[Mapbender-commits] r3108 - branches/noframes/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 3 09:17:48 EDT 2008
Author: nimix
Date: 2008-10-03 09:17:48 -0400 (Fri, 03 Oct 2008)
New Revision: 3108
   branches/noframes/http/javascripts/mod_featureInfoTunnel.php
move getFeatureInfo Code to the FI module
Modified: branches/noframes/http/javascripts/mod_featureInfoTunnel.php
--- branches/noframes/http/javascripts/mod_featureInfoTunnel.php	2008-10-03 13:13:09 UTC (rev 3107)
+++ branches/noframes/http/javascripts/mod_featureInfoTunnel.php	2008-10-03 13:17:48 UTC (rev 3108)
@@ -18,7 +18,17 @@
 # Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
 require_once(dirname(__FILE__)."/../php/mb_validateSession.php");
+include '../include/dyn_js.php';
+//defaults for element vars
+if(typeof(featureInfoLayerPopup)==='undefined')
+	var featureInfoLayerPopup = 'false';
+if(typeof(featureInfoPopupHeight)==='undefined')
+	var featureInfoPopupHeight = '200';
+if(typeof(featureInfoPopupWidth)==='undefined')
+	var featureInfoPopupWidth = '270';
 var mod_featureInfoTunnel_elName = "featureInfoTunnel";
 var mod_featureInfoTunnel_frameName = "";
 var mod_featureInfoTunnel_target = "<?php echo $e_target[0]; ?>";
@@ -54,5 +64,42 @@
 		clickX = e.pageX;
 		clickY = e.pageY;
-	setFeatureInfoRequest(mod_featureInfoTunnel_target,clickX,clickY, '../extensions/ext_featureInfoTunnel.php');
+	eventBeforeFeatureInfo.trigger({"fName":mod_featureInfoTunnel_target});
+	var ind = getMapObjIndexByName(mod_featureInfoTunnel_target);
+	var point = new Point(clickX,clickY);
+	var path = '../extensions/ext_featureInfoTunnel.php';
+//TODO that code should go to featureInfo Redirect module
+	if(document.getElementById("FeatureInfoRedirect")){
+		//fill the frames
+		for(var i=0; i<mb_mapObj[ind].wms.length; i++){
+			var req = mb_mapObj[ind].wms[i].getFeatureInfoRequest(mb_mapObj[ind], point);
+			if(req)
+				window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[ind].wms[i].wms_id).src = path+"?url="+escape(req);
+	else{
+		urls = mb_mapObj[ind].getFeatureInfoRequests(point);
+		if(urls){
+			for(var i=0;i<urls.length;i++){
+				if(featureInfoLayerPopup == 'true'){
+					var p = new mb_popup({
+						title:<?php echo _mb("Informations");?>,
+						url:path+"?url="+escape(urls[i]),
+						width:parseInt(featureInfoPopupWidth, 10),
+						height:parseInt(featureInfoPopupHeight, 10),
+						top:200,
+						left:600
+				else
+					window.open(path+"?url="+escape(urls[i]), "" , "width="+featureInfoPopupWidth+",height="+featureInfoPopupHeight+",scrollbars=yes,resizable=yes");
+		else
+			alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
+//	setFeatureInfoRequest(mod_featureInfoTunnel_target,clickX,clickY, '../extensions/ext_featureInfoTunnel.php');
\ No newline at end of file
More information about the Mapbender_commits mailing list
