[Mapbender-commits] r3112 - branches/noframes/http/javascripts
svn_mapbender at osgeo.org
Fri Oct 3 10:01:48 EDT 2008
Author: christoph
Date: 2008-10-03 10:01:48 -0400 (Fri, 03 Oct 2008)
New Revision: 3112
branches/noframes/http/javascripts/map_obj.js
unique ids
Modified: branches/noframes/http/javascripts/map_obj.js
--- branches/noframes/http/javascripts/map_obj.js 2008-10-03 13:46:14 UTC (rev 3111)
+++ branches/noframes/http/javascripts/map_obj.js 2008-10-03 14:01:48 UTC (rev 3112)
@@ -623,9 +623,9 @@
if (mb_log) {
var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
- var myDivId = "div_" + ii;
+ var myDivId = this.elementName + "_div_" + ii;
writeTag(this.frameName, myDivId, newMapRequest);
- var myMapId = "map_" + ii;
+ var myMapId = this.elementName + "_map_" + ii;
eventAfterMapRequest.trigger({"frameName":this.frameName, "myMapId":myMapId});
return true;
@@ -671,8 +671,8 @@
var getLayerHtmlCode = function (ii) {
var currentWms = that.wms[ii];
+ var myDivId = that.elementName + "_div_" + ii;
+ var myMapId = that.elementName + "_map_" + ii;
//disable Layer which are out of scale
var validLayers = that.checkScale(ii);
More information about the Mapbender_commits
