[Mapbender-commits] r3063 - in trunk/build: . checksum
svn_mapbender at osgeo.org
Wed Oct 1 03:35:45 EDT 2008
Author: christoph
Date: 2008-10-01 03:35:44 -0400 (Wed, 01 Oct 2008)
New Revision: 3063
Added:
trunk/build/1_createMySqlDump.php
trunk/build/2_convertDataDumps.php
trunk/build/3_addHeaderToDataDumps.php
trunk/build/checksum/
trunk/build/checksum/build-checksum.php
trunk/build/checksum/checksum-utils.inc
trunk/build/checksum/commandLine.inc
trunk/build/commandLine.inc
trunk/build/test_utf8.sed
Added: trunk/build/1_createMySqlDump.php
--- trunk/build/1_createMySqlDump.php (rev 0)
+++ trunk/build/1_createMySqlDump.php 2008-10-01 07:35:44 UTC (rev 3063)
@@ -0,0 +1,65 @@
+<?php
+ require_once(dirname(__FILE__) . "/commandLine.inc");
+ $mpbnFolder = $_SERVER["argv"][1];
+ $fileArray = array(
+ "mysql" =>
+ array( "from" => dirname(__FILE__) . "/" . $mpbnFolder . "/resources/db/postgresql/utf8/pgsql_data.sql",
+ "to" => dirname(__FILE__) . "/" . $mpbnFolder . "/resources/db/mysql/utf8/mysql_data.sql")
+ function saveAsFile($filename, $data) {
+ if ($h = fopen($filename, "w")) {
+ if (!fwrite($h, $data)) {
+ return false;
+ fclose($h);
+ return true;
+ // load file
+ $from = $fileArray["mysql"]["from"];
+ $to = $fileArray["mysql"]["to"];
+ if (file_exists($from)) {
+ $data = file_get_contents($from);
+ else {
+ echo "Fatal error: File not found ('" . $from . "').\n";
+ exit(1);
+ // replace postgresql's string escape syntax
+ $pattern = "/, E'/";
+ $data = preg_replace($pattern, ", '", $data);
+ // disable foreign keys
+ $pattern = "/UPDATE pg_catalog\.pg_class SET reltriggers = 0;/";
+ if (preg_match($pattern, $data)) {
+ $data = preg_replace($pattern, "SET FOREIGN_KEY_CHECKS=0;", $data);
+ else {
+ echo "Fatal error: Didn't find expression (pattern: " . $pattern . ").\n";
+ exit(1);
+ // enable foreign keys
+ $pattern = "/UPDATE pg_catalog\.pg_class SET reltriggers = \(SELECT pg_catalog\.count\(\*\) FROM pg_catalog\.pg_trigger where pg_class\.oid = tgrelid\);/";
+ $data = preg_replace($pattern, "SET FOREIGN_KEY_CHECKS=1;", $data);
+ else {
+ exit(1);
+ // save mysql file
+ if (!saveAsFile($to, $data)) {
+ echo "Fatal error: File could not be saved ('" . $to . "').\n";
+ exit(1);
+ echo "Finished.\n\n";
+ exit(0);
\ No newline at end of file
Added: trunk/build/2_convertDataDumps.php
--- trunk/build/2_convertDataDumps.php (rev 0)
+++ trunk/build/2_convertDataDumps.php 2008-10-01 07:35:44 UTC (rev 3063)
@@ -0,0 +1,48 @@
+<?php
+ // needs to be set, otherwise the iconv option //TRANSLIT
+ // won't work
+ setlocale(LC_CTYPE, "de_DE.utf8");
+ "mysql" =>
+ array( "from" => dirname(__FILE__) . "/" . $mpbnFolder . "/resources/db/mysql/utf8/mysql_data.sql",
+ "to" => dirname(__FILE__) . "/" . $mpbnFolder . "/resources/db/mysql/iso/mysql_data.sql"),
+ "pgsql" =>
+ "to" => dirname(__FILE__) . "/" . $mpbnFolder . "/resources/db/postgresql/iso/pgsql_data.sql")
+ return false;
+ fclose($h);
+ return true;
+ foreach ($fileArray as $file) {
+ $from = $file["from"];
+ $to = $file["to"];
+ else {
+ $dataConverted = iconv("UTF-8", "ASCII//TRANSLIT", $data);
+ if (!saveAsFile($to, $dataConverted)) {
Added: trunk/build/3_addHeaderToDataDumps.php
--- trunk/build/3_addHeaderToDataDumps.php (rev 0)
+++ trunk/build/3_addHeaderToDataDumps.php 2008-10-01 07:35:44 UTC (rev 3063)
@@ -0,0 +1,64 @@
+<?php
+ if (!file_exists(dirname(__FILE__) . "/" . $mpbnFolder . "/core/system.php")) {
+ echo "File not found: " . dirname(__FILE__) . "/" . $mpbnFolder . "/core/system.php";
+ exit(1);
+ else {
+ require_once(dirname(__FILE__) . "/" . $mpbnFolder . "/core/system.php");
+ setlocale(LC_TIME, "de_DE.utf8");
+ "mysql" =>
+ array( "iso" => dirname(__FILE__) . "/" . $mpbnFolder . "/resources/db/mysql/iso/mysql_data.sql",
+ "utf8" => dirname(__FILE__) . "/" . $mpbnFolder . "/resources/db/mysql/utf8/mysql_data.sql"),
+ "postgresql" =>
+ array( "iso" => dirname(__FILE__) . "/" . $mpbnFolder . "/resources/db/postgresql/iso/pgsql_data.sql",
+ "utf8" => dirname(__FILE__) . "/" . $mpbnFolder . "/resources/db/postgresql/utf8/pgsql_data.sql")
+ return false;
+ fclose($h);
+ return true;
+ foreach ($fileArray as $dbType => $files) {
+ foreach ($files as $characterSet => $file) {
+ if (file_exists($file)) {
+ $data = file_get_contents($file);
+ else {
+ echo "Fatal error: File not found ('" . $file . "').\n";
+ exit(1);
+ // add header to file
+ $header = "--\n" .
+ "-- " . $dbType . " " . $characterSet . " data dump\n" .
+ "-- \n" .
+ "-- Mapbender " . MB_VERSION_NUMBER . " " . MB_VERSION_APPENDIX . "\n" .
+ "-- \n" .
+ "-- " . date("Y/m/d", MB_RELEASE_DATE) . "\n" .
+ "--\n\n";
+ $data = $header . $data;
+ if (!saveAsFile($file, $data)) {
+ echo "Fatal error: File could not be saved ('" . $file . "').\n";
+ exit(1);
+ exit(0);
Added: trunk/build/checksum/build-checksum.php
--- trunk/build/checksum/build-checksum.php (rev 0)
+++ trunk/build/checksum/build-checksum.php 2008-10-01 07:35:44 UTC (rev 3063)
@@ -0,0 +1,70 @@
+<?php
+#build-checksum.php
+#@author Siddharth Prakash Singh (spsneo)
+#Google SoC 2008 Project
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+# Update Script
+# To be executed from command line only.
+#check whether this file is being executed from command line or not
+#abort if it is not being executed from command line
+require_once("commandLine.inc");
+#This file is required
+require_once("checksum-utils.inc");
+#These are the directories which are not to be scanned and checksum not to be evaluated as these
+#directories are prone to change and always include "." and ".." in this list.
+$dir_not_to_scan = array();
+array_push($dir_not_to_scan,".", "..", "license", "log");
+$rootdir_path = dirname(__FILE__) . "/../" . $_SERVER["argv"][1] . "/";
+//remove slash if it is there at the end of the path
+if(substr($rootdir_path, -1) == '/') {
+ $rootdir_path = substr($rootdir_path, 0 , -1);
+#check whether this is a valid directory
+if(!is_dir($rootdir_path)) {
+ echo $rootdir_path." is not a valid directory\n";
+ return FALSE;
+#check whether this directory is readable
+if(!is_readable($rootdir_path)) {
+ echo $rootdir_path." is not readable.\nPlease make sure you have privilege to build.\nAborting...";
+ exit();
+#initialize the directory
+$rootdir = dir($rootdir_path);
+$rootdir_path = $rootdir->path;
+while(false !== ($dir_to_scan = $rootdir->read())) {
+ $dir_to_scan_path = $rootdir_path.'/'.$dir_to_scan;
+ #directories to scan, hidden directories excluded
+ if(is_dir($dir_to_scan_path) && !in_array($dir_to_scan, $dir_not_to_scan) && !preg_match("/^\./", $dir_to_scan)) {
+ echo "Scanning directory: ".$dir_to_scan_path."\n";
+ build_checksum($dir_to_scan_path);
+ echo "All checksums and respective JSON files created for all the files and directories inside ".$dir_to_scan_path."\n\n";
+echo "\n\nDone!\n\n";
Added: trunk/build/checksum/checksum-utils.inc
--- trunk/build/checksum/checksum-utils.inc (rev 0)
+++ trunk/build/checksum/checksum-utils.inc 2008-10-01 07:35:44 UTC (rev 3063)
@@ -0,0 +1,72 @@
+<?php
+#Author: Siddharth Prakash Singh(spsneo)
+#Google Summer Of Code Project 2008
+# Copyright (C) 2002 CCGIS
+function build_checksum($dir_path) {
+ #This array holds the file-name and sha1 checksum for the files in the current directory
+ $file_arr = array();
+ //remove slash if it is there at the end of the path
+ if(substr($dir_path, -1) == '/') {
+ $dir_path = substr($dir_path, 0 , -1);
+ if(!is_dir($dir_path)) {
+ echo $dir_path." is not a valid directory\n";
+ return FALSE;
+ if(!is_readable($dir_path)) {
+ echo $dir_path." is not readable.\nPlease make sure you have privilege to build.\nAborting...\n";
+ exit();
+ $directory = dir($dir_path);
+ while(false !== ($file = $directory->read())) {
+ $file_path = $dir_path.'/'.$file;
+ if(is_file($file_path) && $file != 'checksum.json' && !preg_match("/~$/", $file) && !preg_match("/^\./", $file)) {
+ if(is_readable($file_path)) {
+ $file_arr[$file] = sha1_file($file_path);
+ } else {
+ echo $file_path." is not readable.\nPlease make sure you have privelege to build.\nAborting...\n";
+ exit();
+ } else if (is_dir($file_path) && !preg_match("/^\./", $file)) {
+ if($file != '.' && $file != '..' ) {
+ //echo "Scanning directory: ".$file_path."\n";
+ build_checksum($file_path);
+ } else {
+ $file_json_string = json_encode($file_arr);
+ $file_json_name = $dir_path."/checksum.json";
+ $file_json_handle = fopen($file_json_name, "w");
+ if(!file_json_handle) {
+ echo "Error creating file checksum.json\nPlease execute this script again.\nAborting...\n ";
+ exit();
+ fwrite($file_json_handle, $file_json_string);
+ fclose($file_json_handle);
+ //echo "Succesfully created checksums of files in directory: ".$dir_path."\n";
+ return TRUE;
Added: trunk/build/checksum/commandLine.inc
--- trunk/build/checksum/commandLine.inc (rev 0)
+++ trunk/build/checksum/commandLine.inc 2008-10-01 07:35:44 UTC (rev 3063)
@@ -0,0 +1,39 @@
+<?php
+#Mapbender Updater File
+# This file tests whether the update script has been called from command line or browser.
+# Aborts the update process if called from a web browser
+if ( isset( $_SERVER ) && array_key_exists( 'REQUEST_METHOD', $_SERVER ) ) {
+ echo "This script must be executed from the command line ";
+ exit();
+if(PHP_SAPI != 'cli') {
+echo "This script must be executed from the command line.";
+exit();
+#Set the execution time to infinity
+ at set_time_limit( 0 );
Added: trunk/build/commandLine.inc
--- trunk/build/commandLine.inc (rev 0)
+++ trunk/build/commandLine.inc 2008-10-01 07:35:44 UTC (rev 3063)
@@ -0,0 +1,39 @@
+<?php
+ exit();
+exit();
Added: trunk/build/test_utf8.sed
--- trunk/build/test_utf8.sed (rev 0)
+++ trunk/build/test_utf8.sed 2008-10-01 07:35:44 UTC (rev 3063)
@@ -0,0 +1,20 @@
+s/ß/ss/g;
+s/ä/ae/g;
+s/ü/ue/g;
+s/ö/oe/g;
+s/Ä/Ae/g;
+s/Å‚/l/g;
+s/ó/o/g;
+s/ÃÂÂÂ/i/g;
+s/é/e/g;
+s/é/e/g;
+s/A?AE'A,A-/i/g;
+s/á/a/g;
+s/ú/u/g;
+s/á/a/g;
+s/ñ/n/g;
+s/ú/u/g;
+s/ó/o/g;
+s/ÃÂÂ/i/g;
+s/ñ/n/g;
+s/ü/ue/g;
More information about the Mapbender_commits
