[Mapbender-commits] r3114 - branches/noframes/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Fri Oct 3 10:21:04 EDT 2008
Author: nimix
Date: 2008-10-03 10:21:04 -0400 (Fri, 03 Oct 2008)
New Revision: 3114
   branches/noframes/http/javascripts/mod_coords_div.php
   branches/noframes/http/javascripts/mod_measure.php
Modified: branches/noframes/http/javascripts/mod_coords_div.php
--- branches/noframes/http/javascripts/mod_coords_div.php	2008-10-03 14:02:24 UTC (rev 3113)
+++ branches/noframes/http/javascripts/mod_coords_div.php	2008-10-03 14:21:04 UTC (rev 3114)
@@ -28,8 +28,11 @@
 var mod_showCoords_div_img_off = new Image(); mod_showCoords_div_img_off.src = "<?php  echo $e_src;  ?>";
 var mod_showCoords_div_img_over = new Image(); mod_showCoords_div_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
 var mod_showCoords_div_fix = "";
+var mod_showCoords_div_mapObj = null;
 function init_mod_showCoords_div(ind){
+	mod_showCoords_div_mapObj = getMapObjByName(mod_showCoords_div_target );
 	mb_button[ind] = document.getElementById(mod_showCoords_div_elName);
 	mb_button[ind].img_over = mod_showCoords_div_img_over.src;
 	mb_button[ind].img_on = mod_showCoords_div_img_on.src;
@@ -41,40 +44,24 @@
 	mb_button[ind].stop = new Function ("mod_showCoords_div_disable()");
 function mod_showCoords_div_run(){
-	window.frames[mod_showCoords_div_target].document.onmousemove = mod_showCoords_div_display;
-	window.frames[mod_showCoords_div_target].document.onclick = mod_showCoords_div_click;
+	mod_showCoords_div_mapObj.getDomElement().onmousemove = mod_showCoords_div_display;
+	mod_showCoords_div_mapObj.getDomElement().onclick = mod_showCoords_div_click;
 function mod_showCoords_div_disable(){
-	window.frames[mod_showCoords_div_target].document.onclick = null;
-	window.frames[mod_showCoords_div_target].document.onmousemove = null;
+	mod_showCoords_div_mapObj.getDomElement().onclick = null;
+	mod_showCoords_div_mapObj.getDomElement().onmousemove = null;
 	if(document.getElementById("dependentDiv")){
 		writeTag("","dependentDiv","");
 function mod_showCoords_div_click(e){
-	if(ie){
-		clickX = window.frames[mod_showCoords_div_target].event.clientX;
-		clickY = window.frames[mod_showCoords_div_target].event.clientY;
-	else{
-		clickX = e.pageX;
-		clickY = e.pageY;
+	mod_showCoords_div_mapObj.getMousePos(e);
 	var pos = makeClickPos2RealWorldPos(mod_showCoords_div_target, clickX, clickY);
 	mod_showCoords_div_fix = "Selection: " + pos[0] + " / " +  pos[1];
 	mod_showCoord_write(pos[0],pos[1]);
 function mod_showCoords_div_display(e){
-	if(ie){
-	else{
-		clickX = e.pageX;
-		clickY = e.pageY;
Modified: branches/noframes/http/javascripts/mod_measure.php
--- branches/noframes/http/javascripts/mod_measure.php	2008-10-03 14:02:24 UTC (rev 3113)
+++ branches/noframes/http/javascripts/mod_measure.php	2008-10-03 14:21:04 UTC (rev 3114)
@@ -34,6 +34,7 @@
 var mod_measure_elName = "measure";
 var mod_measure_frameName = "";
+var mod_measure_mapObj = null;
 var mod_measure_epsg;
 var mod_measure_width;
 var mod_measure_height;
@@ -48,6 +49,29 @@
 var mod_measure_img_over = new Image(); mod_measure_img_over.src = "<?php  echo preg_replace("/_off/","_over",$e_src);  ?>";
 function init_mod_measure(ind){
+	mod_measure_mapObj = getMapObjByName(mod_measure_target);
+	//ensure we have the div elements in Mapframe
+	var map_el = mod_measure_mapObj.getDomElement()
+	if(!map_el.ownerDocument.getElementById(mod_measure_target+"_measure_sub")){
+		el = map_el.ownerDocument.createElement("div");
+		el.style.position = "absolute";
+		el.style.top = "0px";
+		el.style.left = "0px";
+		el.style.zIndex = "16";
+		el.style.fontSize = "10px";
+		el1 = el.cloneNode(false);
+		el2 = el.cloneNode(false);
+		el.id = mod_measure_target+"_measure_sub";
+		el1.id = mod_measure_target+"_measure_display";
+		el2.id = mod_measure_target+"_measuring";
+		map_el.appendChild(el);
+		map_el.appendChild(el1);
+		map_el.appendChild(el2);
 	mb_button[ind] = document.getElementById(mod_measure_elName);
 	mb_button[ind].img_over = mod_measure_img_over.src;
 	mb_button[ind].img_on = mod_measure_img_on.src;
@@ -57,54 +81,55 @@
 	mb_button[ind].fName = mod_measure_frameName;
 	mb_button[ind].go = new Function ("mod_measure_go()");
 	mb_button[ind].stop = new Function ("mod_measure_disable()");
-	var ind = getMapObjIndexByName(mod_measure_target);
-	mod_measure_width = mb_mapObj[ind].width;
-	mod_measure_height = mb_mapObj[ind].height;
-	mod_measure_epsg = mb_mapObj[ind].epsg;
+	mod_measure_width = mod_measure_mapObj.width;
+	mod_measure_height = mod_measure_mapObj.height;
+	mod_measure_epsg = mod_measure_mapObj.epsg;
 	mb_registerSubFunctions("drawDashedLine()");
-	mb_registerPanSubElement("measuring");
+	mb_registerPanSubElement(mod_measure_target+"measuring");
 function register_measureSubFunctions(stringFunction){
 	mod_measureSubFunctions[mod_measureSubFunctions.length] = stringFunction;
 function mod_measure_go(){
-	var el = window.frames[mod_measure_target].document;
+	var el = mod_measure_mapObj.getDomElement();
 	el.onmousedown = mod_measure_start;
 	el.onmousemove = mod_measure_run;
 	el.onmouseover = function () {
-		el.body.style.cursor = 'crosshair';
+		el.style.cursor = 'crosshair';
 	el.onmouseout = function () {
-		el.body.style.cursor = 'auto';
+		el.style.cursor = 'auto';
 	var measureSub = "";
 	for(var i=0; i<mod_measureSubFunctions.length; i++){
 		measureSub += eval(mod_measureSubFunctions[i]);
-	writeTag(mod_measure_target,"measure_sub",measureSub);
+	writeTag(mod_measure_mapObj.frameName,mod_measure_target+"_measure_sub",measureSub);
 function mod_measure_disable(){
 	el.onmousedown = null;
 	el.onmousemove = null;
 	el.onmouseover = null;
 	el.onmouseout = null;
-	writeTag(mod_measure_target,"measure_display","");
-	writeTag(mod_measure_target,"measure_sub","");
+	writeTag(mod_measure_mapObj.frameName,mod_measure_target+"_measure_display","");
+	writeTag(mod_measure_mapObj.frameName,mod_measure_target+"_measure_sub","");
 function mod_measure_timeout(){
 	el.ondblclick = null;
 function mod_measure_disableTimeout(){
 function mod_measure_start(e){
-	mb_getMousePos(e,mod_measure_target);
+	mod_measure_mapObj.getMousePos(e);
 	var realWorldPos = makeClickPos2RealWorldPos(mod_measure_target,clickX,clickY);
 	if(mod_measure_epsg=="EPSG:4326"){
 		mod_measure_RX[mod_measure_RX.length] = realWorldPos[0];
@@ -142,12 +167,11 @@
 function drawDashedLine(){
 	//check if epsg has changed
-	if(mod_measure_epsg != mb_mapObj[ind].epsg){
+	if(mod_measure_epsg != mod_measure_mapObj.epsg){
 		mod_measure_delete();
 	var str_mPoints = "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='"+mod_measure_width+"' height='0'></div>";
 	str_mPoints += "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='0' height='"+mod_measure_height+"'></div>";
@@ -170,7 +194,7 @@
 			str_mPoints += evaluateDashes(pos1[0],pos1[1],pos0[0],pos0[1],k);
-	writeTag(mod_measure_target,"measuring",str_mPoints);
+	writeTag(mod_measure_mapObj.frameName,mod_measure_target+"_measuring",str_mPoints);
 function evaluateDashes(x1,y1,x2,y2,count){
 	var str_dashedLine = "";
@@ -195,7 +219,7 @@
 	return str_dashedLine;
 function mod_measure_run(e){
 	var pos = makeClickPos2RealWorldPos(mod_measure_target,clickX,clickY);
 	var dist;
@@ -213,11 +237,11 @@
 	if(isNaN(dist) == false && clickX > 0 && clickX < mod_measure_width && clickY > 0 && clickY < mod_measure_height){
 		var str_display = "<span style='font-family:"+mod_measure_font+";font-size:"+mod_measure_fontsize+";color:"+mod_measure_color2+";'>"+(Math.round(dist*100)/100)+" m</span>";
-		writeTag(mod_measure_target,"measure_display",str_display);
-		mb_arrangeElement(mod_measure_target,"measure_display",clickX +2, clickY - 10);
+		writeTag(mod_measure_mapObj.frameName, mod_measure_target+"_measure_display",str_display);
+		mb_arrangeElement(mod_measure_mapObj.frameName,mod_measure_target+"_measure_display",clickX +2, clickY - 10);
 	else{
 function mod_measure_close(){
@@ -255,6 +279,6 @@
 	mod_measure_RY = new Array();
 	mod_measure_Dist = new Array();
 	mod_measure_TotalDist = new Array();
-	writeTag(mod_measure_target,"measuring","");
+	writeTag(mod_measure_mapObj.frameName,mod_measure_target+"_measuring","");
\ No newline at end of file
More information about the Mapbender_commits mailing list
