='c1' value='<?php echo $label_comment; ?>' onkeydown="valCom(this)">
- </td>
-</tr>
-<tr>
- <td>
- <input type='text' name='c2' value='<?php echo $label_comment; ?>' onkeydown="valCom(this)">
- </td>
-</tr>
-<?php
-if($legend == true){
- echo "<tr>";
- echo "<td>";
- echo "<div><input type='checkbox' class='mycheck' name='mylegendcheckbox' value='false'>".$label_legend."</div>";
- echo "</td>";
- echo "</tr>";
-}else {
- echo "<tr>";
- echo "<td>";
- echo "<input type='hidden' name='mylegendcheckbox' value='false'>";
- echo "</td>";
- echo "</tr>";
-<table>
-<input type='hidden' name='map_url' value=''>
-<input type='hidden' name='overview_url' value=''>
-<input type='hidden' name='wms_title' value=''>
-<input type='hidden' name='wms_id' value=''>
-<input type='hidden' name='layers' value=''>
-<input type='hidden' name='legendurl' value=''>
-<input type='hidden' name='map_scale' value=''>
-<input type='hidden' name='epsg' value=''>
-<input type='button' name='print' value="<?php echo $label_button; ?>" onclick='printMap()'>
-<input type='hidden' name='conf' value='<?php echo $_REQUEST["conf"]; ?>'>
-<input type='hidden' name='comment1' value=''>
-<input type='hidden' name='comment2' value=''>
-<input type='hidden' name='mylegend' value='true'>
-<input type='hidden' name='measured_x_values' value=''>
-<input type='hidden' name='measured_y_values' value=''>
-</form>
-</body>
-</html>
+<?php
+# $Id: mod_printPDF.php
+# http://www.mapbender.org/index.php/mod_printPDF.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
+<head>
+ <meta http-equiv="cache-control" content="no-cache" />
+ <meta http-equiv="pragma" content="no-cache" />
+ <meta http-equiv="expires" content="0" />
+ <?php printf("<meta http-equiv=\"Content-Type\" content=\"text/html; charset=%s\" />",CHARSET); ?>
+ <title>Print PDF</title>
+ <?php
+ //FIXME:
+ //setlocale(LC_ALL, "de_DE.utf8");
+ require_once(dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
+ printf("
+ <script type=\"text/javascript\">
+ var target = '%s';
+ var comment1 = '%s';
+ var comment1_length = %s;
+ var comment2 = '%s';
+ var comment2_length = %s;
+ var label_button = '%s';
+ var type = '%s';
+ </script>",
+ $_REQUEST["target"],$label_comment1,$comment1_length,$label_comment2,$comment2_length,$label_button,$type
+ <script type="text/javascript">
+ var size;
+ var format;
+ var map_width;
+ var map_height;
+ if(type=='window'){
+ var pt = window.opener;
+ else if(type == 'iframe'){
+ var pt = parent;
+ function mod_legend_print(){
+ var mod_legend_target = target;
+ var ind = pt.getMapObjIndexByName(mod_legend_target);
+ var layers;
+ document.forms[0].layers.value = "";
+ document.forms[0].wms_id.value = "";
+ document.forms[0].wms_title.value = "";
+ document.forms[0].legendurl.value = "";
+ for(var i=0; i<pt.mb_mapObj[ind].wms.length; i++){
+ layers = pt.mb_mapObj[ind].wms[i].getLayers(pt.mb_mapObj[ind]);
+ if(layers != "" && layers){
+ if(i>0 && document.forms[0].wms_id.value!=''){
+ document.forms[0].layers.value += "___";
+ document.forms[0].wms_id.value += "___";
+ document.forms[0].wms_title.value += "___";
+ document.forms[0].legendurl.value += "___";
+ document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
+ document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
+ for(var j=0; j<layers.length; j++){
+ var layer = layers[j];
+ var title = pt.mb_mapObj[ind].wms[i].getTitleByLayerName(layers[j]);
+ var layerStyle = pt.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layers[j]);
+ if(layerStyle==false){
+ var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"default");
+ else{
+ var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],layerStyle);
+ //---------- legendurl ----------
+ tmp_name = "";
+ if(j>0){
+ document.forms[0].layers.value += ",";
+ document.forms[0].layers.value += title;
+ if(j>0){
+ document.forms[0].legendurl.value += ",";
+ if (temp_legendurl!= '' || !temp_legendurl == 'true'){
+ document.forms[0].legendurl.value += temp_legendurl;
+ }else{
+ document.forms[0].legendurl.value +='0';
+ else{
+ document.forms[0].layers.value += "0";
+ document.forms[0].wms_id.value += "0";
+ document.forms[0].wms_title.value += "0";
+ document.forms[0].legendurl.value += "0";
+ }//for
+ //alert(document.forms[0].layers.value+"---"+document.forms[0].wms_id.value+"---"+document.forms[0].wms_title.value+"---"+document.forms[0].legendurl.value);
+ function validate(){
+ size = document.getElementById('size').options[document.getElementById('size').selectedIndex].value;
+ format = document.getElementById('format').options[document.getElementById('format').selectedIndex].value;
+ if(size != "false" && format != "false"){
+ var ind = pt.getMapObjIndexByName(target);
+ var coord = pt.mb_mapObj[ind].extent.split(",");
+ var centerX = parseFloat(coord[0]) + (parseFloat(coord[2]) - parseFloat(coord[0]))/2
+ var centerY = parseFloat(coord[1]) + (parseFloat(coord[3]) - parseFloat(coord[1]))/2
+ if(size == "A4" && format == "portrait"){
+ map_width = <?php echo $a4p_map_width; ?>;
+ map_height = <?php echo $a4p_map_height; ?>;
+ if(size == "A4" && format == "landscape"){
+ map_width = <?php echo $a4l_map_width; ?>;
+ map_height = <?php echo $a4l_map_height; ?>;
+ if(size == "A3" && format == "portrait"){
+ map_width = <?php echo $a3p_map_width; ?>;
+ map_height = <?php echo $a3p_map_height; ?>;
+ if(size == "A3" && format == "landscape"){
+ map_width = <?php echo $a3l_map_width; ?>;
+ map_height = <?php echo $a3l_map_height; ?>;
+ if(size == "A2" && format == "portrait"){
+ map_width = <?php echo $a2p_map_width; ?>;
+ map_height = <?php echo $a2p_map_height; ?>;
+ if(size == "A2" && format == "landscape"){
+ map_width = <?php echo $a2l_map_width; ?>;
+ map_height = <?php echo $a2l_map_height; ?>;
+ if(size == "A1" && format == "portrait"){
+ map_width = <?php echo $a1p_map_width; ?>;
+ map_height = <?php echo $a1p_map_height; ?>;
+ if(size == "A1" && format == "landscape"){
+ map_width = <?php echo $a1l_map_width; ?>;
+ map_height = <?php echo $a1l_map_height; ?>;
+ if(size == "A0" && format == "portrait"){
+ map_width = <?php echo $a0p_map_width; ?>;
+ map_height = <?php echo $a0p_map_height; ?>;
+ if(size == "A0" && format == "landscape"){
+ map_width = <?php echo $a0l_map_width; ?>;
+ map_height = <?php echo $a0l_map_height; ?>;
+ var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
+ var prevscale= pt.mb_getScale(target);
+ console.log(prevscale);
+ pt.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," + coord[3];
+ pt.mb_mapObj[ind].width = Math.round(map_width);
+ pt.mb_mapObj[ind].height = Math.round(map_height);
+ pt.document.getElementById(target).style.width = Math.round(map_width);
+ pt.document.getElementById(target).style.height = Math.round(map_height);
+ pt.window.frames[target].document.getElementById("maps").style.width = Math.round(map_width);
+ pt.window.frames[target].document.getElementById("maps").style.height = Math.round(map_height);
+ //pt.setMapRequest(target);
+// pt.mb_repaintScale(target, null, null, prevscale);
+ pt.mb_repaint(target, parseFloat(coord[0]), pos[1], pos[0], parseFloat(coord[3]));
+ document.form1.map_url.value = '';
+ if(pt.mb_mapObj[ind].wms[i].gui_wms_visible > 0){
+ if(pt.mb_mapObj[ind].wms[i].mapURL != false && pt.mb_mapObj[ind].wms[i].mapURL != 'false' && pt.mb_mapObj[ind].wms[i].mapURL != ''){
+ if(document.form1.map_url.value != ""){
+ document.form1.map_url.value += "___";
+ document.form1.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
+ //overview_url
+ var ind_overview = pt.getMapObjIndexByName('overview');
+ //alert ("l�nge: " + length+ " - " + ind_overview + name + pt.mb_mapObj[ind_overview].wms.length);
+ if(pt.mb_mapObj[ind_overview].mapURL != false ){
+ document.forms[0].overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
+ function refreshParams(){
+ var f = document.forms[0];
+ if(size != "" && format != ""){
+// pt.mb_repaintScale(target, null, null, pt.mb_getScale(target));
+ f.map_url.value = '';
+ if(f.map_url.value != ""){
+ f.map_url.value += "___";
+ f.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
+ //overview_url
+ f.overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
+ f.map_scale.value = pt.mb_getScale(target);
+ f.epsg.value = pt.mb_mapObj[ind].epsg;
+ mod_legend_print();
+ function printMap(){
+ if(size != "false" && (format == "portrait" || format == "landscape")){
+ refreshParams();
+ if(document.form1.c1.value != comment1){
+ document.form1.comment1.value = document.form1.c1.value;
+ if(document.form1.c2.value != comment2){
+ document.form1.comment2.value = document.form1.c2.value;
+ if(document.form1.mylegendcheckbox.checked == 0){
+ document.form1.mylegend.value = 'false';
+ }else{
+ document.form1.mylegend.value = 'true';
+ // write the measured coordinates
+ if (pt.mod_measure_RX != undefined && pt.mod_measure_RY != undefined) {
+ var tmp_x = '';
+ var tmp_y = '';
+ for(i = 0; i<pt.mod_measure_RX.length; i++) {
+ if(tmp_x != '') {
+ tmp_x += ','
+ tmp_x += pt.mod_measure_RX[i];
+ for(i = 0; i<pt.mod_measure_RY.length; i++) {
+ if(tmp_y != '') {
+ tmp_y += ','
+ tmp_y += pt.mod_measure_RY[i];
+ document.forms['form1'].elements['measured_x_values'].value = tmp_x;
+ document.forms['form1'].elements['measured_y_values'].value = tmp_y;
+ document.form1.submit();
+ else{
+ alert('<?php echo _mb("No format selected")."!"?>');
+ function checkCommentLength(obj,maxLength){
+ if(obj.value.length > maxLength){
+ obj.value = obj.value.substr(0,maxLength);
+ </script>
+ <?php include("../include/dyn_css.php"); ?>
+</head>
+<body>
+<form name="form1" method="post" action="../print/mod_printPDF_pdf.php?<?php echo SID; ?>" target="_blank">
+<p id="container_size">
+ <label for="size"><?php echo $label_format ?></label>
+ <select id="size" name="size" onchange="validate();">
+ <option value="false">-</option>
+ <?php
+ for($i = 4; $i >= 0; $i--) {
+ if(${"a".$i}) {
+ printf("<option value=\"A%s\">%s</option>",$i,${"label_format_a".$i});
+ </select>
+</p>
+<p id="container_orientation">
+ <label for="format"><?php echo $label_orientation; ?></label>
+ <select id="format" name="format" onchange="validate();">
+ <option value="portrait"><?php echo $label_portrait; ?></option>
+ <option value="landscape"><?php echo $label_landscape; ?></option>
+ </select>
+</p>
+<?php if($highquality === TRUE): ?>
+ <p id="container_quality">
+ <label for="quality"><?php echo $label_quality; ?></label>
+ <input type="radio" id="quality" name="quality" value="1" checked="checked" /> <?php echo $label_72dpi; ?>
+ <input type="radio" id="quality" name="quality" value="2" /> <?php echo $label_288dpi; ?>
+ </p>
+<?php endif; ?>
+<?php
+ini_set("error_reporting",E_ALL);
+ini_set("display_errors","on");
+ for($i = 1; $i <= 2; $i++) {
+ $max_comment_length = ${"comment".$i."_length"};
+ $label_hint = ($max_comment_length > -1) ? sprintf(" <em>"._mb("max.")." %s)</em>",$max_comment_length) : NULL;
+ $javascript = ($max_comment_length > -1) ? sprintf(" onblur=\"checkCommentLength(this,%s)\"",$max_comment_length) : NULL;
+ $html = sprintf("<p id=\"container_comment%s\">",$i);
+ $html .= sprintf("<label for=\"c%s\">%s%s</label> ",$i,${"label_comment".$i},$label_hint);
+ $html .= sprintf("<textarea id=\"c%s\" name=\"c%s\" cols=\"20\" rows=\"2\"%s></textarea> ",$i,$i,$javascript);
+ $html .= "</p>";
+ echo $html;
+<?php if($legend === TRUE): ?>
+ <p id="container_legend">
+ <label for="mylegendcheckbox"><?php echo $label_legend; ?></label>
+ <input type="checkbox" id="mylegendcheckbox" name="mylegendcheckbox" value="false" />
+ </p>
+<?php else: ?>
+ <input type="hidden" name="mylegendcheckbox" value="false" />
+<?php endif; ?>
+<input type="hidden" name="map_url" />
+<input type="hidden" name="overview_url" />
+<input type="hidden" name="wms_title" />
+<input type="hidden" name="wms_id" />
+<input type="hidden" name="layers" />
+<input type="hidden" name="legendurl" />
+<input type="hidden" name="map_scale" />
+<input type="hidden" name="epsg" />
+<input type="hidden" name="conf" value="<?php echo $_REQUEST["conf"]; ?>" />
+<input type="hidden" name="comment1" />
+<input type="hidden" name="comment2" />
+<input type="hidden" name="mylegend" value="true" >
+<input type="hidden" name="measured_x_values" />
+<input type="hidden" name="measured_y_values" />
+<p>
+ <input type="button" id="print" name="print" value="<?php echo $label_button; ?>" onclick="printMap();" />
+</p>
+</form>
+</body>
+</html>
Modified: trunk/mapbender/http/print/mod_printPDF_pdf.php
--- trunk/mapbender/http/print/mod_printPDF_pdf.php 2008-11-11 14:32:45 UTC (rev 3219)
+++ trunk/mapbender/http/print/mod_printPDF_pdf.php 2008-11-12 08:43:19 UTC (rev 3220)
@@ -1,850 +1,850 @@
-<?php
-# $Id:
-# http://www.mapbender.org/index.php/mod_printPDF_pdf.php
-include (dirname(__FILE__)."/../classes/class.ezpdf.php");
-include (dirname(__FILE__)."/../classes/class_stripRequest.php");
-include (dirname(__FILE__)."/../classes/class_weldMaps2PNG.php");
-include (dirname(__FILE__)."/../classes/class_weldOverview2PNG.php");
-include (dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
-include (dirname(__FILE__)."/../classes/class_SaveLegend.php");
-include (dirname(__FILE__)."/../print/print_functions.php");
-if($log == true){
- include (dirname(__FILE__)."/../classes/class_log.php");
-#Globals
-$factor = intval($_REQUEST["quality"]);
-#$date = date("d.m.Y",strtotime("now"));
-$linewidth_dashed = 0.5;
-$linewidth = 0.5;
-// DURATION TIME:
-function microtime_float(){
- list($usec, $sec) = explode(" ", microtime());
- return ((float)$usec + (float)$sec);
-$time_start = microtime_float();
-// END DURATION TIME
-$time_end = microtime_float();
-$time = $time_end - $time_start;
-$size = $_REQUEST["size"];
-$format = $_REQUEST["format"];
-$map_scale = $_REQUEST["map_scale"];
-$overview_url = $_REQUEST["overview_url"];
-$epsg = $_REQUEST["epsg"];
-if($overview_url=='false'){
- $overview = false;
-function setscalebar($scale){
- $mb_resolution = 28.35;
- if($scale < 16){
- $value = "10";
- $unit = "cm";
- $scalefactor = 10/$scale;
- $img_width = round($scalefactor * $mb_resolution);
- if($scale >= 16 && $scale < 151){
- $value = "1";
- $unit = "Meter";
- $scalefactor = 100/$scale;
- if($scale >= 151 && $scale < 1550 ){
- $value = "10";
- $unit = "Meter";
- $scalefactor = 1000/$scale;
- if($scale >= 1550 && $scale < 15050){
- $value = "100";
- $unit = "Meter";
- $scalefactor = 10000/$scale;
- if($scale < 150050 && $scale >= 15050){
- $value = "1";
- $unit = "Kilometer";
- $scalefactor = 100000/$scale;
- if($scale < 1500050 && $scale >= 150050){
- $value = "10";
- $scalefactor = 1000000/$scale;
- if($scale < 15000050 && $scale >= 1500050){
- $value = "100";
- $scalefactor = 10000000/$scale;
- if($scale < 150000001 && $scale >= 15000001){
- $value = "1000";
- $scalefactor = 100000000/$scale;
- if($scale >= 150000001){
- $value = "1000";
- $array_scale[0] = $unit;
- $array_scale[1] = $img_width;
- $array_scale[2] = $value;
- return $array_scale;
-$border = 0.8 * $DPC;
-if($matching == true){
- $urls = preg_replace($pattern,$replacement,$_REQUEST["map_url"]);
-else{
- $urls = $_REQUEST["map_url"];
-$array_urls = explode("___", $urls);
-$myURL = new stripRequest($array_urls[0]);
-$map_width = round($myURL->get("width"));
-$map_height = round($myURL->get("height"));
-$map_extent = $myURL->get("BBOX");
-if($factor>1){
- for($i=0; $i<count($array_urls); $i++){
- $m = new stripRequest($array_urls[$i]);
- $m->set('width',(intval($m->get('width'))*4));
- $m->set('height',(intval($m->get('height'))*4));
- if(in_array($m->get('map'),$highqualitymapfiles)){
- $m->set('map',preg_replace("/\.map/","_4.map",$m->get('map')));
- $array_urls[$i] = $m->url;
-$coord = mb_split(",",$map_extent);
-if($overview === true){
- // analyse overview url and draw rectangle with position
- $o_url = new stripRequest($overview_url);
- $overview_width = round($o_url->get("width"));
- $overview_height = round($o_url->get("height"));
- if($factor>1){
- $o_url->set('width',(intval($o_url->get('width'))*4));
- $o_url->set('height',(intval($o_url->get('height'))*4));
- if(in_array($o_url->get('map'),$highqualitymapfiles)){
- $o_url->set('map',preg_replace("/\.map/","_4.map",$o_url->get('map')));
- $overview_url = $o_url->url;
- if($matching == true){
- $overview_url = preg_replace($pattern,$replacement,$overview_url);
- if ($size == "A4" && $format == "portrait"){
- $overview_left = $a4p_overviewOffset_left;
- $overview_bottom =$a4p_overviewOffset_bottom;
- }elseif ($size == "A4" && $format == "landscape"){
- $overview_left = $a4l_overviewOffset_left;
- $overview_bottom =$a4l_overviewOffset_bottom;
- }elseif ($size == "A3" && $format == "portrait"){
- $overview_left = $a3p_overviewOffset_left;
- $overview_bottom =$a3p_overviewOffset_bottom;
- }elseif ($size == "A3" && $format == "landscape"){
- $overview_left = $a3l_overviewOffset_left;
- $overview_bottom = $a3l_overviewOffset_bottom;
- }elseif ($size == "A2" && $format == "portrait"){
- $overview_left = $a2p_overviewOffset_left;
- $overview_bottom =$a2p_overviewOffset_bottom;
- }elseif ($size == "A2" && $format == "landscape"){
- $overview_left = $a2l_overviewOffset_left;
- $overview_bottom = $a2l_overviewOffset_bottom;
- }elseif ($size == "A1" && $format == "portrait"){
- $overview_left = $a1p_overviewOffset_left;
- $overview_bottom =$a1p_overviewOffset_bottom;
- }elseif ($size == "A1" && $format == "landscape"){
- $overview_left = $a1l_overviewOffset_left;
- $overview_bottom = $a1l_overviewOffset_bottom;
- }elseif ($size == "A0" && $format == "portrait"){
- $overview_left = $a0p_overviewOffset_left;
- $overview_bottom =$a0p_overviewOffset_bottom;
- }elseif ($size == "A0" && $format == "landscape"){
- $overview_left = $a0l_overviewOffset_left;
- $overview_bottom = $a0l_overviewOffset_bottom;
- $o_extent = $o_url->get("BBOX");
- $array_overview_url[0] = $overview_url;
- if($log == true){
- $l = new log("printPDF_overview",$array_overview_url);
- $o_new = new stripRequest($overview_url);
- $o_new->set('width',50);
- $o_new->set('height',50);
- //$o->set('BBOX',$overview_extent);
- $o_url_new =$o_new->url;
- $array_overview[0] = $overview_url;
- $array_overview[1] = $o_url;
- * north arrow
-if($size == "A4" && $format == "portrait"){
- $northarrow_left = $a4p_northarrow_left;
- $northarrow_bottom = $a4p_northarrow_bottom;
-}elseif ($size == "A4" && $format == "landscape"){
- $northarrow_left = $a4l_northarrow_left;
- $northarrow_bottom = $a4l_northarrow_bottom;
-}elseif ($size == "A3" && $format == "portrait"){
- $northarrow_left = $a3p_northarrow_left;
- $northarrow_bottom = $a3p_northarrow_bottom;
-}elseif ($size == "A3" && $format == "landscape"){
- $northarrow_left = $a3l_northarrow_left;
- $northarrow_bottom = $a3l_northarrow_bottom;
-}elseif ($size == "A2" && $format == "portrait"){
- $northarrow_left = $a2p_northarrow_left;
- $northarrow_bottom = $a2p_northarrow_bottom;
-}elseif ($size == "A2" && $format == "landscape"){
- $northarrow_left = $a2l_northarrow_left;
- $northarrow_bottom = $a2l_northarrow_bottom;
-}elseif ($size == "A1" && $format == "portrait"){
- $northarrow_left = $a1p_northarrow_left;
- $northarrow_bottom = $a1p_northarrow_bottom;
-}elseif ($size == "A1" && $format == "landscape"){
- $northarrow_left = $a1l_northarrow_left;
- $northarrow_bottom = $a1l_northarrow_bottom;
-}elseif ($size == "A0" && $format == "portrait"){
- $northarrow_left = $a0p_northarrow_left;
- $northarrow_bottom = $a0p_northarrow_bottom;
-}elseif ($size == "A0" && $format == "landscape"){
- $northarrow_left = $a0l_northarrow_left;
- $northarrow_bottom = $a0l_northarrow_bottom;
- * special image
-if ($size == "A4" && $format == "portrait"){
- $specialImage_left = $a4p_special_left;
- $specialImage_bottom = $a4p_special_bottom;
- $specialImage_left = $a4l_special_left;
- $specialImage_bottom = $a4l_special_bottom;
- $specialImage_left = $a3p_special_left;
- $specialImage_bottom = $a3p_special_bottom;
- $specialImage_left = $a3l_special_left;
- $specialImage_bottom = $a3l_special_bottom;
- $specialImage_left = $a2p_special_left;
- $specialImage_bottom = $a2p_special_bottom;
- $specialImage_left = $a2l_special_left;
- $specialImage_bottom = $a2l_special_bottom;
- $specialImage_left = $a1p_special_left;
- $specialImage_bottom = $a1p_special_bottom;
- $specialImage_left = $a1l_special_left;
- $specialImage_bottom = $a1l_special_bottom;
- $specialImage_left = $a0p_special_left;
- $specialImage_bottom = $a0p_special_bottom;
- $specialImage_left = $a0l_special_left;
- $specialImage_bottom = $a0l_special_bottom;
-if($log == true){
- $l = new log("printPDF",$array_urls);
-$pdf = new Cezpdf();
-$pdf->Cezpdf(mb_strtolower($size),$format);
-$diff=array(196=>'Adieresis',228=>'adieresis',
- 214=>'Odieresis',246=>'odieresis',
- 220=>'Udieresis',252=>'udieresis',
- 223=>'germandbls');
-$pdf->selectFont('../classes/fonts/Helvetica.afm', array('encoding'=>'WinAnsiEncoding','differences'=>$diff));
- $mapOffset_left = $a4p_mapOffset_left;
- $mapOffset_bottom = $a4p_mapOffset_bottom;
- $header_height = $a4p_header_height;
- $footer_height = $a4p_footer_height;
-else{
- $mapOffset_left = $a4l_mapOffset_left;
- $mapOffset_bottom = $a4l_mapOffset_bottom;
- $header_height = $a4l_header_height;
- $header_width = $a4l_header_width;
-session_write_close();
-$i = new weldMaps2PNG(implode("___",$array_urls),$filename);
-$pdf->addPngFromFile($filename, $mapOffset_left, $mapOffset_bottom, $map_width, $map_height);
-if($unlink == true){
- unlink($filename);
-* user drawn elements
-$theMeasureConfigArray = array(
- "do_fill" => FALSE,
- "fill_color" => array(
- "r" => 128 / 255,
- "g" => 128 / 255,
- "b" => 128 / 255
- "do_stroke" => FALSE,
- "stroke_color" => array(
- "r" => 254 / 255,
- "g" => 1 / 255,
- "b" => 1 / 255
- "line_style" => array(
- "width" => 2,
- "cap" => 'butt',
- "join" => 'miter',
- "dash" => array(10, 6)
-if ($_REQUEST["measured_x_values"]!=''){
- addMeasuredItem($pdf, $_REQUEST["measured_x_values"], $_REQUEST["measured_y_values"], $theMeasureConfigArray);
- hideElementsOutsideMapframe($pdf);
-# dashed line
-$pdf->setLineStyle($linewidth_dashed, '','', array(2,2));
-$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
-$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
-$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed);
-$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed);
-#line
-$pdf->setLineStyle($linewidth, '', '', array());
-$pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border);
-$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
-$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom -$border);
-$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border, $mapOffset_left - $border, $mapOffset_bottom - $border);
-if($epsg == "EPSG:4326"){
- $text4 = "";
- #header:
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height);
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height);
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
- $pdf->line( $mapOffset_left + $map_width/2, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width/2, $mapOffset_bottom + $map_height + $border + $header_height);
- #header-text
- $mySize = 9;
- $length = $pdf->getTextWidth($mySize, $text1);
- $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text1);
- $mySize = 8;
- $length = $pdf->getTextWidth($mySize, $text2);
- $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 45,$mySize,$text2);
- $length = $pdf->getTextWidth($mySize, $text3);
- $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 35,$mySize,$text3);
- $mySize = 9;
- $length = $pdf->getTextWidth($mySize, $text4);
- $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text4);
- $mySize = 8;
- $length = $pdf->getTextWidth($mySize, $text5);
- $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text5);
- $mySize = 9;
- $length = $pdf->getTextWidth($mySize, $text6);
- $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text6);
- $length = $pdf->getTextWidth($mySize, $text7);
- $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 50,$mySize,$text7);
- $length = $pdf->getTextWidth($mySize, $text8);
- $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 30,$mySize,$text8);
- $length = $pdf->getTextWidth($mySize, $text9);
- $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text9);
- $length = $pdf->getTextWidth($mySize, $text10);
- $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text10);
- //special image on the map-page
- if ($special == true){
- $pdf->addPngFromFile($specialImage, $specialImage_left, $specialImage_bottom , $specialImage_width, $specialImage_height);
- #footer
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
- $mySize = 8;
- $length = $pdf->getTextWidth($mySize, $text11);
- $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 10,$mySize,$text11);
- $mySize = 6;
- $length = $pdf->getTextWidth($mySize, $text12);
- $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 18,$mySize,$text12);
- $length = $pdf->getTextWidth($mySize, $text13);
- $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 25,$mySize,$text13);
-else{
- $pdf->setColor(1,1,1);
- $ll = array($mapOffset_left + $map_width - $header_width + $border - $linewidth, $mapOffset_bottom - $border + 1);
- $pdf->filledRectangle($ll[0], $ll[1], $header_width,$header_height);
- $pdf->line($ll[0], $ll[1], $ll[0], $ll[1] + $header_height);
- $pdf->line($ll[0], $ll[1] + $header_height, $ll[0] + $header_width, $ll[1] + $header_height);
- $pdf->line($ll[0] + 2, $ll[1] + 2, $ll[0] + 2, $ll[1] + $header_height - 2);
- $pdf->line($ll[0] + 2, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + $header_height - 2);
- $pdf->line($ll[0] - 2 + $header_width, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + 2);
- $pdf->line($ll[0] - 2 + $header_width, $ll[1] + 2, $ll[0] + 2, $ll[1] + 2);
- $pdf->line($ll[0] + 2, $ll[1] + 110 , $ll[0] - 2 + $header_width, $ll[1] + 110);
- $pdf->line($ll[0] + 2, $ll[1] + 40 , $ll[0] - 2 + $header_width, $ll[1] + 40);
- if($epsg == "EPSG:4326"){
- $text4 = "";
- $pdf->setColor(0,0,0);
- $mySize = 9;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,185,$mySize,$text1);
- $mySize = 8;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,175,$mySize,$text2);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,165,$mySize,$text3);
- $mySize = 9;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,155,$mySize,$text4);
- $mySize = 8;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,145,$mySize,$text5);
- $mySize = 9;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,125,$mySize,$text6);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,115,$mySize,$text7);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,95,$mySize,$text8);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,85,$mySize,$text9);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,75,$mySize,$text10);
- $mySize = 8;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,60,$mySize,$text11);
- $mySize = 6;
- $length = $pdf->getTextWidth($mySize, $text14);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,53,$mySize,$text14);
- $length = $pdf->getTextWidth($mySize, $text15);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,47,$mySize,$text15);
- $length = $pdf->getTextWidth($mySize, $text16);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,41,$mySize,$text16);
- $length = $pdf->getTextWidth($mySize, $text17);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,35,$mySize,$text17);
-#Coordinates
-$myMinx = "R ".substr(round($coord[0]), 0, 4)." ".substr(round($coord[0]), 4, 3)."";
-$myMiny = "H ".substr(round($coord[1]), 0, 4)." ".substr(round($coord[1]), 4, 3)."";
-$myMaxx = "R ".substr(round($coord[2]), 0, 4)." ".substr(round($coord[2]), 4, 3)."";
-$myMaxy = "H ".substr(round($coord[3]), 0, 4)." ".substr(round($coord[3]), 4, 3)."";
-$mySize = 9;
-$pdf->addText($mapOffset_left - 3, $mapOffset_bottom, $mySize, $myMinx, -90);
-$pdf->addText($mapOffset_left, $mapOffset_bottom - ($pdf->getFontHeight($mySize)), $mySize, $myMiny);
-$pdf->addText($mapOffset_left + $map_width - ($pdf->getTextWidth($mySize, $myMaxx)), $mapOffset_bottom + $map_height + 3, $mySize, $myMaxx);
-$pdf->addText($mapOffset_left + $map_width + 3, $mapOffset_bottom + $map_height, $mySize, $myMaxy, 90);
-if ($overview==true){
- // analyse request, draw rectancle
- $filename = preg_replace("/map_/","overview_",$filename);
- if($size == "A4" && $format == "portrait"){
- $i = new weldOverview2PNG($overview_url,$array_urls[0] ,$filename);
- $pdf->addPngFromFile($filename, $overview_left,$overview_bottom, $overview_width, $overview_height);
- if($unlink == true){
- else{
- $i = new weldOverview2PNG($overview_url,$array_urls[0],$filename);
- //$pdf->addPngFromFile($filename, $mapOffset_left,$mapOffset_bottom, $overview_width, $overview_height);
-if ($northarrow==true){
- $pdf->addPngFromFile($northarrowImage, $northarrow_left, $northarrow_bottom , $northarrowImage_width, $northarrowImage_height);
- $scalebar = false;
-if($scalebar == true){
- $scalebar_left = $a4p_scalebar_left;
- $scalebar_bottom = $a4p_scalebar_bottom;
- $scalebar_left = $a4l_scalebar_left;
- $scalebar_bottom = $a4l_scalebar_bottom;
- $scalebar_left = $a3p_scalebar_left;
- $scalebar_bottom = $a3p_scalebar_bottom;
- $scalebar_left = $a3l_scalebar_left;
- $scalebar_bottom = $a3l_scalebar_bottom;
- $scalebar_left = $a2p_scalebar_left;
- $scalebar_bottom = $a2p_scalebar_bottom;
- $scalebar_left = $a2l_scalebar_left;
- $scalebar_bottom = $a2l_scalebar_bottom;
- $scalebar_left = $a1p_scalebar_left;
- $scalebar_bottom = $a1p_scalebar_bottom;
- $scalebar_left = $a1l_scalebar_left;
- $scalebar_bottom = $a1l_scalebar_bottom;
- $scalebar_left = $a0p_scalebar_left;
- $scalebar_bottom = $a0p_scalebar_bottom;
- $scalebar_left = $a0l_scalebar_left;
- $scalebar_bottom = $a0l_scalebar_bottom;
- $array_scalebar = setscalebar($map_scale);
- $scalebar_left = $scalebar_left + $header_width/2 - $array_scalebar[1]/2;
- $pdf->setLineStyle($scalebar_height, '','', array());
- #$pdf->line($scalebar_left, $scalebar_bottom , $scalebar_left - 200 + $array_scalebar[1], $scalebar_bottom);
- $pdf->filledRectangle($scalebar_left, $scalebar_bottom, $array_scalebar[1],$scalebar_height);
- $pdf->filledRectangle($scalebar_left + $array_scalebar[1]/4 + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 1 ,$scalebar_height-2);
- $pdf->filledRectangle($scalebar_left + 3*($array_scalebar[1]/4) + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 2 ,$scalebar_height-2);
- #$pdf->setColor(1,0,1);
- #$pdf->filledRectangle($scalebar_left , $scalebar_bottom - 20, 1 * $DPC ,$scalebar_height-2);
- # value - Einheiten
- $mySize = 8;
- $scalebar_height_half = 0.5 * $scalebar_height;
- $myText = 0;
- $length = $pdf->getTextWidth($mySize, $myText);
- $pdf->addText($scalebar_left - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
- $myText = $array_scalebar[2]/2;
- $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
- $myText = $array_scalebar[2];
- $pdf->addText($scalebar_left + $array_scalebar[1] - $length/2 - $length/4 ,$scalebar_bottom + 9 ,$mySize,$myText);
- $mySize = 8;
- $myText = $array_scalebar[0];
- #$pdf->addText($scalebar_left + $scalebar_width + 5,$scalebar_bottom - $scalebar_height_half ,$mySize,$myText);
- #units
- $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom - 12 ,$mySize,$myText);
- new page for legend
-if ($legend == true && $_REQUEST["mylegend"]=='true'){
- $pdf->ezNewPage();
- //Pageborder (top, bottom, left, right)
- $pdf->ezSetMargins(50,50,80,30);
- } else {
- $pdf->ezSetMargins(60,35,60,60);
- //Requests
- if(CHARSET=="UTF-8"){
- $new_wms_title=utf8_decode($_REQUEST["wms_title"]);
- }else{
- $new_wms_title=$_REQUEST["wms_title"];
- $new_layers=utf8_decode($_REQUEST["layers"]);
- }else{
- $new_layers=$_REQUEST["layers"];
- $my_wms_id = explode("___",$_REQUEST["wms_id"]);
- $my_wms_title = explode("___",$new_wms_title);
- $my_layers = explode("___",$new_layers);
- $my_legend = preg_replace($pattern,$replacement,$_REQUEST["legendurl"]);
- else{
- $my_legend = $_REQUEST["legendurl"];
- $my_legend = explode("___",$my_legend);
- //columns
- $pdf->ezColumnsStart(array ('num'=>2, 'gap'=>10));
- } else {
- $pdf->ezColumnsStart(array ('num'=>3, 'gap'=>10));
- //header from printPDF.conf
- //$pdf->ezText("<b>".$titel."</b>", 13);
- $pdf->ezText("<b><u>".$legendText."</u></b>", 13);
- //Seitenraender (top, bottom, left, right)
- $pdf->ezSetMargins(70,35,80,30);
- } else {
- $pdf->ezSetMargins(100,35,60,60);
- //generate the legend---------------------------------------------
- // Gesamthoehe Legende / height of the legend
- $sum_legend_height = 0;
- for($i=0; $i<count($my_wms_id); $i++){
- if ($my_wms_id[$i] != '0'){ //wms_id not 0
- $layer = explode(",",$my_layers[$i]);
- $my_legendurls = explode(",",$my_legend[$i]);
- $wms_y_position = $pdf->ezText("<b>".$my_wms_title[$i]."</b>", 12, array('spacing'=>1.2));
- $wms_zeilenhoehe = $pdf->getFontHeight(12);
- // add this to the height of the legend /addiere dies zur Gesamthoehe Legende
- $sum_legend_height += $wms_zeilenhoehe;
- //Layer
- $l = 0; #l temporary parameter to count the layer /Hilfvariable zum durchz�hlen der angezeigten Layer
- for($j=0; $j<count($my_legendurls); $j++){
- // url with grouped layers------------------
- $temp_url = explode('*',$my_legendurls[$j]);
- $temp_layers = explode('*',$layer[$j]);
- for ($q=0; $q <count($temp_url);$q++){
- if($temp_url[$q] == '1' ){ // Layertitle for the parent of grouped layers
- // add this to the height of the legend /addiere dies zur Gesamth�he Legende
- $layer_y_position = $pdf->ezText($temp_layers[$q], 11, array('spacing'=>1.2));
- $layer_zeilenhoehe = $pdf->getFontHeight(12);
- $sum_legend_height += $layer_zeilenhoehe;
- }elseif($temp_url[$q] != '0' ){
- $funktionsaufruf = new SaveLegend($temp_url[$q],$legendFilename);
- $imgsize = getimagesize($legendFilename);
- // add this to the height of the legend /addiere dies zur Gesamthoehe der Legende
- $sum_legend_height += $imgsize[1];
- //calculate text + picture / Berechnung Groesse Schrift + Bild
- if($l == 0){
- $y_position = $wms_y_position;
- $wms_y_position = '';
- }else{
- $y_position = $pdf->ezText("", 1, array('spacing'=>1.2));
- $layer_zeilenhoehe = $pdf->getFontHeight(11);
- $next_position = $y_position - $layer_zeilenhoehe - $imgsize[1];
- // add this to the height of the legend / addiere dies zur Gesamth�he Legende
- $l = $l+1;
- // if text + picture are smaler then the lower margin + textsize, then set a space
- //wenn Schrift + Bild kleiner der unteren Margin + Zeilenhoehe, dann Abstand setzen
- if($size == "A4" && $format == "portrait" && $next_position <= 35 +$layer_zeilenhoehe){ //90 $layer_zeilenhoehe
- $space = $layer_zeilenhoehe + $imgsize[1];
- $pdf->ezSetDy(-$space);
- if($size == "A4" && $format == "landscape" && $next_position <= 35+$layer_zeilenhoehe){//50
- //write the header layername / Ueberschrift schreiben
- $legend = $temp_layers[$q]."\n"; //$layer[$j]."\n";
- $pdf->ezText($legend, 11, array('spacing'=>1.2));
- //$pdf->ezText($url, 9, array('spacing'=>1.2));
- //print the picture / Bild schreiben
- $pdf->ezImage($legendFilename, 0, 'width', 'none', 'left');
- unlink($legendFilename);
- } //if legendurl
- }// for legendurl
- //frames (x1, y1, x2, y2)
- #line
- $pdf->setLineStyle($linewidth, '', '', array());
- //left
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height);
- //right
- //top
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
- //bottom
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
- if ($legendImage!=''){
- //image on top of page
- $pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border + $header_height - $legendImage_height - 4 , $legendImage_width, $legendImage_height);
- } else {
- //left
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border);
- //right
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
- //top
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
- //bottom
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border , $mapOffset_left - $border, $mapOffset_bottom - $border);
- $pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border - $legendImage_height -4 , $legendImage_width, $legendImage_height);
- //line under legend (only landscape)
- //$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 4 , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 6);
- }// for layers
- } //if wms_id not 0
- }// for wms
- * USER POLYGON:
- if($_REQUEST["measured_x_values"] != ""
- && $_REQUEST["measured_y_values"] != ""
- && is_file($legendFilenameUserPolygon)) {
- // load image
- $myY = $pdf->ezText("<b>temporary Object</b>", 11);
- $pdf->ezSetDy(-15);
- $pdf->ezImage($legendFilenameUserPolygon, 5, 17, 'none', 'left');
- unlink($legendFilenameUserPolygon);
- $pdf->ezSetY($myY - 7);
- $pdf->ezText("Element", 11, array("left" => 25));
- // deletes image
-$pdf->ezText($legendFooter, 11);
-}//legend true
- end of legend
-ob_clean();
-if($download == false){
- $pdf->ezStream();
-else{
- $content = $pdf->ezOutput();
- $fp = fopen($downloadFile,'w');
- fwrite($fp,$content);
- fclose($fp);
- echo "<html><head></head><body><a href='".$downloadFile."'>".$downloadText."</a></body></html>";
+<?php
+# $Id:
+# http://www.mapbender.org/index.php/mod_printPDF_pdf.php
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+include (dirname(__FILE__)."/../classes/class.ezpdf.php");
+include (dirname(__FILE__)."/../classes/class_stripRequest.php");
+include (dirname(__FILE__)."/../classes/class_weldMaps2PNG.php");
+include (dirname(__FILE__)."/../classes/class_weldOverview2PNG.php");
+include (dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
+include (dirname(__FILE__)."/../classes/class_SaveLegend.php");
+include (dirname(__FILE__)."/../print/print_functions.php");
+if($log == true){
+ include (dirname(__FILE__)."/../classes/class_log.php");
+#Globals
+$factor = intval($_REQUEST["quality"]);
+#$date = date("d.m.Y",strtotime("now"));
+$linewidth_dashed = 0.5;
+$linewidth = 0.5;
+// DURATION TIME:
+function microtime_float(){
+ list($usec, $sec) = explode(" ", microtime());
+ return ((float)$usec + (float)$sec);
+$time_start = microtime_float();
+// END DURATION TIME
+$time_end = microtime_float();
+$time = $time_end - $time_start;
+$size = $_REQUEST["size"];
+$format = $_REQUEST["format"];
+$map_scale = $_REQUEST["map_scale"];
+$overview_url = $_REQUEST["overview_url"];
+$epsg = $_REQUEST["epsg"];
+if($overview_url=='false'){
+ $overview = false;
+function setscalebar($scale){
+ $mb_resolution = 28.35;
+ if($scale < 16){
+ $value = "10";
+ $unit = "cm";
+ $scalefactor = 10/$scale;
+ $img_width = round($scalefactor * $mb_resolution);
+ if($scale >= 16 && $scale < 151){
+ $value = "1";
+ $unit = "Meter";
+ $scalefactor = 100/$scale;
+ if($scale >= 151 && $scale < 1550 ){
+ $value = "10";
+ $unit = "Meter";
+ $scalefactor = 1000/$scale;
+ if($scale >= 1550 && $scale < 15050){
+ $value = "100";
+ $unit = "Meter";
+ $scalefactor = 10000/$scale;
+ if($scale < 150050 && $scale >= 15050){
+ $value = "1";
+ $unit = "Kilometer";
+ $scalefactor = 100000/$scale;
+ if($scale < 1500050 && $scale >= 150050){
+ $value = "10";
+ $scalefactor = 1000000/$scale;
+ if($scale < 15000050 && $scale >= 1500050){
+ $value = "100";
+ $scalefactor = 10000000/$scale;
+ if($scale < 150000001 && $scale >= 15000001){
+ $value = "1000";
+ $scalefactor = 100000000/$scale;
+ if($scale >= 150000001){
+ $value = "1000";
+ $array_scale[0] = $unit;
+ $array_scale[1] = $img_width;
+ $array_scale[2] = $value;
+ return $array_scale;
+$border = 0.8 * $DPC;
+if($matching == true){
+ $urls = preg_replace($pattern,$replacement,$_REQUEST["map_url"]);
+else{
+ $urls = $_REQUEST["map_url"];
+$array_urls = explode("___", $urls);
+$myURL = new stripRequest($array_urls[0]);
+$map_width = round($myURL->get("width"));
+$map_height = round($myURL->get("height"));
+$map_extent = $myURL->get("BBOX");
+if($factor>1){
+ for($i=0; $i<count($array_urls); $i++){
+ $m = new stripRequest($array_urls[$i]);
+ $m->set('width',(intval($m->get('width'))*4));
+ $m->set('height',(intval($m->get('height'))*4));
+ if(in_array($m->get('map'),$highqualitymapfiles)){
+ $m->set('map',preg_replace("/\.map/","_4.map",$m->get('map')));
+ $array_urls[$i] = $m->url;
+$coord = mb_split(",",$map_extent);
+if($overview === true){
+ // analyse overview url and draw rectangle with position
+ $o_url = new stripRequest($overview_url);
+ $overview_width = round($o_url->get("width"));
+ $overview_height = round($o_url->get("height"));
+ if($factor>1){
+ $o_url->set('width',(intval($o_url->get('width'))*4));
+ $o_url->set('height',(intval($o_url->get('height'))*4));
+ if(in_array($o_url->get('map'),$highqualitymapfiles)){
+ $o_url->set('map',preg_replace("/\.map/","_4.map",$o_url->get('map')));
+ $overview_url = $o_url->url;
+ if($matching == true){
+ $overview_url = preg_replace($pattern,$replacement,$overview_url);
+ if ($size == "A4" && $format == "portrait"){
+ $overview_left = $a4p_overviewOffset_left;
+ $overview_bottom =$a4p_overviewOffset_bottom;
+ }elseif ($size == "A4" && $format == "landscape"){
+ $overview_left = $a4l_overviewOffset_left;
+ $overview_bottom =$a4l_overviewOffset_bottom;
+ }elseif ($size == "A3" && $format == "portrait"){
+ $overview_left = $a3p_overviewOffset_left;
+ $overview_bottom =$a3p_overviewOffset_bottom;
+ }elseif ($size == "A3" && $format == "landscape"){
+ $overview_left = $a3l_overviewOffset_left;
+ $overview_bottom = $a3l_overviewOffset_bottom;
+ }elseif ($size == "A2" && $format == "portrait"){
+ $overview_left = $a2p_overviewOffset_left;
+ $overview_bottom =$a2p_overviewOffset_bottom;
+ }elseif ($size == "A2" && $format == "landscape"){
+ $overview_left = $a2l_overviewOffset_left;
+ $overview_bottom = $a2l_overviewOffset_bottom;
+ }elseif ($size == "A1" && $format == "portrait"){
+ $overview_left = $a1p_overviewOffset_left;
+ $overview_bottom =$a1p_overviewOffset_bottom;
+ }elseif ($size == "A1" && $format == "landscape"){
+ $overview_left = $a1l_overviewOffset_left;
+ $overview_bottom = $a1l_overviewOffset_bottom;
+ }elseif ($size == "A0" && $format == "portrait"){
+ $overview_left = $a0p_overviewOffset_left;
+ $overview_bottom =$a0p_overviewOffset_bottom;
+ }elseif ($size == "A0" && $format == "landscape"){
+ $overview_left = $a0l_overviewOffset_left;
+ $overview_bottom = $a0l_overviewOffset_bottom;
+ $o_extent = $o_url->get("BBOX");
+ $array_overview_url[0] = $overview_url;
+ if($log == true){
+ $l = new log("printPDF_overview",$array_overview_url);
+ $o_new = new stripRequest($overview_url);
+ $o_new->set('width',50);
+ $o_new->set('height',50);
+ //$o->set('BBOX',$overview_extent);
+ $o_url_new =$o_new->url;
+ $array_overview[0] = $overview_url;
+ $array_overview[1] = $o_url;
+ * north arrow
+if($size == "A4" && $format == "portrait"){
+ $northarrow_left = $a4p_northarrow_left;
+ $northarrow_bottom = $a4p_northarrow_bottom;
+}elseif ($size == "A4" && $format == "landscape"){
+ $northarrow_left = $a4l_northarrow_left;
+ $northarrow_bottom = $a4l_northarrow_bottom;
+}elseif ($size == "A3" && $format == "portrait"){
+ $northarrow_left = $a3p_northarrow_left;
+ $northarrow_bottom = $a3p_northarrow_bottom;
+}elseif ($size == "A3" && $format == "landscape"){
+ $northarrow_left = $a3l_northarrow_left;
+ $northarrow_bottom = $a3l_northarrow_bottom;
+}elseif ($size == "A2" && $format == "portrait"){
+ $northarrow_left = $a2p_northarrow_left;
+ $northarrow_bottom = $a2p_northarrow_bottom;
+}elseif ($size == "A2" && $format == "landscape"){
+ $northarrow_left = $a2l_northarrow_left;
+ $northarrow_bottom = $a2l_northarrow_bottom;
+}elseif ($size == "A1" && $format == "portrait"){
+ $northarrow_left = $a1p_northarrow_left;
+ $northarrow_bottom = $a1p_northarrow_bottom;
+}elseif ($size == "A1" && $format == "landscape"){
+ $northarrow_left = $a1l_northarrow_left;
+ $northarrow_bottom = $a1l_northarrow_bottom;
+}elseif ($size == "A0" && $format == "portrait"){
+ $northarrow_left = $a0p_northarrow_left;
+ $northarrow_bottom = $a0p_northarrow_bottom;
+}elseif ($size == "A0" && $format == "landscape"){
+ $northarrow_left = $a0l_northarrow_left;
+ $northarrow_bottom = $a0l_northarrow_bottom;
+ * special image
+if ($size == "A4" && $format == "portrait"){
+ $specialImage_left = $a4p_special_left;
+ $specialImage_bottom = $a4p_special_bottom;
+ $specialImage_left = $a4l_special_left;
+ $specialImage_bottom = $a4l_special_bottom;
+ $specialImage_left = $a3p_special_left;
+ $specialImage_bottom = $a3p_special_bottom;
+ $specialImage_left = $a3l_special_left;
+ $specialImage_bottom = $a3l_special_bottom;
+ $specialImage_left = $a2p_special_left;
+ $specialImage_bottom = $a2p_special_bottom;
+ $specialImage_left = $a2l_special_left;
+ $specialImage_bottom = $a2l_special_bottom;
+ $specialImage_left = $a1p_special_left;
+ $specialImage_bottom = $a1p_special_bottom;
+ $specialImage_left = $a1l_special_left;
+ $specialImage_bottom = $a1l_special_bottom;
+ $specialImage_left = $a0p_special_left;
+ $specialImage_bottom = $a0p_special_bottom;
+ $specialImage_left = $a0l_special_left;
+ $specialImage_bottom = $a0l_special_bottom;
+if($log == true){
+ $l = new log("printPDF",$array_urls);
+$pdf = new Cezpdf();
+$pdf->Cezpdf(mb_strtolower($size),$format);
+$diff=array(196=>'Adieresis',228=>'adieresis',
+ 214=>'Odieresis',246=>'odieresis',
+ 220=>'Udieresis',252=>'udieresis',
+ 223=>'germandbls');
+$pdf->selectFont('../classes/fonts/Helvetica.afm', array('encoding'=>'WinAnsiEncoding','differences'=>$diff));
+ $mapOffset_left = $a4p_mapOffset_left;
+ $mapOffset_bottom = $a4p_mapOffset_bottom;
+ $header_height = $a4p_header_height;
+ $footer_height = $a4p_footer_height;
+else{
+ $mapOffset_left = $a4l_mapOffset_left;
+ $mapOffset_bottom = $a4l_mapOffset_bottom;
+ $header_height = $a4l_header_height;
+ $header_width = $a4l_header_width;
+session_write_close();
+$i = new weldMaps2PNG(implode("___",$array_urls),$filename);
+$pdf->addPngFromFile($filename, $mapOffset_left, $mapOffset_bottom, $map_width, $map_height);
+if($unlink == true){
+ unlink($filename);
+* user drawn elements
+$theMeasureConfigArray = array(
+ "do_fill" => FALSE,
+ "fill_color" => array(
+ "r" => 128 / 255,
+ "g" => 128 / 255,
+ "b" => 128 / 255
+ "do_stroke" => FALSE,
+ "stroke_color" => array(
+ "r" => 254 / 255,
+ "g" => 1 / 255,
+ "b" => 1 / 255
+ "line_style" => array(
+ "width" => 2,
+ "cap" => 'butt',
+ "join" => 'miter',
+ "dash" => array(10, 6)
+if ($_REQUEST["measured_x_values"]!=''){
+ addMeasuredItem($pdf, $_REQUEST["measured_x_values"], $_REQUEST["measured_y_values"], $theMeasureConfigArray);
+ hideElementsOutsideMapframe($pdf);
+# dashed line
+$pdf->setLineStyle($linewidth_dashed, '','', array(2,2));
+$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
+$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
+$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed);
+$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed);
+#line
+$pdf->setLineStyle($linewidth, '', '', array());
+$pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border);
+$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom -$border);
+$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border, $mapOffset_left - $border, $mapOffset_bottom - $border);
+if($epsg == "EPSG:4326"){
+ $text4 = "";
+ #header:
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height);
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height);
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+ $pdf->line( $mapOffset_left + $map_width/2, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width/2, $mapOffset_bottom + $map_height + $border + $header_height);
+ #header-text
+ $mySize = 9;
+ $length = $pdf->getTextWidth($mySize, $text1);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text1);
+ $mySize = 8;
+ $length = $pdf->getTextWidth($mySize, $text2);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 45,$mySize,$text2);
+ $length = $pdf->getTextWidth($mySize, $text3);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 35,$mySize,$text3);
+ $mySize = 9;
+ $length = $pdf->getTextWidth($mySize, $text4);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text4);
+ $mySize = 8;
+ $length = $pdf->getTextWidth($mySize, $text5);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text5);
+ $mySize = 9;
+ $length = $pdf->getTextWidth($mySize, $text6);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text6);
+ $length = $pdf->getTextWidth($mySize, $text7);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 50,$mySize,$text7);
+ $length = $pdf->getTextWidth($mySize, $text8);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 30,$mySize,$text8);
+ $length = $pdf->getTextWidth($mySize, $text9);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text9);
+ $length = $pdf->getTextWidth($mySize, $text10);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text10);
+ //special image on the map-page
+ if ($special == true){
+ $pdf->addPngFromFile($specialImage, $specialImage_left, $specialImage_bottom , $specialImage_width, $specialImage_height);
+ #footer
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
+ $mySize = 8;
+ $length = $pdf->getTextWidth($mySize, $text11);
+ $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 10,$mySize,$text11);
+ $mySize = 6;
+ $length = $pdf->getTextWidth($mySize, $text12);
+ $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 18,$mySize,$text12);
+ $length = $pdf->getTextWidth($mySize, $text13);
+ $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 25,$mySize,$text13);
+else{
+ $pdf->setColor(1,1,1);
+ $ll = array($mapOffset_left + $map_width - $header_width + $border - $linewidth, $mapOffset_bottom - $border + 1);
+ $pdf->filledRectangle($ll[0], $ll[1], $header_width,$header_height);
+ $pdf->line($ll[0], $ll[1], $ll[0], $ll[1] + $header_height);
+ $pdf->line($ll[0], $ll[1] + $header_height, $ll[0] + $header_width, $ll[1] + $header_height);
+ $pdf->line($ll[0] + 2, $ll[1] + 2, $ll[0] + 2, $ll[1] + $header_height - 2);
+ $pdf->line($ll[0] + 2, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + $header_height - 2);
+ $pdf->line($ll[0] - 2 + $header_width, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + 2);
+ $pdf->line($ll[0] - 2 + $header_width, $ll[1] + 2, $ll[0] + 2, $ll[1] + 2);
+ $pdf->line($ll[0] + 2, $ll[1] + 110 , $ll[0] - 2 + $header_width, $ll[1] + 110);
+ $pdf->line($ll[0] + 2, $ll[1] + 40 , $ll[0] - 2 + $header_width, $ll[1] + 40);
+ if($epsg == "EPSG:4326"){
+ $text4 = "";
+ $pdf->setColor(0,0,0);
+ $mySize = 9;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,185,$mySize,$text1);
+ $mySize = 8;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,175,$mySize,$text2);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,165,$mySize,$text3);
+ $mySize = 9;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,155,$mySize,$text4);
+ $mySize = 8;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,145,$mySize,$text5);
+ $mySize = 9;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,125,$mySize,$text6);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,115,$mySize,$text7);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,95,$mySize,$text8);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,85,$mySize,$text9);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,75,$mySize,$text10);
+ $mySize = 8;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,60,$mySize,$text11);
+ $mySize = 6;
+ $length = $pdf->getTextWidth($mySize, $text14);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,53,$mySize,$text14);
+ $length = $pdf->getTextWidth($mySize, $text15);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,47,$mySize,$text15);
+ $length = $pdf->getTextWidth($mySize, $text16);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,41,$mySize,$text16);
+ $length = $pdf->getTextWidth($mySize, $text17);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,35,$mySize,$text17);
+#Coordinates
+$myMinx = "R ".substr(round($coord[0]), 0, 4)." ".substr(round($coord[0]), 4, 3)."";
+$myMiny = "H ".substr(round($coord[1]), 0, 4)." ".substr(round($coord[1]), 4, 3)."";
+$myMaxx = "R ".substr(round($coord[2]), 0, 4)." ".substr(round($coord[2]), 4, 3)."";
+$myMaxy = "H ".substr(round($coord[3]), 0, 4)." ".substr(round($coord[3]), 4, 3)."";
+$mySize = 9;
+$pdf->addText($mapOffset_left - 3, $mapOffset_bottom, $mySize, $myMinx, -90);
+$pdf->addText($mapOffset_left, $mapOffset_bottom - ($pdf->getFontHeight($mySize)), $mySize, $myMiny);
+$pdf->addText($mapOffset_left + $map_width - ($pdf->getTextWidth($mySize, $myMaxx)), $mapOffset_bottom + $map_height + 3, $mySize, $myMaxx);
+$pdf->addText($mapOffset_left + $map_width + 3, $mapOffset_bottom + $map_height, $mySize, $myMaxy, 90);
+if ($overview==true){
+ // analyse request, draw rectancle
+ $filename = preg_replace("/map_/","overview_",$filename);
+ if($size == "A4" && $format == "portrait"){
+ $i = new weldOverview2PNG($overview_url,$array_urls[0] ,$filename);
+ $pdf->addPngFromFile($filename, $overview_left,$overview_bottom, $overview_width, $overview_height);
+ if($unlink == true){
+ else{
+ $i = new weldOverview2PNG($overview_url,$array_urls[0],$filename);
+ //$pdf->addPngFromFile($filename, $mapOffset_left,$mapOffset_bottom, $overview_width, $overview_height);
+if ($northarrow==true){
+ $pdf->addPngFromFile($northarrowImage, $northarrow_left, $northarrow_bottom , $northarrowImage_width, $northarrowImage_height);
+ $scalebar = false;
+if($scalebar == true){
+ $scalebar_left = $a4p_scalebar_left;
+ $scalebar_bottom = $a4p_scalebar_bottom;
+ $scalebar_left = $a4l_scalebar_left;
+ $scalebar_bottom = $a4l_scalebar_bottom;
+ $scalebar_left = $a3p_scalebar_left;
+ $scalebar_bottom = $a3p_scalebar_bottom;
+ $scalebar_left = $a3l_scalebar_left;
+ $scalebar_bottom = $a3l_scalebar_bottom;
+ $scalebar_left = $a2p_scalebar_left;
+ $scalebar_bottom = $a2p_scalebar_bottom;
+ $scalebar_left = $a2l_scalebar_left;
+ $scalebar_bottom = $a2l_scalebar_bottom;
+ $scalebar_left = $a1p_scalebar_left;
+ $scalebar_bottom = $a1p_scalebar_bottom;
+ $scalebar_left = $a1l_scalebar_left;
+ $scalebar_bottom = $a1l_scalebar_bottom;
+ $scalebar_left = $a0p_scalebar_left;
+ $scalebar_bottom = $a0p_scalebar_bottom;
+ $scalebar_left = $a0l_scalebar_left;
+ $scalebar_bottom = $a0l_scalebar_bottom;
+ $array_scalebar = setscalebar($map_scale);
+ $scalebar_left = $scalebar_left + $header_width/2 - $array_scalebar[1]/2;
+ $pdf->setLineStyle($scalebar_height, '','', array());
+ #$pdf->line($scalebar_left, $scalebar_bottom , $scalebar_left - 200 + $array_scalebar[1], $scalebar_bottom);
+ $pdf->filledRectangle($scalebar_left, $scalebar_bottom, $array_scalebar[1],$scalebar_height);
+ $pdf->filledRectangle($scalebar_left + $array_scalebar[1]/4 + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 1 ,$scalebar_height-2);
+ $pdf->filledRectangle($scalebar_left + 3*($array_scalebar[1]/4) + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 2 ,$scalebar_height-2);
+ #$pdf->setColor(1,0,1);
+ #$pdf->filledRectangle($scalebar_left , $scalebar_bottom - 20, 1 * $DPC ,$scalebar_height-2);
+ # value - Einheiten
+ $mySize = 8;
+ $scalebar_height_half = 0.5 * $scalebar_height;
+ $myText = 0;
+ $length = $pdf->getTextWidth($mySize, $myText);
+ $pdf->addText($scalebar_left - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
+ $myText = $array_scalebar[2]/2;
+ $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
+ $myText = $array_scalebar[2];
+ $pdf->addText($scalebar_left + $array_scalebar[1] - $length/2 - $length/4 ,$scalebar_bottom + 9 ,$mySize,$myText);
+ $mySize = 8;
+ $myText = $array_scalebar[0];
+ #$pdf->addText($scalebar_left + $scalebar_width + 5,$scalebar_bottom - $scalebar_height_half ,$mySize,$myText);
+ #units
+ $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom - 12 ,$mySize,$myText);
+ new page for legend
+if ($legend == true && $_REQUEST["mylegend"]=='true'){
+ $pdf->ezNewPage();
+ //Pageborder (top, bottom, left, right)
+ $pdf->ezSetMargins(50,50,80,30);
+ } else {
+ $pdf->ezSetMargins(60,35,60,60);
+ //Requests
+ if(CHARSET=="UTF-8"){
+ $new_wms_title=utf8_decode($_REQUEST["wms_title"]);
+ }else{
+ $new_wms_title=$_REQUEST["wms_title"];
+ $new_layers=utf8_decode($_REQUEST["layers"]);
+ }else{
+ $new_layers=$_REQUEST["layers"];
+ $my_wms_id = explode("___",$_REQUEST["wms_id"]);
+ $my_wms_title = explode("___",$new_wms_title);
+ $my_layers = explode("___",$new_layers);
+ $my_legend = preg_replace($pattern,$replacement,$_REQUEST["legendurl"]);
+ else{
+ $my_legend = $_REQUEST["legendurl"];
+ $my_legend = explode("___",$my_legend);
+ //columns
+ $pdf->ezColumnsStart(array ('num'=>2, 'gap'=>10));
+ } else {
+ $pdf->ezColumnsStart(array ('num'=>3, 'gap'=>10));
+ //header from printPDF.conf
+ //$pdf->ezText("<b>".$titel."</b>", 13);
+ $pdf->ezText("<b><u>".$legendText."</u></b>", 13);
+ //Seitenraender (top, bottom, left, right)
+ $pdf->ezSetMargins(70,35,80,30);
+ } else {
+ $pdf->ezSetMargins(100,35,60,60);
+ //generate the legend---------------------------------------------
+ // Gesamthoehe Legende / height of the legend
+ $sum_legend_height = 0;
+ for($i=0; $i<count($my_wms_id); $i++){
+ if ($my_wms_id[$i] != '0'){ //wms_id not 0
+ $layer = explode(",",$my_layers[$i]);
+ $my_legendurls = explode(",",$my_legend[$i]);
+ $wms_y_position = $pdf->ezText("<b>".$my_wms_title[$i]."</b>", 12, array('spacing'=>1.2));
+ $wms_zeilenhoehe = $pdf->getFontHeight(12);
+ // add this to the height of the legend /addiere dies zur Gesamthoehe Legende
+ $sum_legend_height += $wms_zeilenhoehe;
+ //Layer
+ $l = 0; #l temporary parameter to count the layer /Hilfvariable zum durchz�hlen der angezeigten Layer
+ for($j=0; $j<count($my_legendurls); $j++){
+ // url with grouped layers------------------
+ $temp_url = explode('*',$my_legendurls[$j]);
+ $temp_layers = explode('*',$layer[$j]);
+ for ($q=0; $q <count($temp_url);$q++){
+ if($temp_url[$q] == '1' ){ // Layertitle for the parent of grouped layers
+ // add this to the height of the legend /addiere dies zur Gesamth�he Legende
+ $layer_y_position = $pdf->ezText($temp_layers[$q], 11, array('spacing'=>1.2));
+ $layer_zeilenhoehe = $pdf->getFontHeight(12);
+ $sum_legend_height += $layer_zeilenhoehe;
+ }elseif($temp_url[$q] != '0' ){
+ $funktionsaufruf = new SaveLegend($temp_url[$q],$legendFilename);
+ $imgsize = getimagesize($legendFilename);
+ // add this to the height of the legend /addiere dies zur Gesamthoehe der Legende
+ $sum_legend_height += $imgsize[1];
+ //calculate text + picture / Berechnung Groesse Schrift + Bild
+ if($l == 0){
+ $y_position = $wms_y_position;
+ $wms_y_position = '';
+ }else{
+ $y_position = $pdf->ezText("", 1, array('spacing'=>1.2));
+ $layer_zeilenhoehe = $pdf->getFontHeight(11);
+ $next_position = $y_position - $layer_zeilenhoehe - $imgsize[1];
+ // add this to the height of the legend / addiere dies zur Gesamth�he Legende
+ $l = $l+1;
+ // if text + picture are smaler then the lower margin + textsize, then set a space
+ //wenn Schrift + Bild kleiner der unteren Margin + Zeilenhoehe, dann Abstand setzen
+ if($size == "A4" && $format == "portrait" && $next_position <= 35 +$layer_zeilenhoehe){ //90 $layer_zeilenhoehe
+ $space = $layer_zeilenhoehe + $imgsize[1];
+ $pdf->ezSetDy(-$space);
+ if($size == "A4" && $format == "landscape" && $next_position <= 35+$layer_zeilenhoehe){//50
+ //write the header layername / Ueberschrift schreiben
+ $legend = $temp_layers[$q]."\n"; //$layer[$j]."\n";
+ $pdf->ezText($legend, 11, array('spacing'=>1.2));
+ //$pdf->ezText($url, 9, array('spacing'=>1.2));
+ //print the picture / Bild schreiben
+ $pdf->ezImage($legendFilename, 0, 'width', 'none', 'left');
+ unlink($legendFilename);
+ } //if legendurl
+ }// for legendurl
+ //frames (x1, y1, x2, y2)
+ #line
+ $pdf->setLineStyle($linewidth, '', '', array());
+ //left
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height);
+ //right
+ //top
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
+ //bottom
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
+ if ($legendImage!=''){
+ //image on top of page
+ $pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border + $header_height - $legendImage_height - 4 , $legendImage_width, $legendImage_height);
+ } else {
+ //left
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border);
+ //right
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+ //top
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
+ //bottom
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border , $mapOffset_left - $border, $mapOffset_bottom - $border);
+ $pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border - $legendImage_height -4 , $legendImage_width, $legendImage_height);
+ //line under legend (only landscape)
+ //$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 4 , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 6);
+ }// for layers
+ } //if wms_id not 0
+ }// for wms
+ * USER POLYGON:
+ if($_REQUEST["measured_x_values"] != ""
+ && $_REQUEST["measured_y_values"] != ""
+ && is_file($legendFilenameUserPolygon)) {
+ // load image
+ $myY = $pdf->ezText("<b>temporary Object</b>", 11);
+ $pdf->ezSetDy(-15);
+ $pdf->ezImage($legendFilenameUserPolygon, 5, 17, 'none', 'left');
+ unlink($legendFilenameUserPolygon);
+ $pdf->ezSetY($myY - 7);
+ $pdf->ezText("Element", 11, array("left" => 25));
+ // deletes image
+$pdf->ezText($legendFooter, 11);
+}//legend true
+ end of legend
+ob_clean();
+if($download == false){
+ $pdf->ezStream();
+else{
+ $content = $pdf->ezOutput();
+ $fp = fopen($downloadFile,'w');
+ fwrite($fp,$content);
+ fclose($fp);
+ echo "<html><head></head><body><a href='".$downloadFile."'>".$downloadText."</a></body></html>";
More information about the Mapbender_commits
