[Mapbender-commits] r3227 - trunk/mapbender/http/classes
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Nov 12 03:53:01 EST 2008
Author: christoph
Date: 2008-11-12 03:53:01 -0500 (Wed, 12 Nov 2008)
New Revision: 3227
   trunk/mapbender/http/classes/class_administration.php
merged from noframes branch. I'm not sure if these functions are needed.
Modified: trunk/mapbender/http/classes/class_administration.php
--- trunk/mapbender/http/classes/class_administration.php	2008-11-12 08:52:12 UTC (rev 3226)
+++ trunk/mapbender/http/classes/class_administration.php	2008-11-12 08:53:01 UTC (rev 3227)
@@ -585,6 +585,83 @@
+	function getAllFilteredUsers($owner) {
+		$allUsers = array();
+		$sql = "SELECT mb_user_id,mb_user_name,mb_user_email FROM mb_user ";
+		$sql .= " WHERE mb_user_owner = $1 ORDER BY mb_user_name ";
+		$v = array($owner);
+		$t = array('i');
+		$res = db_prep_query($sql, $v, $t);
+		while ($row = db_fetch_array($res)) {
+			array_push($allUsers, array("mb_user_id" => $row["mb_user_id"], "mb_user_name" => $row["mb_user_name"], "mb_user_email" => $row["mb_user_email"]));
+		$json = new Mapbender_JSON();
+		$output = $json->encode($allUsers);
+		header("Content-type:text/plain; charset=utf-8");
+		return $output;
+	function getAllUserColumns($userId) {
+		$userArray = array();
+		$sql = "SELECT * FROM mb_user WHERE mb_user_id = $1";
+		$v = array($userId);
+		$t = array('s');
+		$res = db_prep_query($sql,$v,$t);
+			foreach ($row as $key => $value){
+				if (is_int($key)==false) {
+					array_push($userArray, array("id" => $key, "value" => $value));
+		$output = $json->encode($userArray);
+		return $output;
+	 * Returns an array of column names and fieldtype for a table.
+	function getTableColumns($table) {
+		$sql = "SELECT * FROM $table LIMIT 1";
+		$columnArray = array();
+		$v = array();
+		$t = array();
+		$i = 0;
+		while ($i < db_num_fields($res)) {
+			if(db_field_type($res, $i)=="varchar") {
+				$fieldType = "s";
+			else {
+				$fieldType = "i";
+			$columnArray[db_fieldname($res, $i)] = $fieldType;
+			$i++;
+		return $columnArray;
+	function deleteTableRecord($table,$keyField,$keyFieldValue) {
+		$sql = "DELETE FROM $table WHERE $keyField = $1";
+		$v = array($keyFieldValue);
+		$t = array('s');
+		if (!$res) {
+			return false;
+		else {
+			return true;
 	function getUserIdByUserName($username){
 		$sql = "SELECT mb_user_id FROM mb_user ";
 		$sql .= "WHERE mb_user_name = $1 GROUP BY mb_user_id";
More information about the Mapbender_commits mailing list
