[Mapbender-commits] r3100 - in branches/noframes: conf core
http/classes http/javascripts http/php http/print http/tools
svn_mapbender at osgeo.org
Fri Oct 3 04:42:59 EDT 2008
Author: christoph
Date: 2008-10-03 04:42:59 -0400 (Fri, 03 Oct 2008)
New Revision: 3100
Removed:
branches/noframes/http/javascripts/wfs_usemap.js
branches/noframes/conf/wfs_additional_spatial_search.conf
branches/noframes/conf/wfs_default.conf
branches/noframes/core/globalSettings.php
branches/noframes/http/classes/class_administration.php
branches/noframes/http/classes/class_bbox.php
branches/noframes/http/classes/class_kml_line.php
branches/noframes/http/classes/class_kml_linearring.php
branches/noframes/http/classes/class_kml_ows.php
branches/noframes/http/classes/class_kml_parser_ows.php
branches/noframes/http/classes/class_kml_placemark.php
branches/noframes/http/classes/class_kml_point.php
branches/noframes/http/classes/class_locale.php
branches/noframes/http/classes/class_point.php
branches/noframes/http/classes/class_wfs.php
branches/noframes/http/classes/class_wfs_conf.php
branches/noframes/http/javascripts/geometry.js
branches/noframes/http/javascripts/mod_highlightPOI.php
branches/noframes/http/javascripts/mod_savewmc.php
branches/noframes/http/javascripts/mod_wfs_SpatialRequest.php
branches/noframes/http/javascripts/mod_wfs_gazetteer_client.php
branches/noframes/http/javascripts/wfs.js
branches/noframes/http/php/mod_forgottenPassword.php
branches/noframes/http/php/mod_meetingPoint.php
branches/noframes/http/print/mod_printPDF.php
branches/noframes/http/print/mod_printPDF_pdf.php
branches/noframes/http/tools/mod_monitorCapabilities_read.php
merged w/ trunk
Modified: branches/noframes/conf/wfs_additional_spatial_search.conf
--- branches/noframes/conf/wfs_additional_spatial_search.conf 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/conf/wfs_additional_spatial_search.conf 2008-10-03 08:42:59 UTC (rev 3100)
@@ -12,6 +12,8 @@
var buttonPoint = {"status":1, "img":"select_point_off.png","title":"Punktauswahl"};
var buttonExtent = {"status":1,"img":"select_extent_off.png","title":"Auswahl Kartenrahmen"};
+var mb_wfs_tolerance = 8;
var spatialRequestIsSetMessage = "Gebiet eingegrenzt, bitte OK klicken!";
var clearFilterButtonLabel = "Neu";
Modified: branches/noframes/conf/wfs_default.conf
--- branches/noframes/conf/wfs_default.conf 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/conf/wfs_default.conf 2008-10-03 08:42:59 UTC (rev 3100)
@@ -14,6 +14,8 @@
var buttonExtent = {"status":1, "x":840, "y":10, "img":"select_extent_off.png"};
var buttonDialogue = {"status":1, "x":870, "y":10, "img":"select_choose_off.png"};
var buttonWfs_imgdir = "../img/button_gray/";
var buttonWfs_zIndex = 10;
Modified: branches/noframes/core/globalSettings.php
--- branches/noframes/core/globalSettings.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/core/globalSettings.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -63,4 +63,9 @@
$con = db_connect($DBSERVER, $OWNER, $PW);
db_select_db(DB, $con);
+// Do not display PHP errors
+ini_set("display_errors", "0");
Modified: branches/noframes/http/classes/class_administration.php
--- branches/noframes/http/classes/class_administration.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_administration.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -585,6 +585,83 @@
+ function getAllFilteredUsers($owner) {
+ $allUsers = array();
+ $sql = "SELECT mb_user_id,mb_user_name,mb_user_email FROM mb_user ";
+ $sql .= " WHERE mb_user_owner = $1 ORDER BY mb_user_name ";
+ $v = array($owner);
+ $t = array('i');
+ $res = db_prep_query($sql, $v, $t);
+ while ($row = db_fetch_array($res)) {
+ array_push($allUsers, array("mb_user_id" => $row["mb_user_id"], "mb_user_name" => $row["mb_user_name"], "mb_user_email" => $row["mb_user_email"]));
+ $json = new Mapbender_JSON();
+ $output = $json->encode($allUsers);
+ header("Content-type:text/plain; charset=utf-8");
+ return $output;
+ function getAllUserColumns($userId) {
+ $userArray = array();
+ $sql = "SELECT * FROM mb_user WHERE mb_user_id = $1";
+ $v = array($userId);
+ $t = array('s');
+ $res = db_prep_query($sql,$v,$t);
+ foreach ($row as $key => $value){
+ if (is_int($key)==false) {
+ array_push($userArray, array("id" => $key, "value" => $value));
+ $output = $json->encode($userArray);
+ return $output;
+ * Returns an array of column names and fieldtype for a table.
+ function getTableColumns($table) {
+ $sql = "SELECT * FROM $table LIMIT 1";
+ $columnArray = array();
+ $v = array();
+ $t = array();
+ $i = 0;
+ while ($i < db_num_fields($res)) {
+ if(db_field_type($res, $i)=="varchar") {
+ $fieldType = "s";
+ else {
+ $fieldType = "i";
+ $columnArray[db_fieldname($res, $i)] = $fieldType;
+ $i++;
+ return $columnArray;
+ function deleteTableRecord($table,$keyField,$keyFieldValue) {
+ $sql = "DELETE FROM $table WHERE $keyField = $1";
+ $v = array($keyFieldValue);
+ $t = array('s');
+ if (!$res) {
+ return false;
+ else {
+ return true;
function getUserIdByUserName($username){
$sql = "SELECT mb_user_id FROM mb_user ";
$sql .= "WHERE mb_user_name = $1 GROUP BY mb_user_id";
Modified: branches/noframes/http/classes/class_bbox.php
--- branches/noframes/http/classes/class_bbox.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_bbox.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -18,6 +18,7 @@
# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+require_once(dirname(__FILE__)."/class_point.php");
* A bounding box consisting of an lower left and an upper right point, and an EPSG.
Modified: branches/noframes/http/classes/class_kml_line.php
--- branches/noframes/http/classes/class_kml_line.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_kml_line.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -44,34 +44,32 @@
if (preg_match("/,/", $pointArray[$i])) {
$aPoint = explode(",", $pointArray[$i]);
- # ignore altitude
// KML only supperts EPSG 4326, so
// the coordinates are transformed
- $pt = new Mapbender_point($aPoint[0], $aPoint[1], $epsg);
+ $pt = new Mapbender_point($aPoint[0], $aPoint[1], $aPoint[2], $epsg);
if (isset($epsg) && $epsg != 4326) {
$pt->transform(4326);
- $point = array("x" => $pt->x, "y" => $pt->y);
+ $point = array("x" => $pt->x, "y" => $pt->y, "z" => $pt->z);
array_push($this->pointArray, $point);
else {
$pointArray = explode(" ", $geometryString);
- for ($i=0; $i < count($pointArray); $i+=2) {
+ for ($i=0; $i < count($pointArray); $i+=3) {
# Some KMLs have a lot of whitespaces; this "if" is an
# ugly hack to prevent adding empty points
if ($pointArray[$i] && $pointArray[$i+1]) {
- # ignore altitude
- $pt = new Mapbender_point($pointArray[$i], $pointArray[$i+1], $epsg);
+ $pt = new Mapbender_point($pointArray[$i], $pointArray[$i+1], $pointArray[$i+2], $epsg);
@@ -96,7 +94,12 @@
if ($i > 0) {
$str .= ",";
- $str .= "[".$this->pointArray[$i]["x"].",".$this->pointArray[$i]["y"]."]";
+ if ($this->pointArray[$i]["z"]) {
+ $str .= "[".$this->pointArray[$i]["x"].",".$this->pointArray[$i]["y"].",".$this->pointArray[$i]["z"]."]";
+ else {
+ $str .= "[".$this->pointArray[$i]["x"].",".$this->pointArray[$i]["y"]."]";
return "{\"type\": \"LineString\", \"coordinates\":[" . $str . "]}";
@@ -106,7 +109,7 @@
- * @return array an array of points as associative array, coordinates as ["x"] and ["y"]
+ * @return array an array of points as associative array, coordinates as ["x"] and ["y"] and ["z"]
public function getPointArray () {
return $this->pointArray;
@@ -114,7 +117,7 @@
* An array of points, with a point being an associative
- * array consisting of attributes "x" and "y".
+ * array consisting of attributes "x" and "y" and "z"
protected $pointArray = array();
Modified: branches/noframes/http/classes/class_kml_linearring.php
--- branches/noframes/http/classes/class_kml_linearring.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_kml_linearring.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -42,7 +42,12 @@
if ($i > 0) {
$str .= ",";
+ else {
return "[" . $str . "]";
Modified: branches/noframes/http/classes/class_kml_ows.php
--- branches/noframes/http/classes/class_kml_ows.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_kml_ows.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -45,6 +45,114 @@
public function __construct() {
+ public function toSingleLineStringKml() {
+ //KML 2.2 output
+ $doc = new DOMDocument("1.0", CHARSET);
+ $doc->preserveWhiteSpace = false;
+ // attach kml and Document tag
+ $e_kml = $doc->createElementNS("http://earth.google.com/kml/2.2", "kml");
+ $e_document = $doc->createElement("Document");
+ $e_kml->appendChild($e_document);
+ $doc->appendChild($e_kml);
+ // attach placemarks
+ $e = new mb_notice("to string: #placemarks: " . count($this->placemarkArray));
+ $lineStyleNode = $doc->createElement("Style");
+ $lineStyleNode->setAttribute("id", "linestyleExample");
+ $lineStyleColorNode = $doc->createElement("color", "7f0000ff");
+ $lineStyleWidthNode = $doc->createElement("width", 4);
+ $lineStyleNode->appendChild($lineStyleColorNode);
+ $lineStyleNode->appendChild($lineStyleWidthNode);
+ $e_document->appendChild($lineStyleNode);
+ // line segments first
+ $coordinates = "";
+ for ($i = 0; $i < count($this->placemarkArray); $i++) {
+ $currentPlacemark = $this->placemarkArray[$i];
+ $e = new mb_notice("now: " . $i . " of " . (count($this->placemarkArray)-1) . " (is a " . get_class($currentPlacemark) . ")");
+ switch ($currentPlacemark->getGeometryType()) {
+ case "KMLLine" :
+ $coordinatesArray = $currentPlacemark->getGeometry()->getPointArray();
+ for ($j = 0; $j < count($coordinatesArray); $j++) {
+ if (!($j == 0 && $i == 0)) {
+ $coordinates .= " ";
+ $coordinates .= $coordinatesArray[$j]["x"] . "," . $coordinatesArray[$j]["y"] . "," . $coordinatesArray[$j]["z"];
+ break;
+ // create a placemark tag with a geometry and add it to the document
+ $e_coordinates = $doc->createElement("coordinates", $coordinates);
+ $e_geometry = $doc->createElement("LineString");
+ $e_geometry->appendChild($e_coordinates);
+ $e_placemark = $doc->createElement("Placemark");
+ $e_placemark->appendChild($e_geometry);
+ $e_pl_name = $doc->createElement("name", "Route");
+ $e_placemark->appendChild($e_pl_name);
+ $e_pl_style = $doc->createElement("styleUrl", "#linestyleExample");
+ $e_placemark->appendChild($e_pl_style);
+ $e_document->appendChild($e_placemark);
+ // now pois
+ $pl_instructions = $currentPlacemark->getProperty("instruction");
+ $pl_name_array = array();
+ $pl_name = false;
+ $pl_description = false;
+ if ($pl_instructions != null) {
+ $pl_name_array = explode("|", $pl_instructions);
+ case "KMLPoint" :
+ if (count($pl_name_array) > 2) {
+ $pl_name = $pl_name_array[0];
+ $pl_description = $pl_name_array[1];
+ $e_geometry = $doc->createElement("Point");
+ $point = $currentPlacemark->getGeometry()->getPoint();
+ $coordinates = $point["x"] . "," . $point["y"];
+ break;
+ if ($e_geometry) {
+ if ($pl_name) {
+ $e_pl_name = $doc->createElement("name", $pl_name);
+ if ($pl_description) {
+ $e_pl_description = $doc->createElement("description", $pl_description);
+ $e_placemark->appendChild($e_pl_description);
+ return $doc->saveXML();
* @return string the KML document.
@@ -69,9 +177,20 @@
+ $pl_name = false;
case "KMLPoint" :
@@ -100,6 +219,9 @@
break;
case "KMLLine" :
$coordinates = "";
@@ -107,7 +229,7 @@
if ($j > 0) {
- $coordinates .= $coordinatesArray[$j]["x"] . "," . $coordinatesArray[$j]["y"] . ",0";
@@ -123,6 +245,14 @@
if ($e_geometry) {
+ if ($pl_name) {
@@ -300,23 +430,29 @@
* @return boolean true, if the KML could be stored in the database; else false.
private function storeInDb () {
- $con = db_connect(DBSERVER,OWNER,PW);
- db_select_db(DB,$con);
- $sql = "INSERT INTO gui_kml ";
- $sql .= "(fkey_mb_user_id, fkey_gui_id, kml_doc, kml_name, kml_description, kml_timestamp) ";
- $sql .= "VALUES ";
- $sql .= "($1, $2, $3, $4, $5, $6)";
- $v = array ($_SESSION["mb_user_id"], $_SESSION["mb_user_gui"], $this->kml, "name", "description", time());
- $t = array ("i", "s", "s", "s", "s", "s");
- $res = db_prep_query($sql, $v, $t);
- if (!$res) {
- $e = new mb_exception("class_kml.php: storeInDb: failed to store KML in database: " . db_error());
- return false;
+ if ($_SESSION["mb_user_id"] && $_SESSION["mb_user_gui"]) {
+ $con = db_connect(DBSERVER,OWNER,PW);
+ db_select_db(DB,$con);
+ $sql = "INSERT INTO gui_kml ";
+ $sql .= "(fkey_mb_user_id, fkey_gui_id, kml_doc, kml_name, kml_description, kml_timestamp) ";
+ $sql .= "VALUES ";
+ $sql .= "($1, $2, $3, $4, $5, $6)";
+ $v = array ($_SESSION["mb_user_id"], $_SESSION["mb_user_gui"], $this->kml, "name", "description", time());
+ $t = array ("i", "s", "s", "s", "s", "s");
+ if (!$res) {
+ $e = new mb_exception("class_kml.php: storeInDb: failed to store KML in database: " . db_error());
+ return false;
+ $this->id = db_insert_id($con, "gui_kml", "kml_id");
+ return true;
- $this->id = db_insert_id($con, "gui_kml", "kml_id");
- return true;
+ else {
+ // should be false, but code in caller has to be changed first.
+ return true;
Modified: branches/noframes/http/classes/class_kml_parser_ows.php
--- branches/noframes/http/classes/class_kml_parser_ows.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_kml_parser_ows.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -44,6 +44,9 @@
$id = 0;
if (gettype($geometryFromGeoJSON) == "object" && $geometryFromGeoJSON->type == "FeatureCollection") {
+ if ($geometryFromGeoJSON->crs->type == "EPSG" && $geometryFromGeoJSON->crs->properties->code) {
+ $epsg = $geometryFromGeoJSON->crs->properties->code;
// create Placemarks
for ($i = 0; $i < count($geometryFromGeoJSON->features); $i++) {
$e = new mb_notice("parsing plm #" . $i . "...length of placemarkArray: " . count($this->placemarkArray));
@@ -52,7 +55,9 @@
if ($feature->geometry->crs->type == "EPSG") {
$epsg = $feature->geometry->crs->properties->code;
- $e = new mb_notice("EPSG: " . $epsg);
+ if (!$epsg) {
+ $e = new mb_notice("EPSG is not set! Aborting...(" . $epsg . ")");
$geometry = $feature->geometry;
$currentGeometry = false;
Modified: branches/noframes/http/classes/class_kml_placemark.php
--- branches/noframes/http/classes/class_kml_placemark.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_kml_placemark.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -54,7 +54,7 @@
* @return mixed the property value; if none exists, null.
public function getProperty ($key) {
- if (array_key_exists($key)) {
+ if (array_key_exists($key, $this->properties)) {
return $this->properties[$key];
$e = new mb_exception("class_kml_placemark.php: getProperty: no value for key '" . $key . "'");
Modified: branches/noframes/http/classes/class_kml_point.php
--- branches/noframes/http/classes/class_kml_point.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_kml_point.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -41,12 +41,12 @@
if (preg_match("/,/", $geometryString)) {
$aPoint = explode(",", $geometryString);
// ignore altitude
else {
$aPoint = explode(" ", $geometryString);
// ignore altitude
@@ -54,7 +54,7 @@
- $this->point = array("x" => $pt->x, "y" => $pt->y);
+ $this->point = array("x" => $pt->x, "y" => $pt->y, "z" => $pt->z);
@@ -69,7 +69,12 @@
public function toGeoJSON () {
if ($this->point !== null) {
- return "{\"type\": \"Point\", \"coordinates\": [".$this->point["x"].",".$this->point["y"]."]}";
+ if ($this->point["z"]) {
+ return "{\"type\": \"Point\", \"coordinates\": [".$this->point["x"].",".$this->point["y"].",".$this->point["z"]."]}";
+ else {
+ return "{\"type\": \"Point\", \"coordinates\": [".$this->point["x"].",".$this->point["y"]."]}";
$e = new mb_exception("KMLPoint: toGeoJSON: this point is null.");
@@ -77,14 +82,14 @@
- * @return array a point as associative array, coordinates as ["x"] and ["y"]
+ * @return array a point as associative array, coordinates as ["x"] and ["y"] and ["z"]
public function getPoint () {
return $this->point;
- * @var float[] an associative array, with "x", and "y" being float values.
+ * @var float[] an associative array, with "x", and "y" and "z" being float values.
private $point;
Modified: branches/noframes/http/classes/class_locale.php
--- branches/noframes/http/classes/class_locale.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_locale.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -1,216 +1,218 @@
-<?php
-# $Id$
-# http://www.mapbender.org/index.php/class_locale.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
-require_once(dirname(__FILE__)."/../../core/globalSettings.php");
- * sets the locale, depending on various settings:
- * 1) a language ID passed to the constructor
- * 2) the browser settings $_SERVER["HTTP_ACCEPT_LANGUAGE"]
- * 3) a default language ID
-class Mb_locale {
- var $knownLanguages = null;
- var $systemLocales = null;
- var $browserLanguages = null;
- var $os = null;
- var $name = null;
- var $defaultLanguage = "en";
- var $status = "No locale set.";
- function Mb_locale($languageId) {
- if (!$languageId) {
- $languageId = LANGUAGE;
- $e = new Mb_notice("class_locale: setting locale to " . $languageId);
- if (USE_I18N) {
- if (!$this->setCurrentLocale($languageId)) {
- $e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
- else {
- $this->setCurrentLocale($this->defaultLanguage);
- * Get the current locale, evaluating GET/POST variables, browser languages
- * and a default locale (in that preference)
- * @returns current locale
- function setCurrentLocale($languageId) {
- // try to set the locale to $languageId
- if ($this->checkAndSetLocale($languageId)) {
- return true;
- else {
- $e = new Mb_notice("class_locale: no input parameter specified.");
- // determine the browser setting and try to set locale according to that
- if ($this->browserLanguage == null) {
- $this->setBrowserLanguages();
- foreach ($this->browserLanguages as $lang) {
- $e = new Mb_notice("trying browser setting " . $lang);
- if ($this->checkAndSetLocale($lang)) {
- return true;
- // set to default language
- $e = new Mb_notice("trying default language " . $this->defaultLanguage);
- return $this->checkAndSetLocale($this->defaultLanguage);
- * checks if a locale is available; if yes, it is set via setlocale
- * @returns true if the the locale is set successfully; otherwise false
- function checkAndSetLocale($languageId) {
- if ($this->os == null) {
- $this->os = $this->guessHostOS();
- if (!USE_I18N || ($this->os != null && isset($languageId))) {
- if ($this->isKnownLanguage($languageId)) {
- if ($this->systemLocales == null) {
- $this->setSystemLocales();
- $locale = $this->systemLocales[$this->knownLanguages[$languageId]][$this->os];
- $selectedLocale = setlocale(LC_MESSAGES, $locale);
- if ($selectedLocale) {
- $this->name = $selectedLocale;
- $_SESSION["mb_lang"] = $languageId;
- $_SESSION["mb_locale"] = $this->name;
- $e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
- // from http://de3.php.net/manual/de/function.gettext.php
- $path = bindtextdomain("Mapbender", dirname(__FILE__)."/../../resources/locale/");
- $enc = bind_textdomain_codeset("Mapbender", "UTF-8");
- $dom = textdomain("Mapbender");
- return true;
- $e = new Mb_notice("locale " . $locale . " not found.");
- return false;
- * Guess the operating system which on which this code is running
- * multiple methods are tested for reliably guessing the os
- * @private
- * @returns string with os name
- function guessHostOS(){
- if (strncasecmp(php_uname(), 'Windows', 7) == 0)
- return 'windows';
- else if (strncasecmp(php_uname(), 'Linux', 5) == 0)
- return 'linux';
- else if (strncasecmp(php_uname(), 'OpenBSD', 7) == 0)
- return 'bsd';
- else if (strncasecmp(php_uname(), 'FreeBSD', 7) == 0)
- return 'bsd';
- else {
- $e = new mb_exception('unknown platform: could not interpret uname. php_uname() returned '. php_uname().'. Please report to MB developers');
- return null;
- * checks if a language is supported
- * @returns true if the language is supported; otherwise false
- function isKnownLanguage($languageId) {
- if ($this->knownLocales == null) {
- $this->setKnownLanguages();
- if (array_key_exists($languageId, $this->knownLanguages)) {
- return true;
- else {
- $e = new Mb_notice("language " . $languageId . " not supported.");
- return false;
- * determines the available Locales on this system
- function setSystemLocales() {
- $this->systemLocales['it_IT'] = array('linux' => 'it_IT.utf8',
- 'windows' => 'Italian_Italy.1252',
- 'bsd' => 'it_IT',
- 'posix' => 'it_IT');
- $this->systemLocales['de_DE'] = array('linux' => 'de_DE.utf8',
- 'windows' => 'German_Germany.1252',
- 'bsd' => 'de_DE',
- $this->systemLocales['en_US'] = array('linux' => 'en_US.utf8',
- 'windows' => 'English_United States.1252',
- 'bsd' => 'en_US',
- * set the known languages
- function setKnownLanguages() {
- $this->knownLanguages = array('en_US' => 'en_US',
- 'en' => 'en_US',
- 'de_DE' => 'de_DE',
- 'de' => 'de_DE',
- 'bg_BG' => 'bg_BG',
- 'bg' => 'bg_BG',
- 'es_ES' => 'es_ES',
- 'es' => 'es_ES',
- 'nl_NL' => 'nl_NL',
- 'nl' => 'nl_NL',
- 'gr_GR' => 'gr_GR',
- 'gr' => 'gr_GR',
- 'it_IT' => 'it_IT',
- 'it' => 'it_IT');
- * sets the languages accepted by the client browser
- function setBrowserLanguages () {
- $this->browserLanguages = array();
- $bLangs = split(',', $_SERVER["HTTP_ACCEPT_LANGUAGE"]);
- foreach ($bLangs as $lang) {
- if (strpos($lang, ';') === false)
- array_push($this->browserLanguages, $lang);
- else
- array_push($this->browserLanguages, substr($lang, 0, strpos($lang, ';')));
+<?php
+# $Id$
+# http://www.mapbender.org/index.php/class_locale.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+ * sets the locale, depending on various settings:
+ * 1) a language ID passed to the constructor
+ * 2) the browser settings $_SERVER["HTTP_ACCEPT_LANGUAGE"]
+ * 3) a default language ID
+class Mb_locale {
+ var $knownLanguages = null;
+ var $systemLocales = null;
+ var $browserLanguages = null;
+ var $os = null;
+ var $name = null;
+ var $defaultLanguage = "en";
+ var $status = "No locale set.";
+ function Mb_locale($languageId) {
+ if (!$languageId) {
+ $languageId = LANGUAGE;
+ $e = new Mb_notice("class_locale: setting locale to " . $languageId);
+ if (USE_I18N) {
+ if (!$this->setCurrentLocale($languageId)) {
+ $e = new Mb_exception("Locale could not be set. Language ID: '" . $languageId . "'");
+ else {
+ $this->setCurrentLocale($this->defaultLanguage);
+ * Get the current locale, evaluating GET/POST variables, browser languages
+ * and a default locale (in that preference)
+ * @returns current locale
+ function setCurrentLocale($languageId) {
+ // try to set the locale to $languageId
+ if ($this->checkAndSetLocale($languageId)) {
+ return true;
+ else {
+ $e = new Mb_notice("class_locale: no input parameter specified.");
+ // determine the browser setting and try to set locale according to that
+ if ($this->browserLanguage == null) {
+ $this->setBrowserLanguages();
+ foreach ($this->browserLanguages as $lang) {
+ $e = new Mb_notice("trying browser setting " . $lang);
+ if ($this->checkAndSetLocale($lang)) {
+ return true;
+ // set to default language
+ $e = new Mb_notice("trying default language " . $this->defaultLanguage);
+ return $this->checkAndSetLocale($this->defaultLanguage);
+ * checks if a locale is available; if yes, it is set via setlocale
+ * @returns true if the the locale is set successfully; otherwise false
+ function checkAndSetLocale($languageId) {
+ if ($this->os == null) {
+ $this->os = $this->guessHostOS();
+ if (!USE_I18N || ($this->os != null && isset($languageId))) {
+ if ($this->isKnownLanguage($languageId)) {
+ if ($this->systemLocales == null) {
+ $this->setSystemLocales();
+ $locale = $this->systemLocales[$this->knownLanguages[$languageId]][$this->os];
+ $selectedLocale = setlocale(LC_MESSAGES, $locale);
+ if ($selectedLocale) {
+ $this->name = $selectedLocale;
+ $_SESSION["mb_lang"] = $languageId;
+ $_SESSION["mb_locale"] = $this->name;
+ $e = new Mb_notice("locale " . $this->name . " ok on " . $this->os);
+ // from http://de3.php.net/manual/de/function.gettext.php
+ $path = bindtextdomain("Mapbender", dirname(__FILE__)."/../../resources/locale/");
+ $enc = bind_textdomain_codeset("Mapbender", "UTF-8");
+ $dom = textdomain("Mapbender");
+ return true;
+ $e = new Mb_notice("locale " . $locale . " not found.");
+ return false;
+ * Guess the operating system which on which this code is running
+ * multiple methods are tested for reliably guessing the os
+ * @private
+ * @returns string with os name
+ function guessHostOS(){
+ if (strncasecmp(php_uname(), 'Windows', 7) == 0)
+ return 'windows';
+ else if (strncasecmp(php_uname(), 'Linux', 5) == 0)
+ return 'linux';
+ else if (strncasecmp(php_uname(), 'OpenBSD', 7) == 0)
+ return 'bsd';
+ else if (strncasecmp(php_uname(), 'FreeBSD', 7) == 0)
+ return 'bsd';
+ else {
+ throw new Mb_exception('unknown platform: could not interpret uname. php_uname() returned '. php_uname().'. Please report to MB developers');
+ return null;
+ * checks if a language is supported
+ * @returns true if the language is supported; otherwise false
+ function isKnownLanguage($languageId) {
+ if ($this->knownLocales == null) {
+ $this->setKnownLanguages();
+ if (array_key_exists($languageId, $this->knownLanguages)) {
+ return true;
+ else {
+ $e = new Mb_notice("language " . $languageId . " not supported.");
+ return false;
+ * determines the available Locales on this system
+ function setSystemLocales() {
+ $this->systemLocales['it_IT'] = array('linux' => 'it_IT.utf8',
+ 'windows' => 'Italian_Italy.1252',
+ 'bsd' => 'it_IT',
+ 'posix' => 'it_IT');
+ $this->systemLocales['de_DE'] = array('linux' => 'de_DE.utf8',
+ 'windows' => 'German_Germany.1252',
+ 'bsd' => 'de_DE',
+ 'posix' => 'de_DE');
+ $this->systemLocales['en_US'] = array('linux' => 'en_US.utf8',
+ 'windows' => 'English_United States.1252',
+ 'bsd' => 'en_US',
+ 'posix' => 'en_US');
+ * set the known languages
+ function setKnownLanguages() {
+ $this->knownLanguages = array('en_US' => 'en_US',
+ 'en' => 'en_US',
+ 'de_DE' => 'de_DE',
+ 'de' => 'de_DE',
+ 'bg_BG' => 'bg_BG',
+ 'bg' => 'bg_BG',
+ 'es_ES' => 'es_ES',
+ 'es' => 'es_ES',
+ 'nl_NL' => 'nl_NL',
+ 'nl' => 'nl_NL',
+ 'fr_FR' => 'fr_FR',
+ 'fr' => 'fr_FR',
+ 'gr_GR' => 'gr_GR',
+ 'gr' => 'gr_GR',
+ 'it_IT' => 'it_IT',
+ 'it' => 'it_IT');
+ * sets the languages accepted by the client browser
+ function setBrowserLanguages () {
+ $this->browserLanguages = array();
+ $bLangs = split(',', $_SERVER["HTTP_ACCEPT_LANGUAGE"]);
+ foreach ($bLangs as $lang) {
+ if (strpos($lang, ';') === false)
+ array_push($this->browserLanguages, $lang);
+ else
+ array_push($this->browserLanguages, substr($lang, 0, strpos($lang, ';')));
\ No newline at end of file
Modified: branches/noframes/http/classes/class_point.php
--- branches/noframes/http/classes/class_point.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_point.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -20,22 +20,30 @@
- * A Mapbender_point is a 2-dimensional point with an EPSG.
+ * A Mapbender_point is a 2- or 3-dimensional point with an EPSG.
class Mapbender_point {
var $x;
var $y;
+ var $z;
var $epsg;
* @constructor
- function __construct($x, $y, $epsg) {
- if (!$x || !$y || !$epsg) {
- $e = new mb_exception("Mapbender_point: constructor: some parameters are not set (set (x: ".$x.", y: ".$y.", epsg:".$epsg.")!");
+ function __construct($x, $y, $z, $epsg) {
+ // may be called without $z; so $epsg is the third parameter, $z
+ if (isset($x) && isset($y) && isset($z) && !isset($epsg)) {
+ $e = new mb_notice("Mapbender_point: constructor: probably 2d call (x: ".$x.", y: ".$y.", z: ".$z.", epsg:".$epsg.")!");
+ $epsg = $z;
+ $z = false;
+ if (!isset($x) || !isset($y) || !isset($epsg)) {
+ $e = new mb_exception("Mapbender_point: constructor: some parameters are not set (set (x: ".$x.", y: ".$y.", z: ".$z.", epsg:".$epsg.")!");
$this->x = $x;
$this->y = $y;
+ $this->z = $z;
$this->epsg = $epsg;
@@ -136,11 +144,20 @@
$currentEpsg = preg_replace("/EPSG:/", "", $this->epsg);
$targetEpsg = preg_replace("/EPSG:/", "", $toEpsg);
$sql = "SELECT X(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as x, ";
- $sql .= "Y(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as y";
+ $sql .= "Y(transform(GeometryFromText('POINT(".$this->x." ".$this->y.")',".$currentEpsg."),".$targetEpsg.")) as y, ";
+ if (isset($this->z)) {
+ $sql .= "Z(transform(GeometryFromText('POINT(".$this->x." ".$this->y." ".$this->z.")',".$currentEpsg."),".$targetEpsg.")) as z";
$res = db_query($sql);
- $point = new Mapbender_point(db_result($res,0,"x"), db_result($res,0,"y"), $toEpsg);
+ $point = new Mapbender_point(db_result($res,0,"x"), db_result($res,0,"y"), db_result($res,0,"z"), $toEpsg);
+ else {
+ $point = new Mapbender_point(db_result($res,0,"x"), db_result($res,0,"y"), $toEpsg);
$this->x = $point->x;
$this->y = $point->y;
+ $this->z = $point->z;
$this->epsg = $point->epsg;
else {
@@ -169,7 +186,7 @@
function __toString() {
- return (string) "(" . $this->x . "," . $this->y . "," . $this->epsg . ")";
+ return (string) "(" . $this->x . "," . $this->y . "," . $this->z . "," . $this->epsg . ")";
Modified: branches/noframes/http/classes/class_wfs.php
--- branches/noframes/http/classes/class_wfs.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_wfs.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -22,8 +22,8 @@
-require_once(dirname(__FILE__)."/class_connector.php");
-require_once(dirname(__FILE__)."/class_administration.php");
+require_once(dirname(__FILE__)."/class_connector.php");
+require_once(dirname(__FILE__)."/class_administration.php");
class wfs {
@@ -64,7 +64,7 @@
$values = null;
$tags = null;
$admin = new administration();
- $this->wfs_getcapabilities_doc = $admin->char_encode($data);
+ $this->wfs_getcapabilities_doc = $admin->char_encode($data);
$this->wfs_upload_url = $url;
# for temporary wfs a id has to be created...
@@ -75,7 +75,7 @@
xml_parser_set_option($parser,XML_OPTION_TARGET_ENCODING,CHARSET);
xml_parse_into_struct($parser,$this->wfs_getcapabilities_doc,$values,$tags);
//xml_parse_into_struct($parser,$data,$values,$tags);
xml_parser_free($parser);
$section = false;
@@ -115,7 +115,7 @@
if(strtoupper($element[tag]) == "GETCAPABILITIES" && $element[type] == "open"){
$section = "getcapabilities";
- if($section == "getcapabilities" && strtoupper($element[tag]) == "GET"){
+ if($section == "getcapabilities" && strtoupper($element[tag]) == "POST"){
$this->wfs_getcapabilities = $element[attributes][onlineResource];
@@ -126,7 +126,7 @@
- if($section == "describefeaturetype" && strtoupper($element[tag]) == "GET"){
+ if($section == "describefeaturetype" && strtoupper($element[tag]) == "POST"){
$this->wfs_describefeaturetype = $element[attributes][onlineResource];
@@ -134,7 +134,7 @@
if(strtoupper($element[tag]) == "GETFEATURE" && $element[type] == "open"){
$section = "getfeature";
- if($section == "getfeature" && strtoupper($element[tag]) == "GET"){
+ if($section == "getfeature" && strtoupper($element[tag]) == "POST"){
$this->wfs_getfeature = $element[attributes][onlineResource];
if(strtoupper($element[tag]) == "GETFEATURE" && $element[type] == "close"){
@@ -144,7 +144,7 @@
if(strtoupper($element[tag]) == "TRANSACTION" && $element[type] == "open"){
$section = "transaction";
- if($section == "transaction" && strtoupper($element[tag]) == "GET"){
+ if($section == "transaction" && strtoupper($element[tag]) == "POST"){
$this->wfs_transaction = $element[attributes][onlineResource];
if(strtoupper($element[tag]) == "TRANSACTION" && $element[type] == "close"){
@@ -195,7 +195,7 @@
function addFeaturetype($name,$title,$abstract,$srs,$url,$version){
$this->wfs_featuretype[count($this->wfs_featuretype)] = new featuretype($name,$title,$abstract,$srs,$url,$version);
function stripEndlineAndCarriageReturn($string) {
return preg_replace("/\n/", "", preg_replace("/\r/", " ", $string));
@@ -565,7 +565,7 @@
@@ -576,7 +576,7 @@
@@ -584,7 +584,7 @@
@@ -594,7 +594,7 @@
@@ -808,4 +808,4 @@
Modified: branches/noframes/http/classes/class_wfs_conf.php
--- branches/noframes/http/classes/class_wfs_conf.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/classes/class_wfs_conf.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -93,27 +93,19 @@
* @param $idArray Array an array of integer values representing WFS conf IDs.
private static function getWfsConfFromDbByArray ($idArray) {
- $sql = "SELECT * FROM wfs_conf ";
- $sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
- $sql .= "WHERE wfs_conf.wfs_conf_id IN (";
- $v = array();
- $t = array();
- for ($i = 0; $i < count($idArray); $i++) {
- if ($i > 0) {$sql .= ", ";}
- $sql .= "$" . ($i+1);
- array_push($v, $idArray[$i]);
- array_push($t, 'i');
- $sql .= ")";
$rowArray = array();
- while ($row = db_fetch_array($res)) {
- array_push($rowArray, $row);
- return $rowArray;
+ foreach ($idArray as $id) {
+ $sql = "SELECT * FROM wfs_conf ";
+ $sql .= "JOIN wfs ON wfs_conf.fkey_wfs_id = wfs.wfs_id ";
+ $sql .= "WHERE wfs_conf.wfs_conf_id = $1 LIMIT 1";
+ $v = array($id);
+ $t = array("i");
+ $row = db_fetch_array($res);
+ array_push($rowArray, $row);
+ return $rowArray;
Modified: branches/noframes/http/javascripts/geometry.js
--- branches/noframes/http/javascripts/geometry.js 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/javascripts/geometry.js 2008-10-03 08:42:59 UTC (rev 3100)
@@ -231,7 +231,7 @@
var q = this.get(0).get(0).get(0);
var min = cloneObject(q);
var max = cloneObject(q);
- for(var i=0; i<this.count();i++){
+ for(var i=0; i < this.count();i++){
var pos = this.get(i).getBBox();
if (pos[0].x < min.x) {min.x = pos[0].x;}
if (pos[1].x > max.x) {max.x = pos[1].x;}
@@ -363,7 +363,7 @@
this.addMember(geomType.point);
this.get(-1).addGeometry();
- this.getGeometry(-1,-1).addPointByCoordinates(coordinates[0], coordinates[1]);
+ this.getGeometry(-1,-1).addPointByCoordinates(coordinates[0], coordinates[1], coordinates[2]);
this.getGeometry(-1,-1).setEpsg(featureEpsg);
this.close();
break;
@@ -376,7 +376,7 @@
for (var m = 0; m < coordinates.length; m++) {
var currentPoint = coordinates[m];
- this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0], currentPoint[1]);
+ this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0], currentPoint[1], currentPoint[2]);
this.close();
@@ -392,7 +392,7 @@
var currentLine = coordinates[m];
for (var n = 0; n < currentLine.length; n++) {
var currentPoint = currentLine[n];
@@ -409,7 +409,7 @@
var currentPolygon = coordinates[m];
for (var n = 0; n < currentPolygon.length; n++) {
var currentPoint = currentPolygon[n];
@@ -426,7 +426,7 @@
@@ -1395,7 +1395,7 @@
var diameter = 8;
var minWidth = 8;
- var lineWidth = aLineWidth;
+ var lineWidth = aLineWidth || 2;
var mapframe = aMapframe;
var mapObjInd = getMapObjIndexByName(mapframe);
var mapframeWidth = mb_mapObj[mapObjInd].width;
@@ -1861,7 +1861,7 @@
for (attr in a) {
var b = a[attr];
if (typeof(b) == "object") {z += objString(b);}
- else {z += attr + " " + b + "\n";alert(attr + " " + b);}
+ else {z += attr + " " + b + "\n";}
return z;
Modified: branches/noframes/http/javascripts/mod_highlightPOI.php
--- branches/noframes/http/javascripts/mod_highlightPOI.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/javascripts/mod_highlightPOI.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -67,14 +67,14 @@
function mod_highlightPOI_init(){
var myPOI = "<?php if (CHARSET == 'UTF-8'){
- echo utf8_encode($_SESSION['mb_myPOI']);
+ echo preg_replace("/\n/", "<br>", $_SESSION['mb_myPOI']);
}else{
- echo $_SESSION['mb_myPOI'];
+ echo preg_replace("/\n/", "<br>", utf8_decode($_SESSION['mb_myPOI']));
if(myPOI != ""){
- mod_highlightPOI_params = myPOI.split(",");
+ mod_highlightPOI_params = myPOI.split("|");
Modified: branches/noframes/http/javascripts/mod_savewmc.php
--- branches/noframes/http/javascripts/mod_savewmc.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/javascripts/mod_savewmc.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -36,7 +36,10 @@
try {if (saveInSession) {}}catch(e) {saveInSession = 0;}
if (saveInSession == 1) {
- mb_registerInitFunctions('setOnUnload()');
+ eventAfterMapRequest.register(function () {
+ mod_savewmc_session();
+// mb_registerInitFunctions('setOnUnload()');
<?php
Modified: branches/noframes/http/javascripts/mod_wfs_SpatialRequest.php
--- branches/noframes/http/javascripts/mod_wfs_SpatialRequest.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/javascripts/mod_wfs_SpatialRequest.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -60,7 +60,6 @@
var button_rectangle = "rectangle";
var button_extent = "extent";
var button_dialogue = "dialogue";
-var mb_wfs_tolerance = 8;
var activeButton = null;
var mod_wfs_spatialRequest_geometry = null;
@@ -576,7 +575,7 @@
var mapPosYRemovePix = mapPos[1] - buffer;
var realWorld1 = makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYRemovePix);
var realWorld2 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
- var realWorld3 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYAddPix);
+ var realWorld3 = makeClickPos2RealWorldPos("mapframe1",mapPosXAddPix,mapPosYRemovePix);
var realWorld4 = makeClickPos2RealWorldPos("mapframe1",mapPosXRemovePix,mapPosYAddPix);
for(var i=0; i<js_wfs_conf_id.length; i++){
var srs = wfs_config[js_wfs_conf_id[i]]['featuretype_srs'];
@@ -782,4 +781,4 @@
if(wfsResultToPopupDiv==1){
mb_registerWfsReadSubFunctions(function(geom){displayPopup(geom);});
Modified: branches/noframes/http/javascripts/mod_wfs_gazetteer_client.php
--- branches/noframes/http/javascripts/mod_wfs_gazetteer_client.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/javascripts/mod_wfs_gazetteer_client.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -84,7 +84,6 @@
var button_polygon = "polygon";
Modified: branches/noframes/http/javascripts/wfs.js
--- branches/noframes/http/javascripts/wfs.js 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/javascripts/wfs.js 2008-10-03 08:42:59 UTC (rev 3100)
@@ -1,33 +1,166 @@
-<?php
-#$Id$
-#$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_wfs_spatialRequest.php,v 1.4 2006/03/08 15:26:26 c_baudson Exp $
-# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+// --- usemap (begin) --------------------------------------------------------------------------------------------
-session_start();
-import_request_variables("PG");
-require_once(dirname(__FILE__) . "/../php/mb_validateSession.php");
-require_once(dirname(__FILE__) . "/../../conf/mapbender.conf");
-$con = db_connect(DBSERVER,OWNER,PW);
-db_select_db(DB,$con);
+function mod_usemap(wfs_name) {
+ if (wfs_name == "") {
+ usemap = "";
+ var ind = getMapObjIndexByName(mb_wfs_target);
+ var myImg = window.frames[mb_wfs_target].document.getElementById("um_img").style;
+ myImg.width = mb_mapObj[ind].width;
+ myImg.height = mb_mapObj[ind].height;
-$e_id_css = "wfs";
-include '../include/dyn_js.php';
-require_once(dirname(__FILE__) . "/wfs_usemap.js");
+ for (var i = 0 ; i < mb_wfs_fetch.count() ; i ++) {
+ if (mb_wfs_fetch.get(i).wfs_conf == wfs_name || wfs_name == "") {
+ if (mb_wfs_fetch.get(i).geomType == geomType.polygon) {
+ usemap += mod_usemap_polygon(i);
+ else if (mb_wfs_fetch.get(i).geomType == geomType.point) {
+ usemap += mod_usemap_circle(i);
+ else if (mb_wfs_fetch.get(i).geomType == geomType.line) {
+ usemap += mod_usemap_line(i);
+ writeUsemap(usemap);
+function mod_usemap_circle(ind){
+ var str = "";
+ var coord = "";
+ var title = "";
+ for (var i = 0 ; i < mb_wfs_fetch.get(ind).e.count(); i++) {
+ if (i>0) title += " ";
+ title += mb_wfs_fetch.get(ind).e.getName(i) + ": " + mb_wfs_fetch.get(ind).e.getValue(i);
+ for (var i = 0 ; i < mb_wfs_fetch.get(ind).count() ; i ++) {
+ var p = mb_wfs_fetch.getPoint(ind, i, 0);
+ var pos = realToMap(mb_wfs_target,p);
+ coord += pos.x + ", " + pos.y;
+ str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
+ str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='circle' coords='";
+ str += coord + ", " + mod_usemap_radius + "' href='#'>";
+ return str;
+function mod_usemap_line_calculate (aGeometry, j, orientation, cnt) {
+ var coord = "";
+ var p1 = realToMap(mb_wfs_targets[0],aGeometry.get(j));
+ var p2 = realToMap(mb_wfs_targets[0],aGeometry.get(j+orientation));
+ var vec = p2.minus(p1);
+ if (vec.x != 0 || vec.y != 0) {
+ var n_vec;
+ if (vec.x != 0) {
+ if (vec.x > 0) n_vec = new Point((-vec.y)/vec.x, -1);
+ else n_vec = new Point(vec.y/vec.x, 1);
+ else {
+ if (vec.y > 0) n_vec = new Point(1,0);
+ else n_vec = new Point(-1,0);
+ n_vec = n_vec.times(mod_usemap_line_tolerance).dividedBy(n_vec.dist(new Point(0,0)))
+ lp = new Point(p1.x + n_vec.x, p1.y - n_vec.y);
+ if (cnt > 0) coord += ", ";
+ coord += parseInt(lp.x) + ", " + parseInt(lp.y);
+ coord += ", " + parseInt(lp.x+vec.x) + ", " + parseInt(lp.y+vec.y);
+ return coord;
+function mod_usemap_line(ind){
+ var str = "";
+ var title = "";
+ var coord = "";
+ var cnt = 0;
+ for (var j = 0 ; j < mb_wfs_fetch.getGeometry(ind,i).count() - 1 ; j ++) {
+ var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, 1, cnt);
+ if (result != "") {
+ coord += result;
+ cnt++;
+ for (var j = (mb_wfs_fetch.getGeometry(ind,i).count() - 1) ; j > 0 ; j--) {
+ var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, -1, cnt);
+ coord += result;
+ cnt++;
+ if (coord != "") {
+ str += "<AREA title='"+title+"'";
+ str += "onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
+ str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' ";
+ str += "shape='poly' coords='";
+ str += coord + "' href='#'>";
+ else {
+ //display circle
+ var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind,i,0));
+ str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
+ return str;
+function mod_usemap_polygon(ind){
+ var str = "";
+ var coord = "";
+ var title = "";
+ var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, 0));
+ for (var j = 1 ; j < mb_wfs_fetch.getGeometry(ind,i).count() ; j ++) {
+ pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, j));
+ coord += ", " + pos.x + ", " + pos.y;
+ str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='poly' coords='";
+ return str;
+function writeUsemap(str) {
+ writeTag(mb_wfs_targets[0], 'um', str);
+// --- usemap (end) ----------------------------------------------------------------------------------------------
var highlight_tag_id = "wfs_highlight_tag";
var mb_wfs_fetched = [];
@@ -86,14 +219,14 @@
var ind = getMapObjIndexByName(mb_wfs_targets[0]);
var pos_a = makeClickPos2RealWorldPos(mb_wfs_targets[0],0,0);
var pos_b = makeClickPos2RealWorldPos(mb_wfs_targets[0],mb_mapObj[ind].width,mb_mapObj[ind].height);
var x = [];
var y = [];
x[0] = pos_a[0];
x[1] = pos_b[0];
y[0] = pos_a[1];
y[1] = pos_b[1];
mb_setwfsrequest(mb_wfs_targets[0],'rectangle',x,y);
@@ -133,7 +266,7 @@
function mb_wfs_reset(){
mb_wfs_fetch = new parent.GeometryArray();
usemap = "";
if(mb_wfs_objwin == null){
var iframe=document.createElement('div');
iframe.setAttribute("style","position:absolute;left:"+mb_wfs_objwin_left+"px;top:"+mb_wfs_objwin_top+"px;width:"+mb_wfs_objwin_width+"px;height:"+mb_wfs_objwin_height+"px");
@@ -183,7 +316,7 @@
highlight.del(m, '#ff0000');
highlight.paint();
- else
+ else
if (type == 'click') {
var tmp = m.getBBox();
if (m.geomType == geomType.point) {
@@ -205,17 +338,17 @@
function get_wfs_str(myconf, d, m, type, fid) {
- <!-- Getting the Namspace for the FeautureType -->
+ <!-- Getting the Namspace for the FeautureType -->
var featureTypeArray = myconf['featuretype_name'].split(':')
var featureNS = featureTypeArray[0];
var str = '<wfs:Transaction version="1.0.0" service="WFS" ';
var ns_gml = false; var ns_ogc = false; var ns_xsi = false; var ns_wfs = false; var ns_featureNS = false;
for (var q = 0 ; q < myconf['namespaces'].length ; q++) {
- if (myconf['namespaces'][q]['name'] == "gml"){
+ if (myconf['namespaces'][q]['name'] == "gml"){
ns_gml = true;
str += 'xmlns:' + myconf['namespaces'][q]['name'] + '="' + myconf['namespaces'][q]['location'] + '" ';
} else if (myconf['namespaces'][q]['name'] == "ogc") {
@@ -233,13 +366,13 @@
strForSchemaLocation = myconf['namespaces'][q]['location'];
if (ns_gml == false) str += 'xmlns:gml="http://www.opengis.net/gml" ';
if (ns_ogc == false) str += 'xmlns:ogc="http://www.opengis.net/ogc" ';
if (ns_xsi == false) str += 'xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" ';
if (ns_featureNS == false) str += 'xmlns:"+featureNS+"="http://www.someserver.com/"+featureNS+"" ';
if (ns_wfs == false) str += 'xmlns:wfs="http://www.opengis.net/wfs" ';
str += 'xsi:schemaLocation="http://www.opengis.net/wfs';
str += ' http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd';
str += ' ' + strForSchemaLocation;
@@ -261,24 +394,24 @@
for(var j=0; j<myconf['element'].length; j++){
if(myconf['element'][j]['f_geom'] == 1){
- var el_geom = myconf['element'][j]['element_name'];
+ var el_geom = myconf['element'][j]['element_name'];
- str += '<' + el_geom + '>';
+ str += '<' + el_geom + '>';
if(d.get(m).geomType == geomType.point){
str += '<gml:Point srsName="' + myconf['featuretype_srs'] + '">';
str += '<gml:coordinates>';
- str += d.getPoint(m,0,0).x + "," + d.getPoint(m,0,0).y;
+ str += d.getPoint(m,0,0).x + "," + d.getPoint(m,0,0).y;
str += '</gml:coordinates>';
- str += '</gml:Point>';
+ str += '</gml:Point>';
if(d.get(m).geomType == geomType.line){
str += '<gml:MultiLineString srsName="' + myconf['featuretype_srs'] + '">';
str += '<gml:lineStringMember><gml:LineString><gml:coordinates>';
for(var k=0; k<d.getGeometry(m,0).count(); k++){
- if(k>0) str += " ";
+ if(k>0) str += " ";
str += d.getPoint(m,0,k).x + "," + d.getPoint(m,0,k).y;
str += '</gml:coordinates></gml:LineString></gml:lineStringMember>';
str += '</gml:MultiLineString>';
@@ -287,12 +420,12 @@
str += '<gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>';
str += '</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon>';
- str += '</' + el_geom + '></'+ myconf['featuretype_name']+'></wfs:Insert>';
+ str += '</' + el_geom + '></'+ myconf['featuretype_name']+'></wfs:Insert>';
// --------------------------------------- UPDATE ------------------------------------------------
@@ -309,22 +442,22 @@
str += '<wfs:Property><wfs:Name>' + el_geom + '</wfs:Name><wfs:Value>';
str += '<gml:Point srsName="' + myconf['featuretype_srs'] + '"><gml:coordinates>';
- str += '</gml:coordinates></gml:Point>';
+ str += '</gml:coordinates></gml:Point>';
@@ -332,9 +465,9 @@
str += '<gml:MultiPolygon srsName="' + myconf['featuretype_srs'] + '">';
str += '</wfs:Value></wfs:Property>';
@@ -348,13 +481,13 @@
str += '<wfs:Delete typeName="'+ myconf['featuretype_name']+'">';
str += '<ogc:Filter><ogc:FeatureId fid="'+fid+'"/></ogc:Filter>';
str += '</wfs:Delete>';
str += '</wfs:Transaction>';
return str;
Deleted: branches/noframes/http/javascripts/wfs_usemap.js
--- branches/noframes/http/javascripts/wfs_usemap.js 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/javascripts/wfs_usemap.js 2008-10-03 08:42:59 UTC (rev 3100)
@@ -1,167 +0,0 @@
-* $Id$
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-// --- usemap (begin) --------------------------------------------------------------------------------------------
-function mod_usemap(wfs_name) {
- if (wfs_name == "") {
- usemap = "";
- var ind = getMapObjIndexByName(mb_wfs_target);
- var myImg = window.frames[mb_wfs_target].document.getElementById("um_img").style;
- myImg.width = mb_mapObj[ind].width;
- myImg.height = mb_mapObj[ind].height;
- for (var i = 0 ; i < mb_wfs_fetch.count() ; i ++) {
- if (mb_wfs_fetch.get(i).wfs_conf == wfs_name || wfs_name == "") {
- if (mb_wfs_fetch.get(i).geomType == geomType.polygon) {
- usemap += mod_usemap_polygon(i);
- else if (mb_wfs_fetch.get(i).geomType == geomType.point) {
- usemap += mod_usemap_circle(i);
- else if (mb_wfs_fetch.get(i).geomType == geomType.line) {
- usemap += mod_usemap_line(i);
- writeUsemap(usemap);
-function mod_usemap_circle(ind){
- var str = "";
- var coord = "";
- var title = "";
- for (var i = 0 ; i < mb_wfs_fetch.get(ind).e.count(); i++) {
- if (i>0) title += " ";
- title += mb_wfs_fetch.get(ind).e.getName(i) + ": " + mb_wfs_fetch.get(ind).e.getValue(i);
- for (var i = 0 ; i < mb_wfs_fetch.get(ind).count() ; i ++) {
- var p = mb_wfs_fetch.getPoint(ind, i, 0);
- var pos = realToMap(mb_wfs_target,p);
- coord += pos.x + ", " + pos.y;
- str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
- str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='circle' coords='";
- str += coord + ", " + mod_usemap_radius + "' href='#'>";
- return str;
-function mod_usemap_line_calculate (aGeometry, j, orientation, cnt) {
- var coord = "";
- var p1 = realToMap(mb_wfs_targets[0],aGeometry.get(j));
- var p2 = realToMap(mb_wfs_targets[0],aGeometry.get(j+orientation));
- var vec = p2.minus(p1);
- if (vec.x != 0 || vec.y != 0) {
- var n_vec;
- if (vec.x != 0) {
- if (vec.x > 0) n_vec = new Point((-vec.y)/vec.x, -1);
- else n_vec = new Point(vec.y/vec.x, 1);
- else {
- if (vec.y > 0) n_vec = new Point(1,0);
- else n_vec = new Point(-1,0);
- n_vec = n_vec.times(mod_usemap_line_tolerance).dividedBy(n_vec.dist(new Point(0,0)))
- lp = new Point(p1.x + n_vec.x, p1.y - n_vec.y);
- if (cnt > 0) coord += ", ";
- coord += parseInt(lp.x) + ", " + parseInt(lp.y);
- coord += ", " + parseInt(lp.x+vec.x) + ", " + parseInt(lp.y+vec.y);
- return coord;
-function mod_usemap_line(ind){
- var str = "";
- var title = "";
- var coord = "";
- var cnt = 0;
- for (var j = 0 ; j < mb_wfs_fetch.getGeometry(ind,i).count() - 1 ; j ++) {
- var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, 1, cnt);
- if (result != "") {
- coord += result;
- cnt++;
- for (var j = (mb_wfs_fetch.getGeometry(ind,i).count() - 1) ; j > 0 ; j--) {
- var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, -1, cnt);
- coord += result;
- cnt++;
- if (coord != "") {
- str += "<AREA title='"+title+"'";
- str += "onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
- str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' ";
- str += "shape='poly' coords='";
- str += coord + "' href='#'>";
- else {
- //display circle
- var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind,i,0));
- str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
- return str;
-function mod_usemap_polygon(ind){
- var str = "";
- var coord = "";
- var title = "";
- var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, 0));
- for (var j = 1 ; j < mb_wfs_fetch.getGeometry(ind,i).count() ; j ++) {
- pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, j));
- coord += ", " + pos.x + ", " + pos.y;
- str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='poly' coords='";
- return str;
-function writeUsemap(str) {
- writeTag(mb_wfs_targets[0], 'um', str);
-// --- usemap (end) ----------------------------------------------------------------------------------------------
Modified: branches/noframes/http/php/mod_forgottenPassword.php
--- branches/noframes/http/php/mod_forgottenPassword.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/php/mod_forgottenPassword.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -18,7 +18,7 @@
-require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
require_once(dirname(__FILE__)."/../classes/class_administration.php");
<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
Modified: branches/noframes/http/php/mod_meetingPoint.php
--- branches/noframes/http/php/mod_meetingPoint.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/php/mod_meetingPoint.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -221,7 +221,7 @@
my_meetingPoint += encodeURIComponent(document.forms[0].mytext.value);
- my_meetingPoint += "," + document.forms[0].x.value + ",";
+ my_meetingPoint += "|" + document.forms[0].x.value + "|";
my_meetingPoint += document.forms[0].y.value;
if(meetingPoint_export_format == 'email'){
Modified: branches/noframes/http/print/mod_printPDF.php
--- branches/noframes/http/print/mod_printPDF.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/print/mod_printPDF.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -1,429 +1,400 @@
-<?php
-# $Id: mod_printPDF.php
-# http://www.mapbender.org/index.php/mod_printPDF.php
-session_start();
-require_once(dirname(__FILE__)."/../../conf/mapbender.conf");
-<!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
-<html>
-<head>
-<meta http-equiv="cache-control" content="no-cache">
-<meta http-equiv="pragma" content="no-cache">
-<meta http-equiv="expires" content="0">
-<?php
-echo '<meta http-equiv="Content-Type" content="text/html; charset='.CHARSET.'">';
-<title>Print PDF</title>
-</head>
-<style type="text/css">
-select{
- width:150px;
-input{
- width:150px;
-.mycheck{
- width:15px;
-div{
- font-family : Arial, Helvetica, sans-serif;
- font-size: 12px;
-</style>
-<?php
-//FIXME:
-//setlocale(LC_ALL, "de_DE.utf8");
-require_once(dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
-echo "<script type='text/javascript'>";
-echo "var target = '".$_REQUEST["target"]."';";
-echo "var comment = '".$label_comment."';";
-echo "var comment_length = ".$comment_length.";";
-echo "var label_button = '".$label_button."';";
-echo "var type = '".$type."';";
-echo "</script>";
-<script type="text/javascript">
-var size;
-var format;
-var map_width;
-var map_height;
-if(type=='window'){
- var pt = window.opener;
-else if(type == 'iframe'){
- var pt = parent;
-function mod_legend_print(){
- var mod_legend_target = target;
- var ind = pt.getMapObjIndexByName(mod_legend_target);
- var layers;
- document.forms[0].layers.value = "";
- document.forms[0].wms_id.value = "";
- document.forms[0].wms_title.value = "";
- document.forms[0].legendurl.value = "";
- for(var i=0; i<pt.mb_mapObj[ind].wms.length; i++){
- layers = pt.mb_mapObj[ind].wms[i].getLayers(pt.mb_mapObj[ind]);
- if(layers != "" && layers){
- if(i>0 && document.forms[0].wms_id.value!=''){
- document.forms[0].layers.value += "___";
- document.forms[0].wms_id.value += "___";
- document.forms[0].wms_title.value += "___";
- document.forms[0].legendurl.value += "___";
- document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
- document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
- for(var j=0; j<layers.length; j++){
- var layer = layers[j];
- var title = pt.mb_mapObj[ind].wms[i].getTitleByLayerName(layers[j]);
- var layerStyle = pt.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layers[j]);
- if(layerStyle==false){
- var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"default");
- else{
- var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],layerStyle);
- //---------- legendurl ----------
- tmp_name = "";
- if(j>0){
- document.forms[0].layers.value += ",";
- document.forms[0].layers.value += title;
- if(j>0){
- document.forms[0].legendurl.value += ",";
- if (temp_legendurl!= '' || !temp_legendurl == 'true'){
- document.forms[0].legendurl.value += temp_legendurl;
- }else{
- document.forms[0].legendurl.value +='0';
- else{
- document.forms[0].layers.value += "0";
- document.forms[0].wms_id.value += "0";
- document.forms[0].wms_title.value += "0";
- document.forms[0].legendurl.value += "0";
- }//for
- //alert(document.forms[0].layers.value+"---"+document.forms[0].wms_id.value+"---"+document.forms[0].wms_title.value+"---"+document.forms[0].legendurl.value);
-function validate(){
- size = document.form1.size.options[document.form1.size.selectedIndex].value;
- format = document.form1.format.options[document.form1.format.selectedIndex].value;
- if(size != "" && format != ""){
- var ind = pt.getMapObjIndexByName(target);
- var coord = pt.mb_mapObj[ind].extent.split(",");
- var centerX = parseFloat(coord[0]) + (parseFloat(coord[2]) - parseFloat(coord[0]))/2
- var centerY = parseFloat(coord[1]) + (parseFloat(coord[3]) - parseFloat(coord[1]))/2
- if(size == "A4" && format == "portrait"){
- map_width = <?php echo $a4p_map_width; ?>;
- map_height = <?php echo $a4p_map_height; ?>;
- if(size == "A4" && format == "landscape"){
- map_width = <?php echo $a4l_map_width; ?>;
- map_height = <?php echo $a4l_map_height; ?>;
- if(size == "A3" && format == "portrait"){
- map_width = <?php echo $a3p_map_width; ?>;
- map_height = <?php echo $a3p_map_height; ?>;
- if(size == "A3" && format == "landscape"){
- map_width = <?php echo $a3l_map_width; ?>;
- map_height = <?php echo $a3l_map_height; ?>;
- if(size == "A2" && format == "portrait"){
- map_width = <?php echo $a2p_map_width; ?>;
- map_height = <?php echo $a2p_map_height; ?>;
- if(size == "A2" && format == "landscape"){
- map_width = <?php echo $a2l_map_width; ?>;
- map_height = <?php echo $a2l_map_height; ?>;
- if(size == "A1" && format == "portrait"){
- map_width = <?php echo $a1p_map_width; ?>;
- map_height = <?php echo $a1p_map_height; ?>;
- if(size == "A1" && format == "landscape"){
- map_width = <?php echo $a1l_map_width; ?>;
- map_height = <?php echo $a1l_map_height; ?>;
- if(size == "A0" && format == "portrait"){
- map_width = <?php echo $a0p_map_width; ?>;
- map_height = <?php echo $a0p_map_height; ?>;
- if(size == "A0" && format == "landscape"){
- map_width = <?php echo $a0l_map_width; ?>;
- map_height = <?php echo $a0l_map_height; ?>;
- var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
- var prevscale= pt.mb_getScale(target);
- pt.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," + coord[3];
- pt.mb_mapObj[ind].width = Math.round(map_width);
- pt.mb_mapObj[ind].height = Math.round(map_height);
- pt.document.getElementById(target).style.width = Math.round(map_width);
- pt.document.getElementById(target).style.height = Math.round(map_height);
- pt.window.frames[target].document.getElementById("maps").style.width = Math.round(map_width);
- pt.window.frames[target].document.getElementById("maps").style.height = Math.round(map_height);
- //pt.setMapRequest(target);
- pt.mb_repaintScale(target, null, null, prevscale);
- document.form1.map_url.value = '';
- if(pt.mb_mapObj[ind].wms[i].gui_wms_visible > 0){
- if(pt.mb_mapObj[ind].wms[i].mapURL != false && pt.mb_mapObj[ind].wms[i].mapURL != 'false' && pt.mb_mapObj[ind].wms[i].mapURL != ''){
- if(document.form1.map_url.value != ""){
- document.form1.map_url.value += "___";
- document.form1.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
- //overview_url
- var ind_overview = pt.getMapObjIndexByName('overview');
- //alert ("l�nge: " + length+ " - " + ind_overview + name + pt.mb_mapObj[ind_overview].wms.length);
- if(pt.mb_mapObj[ind_overview].mapURL != false ){
- document.forms[0].overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
-function refreshParams(){
- var f = document.forms[0];
- size = document.getElementById('size').options[document.getElementById('size').selectedIndex].value;
- format = document.getElementById('format').options[document.getElementById('format').selectedIndex].value;
- pt.mb_repaintScale(target, null, null, pt.mb_getScale(target));
- f.map_url.value = '';
- if(f.map_url.value != ""){
- f.map_url.value += "___";
- f.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
- //overview_url
- f.overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
- f.map_scale.value = pt.mb_getScale(target);
- f.epsg.value = pt.mb_mapObj[ind].epsg;
- mod_legend_print();
-function printMap(){
- if(size != "" && (format == "portrait" || format == "landscape")){
- refreshParams();
- if(document.form1.c1.value != comment){
- document.form1.comment1.value = document.form1.c1.value;
- if(document.form1.c2.value != comment){
- document.form1.comment2.value = document.form1.c2.value;
- if(document.form1.mylegendcheckbox.checked == 0){
- document.form1.mylegend.value = 'false';
- }else{
- document.form1.mylegend.value = 'true';
- // write the measured coordinates
- if (pt.mod_measure_RX != undefined && pt.mod_measure_RY != undefined) {
- var tmp_x = '';
- var tmp_y = '';
- for(i = 0; i<pt.mod_measure_RX.length; i++) {
- if(tmp_x != '') {
- tmp_x += ','
- tmp_x += pt.mod_measure_RX[i];
- for(i = 0; i<pt.mod_measure_RY.length; i++) {
- if(tmp_y != '') {
- tmp_y += ','
- tmp_y += pt.mod_measure_RY[i];
- document.forms['form1'].elements['measured_x_values'].value = tmp_x;
- document.forms['form1'].elements['measured_y_values'].value = tmp_y;
- document.form1.submit();
- else{
- alert("<?php echo _("No format selected.")?>");
-function valCom(obj){
- if(obj.value.length > comment_length){
- obj.value = obj.value.substr(0,comment_length);
-</script>
-<body>
-<form name='form1' method='POST' action='../print/mod_printPDF_pdf.php?<?php echo SID; ?>' target="_blank">
-<table border='0'>
-<tr>
- <td>
- <select name='size' onchange='validate()'>
-<?php
- if($a4 == true && $a3 == true){
- echo "<option value=''>".$label_format."</option>";
- if($a4 == true){
- echo "<option value='A4'>".$label_format_a4."</option>";
- if($a3 == true){
- echo "<option value='A3'>".$label_format_a3."</option>";
- if($a2 == true){
- echo "<option value='A2'>".$label_format_a2."</option>";
- if($a1 == true){
- echo "<option value='A1'>".$label_format_a1."</option>";
- if($a0 == true){
- echo "<option value='A0'>".$label_format_a0."</option>";
- </select>
- </td>
-</tr>
-<tr>
- <td>
- <select name='format' onchange='validate()'>
- <option value=''><?php echo $label_orientation; ?></option>
- <option value='portrait'><?php echo $label_portrait; ?></option>
- <option value='landscape'><?php echo $label_landscape; ?></option>
- </select>
- </td>
-</tr>
-<?php
-if($highquality == true){
- echo "<tr>";
- echo "<td>";
- echo "<select name='quality'>";
- echo "<option value='1'>".$label_72dpi."</option>";
- echo "<option value='2'>".$label_288dpi."</option>";
- echo "</select>";
- echo "</td>";
- echo "</tr>";
-<tr>
- <td>
- <input type='text' name='c1' value='<?php echo $label_comment; ?>' onkeydown="valCom(this)">
- </td>
-</tr>
-<tr>
- <td>
- <input type='text' name='c2' value='<?php echo $label_comment; ?>' onkeydown="valCom(this)">
- </td>
-</tr>
-<?php
-if($legend == true){
- echo "<tr>";
- echo "<td>";
- echo "<div><input type='checkbox' class='mycheck' name='mylegendcheckbox' value='false'>".$label_legend."</div>";
- echo "</td>";
- echo "</tr>";
-}else {
- echo "<tr>";
- echo "<td>";
- echo "<input type='hidden' name='mylegendcheckbox' value='false'>";
- echo "</td>";
- echo "</tr>";
-<table>
-<input type='hidden' name='map_url' value=''>
-<input type='hidden' name='overview_url' value=''>
-<input type='hidden' name='wms_title' value=''>
-<input type='hidden' name='wms_id' value=''>
-<input type='hidden' name='layers' value=''>
-<input type='hidden' name='legendurl' value=''>
-<input type='hidden' name='map_scale' value=''>
-<input type='hidden' name='epsg' value=''>
-<input type='button' name='print' value="<?php echo $label_button; ?>" onclick='printMap()'>
-<input type='hidden' name='conf' value='<?php echo $_REQUEST["conf"]; ?>'>
-<input type='hidden' name='comment1' value=''>
-<input type='hidden' name='comment2' value=''>
-<input type='hidden' name='mylegend' value='true'>
-<input type='hidden' name='measured_x_values' value=''>
-<input type='hidden' name='measured_y_values' value=''>
-</form>
-</body>
-</html>
+<?php
+# $Id: mod_printPDF.php
+# http://www.mapbender.org/index.php/mod_printPDF.php
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Strict//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-strict.dtd">
+<html xmlns="http://www.w3.org/1999/xhtml" xml:lang="en" lang="en">
+<head>
+ <meta http-equiv="cache-control" content="no-cache" />
+ <meta http-equiv="pragma" content="no-cache" />
+ <meta http-equiv="expires" content="0" />
+ <?php printf("<meta http-equiv=\"Content-Type\" content=\"text/html; charset=%s\" />",CHARSET); ?>
+ <title>Print PDF</title>
+ <?php
+ //FIXME:
+ //setlocale(LC_ALL, "de_DE.utf8");
+ require_once(dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
+ printf("
+ <script type=\"text/javascript\">
+ var target = '%s';
+ var comment1 = '%s';
+ var comment1_length = %s;
+ var comment2 = '%s';
+ var comment2_length = %s;
+ var label_button = '%s';
+ var type = '%s';
+ </script>",
+ $_REQUEST["target"],$label_comment1,$comment1_length,$label_comment2,$comment2_length,$label_button,$type
+ <script type="text/javascript">
+ var size;
+ var format;
+ var map_width;
+ var map_height;
+ if(type=='window'){
+ var pt = window.opener;
+ else if(type == 'iframe'){
+ var pt = parent;
+ function mod_legend_print(){
+ var mod_legend_target = target;
+ var ind = pt.getMapObjIndexByName(mod_legend_target);
+ var layers;
+ document.forms[0].layers.value = "";
+ document.forms[0].wms_id.value = "";
+ document.forms[0].wms_title.value = "";
+ document.forms[0].legendurl.value = "";
+ for(var i=0; i<pt.mb_mapObj[ind].wms.length; i++){
+ layers = pt.mb_mapObj[ind].wms[i].getLayers(pt.mb_mapObj[ind]);
+ if(layers != "" && layers){
+ if(i>0 && document.forms[0].wms_id.value!=''){
+ document.forms[0].layers.value += "___";
+ document.forms[0].wms_id.value += "___";
+ document.forms[0].wms_title.value += "___";
+ document.forms[0].legendurl.value += "___";
+ document.forms[0].wms_id.value += pt.mb_mapObj[ind].wms[i].wms_id;
+ document.forms[0].wms_title.value += pt.mb_mapObj[ind].wms[i].wms_title;
+ for(var j=0; j<layers.length; j++){
+ var layer = layers[j];
+ var title = pt.mb_mapObj[ind].wms[i].getTitleByLayerName(layers[j]);
+ var layerStyle = pt.mb_mapObj[ind].wms[i].getCurrentStyleByLayerName(layers[j]);
+ if(layerStyle==false){
+ var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],"default");
+ else{
+ var temp_legendurl = pt.mb_mapObj[ind].wms[i].getLegendUrlByGuiLayerStyle(layers[j],layerStyle);
+ //---------- legendurl ----------
+ tmp_name = "";
+ if(j>0){
+ document.forms[0].layers.value += ",";
+ document.forms[0].layers.value += title;
+ if(j>0){
+ document.forms[0].legendurl.value += ",";
+ if (temp_legendurl!= '' || !temp_legendurl == 'true'){
+ document.forms[0].legendurl.value += temp_legendurl;
+ }else{
+ document.forms[0].legendurl.value +='0';
+ else{
+ document.forms[0].layers.value += "0";
+ document.forms[0].wms_id.value += "0";
+ document.forms[0].wms_title.value += "0";
+ document.forms[0].legendurl.value += "0";
+ }//for
+ //alert(document.forms[0].layers.value+"---"+document.forms[0].wms_id.value+"---"+document.forms[0].wms_title.value+"---"+document.forms[0].legendurl.value);
+ function validate(){
+ size = document.getElementById('size').options[document.getElementById('size').selectedIndex].value;
+ format = document.getElementById('format').options[document.getElementById('format').selectedIndex].value;
+ if(size != "false" && format != "false"){
+ var ind = pt.getMapObjIndexByName(target);
+ var coord = pt.mb_mapObj[ind].extent.split(",");
+ var centerX = parseFloat(coord[0]) + (parseFloat(coord[2]) - parseFloat(coord[0]))/2
+ var centerY = parseFloat(coord[1]) + (parseFloat(coord[3]) - parseFloat(coord[1]))/2
+ if(size == "A4" && format == "portrait"){
+ map_width = <?php echo $a4p_map_width; ?>;
+ map_height = <?php echo $a4p_map_height; ?>;
+ if(size == "A4" && format == "landscape"){
+ map_width = <?php echo $a4l_map_width; ?>;
+ map_height = <?php echo $a4l_map_height; ?>;
+ if(size == "A3" && format == "portrait"){
+ map_width = <?php echo $a3p_map_width; ?>;
+ map_height = <?php echo $a3p_map_height; ?>;
+ if(size == "A3" && format == "landscape"){
+ map_width = <?php echo $a3l_map_width; ?>;
+ map_height = <?php echo $a3l_map_height; ?>;
+ if(size == "A2" && format == "portrait"){
+ map_width = <?php echo $a2p_map_width; ?>;
+ map_height = <?php echo $a2p_map_height; ?>;
+ if(size == "A2" && format == "landscape"){
+ map_width = <?php echo $a2l_map_width; ?>;
+ map_height = <?php echo $a2l_map_height; ?>;
+ if(size == "A1" && format == "portrait"){
+ map_width = <?php echo $a1p_map_width; ?>;
+ map_height = <?php echo $a1p_map_height; ?>;
+ if(size == "A1" && format == "landscape"){
+ map_width = <?php echo $a1l_map_width; ?>;
+ map_height = <?php echo $a1l_map_height; ?>;
+ if(size == "A0" && format == "portrait"){
+ map_width = <?php echo $a0p_map_width; ?>;
+ map_height = <?php echo $a0p_map_height; ?>;
+ if(size == "A0" && format == "landscape"){
+ map_width = <?php echo $a0l_map_width; ?>;
+ map_height = <?php echo $a0l_map_height; ?>;
+ var pos = pt.makeClickPos2RealWorldPos(target, map_width , map_height);
+ var prevscale= pt.mb_getScale(target);
+ pt.mb_mapObj[ind].extent = coord[0] + "," + pos[1] + "," + pos[0] + "," + coord[3];
+ pt.mb_mapObj[ind].width = Math.round(map_width);
+ pt.mb_mapObj[ind].height = Math.round(map_height);
+ pt.document.getElementById(target).style.width = Math.round(map_width);
+ pt.document.getElementById(target).style.height = Math.round(map_height);
+ pt.window.frames[target].document.getElementById("maps").style.width = Math.round(map_width);
+ pt.window.frames[target].document.getElementById("maps").style.height = Math.round(map_height);
+ //pt.setMapRequest(target);
+ pt.mb_repaintScale(target, null, null, prevscale);
+ document.form1.map_url.value = '';
+ if(pt.mb_mapObj[ind].wms[i].gui_wms_visible > 0){
+ if(pt.mb_mapObj[ind].wms[i].mapURL != false && pt.mb_mapObj[ind].wms[i].mapURL != 'false' && pt.mb_mapObj[ind].wms[i].mapURL != ''){
+ if(document.form1.map_url.value != ""){
+ document.form1.map_url.value += "___";
+ document.form1.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
+ //overview_url
+ var ind_overview = pt.getMapObjIndexByName('overview');
+ //alert ("l�nge: " + length+ " - " + ind_overview + name + pt.mb_mapObj[ind_overview].wms.length);
+ if(pt.mb_mapObj[ind_overview].mapURL != false ){
+ document.forms[0].overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
+ function refreshParams(){
+ var f = document.forms[0];
+ if(size != "" && format != ""){
+ pt.mb_repaintScale(target, null, null, pt.mb_getScale(target));
+ f.map_url.value = '';
+ if(f.map_url.value != ""){
+ f.map_url.value += "___";
+ f.map_url.value += pt.mb_mapObj[ind].wms[i].mapURL;
+ //overview_url
+ f.overview_url.value = pt.mb_mapObj[ind_overview].mapURL;
+ f.map_scale.value = pt.mb_getScale(target);
+ f.epsg.value = pt.mb_mapObj[ind].epsg;
+ mod_legend_print();
+ function printMap(){
+ if(size != "false" && (format == "portrait" || format == "landscape")){
+ refreshParams();
+ if(document.form1.c1.value != comment1){
+ document.form1.comment1.value = document.form1.c1.value;
+ if(document.form1.c2.value != comment2){
+ document.form1.comment2.value = document.form1.c2.value;
+ if(document.form1.mylegendcheckbox.checked == 0){
+ document.form1.mylegend.value = 'false';
+ }else{
+ document.form1.mylegend.value = 'true';
+ // write the measured coordinates
+ if (pt.mod_measure_RX != undefined && pt.mod_measure_RY != undefined) {
+ var tmp_x = '';
+ var tmp_y = '';
+ for(i = 0; i<pt.mod_measure_RX.length; i++) {
+ if(tmp_x != '') {
+ tmp_x += ','
+ tmp_x += pt.mod_measure_RX[i];
+ for(i = 0; i<pt.mod_measure_RY.length; i++) {
+ if(tmp_y != '') {
+ tmp_y += ','
+ tmp_y += pt.mod_measure_RY[i];
+ document.forms['form1'].elements['measured_x_values'].value = tmp_x;
+ document.forms['form1'].elements['measured_y_values'].value = tmp_y;
+ document.form1.submit();
+ else{
+ alert('<?php echo _mb("No format selected")."!"?>');
+ function checkCommentLength(obj,maxLength){
+ if(obj.value.length > maxLength){
+ obj.value = obj.value.substr(0,maxLength);
+ </script>
+ <?php include("../include/dyn_css.php"); ?>
+</head>
+<body>
+<form name="form1" method="post" action="../print/mod_printPDF_pdf.php?<?php echo SID; ?>" target="_blank">
+<p id="container_size">
+ <label for="size"><?php echo $label_format ?></label>
+ <select id="size" name="size" onchange="validate();">
+ <option value="false">-</option>
+ <?php
+ for($i = 4; $i >= 0; $i--) {
+ if(${"a".$i}) {
+ printf("<option value=\"A%s\">%s</option>",$i,${"label_format_a".$i});
+ </select>
+</p>
+<p id="container_orientation">
+ <label for="format"><?php echo $label_orientation; ?></label>
+ <select id="format" name="format" onchange="validate();">
+ <option value="portrait"><?php echo $label_portrait; ?></option>
+ <option value="landscape"><?php echo $label_landscape; ?></option>
+ </select>
+</p>
+<?php if($highquality === TRUE): ?>
+ <p id="container_quality">
+ <label for="quality"><?php echo $label_quality; ?></label>
+ <input type="radio" id="quality" name="quality" value="1" checked="checked" /> <?php echo $label_72dpi; ?>
+ <input type="radio" id="quality" name="quality" value="2" /> <?php echo $label_288dpi; ?>
+ </p>
+<?php endif; ?>
+<?php
+ini_set("error_reporting",E_ALL);
+ini_set("display_errors","on");
+ for($i = 1; $i <= 2; $i++) {
+ $max_comment_length = ${"comment".$i."_length"};
+ $label_hint = ($max_comment_length > -1) ? sprintf(" <em>"._mb("max.")." %s)</em>",$max_comment_length) : NULL;
+ $javascript = ($max_comment_length > -1) ? sprintf(" onblur=\"checkCommentLength(this,%s)\"",$max_comment_length) : NULL;
+ $html = sprintf("<p id=\"container_comment%s\">",$i);
+ $html .= sprintf("<label for=\"c%s\">%s%s</label> ",$i,${"label_comment".$i},$label_hint);
+ $html .= sprintf("<textarea id=\"c%s\" name=\"c%s\" cols=\"20\" rows=\"2\"%s></textarea> ",$i,$i,$javascript);
+ $html .= "</p>";
+ echo $html;
+<?php if($legend === TRUE): ?>
+ <p id="container_legend">
+ <label for="mylegendcheckbox"><?php echo $label_legend; ?></label>
+ <input type="checkbox" id="mylegendcheckbox" name="mylegendcheckbox" value="false" />
+ </p>
+<?php else: ?>
+ <input type="hidden" name="mylegendcheckbox" value="false" />
+<?php endif; ?>
+<input type="hidden" name="map_url" />
+<input type="hidden" name="overview_url" />
+<input type="hidden" name="wms_title" />
+<input type="hidden" name="wms_id" />
+<input type="hidden" name="layers" />
+<input type="hidden" name="legendurl" />
+<input type="hidden" name="map_scale" />
+<input type="hidden" name="epsg" />
+<input type="hidden" name="conf" value="<?php echo $_REQUEST["conf"]; ?>" />
+<input type="hidden" name="comment1" />
+<input type="hidden" name="comment2" />
+<input type="hidden" name="mylegend" value="true" >
+<input type="hidden" name="measured_x_values" />
+<input type="hidden" name="measured_y_values" />
+<p>
+ <input type="button" id="print" name="print" value="<?php echo $label_button; ?>" onclick="printMap();" />
+</p>
+</form>
+</body>
+</html>
Modified: branches/noframes/http/print/mod_printPDF_pdf.php
--- branches/noframes/http/print/mod_printPDF_pdf.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/print/mod_printPDF_pdf.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -1,847 +1,850 @@
-<?php
-# $Id:
-# http://www.mapbender.org/index.php/mod_printPDF_pdf.php
-# Copyright (C) 2002 CCGIS
-# This program is free software; you can redistribute it and/or modify
-# it under the terms of the GNU General Public License as published by
-# the Free Software Foundation; either version 2, or (at your option)
-# any later version.
-# This program is distributed in the hope that it will be useful,
-# but WITHOUT ANY WARRANTY; without even the implied warranty of
-# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
-# GNU General Public License for more details.
-# You should have received a copy of the GNU General Public License
-# along with this program; if not, write to the Free Software
-include (dirname(__FILE__)."/../classes/class.ezpdf.php");
-include (dirname(__FILE__)."/../classes/class_stripRequest.php");
-include (dirname(__FILE__)."/../classes/class_weldMaps2PNG.php");
-include (dirname(__FILE__)."/../classes/class_weldOverview2PNG.php");
-include (dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
-include (dirname(__FILE__)."/../classes/class_SaveLegend.php");
-include (dirname(__FILE__)."/../print/print_functions.php");
-if($log == true){
- include (dirname(__FILE__)."/../classes/class_log.php");
-#Globals
-$factor = intval($_REQUEST["quality"]);
-#$date = date("d.m.Y",strtotime("now"));
-$linewidth_dashed = 0.5;
-$linewidth = 0.5;
-// DURATION TIME:
-function microtime_float(){
- list($usec, $sec) = explode(" ", microtime());
- return ((float)$usec + (float)$sec);
-$time_start = microtime_float();
-// END DURATION TIME
-$time_end = microtime_float();
-$time = $time_end - $time_start;
-$size = $_REQUEST["size"];
-$format = $_REQUEST["format"];
-$map_scale = $_REQUEST["map_scale"];
-$overview_url = $_REQUEST["overview_url"];
-$epsg = $_REQUEST["epsg"];
-function setscalebar($scale){
- $mb_resolution = 28.35;
- if($scale < 16){
- $value = "10";
- $unit = "cm";
- $scalefactor = 10/$scale;
- $img_width = round($scalefactor * $mb_resolution);
- if($scale >= 16 && $scale < 151){
- $value = "1";
- $unit = "Meter";
- $scalefactor = 100/$scale;
- if($scale >= 151 && $scale < 1550 ){
- $value = "10";
- $unit = "Meter";
- $scalefactor = 1000/$scale;
- if($scale >= 1550 && $scale < 15050){
- $value = "100";
- $unit = "Meter";
- $scalefactor = 10000/$scale;
- if($scale < 150050 && $scale >= 15050){
- $value = "1";
- $unit = "Kilometer";
- $scalefactor = 100000/$scale;
- if($scale < 1500050 && $scale >= 150050){
- $value = "10";
- $scalefactor = 1000000/$scale;
- if($scale < 15000050 && $scale >= 1500050){
- $value = "100";
- $scalefactor = 10000000/$scale;
- if($scale < 150000001 && $scale >= 15000001){
- $value = "1000";
- $scalefactor = 100000000/$scale;
- if($scale >= 150000001){
- $value = "1000";
- $array_scale[0] = $unit;
- $array_scale[1] = $img_width;
- $array_scale[2] = $value;
- return $array_scale;
-$border = 0.8 * $DPC;
-if($matching == true){
- $urls = preg_replace($pattern,$replacement,$_REQUEST["map_url"]);
-else{
- $urls = $_REQUEST["map_url"];
-$array_urls = explode("___", $urls);
-$myURL = new stripRequest($array_urls[0]);
-$map_width = round($myURL->get("width"));
-$map_height = round($myURL->get("height"));
-$map_extent = $myURL->get("BBOX");
-if($factor>1){
- for($i=0; $i<count($array_urls); $i++){
- $m = new stripRequest($array_urls[$i]);
- $m->set('width',(intval($m->get('width'))*4));
- $m->set('height',(intval($m->get('height'))*4));
- if(in_array($m->get('map'),$highqualitymapfiles)){
- $m->set('map',preg_replace("/\.map/","_4.map",$m->get('map')));
- $array_urls[$i] = $m->url;
-$coord = mb_split(",",$map_extent);
-if($overview === true){
- // analyse overview url and draw rectangle with position
- $o_url = new stripRequest($overview_url);
- $overview_width = round($o_url->get("width"));
- $overview_height = round($o_url->get("height"));
- if($factor>1){
- $o_url->set('width',(intval($o_url->get('width'))*4));
- $o_url->set('height',(intval($o_url->get('height'))*4));
- if(in_array($o_url->get('map'),$highqualitymapfiles)){
- $o_url->set('map',preg_replace("/\.map/","_4.map",$o_url->get('map')));
- $overview_url = $o_url->url;
- if($matching == true){
- $overview_url = preg_replace($pattern,$replacement,$overview_url);
- if ($size == "A4" && $format == "portrait"){
- $overview_left = $a4p_overviewOffset_left;
- $overview_bottom =$a4p_overviewOffset_bottom;
- }elseif ($size == "A4" && $format == "landscape"){
- $overview_left = $a4l_overviewOffset_left;
- $overview_bottom =$a4l_overviewOffset_bottom;
- }elseif ($size == "A3" && $format == "portrait"){
- $overview_left = $a3p_overviewOffset_left;
- $overview_bottom =$a3p_overviewOffset_bottom;
- }elseif ($size == "A3" && $format == "landscape"){
- $overview_left = $a3l_overviewOffset_left;
- $overview_bottom = $a3l_overviewOffset_bottom;
- }elseif ($size == "A2" && $format == "portrait"){
- $overview_left = $a2p_overviewOffset_left;
- $overview_bottom =$a2p_overviewOffset_bottom;
- }elseif ($size == "A2" && $format == "landscape"){
- $overview_left = $a2l_overviewOffset_left;
- $overview_bottom = $a2l_overviewOffset_bottom;
- }elseif ($size == "A1" && $format == "portrait"){
- $overview_left = $a1p_overviewOffset_left;
- $overview_bottom =$a1p_overviewOffset_bottom;
- }elseif ($size == "A1" && $format == "landscape"){
- $overview_left = $a1l_overviewOffset_left;
- $overview_bottom = $a1l_overviewOffset_bottom;
- }elseif ($size == "A0" && $format == "portrait"){
- $overview_left = $a0p_overviewOffset_left;
- $overview_bottom =$a0p_overviewOffset_bottom;
- }elseif ($size == "A0" && $format == "landscape"){
- $overview_left = $a0l_overviewOffset_left;
- $overview_bottom = $a0l_overviewOffset_bottom;
- $o_extent = $o_url->get("BBOX");
- $array_overview_url[0] = $overview_url;
- if($log == true){
- $l = new log("printPDF_overview",$array_overview_url);
- $o_new = new stripRequest($overview_url);
- $o_new->set('width',50);
- $o_new->set('height',50);
- //$o->set('BBOX',$overview_extent);
- $o_url_new =$o_new->url;
- $array_overview[0] = $overview_url;
- $array_overview[1] = $o_url;
- * north arrow
-if($size == "A4" && $format == "portrait"){
- $northarrow_left = $a4p_northarrow_left;
- $northarrow_bottom = $a4p_northarrow_bottom;
-}elseif ($size == "A4" && $format == "landscape"){
- $northarrow_left = $a4l_northarrow_left;
- $northarrow_bottom = $a4l_northarrow_bottom;
-}elseif ($size == "A3" && $format == "portrait"){
- $northarrow_left = $a3p_northarrow_left;
- $northarrow_bottom = $a3p_northarrow_bottom;
-}elseif ($size == "A3" && $format == "landscape"){
- $northarrow_left = $a3l_northarrow_left;
- $northarrow_bottom = $a3l_northarrow_bottom;
-}elseif ($size == "A2" && $format == "portrait"){
- $northarrow_left = $a2p_northarrow_left;
- $northarrow_bottom = $a2p_northarrow_bottom;
-}elseif ($size == "A2" && $format == "landscape"){
- $northarrow_left = $a2l_northarrow_left;
- $northarrow_bottom = $a2l_northarrow_bottom;
-}elseif ($size == "A1" && $format == "portrait"){
- $northarrow_left = $a1p_northarrow_left;
- $northarrow_bottom = $a1p_northarrow_bottom;
-}elseif ($size == "A1" && $format == "landscape"){
- $northarrow_left = $a1l_northarrow_left;
- $northarrow_bottom = $a1l_northarrow_bottom;
-}elseif ($size == "A0" && $format == "portrait"){
- $northarrow_left = $a0p_northarrow_left;
- $northarrow_bottom = $a0p_northarrow_bottom;
-}elseif ($size == "A0" && $format == "landscape"){
- $northarrow_left = $a0l_northarrow_left;
- $northarrow_bottom = $a0l_northarrow_bottom;
- * special image
-if ($size == "A4" && $format == "portrait"){
- $specialImage_left = $a4p_special_left;
- $specialImage_bottom = $a4p_special_bottom;
- $specialImage_left = $a4l_special_left;
- $specialImage_bottom = $a4l_special_bottom;
- $specialImage_left = $a3p_special_left;
- $specialImage_bottom = $a3p_special_bottom;
- $specialImage_left = $a3l_special_left;
- $specialImage_bottom = $a3l_special_bottom;
- $specialImage_left = $a2p_special_left;
- $specialImage_bottom = $a2p_special_bottom;
- $specialImage_left = $a2l_special_left;
- $specialImage_bottom = $a2l_special_bottom;
- $specialImage_left = $a1p_special_left;
- $specialImage_bottom = $a1p_special_bottom;
- $specialImage_left = $a1l_special_left;
- $specialImage_bottom = $a1l_special_bottom;
- $specialImage_left = $a0p_special_left;
- $specialImage_bottom = $a0p_special_bottom;
- $specialImage_left = $a0l_special_left;
- $specialImage_bottom = $a0l_special_bottom;
-if($log == true){
- $l = new log("printPDF",$array_urls);
-$pdf = new Cezpdf();
-$pdf->Cezpdf(mb_strtolower($size),$format);
-$diff=array(196=>'Adieresis',228=>'adieresis',
- 214=>'Odieresis',246=>'odieresis',
- 220=>'Udieresis',252=>'udieresis',
- 223=>'germandbls');
-$pdf->selectFont('../classes/fonts/Helvetica.afm', array('encoding'=>'WinAnsiEncoding','differences'=>$diff));
- $mapOffset_left = $a4p_mapOffset_left;
- $mapOffset_bottom = $a4p_mapOffset_bottom;
- $header_height = $a4p_header_height;
- $footer_height = $a4p_footer_height;
-else{
- $mapOffset_left = $a4l_mapOffset_left;
- $mapOffset_bottom = $a4l_mapOffset_bottom;
- $header_height = $a4l_header_height;
- $header_width = $a4l_header_width;
-session_write_close();
-$i = new weldMaps2PNG(implode("___",$array_urls),$filename);
-$pdf->addPngFromFile($filename, $mapOffset_left, $mapOffset_bottom, $map_width, $map_height);
-if($unlink == true){
- unlink($filename);
-* user drawn elements
-$theMeasureConfigArray = array(
- "do_fill" => FALSE,
- "fill_color" => array(
- "r" => 128 / 255,
- "g" => 128 / 255,
- "b" => 128 / 255
- "do_stroke" => FALSE,
- "stroke_color" => array(
- "r" => 254 / 255,
- "g" => 1 / 255,
- "b" => 1 / 255
- "line_style" => array(
- "width" => 2,
- "cap" => 'butt',
- "join" => 'miter',
- "dash" => array(10, 6)
-if ($_REQUEST["measured_x_values"]!=''){
- addMeasuredItem($pdf, $_REQUEST["measured_x_values"], $_REQUEST["measured_y_values"], $theMeasureConfigArray);
- hideElementsOutsideMapframe($pdf);
-# dashed line
-$pdf->setLineStyle($linewidth_dashed, '','', array(2,2));
-$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
-$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
-$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed);
-$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed);
-#line
-$pdf->setLineStyle($linewidth, '', '', array());
-$pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border);
-$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
-$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom -$border);
-$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border, $mapOffset_left - $border, $mapOffset_bottom - $border);
-if($epsg == "EPSG:4326"){
- $text4 = "";
- #header:
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height);
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height);
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
- $pdf->line( $mapOffset_left + $map_width/2, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width/2, $mapOffset_bottom + $map_height + $border + $header_height);
- #header-text
- $mySize = 9;
- $length = $pdf->getTextWidth($mySize, $text1);
- $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text1);
- $mySize = 8;
- $length = $pdf->getTextWidth($mySize, $text2);
- $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 45,$mySize,$text2);
- $length = $pdf->getTextWidth($mySize, $text3);
- $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 35,$mySize,$text3);
- $mySize = 9;
- $length = $pdf->getTextWidth($mySize, $text4);
- $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text4);
- $mySize = 8;
- $length = $pdf->getTextWidth($mySize, $text5);
- $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text5);
- $mySize = 9;
- $length = $pdf->getTextWidth($mySize, $text6);
- $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text6);
- $length = $pdf->getTextWidth($mySize, $text7);
- $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 50,$mySize,$text7);
- $length = $pdf->getTextWidth($mySize, $text8);
- $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 30,$mySize,$text8);
- $length = $pdf->getTextWidth($mySize, $text9);
- $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text9);
- $length = $pdf->getTextWidth($mySize, $text10);
- $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text10);
- //special image on the map-page
- if ($special == true){
- $pdf->addPngFromFile($specialImage, $specialImage_left, $specialImage_bottom , $specialImage_width, $specialImage_height);
- #footer
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
- $mySize = 8;
- $length = $pdf->getTextWidth($mySize, $text11);
- $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 10,$mySize,$text11);
- $mySize = 6;
- $length = $pdf->getTextWidth($mySize, $text12);
- $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 18,$mySize,$text12);
- $length = $pdf->getTextWidth($mySize, $text13);
- $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 25,$mySize,$text13);
-else{
- $pdf->setColor(1,1,1);
- $ll = array($mapOffset_left + $map_width - $header_width + $border - $linewidth, $mapOffset_bottom - $border + 1);
- $pdf->filledRectangle($ll[0], $ll[1], $header_width,$header_height);
- $pdf->line($ll[0], $ll[1], $ll[0], $ll[1] + $header_height);
- $pdf->line($ll[0], $ll[1] + $header_height, $ll[0] + $header_width, $ll[1] + $header_height);
- $pdf->line($ll[0] + 2, $ll[1] + 2, $ll[0] + 2, $ll[1] + $header_height - 2);
- $pdf->line($ll[0] + 2, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + $header_height - 2);
- $pdf->line($ll[0] - 2 + $header_width, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + 2);
- $pdf->line($ll[0] - 2 + $header_width, $ll[1] + 2, $ll[0] + 2, $ll[1] + 2);
- $pdf->line($ll[0] + 2, $ll[1] + 110 , $ll[0] - 2 + $header_width, $ll[1] + 110);
- $pdf->line($ll[0] + 2, $ll[1] + 40 , $ll[0] - 2 + $header_width, $ll[1] + 40);
- if($epsg == "EPSG:4326"){
- $text4 = "";
- $pdf->setColor(0,0,0);
- $mySize = 9;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,185,$mySize,$text1);
- $mySize = 8;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,175,$mySize,$text2);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,165,$mySize,$text3);
- $mySize = 9;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,155,$mySize,$text4);
- $mySize = 8;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,145,$mySize,$text5);
- $mySize = 9;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,125,$mySize,$text6);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,115,$mySize,$text7);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,95,$mySize,$text8);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,85,$mySize,$text9);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,75,$mySize,$text10);
- $mySize = 8;
- $pdf->addText($ll[0] + $header_width/2 - $length/2,60,$mySize,$text11);
- $mySize = 6;
- $length = $pdf->getTextWidth($mySize, $text14);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,53,$mySize,$text14);
- $length = $pdf->getTextWidth($mySize, $text15);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,47,$mySize,$text15);
- $length = $pdf->getTextWidth($mySize, $text16);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,41,$mySize,$text16);
- $length = $pdf->getTextWidth($mySize, $text17);
- $pdf->addText($ll[0] + $header_width/2 - $length/2,35,$mySize,$text17);
-#Coordinates
-$myMinx = "R ".substr(round($coord[0]), 0, 4)." ".substr(round($coord[0]), 4, 3)."";
-$myMiny = "H ".substr(round($coord[1]), 0, 4)." ".substr(round($coord[1]), 4, 3)."";
-$myMaxx = "R ".substr(round($coord[2]), 0, 4)." ".substr(round($coord[2]), 4, 3)."";
-$myMaxy = "H ".substr(round($coord[3]), 0, 4)." ".substr(round($coord[3]), 4, 3)."";
-$mySize = 9;
-$pdf->addText($mapOffset_left - 3, $mapOffset_bottom, $mySize, $myMinx, -90);
-$pdf->addText($mapOffset_left, $mapOffset_bottom - ($pdf->getFontHeight($mySize)), $mySize, $myMiny);
-$pdf->addText($mapOffset_left + $map_width - ($pdf->getTextWidth($mySize, $myMaxx)), $mapOffset_bottom + $map_height + 3, $mySize, $myMaxx);
-$pdf->addText($mapOffset_left + $map_width + 3, $mapOffset_bottom + $map_height, $mySize, $myMaxy, 90);
-if ($overview==true){
- // analyse request, draw rectancle
- $filename = preg_replace("/map_/","overview_",$filename);
- if($size == "A4" && $format == "portrait"){
- $i = new weldOverview2PNG($overview_url,$array_urls[0] ,$filename);
- $pdf->addPngFromFile($filename, $overview_left,$overview_bottom, $overview_width, $overview_height);
- if($unlink == true){
- else{
- $i = new weldOverview2PNG($overview_url,$array_urls[0],$filename);
- //$pdf->addPngFromFile($filename, $mapOffset_left,$mapOffset_bottom, $overview_width, $overview_height);
-if ($northarrow==true){
- $pdf->addPngFromFile($northarrowImage, $northarrow_left, $northarrow_bottom , $northarrowImage_width, $northarrowImage_height);
- $scalebar = false;
-if($scalebar == true){
- $scalebar_left = $a4p_scalebar_left;
- $scalebar_bottom = $a4p_scalebar_bottom;
- $scalebar_left = $a4l_scalebar_left;
- $scalebar_bottom = $a4l_scalebar_bottom;
- $scalebar_left = $a3p_scalebar_left;
- $scalebar_bottom = $a3p_scalebar_bottom;
- $scalebar_left = $a3l_scalebar_left;
- $scalebar_bottom = $a3l_scalebar_bottom;
- $scalebar_left = $a2p_scalebar_left;
- $scalebar_bottom = $a2p_scalebar_bottom;
- $scalebar_left = $a2l_scalebar_left;
- $scalebar_bottom = $a2l_scalebar_bottom;
- $scalebar_left = $a1p_scalebar_left;
- $scalebar_bottom = $a1p_scalebar_bottom;
- $scalebar_left = $a1l_scalebar_left;
- $scalebar_bottom = $a1l_scalebar_bottom;
- $scalebar_left = $a0p_scalebar_left;
- $scalebar_bottom = $a0p_scalebar_bottom;
- $scalebar_left = $a0l_scalebar_left;
- $scalebar_bottom = $a0l_scalebar_bottom;
- $array_scalebar = setscalebar($map_scale);
- $scalebar_left = $scalebar_left + $header_width/2 - $array_scalebar[1]/2;
- $pdf->setLineStyle($scalebar_height, '','', array());
- #$pdf->line($scalebar_left, $scalebar_bottom , $scalebar_left - 200 + $array_scalebar[1], $scalebar_bottom);
- $pdf->filledRectangle($scalebar_left, $scalebar_bottom, $array_scalebar[1],$scalebar_height);
- $pdf->filledRectangle($scalebar_left + $array_scalebar[1]/4 + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 1 ,$scalebar_height-2);
- $pdf->filledRectangle($scalebar_left + 3*($array_scalebar[1]/4) + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 2 ,$scalebar_height-2);
- #$pdf->setColor(1,0,1);
- #$pdf->filledRectangle($scalebar_left , $scalebar_bottom - 20, 1 * $DPC ,$scalebar_height-2);
- # value - Einheiten
- $mySize = 8;
- $scalebar_height_half = 0.5 * $scalebar_height;
- $myText = 0;
- $length = $pdf->getTextWidth($mySize, $myText);
- $pdf->addText($scalebar_left - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
- $myText = $array_scalebar[2]/2;
- $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
- $myText = $array_scalebar[2];
- $pdf->addText($scalebar_left + $array_scalebar[1] - $length/2 - $length/4 ,$scalebar_bottom + 9 ,$mySize,$myText);
- $mySize = 8;
- $myText = $array_scalebar[0];
- #$pdf->addText($scalebar_left + $scalebar_width + 5,$scalebar_bottom - $scalebar_height_half ,$mySize,$myText);
- #units
- $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom - 12 ,$mySize,$myText);
- new page for legend
-if ($legend == true && $_REQUEST["mylegend"]=='true'){
- $pdf->ezNewPage();
- //Pageborder (top, bottom, left, right)
- $pdf->ezSetMargins(50,50,80,30);
- } else {
- $pdf->ezSetMargins(60,35,60,60);
- //Requests
- if(CHARSET=="UTF-8"){
- $new_wms_title=utf8_decode($_REQUEST["wms_title"]);
- }else{
- $new_wms_title=$_REQUEST["wms_title"];
- $new_layers=utf8_decode($_REQUEST["layers"]);
- }else{
- $new_layers=$_REQUEST["layers"];
- $my_wms_id = explode("___",$_REQUEST["wms_id"]);
- $my_wms_title = explode("___",$new_wms_title);
- $my_layers = explode("___",$new_layers);
- $my_legend = preg_replace($pattern,$replacement,$_REQUEST["legendurl"]);
- else{
- $my_legend = $_REQUEST["legendurl"];
- $my_legend = explode("___",$my_legend);
- //columns
- $pdf->ezColumnsStart(array ('num'=>2, 'gap'=>10));
- } else {
- $pdf->ezColumnsStart(array ('num'=>3, 'gap'=>10));
- //header from printPDF.conf
- //$pdf->ezText("<b>".$titel."</b>", 13);
- $pdf->ezText("<b><u>".$legendText."</u></b>", 13);
- //Seitenraender (top, bottom, left, right)
- $pdf->ezSetMargins(70,35,80,30);
- } else {
- $pdf->ezSetMargins(100,35,60,60);
- //generate the legend---------------------------------------------
- // Gesamthoehe Legende / height of the legend
- $sum_legend_height = 0;
- for($i=0; $i<count($my_wms_id); $i++){
- if ($my_wms_id[$i] != '0'){ //wms_id not 0
- $layer = explode(",",$my_layers[$i]);
- $my_legendurls = explode(",",$my_legend[$i]);
- $wms_y_position = $pdf->ezText("<b>".$my_wms_title[$i]."</b>", 12, array('spacing'=>1.2));
- $wms_zeilenhoehe = $pdf->getFontHeight(12);
- // add this to the height of the legend /addiere dies zur Gesamthoehe Legende
- $sum_legend_height += $wms_zeilenhoehe;
- //Layer
- $l = 0; #l temporary parameter to count the layer /Hilfvariable zum durchz�hlen der angezeigten Layer
- for($j=0; $j<count($my_legendurls); $j++){
- // url with grouped layers------------------
- $temp_url = explode('*',$my_legendurls[$j]);
- $temp_layers = explode('*',$layer[$j]);
- for ($q=0; $q <count($temp_url);$q++){
- if($temp_url[$q] == '1' ){ // Layertitle for the parent of grouped layers
- // add this to the height of the legend /addiere dies zur Gesamth�he Legende
- $layer_y_position = $pdf->ezText($temp_layers[$q], 11, array('spacing'=>1.2));
- $layer_zeilenhoehe = $pdf->getFontHeight(12);
- $sum_legend_height += $layer_zeilenhoehe;
- }elseif($temp_url[$q] != '0' ){
- $funktionsaufruf = new SaveLegend($temp_url[$q],$legendFilename);
- $imgsize = getimagesize($legendFilename);
- // add this to the height of the legend /addiere dies zur Gesamthoehe der Legende
- $sum_legend_height += $imgsize[1];
- //calculate text + picture / Berechnung Groesse Schrift + Bild
- if($l == 0){
- $y_position = $wms_y_position;
- $wms_y_position = '';
- }else{
- $y_position = $pdf->ezText("", 1, array('spacing'=>1.2));
- $layer_zeilenhoehe = $pdf->getFontHeight(11);
- $next_position = $y_position - $layer_zeilenhoehe - $imgsize[1];
- // add this to the height of the legend / addiere dies zur Gesamth�he Legende
- $l = $l+1;
- // if text + picture are smaler then the lower margin + textsize, then set a space
- //wenn Schrift + Bild kleiner der unteren Margin + Zeilenhoehe, dann Abstand setzen
- if($size == "A4" && $format == "portrait" && $next_position <= 35 +$layer_zeilenhoehe){ //90 $layer_zeilenhoehe
- $space = $layer_zeilenhoehe + $imgsize[1];
- $pdf->ezSetDy(-$space);
- if($size == "A4" && $format == "landscape" && $next_position <= 35+$layer_zeilenhoehe){//50
- //write the header layername / Ueberschrift schreiben
- $legend = $temp_layers[$q]."\n"; //$layer[$j]."\n";
- $pdf->ezText($legend, 11, array('spacing'=>1.2));
- //$pdf->ezText($url, 9, array('spacing'=>1.2));
- //print the picture / Bild schreiben
- $pdf->ezImage($legendFilename, 0, 'width', 'none', 'left');
- unlink($legendFilename);
- } //if legendurl
- }// for legendurl
- //frames (x1, y1, x2, y2)
- #line
- $pdf->setLineStyle($linewidth, '', '', array());
- //left
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height);
- //right
- //top
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
- //bottom
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
- if ($legendImage!=''){
- //image on top of page
- $pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border + $header_height - $legendImage_height - 4 , $legendImage_width, $legendImage_height);
- } else {
- //left
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border);
- //right
- $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
- //top
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
- //bottom
- $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border , $mapOffset_left - $border, $mapOffset_bottom - $border);
- $pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border - $legendImage_height -4 , $legendImage_width, $legendImage_height);
- //line under legend (only landscape)
- //$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 4 , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 6);
- }// for layers
- } //if wms_id not 0
- }// for wms
- * USER POLYGON:
- if($_REQUEST["measured_x_values"] != ""
- && $_REQUEST["measured_y_values"] != ""
- && is_file($legendFilenameUserPolygon)) {
- // load image
- $myY = $pdf->ezText("<b>temporary Object</b>", 11);
- $pdf->ezSetDy(-15);
- $pdf->ezImage($legendFilenameUserPolygon, 5, 17, 'none', 'left');
- unlink($legendFilenameUserPolygon);
- $pdf->ezSetY($myY - 7);
- $pdf->ezText("Element", 11, array("left" => 25));
- // deletes image
-$pdf->ezText($legendFooter, 11);
-}//legend true
- end of legend
-ob_clean();
-if($download == false){
- $pdf->ezStream();
-else{
- $content = $pdf->ezOutput();
- $fp = fopen($downloadFile,'w');
- fwrite($fp,$content);
- fclose($fp);
- echo "<html><head></head><body><a href='".$downloadFile."'>".$downloadText."</a></body></html>";
+<?php
+# $Id:
+# http://www.mapbender.org/index.php/mod_printPDF_pdf.php
+# Copyright (C) 2002 CCGIS
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+include (dirname(__FILE__)."/../classes/class.ezpdf.php");
+include (dirname(__FILE__)."/../classes/class_stripRequest.php");
+include (dirname(__FILE__)."/../classes/class_weldMaps2PNG.php");
+include (dirname(__FILE__)."/../classes/class_weldOverview2PNG.php");
+include (dirname(__FILE__)."/../print/".$_REQUEST["conf"]);
+include (dirname(__FILE__)."/../classes/class_SaveLegend.php");
+include (dirname(__FILE__)."/../print/print_functions.php");
+if($log == true){
+ include (dirname(__FILE__)."/../classes/class_log.php");
+#Globals
+$factor = intval($_REQUEST["quality"]);
+#$date = date("d.m.Y",strtotime("now"));
+$linewidth_dashed = 0.5;
+$linewidth = 0.5;
+// DURATION TIME:
+function microtime_float(){
+ list($usec, $sec) = explode(" ", microtime());
+ return ((float)$usec + (float)$sec);
+$time_start = microtime_float();
+// END DURATION TIME
+$time_end = microtime_float();
+$time = $time_end - $time_start;
+$size = $_REQUEST["size"];
+$format = $_REQUEST["format"];
+$map_scale = $_REQUEST["map_scale"];
+$overview_url = $_REQUEST["overview_url"];
+$epsg = $_REQUEST["epsg"];
+if($overview_url=='false'){
+ $overview = false;
+function setscalebar($scale){
+ $mb_resolution = 28.35;
+ if($scale < 16){
+ $value = "10";
+ $unit = "cm";
+ $scalefactor = 10/$scale;
+ $img_width = round($scalefactor * $mb_resolution);
+ if($scale >= 16 && $scale < 151){
+ $value = "1";
+ $unit = "Meter";
+ $scalefactor = 100/$scale;
+ if($scale >= 151 && $scale < 1550 ){
+ $value = "10";
+ $unit = "Meter";
+ $scalefactor = 1000/$scale;
+ if($scale >= 1550 && $scale < 15050){
+ $value = "100";
+ $unit = "Meter";
+ $scalefactor = 10000/$scale;
+ if($scale < 150050 && $scale >= 15050){
+ $value = "1";
+ $unit = "Kilometer";
+ $scalefactor = 100000/$scale;
+ if($scale < 1500050 && $scale >= 150050){
+ $value = "10";
+ $scalefactor = 1000000/$scale;
+ if($scale < 15000050 && $scale >= 1500050){
+ $value = "100";
+ $scalefactor = 10000000/$scale;
+ if($scale < 150000001 && $scale >= 15000001){
+ $value = "1000";
+ $scalefactor = 100000000/$scale;
+ if($scale >= 150000001){
+ $value = "1000";
+ $array_scale[0] = $unit;
+ $array_scale[1] = $img_width;
+ $array_scale[2] = $value;
+ return $array_scale;
+$border = 0.8 * $DPC;
+if($matching == true){
+ $urls = preg_replace($pattern,$replacement,$_REQUEST["map_url"]);
+else{
+ $urls = $_REQUEST["map_url"];
+$array_urls = explode("___", $urls);
+$myURL = new stripRequest($array_urls[0]);
+$map_width = round($myURL->get("width"));
+$map_height = round($myURL->get("height"));
+$map_extent = $myURL->get("BBOX");
+if($factor>1){
+ for($i=0; $i<count($array_urls); $i++){
+ $m = new stripRequest($array_urls[$i]);
+ $m->set('width',(intval($m->get('width'))*4));
+ $m->set('height',(intval($m->get('height'))*4));
+ if(in_array($m->get('map'),$highqualitymapfiles)){
+ $m->set('map',preg_replace("/\.map/","_4.map",$m->get('map')));
+ $array_urls[$i] = $m->url;
+$coord = mb_split(",",$map_extent);
+if($overview === true){
+ // analyse overview url and draw rectangle with position
+ $o_url = new stripRequest($overview_url);
+ $overview_width = round($o_url->get("width"));
+ $overview_height = round($o_url->get("height"));
+ if($factor>1){
+ $o_url->set('width',(intval($o_url->get('width'))*4));
+ $o_url->set('height',(intval($o_url->get('height'))*4));
+ if(in_array($o_url->get('map'),$highqualitymapfiles)){
+ $o_url->set('map',preg_replace("/\.map/","_4.map",$o_url->get('map')));
+ $overview_url = $o_url->url;
+ if($matching == true){
+ $overview_url = preg_replace($pattern,$replacement,$overview_url);
+ if ($size == "A4" && $format == "portrait"){
+ $overview_left = $a4p_overviewOffset_left;
+ $overview_bottom =$a4p_overviewOffset_bottom;
+ }elseif ($size == "A4" && $format == "landscape"){
+ $overview_left = $a4l_overviewOffset_left;
+ $overview_bottom =$a4l_overviewOffset_bottom;
+ }elseif ($size == "A3" && $format == "portrait"){
+ $overview_left = $a3p_overviewOffset_left;
+ $overview_bottom =$a3p_overviewOffset_bottom;
+ }elseif ($size == "A3" && $format == "landscape"){
+ $overview_left = $a3l_overviewOffset_left;
+ $overview_bottom = $a3l_overviewOffset_bottom;
+ }elseif ($size == "A2" && $format == "portrait"){
+ $overview_left = $a2p_overviewOffset_left;
+ $overview_bottom =$a2p_overviewOffset_bottom;
+ }elseif ($size == "A2" && $format == "landscape"){
+ $overview_left = $a2l_overviewOffset_left;
+ $overview_bottom = $a2l_overviewOffset_bottom;
+ }elseif ($size == "A1" && $format == "portrait"){
+ $overview_left = $a1p_overviewOffset_left;
+ $overview_bottom =$a1p_overviewOffset_bottom;
+ }elseif ($size == "A1" && $format == "landscape"){
+ $overview_left = $a1l_overviewOffset_left;
+ $overview_bottom = $a1l_overviewOffset_bottom;
+ }elseif ($size == "A0" && $format == "portrait"){
+ $overview_left = $a0p_overviewOffset_left;
+ $overview_bottom =$a0p_overviewOffset_bottom;
+ }elseif ($size == "A0" && $format == "landscape"){
+ $overview_left = $a0l_overviewOffset_left;
+ $overview_bottom = $a0l_overviewOffset_bottom;
+ $o_extent = $o_url->get("BBOX");
+ $array_overview_url[0] = $overview_url;
+ if($log == true){
+ $l = new log("printPDF_overview",$array_overview_url);
+ $o_new = new stripRequest($overview_url);
+ $o_new->set('width',50);
+ $o_new->set('height',50);
+ //$o->set('BBOX',$overview_extent);
+ $o_url_new =$o_new->url;
+ $array_overview[0] = $overview_url;
+ $array_overview[1] = $o_url;
+ * north arrow
+if($size == "A4" && $format == "portrait"){
+ $northarrow_left = $a4p_northarrow_left;
+ $northarrow_bottom = $a4p_northarrow_bottom;
+}elseif ($size == "A4" && $format == "landscape"){
+ $northarrow_left = $a4l_northarrow_left;
+ $northarrow_bottom = $a4l_northarrow_bottom;
+}elseif ($size == "A3" && $format == "portrait"){
+ $northarrow_left = $a3p_northarrow_left;
+ $northarrow_bottom = $a3p_northarrow_bottom;
+}elseif ($size == "A3" && $format == "landscape"){
+ $northarrow_left = $a3l_northarrow_left;
+ $northarrow_bottom = $a3l_northarrow_bottom;
+}elseif ($size == "A2" && $format == "portrait"){
+ $northarrow_left = $a2p_northarrow_left;
+ $northarrow_bottom = $a2p_northarrow_bottom;
+}elseif ($size == "A2" && $format == "landscape"){
+ $northarrow_left = $a2l_northarrow_left;
+ $northarrow_bottom = $a2l_northarrow_bottom;
+}elseif ($size == "A1" && $format == "portrait"){
+ $northarrow_left = $a1p_northarrow_left;
+ $northarrow_bottom = $a1p_northarrow_bottom;
+}elseif ($size == "A1" && $format == "landscape"){
+ $northarrow_left = $a1l_northarrow_left;
+ $northarrow_bottom = $a1l_northarrow_bottom;
+}elseif ($size == "A0" && $format == "portrait"){
+ $northarrow_left = $a0p_northarrow_left;
+ $northarrow_bottom = $a0p_northarrow_bottom;
+}elseif ($size == "A0" && $format == "landscape"){
+ $northarrow_left = $a0l_northarrow_left;
+ $northarrow_bottom = $a0l_northarrow_bottom;
+ * special image
+if ($size == "A4" && $format == "portrait"){
+ $specialImage_left = $a4p_special_left;
+ $specialImage_bottom = $a4p_special_bottom;
+ $specialImage_left = $a4l_special_left;
+ $specialImage_bottom = $a4l_special_bottom;
+ $specialImage_left = $a3p_special_left;
+ $specialImage_bottom = $a3p_special_bottom;
+ $specialImage_left = $a3l_special_left;
+ $specialImage_bottom = $a3l_special_bottom;
+ $specialImage_left = $a2p_special_left;
+ $specialImage_bottom = $a2p_special_bottom;
+ $specialImage_left = $a2l_special_left;
+ $specialImage_bottom = $a2l_special_bottom;
+ $specialImage_left = $a1p_special_left;
+ $specialImage_bottom = $a1p_special_bottom;
+ $specialImage_left = $a1l_special_left;
+ $specialImage_bottom = $a1l_special_bottom;
+ $specialImage_left = $a0p_special_left;
+ $specialImage_bottom = $a0p_special_bottom;
+ $specialImage_left = $a0l_special_left;
+ $specialImage_bottom = $a0l_special_bottom;
+if($log == true){
+ $l = new log("printPDF",$array_urls);
+$pdf = new Cezpdf();
+$pdf->Cezpdf(mb_strtolower($size),$format);
+$diff=array(196=>'Adieresis',228=>'adieresis',
+ 214=>'Odieresis',246=>'odieresis',
+ 220=>'Udieresis',252=>'udieresis',
+ 223=>'germandbls');
+$pdf->selectFont('../classes/fonts/Helvetica.afm', array('encoding'=>'WinAnsiEncoding','differences'=>$diff));
+ $mapOffset_left = $a4p_mapOffset_left;
+ $mapOffset_bottom = $a4p_mapOffset_bottom;
+ $header_height = $a4p_header_height;
+ $footer_height = $a4p_footer_height;
+else{
+ $mapOffset_left = $a4l_mapOffset_left;
+ $mapOffset_bottom = $a4l_mapOffset_bottom;
+ $header_height = $a4l_header_height;
+ $header_width = $a4l_header_width;
+session_write_close();
+$i = new weldMaps2PNG(implode("___",$array_urls),$filename);
+$pdf->addPngFromFile($filename, $mapOffset_left, $mapOffset_bottom, $map_width, $map_height);
+if($unlink == true){
+ unlink($filename);
+* user drawn elements
+$theMeasureConfigArray = array(
+ "do_fill" => FALSE,
+ "fill_color" => array(
+ "r" => 128 / 255,
+ "g" => 128 / 255,
+ "b" => 128 / 255
+ "do_stroke" => FALSE,
+ "stroke_color" => array(
+ "r" => 254 / 255,
+ "g" => 1 / 255,
+ "b" => 1 / 255
+ "line_style" => array(
+ "width" => 2,
+ "cap" => 'butt',
+ "join" => 'miter',
+ "dash" => array(10, 6)
+if ($_REQUEST["measured_x_values"]!=''){
+ addMeasuredItem($pdf, $_REQUEST["measured_x_values"], $_REQUEST["measured_y_values"], $theMeasureConfigArray);
+ hideElementsOutsideMapframe($pdf);
+# dashed line
+$pdf->setLineStyle($linewidth_dashed, '','', array(2,2));
+$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
+$pdf->line($mapOffset_left - $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed);
+$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom + $map_height + $linewidth_dashed, $mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed);
+$pdf->line($mapOffset_left + $map_width + $linewidth_dashed, $mapOffset_bottom -$linewidth_dashed, $mapOffset_left - $linewidth_dashed, $mapOffset_bottom - $linewidth_dashed);
+#line
+$pdf->setLineStyle($linewidth, '', '', array());
+$pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border);
+$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width + $border, $mapOffset_bottom -$border);
+$pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border, $mapOffset_left - $border, $mapOffset_bottom - $border);
+if($epsg == "EPSG:4326"){
+ $text4 = "";
+ #header:
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height);
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height);
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+ $pdf->line( $mapOffset_left + $map_width/2, $mapOffset_bottom + $map_height + $border, $mapOffset_left + $map_width/2, $mapOffset_bottom + $map_height + $border + $header_height);
+ #header-text
+ $mySize = 9;
+ $length = $pdf->getTextWidth($mySize, $text1);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text1);
+ $mySize = 8;
+ $length = $pdf->getTextWidth($mySize, $text2);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 45,$mySize,$text2);
+ $length = $pdf->getTextWidth($mySize, $text3);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 35,$mySize,$text3);
+ $mySize = 9;
+ $length = $pdf->getTextWidth($mySize, $text4);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text4);
+ $mySize = 8;
+ $length = $pdf->getTextWidth($mySize, $text5);
+ $pdf->addText($mapOffset_left - ($border/2) + ($map_width/4) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text5);
+ $mySize = 9;
+ $length = $pdf->getTextWidth($mySize, $text6);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 60,$mySize,$text6);
+ $length = $pdf->getTextWidth($mySize, $text7);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 50,$mySize,$text7);
+ $length = $pdf->getTextWidth($mySize, $text8);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 30,$mySize,$text8);
+ $length = $pdf->getTextWidth($mySize, $text9);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 20,$mySize,$text9);
+ $length = $pdf->getTextWidth($mySize, $text10);
+ $pdf->addText($mapOffset_left + ($border/2) + ($map_width/4*3) - ($length/2),$mapOffset_bottom + $map_height + $border + 10,$mySize,$text10);
+ //special image on the map-page
+ if ($special == true){
+ $pdf->addPngFromFile($specialImage, $specialImage_left, $specialImage_bottom , $specialImage_width, $specialImage_height);
+ #footer
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
+ $mySize = 8;
+ $length = $pdf->getTextWidth($mySize, $text11);
+ $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 10,$mySize,$text11);
+ $mySize = 6;
+ $length = $pdf->getTextWidth($mySize, $text12);
+ $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 18,$mySize,$text12);
+ $length = $pdf->getTextWidth($mySize, $text13);
+ $pdf->addText( $mapOffset_left + $map_width/2 - ($length/2),$mapOffset_bottom - $border - 25,$mySize,$text13);
+else{
+ $pdf->setColor(1,1,1);
+ $ll = array($mapOffset_left + $map_width - $header_width + $border - $linewidth, $mapOffset_bottom - $border + 1);
+ $pdf->filledRectangle($ll[0], $ll[1], $header_width,$header_height);
+ $pdf->line($ll[0], $ll[1], $ll[0], $ll[1] + $header_height);
+ $pdf->line($ll[0], $ll[1] + $header_height, $ll[0] + $header_width, $ll[1] + $header_height);
+ $pdf->line($ll[0] + 2, $ll[1] + 2, $ll[0] + 2, $ll[1] + $header_height - 2);
+ $pdf->line($ll[0] + 2, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + $header_height - 2);
+ $pdf->line($ll[0] - 2 + $header_width, $ll[1] + $header_height - 2, $ll[0] - 2 + $header_width, $ll[1] + 2);
+ $pdf->line($ll[0] - 2 + $header_width, $ll[1] + 2, $ll[0] + 2, $ll[1] + 2);
+ $pdf->line($ll[0] + 2, $ll[1] + 110 , $ll[0] - 2 + $header_width, $ll[1] + 110);
+ $pdf->line($ll[0] + 2, $ll[1] + 40 , $ll[0] - 2 + $header_width, $ll[1] + 40);
+ if($epsg == "EPSG:4326"){
+ $text4 = "";
+ $pdf->setColor(0,0,0);
+ $mySize = 9;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,185,$mySize,$text1);
+ $mySize = 8;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,175,$mySize,$text2);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,165,$mySize,$text3);
+ $mySize = 9;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,155,$mySize,$text4);
+ $mySize = 8;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,145,$mySize,$text5);
+ $mySize = 9;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,125,$mySize,$text6);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,115,$mySize,$text7);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,95,$mySize,$text8);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,85,$mySize,$text9);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,75,$mySize,$text10);
+ $mySize = 8;
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,60,$mySize,$text11);
+ $mySize = 6;
+ $length = $pdf->getTextWidth($mySize, $text14);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,53,$mySize,$text14);
+ $length = $pdf->getTextWidth($mySize, $text15);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,47,$mySize,$text15);
+ $length = $pdf->getTextWidth($mySize, $text16);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,41,$mySize,$text16);
+ $length = $pdf->getTextWidth($mySize, $text17);
+ $pdf->addText($ll[0] + $header_width/2 - $length/2,35,$mySize,$text17);
+#Coordinates
+$myMinx = "R ".substr(round($coord[0]), 0, 4)." ".substr(round($coord[0]), 4, 3)."";
+$myMiny = "H ".substr(round($coord[1]), 0, 4)." ".substr(round($coord[1]), 4, 3)."";
+$myMaxx = "R ".substr(round($coord[2]), 0, 4)." ".substr(round($coord[2]), 4, 3)."";
+$myMaxy = "H ".substr(round($coord[3]), 0, 4)." ".substr(round($coord[3]), 4, 3)."";
+$mySize = 9;
+$pdf->addText($mapOffset_left - 3, $mapOffset_bottom, $mySize, $myMinx, -90);
+$pdf->addText($mapOffset_left, $mapOffset_bottom - ($pdf->getFontHeight($mySize)), $mySize, $myMiny);
+$pdf->addText($mapOffset_left + $map_width - ($pdf->getTextWidth($mySize, $myMaxx)), $mapOffset_bottom + $map_height + 3, $mySize, $myMaxx);
+$pdf->addText($mapOffset_left + $map_width + 3, $mapOffset_bottom + $map_height, $mySize, $myMaxy, 90);
+if ($overview==true){
+ // analyse request, draw rectancle
+ $filename = preg_replace("/map_/","overview_",$filename);
+ if($size == "A4" && $format == "portrait"){
+ $i = new weldOverview2PNG($overview_url,$array_urls[0] ,$filename);
+ $pdf->addPngFromFile($filename, $overview_left,$overview_bottom, $overview_width, $overview_height);
+ if($unlink == true){
+ else{
+ $i = new weldOverview2PNG($overview_url,$array_urls[0],$filename);
+ //$pdf->addPngFromFile($filename, $mapOffset_left,$mapOffset_bottom, $overview_width, $overview_height);
+if ($northarrow==true){
+ $pdf->addPngFromFile($northarrowImage, $northarrow_left, $northarrow_bottom , $northarrowImage_width, $northarrowImage_height);
+ $scalebar = false;
+if($scalebar == true){
+ $scalebar_left = $a4p_scalebar_left;
+ $scalebar_bottom = $a4p_scalebar_bottom;
+ $scalebar_left = $a4l_scalebar_left;
+ $scalebar_bottom = $a4l_scalebar_bottom;
+ $scalebar_left = $a3p_scalebar_left;
+ $scalebar_bottom = $a3p_scalebar_bottom;
+ $scalebar_left = $a3l_scalebar_left;
+ $scalebar_bottom = $a3l_scalebar_bottom;
+ $scalebar_left = $a2p_scalebar_left;
+ $scalebar_bottom = $a2p_scalebar_bottom;
+ $scalebar_left = $a2l_scalebar_left;
+ $scalebar_bottom = $a2l_scalebar_bottom;
+ $scalebar_left = $a1p_scalebar_left;
+ $scalebar_bottom = $a1p_scalebar_bottom;
+ $scalebar_left = $a1l_scalebar_left;
+ $scalebar_bottom = $a1l_scalebar_bottom;
+ $scalebar_left = $a0p_scalebar_left;
+ $scalebar_bottom = $a0p_scalebar_bottom;
+ $scalebar_left = $a0l_scalebar_left;
+ $scalebar_bottom = $a0l_scalebar_bottom;
+ $array_scalebar = setscalebar($map_scale);
+ $scalebar_left = $scalebar_left + $header_width/2 - $array_scalebar[1]/2;
+ $pdf->setLineStyle($scalebar_height, '','', array());
+ #$pdf->line($scalebar_left, $scalebar_bottom , $scalebar_left - 200 + $array_scalebar[1], $scalebar_bottom);
+ $pdf->filledRectangle($scalebar_left, $scalebar_bottom, $array_scalebar[1],$scalebar_height);
+ $pdf->filledRectangle($scalebar_left + $array_scalebar[1]/4 + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 1 ,$scalebar_height-2);
+ $pdf->filledRectangle($scalebar_left + 3*($array_scalebar[1]/4) + 1 , $scalebar_bottom + 1, $array_scalebar[1]/4 - 2 ,$scalebar_height-2);
+ #$pdf->setColor(1,0,1);
+ #$pdf->filledRectangle($scalebar_left , $scalebar_bottom - 20, 1 * $DPC ,$scalebar_height-2);
+ # value - Einheiten
+ $mySize = 8;
+ $scalebar_height_half = 0.5 * $scalebar_height;
+ $myText = 0;
+ $length = $pdf->getTextWidth($mySize, $myText);
+ $pdf->addText($scalebar_left - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
+ $myText = $array_scalebar[2]/2;
+ $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom + 9 ,$mySize,$myText);
+ $myText = $array_scalebar[2];
+ $pdf->addText($scalebar_left + $array_scalebar[1] - $length/2 - $length/4 ,$scalebar_bottom + 9 ,$mySize,$myText);
+ $mySize = 8;
+ $myText = $array_scalebar[0];
+ #$pdf->addText($scalebar_left + $scalebar_width + 5,$scalebar_bottom - $scalebar_height_half ,$mySize,$myText);
+ #units
+ $pdf->addText($scalebar_left + $array_scalebar[1]/2 - $length/2 ,$scalebar_bottom - 12 ,$mySize,$myText);
+ new page for legend
+if ($legend == true && $_REQUEST["mylegend"]=='true'){
+ $pdf->ezNewPage();
+ //Pageborder (top, bottom, left, right)
+ $pdf->ezSetMargins(50,50,80,30);
+ } else {
+ $pdf->ezSetMargins(60,35,60,60);
+ //Requests
+ if(CHARSET=="UTF-8"){
+ $new_wms_title=utf8_decode($_REQUEST["wms_title"]);
+ }else{
+ $new_wms_title=$_REQUEST["wms_title"];
+ $new_layers=utf8_decode($_REQUEST["layers"]);
+ }else{
+ $new_layers=$_REQUEST["layers"];
+ $my_wms_id = explode("___",$_REQUEST["wms_id"]);
+ $my_wms_title = explode("___",$new_wms_title);
+ $my_layers = explode("___",$new_layers);
+ $my_legend = preg_replace($pattern,$replacement,$_REQUEST["legendurl"]);
+ else{
+ $my_legend = $_REQUEST["legendurl"];
+ $my_legend = explode("___",$my_legend);
+ //columns
+ $pdf->ezColumnsStart(array ('num'=>2, 'gap'=>10));
+ } else {
+ $pdf->ezColumnsStart(array ('num'=>3, 'gap'=>10));
+ //header from printPDF.conf
+ //$pdf->ezText("<b>".$titel."</b>", 13);
+ $pdf->ezText("<b><u>".$legendText."</u></b>", 13);
+ //Seitenraender (top, bottom, left, right)
+ $pdf->ezSetMargins(70,35,80,30);
+ } else {
+ $pdf->ezSetMargins(100,35,60,60);
+ //generate the legend---------------------------------------------
+ // Gesamthoehe Legende / height of the legend
+ $sum_legend_height = 0;
+ for($i=0; $i<count($my_wms_id); $i++){
+ if ($my_wms_id[$i] != '0'){ //wms_id not 0
+ $layer = explode(",",$my_layers[$i]);
+ $my_legendurls = explode(",",$my_legend[$i]);
+ $wms_y_position = $pdf->ezText("<b>".$my_wms_title[$i]."</b>", 12, array('spacing'=>1.2));
+ $wms_zeilenhoehe = $pdf->getFontHeight(12);
+ // add this to the height of the legend /addiere dies zur Gesamthoehe Legende
+ $sum_legend_height += $wms_zeilenhoehe;
+ //Layer
+ $l = 0; #l temporary parameter to count the layer /Hilfvariable zum durchz�hlen der angezeigten Layer
+ for($j=0; $j<count($my_legendurls); $j++){
+ // url with grouped layers------------------
+ $temp_url = explode('*',$my_legendurls[$j]);
+ $temp_layers = explode('*',$layer[$j]);
+ for ($q=0; $q <count($temp_url);$q++){
+ if($temp_url[$q] == '1' ){ // Layertitle for the parent of grouped layers
+ // add this to the height of the legend /addiere dies zur Gesamth�he Legende
+ $layer_y_position = $pdf->ezText($temp_layers[$q], 11, array('spacing'=>1.2));
+ $layer_zeilenhoehe = $pdf->getFontHeight(12);
+ $sum_legend_height += $layer_zeilenhoehe;
+ }elseif($temp_url[$q] != '0' ){
+ $funktionsaufruf = new SaveLegend($temp_url[$q],$legendFilename);
+ $imgsize = getimagesize($legendFilename);
+ // add this to the height of the legend /addiere dies zur Gesamthoehe der Legende
+ $sum_legend_height += $imgsize[1];
+ //calculate text + picture / Berechnung Groesse Schrift + Bild
+ if($l == 0){
+ $y_position = $wms_y_position;
+ $wms_y_position = '';
+ }else{
+ $y_position = $pdf->ezText("", 1, array('spacing'=>1.2));
+ $layer_zeilenhoehe = $pdf->getFontHeight(11);
+ $next_position = $y_position - $layer_zeilenhoehe - $imgsize[1];
+ // add this to the height of the legend / addiere dies zur Gesamth�he Legende
+ $l = $l+1;
+ // if text + picture are smaler then the lower margin + textsize, then set a space
+ //wenn Schrift + Bild kleiner der unteren Margin + Zeilenhoehe, dann Abstand setzen
+ if($size == "A4" && $format == "portrait" && $next_position <= 35 +$layer_zeilenhoehe){ //90 $layer_zeilenhoehe
+ $space = $layer_zeilenhoehe + $imgsize[1];
+ $pdf->ezSetDy(-$space);
+ if($size == "A4" && $format == "landscape" && $next_position <= 35+$layer_zeilenhoehe){//50
+ //write the header layername / Ueberschrift schreiben
+ $legend = $temp_layers[$q]."\n"; //$layer[$j]."\n";
+ $pdf->ezText($legend, 11, array('spacing'=>1.2));
+ //$pdf->ezText($url, 9, array('spacing'=>1.2));
+ //print the picture / Bild schreiben
+ $pdf->ezImage($legendFilename, 0, 'width', 'none', 'left');
+ unlink($legendFilename);
+ } //if legendurl
+ }// for legendurl
+ //frames (x1, y1, x2, y2)
+ #line
+ $pdf->setLineStyle($linewidth, '', '', array());
+ //left
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border + $header_height);
+ //right
+ //top
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border + $header_height, $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border - $footer_height);
+ //bottom
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border - $footer_height, $mapOffset_left - $border, $mapOffset_bottom - $border - $footer_height);
+ if ($legendImage!=''){
+ //image on top of page
+ $pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border + $header_height - $legendImage_height - 4 , $legendImage_width, $legendImage_height);
+ } else {
+ //left
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom - $border, $mapOffset_left - $border, $mapOffset_bottom + $map_height + $border);
+ //right
+ $pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border);
+ //top
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border , $mapOffset_left + $map_width + $border, $mapOffset_bottom - $border);
+ //bottom
+ $pdf->line($mapOffset_left + $map_width + $border, $mapOffset_bottom -$border , $mapOffset_left - $border, $mapOffset_bottom - $border);
+ $pdf->addPngFromFile($legendImage, $mapOffset_left + $map_width + $border - $legendImage_width -6, $mapOffset_bottom + $map_height + $border - $legendImage_height -4 , $legendImage_width, $legendImage_height);
+ //line under legend (only landscape)
+ //$pdf->line($mapOffset_left - $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 4 , $mapOffset_left + $map_width + $border, $mapOffset_bottom + $map_height + $border - $legendImage_height - 6);
+ }// for layers
+ } //if wms_id not 0
+ }// for wms
+ * USER POLYGON:
+ if($_REQUEST["measured_x_values"] != ""
+ && $_REQUEST["measured_y_values"] != ""
+ && is_file($legendFilenameUserPolygon)) {
+ // load image
+ $myY = $pdf->ezText("<b>temporary Object</b>", 11);
+ $pdf->ezSetDy(-15);
+ $pdf->ezImage($legendFilenameUserPolygon, 5, 17, 'none', 'left');
+ unlink($legendFilenameUserPolygon);
+ $pdf->ezSetY($myY - 7);
+ $pdf->ezText("Element", 11, array("left" => 25));
+ // deletes image
+$pdf->ezText($legendFooter, 11);
+}//legend true
+ end of legend
+ob_clean();
+if($download == false){
+ $pdf->ezStream();
+else{
+ $content = $pdf->ezOutput();
+ $fp = fopen($downloadFile,'w');
+ fwrite($fp,$content);
+ fclose($fp);
+ echo "<html><head></head><body><a href='".$downloadFile."'>".$downloadText."</a></body></html>";
Modified: branches/noframes/http/tools/mod_monitorCapabilities_read.php
--- branches/noframes/http/tools/mod_monitorCapabilities_read.php 2008-10-02 15:29:23 UTC (rev 3099)
+++ branches/noframes/http/tools/mod_monitorCapabilities_read.php 2008-10-03 08:42:59 UTC (rev 3100)
@@ -237,11 +237,11 @@
$str .= "</tr></table></td>";
# $str .= "\n\t\t\t<td><a href='output_".$wms_id[$k]."_".$max.".txt' target=_blank>log</a></td>";
- $str .= "\n\t\t<td><input type=button value='details' onclick=\"var newWindow = window.open('../php/mod_monitorCapabilities_read_single.php?wmsid=".$wms_id[$k]."','wms','width=500,height=700,scrollbars');newWindow.href.location='test.php'\"></td></tr>";
+ $str .= "\n\t\t<td><input type=button value='details' onclick=\"var newWindow = window.open('../tools/mod_monitorCapabilities_read_single.php?wmsid=".$wms_id[$k]."','wms','width=500,height=700,scrollbars');newWindow.href.location='test.php'\"></td></tr>";
$cnt++;
$str .= "\n\t</table>\n\t<br/><input type=hidden name=cbs value='".$cnt."'>\n</form>";
echo $str;
-</body></html>
\ No newline at end of file
+</body></html>
More information about the Mapbender_commits
