[Mapbender-commits] r3069 - in tags: . 2.5_min/http/extensions 2.5_min/http/extensions/datepicker 2.5_min/http/javascripts
svn_mapbender at osgeo.org svn_mapbender at osgeo.org
Wed Oct 1 04:39:43 EDT 2008
Author: christoph
Date: 2008-10-01 04:39:43 -0400 (Wed, 01 Oct 2008)
New Revision: 3069
Added:
   tags/2.5_min/
   tags/2.5_min/http/extensions/datepicker/datepicker.js
   tags/2.5_min/http/extensions/fisheye.js
   tags/2.5_min/http/extensions/jqjson.js
   tags/2.5_min/http/extensions/jquery.ajaxmanager.js
   tags/2.5_min/http/extensions/jquery.js
   tags/2.5_min/http/extensions/json.js
   tags/2.5_min/http/extensions/wz_jsgraphics.js
   tags/2.5_min/http/javascripts/core.js
   tags/2.5_min/http/javascripts/event.js
   tags/2.5_min/http/javascripts/geometry.js
   tags/2.5_min/http/javascripts/geometry1.1.js
   tags/2.5_min/http/javascripts/jsTree.js
   tags/2.5_min/http/javascripts/map.js
   tags/2.5_min/http/javascripts/map_obj.js
   tags/2.5_min/http/javascripts/mod_addWMSgeneralFunctions.js
   tags/2.5_min/http/javascripts/mod_adminNavigation.js
   tags/2.5_min/http/javascripts/mod_box1.js
   tags/2.5_min/http/javascripts/mod_cardindex.js
   tags/2.5_min/http/javascripts/mod_closePolygon.js
   tags/2.5_min/http/javascripts/mod_closePolygonExt.js
   tags/2.5_min/http/javascripts/mod_displayObj.js
   tags/2.5_min/http/javascripts/mod_horizTabs.js
   tags/2.5_min/http/javascripts/mod_permanentHighlight.js
   tags/2.5_min/http/javascripts/mod_rubber.js
   tags/2.5_min/http/javascripts/mod_rubberExt.js
   tags/2.5_min/http/javascripts/mod_saveWKT.js
   tags/2.5_min/http/javascripts/mod_tab.js
   tags/2.5_min/http/javascripts/mod_treeConf.js
   tags/2.5_min/http/javascripts/point.js
   tags/2.5_min/http/javascripts/popup.js
   tags/2.5_min/http/javascripts/requestGeometryConstructor.js
   tags/2.5_min/http/javascripts/style.js
   tags/2.5_min/http/javascripts/wfs.js
   tags/2.5_min/http/javascripts/wfs_obj.js
this is the build script creating a tag for version 2.5 (minified, checksums)
Copied: tags/2.5_min (from rev 3067, branches/2.5)
Modified: tags/2.5_min/http/extensions/datepicker/datepicker.js
--- branches/2.5/http/extensions/datepicker/datepicker.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/extensions/datepicker/datepicker.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,110 +1,19 @@
-var monthDays=new Array(31,28,31,30,31,30,31,31,30,31,30,31);
-var currDate=new Date();
-var showDate=new Date();
-var target = window.opener.dTarget;
-showDate.setDate(1);
-function writeY() {
-  for(i=2000; i<2021; i++) {
-	document.write('<option value='+i+'>'+i+'<\/option>');
-function writeM() {
-  for(i=0; i<12; i++) {
-		var j = i + 1;
-		document.write('<option value='+j+'>'+monthNames[i]+'</option>');
-function picker() {
-  document.frm.lYears.selectedIndex = showDate.getFullYear() - 2000;
-  document.frm.lMonths.selectedIndex = showDate.getMonth();
-  var d = lenM(showDate);
-  var y = showDate.getFullYear() - 2000;
-	var begin = showDate.getDay() - 1;
-	if(begin < 0) begin += 7;
-  for(i=0; i<42; i++) {
-    btn=document.frm.elements['btn'+(i+1)];
-    if(i<begin) {
-      btn.value='';
-    else if(i>=begin+d) {
-      btn.value='';
-    else {
-      btn.style.color='black';
-      btn.value=i-begin+1;
-function go(x){
-	var out;
-	if(x){
-		if (x =='x'){
-			out = twoDigits(currDate.getDate()) + '.' + (twoDigits(currDate.getMonth()+1)) + '.' + currDate.getFullYear();
-		else{
-  		out = twoDigits(x) + '.' + (twoDigits(showDate.getMonth()+1)) + '.' + showDate.getFullYear();
-		target.value = out;
-		close();
-function twoDigits(x){
-	x = '0' + x;
-	return x.match(/\d\d$/);
-function lenM(dt) {
-  var m = dt.getMonth();
-	var d = monthDays[m];
-  if(m == 1 && !(dt.getFullYear() % 4)) {
-    d=29;
-  return d;
-function setDate(y, m) {
-  showDate.setFullYear(y);
-  showDate.setMonth(m);
-function selMonth(m) {
-  picker();
-function selYear(y) {
-  showDate.setFullYear(y+2000);
-  picker();
-function prevMonth() {
-  var m=showDate.getMonth()-1;
-  var y=showDate.getFullYear();
-  if(m<0) {
-    m=11;
-    y--;
-    if(y<2000) y=2020;
-  setDate(y, m);
-  picker();
-function nextMonth() {
-  var m=showDate.getMonth()+1;
-  if(m>11) {
-    m=0;
-    y++;
-    if(y>2020) y=2000;
-  setDate(y, m);
-  picker();
+var monthDays=new Array(31,28,31,30,31,30,31,31,30,31,30,31);var currDate=new Date();var showDate=new Date();var target=window.opener.dTarget;showDate.setDate(1);function writeY(){for(i=2000;i<2021;i++){document.write('<option value='+i+'>'+i+'<\/option>');}}
+function writeM(){for(i=0;i<12;i++){var j=i+1;document.write('<option value='+j+'>'+monthNames[i]+'</option>');}}
+function picker(){document.frm.lYears.selectedIndex=showDate.getFullYear()-2000;document.frm.lMonths.selectedIndex=showDate.getMonth();var d=lenM(showDate);var y=showDate.getFullYear()-2000;var begin=showDate.getDay()-1;if(begin<0)begin+=7;for(i=0;i<42;i++){btn=document.frm.elements['btn'+(i+1)];if(i<begin){btn.value='';}
+else if(i>=begin+d){btn.value='';}
+else{btn.style.color='black';btn.value=i-begin+1;}}}
+function go(x){var out;if(x){if(x=='x'){out=twoDigits(currDate.getDate())+'.'+(twoDigits(currDate.getMonth()+1))+'.'+currDate.getFullYear();}
+else{out=twoDigits(x)+'.'+(twoDigits(showDate.getMonth()+1))+'.'+showDate.getFullYear();}
+target.value=out;close();}}
+function twoDigits(x){x='0'+x;return x.match(/\d\d$/);}
+function lenM(dt){var m=dt.getMonth();var d=monthDays[m];if(m==1&&!(dt.getFullYear()%4)){d=29;}
+return d;}
+function setDate(y,m){showDate.setFullYear(y);showDate.setMonth(m);}
+function selMonth(m){showDate.setMonth(m);picker();}
+function selYear(y){showDate.setFullYear(y+2000);picker();}
+function prevMonth(){var m=showDate.getMonth()-1;var y=showDate.getFullYear();if(m<0){m=11;y--;if(y<2000)y=2020;}
+setDate(y,m);picker();}
+function nextMonth(){var m=showDate.getMonth()+1;var y=showDate.getFullYear();if(m>11){m=0;y++;if(y>2020)y=2000;}
\ No newline at end of file
Modified: tags/2.5_min/http/extensions/fisheye.js
--- branches/2.5/http/extensions/fisheye.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/extensions/fisheye.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,8 +1,2 @@
- * Interface elements for jQuery - http://interface.eyecon.ro
- * Copyright (c) 2006 Stefan Petre
- * Dual licensed under the MIT (MIT-LICENSE.txt)
- * and GPL (GPL-LICENSE.txt) licenses.
- eval(function(p,a,c,k,e,d){e=function(c){return(c<a?'':e(parseInt(c/a)))+((c=c%a)>35?String.fromCharCode(c+29):c.toString(36))};if(!''.replace(/^/,String)){while(c--){d[e(c)]=k[c]||e(c)}k=[function(e){return d[e]}];e=function(){return'\\w+'};c=1};while(c--){if(k[c]){p=p.replace(new RegExp('\\b'+e(c)+'\\b','g'),k[c])}}return p}('6.15={3o:d(e){7 x=0;7 y=0;7 1Q=1A;7 A=e.L;8(6(e).H(\'Q\')==\'U\'){1E=A.1a;2y=A.O;A.1a=\'1F\';A.Q=\'1Y\';A.O=\'2e\';1Q=26}7 4=e;2P(4){x+=4.3B+(4.1I&&!6.3p.41?F(4.1I.2X)||0:0);y+=4.3x+(4.1I&&!6.3p.41?F(4.1I.2Z)||0:0);4=4.4e}4=e;2P(4&&4.4a&&4.4a.39()!=\'V\'){x-=4.1D||0;y-=4.1s||0;4=4.2x}8(1Q){A.Q=\'U\';A.O=2y;A.1a=1E}q{x:x,y:y}},4E:d(4){7 x=0,y=0;2P(4){x+=4.3B||0;y+=4.3x||0;4=4.4e}q{x:x,y:y}},35:d(e){7 w=6.H(e,\'1T\');7 h=6.H(e,\'36\');7 1e=0;7 1o=0;7 A=e.L;8(6(e).H(\'Q\')!=\'U\'){1e=e.1z;1o=e.2s}u{1E=A.1a;2y=A.O;A.1a=\'1F\';A.Q=\'1Y\';A.O=\'2e\';1e=e.1z;1o=e.2s;A.Q=\'U\';A.O=2y;A.1a=1E}q{w:w,h:h,1e:1e,1o:1o}},4P:d(4){q{1e:4.1z||0,1o:4.2s||0}},58:d(e){7 h,w,22;8(e){w=e.2a;h=e.29}u{22=D.Y;w=2z.3c||2N.3c||(22&&22.2a)||D.V.2a;h=2z.31||2N.31||(22&&22.29)||D.V.29}q{w:w,h:h}},3P:d(e){7 t,l,w,h,1J,1R;8(e&&e.2E.39()!=\'V\'){t=e.1s;l=e.1D;w=e.3j;h=e.3e;1J=0;1R=0}u{8(D.Y&&D.Y.1s){t=D.Y.1s;l=D.Y.1D;w=D.Y.3j;h=D.Y.3e}u 8(D.V){t=D.V.1s;l=D.V.1D;w=D.V.3j;h=D.V.3e}1J=2N.3c||D.Y.2a||D.V.2a||0;1R=2N.31||D.Y.29||D.V.29||0}q{t:t,l:l,w:w,h:h,1J:1J,1R:1R}},3L:d(e,1U){7 4=6(e);7 t=4.H(\'2j\')||\'\';7 r=4.H(\'2k\')||\'\';7 b=4.H(\'2n\')||\'\';7 l=4.H(\'2l\')||\'\';8(1U)q{t:F(t)||0,r:F(r)||0,b:F(b)||0,l:F(l)};u q{t:t,r:r,b:b,l:l}},56:d(e,1U){7 4=6(e);7 t=4.H(\'3w\')||\'\';7 r=4.H(\'3u\')||\'\';7 b=4.H(\'3s\')||\'\';7 l=4.H(\'3t\')||\'\';8(1U)q{t:F(t)||0,r:F(r)||0,b:F(b)||0,l:F(l)};u q{t:t,r:r,b:b,l:l}},4Z:d(e,1U){7 4=6(e);7 t=4.H(\'2Z\')||\'\';7 r=4.H(\'3G\')||\'\';7 b=4.H(\'3y\')||\'\';7 l=4.H(\'2X\')||\'\';8(1U)q{t:F(t)||0,r:F(r)||0,b:F(b)||0,l:F(l)||0};u q{t:t,r:r,b:b,l:l}},3T:d(2i){7 x=2i.53||(2i.52+(D.Y.1D||D.V.1D))||0;7 y=2i.51||(2i.54+(D.Y.1s||D.V.1s))||0;q{x:x,y:y}},3h:d(12,3g){3g(12);12=12.3F;2P(12){6.15.3h(12,3g);12=12.5a}},59:d(12){6.15.3h(12,d(4){S(7 1j 1q 4){8(2R 4[1j]===\'d\'){4[1j]=20}}})},57:d(4,27){7 1b=$.15.3P();7 3l=$.15.35(4);8(!27||27==\'4Y\')$(4).H({X:1b.t+((1i.3S(1b.h,1b.1R)-1b.t-3l.1o)/2)+\'K\'});8(!27||27==\'4Q\')$(4).H({N:1b.l+((1i.3S(1b.w,1b.1J)-1b.l-3l.1e)/2)+\'K\'})},4O:d(4,3U){7 3V=$(\'3q[@2u*="2w"]\',4||D),2w;3V.1V(d(){2w=k.2u;k.2u=3U;k.L.4M="4N:4R.4S.4W(2u=\'"+2w+"\')"})}};[].4i||(4V.4U.4i=d(v,n){n=(n==20)?0:n;7 m=k.1m;S(7 i=n;i<m;i++)8(k[i]==v)q i;q-1});6.3A=d(e){8(/^4T$|^4L$|^5b$|^5c$|^5t$|^5s$|^5r$|^5q$|^5u$|^V$|^5v$|^5z$|^5y$|^5x$|^5w$|^5p$|^5o$/i.2q(e.2E))q 1A;u q 26};6.E.5h=d(e,1p){7 c=e.3F;7 1d=c.L;1d.O=1p.O;1d.2j=1p.18.t;1d.2l=1p.18.l;1d.2n=1p.18.b;1d.2k=1p.18.r;1d.X=1p.X+\'K\';1d.N=1p.N+\'K\';e.2x.4f(c,e);e.2x.5g(e)};6.E.5f=d(e){8(!6.3A(e))q 1A;7 t=6(e);7 A=e.L;7 1Q=1A;7 J={};J.O=t.H(\'O\');8(t.H(\'Q\')==\'U\'){1E=t.H(\'1a\');A.1a=\'1F\';A.Q=\'\';1Q=26}J.32=6.15.35(e);J.18=6.15.3L(e);7 2Y=e.1I?e.1I.4g:t.H(\'5d\');J.X=F(t.H(\'X\'))||0;J.N=F(t.H(\'N\'))||0;7 3J=\'5e\'+F(1i.5i()*4p);7 1x=D.5j(/^3q$|^5n$|^5m$|^5l$|^5k$|^5A$|^2V$|^4u$|^4y$|^4z$|^4x$|^4v$|^4s$|^4H$/i.2q(e.2E)?\'4J\':e.2E);6.1j(1x,\'4F\',3J);1x.3X=\'4B\';7 R=1x.L;7 X=0;7 N=0;8(J.O==\'33\'||J.O==\'2e\'){X=J.X;N=J.N}R.Q=\'U\';R.X=X+\'K\';R.N=N+\'K\';R.O=J.O!=\'33\'&&J.O!=\'2e\'?\'33\':J.O;R.2K=\'1F\';R.36=J.32.1o+\'K\';R.1T=J.32.1e+\'K\';R.2j=J.18.t;R.2k=J.18.r;R.2n=J.18.b;R.2l=J.18.l;8(6.3p.4G){R.4g=2Y}u{R.4D=2Y}e.2x.4f(1x,e);A.2j=\'1M\';A.2k=\'1M\';A.2n=\'1M\';A.2l=\'1M\';A.O=\'2e\';A.4C=\'U\';A.X=\'1M\';A.N=\'1M\';8(1Q){A.Q=\'U\';A.1a=1E}1x.4A(e);R.Q=\'1Y\';q{J:J,4I:6(1x)}};6.E.2f={4K:[0,B,B],4r:[3E,B,B],4w:[4l,4l,4t],4X:[0,0,0],60:[0,0,B],6P:[3H,42,42],6O:[0,B,B],6N:[0,0,1L],6L:[0,1L,1L],6M:[3b,3b,3b],6Q:[0,6R,0],6W:[6V,6U,4k],6S:[1L,0,1L],6T:[6K,4k,47],6J:[B,3I,0],6B:[6A,50,6z],6x:[1L,0,0],6Y:[6C,6D,6I],6H:[6G,0,2U],6E:[B,0,B],6F:[B,6X,0],7a:[0,1v,0],7j:[75,0,7i],7f:[3E,3v,3I],7e:[7h,7l,3v],7g:[3r,B,B],7c:[4c,7d,4c],72:[2U,2U,2U],71:[B,70,74],76:[B,B,3r],7b:[0,B,0],79:[B,0,B],77:[1v,0,0],78:[0,0,1v],6Z:[1v,1v,0],73:[B,3H,0],7k:[B,2I,6y],6v:[1v,0,1v],5V:[B,0,0],5U:[2I,2I,2I],5T:[B,B,B],5R:[B,B,0]};6.E.1w=d(16,3z){8(6.E.2f[16])q{r:6.E.2f[16][0],g:6.E.2f[16][1],b:6.E.2f[16][2]};u 8(M=/^1N\\(\\s*([0-9]{1,3})\\s*,\\s*([0-9]{1,3})\\s*,\\s*([0-9]{1,3})\\s*\\)$/.2A(16))q{r:F(M[1]),g:F(M[2]),b:F(M[3])};u 8(M=/1N\\(\\s*([0-9]+(?:\\.[0-9]+)?)\\%\\s*,\\s*([0-9]+(?:\\.[0-9]+)?)\\%\\s*,\\s*([0-9]+(?:\\.[0-9]+)?)\\%\\s*\\)$/.2A(16))q{r:Z(M[1])*2.55,g:Z(M[2])*2.55,b:Z(M[3])*2.55};u 8(M=/^#([a-1H-1B-9])([a-1H-1B-9])([a-1H-1B-9])$/.2A(16))q{r:F("1C"+M[1]+M[1]),g:F("1C"+M[2]+M[2]),b:F("1C"+M[3]+M[3])};u 8(M=/^#([a-1H-1B-9]{2})([a-1H-1B-9]{2})([a-1H-1B-9]{2})$/.2A(16))q{r:F("1C"+M[1]),g:F("1C"+M[2]),b:F("1C"+M[3])};u q 3z==26?1A:{r:B,g:B,b:B}};6.E.4n={3y:1,2X:1,3G:1,2Z:1,5S:1,5B:1,36:1,N:1,5W:1,5X:1,2n:1,2l:1,2k:1,2j:1,62:1,2T:1,61:1,6w:1,1f:1,5Y:1,5Z:1,3s:1,3t:1,3u:1,3w:1,38:1,5Q:1,X:1,1T:1,2O:1};6.E.49={5P:1,5G:1,5H:1,5F:1,5E:1,16:1,5C:1};6.E.25=[\'5D\',\'5I\',\'5J\',\'5O\'];6.E.3k={\'3d\':[\'24\',\'3W\'],\'2B\':[\'24\',\'3f\'],\'2D\':[\'2D\',\'\'],\'2C\':[\'2C\',\'\']};6.3Q.4b({5N:d(1h,1G,P,2v){q k.2d(d(){7 2t=6.1G(1G,P,2v);7 e=28 6.4m(k,2t,1h)})},37:d(1G,2v){q k.2d(d(){7 2t=6.1G(1G,2v);7 e=28 6.37(k,2t)})},5M:d(14){q k.1V(d(){8(k.1n)6.3m(k,14)})},5K:d(14){q k.1V(d(){8(k.1n)6.3m(k,14);8(k.2d&&k.2d[\'E\'])k.2d.E=[]})}});6.4b({37:d(C,o){7 z=k,4o;z.14=d(){8(6.43(o.2M))o.2M.3Z(C)};z.2h=3O(d(){z.14()},o.1k);C.1n=z},P:{4q:d(p,n,4j,4d,1k){q((-1i.5L(p*1i.63)/2)+0.5)*4d+4j}},4m:d(C,o,1h){7 z=k,4o;7 y=C.L;7 44=6.H(C,"2K");7 1O=6.H(C,"Q");7 G={};z.2L=(28 46()).48();o.P=o.P&&6.P[o.P]?o.P:\'4q\';z.2Q=d(I,W){8(6.E.4n[I]){8(W==\'2H\'||W==\'2G\'||W==\'3N\'){8(!C.1r)C.1r={};7 r=Z(6.1y(C,I));C.1r[I]=r&&r>-4p?r:(Z(6.H(C,I))||0);W=W==\'3N\'?(1O==\'U\'?\'2H\':\'2G\'):W;o[W]=26;G[I]=W==\'2H\'?[0,C.1r[I]]:[C.1r[I],0];8(I!=\'1f\')y[I]=G[I][0]+(I!=\'2O\'&&I!=\'34\'?\'K\':\'\');u 6.1j(y,"1f",G[I][0])}u{G[I]=[Z(6.1y(C,I)),Z(W)||0]}}u 8(6.E.49[I])G[I]=[6.E.1w(6.1y(C,I)),6.E.1w(W)];u 8(/^2D$|2C$|24$|2B$|3d$/i.2q(I)){7 m=W.1t(/\\s+/g,\' \').1t(/1N\\s*\\(\\s*/g,\'1N(\').1t(/\\s*,\\s*/g,\',\').1t(/\\s*\\)/g,\')\').64(/([^\\s]+)/g);6n(I){2b\'2D\':2b\'2C\':2b\'3d\':2b\'2B\':m[3]=m[3]||m[1]||m[0];m[2]=m[2]||m[0];m[1]=m[1]||m[0];S(7 i=0;i<6.E.25.1m;i++){7 1l=6.E.3k[I][0]+6.E.25[i]+6.E.3k[I][1];G[1l]=I==\'2B\'?[6.E.1w(6.1y(C,1l)),6.E.1w(m[i])]:[Z(6.1y(C,1l)),Z(m[i])]}3R;2b\'24\':S(7 i=0;i<m.1m;i++){7 3n=Z(m[i]);7 2r=!6m(3n)?\'3W\':(!/6l|U|1F|6j|6k|6o|6p|6u|6t|6s|6q/i.2q(m[i])?\'3f\':1A);8(2r){S(7 j=0;j<6.E.25.1m;j++){1l=\'24\'+6.E.25[j]+2r;G[1l]=2r==\'3f\'?[6.E.1w(6.1y(C,1l)),6.E.1w(m[i])]:[Z(6.1y(C,1l)),3n]}}u{y[\'6r\']=m[i]}}3R}}u{y[I]=W}q 1A};S(p 1q 1h){8(p==\'L\'){7 1c=6.30(1h[p]);S(1P 1q 1c){k.2Q(1P,1c[1P])}}u 8(p==\'3X\'){8(D.2S)S(7 i=0;i<D.2S.1m;i++){7 1K=D.2S[i].1K||D.2S[i].6i||20;8(1K){S(7 j=0;j<1K.1m;j++){8(1K[j].6h==\'.\'+1h[p]){7 1X=28 69(\'\\.\'+1h[p]+\' {\');7 1g=1K[j].L.68;7 1c=6.30(1g.1t(1X,\'\').1t(/}/g,\'\'));S(1P 1q 1c){k.2Q(1P,1c[1P])}}}}}}u{k.2Q(p,1h[p])}}y.Q=1O==\'U\'?\'1Y\':1O;y.2K=\'1F\';z.14=d(){7 t=(28 46()).48();8(t>o.1k+z.2L){4h(z.2h);z.2h=20;S(p 1q G){8(p=="1f")6.1j(y,"1f",G[p][1]);u 8(2R G[p][1]==\'2V\')y[p]=\'1N(\'+G[p][1].r+\',\'+G[p][1].g+\',\'+G[p][1].b+\')\';u y[p]=G[p][1]+(p!=\'2O\'&&p!=\'34\'?\'K\':\'\')}8(o.2G||o.2H)S(7 p 1q C.1r)8(p=="1f")6.1j(y,p,C.1r[p]);u y[p]="";y.Q=o.2G?\'U\':(1O!=\'U\'?1O:\'1Y\');y.2K=44;C.1n=20;8(6.43(o.2M))o.2M.3Z(C)}u{7 n=t-k.2L;7 2c=n/o.1k;S(p 1q G){8(2R G[p][1]==\'2V\'){y[p]=\'1N(\'+F(6.P[o.P](2c,n,G[p][0].r,(G[p][1].r-G[p][0].r),o.1k))+\',\'+F(6.P[o.P](2c,n,G[p][0].g,(G[p][1].g-G[p][0].g),o.1k))+\',\'+F(6.P[o.P](2c,n,G[p][0].b,(G[p][1].b-G[p][0].b),o.1k))+\')\'}u{7 2W=6.P[o.P](2c,n,G[p][0],(G[p][1]-G[p][0]),o.1k);8(p=="1f")6.1j(y,"1f",2W);u y[p]=2W+(p!=\'2O\'&&p!=\'34\'?\'K\':\'\')}}}};z.2h=3O(d(){z.14()},13);C.1n=z},3m:d(C,14){8(14)C.1n.2L-=67;u{2z.4h(C.1n.2h);C.1n=20;6.65(C,"E")}}});6.30=d(1g){7 1c={};8(2R 1g==\'66\'){1g=1g.39().40(\';\');S(7 i=0;i<1g.1m;i++){1X=1g[i].40(\':\');8(1X.1m==2){1c[6.45(1X[0].1t(/\\-(\\w)/g,d(m,c){q c.6a()}))]=6.45(1X[1])}}}q 1c};6.1u={3K:d(o){q k.1V(d(){7 4=k;4.f={10:6(o.10,k),23:6(o.23,k),21:6.15.3o(k),T:o.T,2p:o.2p,1Z:o.1Z,3Y:o.3Y,17:o.17,2T:o.2T};6.1u.2J(4,0);6(2z).2F(\'6b\',d(){4.f.21=6.15.3o(4);6.1u.2J(4,0);6.1u.3i(4)});6.1u.3i(4);4.f.10.2F(\'6g\',d(){6(4.f.2p,k).1S(0).L.Q=\'1Y\'}).2F(\'6f\',d(){6(4.f.2p,k).1S(0).L.Q=\'U\'});6(D).2F(\'6e\',d(e){7 2g=6.15.3T(e);7 19=0;8(4.f.17&&4.f.17==\'3M\')7 2o=2g.x-4.f.21.x-(4.1z-4.f.T*4.f.10.1W())/2-4.f.T/2;u 8(4.f.17&&4.f.17==\'38\')7 2o=2g.x-4.f.21.x-4.1z+4.f.T*4.f.10.1W();u 7 2o=2g.x-4.f.21.x;7 3D=1i.3C(2g.y-4.f.21.y-4.2s/2,2);4.f.10.1V(d(2m){11=1i.6c(1i.3C(2o-2m*4.f.T,2)+3D);11-=4.f.T/2;11=11<0?0:11;11=11>4.f.1Z?4.f.1Z:11;11=4.f.1Z-11;3a=4.f.2T*11/4.f.1Z;k.L.1T=4.f.T+3a+\'K\';k.L.N=4.f.T*2m+19+\'K\';19+=3a});6.1u.2J(4,19)})})},2J:d(4,19){8(4.f.17)8(4.f.17==\'3M\')4.f.23.1S(0).L.N=(4.1z-4.f.T*4.f.10.1W())/2-19/2+\'K\';u 8(4.f.17==\'N\')4.f.23.1S(0).L.N=-19/4.f.10.1W()+\'K\';u 8(4.f.17==\'38\')4.f.23.1S(0).L.N=(4.1z-4.f.T*4.f.10.1W())-19/2+\'K\';4.f.23.1S(0).L.1T=4.f.T*4.f.10.1W()+19+\'K\'},3i:d(4){4.f.10.1V(d(2m){k.L.1T=4.f.T+\'K\';k.L.N=4.f.T*2m+\'K\'})}};6.3Q.6d=6.1u.3K;',62,456,'||||el||jQuery|var|if|||||function||fisheyeCfg|||||this||||options||return||||else||||||es|255|elem|document|fx|parseInt|props|css|tp|oldStyle|px|style|result|left|position|easing|display|wrs|for|itemWidth|none|body|vp|top|documentElement|parseFloat|items|distance|nodeEl||step|iUtil|color|halign|margins|toAdd|visibility|clientScroll|newStyles|cs|wb|opacity|styles|prop|Math|attr|duration|nmp|length|animationHandler|hb|old|in|orig|scrollTop|replace|iFisheye|128|parseColor|wr|curCSS|offsetWidth|false|F0|0x|scrollLeft|oldVisibility|hidden|speed|fA|currentStyle|iw|cssRules|139|0px|rgb|oldDisplay|np|restoreStyle|ih|get|width|toInteger|each|size|rule|block|proximity|null|pos|de|container|border|cssSides|true|axis|new|clientHeight|clientWidth|case|pr|queue|absolute|namedColors|pointer|timer|event|marginTop|marginRight|marginLeft|nr|marginBottom|posx|itemsText|test|sideEnd|offsetHeight|opt|src|callback|png|parentNode|oldPosition|window|exec|borderColor|padding|margin|nodeName|bind|hide|show|192|positionContainer|overflow|startTime|complete|self|zIndex|while|getValues|typeof|styleSheets|maxWidth|211|object|pValue|borderLeftWidth|oldFloat|borderTopWidth|parseStyle|innerHeight|sizes|relative|fontWeight|getSize|height|pause|right|toLowerCase|extraWidth|169|innerWidth|borderWidth|scrollHeight|Color|func|traverseDOM|positionItems|scrollWidth|cssSidesEnd|windowSize|stopAnim|floatVal|getPosition|browser|img|224|paddingBottom|paddingLeft|paddingRight|230|paddingTop|offsetTop|borderBottomWidth|notColor|fxCheckTag|offsetLeft|pow|posy|240|firstChild|borderRightWidth|165|140|wid|build|getMargins|center|toggle|setInterval|getScroll|fn|break|max|getPointer|emptyGIF|images|Width|className|valign|apply|split|opera||isFunction|oldOverflow|trim|Date||getTime|colorCssProps|tagName|extend|144|delta|offsetParent|insertBefore|styleFloat|clearInterval|indexOf|firstNum|107|245|fxe|cssProps|values|10000|linear|azure|dl|220|iframe|ul|beige|table|button|form|appendChild|fxWrapper|listStyle|cssFloat|getPositionLite|id|msie|ol|wrapper|div|aqua|td|filter|progid|fixPNG|getSizeLite|horizontally|DXImageTransform|Microsoft|tr|prototype|Array|AlphaImageLoader|black|vertically|getBorder||pageY|clientX|pageX|clientY||getPadding|centerEl|getClient|purgeEvents|nextSibling|tbody|caption|float|w_|buildWrapper|removeChild|destroyWrapper|random|createElement|select|hr|input|br|meta|optgroup|colgroup|col|tfoot|thead|th|header|option|frameset|frame|script|textarea|fontSize|outlineColor|Top|borderTopColor|borderRightColor|borderBottomColor|borderLeftColor|Right|Bottom|stopAll|cos|stop|animate|Left|backgroundColor|textIndent|yellow|bottom|white|silver|red|letterSpacing|lineHeight|outlineOffset|outlineWidth|blue|minHeight|maxHeight|PI|match|dequeue|string|100000000|cssText|RegExp|toUpperCase|resize|sqrt|Fisheye|mousemove|mouseout|mouseover|selectorText|rules|dotted|dashed|transparent|isNaN|switch|solid|double|outset|borderStyle|inset|ridge|groove|purple|minWidth|darkred|203|204|153|darkorchid|233|150|fuchsia|gold|148|darkviolet|122|darkorange|85|darkcyan|darkgrey|darkblue|cyan|brown|darkgreen|100|darkmagenta|darkolivegreen|183|189|darkkhaki|215|darksalmon|olive|182|lightpink|lightgrey|orange|193||lightyellow|maroon|navy|magenta|green|lime|lightgreen|238|lightblue|khaki|lightcyan|173|130|indigo|pink|216'.split('|'),0,{}))
+eval(function(p,a,c,k,e,d){e=function(c){return(c<a?'':e(parseInt(c/a)))+((c=c%a)>35?String.fromCharCode(c+29):c.toString(36))};if(!''.replace(/^/,String)){while(c--){d[e(c)]=k[c]||e(c)}k=[function(e){return d[e]}];e=function(){return'\\w+'};c=1};while(c--){if(k[c]){p=p.replace(new RegExp('\\b'+e(c)+'\\b','g'),k[c])}}return p}('6.15={3o:d(e){7 x=0;7 y=0;7 1Q=1A;7 A=e.L;8(6(e).H(\'Q\')==\'U\'){1E=A.1a;2y=A.O;A.1a=\'1F\';A.Q=\'1Y\';A.O=\'2e\';1Q=26}7 4=e;2P(4){x+=4.3B+(4.1I&&!6.3p.41?F(4.1I.2X)||0:0);y+=4.3x+(4.1I&&!6.3p.41?F(4.1I.2Z)||0:0);4=4.4e}4=e;2P(4&&4.4a&&4.4a.39()!=\'V\'){x-=4.1D||0;y-=4.1s||0;4=4.2x}8(1Q){A.Q=\'U\';A.O=2y;A.1a=1E}q{x:x,y:y}},4E:d(4){7 x=0,y=0;2P(4){x+=4.3B||0;y+=4.3x||0;4=4.4e}q{x:x,y:y}},35:d(e){7 w=6.H(e,\'1T\');7 h=6.H(e,\'36\');7 1e=0;7 1o=0;7 A=e.L;8(6(e).H(\'Q\')!=\'U\'){1e=e.1z;1o=e.2s}u{1E=A.1a;2y=A.O;A.1a=\'1F\';A.Q=\'1Y\';A.O=\'2e\';1e=e.1z;1o=e.2s;A.Q=\'U\';A.O=2y;A.1a=1E}q{w:w,h:h,1e:1e,1o:1o}},4P:d(4){q{1e:4.1z||0,1o:4.2s||0}},58:d(e){7 h,w,22;8(e){w=e.2a;h=e.29}u{22=D.Y;w=2z.3c||2N.3c||(22&&22.2a)||D.V.2a;h=2z.31||2N.31||(22&&22.29)||D.V.29}q{w:w,h:h}},3P:d(e){7 t,l,w,h,1J,1R;8(e&&e.2E.39()!=\'V\'){t=e.1s;l=e.1D;w=e.3j;h=e.3e;1J=0;1R=0}u{8(D.Y&&D.Y.1s){t=D.Y.1s;l=D.Y.1D;w=D.Y.3j;h=D.Y.3e}u 8(D.V){t=D.V.1s;l=D.V.1D;w=D.V.3j;h=D.V.3e}1J=2N.3c||D.Y.2a||D.V.2a||0;1R=2N.31||D.Y.29||D.V.29||0}q{t:t,l:l,w:w,h:h,1J:1J,1R:1R}},3L:d(e,1U){7 4=6(e);7 t=4.H(\'2j\')||\'\';7 r=4.H(\'2k\')||\'\';7 b=4.H(\'2n\')||\'\';7 l=4.H(\'2l\')||\'\';8(1U)q{t:F(t)||0,r:F(r)||0,b:F(b)||0,l:F(l)};u q{t:t,r:r,b:b,l:l}},56:d(e,1U){7 4=6(e);7 t=4.H(\'3w\')||\'\';7 r=4.H(\'3u\')||\'\';7 b=4.H(\'3s\')||\'\';7 l=4.H(\'3t\')||\'\';8(1U)q{t:F(t)||0,r:F(r)||0,b:F(b)||0,l:F(l)};u q{t:t,r:r,b:b,l:l}},4Z:d(e,1U){7 4=6(e);7 t=4.H(\'2Z\')||\'\';7 r=4.H(\'3G\')||\'\';7 b=4.H(\'3y\')||\'\';7 l=4.H(\'2X\')||\'\';8(1U)q{t:F(t)||0,r:F(r)||0,b:F(b)||0,l:F(l)||0};u q{t:t,r:r,b:b,l:l}},3T:d(2i){7 x=2i.53||(2i.52+(D.Y.1D||D.V.1D))||0;7 y=2i.51||(2i.54+(D.Y.1s||D.V.1s))||0;q{x:x,y:y}},3h:d(12,3g){3g(12);12=12.3F;2P(12){6.15.3h(12,3g);12=12.5a}},59:d(12){6.15.3h(12,d(4){S(7 1j 1q 4){8(2R 4[1j]===\'d\'){4[1j]=20}}})},57:d(4,27){7 1b=$.15.3P();7 3l=$.15.35(4);8(!27||27==\'4Y\')$(4).H({X:1b.t+((1i.3S(1b.h,1b.1R)-1b.t-3l.1o)/2)+\'K\'});8(!27||27==\'4Q\')$(4).H({N:1b.l+((1i.3S(1b.w,1b.1J)-1b.l-3l.1e)/2)+\'K\'})},4O:d(4,3U){7 3V=$(\'3q[@2u*="2w"]\',4||D),2w;3V.1V(d(){2w=k.2u;k.2u=3U;k.L.4M="4N:4R.4S.4W(2u=\'"+2w+"\')"})}};[].4i||(4V.4U.4i=d(v,n){n=(n==20)?0:n;7 m=k.1m;S(7 i=n;i<m;i++)8(k[i]==v)q i;q-1});6.3A=d(e){8(/^4T$|^4L$|^5b$|^5c$|^5t$|^5s$|^5r$|^5q$|^5u$|^V$|^5v$|^5z$|^5y$|^5x$|^5w$|^5p$|^5o$/i.2q(e.2E))q 1A;u q 26};6.E.5h=d(e,1p){7 c=e.3F;7 1d=c.L;1d.O=1p.O;1d.2j=1p.18.t;1d.2l=1p.18.l;1d.2n=1p.18.b;1d.2k=1p.18.r;1d.X=1p.X+\'K\';1d.N=1p.N+\'K\';e.2x.4f(c,e);e.2x.5g(e)};6.E.5f=d(e){8(!6.3A(e))q 1A;7 t=6(e);7 A=e.L;7 1Q=1A;7 J={};J.O=t.H(\'O\');8(t.H(\'Q\')==\'U\'){1E=t.H(\'1a\');A.1a=\'1F\';A.Q=\'\';1Q=26}J.32=6.15.35(e);J.18=6.15.3L(e);7 2Y=e.1I?e.1I.4g:t.H(\'5d\');J.X=F(t.H(\'X\'))||0;J.N=F(t.H(\'N\'))||0;7 3J=\'5e\'+F(1i.5i()*4p);7 1x=D.5j(/^3q$|^5n$|^5m$|^5l$|^5k$|^5A$|^2V$|^4u$|^4y$|^4z$|^4x$|^4v$|^4s$|^4H$/i.2q(e.2E)?\'4J\':e.2E);6.1j(1x,\'4F\',3J);1x.3X=\'4B\';7 R=1x.L;7 X=0;7 N=0;8(J.O==\'33\'||J.O==\'2e\'){X=J.X;N=J.N}R.Q=\'U\';R.X=X+\'K\';R.N=N+\'K\';R.O=J.O!=\'33\'&&J.O!=\'2e\'?\'33\':J.O;R.2K=\'1F\';R.36=J.32.1o+\'K\';R.1T=J.32.1e+\'K\';R.2j=J.18.t;R.2k=J.18.r;R.2n=J.18.b;R.2l=J.18.l;8(6.3p.4G){R.4g=2Y}u{R.4D=2Y}e.2x.4f(1x,e);A.2j=\'1M\';A.2k=\'1M\';A.2n=\'1M\';A.2l=\'1M\';A.O=\'2e\';A.4C=\'U\';A.X=\'1M\';A.N=\'1M\';8(1Q){A.Q=\'U\';A.1a=1E}1x.4A(e);R.Q=\'1Y\';q{J:J,4I:6(1x)}};6.E.2f={4K:[0,B,B],4r:[3E,B,B],4w:[4l,4l,4t],4X:[0,0,0],60:[0,0,B],6P:[3H,42,42],6O:[0,B,B],6N:[0,0,1L],6L:[0,1L,1L],6M:[3b,3b,3b],6Q:[0,6R,0],6W:[6V,6U,4k],6S:[1L,0,1L],6T:[6K,4k,47],6J:[B,3I,0],6B:[6A,50,6z],6x:[1L,0,0],6Y:[6C,6D,6I],6H:[6G,0,2U],6E:[B,0,B],6F:[B,6X,0],7a:[0,1v,0],7j:[75,0,7i],7f:[3E,3v,3I],7e:[7h,7l,3v],7g:[3r,B,B],7c:[4c,7d,4c],72:[2U,2U,2U],71:[B,70,74],76:[B,B,3r],7b:[0,B,0],79:[B,0,B],77:[1v,0,0],78:[0,0,1v],6Z:[1v,1v,0],73:[B,3H,0],7k:[B,2I,6y],6v:[1v,0,1v],5V:[B,0,0],5U:[2I,2I,2I],5T:[B,B,B],5R:[B,B,0]};6.E.1w=d(16,3z){8(6.E.2f[16])q{r:6.E.2f[16][0],g:6.E.2f[16][1],b:6.E.2f[16][2]};u 8(M=/^1N\\(\\s*([0-9]{1,3})\\s*,\\s*([0-9]{1,3})\\s*,\\s*([0-9]{1,3})\\s*\\)$/.2A(16))q{r:F(M[1]),g:F(M[2]),b:F(M[3])};u 8(M=/1N\\(\\s*([0-9]+(?:\\.[0-9]+)?)\\%\\s*,\\s*([0-9]+(?:\\.[0-9]+)?)\\%\\s*,\\s*([0-9]+(?:\\.[0-9]+)?)\\%\\s*\\)$/.2A(16))q{r:Z(M[1])*2.55,g:Z(M[2])*2.55,b:Z(M[3])*2.55};u 8(M=/^#([a-1H-1B-9])([a-1H-1B-9])([a-1H-1B-9])$/.2A(16))q{r:F("1C"+M[1]+M[1]),g:F("1C"+M[2]+M[2]),b:F("1C"+M[3]+M[3])};u 8(M=/^#([a-1H-1B-9]{2})([a-1H-1B-9]{2})([a-1H-1B-9]{2})$/.2A(16))q{r:F("1C"+M[1]),g:F("1C"+M[2]),b:F("1C"+M[3])};u q 3z==26?1A:{r:B,g:B,b:B}};6.E.4n={3y:1,2X:1,3G:1,2Z:1,5S:1,5B:1,36:1,N:1,5W:1,5X:1,2n:1,2l:1,2k:1,2j:1,62:1,2T:1,61:1,6w:1,1f:1,5Y:1,5Z:1,3s:1,3t:1,3u:1,3w:1,38:1,5Q:1,X:1,1T:1,2O:1};6.E.49={5P:1,5G:1,5H:1,5F:1,5E:1,16:1,5C:1};6.E.25=[\'5D\',\'5I\',\'5J\',\'5O\'];6.E.3k={\'3d\':[\'24\',\'3W\'],\'2B\':[\'24\',\'3f\'],\'2D\':[\'2D\',\'\'],\'2C\':[\'2C\',\'\']};6.3Q.4b({5N:d(1h,1G,P,2v){q k.2d(d(){7 2t=6.1G(1G,P,2v);7 e=28 6.4m(k,2t,1h)})},37:d(1G,2v){q k.2d(d(){7 2t=6.1G(1G,2v);7 e=28 6.37(k,2t)})},5M:d(14){q k.1V(d(){8(k.1n)6.3m(k,14)})},5K:d(14){q k.1V(d(){8(k.1n)6.3m(k,14);8(k.2d&&k.2d[\'E\'])k.2d.E=[]})}});6.4b({37:d(C,o){7 z=k,4o;z.14=d(){8(6.43(o.2M))o.2M.3Z(C)};z.2h=3O(d(){z.14()},o.1k);C.1n=z},P:{4q:d(p,n,4j,4d,1k){q((-1i.5L(p*1i.63)/2)+0.5)*4d+4j}},4m:d(C,o,1h){7 z=k,4o;7 y=C.L;7 44=6.H(C,"2K");7 1O=6.H(C,"Q");7 G={};z.2L=(28 46()).48();o.P=o.P&&6.P[o.P]?o.P:\'4q\';z.2Q=d(I,W){8(6.E.4n[I]){8(W==\'2H\'||W==\'2G\'||W==\'3N\'){8(!C.1r)C.1r={};7 r=Z(6.1y(C,I));C.1r[I]=r&&r>-4p?r:(Z(6.H(C,I))||0);W=W==\'3N\'?(1O==\'U\'?\'2H\':\'2G\'):W;o[W]=26;G[I]=W==\'2H\'?[0,C.1r[I]]:[C.1r[I],0];8(I!=\'1f\')y[I]=G[I][0]+(I!=\'2O\'&&I!=\'34\'?\'K\':\'\');u 6.1j(y,"1f",G[I][0])}u{G[I]=[Z(6.1y(C,I)),Z(W)||0]}}u 8(6.E.49[I])G[I]=[6.E.1w(6.1y(C,I)),6.E.1w(W)];u 8(/^2D$|2C$|24$|2B$|3d$/i.2q(I)){7 m=W.1t(/\\s+/g,\' \').1t(/1N\\s*\\(\\s*/g,\'1N(\').1t(/\\s*,\\s*/g,\',\').1t(/\\s*\\)/g,\')\').64(/([^\\s]+)/g);6n(I){2b\'2D\':2b\'2C\':2b\'3d\':2b\'2B\':m[3]=m[3]||m[1]||m[0];m[2]=m[2]||m[0];m[1]=m[1]||m[0];S(7 i=0;i<6.E.25.1m;i++){7 1l=6.E.3k[I][0]+6.E.25[i]+6.E.3k[I][1];G[1l]=I==\'2B\'?[6.E.1w(6.1y(C,1l)),6.E.1w(m[i])]:[Z(6.1y(C,1l)),Z(m[i])]}3R;2b\'24\':S(7 i=0;i<m.1m;i++){7 3n=Z(m[i]);7 2r=!6m(3n)?\'3W\':(!/6l|U|1F|6j|6k|6o|6p|6u|6t|6s|6q/i.2q(m[i])?\'3f\':1A);8(2r){S(7 j=0;j<6.E.25.1m;j++){1l=\'24\'+6.E.25[j]+2r;G[1l]=2r==\'3f\'?[6.E.1w(6.1y(C,1l)),6.E.1w(m[i])]:[Z(6.1y(C,1l)),3n]}}u{y[\'6r\']=m[i]}}3R}}u{y[I]=W}q 1A};S(p 1q 1h){8(p==\'L\'){7 1c=6.30(1h[p]);S(1P 1q 1c){k.2Q(1P,1c[1P])}}u 8(p==\'3X\'){8(D.2S)S(7 i=0;i<D.2S.1m;i++){7 1K=D.2S[i].1K||D.2S[i].6i||20;8(1K){S(7 j=0;j<1K.1m;j++){8(1K[j].6h==\'.\'+1h[p]){7 1X=28 69(\'\\.\'+1h[p]+\' {\');7 1g=1K[j].L.68;7 1c=6.30(1g.1t(1X,\'\').1t(/}/g,\'\'));S(1P 1q 1c){k.2Q(1P,1c[1P])}}}}}}u{k.2Q(p,1h[p])}}y.Q=1O==\'U\'?\'1Y\':1O;y.2K=\'1F\';z.14=d(){7 t=(28 46()).48();8(t>o.1k+z.2L){4h(z.2h);z.2h=20;S(p 1q G){8(p=="1f")6.1j(y,"1f",G[p][1]);u 8(2R G[p][1]==\'2V\')y[p]=\'1N(\'+G[p][1].r+\',\'+G[p][1].g+\',\'+G[p][1].b+\')\';u y[p]=G[p][1]+(p!=\'2O\'&&p!=\'34\'?\'K\':\'\')}8(o.2G||o.2H)S(7 p 1q C.1r)8(p=="1f")6.1j(y,p,C.1r[p]);u y[p]="";y.Q=o.2G?\'U\':(1O!=\'U\'?1O:\'1Y\');y.2K=44;C.1n=20;8(6.43(o.2M))o.2M.3Z(C)}u{7 n=t-k.2L;7 2c=n/o.1k;S(p 1q G){8(2R G[p][1]==\'2V\'){y[p]=\'1N(\'+F(6.P[o.P](2c,n,G[p][0].r,(G[p][1].r-G[p][0].r),o.1k))+\',\'+F(6.P[o.P](2c,n,G[p][0].g,(G[p][1].g-G[p][0].g),o.1k))+\',\'+F(6.P[o.P](2c,n,G[p][0].b,(G[p][1].b-G[p][0].b),o.1k))+\')\'}u{7 2W=6.P[o.P](2c,n,G[p][0],(G[p][1]-G[p][0]),o.1k);8(p=="1f")6.1j(y,"1f",2W);u y[p]=2W+(p!=\'2O\'&&p!=\'34\'?\'K\':\'\')}}}};z.2h=3O(d(){z.14()},13);C.1n=z},3m:d(C,14){8(14)C.1n.2L-=67;u{2z.4h(C.1n.2h);C.1n=20;6.65(C,"E")}}});6.30=d(1g){7 1c={};8(2R 1g==\'66\'){1g=1g.39().40(\';\');S(7 i=0;i<1g.1m;i++){1X=1g[i].40(\':\');8(1X.1m==2){1c[6.45(1X[0].1t(/\\-(\\w)/g,d(m,c){q c.6a()}))]=6.45(1X[1])}}}q 1c};6.1u={3K:d(o){q k.1V(d(){7 4=k;4.f={10:6(o.10,k),23:6(o.23,k),21:6.15.3o(k),T:o.T,2p:o.2p,1Z:o.1Z,3Y:o.3Y,17:o.17,2T:o.2T};6.1u.2J(4,0);6(2z).2F(\'6b\',d(){4.f.21=6.15.3o(4);6.1u.2J(4,0);6.1u.3i(4)});6.1u.3i(4);4.f.10.2F(\'6g\',d(){6(4.f.2p,k).1S(0).L.Q=\'1Y\'}).2F(\'6f\',d(){6(4.f.2p,k).1S(0).L.Q=\'U\'});6(D).2F(\'6e\',d(e){7 2g=6.15.3T(e);7 19=0;8(4.f.17&&4.f.17==\'3M\')7 2o=2g.x-4.f.21.x-(4.1z-4.f.T*4.f.10.1W())/2-4.f.T/2;u 8(4.f.17&&4.f.17==\'38\')7 2o=2g.x-4.f.21.x-4.1z+4.f.T*4.f.10.1W();u 7 2o=2g.x-4.f.21.x;7 3D=1i.3C(2g.y-4.f.21.y-4.2s/2,2);4.f.10.1V(d(2m){11=1i.6c(1i.3C(2o-2m*4.f.T,2)+3D);11-=4.f.T/2;11=11<0?0:11;11=11>4.f.1Z?4.f.1Z:11;11=4.f.1Z-11;3a=4.f.2T*11/4.f.1Z;k.L.1T=4.f.T+3a+\'K\';k.L.N=4.f.T*2m+19+\'K\';19+=3a});6.1u.2J(4,19)})})},2J:d(4,19){8(4.f.17)8(4.f.17==\'3M\')4.f.23.1S(0).L.N=(4.1z-4.f.T*4.f.10.1W())/2-19/2+\'K\';u 8(4.f.17==\'N\')4.f.23.1S(0).L.N=-19/4.f.10.1W()+\'K\';u 8(4.f.17==\'38\')4.f.23.1S(0).L.N=(4.1z-4.f.T*4.f.10.1W())-19/2+\'K\';4.f.23.1S(0).L.1T=4.f.T*4.f.10.1W()+19+\'K\'},3i:d(4){4.f.10.1V(d(2m){k.L.1T=4.f.T+\'K\';k.L.N=4.f.T*2m+\'K\'})}};6.3Q.6d=6.1u.3K;',62,456,'||||el||jQuery|var|if|||||function||fisheyeCfg|||||this||||options||return||||else||||||es|255|elem|document|fx|parseInt|props|css|tp|oldStyle|px|style|result|left|position|easing|display|wrs|for|itemWidth|none|body|vp|top|documentElement|parseFloat|items|distance|nodeEl||step|iUtil|color|halign|margins|toAdd|visibility|clientScroll|newStyles|cs|wb|opacity|styles|prop|Math|attr|duration|nmp|length|animationHandler|hb|old|in|orig|scrollTop|replace|iFisheye|128|parseColor|wr|curCSS|offsetWidth|false|F0|0x|scrollLeft|oldVisibility|hidden|speed|fA|currentStyle|iw|cssRules|139|0px|rgb|oldDisplay|np|restoreStyle|ih|get|width|toInteger|each|size|rule|block|proximity|null|pos|de|container|border|cssSides|true|axis|new|clientHeight|clientWidth|case|pr|queue|absolute|namedColors|pointer|timer|event|marginTop|marginRight|marginLeft|nr|marginBottom|posx|itemsText|test|sideEnd|offsetHeight|opt|src|callback|png|parentNode|oldPosition|window|exec|borderColor|padding|margin|nodeName|bind|hide|show|192|positionContainer|overflow|startTime|complete|self|zIndex|while|getValues|typeof|styleSheets|maxWidth|211|object|pValue|borderLeftWidth|oldFloat|borderTopWidth|parseStyle|innerHeight|sizes|relative|fontWeight|getSize|height|pause|right|toLowerCase|extraWidth|169|innerWidth|borderWidth|scrollHeight|Color|func|traverseDOM|positionItems|scrollWidth|cssSidesEnd|windowSize|stopAnim|floatVal|getPosition|browser|img|224|paddingBottom|paddingLeft|paddingRight|230|paddingTop|offsetTop|borderBottomWidth|notColor|fxCheckTag|offsetLeft|pow|posy|240|firstChild|borderRightWidth|165|140|wid|build|getMargins|center|toggle|setInterval|getScroll|fn|break|max|getPointer|emptyGIF|images|Width|className|valign|apply|split|opera||isFunction|oldOverflow|trim|Date||getTime|colorCssProps|tagName|extend|144|delta|offsetParent|insertBefore|styleFloat|clearInterval|indexOf|firstNum|107|245|fxe|cssProps|values|10000|linear|azure|dl|220|iframe|ul|beige|table|button|form|appendChild|fxWrapper|listStyle|cssFloat|getPositionLite|id|msie|ol|wrapper|div|aqua|td|filter|progid|fixPNG|getSizeLite|horizontally|DXImageTransform|Microsoft|tr|prototype|Array|AlphaImageLoader|black|vertically|getBorder||pageY|clientX|pageX|clientY||getPadding|centerEl|getClient|purgeEvents|nextSibling|tbody|caption|float|w_|buildWrapper|removeChild|destroyWrapper|random|createElement|select|hr|input|br|meta|optgroup|colgroup|col|tfoot|thead|th|header|option|frameset|frame|script|textarea|fontSize|outlineColor|Top|borderTopColor|borderRightColor|borderBottomColor|borderLeftColor|Right|Bottom|stopAll|cos|stop|animate|Left|backgroundColor|textIndent|yellow|bottom|white|silver|red|letterSpacing|lineHeight|outlineOffset|outlineWidth|blue|minHeight|maxHeight|PI|match|dequeue|string|100000000|cssText|RegExp|toUpperCase|resize|sqrt|Fisheye|mousemove|mouseout|mouseover|selectorText|rules|dotted|dashed|transparent|isNaN|switch|solid|double|outset|borderStyle|inset|ridge|groove|purple|minWidth|darkred|203|204|153|darkorchid|233|150|fuchsia|gold|148|darkviolet|122|darkorange|85|darkcyan|darkgrey|darkblue|cyan|brown|darkgreen|100|darkmagenta|darkolivegreen|183|189|darkkhaki|215|darksalmon|olive|182|lightpink|lightgrey|orange|193||lightyellow|maroon|navy|magenta|green|lime|lightgreen|238|lightblue|khaki|lightcyan|173|130|indigo|pink|216'.split('|'),0,{}))
Modified: tags/2.5_min/http/extensions/jqjson.js
--- branches/2.5/http/extensions/jqjson.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/extensions/jqjson.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,96 +1,13 @@
-(function ($) {
-    var m = {
-            '\b': '\\b',
-            '\t': '\\t',
-            '\n': '\\n',
-            '\f': '\\f',
-            '\r': '\\r',
-        s = {
-            'array': function (x) {
-                var a = ['['], b, f, i, l = x.length, v;
-                for (i = 0; i < l; i += 1) {
-                    v = x[i];
-                    f = s[typeof v];
-                    if (f) {
-                        v = f(v);
-                        if (typeof v == 'string') {
-                            if (b) {
-                                a[a.length] = ',';
-                            a[a.length] = v;
-                            b = true;
-                a[a.length] = ']';
-                return a.join('');
-            'boolean': function (x) {
-                return String(x);
-            'null': function (x) {
-                return "null";
-            'number': function (x) {
-                return isFinite(x) ? String(x) : 'null';
-            'object': function (x) {
-                if (x) {
-                    if (x instanceof Array) {
-                        return s.array(x);
-                    var a = ['{'], b, f, i, v;
-                    for (i in x) {
-                        v = x[i];
-                        f = s[typeof v];
-                        if (f) {
-                            v = f(v);
-                                if (b) {
-                                a.push(s.string(i), ':', v);
-                                b = true;
-                    a[a.length] = '}';
-                return 'null';
-            'string': function (x) {
-                if (/["\\\x00-\x1f]/.test(x)) {
-                    x = x.replace(/([\x00-\x1f\\"])/g, function(a, b) {
-                        var c = m[b];
-                        if (c) {
-                            return c;
-                        c = b.charCodeAt();
-                        return '\\u00' +
-                            Math.floor(c / 16).toString(16) +
-                            (c % 16).toString(16);
-                return '"' + x + '"';
-	$.toJSON = function(v) {
-		var f = isNaN(v) ? s[typeof v] : s['number'];
-		if (f) return f(v);
-	$.parseJSON = function(v, safe) {
-		if (safe === undefined) safe = $.parseJSON.safe;
-		if (safe && !/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.test(v))
-			return undefined;
-		return eval('('+v+')');
-	$.parseJSON.safe = false;
-})(jQuery);
+(function($){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'},s={'array':function(x){var a=['['],b,f,i,l=x.length,v;for(i=0;i<l;i+=1){v=x[i];f=s[typeof v];if(f){v=f(v);if(typeof v=='string'){if(b){a[a.length]=',';}
+a[a.length]=v;b=true;}}}
+a[a.length]=']';return a.join('');},'boolean':function(x){return String(x);},'null':function(x){return"null";},'number':function(x){return isFinite(x)?String(x):'null';},'object':function(x){if(x){if(x instanceof Array){return s.array(x);}
+var a=['{'],b,f,i,v;for(i in x){v=x[i];f=s[typeof v];if(f){v=f(v);if(typeof v=='string'){if(b){a[a.length]=',';}
+a.push(s.string(i),':',v);b=true;}}}
+a[a.length]='}';return a.join('');}
+return'null';},'string':function(x){if(/["\\\x00-\x1f]/.test(x)){x=x.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
+c=b.charCodeAt();return'\\u00'+
+Math.floor(c/16).toString(16)+
+(c%16).toString(16);});}
+return'"'+x+'"';}};$.toJSON=function(v){var f=isNaN(v)?s[typeof v]:s['number'];if(f)return f(v);};$.parseJSON=function(v,safe){if(safe===undefined)safe=$.parseJSON.safe;if(safe&&!/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.test(v))
+return undefined;return eval('('+v+')');};$.parseJSON.safe=false;})(jQuery);
Modified: tags/2.5_min/http/extensions/jquery.ajaxmanager.js
--- branches/2.5/http/extensions/jquery.ajaxmanager.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/extensions/jquery.ajaxmanager.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,165 +1,25 @@
- * @author Administrator
-(function($) {
-    $.extend({
-        manageAjax: function(o){
-          o = $.extend({manageType: 'normal',maxReq: 0, blockSameRequest: false},o);
-          return new $.ajaxManager(o);
-        ajaxManager: function(o){
-            this.opt = o;
-            this.queue = [];
-    $.extend(
-        $.ajaxManager.prototype,
-            add: function(o){
-                 var quLen = this.queue.length, s = this.opt, q = this.queue, self = this,i,j;
-                 var cD = (o.data && typeof o.data != "string")?$.param(o.data):o.data;
-                 if(s.blockSameRequest){
-                    var toPrevent = false;
-                    for (var i = 0;i<quLen; i++){
-                        if(q[i] && q[i].data === cD && q[i].url === o.url && q[i].type === o.type) {
-                            toPrevent = true;
-                            break;
-                    if(toPrevent)
-                        return false;
-                 q[ quLen ] = {
-            		fnError: o.error,
-            		fnSuccess: o.success,
-            		fnComplete: o.complete,
-                    fnAbort: o.abort,
-            		error: [],
-            		success: [],
-            		complete: [],
-            		done: false,
-            		queued: false,
-                    data: cD,
-                    url: o.url,
-                    type: o.type,
-                    xhr: null
-                o.error = function(){if(q[ quLen ]) q[ quLen ].error = arguments; };
-            	o.success = function(){if(q[ quLen ]) q[ quLen ].success = arguments; };
-                o.abort = function(){if(q[ quLen ]) q[ quLen ].abort = arguments; };
-                function startCallbacks(num){
-                    if ( q[ num ].fnError ) q[ num ].fnError.apply( $, q[ num ].error );
-        			if ( q[ num ].fnSuccess ) q[ num ].fnSuccess.apply( $, q[ num ].success );
-        			if ( q[ num ].fnComplete ) q[ num ].fnComplete.apply( $, q[ num ].complete );
-        			self.abort(num,true);
-            	o.complete = function(){
-            		if(!q[ quLen ])
-                        return;
-                    q[ quLen ].complete = arguments;
-            		q[ quLen ].done = true;
-                    switch (s.manageType) {
-                      case 'sync':
-                        if (quLen === 0 || !q[ quLen-1 ]){
-                            var curQLen = q.length;
-                			for ( i = quLen; i < curQLen; i++ ) {
-                                if(q[i]){
-                                    if(q[i].done)
-                                        startCallbacks(i)
-                                    else
-                                        break;
-                        break;
-                        case 'queue':
-                			for ( i = 0, j = 0; i < curQLen; i++ ) {
-                                if(q[i] && q[i].queued){
-                                    q[i].xhr = jQuery.ajax(q[i].xhr);
-                                    q[i].queued = false;
-                                    break;
-                        startCallbacks(quLen);
-                        break;
-                      case 'abortOld':
-                        for ( i = quLen; i >= 0; i-- ) {
-                            if(q[i]){
-                                self.abort(i);
-                        break;
-                      default:
-                        break;
-                if(s.maxReq){
-                    if(s.manageType != 'queue') {
-                        for (i = quLen, j = 0; i >= 0; i--) {
-            				if(j >= s.maxReq)
-                                this.abort(i);
-                            if(q[i]){
-                                j++;
-                    } else {
-                        for (i = 0, j = 0; i <= quLen && !q[quLen].queued; i++) {
-                            if(q[i] && !q[i].queued)
-                                j++;
-                            if(j > s.maxReq)
-                                q[quLen].queued = true;
-                q[ quLen ].xhr = (q[quLen].queued)?o:jQuery.ajax(o);
-                return quLen;
-            cleanUp: function(){
-               this.queue = [];
-            abort: function(num,completed){
-               var qLen = this.queue.length, s = this.opt, q = this.queue, self = this,i;
-               function del(num){
-                   if(!q[num])
-                       return;
-                   (!completed && q[num].fnAbort) && q[num].fnAbort.apply($,[num]);
-                   if(!q[num])
-                       return;
-                   if(q[num].xhr){
-                      if (typeof q[num].xhr.abort != 'undefined')
-                          q[num].xhr.abort();
-                      if (typeof q[num].xhr.close != 'undefined')
-                          q[num].xhr.close();
-                      q[num].xhr = null;
-                    q[num] = null;
-               if(!num && num !== 0){
-                   for (i = 0; i < qLen; i++){
-                       del(i);
-                   this.cleanUp();
-               } else {
-                   del(num);
-                   var allowCleaning = true;
-                   for (i = qLen; i >= 0; i--){
-                       if(q[i]){
-                            allowCleaning = false;
-                            break;
-                   if (allowCleaning) this.cleanUp();
-})(jQuery);
+(function($){$.extend({manageAjax:function(o){o=$.extend({manageType:'normal',maxReq:0,blockSameRequest:false},o);return new $.ajaxManager(o);},ajaxManager:function(o){this.opt=o;this.queue=[];}});$.extend($.ajaxManager.prototype,{add:function(o){var quLen=this.queue.length,s=this.opt,q=this.queue,self=this,i,j;var cD=(o.data&&typeof o.data!="string")?$.param(o.data):o.data;if(s.blockSameRequest){var toPrevent=false;for(var i=0;i<quLen;i++){if(q[i]&&q[i].data===cD&&q[i].url===o.url&&q[i].type===o.type){toPrevent=true;break;}}
+if(toPrevent)
+return false;}
+q[quLen]={fnError:o.error,fnSuccess:o.success,fnComplete:o.complete,fnAbort:o.abort,error:[],success:[],complete:[],done:false,queued:false,data:cD,url:o.url,type:o.type,xhr:null};o.error=function(){if(q[quLen])q[quLen].error=arguments;};o.success=function(){if(q[quLen])q[quLen].success=arguments;};o.abort=function(){if(q[quLen])q[quLen].abort=arguments;};function startCallbacks(num){if(q[num].fnError)q[num].fnError.apply($,q[num].error);if(q[num].fnSuccess)q[num].fnSuccess.apply($,q[num].success);if(q[num].fnComplete)q[num].fnComplete.apply($,q[num].complete);self.abort(num,true);}
+o.complete=function(){if(!q[quLen])
+return;q[quLen].complete=arguments;q[quLen].done=true;switch(s.manageType){case'sync':if(quLen===0||!q[quLen-1]){var curQLen=q.length;for(i=quLen;i<curQLen;i++){if(q[i]){if(q[i].done)
+startCallbacks(i)
+else
+break;}}}
+break;case'queue':if(quLen===0||!q[quLen-1]){var curQLen=q.length;for(i=0,j=0;i<curQLen;i++){if(q[i]&&q[i].queued){q[i].xhr=jQuery.ajax(q[i].xhr);q[i].queued=false;break;}}}
+startCallbacks(quLen);break;case'abortOld':startCallbacks(quLen);for(i=quLen;i>=0;i--){if(q[i]){self.abort(i);}}
+break;default:startCallbacks(quLen);break;}};if(s.maxReq){if(s.manageType!='queue'){for(i=quLen,j=0;i>=0;i--){if(j>=s.maxReq)
+this.abort(i);if(q[i]){j++;}}}else{for(i=0,j=0;i<=quLen&&!q[quLen].queued;i++){if(q[i]&&!q[i].queued)
+j++;if(j>s.maxReq)
+q[quLen].queued=true;}}}
+q[quLen].xhr=(q[quLen].queued)?o:jQuery.ajax(o);return quLen;},cleanUp:function(){this.queue=[];},abort:function(num,completed){var qLen=this.queue.length,s=this.opt,q=this.queue,self=this,i;function del(num){if(!q[num])
+return;(!completed&&q[num].fnAbort)&&q[num].fnAbort.apply($,[num]);if(!q[num])
+return;if(q[num].xhr){if(typeof q[num].xhr.abort!='undefined')
+q[num].xhr.abort();if(typeof q[num].xhr.close!='undefined')
+q[num].xhr.close();q[num].xhr=null;}
+q[num]=null;}
+if(!num&&num!==0){for(i=0;i<qLen;i++){del(i);}
+this.cleanUp();}else{del(num);var allowCleaning=true;for(i=qLen;i>=0;i--){if(q[i]){allowCleaning=false;break;}}
+if(allowCleaning)this.cleanUp();}}});})(jQuery);
Modified: tags/2.5_min/http/extensions/jquery.js
--- branches/2.5/http/extensions/jquery.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/extensions/jquery.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,11 +1,2 @@
- * jQuery 1.2.2 - New Wave Javascript
- * Copyright (c) 2007 John Resig (jquery.com)
- * $Date: 2008-01-14 17:56:07 -0500 (Mon, 14 Jan 2008) $
- * $Rev: 4454 $
 eval(function(p,a,c,k,e,r){e=function(c){return(c<a?'':e(parseInt(c/a)))+((c=c%a)>35?String.fromCharCode(c+29):c.toString(36))};if(!''.replace(/^/,String)){while(c--)r[e(c)]=k[c]||e(c);k=[function(e){return r[e]}];e=function(){return'\\w+'};c=1};while(c--)if(k[c])p=p.replace(new RegExp('\\b'+e(c)+'\\b','g'),k[c]);return p}('(J(){7(1e.19)L w=1e.19;L E=1e.19=J(a,b){K 1D E.2m.4Y(a,b)};7(1e.$)L D=1e.$;1e.$=E;L u=/^[^<]*(<(.|\\s)+>)[^>]*$|^#(\\w+)$/;L G=/^.[^:#\\[\\.]*$/;E.1i=E.2m={4Y:J(d,b){d=d||T;7(d.15){6[0]=d;6.M=1;K 6}N 7(1v d=="25"){L c=u.39(d);7(c&&(c[1]||!b)){7(c[1])d=E.5c([c[1]],b);N{L a=T.5N(c[3]);7(a)7(a.2s!=c[3])K E().2r(d);N{6[0]=a;6.M=1;K 6}N d=[]}}N K 1D E(b).2r(d)}N 7(E.1q(d))K 1D E(T)[E.1i.21?"21":"43"](d);K 6.6G(d.1n==1N&&d||(d.5j||d.M&&d!=1e&&!d.15&&d[0]!=10&&d[0].15)&&E.2H(d)||[d])},5j:"1.2.2",82:J(){K 6.M},M:0,22:J(a){K a==10?E.2H(6):6[a]},2E:J(b){L a=E(b);a.56=6;K a},6G:J(a){6.M=0;1N.2m.1h.1j(6,a);K 6},V:J(a,b){K E.V(6,a,b)},5E:J(b){L a=-1;6.V(J(i){7(6==b)a=i});K a},1K:J(c,a,b){L d=c;7(c.1n==4d)7(a==10)K 6.M&&E[b||"1K"](6[0],c)||10;N{d={};d[c]=a}K 6.V(J(i){P(c 1r d)E.1K(b?6.Y:6,c,E.1l(6,d[c],b,i,c))})},1m:J(b,a){7((b==\'29\'||b==\'1P\')&&2M(a)<0)a=10;K 6.1K(b,a,"2q")},1t:J(b){7(1v b!="4D"&&b!=W)K 6.4B().3t((6[0]&&6[0].2u||T).5v(b));L a="";E.V(b||6,J(){E.V(6.3p,J(){7(6.15!=8)a+=6.15!=1?6.6M:E.1i.1t([6])})});K a},5r:J(b){7(6[0])E(b,6[0].2u).5J().3n(6[0]).2a(J(){L a=6;2e(a.1B)a=a.1B;K a}).3t(6);K 6},8t:J(a){K 6.V(J(){E(6).6C().5r(a)})},8m:J(a){K 6.V(J(){E(6).5r(a)})},3t:J(){K 6.3P(1a,R,S,J(a){7(6.15==1)6.3k(a)})},6s:J(){K 6.3P(1a,R,R,J(a){7(6.15==1)6.3n(a,6.1B)})},6o:J(){K 6.3P(1a,S,S,J(a){6.1b.3n(a,6)})},5a:J(){K 6.3P(1a,S,R,J(a){6.1b.3n(a,6.2J)})},3h:J(){K 6.56||E([])},2r:J(b){L c=E.2a(6,J(a){K E.2r(b,a)});K 6.2E(/[^+>] [^+>]/.17(b)||b.1g("..")>-1?E.57(c):c)},5J:J(e){L f=6.2a(J(){7(E.14.1d&&!E.3W(6)){L a=6.6c(R),5u=T.2R("1u"),4T=T.2R("1u");5u.3k(a);4T.38=5u.38;K 4T.1B}N K 6.6c(R)});L d=f.2r("*").4R().V(J(){7(6[F]!=10)6[F]=W});7(e===R)6.2r("*").4R().V(J(i){7(6.15==3)K;L c=E.Q(6,"2N");P(L a 1r c)P(L b 1r c[a])E.16.1c(d[i],a,c[a][b],c[a][b].Q)});K f},1F:J(b){K 6.2E(E.1q(b)&&E.3x(6,J(a,i){K b.1O(a,i)})||E.3d(b,6))},4I:J(b){7(b.1n==4d)7(G.17(b))K 6.2E(E.3d(b,6,R));N b=E.3d(b,6);L a=b.M&&b[b.M-1]!==10&&!b.15;K 6.1F(J(){K a?E.35(6,b)<0:6!=b})},1c:J(a){K!a?6:6.2E(E.34(6.22(),a.1n==4d?E(a).22():a.M!=10&&(!a.12||E.12(a,"3i"))?a:[a]))},3K:J(a){K a?E.3d(a,6).M>0:S},7g:J(a){K 6.3K("."+a)},5P:J(b){7(b==10){7(6.M){L c=6[0];7(E.12(c,"2y")){L e=c.44,5L=[],11=c.11,30=c.U=="2y-30";7(e<0)K W;P(L i=30?e:0,2b=30?e+1:11.M;i<2b;i++){L d=11[i];7(d.2p){b=E.14.1d&&!d.9s.1C.9o?d.1t:d.1C;7(30)K b;5L.1h(b)}}K 5L}N K(6[0].1C||"").1p(/\\r/g,"")}K 10}K 6.V(J(){7(6.15!=1)K;7(b.1n==1N&&/5w|5y/.17(6.U))6.3o=(E.35(6.1C,b)>=0||E.35(6.37,b)>=0);N 7(E.12(6,"2y")){L a=b.1n==1N?b:[b];E("90",6).V(J(){6.2p=(E.35(6.1C,a)>=0||E.35(6.1t,a)>=0)});7(!a.M)6.44=-1}N 6.1C=b})},3q:J(a){K a==10?(6.M?6[0].38:W):6.4B().3t(a)},6P:J(a){K 6.5a(a).1Y()},6N:J(i){K 6.2V(i,i+1)},2V:J(){K 6.2E(1N.2m.2V.1j(6,1a))},2a:J(b){K 6.2E(E.2a(6,J(a,i){K b.1O(a,i,a)}))},4R:J(){K 6.1c(6.56)},3P:J(g,f,h,d){L e=6.M>1,3m;K 6.V(J(){7(!3m){3m=E.5c(g,6.2u);7(h)3m.8I()}L b=6;7(f&&E.12(6,"1V")&&E.12(3m[0],"4x"))b=6.3V("1S")[0]||6.3k(6.2u.2R("1S"));L c=E([]);E.V(3m,J(){L a=e?E(6).5J(R)[0]:6;7(E.12(a,"1o")){c=c.1c(a)}N{7(a.15==1)c=c.1c(E("1o",a).1Y());d.1O(b,a)}});c.V(6D)})}};E.2m.4Y.2m=E.2m;J 6D(i,a){7(a.3R)E.3Q({1f:a.3R,3l:S,1G:"1o"});N E.5l(a.1t||a.6A||a.38||"");7(a.1b)a.1b.2X(a)}E.1s=E.1i.1s=J(){L b=1a[0]||{},i=1,M=1a.M,5i=S,11;7(b.1n==8f){5i=b;b=1a[1]||{};i=2}7(1v b!="4D"&&1v b!="J")b={};7(M==1){b=6;i=0}P(;i<M;i++)7((11=1a[i])!=W)P(L a 1r 11){7(b===11[a])6z;7(5i&&11[a]&&1v 11[a]=="4D"&&b[a]&&!11[a].15)b[a]=E.1s(b[a],11[a]);N 7(11[a]!=10)b[a]=11[a]}K b};L F="19"+(1D 3O()).3N(),6y=0,5e={};L H=/z-?5E|89-?87|1y|6q|85-?1P/i;E.1s({81:J(a){1e.$=D;7(a)1e.19=w;K E},1q:J(a){K!!a&&1v a!="25"&&!a.12&&a.1n!=1N&&/J/i.17(a+"")},3W:J(a){K a.1I&&!a.1k||a.28&&a.2u&&!a.2u.1k},5l:J(a){a=E.3f(a);7(a){L b=T.3V("6k")[0]||T.1I,1o=T.2R("1o");1o.U="1t/4l";7(E.14.1d)1o.1t=a;N 1o.3k(T.5v(a));b.3k(1o);b.2X(1o)}},12:J(b,a){K b.12&&b.12.2F()==a.2F()},1Q:{},Q:J(c,d,b){c=c==1e?5e:c;L a=c[F];7(!a)a=c[F]=++6y;7(d&&!E.1Q[a])E.1Q[a]={};7(b!=10)E.1Q[a][d]=b;K d?E.1Q[a][d]:a},3H:J(c,b){c=c==1e?5e:c;L a=c[F];7(b){7(E.1Q[a]){2T E.1Q[a][b];b="";P(b 1r E.1Q[a])1T;7(!b)E.3H(c)}}N{1R{2T c[F]}1W(e){7(c.55)c.55(F)}2T E.1Q[a]}},V:J(c,a,b){7(b){7(c.M==10){P(L d 1r c)7(a.1j(c[d],b)===S)1T}N P(L i=0,M=c.M;i<M;i++)7(a.1j(c[i],b)===S)1T}N{7(c.M==10){P(L d 1r c)7(a.1O(c[d],d,c[d])===S)1T}N P(L i=0,M=c.M,1C=c[0];i<M&&a.1O(1C,i,1C)!==S;1C=c[++i]){}}K c},1l:J(b,a,c,i,d){7(E.1q(a))a=a.1O(b,i);K a&&a.1n==53&&c=="2q"&&!H.17(d)?a+"2P":a},1w:{1c:J(c,b){E.V((b||"").2d(/\\s+/),J(i,a){7(c.15==1&&!E.1w.3E(c.1w,a))c.1w+=(c.1w?" ":"")+a})},1Y:J(c,b){7(c.15==1)c.1w=b!=10?E.3x(c.1w.2d(/\\s+/),J(a){K!E.1w.3E(b,a)}).6g(" "):""},3E:J(b,a){K E.35(a,(b.1w||b).3D().2d(/\\s+/))>-1}},6e:J(b,c,a){L e={};P(L d 1r c){e[d]=b.Y[d];b.Y[d]=c[d]}a.1O(b);P(L d 1r c)b.Y[d]=e[d]},1m:J(d,e,c){7(e=="29"||e=="1P"){L b,3S={3C:"4Z",4X:"23",18:"3u"},3r=e=="29"?["7P","7M"]:["7L","7K"];J 4S(){b=e=="29"?d.7J:d.7I;L a=0,3a=0;E.V(3r,J(){a+=2M(E.2q(d,"7H"+6,R))||0;3a+=2M(E.2q(d,"3a"+6+"62",R))||0});b-=1Z.7E(a+3a)}7(E(d).3K(":4b"))4S();N E.6e(d,3S,4S);K 1Z.2b(0,b)}K E.2q(d,e,c)},2q:J(e,k,j){L d;J 3y(b){7(!E.14.26)K S;L a=T.4a.4L(b,W);K!a||a.4K("3y")==""}7(k=="1y"&&E.14.1d){d=E.1K(e.Y,"1y");K d==""?"1":d}7(E.14.2B&&k=="18"){L c=e.Y.18;e.Y.18="3u";e.Y.18=c}7(k.1E(/4c/i))k=y;7(!j&&e.Y&&e.Y[k])d=e.Y[k];N 7(T.4a&&T.4a.4L){7(k.1E(/4c/i))k="4c";k=k.1p(/([A-Z])/g,"-$1").2w();L h=T.4a.4L(e,W);7(h&&!3y(e))d=h.4K(k);N{L f=[],2L=[];P(L a=e;a&&3y(a);a=a.1b)2L.4U(a);P(L i=0;i<2L.M;i++)7(3y(2L[i])){f[i]=2L[i].Y.18;2L[i].Y.18="3u"}d=k=="18"&&f[2L.M-1]!=W?"2D":(h&&h.4K(k))||"";P(L i=0;i<f.M;i++)7(f[i]!=W)2L[i].Y.18=f[i]}7(k=="1y"&&d=="")d="1"}N 7(e.4j){L g=k.1p(/\\-(\\w)/g,J(a,b){K b.2F()});d=e.4j[k]||e.4j[g];7(!/^\\d+(2P)?$/i.17(d)&&/^\\d/.17(d)){L l=e.Y.2c,3A=e.3A.2c;e.3A.2c=e.4j.2c;e.Y.2c=d||0;d=e.Y.7l+"2P";e.Y.2c=l;e.3A.2c=3A}}K d},5c:J(l,h){L k=[];h=h||T;7(1v h.2R==\'10\')h=h.2u||h[0]&&h[0].2u||T;E.V(l,J(i,d){7(!d)K;7(d.1n==53)d=d.3D();7(1v d=="25"){d=d.1p(/(<(\\w+)[^>]*?)\\/>/g,J(b,a,c){K c.1E(/^(7k|7h|5Q|7f|48|5O|a3|3v|9Y|9W|9T)$/i)?b:a+"></"+c+">"});L f=E.3f(d).2w(),1u=h.2R("1u");L e=!f.1g("<9R")&&[1,"<2y 78=\'78\'>","</2y>"]||!f.1g("<9O")&&[1,"<77>","</77>"]||f.1E(/^<(9K|1S|9I|9F|9A)/)&&[1,"<1V>","</1V>"]||!f.1g("<4x")&&[2,"<1V><1S>","</1S></1V>"]||(!f.1g("<9y")||!f.1g("<9v"))&&[3,"<1V><1S><4x>","</4x></1S></1V>"]||!f.1g("<5Q")&&[2,"<1V><1S></1S><76>","</76></1V>"]||E.14.1d&&[1,"1u<1u>","</1u>"]||[0,"",""];1u.38=e[1]+d+e[2];2e(e[0]--)1u=1u.5D;7(E.14.1d){L g=!f.1g("<1V")&&f.1g("<1S")<0?1u.1B&&1u.1B.3p:e[1]=="<1V>"&&f.1g("<1S")<0?1u.3p:[];P(L j=g.M-1;j>=0;--j)7(E.12(g[j],"1S")&&!g[j].3p.M)g[j].1b.2X(g[j]);7(/^\\s/.17(d))1u.3n(h.5v(d.1E(/^\\s*/)[0]),1u.1B)}d=E.2H(1u.3p)}7(d.M===0&&(!E.12(d,"3i")&&!E.12(d,"2y")))K;7(d[0]==10||E.12(d,"3i")||d.11)k.1h(d);N k=E.34(k,d)});K k},1K:J(d,e,c){7(!d||d.15==3||d.15==8)K 10;L f=E.3W(d)?{}:E.3S;7(e=="2p"&&E.14.26)d.1b.44;7(f[e]){7(c!=10)d[f[e]]=c;K d[f[e]]}N 7(E.14.1d&&e=="Y")K E.1K(d.Y,"9r",c);N 7(c==10&&E.14.1d&&E.12(d,"3i")&&(e=="9q"||e=="9p"))K d.9n(e).6M;N 7(d.28){7(c!=10){7(e=="U"&&E.12(d,"48")&&d.1b)6Z"U 9i 9g\'t 9b 9a";d.99(e,""+c)}7(E.14.1d&&/6T|3R/.17(e)&&!E.3W(d))K d.4z(e,2);K d.4z(e)}N{7(e=="1y"&&E.14.1d){7(c!=10){d.6q=1;d.1F=(d.1F||"").1p(/6W\\([^)]*\\)/,"")+(2M(c).3D()=="93"?"":"6W(1y="+c*6S+")")}K d.1F&&d.1F.1g("1y=")>=0?(2M(d.1F.1E(/1y=([^)]*)/)[1])/6S).3D():""}e=e.1p(/-([a-z])/92,J(a,b){K b.2F()});7(c!=10)d[e]=c;K d[e]}},3f:J(a){K(a||"").1p(/^\\s+|\\s+$/g,"")},2H:J(b){L a=[];7(1v b!="91")P(L i=0,M=b.M;i<M;i++)a.1h(b[i]);N a=b.2V(0);K a},35:J(b,a){P(L i=0,M=a.M;i<M;i++)7(a[i]==b)K i;K-1},34:J(a,b){7(E.14.1d){P(L i=0;b[i];i++)7(b[i].15!=8)a.1h(b[i])}N P(L i=0;b[i];i++)a.1h(b[i]);K a},57:J(a){L c=[],2j={};1R{P(L i=0,M=a.M;i<M;i++){L b=E.Q(a[i]);7(!2j[b]){2j[b]=R;c.1h(a[i])}}}1W(e){c=a}K c},3x:J(c,a,d){7(1v a=="25")a=4A("S||J(a,i){K "+a+"}");L b=[];P(L i=0,M=c.M;i<M;i++)7(!d&&a(c[i],i)||d&&!a(c[i],i))b.1h(c[i]);K b},2a:J(d,a){L c=[];P(L i=0,M=d.M;i<M;i++){L b=a(d[i],i);7(b!==W&&b!=10){7(b.1n!=1N)b=[b];c=c.6Q(b)}}K c}});L v=8X.8V.2w();E.14={5n:(v.1E(/.+(?:8R|8Q|8P|8O)[\\/: ]([\\d.]+)/)||[])[1],26:/6L/.17(v),2B:/2B/.17(v),1d:/1d/.17(v)&&!/2B/.17(v),3X:/3X/.17(v)&&!/(8M|6L)/.17(v)};L y=E.14.1d?"6K":"6J";E.1s({8J:!E.14.1d||T.6I=="6H",3S:{"P":"8G","8E":"1w","4c":y,6J:y,6K:y,38:"38",1w:"1w",1C:"1C",2W:"2W",3o:"3o",8C:"8B",2p:"2p",8A:"8z",44:"44",6F:"6F",28:"28",12:"12"}});E.V({6E:"O.1b",8y:"19.4w(O,\'1b\')",8x:"19.31(O,2,\'2J\')",8w:"19.31(O,2,\'4v\')",8v:"19.4w(O,\'2J\')",8u:"19.4w(O,\'4v\')",8s:"19.5m(O.1b.1B,O)",8r:"19.5m(O.1B)",6C:"19.12(O,\'8q\')?O.8p||O.8o.T:19.2H(O.3p)"},J(c,d){d=4A("S||J(O){K "+d+"}");E.1i[c]=J(b){L a=E.2a(6,d);7(b&&1v b=="25")a=E.3d(b,a);K 6.2E(E.57(a))}});E.V({6B:"3t",8n:"6s",3n:"6o",8l:"5a",8k:"6P"},J(c,b){E.1i[c]=J(){L a=1a;K 6.V(J(){P(L i=0,M=a.M;i<M;i++)E(a[i])[b](6)})}});E.V({8j:J(a){E.1K(6,a,"");7(6.15==1)6.55(a)},8i:J(a){E.1w.1c(6,a)},8h:J(a){E.1w.1Y(6,a)},8g:J(a){E.1w[E.1w.3E(6,a)?"1Y":"1c"](6,a)},1Y:J(a){7(!a||E.1F(a,[6]).r.M){E("*",6).1c(6).V(J(){E.16.1Y(6);E.3H(6)});7(6.1b)6.1b.2X(6)}},4B:J(){E(">*",6).1Y();2e(6.1B)6.2X(6.1B)}},J(a,b){E.1i[a]=J(){K 6.V(b,1a)}});E.V(["8e","62"],J(i,c){L b=c.2w();E.1i[b]=J(a){K 6[0]==1e?E.14.2B&&T.1k["5h"+c]||E.14.26&&1e["8d"+c]||T.6I=="6H"&&T.1I["5h"+c]||T.1k["5h"+c]:6[0]==T?1Z.2b(1Z.2b(T.1k["5g"+c],T.1I["5g"+c]),1Z.2b(T.1k["5f"+c],T.1I["5f"+c])):a==10?(6.M?E.1m(6[0],b):W):6.1m(b,a.1n==4d?a:a+"2P")}});L C=E.14.26&&4t(E.14.5n)<8c?"(?:[\\\\w*4s-]|\\\\\\\\.)":"(?:[\\\\w\\8b-\\8a*4s-]|\\\\\\\\.)",6w=1D 4r("^>\\\\s*("+C+"+)"),6v=1D 4r("^("+C+"+)(#)("+C+"+)"),6u=1D 4r("^([#.]?)("+C+"*)");E.1s({5d:{"":"m[2]==\'*\'||19.12(a,m[2])","#":"a.4z(\'2s\')==m[2]",":":{88:"i<m[3]-0",86:"i>m[3]-0",31:"m[3]-0==i",6N:"m[3]-0==i",3j:"i==0",3M:"i==r.M-1",6r:"i%2==0",6p:"i%2","3j-4m":"a.1b.3V(\'*\')[0]==a","3M-4m":"19.31(a.1b.5D,1,\'4v\')==a","84-4m":"!19.31(a.1b.5D,2,\'4v\')",6E:"a.1B",4B:"!a.1B",83:"(a.6A||a.80||19(a).1t()||\'\').1g(m[3])>=0",4b:\'"23"!=a.U&&19.1m(a,"18")!="2D"&&19.1m(a,"4X")!="23"\',23:\'"23"==a.U||19.1m(a,"18")=="2D"||19.1m(a,"4X")=="23"\',7Y:"!a.2W",2W:"a.2W",3o:"a.3o",2p:"a.2p||19.1K(a,\'2p\')",1t:"\'1t\'==a.U",5w:"\'5w\'==a.U",5y:"\'5y\'==a.U",5b:"\'5b\'==a.U",3J:"\'3J\'==a.U",59:"\'59\'==a.U",6n:"\'6n\'==a.U",6m:"\'6m\'==a.U",2G:\'"2G"==a.U||19.12(a,"2G")\',48:"/48|2y|6l|2G/i.17(a.12)",3E:"19.2r(m[3],a).M",7X:"/h\\\\d/i.17(a.12)",7W:"19.3x(19.3I,J(1i){K a==1i.O;}).M"}},6j:[/^(\\[) *@?([\\w-]+) *([!*$^~=]*) *(\'?"?)(.*?)\\4 *\\]/,/^(:)([\\w-]+)\\("?\'?(.*?(\\(.*?\\))?[^(]*?)"?\'?\\)/,1D 4r("^([:.#]*)("+C+"+)")],3d:J(a,c,b){L d,2o=[];2e(a&&a!=d){d=a;L f=E.1F(a,c,b);a=f.t.1p(/^\\s*,\\s*/,"");2o=b?c=f.r:E.34(2o,f.r)}K 2o},2r:J(t,p){7(1v t!="25")K[t];7(p&&p.15!=1&&p.15!=9)K[];p=p||T;L d=[p],2j=[],3M,12;2e(t&&3M!=t){L r=[];3M=t;t=E.3f(t);L o=S;L g=6w;L m=g.39(t);7(m){12=m[1].2F();P(L i=0;d[i];i++)P(L c=d[i].1B;c;c=c.2J)7(c.15==1&&(12=="*"||c.12.2F()==12))r.1h(c);d=r;t=t.1p(g,"");7(t.1g(" ")==0)6z;o=R}N{g=/^([>+~])\\s*(\\w*)/i;7((m=g.39(t))!=W){r=[];L l={};12=m[2].2F();m=m[1];P(L j=0,3g=d.M;j<3g;j++){L n=m=="~"||m=="+"?d[j].2J:d[j].1B;P(;n;n=n.2J)7(n.15==1){L h=E.Q(n);7(m=="~"&&l[h])1T;7(!12||n.12.2F()==12){7(m=="~")l[h]=R;r.1h(n)}7(m=="+")1T}}d=r;t=E.3f(t.1p(g,""));o=R}}7(t&&!o){7(!t.1g(",")){7(p==d[0])d.4k();2j=E.34(2j,d);r=d=[p];t=" "+t.6i(1,t.M)}N{L k=6v;L m=k.39(t);7(m){m=[0,m[2],m[3],m[1]]}N{k=6u;m=k.39(t)}m[2]=m[2].1p(/\\\\/g,"");L f=d[d.M-1];7(m[1]=="#"&&f&&f.5N&&!E.3W(f)){L q=f.5N(m[2]);7((E.14.1d||E.14.2B)&&q&&1v q.2s=="25"&&q.2s!=m[2])q=E(\'[@2s="\'+m[2]+\'"]\',f)[0];d=r=q&&(!m[3]||E.12(q,m[3]))?[q]:[]}N{P(L i=0;d[i];i++){L a=m[1]=="#"&&m[3]?m[3]:m[1]!=""||m[0]==""?"*":m[2];7(a=="*"&&d[i].12.2w()=="4D")a="3v";r=E.34(r,d[i].3V(a))}7(m[1]==".")r=E.58(r,m[2]);7(m[1]=="#"){L e=[];P(L i=0;r[i];i++)7(r[i].4z("2s")==m[2]){e=[r[i]];1T}r=e}d=r}t=t.1p(k,"")}}7(t){L b=E.1F(t,r);d=r=b.r;t=E.3f(b.t)}}7(t)d=[];7(d&&p==d[0])d.4k();2j=E.34(2j,d);K 2j},58:J(r,m,a){m=" "+m+" ";L c=[];P(L i=0;r[i];i++){L b=(" "+r[i].1w+" ").1g(m)>=0;7(!a&&b||a&&!b)c.1h(r[i])}K c},1F:J(t,r,h){L d;2e(t&&t!=d){d=t;L p=E.6j,m;P(L i=0;p[i];i++){m=p[i].39(t);7(m){t=t.7V(m[0].M);m[2]=m[2].1p(/\\\\/g,"");1T}}7(!m)1T;7(m[1]==":"&&m[2]=="4I")r=G.17(m[3])?E.1F(m[3],r,R).r:E(r).4I(m[3]);N 7(m[1]==".")r=E.58(r,m[2],h);N 7(m[1]=="["){L g=[],U=m[3];P(L i=0,3g=r.M;i<3g;i++){L a=r[i],z=a[E.3S[m[2]]||m[2]];7(z==W||/6T|3R|2p/.17(m[2]))z=E.1K(a,m[2])||\'\';7((U==""&&!!z||U=="="&&z==m[5]||U=="!="&&z!=m[5]||U=="^="&&z&&!z.1g(m[5])||U=="$="&&z.6i(z.M-m[5].M)==m[5]||(U=="*="||U=="~=")&&z.1g(m[5])>=0)^h)g.1h(a)}r=g}N 7(m[1]==":"&&m[2]=="31-4m"){L e={},g=[],17=/(-?)(\\d*)n((?:\\+|-)?\\d*)/.39(m[3]=="6r"&&"2n"||m[3]=="6p"&&"2n+1"||!/\\D/.17(m[3])&&"7U+"+m[3]||m[3]),3j=(17[1]+(17[2]||1))-0,d=17[3]-0;P(L i=0,3g=r.M;i<3g;i++){L j=r[i],1b=j.1b,2s=E.Q(1b);7(!e[2s]){L c=1;P(L n=1b.1B;n;n=n.2J)7(n.15==1)n.4p=c++;e[2s]=R}L b=S;7(3j==0){7(j.4p==d)b=R}N 7((j.4p-d)%3j==0&&(j.4p-d)/3j>=0)b=R;7(b^h)g.1h(j)}r=g}N{L f=E.5d[m[1]];7(1v f!="25")f=E.5d[m[1]][m[2]];f=4A("S||J(a,i){K "+f+"}");r=E.3x(r,f,h)}}K{r:r,t:t}},4w:J(b,c){L d=[];L a=b[c];2e(a&&a!=T){7(a.15==1)d.1h(a);a=a[c]}K d},31:J(a,e,c,b){e=e||1;L d=0;P(;a;a=a[c])7(a.15==1&&++d==e)1T;K a},5m:J(n,a){L r=[];P(;n;n=n.2J){7(n.15==1&&(!a||n!=a))r.1h(n)}K r}});E.16={1c:J(f,i,g,e){7(f.15==3||f.15==8)K;7(E.14.1d&&f.54!=10)f=1e;7(!g.2A)g.2A=6.2A++;7(e!=10){L h=g;g=J(){K h.1j(6,1a)};g.Q=e;g.2A=h.2A}L j=E.Q(f,"2N")||E.Q(f,"2N",{}),1x=E.Q(f,"1x")||E.Q(f,"1x",J(){L a;7(1v E=="10"||E.16.52)K a;a=E.16.1x.1j(1a.3G.O,1a);K a});1x.O=f;E.V(i.2d(/\\s+/),J(c,b){L a=b.2d(".");b=a[0];g.U=a[1];L d=j[b];7(!d){d=j[b]={};7(!E.16.2l[b]||E.16.2l[b].4i.1O(f)===S){7(f.3F)f.3F(b,1x,S);N 7(f.6h)f.6h("4h"+b,1x)}}d[g.2A]=g;E.16.2g[b]=R});f=W},2A:1,2g:{},1Y:J(e,h,f){7(e.15==3||e.15==8)K;L i=E.Q(e,"2N"),2f,5E;7(i){7(h==10)P(L g 1r i)6.1Y(e,g);N{7(h.U){f=h.2k;h=h.U}E.V(h.2d(/\\s+/),J(b,a){L c=a.2d(".");a=c[0];7(i[a]){7(f)2T i[a][f.2A];N P(f 1r i[a])7(!c[1]||i[a][f].U==c[1])2T i[a][f];P(2f 1r i[a])1T;7(!2f){7(!E.16.2l[a]||E.16.2l[a].4g.1O(e)===S){7(e.6f)e.6f(a,E.Q(e,"1x"),S);N 7(e.6d)e.6d("4h"+a,E.Q(e,"1x"))}2f=W;2T i[a]}}})}P(2f 1r i)1T;7(!2f){L d=E.Q(e,"1x");7(d)d.O=W;E.3H(e,"2N");E.3H(e,"1x")}}},1U:J(f,b,c,d,g){b=E.2H(b||[]);7(!c){7(6.2g[f])E("*").1c([1e,T]).1U(f,b)}N{7(c.15==3||c.15==8)K 10;L a,2f,1i=E.1q(c[f]||W),16=!b[0]||!b[0].32;7(16)b.4U(6.51({U:f,2K:c}));b[0].U=f;7(E.1q(E.Q(c,"1x")))a=E.Q(c,"1x").1j(c,b);7(!1i&&c["4h"+f]&&c["4h"+f].1j(c,b)===S)a=S;7(16)b.4k();7(g&&E.1q(g)){2f=g.1j(c,a==W?b:b.6Q(a));7(2f!==10)a=2f}7(1i&&d!==S&&a!==S&&!(E.12(c,\'a\')&&f=="50")){6.52=R;1R{c[f]()}1W(e){}}6.52=S}K a},1x:J(c){L a;c=E.16.51(c||1e.16||{});L b=c.U.2d(".");c.U=b[0];L f=E.Q(6,"2N")&&E.Q(6,"2N")[c.U],3B=1N.2m.2V.1O(1a,1);3B.4U(c);P(L j 1r f){L d=f[j];3B[0].2k=d;3B[0].Q=d.Q;7(!b[1]||d.U==b[1]){L e=d.1j(6,3B);7(a!==S)a=e;7(e===S){c.32();c.41()}}}7(E.14.1d)c.2K=c.32=c.41=c.2k=c.Q=W;K a},51:J(c){L a=c;c=E.1s({},a);c.32=J(){7(a.32)a.32();a.7T=S};c.41=J(){7(a.41)a.41();a.7S=R};7(!c.2K)c.2K=c.7R||T;7(c.2K.15==3)c.2K=a.2K.1b;7(!c.4W&&c.4V)c.4W=c.4V==c.2K?c.7Q:c.4V;7(c.6b==W&&c.6a!=W){L b=T.1I,1k=T.1k;c.6b=c.6a+(b&&b.2i||1k&&1k.2i||0)-(b.68||0);c.7O=c.7N+(b&&b.2x||1k&&1k.2x||0)-(b.67||0)}7(!c.3r&&((c.4f||c.4f===0)?c.4f:c.66))c.3r=c.4f||c.66;7(!c.65&&c.64)c.65=c.64;7(!c.3r&&c.2G)c.3r=(c.2G&1?1:(c.2G&2?3:(c.2G&4?2:0)));K c},2l:{21:{4i:J(){5A();K},4g:J(){K}},47:{4i:J(){7(E.14.1d)K S;E(6).2z("4Q",E.16.2l.47.2k);K R},4g:J(){7(E.14.1d)K S;E(6).42("4Q",E.16.2l.47.2k);K R},2k:J(a){7(I(a,6))K R;1a[0].U="47";K E.16.1x.1j(6,1a)}},46:{4i:J(){7(E.14.1d)K S;E(6).2z("4P",E.16.2l.46.2k);K R},4g:J(){7(E.14.1d)K S;E(6).42("4P",E.16.2l.46.2k);K R},2k:J(a){7(I(a,6))K R;1a[0].U="46";K E.16.1x.1j(6,1a)}}}};E.1i.1s({2z:J(c,a,b){K c=="4O"?6.30(c,a,b):6.V(J(){E.16.1c(6,c,b||a,b&&a)})},30:J(d,b,c){K 6.V(J(){E.16.1c(6,d,J(a){E(6).42(a);K(c||b).1j(6,1a)},c&&b)})},42:J(a,b){K 6.V(J(){E.16.1Y(6,a,b)})},1U:J(c,a,b){K 6.V(J(){E.16.1U(c,a,6,R,b)})},63:J(c,a,b){7(6[0])K E.16.1U(c,a,6[0],S,b);K 10},2h:J(){L b=1a;K 6.50(J(a){6.4N=0==6.4N?1:0;a.32();K b[6.4N].1j(6,1a)||S})},7F:J(a,b){K 6.2z(\'47\',a).2z(\'46\',b)},21:J(a){5A();7(E.2Q)a.1O(T,E);N E.3w.1h(J(){K a.1O(6,E)});K 6}});E.1s({2Q:S,3w:[],21:J(){7(!E.2Q){E.2Q=R;7(E.3w){E.V(E.3w,J(){6.1j(T)});E.3w=W}E(T).63("21")}}});L x=S;J 5A(){7(x)K;x=R;7(T.3F&&!E.14.2B)T.3F("61",E.21,S);7(E.14.1d&&1e==3b)(J(){7(E.2Q)K;1R{T.1I.7D("2c")}1W(3e){3z(1a.3G,0);K}E.21()})();7(E.14.2B)T.3F("61",J(){7(E.2Q)K;P(L i=0;i<T.4M.M;i++)7(T.4M[i].2W){3z(1a.3G,0);K}E.21()},S);7(E.14.26){L a;(J(){7(E.2Q)K;7(T.3c!="60"&&T.3c!="1z"){3z(1a.3G,0);K}7(a===10)a=E("Y, 5O[7B=7A]").M;7(T.4M.M!=a){3z(1a.3G,0);K}E.21()})()}E.16.1c(1e,"43",E.21)}E.V(("7z,7y,43,7x,5g,4O,50,7w,"+"7v,7u,7C,4Q,4P,7t,2y,"+"59,7s,7r,7G,3e").2d(","),J(i,b){E.1i[b]=J(a){K a?6.2z(b,a):6.1U(b)}});L I=J(a,c){L b=a.4W;2e(b&&b!=c)1R{b=b.1b}1W(3e){b=c}K b==c};E(1e).2z("4O",J(){E("*").1c(T).42()});E.1i.1s({43:J(g,d,c){7(E.1q(g))K 6.2z("43",g);L e=g.1g(" ");7(e>=0){L i=g.2V(e,g.M);g=g.2V(0,e)}c=c||J(){};L f="4J";7(d)7(E.1q(d)){c=d;d=W}N{d=E.3v(d);f="5Z"}L h=6;E.3Q({1f:g,U:f,1G:"3q",Q:d,1z:J(a,b){7(b=="1X"||b=="5Y")h.3q(i?E("<1u/>").3t(a.4e.1p(/<1o(.|\\s)*?\\/1o>/g,"")).2r(i):a.4e);h.V(c,[a.4e,b,a])}});K 6},7q:J(){K E.3v(6.5X())},5X:J(){K 6.2a(J(){K E.12(6,"3i")?E.2H(6.7p):6}).1F(J(){K 6.37&&!6.2W&&(6.3o||/2y|6l/i.17(6.12)||/1t|23|3J/i.17(6.U))}).2a(J(i,c){L b=E(6).5P();K b==W?W:b.1n==1N?E.2a(b,J(a,i){K{37:c.37,1C:a}}):{37:c.37,1C:b}}).22()}});E.V("5W,5V,5U,69,5T,5S".2d(","),J(i,o){E.1i[o]=J(f){K 6.2z(o,f)}});L B=(1D 3O).3N();E.1s({22:J(d,b,a,c){7(E.1q(b)){a=b;b=W}K E.3Q({U:"4J",1f:d,Q:b,1X:a,1G:c})},7o:J(b,a){K E.22(b,W,a,"1o")},7n:J(c,b,a){K E.22(c,b,a,"2O")},7m:J(d,b,a,c){7(E.1q(b)){a=b;b={}}K E.3Q({U:"5Z",1f:d,Q:b,1X:a,1G:c})},7Z:J(a){E.1s(E.4H,a)},4H:{2g:R,U:"4J",2U:0,5R:"49/x-7j-3i-7i",6x:R,3l:R,Q:W,6t:W,3J:W,4n:{3L:"49/3L, 1t/3L",3q:"1t/3q",1o:"1t/4l, 49/4l",2O:"49/2O, 1t/4l",1t:"1t/7e",4o:"*/*"}},4q:{},3Q:J(s){L f,2Y=/=\\?(&|$)/g,1A,Q;s=E.1s(R,s,E.1s(R,{},E.4H,s));7(s.Q&&s.6x&&1v s.Q!="25")s.Q=E.3v(s.Q);7(s.1G=="4u"){7(s.U.2w()=="22"){7(!s.1f.1E(2Y))s.1f+=(s.1f.1E(/\\?/)?"&":"?")+(s.4u||"7d")+"=?"}N 7(!s.Q||!s.Q.1E(2Y))s.Q=(s.Q?s.Q+"&":"")+(s.4u||"7d")+"=?";s.1G="2O"}7(s.1G=="2O"&&(s.Q&&s.Q.1E(2Y)||s.1f.1E(2Y))){f="4u"+B++;7(s.Q)s.Q=(s.Q+"").1p(2Y,"="+f+"$1");s.1f=s.1f.1p(2Y,"="+f+"$1");s.1G="1o";1e[f]=J(a){Q=a;1X();1z();1e[f]=10;1R{2T 1e[f]}1W(e){}7(h)h.2X(g)}}7(s.1G=="1o"&&s.1Q==W)s.1Q=S;7(s.1Q===S&&s.U.2w()=="22"){L i=(1D 3O()).3N();L j=s.1f.1p(/(\\?|&)4s=.*?(&|$)/,"$a2="+i+"$2");s.1f=j+((j==s.1f)?(s.1f.1E(/\\?/)?"&":"?")+"4s="+i:"")}7(s.Q&&s.U.2w()=="22"){s.1f+=(s.1f.1E(/\\?/)?"&":"?")+s.Q;s.Q=W}7(s.2g&&!E.5M++)E.16.1U("5W");7((!s.1f.1g("9Z")||!s.1f.1g("//"))&&(s.1G=="1o"||s.1G=="2O")&&s.U.2w()=="22"){L h=T.3V("6k")[0];L g=T.2R("1o");g.3R=s.1f;7(s.7c)g.9X=s.7c;7(!f){L l=S;g.9V=g.9U=J(){7(!l&&(!6.3c||6.3c=="60"||6.3c=="1z")){l=R;1X();1z();h.2X(g)}}}h.3k(g);K 10}L m=S;L k=1e.7a?1D 7a("9S.9Q"):1D 79();k.9P(s.U,s.1f,s.3l,s.6t,s.3J);1R{7(s.Q)k.4G("9N-9M",s.5R);7(s.5I)k.4G("9L-5H-9J",E.4q[s.1f]||"9H, 9G 9E 9B 5G:5G:5G 9z");k.4G("X-9x-9u","79");k.4G("9t",s.1G&&s.4n[s.1G]?s.4n[s.1G]+", */*":s.4n.4o)}1W(e){}7(s.75)s.75(k);7(s.2g)E.16.1U("5S",[k,s]);L c=J(a){7(!m&&k&&(k.3c==4||a=="2U")){m=R;7(d){74(d);d=W}1A=a=="2U"&&"2U"||!E.73(k)&&"3e"||s.5I&&E.72(k,s.1f)&&"5Y"||"1X";7(1A=="1X"){1R{Q=E.71(k,s.1G)}1W(e){1A="5C"}}7(1A=="1X"){L b;1R{b=k.5B("70-5H")}1W(e){}7(s.5I&&b)E.4q[s.1f]=b;7(!f)1X()}N E.5t(s,k,1A);1z();7(s.3l)k=W}};7(s.3l){L d=54(c,13);7(s.2U>0)3z(J(){7(k){k.9m();7(!m)c("2U")}},s.2U)}1R{k.9l(s.Q)}1W(e){E.5t(s,k,W,e)}7(!s.3l)c();J 1X(){7(s.1X)s.1X(Q,1A);7(s.2g)E.16.1U("5T",[k,s])}J 1z(){7(s.1z)s.1z(k,1A);7(s.2g)E.16.1U("5U",[k,s]);7(s.2g&&!--E.5M)E.16.1U("5V")}K k},5t:J(s,a,b,e){7(s.3e)s.3e(a,b,e);7(s.2g)E.16.1U("69",[a,s,e])},5M:0,73:J(r){1R{K!r.1A&&9k.9j=="5b:"||(r.1A>=6Y&&r.1A<9h)||r.1A==6X||r.1A==9e||E.14.26&&r.1A==10}1W(e){}K S},72:J(a,c){1R{L b=a.5B("70-5H");K a.1A==6X||b==E.4q[c]||E.14.26&&a.1A==10}1W(e){}K S},71:J(r,b){L c=r.5B("9d-U");L d=b=="3L"||!b&&c&&c.1g("3L")>=0;L a=d?r.9c:r.4e;7(d&&a.1I.28=="5C")6Z"5C";7(b=="1o")E.5l(a);7(b=="2O")a=4A("("+a+")");K a},3v:J(a){L s=[];7(a.1n==1N||a.5j)E.V(a,J(){s.1h(3s(6.37)+"="+3s(6.1C))});N P(L j 1r a)7(a[j]&&a[j].1n==1N)E.V(a[j],J(){s.1h(3s(j)+"="+3s(6))});N s.1h(3s(j)+"="+3s(a[j]));K s.6g("&").1p(/%20/g,"+")}});E.1i.1s({1J:J(c,b){K c?6.27({1P:"1J",29:"1J",1y:"1J"},c,b):6.1F(":23").V(J(){6.Y.18=6.5x||"";7(E.1m(6,"18")=="2D"){L a=E("<"+6.28+" />").6B("1k");6.Y.18=a.1m("18");7(6.Y.18=="2D")6.Y.18="3u";a.1Y()}}).3h()},1H:J(b,a){K b?6.27({1P:"1H",29:"1H",1y:"1H"},b,a):6.1F(":4b").V(J(){6.5x=6.5x||E.1m(6,"18");6.Y.18="2D"}).3h()},6U:E.1i.2h,2h:J(a,b){K E.1q(a)&&E.1q(b)?6.6U(a,b):a?6.27({1P:"2h",29:"2h",1y:"2h"},a,b):6.V(J(){E(6)[E(6).3K(":23")?"1J":"1H"]()})},98:J(b,a){K 6.27({1P:"1J"},b,a)},97:J(b,a){K 6.27({1P:"1H"},b,a)},96:J(b,a){K 6.27({1P:"2h"},b,a)},95:J(b,a){K 6.27({1y:"1J"},b,a)},94:J(b,a){K 6.27({1y:"1H"},b,a)},9f:J(c,a,b){K 6.27({1y:a},c,b)},27:J(l,k,j,h){L i=E.6V(k,j,h);K 6[i.2S===S?"V":"2S"](J(){7(6.15!=1)K S;L g=E.1s({},i);L f=E(6).3K(":23"),4y=6;P(L p 1r l){7(l[p]=="1H"&&f||l[p]=="1J"&&!f)K E.1q(g.1z)&&g.1z.1j(6);7(p=="1P"||p=="29"){g.18=E.1m(6,"18");g.36=6.Y.36}}7(g.36!=W)6.Y.36="23";g.40=E.1s({},l);E.V(l,J(c,a){L e=1D E.2v(4y,g,c);7(/2h|1J|1H/.17(a))e[a=="2h"?f?"1J":"1H":a](l);N{L b=a.3D().1E(/^([+-]=)?([\\d+-.]+)(.*)$/),24=e.2o(R)||0;7(b){L d=2M(b[2]),2C=b[3]||"2P";7(2C!="2P"){4y.Y[c]=(d||1)+2C;24=((d||1)/e.2o(R))*24;4y.Y[c]=24+2C}7(b[1])d=((b[1]=="-="?-1:1)*d)+24;e.3Z(24,d,2C)}N e.3Z(24,a,"")}});K R})},2S:J(a,b){7(E.1q(a)||(a&&a.1n==1N)){b=a;a="2v"}7(!a||(1v a=="25"&&!b))K A(6[0],a);K 6.V(J(){7(b.1n==1N)A(6,a,b);N{A(6,a).1h(b);7(A(6,a).M==1)b.1j(6)}})},8Z:J(b,c){L a=E.3I;7(b)6.2S([]);6.V(J(){P(L i=a.M-1;i>=0;i--)7(a[i].O==6){7(c)a[i](R);a.6R(i,1)}});7(!c)6.5z();K 6}});L A=J(b,c,a){7(!b)K 10;c=c||"2v";L q=E.Q(b,c+"2S");7(!q||a)q=E.Q(b,c+"2S",a?E.2H(a):[]);K q};E.1i.5z=J(a){a=a||"2v";K 6.V(J(){L q=A(6,a);q.4k();7(q.M)q[0].1j(6)})};E.1s({6V:J(b,a,c){L d=b&&b.1n==8Y?b:{1z:c||!c&&a||E.1q(b)&&b,2t:b,3Y:c&&a||a&&a.1n!=8W&&a};d.2t=(d.2t&&d.2t.1n==53?d.2t:{9w:8U,8T:6Y}[d.2t])||8S;d.5o=d.1z;d.1z=J(){7(d.2S!==S)E(6).5z();7(E.1q(d.5o))d.5o.1j(6)};K d},3Y:{6O:J(p,n,b,a){K b+a*p},5F:J(p,n,b,a){K((-1Z.9C(p*1Z.9D)/2)+0.5)*a+b}},3I:[],3T:W,2v:J(b,c,a){6.11=c;6.O=b;6.1l=a;7(!c.3U)c.3U={}}});E.2v.2m={4C:J(){7(6.11.33)6.11.33.1j(6.O,[6.2I,6]);(E.2v.33[6.1l]||E.2v.33.4o)(6);7(6.1l=="1P"||6.1l=="29")6.O.Y.18="3u"},2o:J(a){7(6.O[6.1l]!=W&&6.O.Y[6.1l]==W)K 6.O[6.1l];L r=2M(E.1m(6.O,6.1l,a));K r&&r>-8N?r:2M(E.2q(6.O,6.1l))||0},3Z:J(c,b,d){6.5s=(1D 3O()).3N();6.24=c;6.3h=b;6.2C=d||6.2C||"2P";6.2I=6.24;6.4E=6.4F=0;6.4C();L e=6;J t(a){K e.33(a)}t.O=6.O;E.3I.1h(t);7(E.3T==W){E.3T=54(J(){L a=E.3I;P(L i=0;i<a.M;i++)7(!a[i]())a.6R(i--,1);7(!a.M){74(E.3T);E.3T=W}},13)}},1J:J(){6.11.3U[6.1l]=E.1K(6.O.Y,6.1l);6.11.1J=R;6.3Z(0,6.2o());7(6.1l=="29"||6.1l=="1P")6.O.Y[6.1l]="8L";E(6.O).1J()},1H:J(){6.11.3U[6.1l]=E.1K(6.O.Y,6.1l);6.11.1H=R;6.3Z(6.2o(),0)},33:J(a){L t=(1D 3O()).3N();7(a||t>6.11.2t+6.5s){6.2I=6.3h;6.4E=6.4F=1;6.4C();6.11.40[6.1l]=R;L b=R;P(L i 1r 6.11.40)7(6.11.40[i]!==R)b=S;7(b){7(6.11.18!=W){6.O.Y.36=6.11.36;6.O.Y.18=6.11.18;7(E.1m(6.O,"18")=="2D")6.O.Y.18="3u"}7(6.11.1H)6.O.Y.18="2D";7(6.11.1H||6.11.1J)P(L p 1r 6.11.40)E.1K(6.O.Y,p,6.11.3U[p])}7(b&&E.1q(6.11.1z))6.11.1z.1j(6.O);K S}N{L n=t-6.5s;6.4F=n/6.11.2t;6.4E=E.3Y[6.11.3Y||(E.3Y.5F?"5F":"6O")](6.4F,n,0,1,6.11.2t);6.2I=6.24+((6.3h-6.24)*6.4E);6.4C()}K R}};E.2v.33={2i:J(a){a.O.2i=a.2I},2x:J(a){a.O.2x=a.2I},1y:J(a){E.1K(a.O.Y,"1y",a.2I)},4o:J(a){a.O.Y[a.1l]=a.2I+a.2C}};E.1i.5f=J(){L b=0,3b=0,O=6[0],5q;7(O)8K(E.14){L d=O.1b,45=O,1M=O.1M,1L=O.2u,5p=26&&4t(5n)<8H,2Z=E.1m(O,"3C")=="2Z";7(O.7b){L c=O.7b();1c(c.2c+1Z.2b(1L.1I.2i,1L.1k.2i),c.3b+1Z.2b(1L.1I.2x,1L.1k.2x));1c(-1L.1I.68,-1L.1I.67)}N{1c(O.5k,O.5K);2e(1M){1c(1M.5k,1M.5K);7(3X&&!/^t(8F|d|h)$/i.17(1M.28)||26&&!5p)3a(1M);7(!2Z&&E.1m(1M,"3C")=="2Z")2Z=R;45=/^1k$/i.17(1M.28)?45:1M;1M=1M.1M}2e(d&&d.28&&!/^1k|3q$/i.17(d.28)){7(!/^a0|1V.*$/i.17(E.1m(d,"18")))1c(-d.2i,-d.2x);7(3X&&E.1m(d,"36")!="4b")3a(d);d=d.1b}7((5p&&(2Z||E.1m(45,"3C")=="4Z"))||(3X&&E.1m(45,"3C")!="4Z"))1c(-1L.1k.5k,-1L.1k.5K);7(2Z)1c(1Z.2b(1L.1I.2i,1L.1k.2i),1Z.2b(1L.1I.2x,1L.1k.2x))}5q={3b:3b,2c:b}}J 3a(a){1c(E.2q(a,"a1",R),E.2q(a,"8D",R))}J 1c(l,t){b+=4t(l)||0;3b+=4t(t)||0}K 5q}})();',62,624,'||||||this|if||||||||||||||||||||||||||||||||||||||function|return|var|length|else|elem|for|data|true|false|document|type|each|null||style||undefined|options|nodeName||browser|nodeType|event|test|display|jQuery|arguments|parentNode|add|msie|window|url|indexOf|push|fn|apply|body|prop|css|constructor|script|replace|isFunction|in|extend|text|div|typeof|className|handle|opacity|complete|status|firstChild|value|new|match|filter|dataType|hide|documentElement|show|attr|doc|offsetParent|Array|call|height|cache|try|tbody|break|trigger|table|catch|success|remove|Math||ready|get|hidden|start|string|safari|animate|tagName|width|map|max|left|split|while|ret|global|toggle|scrollLeft|done|handler|special|prototype||cur|selected|curCSS|find|id|duration|ownerDocument|fx|toLowerCase|scrollTop|select|bind|guid|opera|unit|none|pushStack|toUpperCase|button|makeArray|now|nextSibling|target|stack|parseFloat|events|json|px|isReady|createElement|queue|delete|timeout|slice|disabled|removeChild|jsre|fixed|one|nth|preventDefault|step|merge|inArray|overflow|name|innerHTML|exec|border|top|readyState|multiFilter|error|trim|rl|end|form|first|appendChild|async|elems|insertBefore|checked|childNodes|html|which|encodeURIComponent|append|block|param|readyList|grep|color|setTimeout|runtimeStyle|args|position|toString|has|addEventListener|callee|removeData|timers|password|is|xml|last|getTime|Date|domManip|ajax|src|props|timerId|orig|getElementsByTagName|isXMLDoc|mozilla|easing|custom|curAnim|stopPropagation|unbind|load|selectedIndex|offsetChild|mouseleave|mouseenter|input|application|defaultView|visible|float|String|responseText|charCode|teardown|on|setup|currentStyle|shift|javascript|child|accepts|_default|nodeIndex|lastModified|RegExp|_|parseInt|jsonp|previousSibling|dir|tr|self|getAttribute|eval|empty|update|object|pos|state|setRequestHeader|ajaxSettings|not|GET|getPropertyValue|getComputedStyle|styleSheets|lastToggle|unload|mouseout|mouseover|andSelf|getWH|container2|unshift|fromElement|relatedTarget|visibility|init|absolute|click|fix|triggered|Number|setInterval|removeAttribute|prevObject|unique|classFilter|submit|after|file|clean|expr|windowData|offset|scroll|client|deep|jquery|offsetLeft|globalEval|sibling|version|old|safari2|results|wrapAll|startTime|handleError|container|createTextNode|radio|oldblock|checkbox|dequeue|bindReady|getResponseHeader|parsererror|lastChild|index|swing|00|Modified|ifModified|clone|offsetTop|values|active|getElementById|link|val|col|contentType|ajaxSend|ajaxSuccess|ajaxComplete|ajaxStop|ajaxStart|serializeArray|notmodified|POST|loaded|DOMContentLoaded|Width|triggerHandler|ctrlKey|metaKey|keyCode|clientTop|clientLeft|ajaxError|clientX|pageX|cloneNode|detachEvent|swap|removeEventListener|join|attachEvent|substr|parse|head|textarea|reset|image|before|odd|zoom|even|prepend|username|quickClass|quickID|quickChild|processData|uuid|continue|textContent|appendTo|contents|evalScript|parent|defaultValue|setArray|CSS1Compat|compatMode|cssFloat|styleFloat|webkit|nodeValue|eq|linear|replaceWith|concat|splice|100|href|_toggle|speed|alpha|304|200|throw|Last|httpData|httpNotModified|httpSuccess|clearInterval|beforeSend|colgroup|fieldset|multiple|XMLHttpRequest|ActiveXObject|getBoundingClientRect|scriptCharset|callback|plain|img|hasClass|br|urlencoded|www|abbr|pixelLeft|post|getJSON|getScript|elements|serialize|keypress|keydown|change|mouseup|mousedown|dblclick|resize|focus|blur|stylesheet|rel|mousemove|doScroll|round|hover|keyup|padding|offsetHeight|offsetWidth|Bottom|Top|Right|clientY|pageY|Left|toElement|srcElement|cancelBubble|returnValue|0n|substring|animated|header|enabled|ajaxSetup|innerText|noConflict|size|contains|only|line|gt|weight|lt|font|uFFFF|u0128|417|inner|Height|Boolean|toggleClass|removeClass|addClass|removeAttr|replaceAll|insertAfter|wrap|prependTo|contentWindow|contentDocument|iframe|children|siblings|wrapInner|prevAll|nextAll|prev|next|parents|maxLength|maxlength|readOnly|readonly|borderTopWidth|class|able|htmlFor|522|reverse|boxModel|with|1px|compatible|10000|ie|ra|it|rv|400|fast|600|userAgent|Function|navigator|Object|stop|option|array|ig|NaN|fadeOut|fadeIn|slideToggle|slideUp|slideDown|setAttribute|changed|be|responseXML|content|1223|fadeTo|can|300|property|protocol|location|send|abort|getAttributeNode|specified|method|action|cssText|attributes|Accept|With|th|slow|Requested|td|GMT|cap|1970|cos|PI|Jan|colg|01|Thu|tfoot|Since|thead|If|Type|Content|leg|open|XMLHTTP|opt|Microsoft|embed|onreadystatechange|onload|area|charset|hr|http|inline|borderLeftWidth|1_|meta'.split('|'),0,{}));
\ No newline at end of file
Modified: tags/2.5_min/http/extensions/json.js
--- branches/2.5/http/extensions/json.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/extensions/json.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,214 +1,28 @@
-    json.js
-    2007-01-10
-    This file adds these methods to JavaScript:
-		toJSONString(obj)
-        arrayToJSONString(obj)
-        booleanToJSONString(obj)
-        dateToJSONString(obj)
-        numberToJSONString(obj)
-        objectToJSONString(obj)
-        stringToJSONString(obj)
-            These methods produce a JSON text from a JavaScript value.
-            It must not contain any cyclical references. Illegal values
-            will be excluded.
-            The default conversion for dates is to an ISO string. You can
-            add a toJSONString method to any date object to get a different
-            representation.
-        parseJSON(string, filter)
-            This method parses a JSON text to produce an object or
-            array. It can throw a SyntaxError exception.
-            The optional filter parameter is a function which can filter and
-            transform the results. It receives each of the keys and values, and
-            its return value is used instead of the original value. If it
-            returns what it received, then structure is not modified. If it
-            returns undefined then the member is deleted.
-            Example:
-            // Parse the text. If a key contains the string 'date' then
-            // convert the value to a date.
-            myData = text.parseJSON(function (key, value) {
-                return key.indexOf('date') >= 0 ? new Date(value) : value;
-    It is expected that these methods will formally become part of the
-    JavaScript Programming Language in the Fourth Edition of the
-    ECMAScript standard in 2007.
-function arrayToJSONString(ao){
-	var a = ['['], b, i, l = ao.length, v;
-	function p(s) {
-		if (b) {
-			a.push(',');
-		a.push(s);
-		b = true;
-		v = ao[i];
-		switch (typeof v) {
-		case 'undefined':
-		case 'function':
-		case 'unknown':
-			break;
-		case 'object':
-			if (v) {
-				p(toJSONString(v));
-			} else {
-				p("null");
-			break;
-		default:
-	a.push(']');
-function boolToJSONString(bo) {
-	return String(bo);
-function dateToJSONString(dao) {
-	function f(n) {
-		return n < 10 ? '0' + n : n;
-	return '"' + dao.getFullYear() + '-' +
-		f(dao.getMonth() + 1) + '-' +
-		f(dao.getDate()) + 'T' +
-		f(dao.getHours()) + ':' +
-		f(dao.getMinutes()) + ':' +
-		f(dao.getSeconds()) + '"';
-function numberToJSONString(no) {
-	return isFinite(no) ? String(no) : "null";
-function objectToJSONString(ob) {
-	var a = ['{'], b, i, v;
-	function p(s) {
-		if (b) {
-			a.push(',');
-		a.push(toJSONString(i), ':', s);
-		b = true;
-	for (i in ob) {
-		if (ob.hasOwnProperty(i)) {
-			v = ob[i];
-			case 'undefined':
-			case 'function':
-			case 'unknown':
-				break;
-			case 'object':
-				if (v) {
-				} else {
-					p("null");
-				break;
-			default:
-	a.push('}');
-function stringToJSONString(so){
-	var m = {
-		'\b': '\\b',
-		'\t': '\\t',
-		'\n': '\\n',
-		'\f': '\\f',
-		'\r': '\\r',
-	if (/["\\\x00-\x1f]/.test(so)) {
-		return '"' + so.replace(/([\x00-\x1f\\"])/g, function(a, b) {
-			var c = m[b];
-			if (c) {
-				return c;
-			return '\\u00' +
-	return '"' + so + '"';
-function toJSONString(o){
-	switch(typeof o){
-	case 'undefined':
-	case 'function':
-	case 'unknown':
-		break;
-	case 'object':
-		if (o.constructor == Array){
-			return arrayToJSONString(o);
-		}else if(o.constructor == Date){
-			return dateToJSONString(o);
-		}else{
-			return objectToJSONString(o);
-	case 'number':
-		return numberToJSONString(o);
-	case 'string':
-		return stringToJSONString(o);
-	case 'boolean':
-		return boolToJSONString(o);
-function parseJSON(so, filter){
-	var m = {
-		'\b': '\\b',
-		'\t': '\\t',
-		'\n': '\\n',
-		'\f': '\\f',
-		'\r': '\\r',
-	try {
-		if (/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.
-				test(so)) {
-			var j = eval('(' + so + ')');
-			if (typeof filter === 'function') {
-				function walk(k, v) {
-					if (v && typeof v === 'object') {
-						for (var i in v) {
-							if (v.hasOwnProperty(i)) {
-								v[i] = walk(i, v[i]);
-					return filter(k, v);
-				return walk('', j);
-			return j;
-	} catch (e) {
-	throw new SyntaxError("parseJSON");
+function arrayToJSONString(ao){var a=['['],b,i,l=ao.length,v;function p(s){if(b){a.push(',');}
+a.push(s);b=true;}
+for(i=0;i<l;i+=1){v=ao[i];switch(typeof v){case'undefined':case'function':case'unknown':break;case'object':if(v){p(toJSONString(v));}else{p("null");}
+break;default:p(toJSONString(v));}}
+a.push(']');return a.join('');}
+function boolToJSONString(bo){return String(bo);};function dateToJSONString(dao){function f(n){return n<10?'0'+n:n;}
+return'"'+dao.getFullYear()+'-'+
+f(dao.getMonth()+1)+'-'+
+f(dao.getDate())+'T'+
+f(dao.getHours())+':'+
+f(dao.getMinutes())+':'+
+f(dao.getSeconds())+'"';};function numberToJSONString(no){return isFinite(no)?String(no):"null";};function objectToJSONString(ob){var a=['{'],b,i,v;function p(s){if(b){a.push(',');}
+a.push(toJSONString(i),':',s);b=true;}
+for(i in ob){if(ob.hasOwnProperty(i)){v=ob[i];switch(typeof v){case'undefined':case'function':case'unknown':break;case'object':if(v){p(toJSONString(v));}else{p("null");}
+break;default:p(toJSONString(v));}}}
+a.push('}');return a.join('');};function stringToJSONString(so){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};if(/["\\\x00-\x1f]/.test(so)){return'"'+so.replace(/([\x00-\x1f\\"])/g,function(a,b){var c=m[b];if(c){return c;}
+(c%16).toString(16);})+'"';}
+return'"'+so+'"';}
+function toJSONString(o){switch(typeof o){case'undefined':case'function':case'unknown':break;case'object':if(o.constructor==Array){return arrayToJSONString(o);}else if(o.constructor==Date){return dateToJSONString(o);}else{return objectToJSONString(o);}
+case'number':return numberToJSONString(o);case'string':return stringToJSONString(o);case'boolean':return boolToJSONString(o);}}
+function parseJSON(so,filter){var m={'\b':'\\b','\t':'\\t','\n':'\\n','\f':'\\f','\r':'\\r','"':'\\"','\\':'\\\\'};try{if(/^("(\\.|[^"\\\n\r])*?"|[,:{}\[\]0-9.\-+Eaeflnr-u \n\r\t])+?$/.test(so)){var j=eval('('+so+')');if(typeof filter==='function'){function walk(k,v){if(v&&typeof v==='object'){for(var i in v){if(v.hasOwnProperty(i)){v[i]=walk(i,v[i]);}}}
+return filter(k,v);}
+return walk('',j);}
+return j;}}catch(e){}
+throw new SyntaxError("parseJSON");}
Modified: tags/2.5_min/http/extensions/wz_jsgraphics.js
--- branches/2.5/http/extensions/wz_jsgraphics.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/extensions/wz_jsgraphics.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,938 +1,212 @@
-/* This notice must be untouched at all times.
-wz_jsgraphics.js    v. 2.3
-The latest version is available at
-http://www.walterzorn.com
-or http://www.devira.com
-or http://www.walterzorn.de
-Copyright (c) 2002-2004 Walter Zorn. All rights reserved.
-Created 3. 11. 2002 by Walter Zorn (Web: http://www.walterzorn.com )
-Last modified: 29. 9. 2004
-Performance optimizations for Internet Explorer
-by Thomas Frank and John Holdsworth.
-fillPolygon method implemented by Matthieu Haller.
-High Performance JavaScript Graphics Library.
-Provides methods
-- to draw lines, rectangles, ellipses, polygons
-  with specifiable line thickness,
-- to fill rectangles and ellipses
-- to draw text.
-NOTE: Operations, functions and branching have rather been optimized
-to efficiency and speed than to shortness of source code.
-LICENSE: LGPL
-This library is free software; you can redistribute it and/or
-modify it under the terms of the GNU Lesser General Public
-License (LGPL) as published by the Free Software Foundation; either
-version 2.1 of the License, or (at your option) any later version.
-This library is distributed in the hope that it will be useful,
-but WITHOUT ANY WARRANTY; without even the implied warranty of
-MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the GNU
-Lesser General Public License for more details.
-You should have received a copy of the GNU Lesser General Public
-License along with this library; if not, write to the Free Software
-Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA  02111-1307  USA,
-or see http://www.gnu.org/copyleft/lesser.html
-var jg_ihtm, jg_ie, jg_fast, jg_dom, jg_moz,
-jg_n4 = (document.layers && typeof document.classes != "undefined");
-function chkDHTM(x, i)
-        x = document.body || null;
-        jg_ie = x && typeof x.insertAdjacentHTML != "undefined";
-        jg_dom = (x && !jg_ie &&
-                typeof x.appendChild != "undefined" &&
-                typeof document.createRange != "undefined" &&
-                typeof (i = document.createRange()).setStartBefore != "undefined" &&
-                typeof i.createContextualFragment != "undefined");
-        jg_ihtm = !jg_ie && !jg_dom && x && typeof x.innerHTML != "undefined";
-        jg_fast = jg_ie && document.all && !window.opera;
-        jg_moz = jg_dom && typeof x.style.MozOpacity != "undefined";
+var jg_ihtm,jg_ie,jg_fast,jg_dom,jg_moz,jg_n4=(document.layers&&typeof document.classes!="undefined");function chkDHTM(x,i)
+{x=document.body||null;jg_ie=x&&typeof x.insertAdjacentHTML!="undefined";jg_dom=(x&&!jg_ie&&typeof x.appendChild!="undefined"&&typeof document.createRange!="undefined"&&typeof(i=document.createRange()).setStartBefore!="undefined"&&typeof i.createContextualFragment!="undefined");jg_ihtm=!jg_ie&&!jg_dom&&x&&typeof x.innerHTML!="undefined";jg_fast=jg_ie&&document.all&&!window.opera;jg_moz=jg_dom&&typeof x.style.MozOpacity!="undefined";}
 function pntDoc()
-        this.wnd.document.write(jg_fast? this.htmRpc() : this.htm);
-        this.htm = '';
+{this.wnd.document.write(jg_fast?this.htmRpc():this.htm);this.htm='';}
 function pntCnvDom()
-        var x = this.wnd.document.createRange();
-        x.setStartBefore(this.cnv);
-        x = x.createContextualFragment(jg_fast? this.htmRpc() : this.htm);
-        this.cnv.appendChild(x);
-        this.htm = '';
+{var x=this.wnd.document.createRange();x.setStartBefore(this.cnv);x=x.createContextualFragment(jg_fast?this.htmRpc():this.htm);this.cnv.appendChild(x);this.htm='';}
 function pntCnvIe()
-        this.cnv.insertAdjacentHTML("BeforeEnd", jg_fast? this.htmRpc() : this.htm);
-        this.htm = '';
+{this.cnv.insertAdjacentHTML("BeforeEnd",jg_fast?this.htmRpc():this.htm);this.htm='';}
 function pntCnvIhtm()
-        this.cnv.innerHTML += this.htm;
-        this.htm = '';
+{this.cnv.innerHTML+=this.htm;this.htm='';}
 function pntCnv()
-        this.htm = '';
-function mkDiv(x, y, w, h)
-		if (!isNaN(h)) {
-	        this.htm += '<div style="position:absolute;'+
-	                'left:' + x + 'px;'+
-	                'top:' + y + 'px;'+
-	                'width:' + w + 'px;'+
-	                'height:' + h + 'px;';
-	        if (ie) {
-	        		this.htm += '-opacity:' + cw_opacity + ';' +
-	                '-khtml-opacity:' + cw_opacity + ';'+
-	                'filter: alpha(opacity=' + (cw_opacity * 100) + ');';
-	//'-moz-opacity:' + window.cw_opacity + ';'+
-	        this.htm +=
-	                'clip:rect(0,'+w+'px,'+h+'px,0);'+
-	                'background-color:' + this.color +
-	                (!jg_moz? ';overflow:hidden' : '')+
-	                ';"><\/div>';
-function mkDivIe(x, y, w, h)
-		if (!isNaN(h)) {
-	        this.htm += '%%'+this.color+';'+x+';'+y+';'+w+';'+h+';';
-function mkDivPrt(x, y, w, h)
-                'border-left:' + w + 'px solid ' + this.color + ';'+
-                'width:0px;'+
-                'height:' + h + 'px;'+
-                ';"><\/div>';
-function mkLyr(x, y, w, h)
-        this.htm += '<layer '+
-                'left="' + x + '" '+
-                'top="' + y + '" '+
-                'width="' + w + '" '+
-                'height="' + h + '" '+
-                'bgcolor="' + this.color + '"><\/layer>\n';
-var regex =  /%%([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);/g;
-function htmRpc()
-        return this.htm.replace(
-                regex,
-                '<div style="overflow:hidden;position:absolute;background-color:'+
-                '$1;left:$2;top:$3;width:$4;height:$5"></div>\n');
+{this.htm='';}
+function mkDiv(x,y,w,h)
+{if(!isNaN(h)){this.htm+='<div style="position:absolute;'+'left:'+x+'px;'+'top:'+y+'px;'+'width:'+w+'px;'+'height:'+h+'px;';if(ie){this.htm+='-opacity:'+cw_opacity+';'+'-khtml-opacity:'+cw_opacity+';'+'filter: alpha(opacity='+(cw_opacity*100)+');';}
+this.htm+='clip:rect(0,'+w+'px,'+h+'px,0);'+'background-color:'+this.color+
+(!jg_moz?';overflow:hidden':'')+';"><\/div>';}}
+function mkDivIe(x,y,w,h)
+{if(!isNaN(h)){this.htm+='%%'+this.color+';'+x+';'+y+';'+w+';'+h+';';}}
+function mkDivPrt(x,y,w,h)
+{this.htm+='<div style="position:absolute;'+'border-left:'+w+'px solid '+this.color+';'+'left:'+x+'px;'+'top:'+y+'px;'+'width:0px;'+'height:'+h+'px;'+'clip:rect(0,'+w+'px,'+h+'px,0);'+'background-color:'+this.color+
+function mkLyr(x,y,w,h)
+{this.htm+='<layer '+'left="'+x+'" '+'top="'+y+'" '+'width="'+w+'" '+'height="'+h+'" '+'bgcolor="'+this.color+'"><\/layer>\n';}
+var regex=/%%([^;]+);([^;]+);([^;]+);([^;]+);([^;]+);/g;function htmRpc()
+{return this.htm.replace(regex,'<div style="overflow:hidden;position:absolute;background-color:'+'$1;left:$2;top:$3;width:$4;height:$5"></div>\n');}
 function htmPrtRpc()
-                regex,
-                '$1;left:$2;top:$3;width:$4;height:$5;border-left:$4px solid $1"></div>\n');
-function mkLin(x1, y1, x2, y2)
-        if (x1 > x2)
-                var _x2 = x2;
-                var _y2 = y2;
-                x2 = x1;
-                y2 = y1;
-                x1 = _x2;
-                y1 = _y2;
-        var dx = x2-x1, dy = Math.abs(y2-y1),
-        x = x1, y = y1,
-        yIncr = (y1 > y2)? -1 : 1;
-        if (dx >= dy)
-                var pr = dy<<1,
-                pru = pr - (dx<<1),
-                p = pr-dx,
-                ox = x;
-                while ((dx--) > 0)
-                        ++x;
-                        if (p > 0)
-                                this.mkDiv(ox, y, x-ox, 1);
-                                y += yIncr;
-                                p += pru;
-                                ox = x;
-                        else p += pr;
-                this.mkDiv(ox, y, x2-ox+1, 1);
-        else
-                var pr = dx<<1,
-                pru = pr - (dy<<1),
-                p = pr-dy,
-                oy = y;
-                if (y2 <= y1)
-                        while ((dy--) > 0)
-                                if (p > 0)
-                                        this.mkDiv(x++, y, 1, oy-y+1);
-                                        y += yIncr;
-                                        p += pru;
-                                        oy = y;
-                                else
-                                        y += yIncr;
-                                        p += pr;
-                        this.mkDiv(x2, y2, 1, oy-y2+1);
-                else
-                                y += yIncr;
-                                if (p > 0)
-                                        this.mkDiv(x++, oy, 1, y-oy);
-                                        p += pru;
-                                        oy = y;
-                                else p += pr;
-                        this.mkDiv(x2, oy, 1, y2-oy+1);
-function mkLin2D(x1, y1, x2, y2)
-        if (x1 > x2)
-                var _x2 = x2;
-                var _y2 = y2;
-                x2 = x1;
-                y2 = y1;
-                x1 = _x2;
-                y1 = _y2;
-        x = x1, y = y1,
-        var s = this.stroke;
-        if (dx >= dy)
-                if (s-3 > 0)
-                        var _s = (s*dx*Math.sqrt(1+dy*dy/(dx*dx))-dx-(s>>1)*dy) / dx;
-                        _s = (!(s-4)? Math.ceil(_s) : Math.round(_s)) + 1;
-                else var _s = s;
-                var ad = Math.ceil(s/2);
-                var pr = dy<<1,
-                p = pr-dx,
-                ox = x;
-                        ++x;
-                        if (p > 0)
-                                this.mkDiv(ox, y, x-ox+ad, _s);
-                                y += yIncr;
-                                p += pru;
-                                ox = x;
-                        else p += pr;
-                this.mkDiv(ox, y, x2-ox+ad+1, _s);
-        else
-                if (s-3 > 0)
-                        var _s = (s*dy*Math.sqrt(1+dx*dx/(dy*dy))-(s>>1)*dx-dy) / dy;
-                else var _s = s;
-                var ad = Math.round(s/2);
-                var pr = dx<<1,
-                p = pr-dy,
-                oy = y;
-                if (y2 <= y1)
-                        ++ad;
-                                if (p > 0)
-                                        this.mkDiv(x++, y, _s, oy-y+ad);
-                                        y += yIncr;
-                                        p += pru;
-                                        oy = y;
-                                else
-                                        y += yIncr;
-                                        p += pr;
-                        this.mkDiv(x2, y2, _s, oy-y2+ad);
-                else
-                                y += yIncr;
-                                if (p > 0)
-                                        this.mkDiv(x++, oy, _s, y-oy+ad);
-                                        p += pru;
-                                        oy = y;
-                                else p += pr;
-                        this.mkDiv(x2, oy, _s, y2-oy+ad+1);
-function mkLinDott(x1, y1, x2, y2)
-        if (x1 > x2)
-                var _x2 = x2;
-                var _y2 = y2;
-                x2 = x1;
-                y2 = y1;
-                x1 = _x2;
-                y1 = _y2;
-        x = x1, y = y1,
-        yIncr = (y1 > y2)? -1 : 1,
-        drw = true;
-        if (dx >= dy)
-                var pr = dy<<1,
-                p = pr-dx;
-                        if (drw) this.mkDiv(x, y, 1, 1);
-                        drw = !drw;
-                        if (p > 0)
-                                y += yIncr;
-                                p += pru;
-                        else p += pr;
-                        ++x;
-        else
-                var pr = dx<<1,
-                p = pr-dy;
-                        drw = !drw;
-                        y += yIncr;
-                        if (p > 0)
-                                ++x;
-                                p += pru;
-                        else p += pr;
-function mkOv(left, top, width, height)
-        var a = width>>1, b = height>>1,
-        wod = width&1, hod = (height&1)+1,
-        cx = left+a, cy = top+b,
-        x = 0, y = b,
-        ox = 0, oy = b,
-        aa = (a*a)<<1, bb = (b*b)<<1,
-        st = (aa>>1)*(1-(b<<1)) + bb,
-        tt = (bb>>1) - aa*((b<<1)-1),
-        w, h;
-        while (y > 0)
-                if (st < 0)
-                        st += bb*((x<<1)+3);
-                        tt += (bb<<1)*(++x);
-                else if (tt < 0)
-                        st += bb*((x<<1)+3) - (aa<<1)*(y-1);
-                        tt += (bb<<1)*(++x) - aa*(((y--)<<1)-3);
-                        w = x-ox;
-                        h = oy-y;
-                        if (w&2 && h&2)
-                                this.mkOvQds(cx, cy, -x+2, ox+wod, -oy, oy-1+hod, 1, 1);
-                                this.mkOvQds(cx, cy, -x+1, x-1+wod, -y-1, y+hod, 1, 1);
-                        else this.mkOvQds(cx, cy, -x+1, ox+wod, -oy, oy-h+hod, w, h);
-                        ox = x;
-                        oy = y;
-                else
-                        tt -= aa*((y<<1)-3);
-                        st -= (aa<<1)*(--y);
-        this.mkDiv(cx-a, cy-oy, a-ox+1, (oy<<1)+hod);
-        this.mkDiv(cx+ox+wod, cy-oy, a-ox+1, (oy<<1)+hod);
-function mkOv2D(left, top, width, height)
-        width += s-1;
-        height += s-1;
-        x = 0, y = b,
-        tt = (bb>>1) - aa*((b<<1)-1);
-        if (s-4 < 0 && (!(s-2) || width-51 > 0 && height-51 > 0))
-                var ox = 0, oy = b,
-                w, h,
-                pxl, pxr, pxt, pxb, pxw;
-                while (y > 0)
-                        if (st < 0)
-                        else if (tt < 0)
-                                w = x-ox;
-                                h = oy-y;
-                                if (w-1)
-                                        pxw = w+1+(s&1);
-                                        h = s;
-                                else if (h-1)
-                                        pxw = s;
-                                        h += 1+(s&1);
-                                else pxw = h = s;
-                                this.mkOvQds(cx, cy, -x+1, ox-pxw+w+wod, -oy, -h+oy+hod, pxw, h);
-                                ox = x;
-                                oy = y;
-                        else
-                this.mkDiv(cx-a, cy-oy, s, (oy<<1)+hod);
-                this.mkDiv(cx+a+wod-s+1, cy-oy, s, (oy<<1)+hod);
-        else
-                var _a = (width-((s-1)<<1))>>1,
-                _b = (height-((s-1)<<1))>>1,
-                _x = 0, _y = _b,
-                _aa = (_a*_a)<<1, _bb = (_b*_b)<<1,
-                _st = (_aa>>1)*(1-(_b<<1)) + _bb,
-                _tt = (_bb>>1) - _aa*((_b<<1)-1),
-                pxl = new Array(),
-                pxt = new Array(),
-                _pxb = new Array();
-                pxl[0] = 0;
-                pxt[0] = b;
-                _pxb[0] = _b-1;
-                while (y > 0)
-                        if (st < 0)
-                                pxl[pxl.length] = x;
-                                pxt[pxt.length] = y;
-                        else if (tt < 0)
-                        else
-                        if (_y > 0)
-                                if (_st < 0)
-                                        _st += _bb*((_x<<1)+3);
-                                        _tt += (_bb<<1)*(++_x);
-                                        _pxb[_pxb.length] = _y-1;
-                                else if (_tt < 0)
-                                        _st += _bb*((_x<<1)+3) - (_aa<<1)*(_y-1);
-                                        _tt += (_bb<<1)*(++_x) - _aa*(((_y--)<<1)-3);
-                                else
-                                        _tt -= _aa*((_y<<1)-3);
-                                        _st -= (_aa<<1)*(--_y);
-                                        _pxb[_pxb.length-1]--;
-                _oy = _pxb[0],
-                l = pxl.length,
-                w, h;
-                for (var i = 0; i < l; i++)
-                        if (typeof _pxb[i] != "undefined")
-                                if (_pxb[i] < _oy || pxt[i] < oy)
-                                        x = pxl[i];
-                                        this.mkOvQds(cx, cy, -x+1, ox+wod, -oy, _oy+hod, x-ox, oy-_oy);
-                                        ox = x;
-                                        oy = pxt[i];
-                                        _oy = _pxb[i];
-                        else
-                                x = pxl[i];
-                                this.mkDiv(cx-x+1, cy-oy, 1, (oy<<1)+hod);
-                                this.mkDiv(cx+ox+wod, cy-oy, 1, (oy<<1)+hod);
-                                ox = x;
-                                oy = pxt[i];
-                this.mkDiv(cx-a, cy-oy, 1, (oy<<1)+hod);
-function mkOvDott(left, top, width, height)
-        wod = width&1, hod = height&1,
-        x = 0, y = b,
-        aa2 = (a*a)<<1, aa4 = aa2<<1, bb = (b*b)<<1,
-        st = (aa2>>1)*(1-(b<<1)) + bb,
-        tt = (bb>>1) - aa2*((b<<1)-1),
-        drw = true;
-        while (y > 0)
-                if (st < 0)
-                else if (tt < 0)
-                        st += bb*((x<<1)+3) - aa4*(y-1);
-                        tt += (bb<<1)*(++x) - aa2*(((y--)<<1)-3);
-                else
-                        tt -= aa2*((y<<1)-3);
-                        st -= aa4*(--y);
-                if (drw) this.mkOvQds(cx, cy, -x, x+wod, -y, y+hod, 1, 1);
-                drw = !drw;
-function mkRect(x, y, w, h)
-        this.mkDiv(x, y, w, s);
-        this.mkDiv(x+w, y, s, h);
-        this.mkDiv(x, y+h, w+s, s);
-        this.mkDiv(x, y+s, s, h-s);
-function mkRectDott(x, y, w, h)
-        this.drawLine(x, y, x+w, y);
-        this.drawLine(x+w, y, x+w, y+h);
-        this.drawLine(x, y+h, x+w, y+h);
-        this.drawLine(x, y, x, y+h);
+{return this.htm.replace(regex,'<div style="overflow:hidden;position:absolute;background-color:'+'$1;left:$2;top:$3;width:$4;height:$5;border-left:$4px solid $1"></div>\n');}
+function mkLin(x1,y1,x2,y2)
+{if(x1>x2)
+{var _x2=x2;var _y2=y2;x2=x1;y2=y1;x1=_x2;y1=_y2;}
+var dx=x2-x1,dy=Math.abs(y2-y1),x=x1,y=y1,yIncr=(y1>y2)?-1:1;if(dx>=dy)
+{var pr=dy<<1,pru=pr-(dx<<1),p=pr-dx,ox=x;while((dx--)>0)
+{++x;if(p>0)
+{this.mkDiv(ox,y,x-ox,1);y+=yIncr;p+=pru;ox=x;}
+else p+=pr;}
+this.mkDiv(ox,y,x2-ox+1,1);}
+else
+{var pr=dx<<1,pru=pr-(dy<<1),p=pr-dy,oy=y;if(y2<=y1)
+{while((dy--)>0)
+{if(p>0)
+{this.mkDiv(x++,y,1,oy-y+1);y+=yIncr;p+=pru;oy=y;}
+else
+{y+=yIncr;p+=pr;}}
+this.mkDiv(x2,y2,1,oy-y2+1);}
+else
+{while((dy--)>0)
+{y+=yIncr;if(p>0)
+{this.mkDiv(x++,oy,1,y-oy);p+=pru;oy=y;}
+else p+=pr;}
+this.mkDiv(x2,oy,1,y2-oy+1);}}}
+function mkLin2D(x1,y1,x2,y2)
+{if(x1>x2)
+var dx=x2-x1,dy=Math.abs(y2-y1),x=x1,y=y1,yIncr=(y1>y2)?-1:1;var s=this.stroke;if(dx>=dy)
+{if(s-3>0)
+{var _s=(s*dx*Math.sqrt(1+dy*dy/(dx*dx))-dx-(s>>1)*dy)/dx;_s=(!(s-4)?Math.ceil(_s):Math.round(_s))+1;}
+else var _s=s;var ad=Math.ceil(s/2);var pr=dy<<1,pru=pr-(dx<<1),p=pr-dx,ox=x;while((dx--)>0)
+{++x;if(p>0)
+{this.mkDiv(ox,y,x-ox+ad,_s);y+=yIncr;p+=pru;ox=x;}
+else p+=pr;}
+this.mkDiv(ox,y,x2-ox+ad+1,_s);}
+else
+{if(s-3>0)
+{var _s=(s*dy*Math.sqrt(1+dx*dx/(dy*dy))-(s>>1)*dx-dy)/dy;_s=(!(s-4)?Math.ceil(_s):Math.round(_s))+1;}
+else var _s=s;var ad=Math.round(s/2);var pr=dx<<1,pru=pr-(dy<<1),p=pr-dy,oy=y;if(y2<=y1)
+{++ad;while((dy--)>0)
+{if(p>0)
+{this.mkDiv(x++,y,_s,oy-y+ad);y+=yIncr;p+=pru;oy=y;}
+else
+{y+=yIncr;p+=pr;}}
+this.mkDiv(x2,y2,_s,oy-y2+ad);}
+else
+{while((dy--)>0)
+{y+=yIncr;if(p>0)
+{this.mkDiv(x++,oy,_s,y-oy+ad);p+=pru;oy=y;}
+else p+=pr;}
+this.mkDiv(x2,oy,_s,y2-oy+ad+1);}}}
+function mkLinDott(x1,y1,x2,y2)
+{if(x1>x2)
+var dx=x2-x1,dy=Math.abs(y2-y1),x=x1,y=y1,yIncr=(y1>y2)?-1:1,drw=true;if(dx>=dy)
+{var pr=dy<<1,pru=pr-(dx<<1),p=pr-dx;while((dx--)>0)
+{if(drw)this.mkDiv(x,y,1,1);drw=!drw;if(p>0)
+{y+=yIncr;p+=pru;}
+else p+=pr;++x;}
+if(drw)this.mkDiv(x,y,1,1);}
+else
+{var pr=dx<<1,pru=pr-(dy<<1),p=pr-dy;while((dy--)>0)
+{if(drw)this.mkDiv(x,y,1,1);drw=!drw;y+=yIncr;if(p>0)
+{++x;p+=pru;}
+else p+=pr;}
+if(drw)this.mkDiv(x,y,1,1);}}
+function mkOv(left,top,width,height)
+{var a=width>>1,b=height>>1,wod=width&1,hod=(height&1)+1,cx=left+a,cy=top+b,x=0,y=b,ox=0,oy=b,aa=(a*a)<<1,bb=(b*b)<<1,st=(aa>>1)*(1-(b<<1))+bb,tt=(bb>>1)-aa*((b<<1)-1),w,h;while(y>0)
+{if(st<0)
+{st+=bb*((x<<1)+3);tt+=(bb<<1)*(++x);}
+else if(tt<0)
+{st+=bb*((x<<1)+3)-(aa<<1)*(y-1);tt+=(bb<<1)*(++x)-aa*(((y--)<<1)-3);w=x-ox;h=oy-y;if(w&2&&h&2)
+{this.mkOvQds(cx,cy,-x+2,ox+wod,-oy,oy-1+hod,1,1);this.mkOvQds(cx,cy,-x+1,x-1+wod,-y-1,y+hod,1,1);}
+else this.mkOvQds(cx,cy,-x+1,ox+wod,-oy,oy-h+hod,w,h);ox=x;oy=y;}
+else
+{tt-=aa*((y<<1)-3);st-=(aa<<1)*(--y);}}
+this.mkDiv(cx-a,cy-oy,a-ox+1,(oy<<1)+hod);this.mkDiv(cx+ox+wod,cy-oy,a-ox+1,(oy<<1)+hod);}
+function mkOv2D(left,top,width,height)
+{var s=this.stroke;width+=s-1;height+=s-1;var a=width>>1,b=height>>1,wod=width&1,hod=(height&1)+1,cx=left+a,cy=top+b,x=0,y=b,aa=(a*a)<<1,bb=(b*b)<<1,st=(aa>>1)*(1-(b<<1))+bb,tt=(bb>>1)-aa*((b<<1)-1);if(s-4<0&&(!(s-2)||width-51>0&&height-51>0))
+{var ox=0,oy=b,w,h,pxl,pxr,pxt,pxb,pxw;while(y>0)
+{if(st<0)
+else if(tt<0)
+{st+=bb*((x<<1)+3)-(aa<<1)*(y-1);tt+=(bb<<1)*(++x)-aa*(((y--)<<1)-3);w=x-ox;h=oy-y;if(w-1)
+{pxw=w+1+(s&1);h=s;}
+else if(h-1)
+{pxw=s;h+=1+(s&1);}
+else pxw=h=s;this.mkOvQds(cx,cy,-x+1,ox-pxw+w+wod,-oy,-h+oy+hod,pxw,h);ox=x;oy=y;}
+else
+this.mkDiv(cx-a,cy-oy,s,(oy<<1)+hod);this.mkDiv(cx+a+wod-s+1,cy-oy,s,(oy<<1)+hod);}
+else
+{var _a=(width-((s-1)<<1))>>1,_b=(height-((s-1)<<1))>>1,_x=0,_y=_b,_aa=(_a*_a)<<1,_bb=(_b*_b)<<1,_st=(_aa>>1)*(1-(_b<<1))+_bb,_tt=(_bb>>1)-_aa*((_b<<1)-1),pxl=new Array(),pxt=new Array(),_pxb=new Array();pxl[0]=0;pxt[0]=b;_pxb[0]=_b-1;while(y>0)
+{if(st<0)
+{st+=bb*((x<<1)+3);tt+=(bb<<1)*(++x);pxl[pxl.length]=x;pxt[pxt.length]=y;}
+else if(tt<0)
+{st+=bb*((x<<1)+3)-(aa<<1)*(y-1);tt+=(bb<<1)*(++x)-aa*(((y--)<<1)-3);pxl[pxl.length]=x;pxt[pxt.length]=y;}
+else
+if(_y>0)
+{if(_st<0)
+{_st+=_bb*((_x<<1)+3);_tt+=(_bb<<1)*(++_x);_pxb[_pxb.length]=_y-1;}
+else if(_tt<0)
+{_st+=_bb*((_x<<1)+3)-(_aa<<1)*(_y-1);_tt+=(_bb<<1)*(++_x)-_aa*(((_y--)<<1)-3);_pxb[_pxb.length]=_y-1;}
+else
+{_tt-=_aa*((_y<<1)-3);_st-=(_aa<<1)*(--_y);_pxb[_pxb.length-1]--;}}}
+var ox=0,oy=b,_oy=_pxb[0],l=pxl.length,w,h;for(var i=0;i<l;i++)
+{if(typeof _pxb[i]!="undefined")
+{if(_pxb[i]<_oy||pxt[i]<oy)
+{x=pxl[i];this.mkOvQds(cx,cy,-x+1,ox+wod,-oy,_oy+hod,x-ox,oy-_oy);ox=x;oy=pxt[i];_oy=_pxb[i];}}
+else
+{x=pxl[i];this.mkDiv(cx-x+1,cy-oy,1,(oy<<1)+hod);this.mkDiv(cx+ox+wod,cy-oy,1,(oy<<1)+hod);ox=x;oy=pxt[i];}}
+this.mkDiv(cx-a,cy-oy,1,(oy<<1)+hod);this.mkDiv(cx+ox+wod,cy-oy,1,(oy<<1)+hod);}}
+function mkOvDott(left,top,width,height)
+{var a=width>>1,b=height>>1,wod=width&1,hod=height&1,cx=left+a,cy=top+b,x=0,y=b,aa2=(a*a)<<1,aa4=aa2<<1,bb=(b*b)<<1,st=(aa2>>1)*(1-(b<<1))+bb,tt=(bb>>1)-aa2*((b<<1)-1),drw=true;while(y>0)
+{if(st<0)
+else if(tt<0)
+{st+=bb*((x<<1)+3)-aa4*(y-1);tt+=(bb<<1)*(++x)-aa2*(((y--)<<1)-3);}
+else
+{tt-=aa2*((y<<1)-3);st-=aa4*(--y);}
+if(drw)this.mkOvQds(cx,cy,-x,x+wod,-y,y+hod,1,1);drw=!drw;}}
+function mkRect(x,y,w,h)
+{var s=this.stroke;this.mkDiv(x,y,w,s);this.mkDiv(x+w,y,s,h);this.mkDiv(x,y+h,w+s,s);this.mkDiv(x,y+s,s,h-s);}
+function mkRectDott(x,y,w,h)
+{this.drawLine(x,y,x+w,y);this.drawLine(x+w,y,x+w,y+h);this.drawLine(x,y+h,x+w,y+h);this.drawLine(x,y,x,y+h);}
 function jsgFont()
-        this.PLAIN = 'font-weight:normal;';
-        this.BOLD = 'font-weight:bold;';
-        this.ITALIC = 'font-style:italic;';
-        this.ITALIC_BOLD = this.ITALIC + this.BOLD;
-        this.BOLD_ITALIC = this.ITALIC_BOLD;
-var Font = new jsgFont();
-function jsgStroke()
-        this.DOTTED = -1;
-var Stroke = new jsgStroke();
-function jsGraphics(id, wnd)
-        this.setColor = new Function('arg', 'this.color = arg.toLowerCase();');
-        this.setStroke = function(x)
-                this.stroke = x;
-                if (!(x+1))
-                        this.drawLine = mkLinDott;
-                        this.mkOv = mkOvDott;
-                        this.drawRect = mkRectDott;
-                else if (x-1 > 0)
-                        this.drawLine = mkLin2D;
-                        this.mkOv = mkOv2D;
-                        this.drawRect = mkRect;
-                else
-                        this.drawLine = mkLin;
-                        this.mkOv = mkOv;
-        this.setPrintable = function(arg)
-                this.printable = arg;
-                if (jg_fast)
-                        this.mkDiv = mkDivIe;
-                        this.htmRpc = arg? htmPrtRpc : htmRpc;
-                else this.mkDiv = jg_n4? mkLyr : arg? mkDivPrt : mkDiv;
-        this.setFont = function(fam, sz, sty)
-                this.ftFam = fam;
-                this.ftSz = sz;
-                this.ftSty = sty || Font.PLAIN;
-        this.drawPolyline = this.drawPolyLine = function(x, y, s)
-                for (var i=0 ; i<x.length-1 ; i++ )
-                        this.drawLine(x[i], y[i], x[i+1], y[i+1]);
-        this.fillRect = function(x, y, w, h)
-                this.mkDiv(x, y, w, h);
-        this.drawPolygon = function(x, y)
-                this.drawPolyline(x, y);
-                this.drawLine(x[x.length-1], y[x.length-1], x[0], y[0]);
-        this.drawEllipse = this.drawOval = function(x, y, w, h)
-                this.mkOv(x, y, w, h);
-        this.fillEllipse = this.fillOval = function(left, top, w, h)
-                var a = (w -= 1)>>1, b = (h -= 1)>>1,
-                wod = (w&1)+1, hod = (h&1)+1,
-                x = 0, y = b,
-                ox = 0, oy = b,
-                pxl, dw, dh;
-                if (w+1) while (y > 0)
-                        if (st < 0)
-                        else if (tt < 0)
-                                pxl = cx-x;
-                                dw = (x<<1)+wod;
-                                dh = oy-y;
-                                this.mkDiv(pxl, cy-oy, dw, dh);
-                                this.mkDiv(pxl, cy+oy-dh+hod, dw, dh);
-                                ox = x;
-                                oy = y;
-                        else
-                                st -= aa4*(--y);
-                this.mkDiv(cx-a, cy-oy, w+1, (oy<<1)+hod);
-/* fillPolygon method, implemented by Matthieu Haller.
-This javascript function is an adaptation of the gdImageFilledPolygon for Walter Zorn lib.
-C source of GD 1.8.4 found at http://www.boutell.com/gd/
-THANKS to Kirsten Schulz for the polygon fixes!
-The intersection finding technique of this code could be improved
-by remembering the previous intertersection, and by using the slope.
-That could help to adjust intersections to produce a nice
-interior_extrema. */
-        this.fillPolygon = function(array_x, array_y)
-                var i;
-                var y;
-                var miny, maxy;
-                var x1, y1;
-                var x2, y2;
-                var ind1, ind2;
-                var ints;
-                var n = array_x.length;
-                if (!n) return;
-                miny = array_y[0];
-                maxy = array_y[0];
-                for (i = 1; i < n; i++)
-                        if (array_y[i] < miny)
-                                miny = array_y[i];
-                        if (array_y[i] > maxy)
-                                maxy = array_y[i];
-                for (y = miny; y <= maxy; y++)
-                        var polyInts = new Array();
-                        ints = 0;
-                        for (i = 0; i < n; i++)
-                                if (!i)
-                                        ind1 = n-1;
-                                        ind2 = 0;
-                                else
-                                        ind1 = i-1;
-                                        ind2 = i;
-                                y1 = array_y[ind1];
-                                y2 = array_y[ind2];
-                                if (y1 < y2)
-                                        x1 = array_x[ind1];
-                                        x2 = array_x[ind2];
-                                else if (y1 > y2)
-                                        y2 = array_y[ind1];
-                                        y1 = array_y[ind2];
-                                        x2 = array_x[ind1];
-                                        x1 = array_x[ind2];
-                                else continue;
-                                 // modified 11. 2. 2004 Walter Zorn
-                                if ((y >= y1) && (y < y2))
-                                        polyInts[ints++] = Math.round((y-y1) * (x2-x1) / (y2-y1) + x1);
-                                else if ((y == maxy) && (y > y1) && (y <= y2))
-                        polyInts.sort(integer_compare);
-                        for (i = 0; i < ints; i+=2)
-                                this.mkDiv(polyInts[i], y, polyInts[i+1]-polyInts[i]+1, 1);
-        this.drawString = function(txt, x, y)
-                this.htm += '<div style="position:absolute;white-space:nowrap;'+
-                        'font-family:' +  this.ftFam + ';'+
-                        'font-size:' + this.ftSz + ';'+
-                        'color:' + this.color + ';' + this.ftSty + '">'+
-                        txt +
-                        '<\/div>';
-        this.drawImage = function(imgSrc, x, y, w, h)
-                        'width:' +  w + ';'+
-                        'height:' + h + ';">'+
-                        '<img src="' + imgSrc + '" width="' + w + '" height="' + h + '">'+
-                        '<\/div>';
-        this.clear = function()
-                this.htm = "";
-                if (this.cnv) this.cnv.innerHTML = this.defhtm;
-        this.mkOvQds = function(cx, cy, xl, xr, yt, yb, w, h)
-                this.mkDiv(xr+cx, yt+cy, w, h);
-                this.mkDiv(xr+cx, yb+cy, w, h);
-                this.mkDiv(xl+cx, yb+cy, w, h);
-                this.mkDiv(xl+cx, yt+cy, w, h);
-        this.setStroke(1);
-        this.setFont('verdana,geneva,helvetica,sans-serif', String.fromCharCode(0x31, 0x32, 0x70, 0x78), Font.PLAIN);
-        this.color = '#000000';
-        this.htm = '';
-        this.wnd = wnd || window;
-        if (!(jg_ie || jg_dom || jg_ihtm)) chkDHTM();
-        if (typeof id != 'string' || !id) this.paint = pntDoc;
-        else
-                this.cnv = document.all? (this.wnd.document.all[id] || null)
-                        : document.getElementById? (this.wnd.document.getElementById(id) || null)
-                        : null;
-                this.defhtm = (this.cnv && this.cnv.innerHTML)? this.cnv.innerHTML : '';
-                this.paint = jg_dom? pntCnvDom : jg_ie? pntCnvIe : jg_ihtm? pntCnvIhtm : pntCnv;
-        this.setPrintable(false);
+{this.PLAIN='font-weight:normal;';this.BOLD='font-weight:bold;';this.ITALIC='font-style:italic;';this.ITALIC_BOLD=this.ITALIC+this.BOLD;this.BOLD_ITALIC=this.ITALIC_BOLD;}
+var Font=new jsgFont();function jsgStroke()
+{this.DOTTED=-1;}
+var Stroke=new jsgStroke();function jsGraphics(id,wnd)
+{this.setColor=new Function('arg','this.color = arg.toLowerCase();');this.setStroke=function(x)
+{this.stroke=x;if(!(x+1))
+{this.drawLine=mkLinDott;this.mkOv=mkOvDott;this.drawRect=mkRectDott;}
+else if(x-1>0)
+{this.drawLine=mkLin2D;this.mkOv=mkOv2D;this.drawRect=mkRect;}
+else
+{this.drawLine=mkLin;this.mkOv=mkOv;this.drawRect=mkRect;}};this.setPrintable=function(arg)
+{this.printable=arg;if(jg_fast)
+{this.mkDiv=mkDivIe;this.htmRpc=arg?htmPrtRpc:htmRpc;}
+else this.mkDiv=jg_n4?mkLyr:arg?mkDivPrt:mkDiv;};this.setFont=function(fam,sz,sty)
+{this.ftFam=fam;this.ftSz=sz;this.ftSty=sty||Font.PLAIN;};this.drawPolyline=this.drawPolyLine=function(x,y,s)
+{for(var i=0;i<x.length-1;i++)
+this.drawLine(x[i],y[i],x[i+1],y[i+1]);};this.fillRect=function(x,y,w,h)
+{this.mkDiv(x,y,w,h);};this.drawPolygon=function(x,y)
+{this.drawPolyline(x,y);this.drawLine(x[x.length-1],y[x.length-1],x[0],y[0]);};this.drawEllipse=this.drawOval=function(x,y,w,h)
+{this.mkOv(x,y,w,h);};this.fillEllipse=this.fillOval=function(left,top,w,h)
+{var a=(w-=1)>>1,b=(h-=1)>>1,wod=(w&1)+1,hod=(h&1)+1,cx=left+a,cy=top+b,x=0,y=b,ox=0,oy=b,aa2=(a*a)<<1,aa4=aa2<<1,bb=(b*b)<<1,st=(aa2>>1)*(1-(b<<1))+bb,tt=(bb>>1)-aa2*((b<<1)-1),pxl,dw,dh;if(w+1)while(y>0)
+{if(st<0)
+else if(tt<0)
+{st+=bb*((x<<1)+3)-aa4*(y-1);pxl=cx-x;dw=(x<<1)+wod;tt+=(bb<<1)*(++x)-aa2*(((y--)<<1)-3);dh=oy-y;this.mkDiv(pxl,cy-oy,dw,dh);this.mkDiv(pxl,cy+oy-dh+hod,dw,dh);ox=x;oy=y;}
+else
+{tt-=aa2*((y<<1)-3);st-=aa4*(--y);}}
+this.mkDiv(cx-a,cy-oy,w+1,(oy<<1)+hod);};this.fillPolygon=function(array_x,array_y)
+{var i;var y;var miny,maxy;var x1,y1;var x2,y2;var ind1,ind2;var ints;var n=array_x.length;if(!n)return;miny=array_y[0];maxy=array_y[0];for(i=1;i<n;i++)
+{if(array_y[i]<miny)
+miny=array_y[i];if(array_y[i]>maxy)
+maxy=array_y[i];}
+for(y=miny;y<=maxy;y++)
+{var polyInts=new Array();ints=0;for(i=0;i<n;i++)
+{if(!i)
+{ind1=n-1;ind2=0;}
+else
+{ind1=i-1;ind2=i;}
+y1=array_y[ind1];y2=array_y[ind2];if(y1<y2)
+{x1=array_x[ind1];x2=array_x[ind2];}
+else if(y1>y2)
+{y2=array_y[ind1];y1=array_y[ind2];x2=array_x[ind1];x1=array_x[ind2];}
+else continue;if((y>=y1)&&(y<y2))
+polyInts[ints++]=Math.round((y-y1)*(x2-x1)/(y2-y1)+x1);else if((y==maxy)&&(y>y1)&&(y<=y2))
+polyInts[ints++]=Math.round((y-y1)*(x2-x1)/(y2-y1)+x1);}
+polyInts.sort(integer_compare);for(i=0;i<ints;i+=2)
+this.mkDiv(polyInts[i],y,polyInts[i+1]-polyInts[i]+1,1);}};this.drawString=function(txt,x,y)
+{this.htm+='<div style="position:absolute;white-space:nowrap;'+'left:'+x+'px;'+'top:'+y+'px;'+'font-family:'+this.ftFam+';'+'font-size:'+this.ftSz+';'+'color:'+this.color+';'+this.ftSty+'">'+
+txt+'<\/div>';}
+this.drawImage=function(imgSrc,x,y,w,h)
+{this.htm+='<div style="position:absolute;'+'left:'+x+'px;'+'top:'+y+'px;'+'width:'+w+';'+'height:'+h+';">'+'<img src="'+imgSrc+'" width="'+w+'" height="'+h+'">'+'<\/div>';}
+this.clear=function()
+{this.htm="";if(this.cnv)this.cnv.innerHTML=this.defhtm;};this.mkOvQds=function(cx,cy,xl,xr,yt,yb,w,h)
+{this.mkDiv(xr+cx,yt+cy,w,h);this.mkDiv(xr+cx,yb+cy,w,h);this.mkDiv(xl+cx,yb+cy,w,h);this.mkDiv(xl+cx,yt+cy,w,h);};this.setStroke(1);this.setFont('verdana,geneva,helvetica,sans-serif',String.fromCharCode(0x31,0x32,0x70,0x78),Font.PLAIN);this.color='#000000';this.htm='';this.wnd=wnd||window;if(!(jg_ie||jg_dom||jg_ihtm))chkDHTM();if(typeof id!='string'||!id)this.paint=pntDoc;else
+{this.cnv=document.all?(this.wnd.document.all[id]||null):document.getElementById?(this.wnd.document.getElementById(id)||null):null;this.defhtm=(this.cnv&&this.cnv.innerHTML)?this.cnv.innerHTML:'';this.paint=jg_dom?pntCnvDom:jg_ie?pntCnvIe:jg_ihtm?pntCnvIhtm:pntCnv;}
+this.setPrintable(false);}
 function integer_compare(x,y)
-        return (x < y) ? -1 : ((x > y)*1);
+{return(x<y)?-1:((x>y)*1);}
Modified: tags/2.5_min/http/javascripts/core.js
--- branches/2.5/http/javascripts/core.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/core.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,175 +1,15 @@
-var currentWmcExtensionData = {};
-var restoredWmcExtensionData = {};
-//var mb_MapRequestSubFunctions = [];
-//var mb_MapRequestPreFunctions = [];
-//var mb_MapObjectSubFunctions = [];
-//var mb_GetScalePreFunctions = [];
-//var mb_FeatureInfoPreFunctions = [];
-//var mb_loadWmsSubFunctions = [];
-//var mb_InitFunctions = [];
-var mb_WfsReadSubFunctions = [];
-var mb_WfsWriteSubFunctions = [];
-var mb_l10nFunctions = [];
- * Triggered after a map is requested.
-var eventAfterMapRequest = new MapbenderEvent();
- * Triggered before a map is requested.
-var eventBeforeMapRequest = new MapbenderEvent();
- * Triggered before the scale is calculated.
-var eventBeforeGetScale = new MapbenderEvent();
- * Triggered before a feature info is requested.
-var eventBeforeFeatureInfo = new MapbenderEvent();
- * Triggered after a WMS has been loaded.
-var eventAfterLoadWMS = new MapbenderEvent();
- * Triggered when Mapbender is loaded and after the map object has been initialised.
-var eventInit = new MapbenderEvent();
- * Initializes the map object. Triggered when Mapbender is loaded.
-var eventInitMap = new MapbenderEvent();
- * Switches the locale. Triggered by module switch_locale or onload(?)
-var eventLocalize = new MapbenderEvent();
- * Triggered after the map object has been created.
-var eventAfterMapObjectConstruction = new MapbenderEvent(); // possibly obsolete!
- * Triggered after the map has been resized
-var eventResizeMap = new MapbenderEvent();
- * deprecated wrapped function
- * @deprecated
-function mb_registerInitFunctions(stringFunction){
-//	mb_InitFunctions[mb_InitFunctions.length] = stringFunction;
-	eventInit.register(stringFunction);
- * @deprecated
-function mb_registerPreFunctions(stringFunction){
-//	mb_MapRequestPreFunctions[mb_MapRequestPreFunctions.length] = stringFunction;
-	eventBeforeMapRequest.register(stringFunction);
- * @deprecated
-function mb_registerFeatureInfoPreFunctions(stringFunction){
-//	mb_FeatureInfoPreFunctions[mb_FeatureInfoPreFunctions.length] = stringFunction;
-	eventBeforeFeatureInfo.register(stringFunction);
- * @deprecated
-function mb_registerSubFunctions(stringFunction){
-//	mb_MapRequestSubFunctions[mb_MapRequestSubFunctions.length] = stringFunction;
-	eventAfterMapRequest.register(stringFunction);
- * @deprecated
-function mb_registerMapObjectSubFunctions(stringFunction){
-//	mb_MapObjectSubFunctions[mb_MapObjectSubFunctions.length] = stringFunction;
-	eventAfterMapObjectConstruction.register(stringFunction);
- * @deprecated
-function mb_registerGetScalePreFunctions(stringFunction){
-//	mb_GetScalePreFunctions[mb_GetScalePreFunctions.length] = stringFunction;
-	eventBeforeGetScale.register(stringFunction);
- * @deprecated
-function mb_registerloadWmsSubFunctions(stringFunction){
-//	mb_loadWmsSubFunctions[mb_loadWmsSubFunctions.length] = stringFunction;
-	eventAfterLoadWMS.register(stringFunction);
- * @deprecated
-function mb_registerWfsReadSubFunctions(stringFunction){
-	mb_WfsReadSubFunctions[mb_WfsReadSubFunctions.length] = stringFunction;
- * @deprecated
-function mb_registerWfsWriteSubFunctions(stringFunction){
-	mb_WfsWriteSubFunctions[mb_WfsWriteSubFunctions.length] = stringFunction;
- * @deprecated
-function mb_registerL10nFunctions(stringFunction) {
-	eventLocalize.register(stringFunction)
-//	mb_l10nFunctions[mb_l10nFunctions.length] = stringFunction;
-var mb_PanSubElements = [];
-function mb_registerPanSubElement(elName){
-	var ind = mb_PanSubElements.length;
-	mb_PanSubElements[ind] = elName;
-var mb_vendorSpecific = [];
-function mb_registerVendorSpecific(stringFunction){
-	mb_vendorSpecific[mb_vendorSpecific.length] = stringFunction;
- * deprecated function for writing content within a tag via innerHTML
- * @deprecated
-function writeTag(frameName, elName, tagSource) {
-  if(frameName && frameName !== ""){
-     window.frames[frameName].document.getElementById(elName).innerHTML = tagSource;
-  else if(!frameName || frameName === ""){
-       document.getElementById(elName).innerHTML = tagSource;
+var currentWmcExtensionData={};var restoredWmcExtensionData={};var mb_WfsReadSubFunctions=[];var mb_WfsWriteSubFunctions=[];var mb_l10nFunctions=[];var eventAfterMapRequest=new MapbenderEvent();var eventBeforeMapRequest=new MapbenderEvent();var eventBeforeGetScale=new MapbenderEvent();var eventBeforeFeatureInfo=new MapbenderEvent();var eventAfterLoadWMS=new MapbenderEvent();var eventInit=new MapbenderEvent();var eventInitMap=new MapbenderEvent();var eventLocalize=new MapbenderEvent();var eventAfterMapObjectConstruction=new MapbenderEvent();var eventResizeMap=new MapbenderEvent();function mb_registerInitFunctions(stringFunction){eventInit.register(stringFunction);}
+function mb_registerPreFunctions(stringFunction){eventBeforeMapRequest.register(stringFunction);}
+function mb_registerFeatureInfoPreFunctions(stringFunction){eventBeforeFeatureInfo.register(stringFunction);}
+function mb_registerSubFunctions(stringFunction){eventAfterMapRequest.register(stringFunction);}
+function mb_registerMapObjectSubFunctions(stringFunction){eventAfterMapObjectConstruction.register(stringFunction);}
+function mb_registerGetScalePreFunctions(stringFunction){eventBeforeGetScale.register(stringFunction);}
+function mb_registerloadWmsSubFunctions(stringFunction){eventAfterLoadWMS.register(stringFunction);}
+function mb_registerWfsReadSubFunctions(stringFunction){mb_WfsReadSubFunctions[mb_WfsReadSubFunctions.length]=stringFunction;}
+function mb_registerWfsWriteSubFunctions(stringFunction){mb_WfsWriteSubFunctions[mb_WfsWriteSubFunctions.length]=stringFunction;}
+function mb_registerL10nFunctions(stringFunction){eventLocalize.register(stringFunction)}
+var mb_PanSubElements=[];function mb_registerPanSubElement(elName){var ind=mb_PanSubElements.length;mb_PanSubElements[ind]=elName;}
+var mb_vendorSpecific=[];function mb_registerVendorSpecific(stringFunction){mb_vendorSpecific[mb_vendorSpecific.length]=stringFunction;}
+function writeTag(frameName,elName,tagSource){if(frameName&&frameName!==""){window.frames[frameName].document.getElementById(elName).innerHTML=tagSource;}
+else if(!frameName||frameName===""){document.getElementById(elName).innerHTML=tagSource;}}
Modified: tags/2.5_min/http/javascripts/event.js
--- branches/2.5/http/javascripts/event.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/event.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,193 +1,16 @@
- * An event. What happens, when the event occurs, depends on which functions have been
- * registered with the event.
- * usage:
- * // create a new Event
- * var eventAfterMapRequest = new MapbenderEvent();
- * // register a function with that event
- * eventAfterMapRequest.register(function () {
- * // trigger the event
- * eventAfterMapRequest.trigger();
-var MapbenderEvent = function () {
-	// public methods
-	 * A function that needs to be executed, when the event occurs, has to be
-	 * registered via this function.
-	this.register = function(aFunction) {
-		var mpbnFunction = new MapbenderFunction(aFunction);
-		functionArray.push(mpbnFunction);
-	 * Exclude a previously registered function from the event
-	this.unregister = function(aFunction) {
-		for (var i = 0, len = functionArray.length; i < len; i++) {
-			if (functionArray[i].getFunction() === aFunction) {
-				for (var j = i + 1; j < len; j++) {
-					functionArray[j-1] = functionArray[j];
-				delete functionArray[len - 1];
-				len = len - 1;
-		functionArray.length = len;
-	 * Checks if a function is already registered with this event
-	this.isRegistered = function (aFunction) {
-				return true;
-		return false;
-	 * This function triggers the event
-	this.trigger = function(properties, booleanOperator) {
-		if (!(functionArray.length > 0)) {
-			return true;
-		// check arguments
-		// properties
-		if (typeof(properties) != "object") {
-			// maybe properties is missing, and so
-			// properties represents booleanOperator
-			if (typeof(booleanOperator) == "undefined") {
-				booleanOperator = properties;
-				properties = undefined;
-			else {
-//				var e = new Mb_exception("MapbenderEvent.trigger: invalid properties: %s", properties);
-		// booleanOperator
-		if (typeof(booleanOperator) == "string") {
-			if (booleanOperator != "AND" && booleanOperator != "OR") {
-//				var e = new Mb_exception("MapbenderEvent.trigger: invalid booleanOperator: %s", booleanOperator);
-		else if (typeof(booleanOperator) != "undefined") {
-//			var e = new Mb_exception("MapbenderEvent.trigger: invalid booleanOperator, must be a string, but is %s", typeof(booleanOperator));
-		var result;
-		// the optional boolean operator allows to combine the return values of the functions
-		// into a single result value.
-		switch (booleanOperator) {
-			case "AND":
-				result = true;
-				break;
-			case "OR":
-				result = false;
-				break;
-			default:
-				result = true;
-				break;
-		if (log) {
-			var e = new Mb_notice("functions (after sort): " + functionArray.join(","));
-		for (var i = 0; i < functionArray.length; i++) {
-			// executes the function at position i
-			// and determines the return value based on the (optional) boolean operator
-				case "AND":
-					result = result && functionArray[i].execute(properties);
-					break;
-				case "OR":
-					result = result || functionArray[i].execute(properties);
-					break;
-				default:
-					result = functionArray[i].execute(properties);
-					break;
-		return result;
-	this.getProperties = function () {
-		return propertiesObj;
-	// private
-	 * these functions will be executed once the event is triggered
-	var functionArray = [];
-	var propertiesObj;
-	var log = false;
- * A MapbenderFunction is a function with a priority.
-var MapbenderFunction = function (aFunction) {
-	// public
-	 * Returns the function itself
-	this.getFunction = function () {
-		return func;
-	 * Executes the function
-	this.execute = function (argumentObj) {
-		if (typeof(aFunction) == "function") {
-			return func(argumentObj);
-		// this branch is for backwards compatibility with the
-		// pre-2.5 event system that is based on strings.
-		else {
-			var argumentNames = [];
-			var argumentValues = [];
-			for (var i in argumentObj) {
-				if (typeof(argumentObj[i]) == "number" || typeof(argumentObj[i]) == "boolean") {
-					argumentNames.push(i);
-					argumentValues.push(argumentObj[i]);
-				else if (typeof(argumentObj[i]) == "string") {
-					argumentValues.push("'" + argumentObj[i] + "'");
-			var str = "";
-			str += "(function (" + argumentNames.join(", ") + ") {";
-			str += "return " + aFunction;
-			str += "}";
-			str += "(" + argumentValues.join(", ") + "));";
-			var returnValue = eval(str);
-			return returnValue;
-	// private
-	var func = aFunction;
+var MapbenderEvent=function(){this.register=function(aFunction){var mpbnFunction=new MapbenderFunction(aFunction);functionArray.push(mpbnFunction);};this.unregister=function(aFunction){for(var i=0,len=functionArray.length;i<len;i++){if(functionArray[i].getFunction()===aFunction){for(var j=i+1;j<len;j++){functionArray[j-1]=functionArray[j];}
+delete functionArray[len-1];len=len-1;}}
+functionArray.length=len;};this.isRegistered=function(aFunction){for(var i=0,len=functionArray.length;i<len;i++){if(functionArray[i].getFunction()===aFunction){return true;}}
+return false;};this.trigger=function(properties,booleanOperator){if(!(functionArray.length>0)){return true;}
+if(typeof(properties)!="object"){if(typeof(booleanOperator)=="undefined"){booleanOperator=properties;properties=undefined;}
+else{}}
+if(typeof(booleanOperator)=="string"){if(booleanOperator!="AND"&&booleanOperator!="OR"){}}
+else if(typeof(booleanOperator)!="undefined"){}
+var result;switch(booleanOperator){case"AND":result=true;break;case"OR":result=false;break;default:result=true;break;}
+if(log){var e=new Mb_notice("functions (after sort): "+functionArray.join(","));}
+for(var i=0;i<functionArray.length;i++){switch(booleanOperator){case"AND":result=result&&functionArray[i].execute(properties);break;case"OR":result=result||functionArray[i].execute(properties);break;default:result=functionArray[i].execute(properties);break;}}
+return result;};this.getProperties=function(){return propertiesObj;};var functionArray=[];var propertiesObj;var log=false;};var MapbenderFunction=function(aFunction){this.getFunction=function(){return func;};this.execute=function(argumentObj){if(typeof(aFunction)=="function"){return func(argumentObj);}
+else{var argumentNames=[];var argumentValues=[];for(var i in argumentObj){if(typeof(argumentObj[i])=="number"||typeof(argumentObj[i])=="boolean"){argumentNames.push(i);argumentValues.push(argumentObj[i]);}
+else if(typeof(argumentObj[i])=="string"){argumentNames.push(i);argumentValues.push("'"+argumentObj[i]+"'");}}
+var str="";str+="(function ("+argumentNames.join(", ")+") {";str+="return "+aFunction;str+="}";str+="("+argumentValues.join(", ")+"));";var returnValue=eval(str);return returnValue;}};var func=aFunction;};
Modified: tags/2.5_min/http/javascripts/geometry.js
--- branches/2.5/http/javascripts/geometry.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/geometry.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,1771 +1,150 @@
-* $Id$
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-// http://www.mapbender.org/index.php/GeometryArray.js
-var nameGeometryArray = "GeometryArray";
-var nameMultiGeometry = "MultiGeometry";
-var nameGeometry = "Geometry";
- * @class A class representing geometry types "polygon", "line" and "point".
- * @constructor
-function GeomType(){
-	 * An identifier for polygons. If you want to check if a {@link MultiGeometry}
-	 * or {@link Geometry} is a polygon, write
-	 * if (someGeometry.geomType == geomType.polygon
-	 * @type String
-	this.polygon = "polygon";
-	 * or {@link Geometry} is a line, write
-	 * if (someGeometry.geomType == geomType.line
-	 * @type String
-	this.line = "line";
-	 * or {@link Geometry} is a point, write
-	 * if (someGeometry.geomType == geomType.point
-	 * @type String
-	this.point = "point";
-var geomType = new GeomType();
- * @class a {@link GeometryArray} is a {@link List} of {@link MultiGeometry} objects
- * @ extends List
- * @ requires MultiGeometry
- * @ requires Geometry
- * @ requires Point
- * @ constructor
-function GeometryArray(){
-	 * creates a new, empty Multigeometry and adds it to this GeometryArray
-	 * @param {String} geomType a {@link GeomType}
-	this.addMember = function(geomType){
-		this.add(new MultiGeometry(geomType));
-	 * @ignore
-	this.name = nameGeometryArray;
-	 * A {@link List} of {@link MultiGeometry} objects.
-	 * @type List
-	this.list = [];
-GeometryArray.prototype = new List();
- * gets the j-th {@link Geometry} object of the i-th {@link MultiGeometry} object
- * @param {Integer} i index of the MultiGeometry
- * @param {Integer} j index of the Geometry
- * @type Geometry
-GeometryArray.prototype.getGeometry = function(i,j){
-	var tmp = this.get(i);
-	return tmp.get(j);
- * gets the k-th Point of the j-th {@link Geometry} object of the i-th {@link MultiGeometry} object
- * @param {Integer} k index of the Point
- * @type Point
- * @returns the Point object at the given indices
-GeometryArray.prototype.getPoint = function(i,j,k){
-	return this.get(i).get(j).get(k);
- * gets an Array of indices; the {@link MultiGeometry} objects at these indices are equal to geom
- * @type Integer[]
- * @param {MultiGeometry} geom
- * @returns an Array of indices
-GeometryArray.prototype.findMultiGeometry = function(geom) {
-	var a = [];
-	for (var i=0; i < this.count(); i++) {
-		if (this.get(i).equals(geom)) {a.push(i);}
-	return a;
- * deletes the j-th {@link Geometry} object of the i-th {@link MultiGeometry} object
-GeometryArray.prototype.delGeometry = function(i,j){
-	if (this.get(i).del(j) === false) {this.del(i);}
- * deletes the k-th {@link Point} of the j-th {@link Geometry} object of the i-th {@link MultiGeometry} object
-GeometryArray.prototype.delPoint = function (i,j,k){
-	var res = this.get(i).delPoint(j,k);
-	if (res === false) {this.del(i);}
- * closes the current {@link MultiGeometry}. Calls method close of the {@link Geometry} class.
-GeometryArray.prototype.close = function(){
-	if (!this.get(-1).get(-1).close()) {
-		this.delGeometry(-1, -1);
-	else {
-		if (this.get(-1).get(-1).count() === 0) {this.get(-1).del(-1);}
-		if (this.get(-1).count() === 0) {this.del(-1);}
- * deletes all {@link Point} objects of this {@link GeometryArray} that equal point
- * @param {Point} point
-GeometryArray.prototype.delAllPointsLike = function(point){
-	var finished = false;
-	while (finished === false){
-		finished = true;
-		for (var i = 0 ; finished === true && i < this.count() ; i++){
-			for (var j = 0 ; finished === true && j < this.get(i).count() ; j++){
-				for (var k = 0 ; finished === true && k < this.get(i).get(j).count() ; k++){
-					if (this.getPoint(i,j,k).equals(point)){
-						this.delPoint(i,j,k);
-						finished = false;
- * updates all {@link Point} objects of this {@link GeometryArray} that equal oldP to newP
- * @param {Point} oldP
- * @param {Point} newP
-GeometryArray.prototype.updateAllPointsLike = function(oldP, newP){
-	for (var i = 0; i < this.count(); i++){
-		this.get(i).updateAllPointsLike(oldP, newP);
-GeometryArray.prototype.placemarkToString = function (placemarkId) {
-	var str = "{\"type\": \"Feature\", \"geometry\": ";
-	// get geometries with placemarkId
-	var geometriesFromPlacemark = [];
-	for (var i = 0, len = this.count(); i < len; i++) {
-		if (this.get(i).isFromKml() && this.get(i).e.getElementValueByName("Mapbender:placemarkId") == placemarkId) {
-			geometriesFromPlacemark.push(i);
-	if (geometriesFromPlacemark.length > 1) {
-		str += "{\"type\": \"GeometryCollection\", \"geometries\": [";
-		for (var i = 0; i < geometriesFromPlacemark.length; i++) {
-			if (i > 0) {
-				str += ",";
-			str += this.get(geometriesFromPlacemark[i]).placemarkToString();
-		str += "]}";
-		// metadata is the same for all indices...get from index 0
-		var propString = this.get(geometriesFromPlacemark[0]).e.toString();
-		if (propString) {
-			str += "," + propString;
-	else if (geometriesFromPlacemark.length === 1) {
-		str += this.get(geometriesFromPlacemark[0]).placemarkToString();
-	str += "}";
-	return str;
-GeometryArray.prototype.getBBox = function(){
-	var q = this.get(0).get(0).get(0);
-	var min = cloneObject(q);
-	var max = cloneObject(q);
-	for(var i=0; i < this.count();i++){
-		var pos = this.get(i).getBBox();
-		if (pos[0].x < min.x) {min.x = pos[0].x;}
-		if (pos[1].x > max.x) {max.x = pos[1].x;}
-		if (pos[1].y > max.y) {max.y = pos[1].y;}
-		if (pos[0].y < min.y) {min.y = pos[0].y;}
-	return [min, max];
-GeometryArray.prototype.importGeoJSON = function (geoJSON) {
-	var isFeatureCollection = false;
-	var featureCollectionEpsg = 4326;
-	var featureEpsg = 4326;
-	// FEATURE COLLECTION
-	for (var i in geoJSON) {
-		if (typeof(geoJSON[i]) != "function") {
-			switch (i) {
-				case "type":
-					isFeatureCollection = (geoJSON[i] == "FeatureCollection") ? true : false;
-					break;
-				case "crs":
-					if (geoJSON[i].type == "EPSG") {
-						featureCollectionEpsg = geoJSON[i].properties.code;
-						featureEpsg = geoJSON[i].properties.code;
-					break;
-				case "features":
-					if (isFeatureCollection) {
-						// FEATURE
-						var featureArray = geoJSON[i];
-						for (var j = 0; j < featureArray.length; j++) {
-							featureEpsg = featureCollectionEpsg;
-							var currentFeature = featureArray[j];
-							var isFeature = false;
-							for (var k in currentFeature) {
-								if (typeof(currentFeature[k]) != "function") {
-									var geometrytype;
-									switch(k) {
-										case "type":
-											isFeature = (currentFeature[k] == "Feature") ? true : false;
-											break;
-										case "properties":
-											var properties = currentFeature[k];
-											// GeometryCollections are NOT YET IMPLEMENTED
-											if (geometrytype != "GeometryCollection") {
-												for (var l in properties) {
-													if (typeof(properties[l]) != "function") {
-														this.get(-1).e.setElement(l, properties[l]);
-											break;
-										case "crs":
-											if (currentFeature[k].type == "EPSG") {
-												featureEpsg = currentFeature[k].properties.code;
-											break;
-										case "geometry":
-											if (isFeature) {
-												// GEOMETRY
-												var currentGeometry = currentFeature[k];
-												for (var l in currentGeometry) {
-													if (typeof(currentGeometry[l]) != "function") {
-														switch (l) {
-															case "type":
-																geometrytype = currentGeometry[l];
-																break;
-															case "coordinates":
-																var coordinates = currentGeometry[l];
-																switch (geometrytype) {
-																	case "Point":
-																		// POINT
-																		this.addMember(geomType.point);
-																		this.get(-1).addGeometry();
-																		this.getGeometry(-1,-1).addPointByCoordinates(coordinates[0], coordinates[1], coordinates[2]);
-																		this.getGeometry(-1,-1).setEpsg(featureEpsg);
-																		this.close();
-																		break;
-																	case "LineString":
-																		// LINESTRING
-																		this.addMember(geomType.line);
-																		for (var m = 0; m < coordinates.length; m++) {
-																			var currentPoint = coordinates[m];
-																			this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0], currentPoint[1], currentPoint[2]);
-																		this.close();
-																		break;
-																	case "MultiLineString":
-																		// MULTILINESTRING
-																			var currentLine = coordinates[m];
-																			for (var n = 0; n < currentLine.length; n++) {
-																				var currentPoint = currentLine[n];
-																		this.close();
-																		break;
-																	case "Polygon":
-																		// POLYGON
-																		this.addMember(geomType.polygon);
-																			var currentPolygon = coordinates[m];
-																			for (var n = 0; n < currentPolygon.length; n++) {
-																				var currentPoint = currentPolygon[n];
-																		this.close();
-																		break;
-																	case "MultiPolygon":
-																		// MULTIPOLYGON
-																		this.close();
-																		break;
-																	case "GeometryCollection":
-																		var exc = new Mb_exception("Geometry: GeometryCollections are not yet supported");
-																		break;
-GeometryArray.prototype.toString = function () {
-	var str = "{\"type\": \"FeatureCollection\", \"features\": [";
-	// separate: geometries that are from a KML and those which are not
-	var multiGeometriesFromKml = [];
-	var multiGeometriesNotFromKml = [];
-		if (this.get(i).isFromKml()) {
-			var placemarkId = this.get(i).e.getElementValueByName("Mapbender:placemarkId");
-			// only add placemark ids once!
-			var isFound = false;
-			for (var j = 0; j < multiGeometriesFromKml && isFound === false; j++) {
-				if (multiGeometriesFromKml == placemarkId) {
-					isFound = true;
-			if (!isFound) {
-				multiGeometriesFromKml.push(placemarkId);
-		else {
-			multiGeometriesNotFromKml.push(i);
-	// add geometries not from KML
-	for (var i = 0, len = multiGeometriesNotFromKml.length; i < len; i++) {
-		if (i > 0) {
-			str += ",";
-		str += this.get(multiGeometriesNotFromKml[i]).toString();
-	// add geometries from KML
-	if (multiGeometriesNotFromKml.length > 0 && multiGeometriesFromKml.length > 0) {
-		str += ",";
-	for (var i=0; i < multiGeometriesFromKml.length; i++) {
-		if (i > 0) {
-			str += ",";
-		str += this.placemarkToString();
-	str += "]}";
-	return str;
- * @class a MultiGeometry is a List of Geometry objects
- * @ extends List
- * @ constructor
- * @ param {String} geomType a geomType
-function MultiGeometry(geomType){
-	 * creates a new, empty {@link Geometry} object and adds it to this {@link MultiGeometry}
-	this.addGeometry = function(){
-		this.add(new Geometry(this.geomType));
-	 * deletes the {@link Geometry} object at index i; -1 refers to the last {@link Geometry object in the list
-	 * overwrites the del function of {@link List}.
-	this.del = function(i){
-		i = this.getIndex(i);
-		if (i !== false){
-			var tmpLength = this.count() - 1;
-			for (var z = i; z < tmpLength ; z ++){
-				this.list[z] = this.list[z+1];
-				e[z] = e[z+1];
-			this.list.length -= 1;
-			if (this.list.length === 0) {return false;}
-		return true;
-	this.list = [];
-	this.e = new Wfs_element();
-	this.geomType = geomType;
-	this.name = nameMultiGeometry;
-MultiGeometry.prototype = new List();
- * updates all {@link Point} objects of this {@link MultiGeometry} that equal oldP to newP
-MultiGeometry.prototype.updateAllPointsLike = function(oldP, newP){
-	for (var i = 0; i < this.count(); i++) {
- * gets the bounding box of this {@link MultiGeometry} as an Array of 2 points
- * @return the bounding box
- * @type Array of two Point objects
-MultiGeometry.prototype.getBBox = function(){
-	var q = this.get(0).get(0);
-	for(var i=0; i<this.count();i++){
- * gets the bounding box of this {@link MultiGeometry} as a polygon of four points
- * @type MultiGeometry
-MultiGeometry.prototype.getBBox4 = function() {
-	var bbox = this.getBBox();
-	var realBox = new MultiGeometry(geomType.polygon);
-	realBox.addGeometry(geomType.polygon);
-	realBox.get(-1).addPointByCoordinates(bbox[0].x, bbox[0].y);
-	realBox.get(-1).addPointByCoordinates(bbox[0].x, bbox[1].y);
-	realBox.get(-1).addPointByCoordinates(bbox[1].x, bbox[1].y);
-	realBox.get(-1).addPointByCoordinates(bbox[1].x, bbox[0].y);
-	realBox.get(-1).close();
-	return realBox;
- * gets the center of the bounding box of this {@link MultiGeometry}.
- * @return the center of the bounding box
- * @type Point
-MultiGeometry.prototype.getCenter = function(){
-	var tmp = this.getBBox();
-	var x = parseFloat(tmp[0].x) + parseFloat((tmp[1].x - tmp[0].x)/2);
-	var y = parseFloat(tmp[0].y) + parseFloat((tmp[1].y - tmp[0].y)/2);
-	return new Point(x,y);
- * gets the total number of {@link Point} objects of this {@link MultiGeometry}.
- * @return number of points
- * @type Integer
-MultiGeometry.prototype.getTotalPointCount = function(){
-	var c = 0;
-	for (var i = 0 ; i < this.count(); i++)	{
-		c += this.get(i).count();
-	return c;
- * @type Integer
-MultiGeometry.prototype.getPoint = function(j,k){
-	return this.get(j).get(k);
- * compares this {@link MultiGeometry} object with the {@link MultiGeometry} object multigeom.
- * @param {MultiGeometry} multigeom another multigeometry
- * @return true if he multigeometries match; else false
- * @type Boolean
-MultiGeometry.prototype.equals = function(multigeom) {
-	if (this.geomType != multigeom.geomType) {return false;}
-	if (this.count() != multigeom.count()) {return false;}
-	if (this.getTotalPointCount() != multigeom.getTotalPointCount()) {return false;}
-	for (var i=0; i<this.count(); i++) {
-		if (!this.get(i).equals(multigeom.get(i))) {return false;}
-	return true;
- * deletes the j-th {@link Point} object of the i-th {@link Geometry} object of this {@link MultiGeometry} object.
- * @param {Integer} i geometry index
- * @param {Integer} j point index
- * @return true if the deletion succeded; else false.
- * @type Boolean
-MultiGeometry.prototype.delPoint = function(i,j){
-	var res = this.get(i).del(j);
-	if (res === false) {return this.del(i);}
-	return true;
-MultiGeometry.prototype.isFromKml = function () {
-	if (this.e.getElementValueByName("Mapbender:kml")) {
-		return true;
-	return false;
-MultiGeometry.prototype.toString = function () {
-	var str = this.toStringWithoutProperties();
-	// properties
-	var propString = this.e.toString();
-	if (propString) {
-	str += "}";
-	return str;
-MultiGeometry.prototype.placemarkToString = function () {
-	var str = "";
-	// geometries
-		if (i > 0) {
-			str += ",";
-		str += this.get(i).toString();
-	return str;
-MultiGeometry.prototype.toStringWithoutProperties = function () {
-	var str = "{\"type\": \"Feature\", ";
-	var epsg = this.getEpsg();
-	if (epsg) {
-		str += "\"crs\": {\"type\": \"EPSG\", \"properties\": {\"code\": " + epsg + "}}, ";
-	str += "\"geometry\": ";
-	// geometries
-		if (i > 0) {
-			str += ",";
-// this closing curly bracket is added in toString()
-//	str += "}";
-	return str;
- * @return the EPSG code of this geometry.
- * @type integer
-MultiGeometry.prototype.getEpsg = function () {
-	if (this.count() > 0) {
-		return this.get(0).getEpsg();
-	return false;
- * @class a Geometry is a List of Point objects. If it is a polygon, the last point has
- * to equal the first point.
- * @extends List
- * @requires Point
- * @constructor
- * @param {String} a string representing a geometry type, see @see GeomType.
-function Geometry(aGeomtype){
-	 * deletes the {@link Point} object at index i; -1 refers to the last
-	 * {@link Point} object in the list. Overwrites the del function of
-	 * {@link List}.
-	 * @return false if deletion is not yet finished. It is cascaded to
-	 *         {@link MultiGeometry}. True if the deletion is finished.
-		if (i !== false) {
-			var tmpLength = this.count()-1;
-			if (this.geomType == geomType.polygon){
-				if (i == tmpLength) {this.list[0] = this.list[tmpLength-1];}
-				else if (i === 0) {this.list[tmpLength-1] = this.list[0];}
-				if (this.list.length == 1){return false;}
-			updateDist();
-			if(this.list.length === 0) {return false;}
-			return true;
-		return false;
-	 * adds a {@link Point} object to this {@link Geometry} object.
-	 * @param {Float} x x value of the point
-	 * @param {Float} y y value of the point
-	this.addPointByCoordinates = function(x,y,z){
-		var newPoint = new Point(x,y,z);
-		this.add(newPoint);
-//		updateDist();
-	 * @param {Point} aPoint another point
-	this.addPoint = function(aPoint){
-		this.add(new Point(aPoint.x, aPoint.y, aPoint.z));
-		updateDist();
-	 * inserts a {@link Point} object at index i of this {@link Geometry} object.
-	 * @param {Point} p another point
-	this.addPointAtIndex = function(p,i){
-		if (i !== false){
-			for(var z = this.count(); z > i; z--){
-				this.list[z] = this.list[z-1];
-			this.list[i] = new Point(p.x, p.y, p.z);
-			updateDist();
-	 * Overwrites the {@link Point) object at index i with the {@link Point} object p.
-	 * @private
-	this.updatePointAtIndex = function(p, i){
-		if ((i === 0 || i == this.count()-1) && this.geomType == geomType.polygon){
-			this.list[0] = p;
-			this.list[this.count()-1] = p;
-		else {this.list[i] = p;}
-		updateDist();
-	 * Updates the {@link Geometry#dist} and {@link Geometry#totaldist}
-	 * @private
-	var updateDist = function(){
- * DISABLED BECAUSE IT IS TOO SLOW
-		dist[0] = 0;
-		totaldist[0] = 0;
-		for (var i = 1 ; i < that.count(); i++){
-			dist[i] = that.get(i-1).dist(that.get(i));
-			totaldist[i] = totaldist[i-1] + dist[i];
-	 * gets the distance between the last and last but one point of this {@link Geometry}.
-	 * @param {Integer} numberOfDigitis round to numberOfDigits (optional)
-	 * @return the distance
-	 * @type Float
-	this.getCurrentDist = function(numberOfDigits) {
-		if (typeof(numberOfDigits) == "number") {
-			return roundToDigits(dist[this.count()-1], numberOfDigits);
-		return dist[this.count()-1];
-	 * gets the length of the outer rim of this {@link Geometry}.
-	 * @type Float
-	this.getTotalDist = function(numberOfDigits) {
-			return roundToDigits(totaldist[this.count()-1], numberOfDigits);
-		return totaldist[this.count()-1];
-	 * closes this {@link Geometry}.
-	 * @return true if the geometry could be closed; otherwise false
-	 * @type Boolean
-	this.close = function(){
-		complete = true;
-			if (this.count() > 2){
-				if (!this.get(0).equals(this.get(-1))) {
-					this.addPoint(this.get(0));
-			else {return false;}
-		if (this.geomType == geomType.line){
-			if (this.count() < 2){return false;}
-		return true;
-	 * checks if this {@link Geometry} has been closed.
-	 * @return true if the geometry is closed; otherwise false
-	 * @type Boolean
-	this.isComplete = function() {
-		return complete;
-	 * Sets the EPSG of this geometry.
-	 * @param {Integer} someEpsg the EPSG of this geometry.
-	 * @return true if the EPSG could be set; else false
-	 * @type boolean
-	this.setEpsg = function (someEpsg) {
-		// TODO: how to check if EPSG code is correct?
-		if (typeof(someEpsg) == "number") {
-			epsg = someEpsg;
-			return true;
-		var e = new Mb_exception("EPSG code not valid ("+someEpsg+")");
-		return false;
-	 * @type integer
-	this.getEpsg = function () {
-		return epsg;
-	this.list = [];
-	var dist = [];
-	var totaldist = [];
-	var complete = false;
-	var epsg;
-	var that = this;
-	this.geomType = aGeomtype;
-	this.name = nameGeometry;
-Geometry.prototype = new List();
- * gets the bounding box of this {@link Geometry}
- * @return the bounding box (array of two Point objects)
- * @type Point[]
-Geometry.prototype.getBBox = function(){
-	var q = this.get(0);
-	for (var j=0; j<this.count(); j++){
-		var pos = this.get(j);
-		if (pos.x < min.x) {min.x = pos.x;}
-		else if (pos.x > max.x) {max.x = pos.x;}
-		if (pos.y < min.y) {min.y = pos.y;}
-		else if (pos.y > max.y) {max.y = pos.y;}
- * updates all {@link Point} objects of this {@link Geometry} that equal oldP to newP
-Geometry.prototype.updateAllPointsLike = function(oldP, newP){
-	var len = this.count();
-	for (var i = 0; i < len ; i++){
-		if (oldP.equals(this.get(i))){
-			if (i>0 && newP.equals(this.get(i-1))){
-				this.del(i);
-				len--;
-				i--;
-			else {this.updatePointAtIndex(newP, i);}
- * compares this {@link Geometry} object with the {@link Geometry} object geom point by point.
- * @param {Geometry} geom another geometry
- * @return true if he geometries match; else false
- * @type Boolean
-Geometry.prototype.equals = function(geom) {
-	if (this.geomType != geom.geomType) {return false;}
-	if (this.count() != geom.count()) {return false;}
-		if (!this.get(i).equals(geom.get(i))) {return false;}
-	return true;
-Geometry.prototype.toString = function () {
-	var str = "";
-	var epsgStr = "";
-	if (epsg) {
-		epsgStr = "\"crs\": {\"type\": \"EPSG\", \"properties\": {\"code\": " + epsg + "}}, ";
-	if (this.geomType == geomType.polygon) {
-		str += "{\"type\": \"Polygon\", " + epsgStr + "\"coordinates\": [[";
-			if (i > 0) {
-				str += ", ";
-		str += "]]}";
-	else if (this.geomType == geomType.line) {
-		str += "{\"type\": \"LineString\", " + epsgStr + "\"coordinates\": [";
-			if (i > 0) {
-				str += ", ";
-		str += "]}";
-	else if (this.geomType == geomType.point) {
-		str += "{\"type\": \"Point\", " + epsgStr + "\"coordinates\": ";
-		str += this.get(0).toString();
-		str += "}";
-	return str;
- * @class an array of elements, each consisting of a name/value pair
- * @ constructor
-function Wfs_element(){
-	 * returns the number of elements of this {@link Wfs_element} object.
-	 * @return the number of elements
-	 * @type Integer
-	this.count = function(){
-		return name.length;
-	 * returns the name of the element at index i.
-	 * @return the name
-	 * @type String
-	this.getName = function(i){
-		if (isValidElementIndex(i)) {return name[i];}
-		return false;
-	 * returns the value of the element at index i.
-	 * @return the value
-	this.getValue = function(i){
-		if (isValidElementIndex(i)) {return value[i];}
-		return false;
-	 * appends a new element with a given name. If an element with this name exists, it is overwritten.
-	 * @param {String} aName the name of the new element
-	 * @param {String} aValue the value of the new element
-	this.setElement = function(aName, aValue){
-		var i = this.getElementIndexByName(aName);
-		if (i === false) {i = this.count();}
-		name[i] = aName;
-		value[i] = aValue;
-	 * removes an element with a given name. If an element with this name exists, it is removed.
-	 * @param {String} aName the name of the element to delete
-	this.delElement = function(aName){
-			name.splice(i, 1);
-			value.splice(i, 1);
-	 * checks if an index is valid
-	 * @private
-	 * @param {Integer} i an index
-	 * @return true if the index is valid; otherwise false
-	 * @type Boolean
-	var isValidElementIndex = function(i){
-		if (i>=0 && i<name.length) {return true;}
-		var e = new Mb_exception("class Wfs_element: function isValidElementIndex: illegal element index");
-		return false;
-	var name  = [];
-	var value = [];
- * gets the index of the element with a given name.
- * @param {String} elementName a name
- * @return the index of the element; if no element with this name exists, false
- * @type Integer, Boolean
-Wfs_element.prototype.getElementIndexByName = function(elementName){
-	for (var j = 0, len = this.count() ; j < len ; j++){
-		if (this.getName(j) == elementName) {return j;}
-	return false;
- * gets the value of the element with a given name.
- * @return the value of the element; if no element with this name exists, false
- * @type String, Boolean
-Wfs_element.prototype.getElementValueByName = function(elementName){
-	var i = this.getElementIndexByName(elementName);
-	if (i === false) {return false;}
-	return this.getValue(i);
-Wfs_element.prototype.toString = function () {
-	var str = "";
-		str += "\"properties\": {";
-		for (i = 0, len = this.count(); i < len; i++) {
-			if (i > 0) {
-				str += ",";
-			var key = this.getName(i);
-			var value = this.getValue(i);
-			str += "\"" + key + "\":\"" + value + "\"";
-		str += "}";
-	return str;
- * @class a {@link Canvas} contains a {@link DivTag} that holds graphics rendered by {@link jsGraphics}
- * @constructor
- * @requires DivTag
- * @requires jsGraphics
- * @requires GeometryArray
- * @requires MultiGeometry
- * @param {String} aMapFrame name of the target mapframe
- * @param {String} aTagName name of the target div tag
- * @param {String} aStyle style of the div tag
- * @param {Integer} aLineWidth the line width of the jsGraphics output
-function Canvas(aMapframe, aTagName, aStyle, aLineWidth) {
-	 * draws the geometry of the canvas
-	 * @param {String} t geometry type (@see GeomType)
-	 * @param {MultiGeometry} g a MultiGeometry object
-	 * @param {String} col a color
-	 * @private
- 	this.drawGeometry = function(t,g,col){
-		if(t == geomType.point) {
-			var poiIcon = g.e.getElementValueByName("Mapbender:icon");
-			for(var i=0, ilen = g.count(); i < ilen; i++){
-				var currentGeom = g.get(i);
-				var p = realToMap(mapframe, currentGeom.get(0));
-				var px = p.x;
-				var py = p.y;
-				var radius = diameter/2;
-				if ((px - radius < mapframeWidth && px + radius > 0 &&
-					py - radius < mapframeHeight && py + radius > 0) ||
-					(p.dist(new Point(0,0)) < radius ||
-					 p.dist(new Point(mapframeWidth, mapframeHeight)) < radius ||
-					 p.dist(new Point(0,mapframeHeight)) < radius ||
-					 p.dist(new Point(mapframeWidth, 0)) < radius
-					// if the point contains a link to an icon, display the icon
-					if (poiIcon) {
-						displayIcon(poiIcon, px, py);
-					else {
-						drawCircle(px-1, py-1, diameter,col);
-		else if(t == geomType.line || t==geomType.polygon) {
-				var previousPoint = realToMap(mapframe, currentGeom.get(0));
-				for (var j=1, jlen = currentGeom.count(); j < jlen; j++) {
-					(function () {
-						var currentPoint = realToMap(mapframe, currentGeom.get(j));
-						var pq = calculateVisibleDash(previousPoint, currentPoint, mapframeWidth, mapframeHeight);
-						if (pq) {
-							drawLine([pq[0].x-1, pq[1].x-1], [pq[0].y-1, pq[1].y-1], col);
-						previousPoint = currentPoint;
-		else {
-			var e = new Mb_exception("class Canvas: function drawGeometry: unknown geomType " + t);
-	 * checks if the MultiGeometry's bounding box width and height is smaller than minWidth
-	 * @private
-	this.isTooSmall = function(g){
-		// TODO switch between dot, original, circle
-//		return false;
-		var tmp = g.getBBox();
-		var min = realToMap(mapframe,tmp[0]);
-		var max = realToMap(mapframe,tmp[1]);
-		if((Math.abs(max.x - min.x) < minWidth) && (Math.abs(max.y - min.y) < minWidth)) {
-			return true;
-		return false;
-	 * gets the jsGraphics.
-	 * @private
-	 * @return the jsGraphics
-	 * @type jsGraphics
-	this.getCanvas = function(){
-		return canvas;
-	this.setDiameter = function (px) {
-		diameter = px;
-	 * draws a circle with {@link jsGraphics}.
-	 * @private
-	 * @param {Float} x x value of the center
-	 * @param {Float} y y value of the center
-	 * @param {Float} diameter diameter of the circle
-	 * @param {String} color the color of the circle in hex format
-	var drawCircle = function(x, y, diameter, color) {
-		canvas.setColor(color);
-		canvas.drawEllipse(x-diameter/2,y-diameter/2,diameter,diameter);
-	 * draws a polyline with {@link jsGraphics}.
-	 * @private
-	 * @param {Array} x_array array of x values
-	 * @param {Array} y_array array of y values
-	 * @param {String} color the color of the polyline in hex format
-	var drawLine = function(x_array, y_array, color) {
-		canvas.drawPolyline(x_array, y_array);
-	 * Displays an icon in the mapframe
-	 * @private
-	 * @param {String} url link to the image
-	 * @param {Float} x x coordinate within the map frame
-	 * @param {Float} y y coordinate within the map frame
-	var displayIcon = function (url, x, y) {
-		var newImg = that.canvasDivTag.getRootNode().createElement("img");
-		newImg.src = url;
-		newImg.className = "mapsymbol";
-		newImg.style.cursor = "help";
-		newImg.style.position = "absolute";
-		// center the image at x, y
-		newImg.style.top = y - Math.round(newImg.height/2);
-		newImg.style.left = x - Math.round(newImg.width/2);
-		newImg.style.zIndex = 100;
-		var thisTag = that.canvasDivTag.getTag();
-		thisTag.appendChild(newImg);
-	 * This is the {@link DivTag} that contains the output by {@link jsGraphics}.
-	 * @type DivTag
-	this.canvasDivTag = new DivTag(aTagName, aMapframe, aStyle);
-	var that = this;
-	var diameter = 8;
-	var minWidth = 8;
-	var lineWidth = aLineWidth || 2;
-	var mapframe = aMapframe;
-	var mapObjInd = getMapObjIndexByName(mapframe);
-	var mapframeWidth = mb_mapObj[mapObjInd].width;
-	var mapframeHeight = mb_mapObj[mapObjInd].height;
-	eventResizeMap.register(function () {
-		mapframeWidth = mb_mapObj[mapObjInd].width;
-		mapframeHeight = mb_mapObj[mapObjInd].height;
-	var style = aStyle;
-	var canvas = new jsGraphics(aTagName, window.frames[mapframe]);
-	canvas.setStroke(lineWidth);
-	mb_registerPanSubElement(aTagName);
- * cleans the canvas by emptying the canvas {@link DivTag}.
-Canvas.prototype.clean = function () {
-	this.canvasDivTag.clean();
- * paints all geometries.
- * @param {GeometryArray} gA the geometries that will be drawn
-Canvas.prototype.paint = function(gA) {
-	for (var q = 0; q < gA.count(); q++) {
-		var m = gA.get(q);
-		var t = m.geomType;
-		var col = m.color;
-		if (t == geomType.point) {
-			this.drawGeometry(t,m,col);
-		else {
-			if (this.isTooSmall(m)){
-				var newMember = new MultiGeometry(geomType.point);
-				newMember.addGeometry();
-				newMember.get(-1).addPoint(m.getCenter());
-				this.drawGeometry(geomType.point,newMember,col);
-			else{
-				if(t == geomType.line) {this.drawGeometry(t,m, col);}
-				else if(t == geomType.polygon) {this.drawGeometry(t,m,col);}
-				else {
-					var e = new Mb_exception("class Canvas: function paint: unknown geomType" + t);
-	this.getCanvas().paint();
- * @class a {@link Highlight} object is {@link jsGraphics} rendering of a {@link GeometryArray} in various mapframes.
- * @constructor
- * @requires Canvas
- * @param {Array} aTargetArray an array of Strings referring to mapframes
- * @param {String} aTagName the name of the div tags
- * @param {Object} aStyle the style of the div tags
- * @param {Integer} the line width of the jsGraphics lines
-function Highlight(aTargetArray, aTagName, aStyle, aLineWidth) {
-	 * removes a {@link MultiGeometry} object from the geometry Array
-	 * @param {MultiGeometry} m a MultiGeometry
-	 * @param {String} color a color
-	this.del = function(m, color) {
-		var a = gA.findMultiGeometry(m);
-		var del = false;
-		for (var i=0; i<a.length && del === false; i++) {
-			if (gA.get(a[i]).color == color) {
-				gA.del(a[i]);
-				del = true;
-	 * adds a {@link MultiGeometry} object to the geometry Array
-	 * @param {String} color the color of the highlight
-	this.add = function(m, color) {
-		gA.addCopy(m);
-		if (typeof(color) != 'undefined') {gA.get(-1).color = color;}
-		else {gA.get(-1).color = lineColor;}
-	this.hide = function () {
-		for (var i=0; i < canvas.length; i++) {
-			if (typeof(canvas[i]) == "object") {canvas[i].clean();}
-	 * removes all MultiGeometries.
-	this.clean = function() {
-		if (gA.count() > 0) {
-			gA = new GeometryArray();
-			this.paint();
-	 * displays the highlight
-	this.paint = function() {
-		this.hide();
-		for (var i=0; i<targets.length; i++){
-			if (typeof(canvas[i]) == 'undefined') {
-				canvas[i] = new Canvas(targets[i], tagname, style, lineWidth);
-			canvas[i].paint(gA);
-	this.setDiameter = function (radius) {
-		for (var i = 0; i < targets.length; i++) {
-			if (typeof(canvas[i]) != "undefined") {
-				canvas[i].setDiameter(radius);
-	this.setMouseOver = function (callback) {
-			if (typeof(canvas[i]) !== 'undefined') {
-				canvas[i].canvasDivTag.getTag().onmouseover = function (e) {
-					callback(e);
-	this.setMouseOut = function (callback) {
-				canvas[i].canvasDivTag.getTag().onmouseout = function (e) {
-					callback(e);
-	this.setMouseClick = function (callback) {
-				canvas[i].canvasDivTag.getTag().onclick = function (e) {
-					callback(e);
-	var lineWidth = aLineWidth;
-	var tagname = 'mod_gaz_draw'+aTagName;
-	var targets = aTargetArray;
-	var canvas = [];
-	var gA = new GeometryArray();
-	var lineColor = "#ff0000";
-	this.paint();
-// Snapping
- * @class a {@link Snapping} object stores is {@link jsGraphics} rendering of a {@link GeometryArray} in various mapframes.
- * @constructor
- * @requires Highlight
- * @param {String} aTarget name of the mapframe where snapping occurs
- * @param {String} aTolerance Snapping is activated if the mouse is
- *                 within aTolerance pixel distance to the reference point.
- * @param {String} aColor apparently deprecated?
- * @param {Integer} aZIndex the z-Index of the {@link jsGraphics} generated by {@link Highlight}.
-function Snapping(aTarget, aTolerance, aColor, aZIndex){
-	 * draws a circle to highlight the snapped point.
-	 * @param {Point} center the snapped point.
-	 * @param {Integer} radius radius of the circular highlight.
-	this.draw = function(center,radius){
-		mG = new MultiGeometry(geomType.point);
-		mG.addGeometry();
-		mG.get(-1).addPoint(center);
-		highlight.add(mG,snappingColor);
-		highlight.paint();
-	this.getTolerance = function() {
-		return tolerance;
-	this.getTarget = function() {
-		return target;
-	this.cleanHighlight = function() {
-		return highlight.clean();
-	this.addPoint = function(aPoint) {
-		coord.push(aPoint);
-	this.getPointCount = function() {
-		return coord.length;
-	this.getPoint = function(i) {
-		return coord[i];
-	this.resetPoints = function() {
-		coord = [];
-	this.getNearestNeighbour = function(){
-		if (min_i != -1) {return this.getPoint(min_i);}
-		return false;
-	this.setIndexOfNearestNeighbour = function(i){
-		min_i = i;
-	this.resetIndexOfNearestNeighbour = function(){
-		min_i = -1;
-	 * @private
-	var tolerance = (typeof(aTolerance) == 'undefined') ? 10 : aTolerance;
-	 * @private
-	var zIndex = (typeof(aZIndex) == 'undefined') ? 50 : aZIndex;
-	 * @private
-	var coord = [];
-	 * @private
-	var min_i = -1;
-	 * @private
-	var target = aTarget;
-	 * @private
-	var snappingColor = aColor;
-	 * @private
-	var lineWidth = 2;
-	 * @private
-	var style = {"position":"absolute", "top":"0px", "left":"0px", "z-index":zIndex};
-	 * @private
-	var highlight = new Highlight([target], "snapping"+Math.round(Math.random()*Math.pow(10,10)), style, lineWidth);
-Snapping.prototype.check = function(currPoint){
-	var minDist = false;
-	for (var i = 0 ; i < this.getPointCount() ; i++) {
-		var currDist = currPoint.dist(realToMap(this.getTarget(), this.getPoint(i)));
-		if (minDist === false || currDist < minDist) {
-			minDist = currDist;
-			if (minDist < this.getTolerance()) {this.setIndexOfNearestNeighbour(i);}
-	if (this.getPointCount() > 0 && minDist > this.getTolerance()) {
-		this.resetIndexOfNearestNeighbour();
-	this.cleanHighlight();
-	if (this.isSnapped()) {
-		this.draw(this.getNearestNeighbour(), this.getTolerance());
- * Stores the points which will have the snapping property.
- * @param {GeometryArray} geom all points of geom will be stored. May also be a
- *                             {@link MultiGeometry} or {@link Geometry}.
- * @param {Point} point this point is excluded. Useful when moving a point of a
- *                      geometry; you don't want to snap against the point you
- *                      move. Optional.
-Snapping.prototype.store = function(geom, point){
-	this.resetPoints();
-	for (var i = 0 ; i < geom.count(); i++){
-		if (geom.name == nameGeometryArray || geom.name == nameMultiGeometry){
-			for (var j = 0 ; j < geom.get(i).count() ; j++){
-				if (geom.get(i).name == nameMultiGeometry){
-					for (var k = 0 ; k < geom.get(i).get(j).count() ; k++){
-						if ((geom.get(i).get(j).isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
-							this.add(geom.getPoint(i, j, k));
-				else {
-					if ((geom.get(i).isComplete() === true && typeof(point) == 'undefined') || (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point))){
-						this.add(geom.getPoint(i, j));
-		else {
-			if (typeof(point) != 'undefined' && !geom.get(i).get(j).get(k).equals(point)){
-				this.add(geom.get(i));
- * Determines whether a point is within snapping distance to the mouse cursor
- * @return true if a point is within snapping distance; else false
- * @type Boolean
-Snapping.prototype.isSnapped = function(){
-	if (this.getNearestNeighbour() !== false) {return true;}
-	return false;
- * Returns the point that is within snapping distance and closest to the mouse cursor.
- * @return the point (if there is any); else false
- * @type Point
-Snapping.prototype.getSnappedPoint = function(){
-	return this.getNearestNeighbour();
- * Adds the point to the stored points with snapping property.
- * @param {Point} point which receives snapping property.
-Snapping.prototype.add = function(aPoint){
-	this.addPoint(aPoint);
- * Removes the highlight.
-Snapping.prototype.clean = function(){
-// misc. functions
- * @ignore
-function calculateVisibleDash (p0, p1, width, height) {
-	if (p0.x > p1.x) {var p_temp = p0; p0 = p1; p1 = p_temp; p_temp = null;}
-	var p = p0; var q = p1; var m; var ix; var iy;
-	if (p1.x != p0.x) {
-		m = -(p1.y-p0.y)/(p1.x-p0.x);
-		if (p0.x < width && p1.x > 0 && !(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height) ) {
-			if (p0.x < 0) {
-				iy = p0.y - m*(0-p0.x);
-				if (iy > 0 && iy < height) {p = new Point(0, iy);}
-				else if (iy > height) {
-				    ix = p0.x+((p0.y - height)/m);
-				    if (ix > 0 && ix < width) {p = new Point(ix, height);} else {return false;}
-				else if (iy < 0) {
-				    ix = p0.x+(p0.y/m);
-				    if (ix > 0 && ix < width) {p = new Point(ix, 0);} else {return false;}
-			else if (p0.y >= 0 && p0.y <= height) {p = p0;}
-			else if (p0.y < 0) {
-			else if (p0.y > height && m > 0) {
-			if (p1.x > width) {
-				iy = p1.y - m*(width-p1.x);
-				if (iy > 0 && iy < height) {q = new Point(width, iy);}
-				    if (ix > 0 && ix < width) {q = new Point(ix, 0);} else {return false;}
-				    if (ix > 0 && ix < width) {q = new Point(ix, height);} else {return false;}
-			else if (p1.y >= 0 && p1.y <= height) {q = p1;}
-			else if (p1.y < 0) {
-			    ix = p1.x+(p1.y/m);
-			else if (p1.y > height) {
-			    ix = p1.x+((p1.y- height)/m);
-	else {
-		if (!(p0.y < 0 && p1.y < 0) && !(p0.y > height && p1.y > height)) {
-			if (p0.y < 0) {p = new Point(p0.x, 0);}
-			else if (p0.y > height) {p = new Point(p0.x, height);}
-			else {p = p0;}
-			if (p1.y < 0) {q = new Point(p0.x, 0);}
-			else if (p1.y > height) {q = new Point(p0.x, height);}
-			else {q = p1;}
-	return [new Point(Math.round(q.x), Math.round(q.y)), new Point(Math.round(p.x), Math.round(p.y))];
- * @ignore
-function objString (a){
-	var z = "";
-	for (attr in a) {
-		var b = a[attr];
-		if (typeof(b) == "object") {z += objString(b);}
-		else {z += attr + " " + b + "\n";}
-	return z;
+var nameGeometryArray="GeometryArray";var nameMultiGeometry="MultiGeometry";var nameGeometry="Geometry";function GeomType(){this.polygon="polygon";this.line="line";this.point="point";}
+var geomType=new GeomType();function GeometryArray(){this.addMember=function(geomType){this.add(new MultiGeometry(geomType));};this.name=nameGeometryArray;this.list=[];}
+GeometryArray.prototype=new List();GeometryArray.prototype.getGeometry=function(i,j){var tmp=this.get(i);return tmp.get(j);};GeometryArray.prototype.getPoint=function(i,j,k){return this.get(i).get(j).get(k);};GeometryArray.prototype.findMultiGeometry=function(geom){var a=[];for(var i=0;i<this.count();i++){if(this.get(i).equals(geom)){a.push(i);}}
+return a;};GeometryArray.prototype.delGeometry=function(i,j){if(this.get(i).del(j)===false){this.del(i);}};GeometryArray.prototype.delPoint=function(i,j,k){var res=this.get(i).delPoint(j,k);if(res===false){this.del(i);}};GeometryArray.prototype.close=function(){if(!this.get(-1).get(-1).close()){this.delGeometry(-1,-1);}
+else{if(this.get(-1).get(-1).count()===0){this.get(-1).del(-1);}
+if(this.get(-1).count()===0){this.del(-1);}}};GeometryArray.prototype.delAllPointsLike=function(point){var finished=false;while(finished===false){finished=true;for(var i=0;finished===true&&i<this.count();i++){for(var j=0;finished===true&&j<this.get(i).count();j++){for(var k=0;finished===true&&k<this.get(i).get(j).count();k++){if(this.getPoint(i,j,k).equals(point)){this.delPoint(i,j,k);finished=false;}}}}}};GeometryArray.prototype.updateAllPointsLike=function(oldP,newP){for(var i=0;i<this.count();i++){this.get(i).updateAllPointsLike(oldP,newP);}};GeometryArray.prototype.placemarkToString=function(placemarkId){var str="{\"type\": \"Feature\", \"geometry\": ";var geometriesFromPlacemark=[];for(var i=0,len=this.count();i<len;i++){if(this.get(i).isFromKml()&&this.get(i).e.getElementValueByName("Mapbender:placemarkId")==placemarkId){geometriesFromPlacemark.push(i);}}
+if(geometriesFromPlacemark.length>1){str+="{\"type\": \"GeometryCollection\", \"geometries\": [";for(var i=0;i<geometriesFromPlacemark.length;i++){if(i>0){str+=",";}
+str+=this.get(geometriesFromPlacemark[i]).placemarkToString();}
+str+="]}";var propString=this.get(geometriesFromPlacemark[0]).e.toString();if(propString){str+=","+propString;}}
+else if(geometriesFromPlacemark.length===1){str+=this.get(geometriesFromPlacemark[0]).placemarkToString();}
+str+="}";return str;};GeometryArray.prototype.getBBox=function(){var q=this.get(0).get(0).get(0);var min=cloneObject(q);var max=cloneObject(q);for(var i=0;i<this.count();i++){var pos=this.get(i).getBBox();if(pos[0].x<min.x){min.x=pos[0].x;}
+if(pos[1].x>max.x){max.x=pos[1].x;}
+if(pos[1].y>max.y){max.y=pos[1].y;}
+if(pos[0].y<min.y){min.y=pos[0].y;}}
+return[min,max];};GeometryArray.prototype.importGeoJSON=function(geoJSON){var isFeatureCollection=false;var featureCollectionEpsg=4326;var featureEpsg=4326;for(var i in geoJSON){if(typeof(geoJSON[i])!="function"){switch(i){case"type":isFeatureCollection=(geoJSON[i]=="FeatureCollection")?true:false;break;case"crs":if(geoJSON[i].type=="EPSG"){featureCollectionEpsg=geoJSON[i].properties.code;featureEpsg=geoJSON[i].properties.code;}
+break;case"features":if(isFeatureCollection){var featureArray=geoJSON[i];for(var j=0;j<featureArray.length;j++){featureEpsg=featureCollectionEpsg;var currentFeature=featureArray[j];var isFeature=false;for(var k in currentFeature){if(typeof(currentFeature[k])!="function"){var geometrytype;switch(k){case"type":isFeature=(currentFeature[k]=="Feature")?true:false;break;case"properties":var properties=currentFeature[k];if(geometrytype!="GeometryCollection"){for(var l in properties){if(typeof(properties[l])!="function"){this.get(-1).e.setElement(l,properties[l]);}}}
+break;case"crs":if(currentFeature[k].type=="EPSG"){featureEpsg=currentFeature[k].properties.code;}
+break;case"geometry":if(isFeature){var currentGeometry=currentFeature[k];for(var l in currentGeometry){if(typeof(currentGeometry[l])!="function"){switch(l){case"type":geometrytype=currentGeometry[l];break;case"coordinates":var coordinates=currentGeometry[l];switch(geometrytype){case"Point":this.addMember(geomType.point);this.get(-1).addGeometry();this.getGeometry(-1,-1).addPointByCoordinates(coordinates[0],coordinates[1],coordinates[2]);this.getGeometry(-1,-1).setEpsg(featureEpsg);this.close();break;case"LineString":this.addMember(geomType.line);this.get(-1).addGeometry();for(var m=0;m<coordinates.length;m++){var currentPoint=coordinates[m];this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0],currentPoint[1],currentPoint[2]);}
+this.getGeometry(-1,-1).setEpsg(featureEpsg);this.close();break;case"MultiLineString":this.addMember(geomType.line);for(var m=0;m<coordinates.length;m++){this.get(-1).addGeometry();var currentLine=coordinates[m];for(var n=0;n<currentLine.length;n++){var currentPoint=currentLine[n];this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0],currentPoint[1],currentPoint[2]);}
+this.getGeometry(-1,-1).setEpsg(featureEpsg);}
+this.close();break;case"Polygon":this.addMember(geomType.polygon);for(var m=0;m<coordinates.length;m++){this.get(-1).addGeometry();var currentPolygon=coordinates[m];for(var n=0;n<currentPolygon.length;n++){var currentPoint=currentPolygon[n];this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0],currentPoint[1],currentPoint[2]);}
+this.close();break;case"MultiPolygon":this.addMember(geomType.polygon);for(var m=0;m<coordinates.length;m++){this.get(-1).addGeometry();var currentPolygon=coordinates[m];for(var n=0;n<currentPolygon.length;n++){var currentPoint=currentPolygon[n];this.getGeometry(-1,-1).addPointByCoordinates(currentPoint[0],currentPoint[1],currentPoint[2]);}
+this.close();break;case"GeometryCollection":var exc=new Mb_exception("Geometry: GeometryCollections are not yet supported");break;}}}}}}}}}}}}}}
+GeometryArray.prototype.toString=function(){var str="{\"type\": \"FeatureCollection\", \"features\": [";var multiGeometriesFromKml=[];var multiGeometriesNotFromKml=[];for(var i=0,len=this.count();i<len;i++){if(this.get(i).isFromKml()){var placemarkId=this.get(i).e.getElementValueByName("Mapbender:placemarkId");var isFound=false;for(var j=0;j<multiGeometriesFromKml&&isFound===false;j++){if(multiGeometriesFromKml==placemarkId){isFound=true;}}
+if(!isFound){multiGeometriesFromKml.push(placemarkId);}}
+else{multiGeometriesNotFromKml.push(i);}}
+for(var i=0,len=multiGeometriesNotFromKml.length;i<len;i++){if(i>0){str+=",";}
+str+=this.get(multiGeometriesNotFromKml[i]).toString();}
+if(multiGeometriesNotFromKml.length>0&&multiGeometriesFromKml.length>0){str+=",";}
+for(var i=0;i<multiGeometriesFromKml.length;i++){if(i>0){str+=",";}
+str+=this.placemarkToString();}
+str+="]}";return str;};function MultiGeometry(geomType){this.addGeometry=function(){this.add(new Geometry(this.geomType));};this.del=function(i){i=this.getIndex(i);if(i!==false){var tmpLength=this.count()-1;for(var z=i;z<tmpLength;z++){this.list[z]=this.list[z+1];e[z]=e[z+1];}
+this.list.length-=1;if(this.list.length===0){return false;}}
+return true;};this.list=[];this.e=new Wfs_element();this.geomType=geomType;this.name=nameMultiGeometry;}
+MultiGeometry.prototype=new List();MultiGeometry.prototype.updateAllPointsLike=function(oldP,newP){for(var i=0;i<this.count();i++){this.get(i).updateAllPointsLike(oldP,newP);}};MultiGeometry.prototype.getBBox=function(){var q=this.get(0).get(0);var min=cloneObject(q);var max=cloneObject(q);for(var i=0;i<this.count();i++){var pos=this.get(i).getBBox();if(pos[0].x<min.x){min.x=pos[0].x;}
+return[min,max];};MultiGeometry.prototype.getBBox4=function(){var bbox=this.getBBox();var realBox=new MultiGeometry(geomType.polygon);realBox.addGeometry(geomType.polygon);realBox.get(-1).addPointByCoordinates(bbox[0].x,bbox[0].y);realBox.get(-1).addPointByCoordinates(bbox[0].x,bbox[1].y);realBox.get(-1).addPointByCoordinates(bbox[1].x,bbox[1].y);realBox.get(-1).addPointByCoordinates(bbox[1].x,bbox[0].y);realBox.get(-1).close();return realBox;};MultiGeometry.prototype.getCenter=function(){var tmp=this.getBBox();var x=parseFloat(tmp[0].x)+parseFloat((tmp[1].x-tmp[0].x)/2);var y=parseFloat(tmp[0].y)+parseFloat((tmp[1].y-tmp[0].y)/2);return new Point(x,y);};MultiGeometry.prototype.getTotalPointCount=function(){var c=0;for(var i=0;i<this.count();i++){c+=this.get(i).count();}
+return c;};MultiGeometry.prototype.getPoint=function(j,k){return this.get(j).get(k);};MultiGeometry.prototype.equals=function(multigeom){if(this.geomType!=multigeom.geomType){return false;}
+if(this.count()!=multigeom.count()){return false;}
+if(this.getTotalPointCount()!=multigeom.getTotalPointCount()){return false;}
+for(var i=0;i<this.count();i++){if(!this.get(i).equals(multigeom.get(i))){return false;}}
+return true;};MultiGeometry.prototype.delPoint=function(i,j){var res=this.get(i).del(j);if(res===false){return this.del(i);}
+return true;};MultiGeometry.prototype.isFromKml=function(){if(this.e.getElementValueByName("Mapbender:kml")){return true;}
+return false;};MultiGeometry.prototype.toString=function(){var str=this.toStringWithoutProperties();var propString=this.e.toString();if(propString){str+=","+propString;}
+str+="}";return str;};MultiGeometry.prototype.placemarkToString=function(){var str="";for(var i=0,len=this.count();i<len;i++){if(i>0){str+=",";}
+str+=this.get(i).toString();}
+return str;};MultiGeometry.prototype.toStringWithoutProperties=function(){var str="{\"type\": \"Feature\", ";var epsg=this.getEpsg();if(epsg){str+="\"crs\": {\"type\": \"EPSG\", \"properties\": {\"code\": "+epsg+"}}, ";}
+str+="\"geometry\": ";for(var i=0,len=this.count();i<len;i++){if(i>0){str+=",";}
+return str;};MultiGeometry.prototype.getEpsg=function(){if(this.count()>0){return this.get(0).getEpsg();}
+return false;};function Geometry(aGeomtype){this.del=function(i){i=this.getIndex(i);if(i!==false){var tmpLength=this.count()-1;for(var z=i;z<tmpLength;z++){this.list[z]=this.list[z+1];}
+this.list.length-=1;if(this.geomType==geomType.polygon){if(i==tmpLength){this.list[0]=this.list[tmpLength-1];}
+else if(i===0){this.list[tmpLength-1]=this.list[0];}
+if(this.list.length==1){return false;}}
+updateDist();if(this.list.length===0){return false;}
+return true;}
+return false;};this.addPointByCoordinates=function(x,y,z){var newPoint=new Point(x,y,z);this.add(newPoint);};this.addPoint=function(aPoint){this.add(new Point(aPoint.x,aPoint.y,aPoint.z));updateDist();};this.addPointAtIndex=function(p,i){i=this.getIndex(i);if(i!==false){for(var z=this.count();z>i;z--){this.list[z]=this.list[z-1];}
+this.list[i]=new Point(p.x,p.y,p.z);updateDist();}};this.updatePointAtIndex=function(p,i){i=this.getIndex(i);if((i===0||i==this.count()-1)&&this.geomType==geomType.polygon){this.list[0]=p;this.list[this.count()-1]=p;}
+else{this.list[i]=p;}
+updateDist();};var updateDist=function(){};this.getCurrentDist=function(numberOfDigits){if(typeof(numberOfDigits)=="number"){return roundToDigits(dist[this.count()-1],numberOfDigits);}
+return dist[this.count()-1];};this.getTotalDist=function(numberOfDigits){if(typeof(numberOfDigits)=="number"){return roundToDigits(totaldist[this.count()-1],numberOfDigits);}
+return totaldist[this.count()-1];};this.close=function(){complete=true;if(this.geomType==geomType.polygon){if(this.count()>2){if(!this.get(0).equals(this.get(-1))){this.addPoint(this.get(0));}}
+else{return false;}}
+if(this.geomType==geomType.line){if(this.count()<2){return false;}}
+return true;};this.isComplete=function(){return complete;};this.setEpsg=function(someEpsg){if(typeof(someEpsg)=="number"){epsg=someEpsg;return true;}
+var e=new Mb_exception("EPSG code not valid ("+someEpsg+")");return false;};this.getEpsg=function(){return epsg;};this.list=[];var dist=[];var totaldist=[];var complete=false;var epsg;var that=this;this.geomType=aGeomtype;this.name=nameGeometry;}
+Geometry.prototype=new List();Geometry.prototype.getBBox=function(){var q=this.get(0);var min=cloneObject(q);var max=cloneObject(q);for(var j=0;j<this.count();j++){var pos=this.get(j);if(pos.x<min.x){min.x=pos.x;}
+else if(pos.x>max.x){max.x=pos.x;}
+if(pos.y<min.y){min.y=pos.y;}
+else if(pos.y>max.y){max.y=pos.y;}}
+return[min,max];};Geometry.prototype.updateAllPointsLike=function(oldP,newP){var len=this.count();for(var i=0;i<len;i++){if(oldP.equals(this.get(i))){if(i>0&&newP.equals(this.get(i-1))){this.del(i);len--;i--;}
+else{this.updatePointAtIndex(newP,i);}}}};Geometry.prototype.equals=function(geom){if(this.geomType!=geom.geomType){return false;}
+if(this.count()!=geom.count()){return false;}
+for(var i=0;i<this.count();i++){if(!this.get(i).equals(geom.get(i))){return false;}}
+return true;};Geometry.prototype.toString=function(){var str="";var epsgStr="";var epsg=this.getEpsg();if(epsg){epsgStr="\"crs\": {\"type\": \"EPSG\", \"properties\": {\"code\": "+epsg+"}}, ";}
+if(this.geomType==geomType.polygon){str+="{\"type\": \"Polygon\", "+epsgStr+"\"coordinates\": [[";for(var i=0;i<this.count();i++){if(i>0){str+=", ";}
+str+="]]}";}
+else if(this.geomType==geomType.line){str+="{\"type\": \"LineString\", "+epsgStr+"\"coordinates\": [";for(var i=0;i<this.count();i++){if(i>0){str+=", ";}
+str+="]}";}
+else if(this.geomType==geomType.point){str+="{\"type\": \"Point\", "+epsgStr+"\"coordinates\": ";str+=this.get(0).toString();str+="}";}
+return str;};function Wfs_element(){this.count=function(){return name.length;};this.getName=function(i){if(isValidElementIndex(i)){return name[i];}
+return false;};this.getValue=function(i){if(isValidElementIndex(i)){return value[i];}
+return false;};this.setElement=function(aName,aValue){var i=this.getElementIndexByName(aName);if(i===false){i=this.count();}
+name[i]=aName;value[i]=aValue;};this.delElement=function(aName){var i=this.getElementIndexByName(aName);if(i!==false){name.splice(i,1);value.splice(i,1);}}
+var isValidElementIndex=function(i){if(i>=0&&i<name.length){return true;}
+var e=new Mb_exception("class Wfs_element: function isValidElementIndex: illegal element index");return false;};var name=[];var value=[];}
+Wfs_element.prototype.getElementIndexByName=function(elementName){for(var j=0,len=this.count();j<len;j++){if(this.getName(j)==elementName){return j;}}
+return false;};Wfs_element.prototype.getElementValueByName=function(elementName){var i=this.getElementIndexByName(elementName);if(i===false){return false;}
+return this.getValue(i);};Wfs_element.prototype.toString=function(){var str="";if(this.count()>0){str+="\"properties\": {";for(i=0,len=this.count();i<len;i++){if(i>0){str+=",";}
+var key=this.getName(i);var value=this.getValue(i);str+="\""+key+"\":\""+value+"\"";}
+str+="}";}
+return str;};function Canvas(aMapframe,aTagName,aStyle,aLineWidth){this.drawGeometry=function(t,g,col){if(t==geomType.point){var poiIcon=g.e.getElementValueByName("Mapbender:icon");for(var i=0,ilen=g.count();i<ilen;i++){var currentGeom=g.get(i);var p=realToMap(mapframe,currentGeom.get(0));var px=p.x;var py=p.y;var radius=diameter/2;if((px-radius<mapframeWidth&&px+radius>0&&py-radius<mapframeHeight&&py+radius>0)||(p.dist(new Point(0,0))<radius||p.dist(new Point(mapframeWidth,mapframeHeight))<radius||p.dist(new Point(0,mapframeHeight))<radius||p.dist(new Point(mapframeWidth,0))<radius)){if(poiIcon){displayIcon(poiIcon,px,py);}
+else{drawCircle(px-1,py-1,diameter,col);}}}}
+else if(t==geomType.line||t==geomType.polygon){for(var i=0,ilen=g.count();i<ilen;i++){var currentGeom=g.get(i);var previousPoint=realToMap(mapframe,currentGeom.get(0));for(var j=1,jlen=currentGeom.count();j<jlen;j++){(function(){var currentPoint=realToMap(mapframe,currentGeom.get(j));var pq=calculateVisibleDash(previousPoint,currentPoint,mapframeWidth,mapframeHeight);if(pq){drawLine([pq[0].x-1,pq[1].x-1],[pq[0].y-1,pq[1].y-1],col);}
+previousPoint=currentPoint;})();}}}
+else{var e=new Mb_exception("class Canvas: function drawGeometry: unknown geomType "+t);}};this.isTooSmall=function(g){var tmp=g.getBBox();var min=realToMap(mapframe,tmp[0]);var max=realToMap(mapframe,tmp[1]);if((Math.abs(max.x-min.x)<minWidth)&&(Math.abs(max.y-min.y)<minWidth)){return true;}
+return false;};this.getCanvas=function(){return canvas;};this.setDiameter=function(px){diameter=px;};var drawCircle=function(x,y,diameter,color){canvas.setColor(color);canvas.drawEllipse(x-diameter/2,y-diameter/2,diameter,diameter);};var drawLine=function(x_array,y_array,color){canvas.setColor(color);canvas.drawPolyline(x_array,y_array);};var displayIcon=function(url,x,y){var newImg=that.canvasDivTag.getRootNode().createElement("img");newImg.src=url;newImg.className="mapsymbol";newImg.style.cursor="help";newImg.style.position="absolute";newImg.style.top=y-Math.round(newImg.height/2);newImg.style.left=x-Math.round(newImg.width/2);newImg.style.zIndex=100;var thisTag=that.canvasDivTag.getTag();thisTag.appendChild(newImg);}
+this.canvasDivTag=new DivTag(aTagName,aMapframe,aStyle);var that=this;var diameter=8;var minWidth=8;var lineWidth=aLineWidth||2;var mapframe=aMapframe;var mapObjInd=getMapObjIndexByName(mapframe);var mapframeWidth=mb_mapObj[mapObjInd].width;var mapframeHeight=mb_mapObj[mapObjInd].height;eventResizeMap.register(function(){mapframeWidth=mb_mapObj[mapObjInd].width;mapframeHeight=mb_mapObj[mapObjInd].height;});var style=aStyle;var canvas=new jsGraphics(aTagName,window.frames[mapframe]);canvas.setStroke(lineWidth);mb_registerPanSubElement(aTagName);}
+Canvas.prototype.clean=function(){this.canvasDivTag.clean();};Canvas.prototype.paint=function(gA){for(var q=0;q<gA.count();q++){var m=gA.get(q);var t=m.geomType;var col=m.color;if(t==geomType.point){this.drawGeometry(t,m,col);}
+else{if(this.isTooSmall(m)){var newMember=new MultiGeometry(geomType.point);newMember.addGeometry();newMember.get(-1).addPoint(m.getCenter());this.drawGeometry(geomType.point,newMember,col);}
+else{if(t==geomType.line){this.drawGeometry(t,m,col);}
+else if(t==geomType.polygon){this.drawGeometry(t,m,col);}
+else{var e=new Mb_exception("class Canvas: function paint: unknown geomType"+t);}}}}
+this.getCanvas().paint();};function Highlight(aTargetArray,aTagName,aStyle,aLineWidth){this.del=function(m,color){var a=gA.findMultiGeometry(m);var del=false;for(var i=0;i<a.length&&del===false;i++){if(gA.get(a[i]).color==color){gA.del(a[i]);del=true;}}};this.add=function(m,color){gA.addCopy(m);if(typeof(color)!='undefined'){gA.get(-1).color=color;}
+else{gA.get(-1).color=lineColor;}};this.hide=function(){for(var i=0;i<canvas.length;i++){if(typeof(canvas[i])=="object"){canvas[i].clean();}}};this.clean=function(){if(gA.count()>0){gA=new GeometryArray();this.paint();}};this.paint=function(){this.hide();for(var i=0;i<canvas.length;i++){if(typeof(canvas[i])=="object"){canvas[i].clean();}}
+for(var i=0;i<targets.length;i++){if(typeof(canvas[i])=='undefined'){canvas[i]=new Canvas(targets[i],tagname,style,lineWidth);}
+canvas[i].paint(gA);}};this.setDiameter=function(radius){for(var i=0;i<targets.length;i++){if(typeof(canvas[i])!="undefined"){canvas[i].setDiameter(radius);}}}
+this.setMouseOver=function(callback){for(var i=0;i<targets.length;i++){if(typeof(canvas[i])!=='undefined'){canvas[i].canvasDivTag.getTag().onmouseover=function(e){callback(e);};}}};this.setMouseOut=function(callback){for(var i=0;i<targets.length;i++){if(typeof(canvas[i])!=='undefined'){canvas[i].canvasDivTag.getTag().onmouseout=function(e){callback(e);};}}};this.setMouseClick=function(callback){for(var i=0;i<targets.length;i++){if(typeof(canvas[i])!=='undefined'){canvas[i].canvasDivTag.getTag().onclick=function(e){callback(e);};}}};var lineWidth=aLineWidth;var tagname='mod_gaz_draw'+aTagName;var style=aStyle;var targets=aTargetArray;var canvas=[];var gA=new GeometryArray();var lineColor="#ff0000";this.paint();}
+function Snapping(aTarget,aTolerance,aColor,aZIndex){this.draw=function(center,radius){mG=new MultiGeometry(geomType.point);mG.addGeometry();mG.get(-1).addPoint(center);highlight.add(mG,snappingColor);highlight.paint();};this.getTolerance=function(){return tolerance;};this.getTarget=function(){return target;};this.cleanHighlight=function(){return highlight.clean();};this.addPoint=function(aPoint){coord.push(aPoint);};this.getPointCount=function(){return coord.length;};this.getPoint=function(i){return coord[i];};this.resetPoints=function(){coord=[];};this.getNearestNeighbour=function(){if(min_i!=-1){return this.getPoint(min_i);}
+return false;};this.setIndexOfNearestNeighbour=function(i){min_i=i;};this.resetIndexOfNearestNeighbour=function(){min_i=-1;};var tolerance=(typeof(aTolerance)=='undefined')?10:aTolerance;var zIndex=(typeof(aZIndex)=='undefined')?50:aZIndex;var coord=[];var min_i=-1;var target=aTarget;var snappingColor=aColor;var lineWidth=2;var style={"position":"absolute","top":"0px","left":"0px","z-index":zIndex};var highlight=new Highlight([target],"snapping"+Math.round(Math.random()*Math.pow(10,10)),style,lineWidth);}
+Snapping.prototype.check=function(currPoint){var minDist=false;for(var i=0;i<this.getPointCount();i++){var currDist=currPoint.dist(realToMap(this.getTarget(),this.getPoint(i)));if(minDist===false||currDist<minDist){minDist=currDist;if(minDist<this.getTolerance()){this.setIndexOfNearestNeighbour(i);}}}
+if(this.getPointCount()>0&&minDist>this.getTolerance()){this.resetIndexOfNearestNeighbour();}
+this.cleanHighlight();if(this.isSnapped()){this.draw(this.getNearestNeighbour(),this.getTolerance());}};Snapping.prototype.store=function(geom,point){this.resetPoints();this.resetIndexOfNearestNeighbour();for(var i=0;i<geom.count();i++){if(geom.name==nameGeometryArray||geom.name==nameMultiGeometry){for(var j=0;j<geom.get(i).count();j++){if(geom.get(i).name==nameMultiGeometry){for(var k=0;k<geom.get(i).get(j).count();k++){if((geom.get(i).get(j).isComplete()===true&&typeof(point)=='undefined')||(typeof(point)!='undefined'&&!geom.get(i).get(j).get(k).equals(point))){this.add(geom.getPoint(i,j,k));}}}
+else{if((geom.get(i).isComplete()===true&&typeof(point)=='undefined')||(typeof(point)!='undefined'&&!geom.get(i).get(j).get(k).equals(point))){this.add(geom.getPoint(i,j));}}}}
+else{if(typeof(point)!='undefined'&&!geom.get(i).get(j).get(k).equals(point)){this.add(geom.get(i));}}}};Snapping.prototype.isSnapped=function(){if(this.getNearestNeighbour()!==false){return true;}
+return false;};Snapping.prototype.getSnappedPoint=function(){return this.getNearestNeighbour();};Snapping.prototype.add=function(aPoint){this.addPoint(aPoint);};Snapping.prototype.clean=function(){this.cleanHighlight();};function calculateVisibleDash(p0,p1,width,height){if(p0.x>p1.x){var p_temp=p0;p0=p1;p1=p_temp;p_temp=null;}
+var p=p0;var q=p1;var m;var ix;var iy;if(p1.x!=p0.x){m=-(p1.y-p0.y)/(p1.x-p0.x);if(p0.x<width&&p1.x>0&&!(p0.y<0&&p1.y<0)&&!(p0.y>height&&p1.y>height)){if(p0.x<0){iy=p0.y-m*(0-p0.x);if(iy>0&&iy<height){p=new Point(0,iy);}
+else if(iy>height){ix=p0.x+((p0.y-height)/m);if(ix>0&&ix<width){p=new Point(ix,height);}else{return false;}}
+else if(iy<0){ix=p0.x+(p0.y/m);if(ix>0&&ix<width){p=new Point(ix,0);}else{return false;}}
+else if(p0.y>=0&&p0.y<=height){p=p0;}
+else if(p0.y<0){ix=p0.x+(p0.y/m);if(ix>0&&ix<width){p=new Point(ix,0);}else{return false;}}
+else if(p0.y>height&&m>0){ix=p0.x+((p0.y-height)/m);if(ix>0&&ix<width){p=new Point(ix,height);}else{return false;}}
+if(p1.x>width){iy=p1.y-m*(width-p1.x);if(iy>0&&iy<height){q=new Point(width,iy);}
+else if(iy<0){ix=p0.x+(p0.y/m);if(ix>0&&ix<width){q=new Point(ix,0);}else{return false;}}
+else if(iy>height){ix=p0.x+((p0.y-height)/m);if(ix>0&&ix<width){q=new Point(ix,height);}else{return false;}}
+else if(p1.y>=0&&p1.y<=height){q=p1;}
+else if(p1.y<0){ix=p1.x+(p1.y/m);if(ix>0&&ix<width){q=new Point(ix,0);}else{return false;}}
+else if(p1.y>height){ix=p1.x+((p1.y-height)/m);if(ix>0&&ix<width){q=new Point(ix,height);}else{return false;}}}
+else{if(!(p0.y<0&&p1.y<0)&&!(p0.y>height&&p1.y>height)){if(p0.y<0){p=new Point(p0.x,0);}
+else if(p0.y>height){p=new Point(p0.x,height);}
+else{p=p0;}
+if(p1.y<0){q=new Point(p0.x,0);}
+else if(p1.y>height){q=new Point(p0.x,height);}
+else{q=p1;}}
+return[new Point(Math.round(q.x),Math.round(q.y)),new Point(Math.round(p.x),Math.round(p.y))];}
+function objString(a){var z="";for(attr in a){var b=a[attr];if(typeof(b)=="object"){z+=objString(b);}
+else{z+=attr+" "+b+"\n";}}
+return z;}
\ No newline at end of file
Modified: tags/2.5_min/http/javascripts/geometry1.1.js
--- branches/2.5/http/javascripts/geometry1.1.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/geometry1.1.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,1125 +1,90 @@
-* $Id$
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-var Geometry = {
-	 * A static class representing geometry types.
-	Type : {
-		 * excludes Linear ring as it is no valid geometry itself
-		isValid : function (aGeometry) {
-			try {
-				if (aGeometry.getType() == this.point ||
-					aGeometry.getType() == this.line ||
-					aGeometry.getType() == this.polygon	||
-					aGeometry.getType() == this.multigeometry)
-					return true;
-			catch (e) {
-				var exc = new Mb_exception ("Geometry.Type.isValid: invalid geometry type for geometry: " + aGeometry + "; " + e);
-			return false;
-		isPoint : function (aGeometry) {
-			try {
-				if (aGeometry.getType() == this.point) {
-					return true;
-			catch (e) {
-				var exc = new Mb_exception ("Geometry.Type.isPoint: not a point: geometry: " + aGeometry + "; " + e);
-			return false;
-		isLine : function (aGeometry) {
-			try {
-				if (aGeometry.getType() == this.line) {
-					return true;
-			catch (e) {
-				var exc = new Mb_exception ("Geometry.Type.isLine: not a line: geometry: " + aGeometry + "; " + e);
-			return false;
-		isPolygon : function (aGeometry) {
-			try {
-				if (aGeometry.getType() == this.polygon) {
-					return true;
-			catch (e) {
-				var exc = new Mb_exception ("Geometry.Type.isPolygon: not a polygon: geometry: " + aGeometry + "; " + e);
-			return false;
-		isLinearRing : function (aGeometry) {
-			try {
-				if (aGeometry.getType() == this.linearring) {
-					return true;
-			catch (e) {
-				var exc = new Mb_exception ("Geometry.Type.isLinearRing: not a linear ring: geometry: " + aGeometry + "; " + e);
-			return false;
-		point : "point",
-		line : "line",
-		linearring : "linearring",
-		polygon : "polygon",
-		multigeometry : "multigeometry"
-	 * A class representing MultiGeometries. A MultiGeometry is a List containing
-	 * Point objects, Line objects, Polygon objects and MultiGeometry objects.
-	MultiGeometry : function () {
-		this.getType = function () {
-			return Geometry.Type.multipolygon;
-		this.push = function (aGeometry) {
-			if (Geometry.Type.isValid(aGeometry)) {
-				this.add(aGeometry);
-				this.get(-1).onEmpty.register(function () {
-					that.isEmpty();
-				return true;
-			return false;
-		this.pop = function () {
-			return this.remove(-1);
-		this.remove = function (index) {
-			// TODO: parameter might be a geometry
-			if (this.del(index)) {
-				this.isEmpty();
-				return true;
-			return false;
-		 * Checks if the multi geometry is empty. If yes, the event onEmpty is triggered.
-		this.isEmpty = function () {
-			if (this.count() === 0) {
-				this.onEmpty.trigger();
-				return true;
-			return false;
-		this.onEmpty = new MapbenderEvent();
-		// this class extends List
-		this.list = [];
-	 * A class representing lines. A line is a List of Point objects
-	Line : function () {
-			return Geometry.Type.line;
-		this.push = function (aPoint) {
-			if (Geometry.Type.isPoint(aPoint)) {
-				this.add(aPoint);
-					that.rearrangeList();
-				return true;
-			return false;
-			// TODO: parameter might be a point
-				return this.isEmpty();
-			return false;
-		 * remove all invalid points
-		this.rearrangeList = function () {
-			var listLength = this.count();
-			for (var i = 0; i < listLength; i++) {
-				if (!this.get(i).isSet()) {
-					this.remove(i);
-					i -= 1;
-					listLength -= 1;
-			if (this.count === 0) {
-				return true;
-			return false;
-		this.list = [];
-	 * A class representing a Polygon. A Polygon consists of an outer boundary (LinearRing)
-	 * and 0..n inner boundaries (InnerBoundaryArray).
-	Polygon : function () {
-			return Geometry.Type.polygon;
-		this.setOuterBoundary = function (aLinearRing) {
-			if (Geometry.Type.isLinearRing(aLinearRing)) {
-				outerBoundary = aLinearRing;
-				outerBoundary.onEmpty.register(function () {
-					that.isEmpty();
-				return true;
-			return false;
-		this.removeOuterBoundary = function () {
-			outerBoundary = null;
-			innerBoundaryArray = null;
-			return this.onEmpty.trigger();
-		this.appendInnerBoundary = function (aLinearRing) {
-			innerBoundaryArray.push(aLinearRing);
-		this.removeInnerBoundary = function (index) {
-			return innerBoundaryArray.remove(index);
-			if (!Geometry.Type.isLinearRing(outerBoundary)) {
-			return false;
-		var outerBoundary;
-		var innerBoundaryArray = new Geometry.InnerBoundaryArray();
-	 * An InnerBoundaryArray is a List of LinearRing objects.
-	InnerBoundaryArray : function () {
-		this.push = function (aLinearRing) {
-				return this.add(aLinearRing);
-			return false;
-			return this.del(index);
-		this.list = [];
-	 * A Linear Ring is a List of Point objects. The last Point and the first Point must be identical.
-	LinearRing : function () {
-			return Geometry.Type.linearring;
-				if (!this.isClosed()) {
-					this.add(aPoint);
-					// linear ring with at least 4 points (triangle!)
-					// AND
-					// last point equals first point
-					if (this.count() > 3 && this.get(0).equals(this.get(-1))) {
-						this.close();
-					return true;
-				else {
-					var e = new Mb_warning("Geometry.LinearRing: push: Cannot add point; linear ring is already closed!");
-			return false;
-			var i = this.getIndex(index);
-				// if the first or last point is being deleted,
-				// re-set the first or last point so that the
-				// ring remains closed
-				if (i === 0 || i === this.getIndex(-1)) {
-					// remove the first point (list is automatically shifted)
-					this.del(0);
-					// check if there are still points remaining
-					if (!this.isEmpty()) {
-						// add the new first point as the last point
-						this.list[this.count()-1] = this.list[0];
-					return true;
-				// if it is a point in the middle, just delete it (list is automatically shifted)
-				else {
-					return this.del(i);
-			return false;
-		 * Checks if the outer boundary is empty. If yes, the event onEmpty is triggered.
-				return true;
-			return false;
-					this.remove(i);
-					i -= 1;
-					listLength -= 1;
-		this.close = function () {
-			// AND
-				closed = true;
-				return closed;
-			// linear with at least 3 points (triangle!)
-			// AND
-			// last point DOESNT equal first point
-			else if (this.count() > 2 && !this.get(0).equals(this.get(-1))) {
-				var newPoint = new Geometry.Point(this.get(0).x, this.get(0).y);
-				// push will return to close to set closed to true
-				this.push(newPoint);
-			else {
-				var e = new Mb_warning("Geometry.LinearRing: close: cannot close linear ring, must have at least 3 points (triangle)");
-			return false;
-		this.isClosed = function () {
-			return closed;
-		 * if the first point and the last point match, and the ring has at least 4 points (triangle!)
-		 * closed is set to true via close
-		var closed = false;
-		this.list = [];
-	 * A Point consists of an x- and a y-coordinate.
-	Point : function () {
-			return Geometry.Type.point;
-		this.remove = function () {
-			onEmpty.trigger();
-			this.x = null;
-			this.y = null;
-			this.onEmpty = null;
-	 	 * x value of the {@link Point}
-		 * @type Float
-		this.x = parseFloat(x);
-	 	 * y value of the {@link Point}
-		 * @type Float
-		this.y = parseFloat(y);
-		this.isSet = function () {
-			return (this.x !== null && this.y !== null);
-Geometry.GeometryArray.prototype = new List();
-Geometry.MultiGeometry.prototype = new List();
-Geometry.InnerBoundary.prototype = new List();
-Geometry.LinearRing.prototype = new List();
-Geometry.Line.prototype = new List();
- * computes the distance between a {@link Point} p and this {@link Point}
- * @param {Point} p the distance between this {@link Point} and the {@link Point} p is computed.
- * @return {Float} the distance between the two {@link Point} objects.
-Geometry.Point.prototype.dist = function(p){
-	return Math.sqrt(Math.pow(this.y-p.y,2) + Math.pow(this.x-p.x,2)) ;
- * checks if the coordinates of this {@link Point} match the coordinates of a {@link Point} p
- * @return {Boolean} true if the two points are equal; elso false
-Geometry.Point.prototype.equals = function(p){
-	if (this.x == p.x && this.y == p.y) {return true;}
-	return false;
- * subtracts a {@link Point} p from this {@link Point}
- * @return a new {@link Point} with the difference of the two points
-Geometry.Point.prototype.minus = function(p){
-	return new Point(this.x-p.x, this.y-p.y);
- * adds this {@link Point} to a {@link Point} p
- * @return a new {@link Point} with the sum of the two points
-Geometry.Point.prototype.plus = function(p){
-	return new Point(this.x+p.x, this.y+p.y);
- * divides this {@link Point} by a scalar c
- * @param {Float} c divisor
- * @return a new {@link Point} divided by c
-Geometry.Point.prototype.dividedBy = function(c){
-	if (c !== 0) {
-		return new Point(this.x/c, this.y/c);
-	var e = new Mb_exception("Point.dividedBy: Division by zero");
-	return false;
- * multiplies this {@link Point} by a scalar c
- * @param {Float} c factor
- * @return a new {@link Point} multiplied by c
-Geometry.Point.prototype.times = function(c){
-	return new Point(this.x*c, this.y*c);
- * rounds the coordinates to numOfDigits digits
- * @param numOfDigits the coordinate will be rounded to numOfDigits digits
- * @return a new {@link Point} rounded to numOfDigits digits
- * @type Point
-Geometry.Point.prototype.round = function(numOfDigits){
-	return new Point(roundToDigits(this.x, numOfDigits), roundToDigits(this.y, numOfDigits));
- * @returns a {String} representation of this Point
- * @type String
-Geometry.Point.prototype.toString = function(){
-	return "(" + this.x + ", " + this.y + ")";
- * @ constructor
-	 * @type Integer
-	 * @param {Integer} i index
-	 * @type String
-		return false;
-		return false;
-		name[i] = aName;
-	 * @private
-	 * @type Boolean
-		return false;
-	var name  = [];
-	var value = [];
-	for (var j = 0 ; j < this.count() ; j++){
-	return false;
- * @constructor
-	 * @private
-		width = mb_mapObj[mapObjInd].width;
-		height = mb_mapObj[mapObjInd].height;
-		for(var i=0; i < g.count(); i++){
-			if(t==geomType.point) {
-				var p = realToMap(mapframe,g.get(i).get(0));
-				if (p.x + diameter < mb_mapObj[mapObjInd].width && p.x - diameter > 0 &&
-					p.y + diameter < mb_mapObj[mapObjInd].height && p.y - diameter > 0) {
-					drawCircle(p.x-1, p.y-1, diameter,col);
-			else if(t==geomType.line || t==geomType.polygon) {
-				for (var j=0; j<g.get(i).count()-1; j++) {
-					var pq = calculateVisibleDash(realToMap(mapframe,g.get(i).get(j)), realToMap(mapframe,g.get(i).get(j+1)), width, height);
-					if (pq) {
-			else {
-	 * @private
-			return true;
-		return false;
-	 * @private
-		return canvas;
-	 * @private
-	 * @private
-	 * @type DivTag
-	var that = this;
-	var diameter = 8;
-	var minWidth = 8;
-		else {
-			else{
-				else {
- * @constructor
-		var del = false;
-				gA.del(a[i]);
-				del = true;
-		this.paint();
-		gA.addCopy(m);
-		this.paint();
-			this.paint();
-	var canvas = [];
-	this.paint();
-// Snapping
- * @constructor
-		mG.addGeometry();
-		highlight.add(mG);
-		return tolerance;
-		return target;
-		return coord[i];
-		coord = [];
-		return false;
-		min_i = i;
-		min_i = -1;
-	 * @private
-	 * @private
-	 * @private
-	var coord = [];
-	 * @private
-	var min_i = -1;
-	 * @private
-	 * @private
-	 * @private
-	 * @private
- *                      move. Optional.
-				else {
-		else {
- * @type Boolean
-	return false;
- * @type Point
-// misc. functions
- * @ignore
-			if (p0.x < 0) {
-	else {
-			else {p = p0;}
-			else {q = p1;}
- * @ignore
-	var z = "";
-	for (attr in a) {
-		var b = a[attr];
-		else {z += attr + " " + b + "\n";alert(attr + " " + b);}
-	return z;
+var Geometry={Type:{isValid:function(aGeometry){try{if(aGeometry.getType()==this.point||aGeometry.getType()==this.line||aGeometry.getType()==this.polygon||aGeometry.getType()==this.multigeometry)
+{return true;}}
+catch(e){var exc=new Mb_exception("Geometry.Type.isValid: invalid geometry type for geometry: "+aGeometry+"; "+e);}
+return false;},isPoint:function(aGeometry){try{if(aGeometry.getType()==this.point){return true;}}
+catch(e){var exc=new Mb_exception("Geometry.Type.isPoint: not a point: geometry: "+aGeometry+"; "+e);}
+return false;},isLine:function(aGeometry){try{if(aGeometry.getType()==this.line){return true;}}
+catch(e){var exc=new Mb_exception("Geometry.Type.isLine: not a line: geometry: "+aGeometry+"; "+e);}
+return false;},isPolygon:function(aGeometry){try{if(aGeometry.getType()==this.polygon){return true;}}
+catch(e){var exc=new Mb_exception("Geometry.Type.isPolygon: not a polygon: geometry: "+aGeometry+"; "+e);}
+return false;},isLinearRing:function(aGeometry){try{if(aGeometry.getType()==this.linearring){return true;}}
+catch(e){var exc=new Mb_exception("Geometry.Type.isLinearRing: not a linear ring: geometry: "+aGeometry+"; "+e);}
+return false;},point:"point",line:"line",linearring:"linearring",polygon:"polygon",multigeometry:"multigeometry"},MultiGeometry:function(){this.getType=function(){return Geometry.Type.multipolygon;};this.push=function(aGeometry){if(Geometry.Type.isValid(aGeometry)){this.add(aGeometry);this.get(-1).onEmpty.register(function(){that.isEmpty();});return true;}
+return false;};this.pop=function(){return this.remove(-1);};this.remove=function(index){if(this.del(index)){this.isEmpty();return true;}
+return false;};this.isEmpty=function(){if(this.count()===0){this.onEmpty.trigger();return true;}
+return false;};this.onEmpty=new MapbenderEvent();this.list=[];},Line:function(){this.getType=function(){return Geometry.Type.line;};this.push=function(aPoint){if(Geometry.Type.isPoint(aPoint)){this.add(aPoint);this.get(-1).onEmpty.register(function(){that.rearrangeList();});return true;}
+return false;};this.remove=function(index){if(this.del(index)){return this.isEmpty();}
+return false;};this.rearrangeList=function(){var listLength=this.count();for(var i=0;i<listLength;i++){if(!this.get(i).isSet()){this.remove(i);i-=1;listLength-=1;}}};this.isEmpty=function(){if(this.count===0){this.onEmpty.trigger();return true;}
+return false;};this.onEmpty=new MapbenderEvent();this.list=[];},Polygon:function(){this.getType=function(){return Geometry.Type.polygon;};this.setOuterBoundary=function(aLinearRing){if(Geometry.Type.isLinearRing(aLinearRing)){outerBoundary=aLinearRing;outerBoundary.onEmpty.register(function(){that.isEmpty();});return true;}
+return false;};this.removeOuterBoundary=function(){outerBoundary=null;innerBoundaryArray=null;return this.onEmpty.trigger();};this.appendInnerBoundary=function(aLinearRing){innerBoundaryArray.push(aLinearRing);};this.removeInnerBoundary=function(index){return innerBoundaryArray.remove(index);};this.isEmpty=function(){if(!Geometry.Type.isLinearRing(outerBoundary)){return this.onEmpty.trigger();}
+return false;};var outerBoundary;var innerBoundaryArray=new Geometry.InnerBoundaryArray();},InnerBoundaryArray:function(){this.push=function(aLinearRing){if(Geometry.Type.isLinearRing(aLinearRing)){return this.add(aLinearRing);}
+return false;};this.remove=function(index){return this.del(index);};this.onEmpty=new MapbenderEvent();this.list=[];},LinearRing:function(){this.getType=function(){return Geometry.Type.linearring;};this.push=function(aPoint){if(Geometry.Type.isPoint(aPoint)){if(!this.isClosed()){this.add(aPoint);if(this.count()>3&&this.get(0).equals(this.get(-1))){this.close();}
+this.get(-1).onEmpty.register(function(){that.rearrangeList();});return true;}
+else{var e=new Mb_warning("Geometry.LinearRing: push: Cannot add point; linear ring is already closed!");}}
+return false;};this.remove=function(index){var i=this.getIndex(index);if(i!==false){if(i===0||i===this.getIndex(-1)){this.del(0);if(!this.isEmpty()){this.list[this.count()-1]=this.list[0];}
+return true;}
+else{return this.del(i);}}
+return false;};this.rearrangeList=function(){var listLength=this.count();for(var i=0;i<listLength;i++){if(!this.get(i).isSet()){this.remove(i);i-=1;listLength-=1;}}};this.close=function(){if(this.count()>3&&this.get(0).equals(this.get(-1))){closed=true;return closed;}
+else if(this.count()>2&&!this.get(0).equals(this.get(-1))){var newPoint=new Geometry.Point(this.get(0).x,this.get(0).y);this.push(newPoint);}
+else{var e=new Mb_warning("Geometry.LinearRing: close: cannot close linear ring, must have at least 3 points (triangle)");}
+return false;};this.isClosed=function(){return closed;};this.onEmpty=new MapbenderEvent();var closed=false;this.list=[];},Point:function(){this.getType=function(){return Geometry.Type.point;};this.remove=function(){onEmpty.trigger();this.x=null;this.y=null;this.onEmpty=null;};this.x=parseFloat(x);this.y=parseFloat(y);this.isSet=function(){return(this.x!==null&&this.y!==null);};this.onEmpty=new MapbenderEvent();}};Geometry.GeometryArray.prototype=new List();Geometry.MultiGeometry.prototype=new List();Geometry.InnerBoundary.prototype=new List();Geometry.LinearRing.prototype=new List();Geometry.Line.prototype=new List();Geometry.Point.prototype.dist=function(p){return Math.sqrt(Math.pow(this.y-p.y,2)+Math.pow(this.x-p.x,2));};Geometry.Point.prototype.equals=function(p){if(this.x==p.x&&this.y==p.y){return true;}
+return false;};Geometry.Point.prototype.minus=function(p){return new Point(this.x-p.x,this.y-p.y);};Geometry.Point.prototype.plus=function(p){return new Point(this.x+p.x,this.y+p.y);};Geometry.Point.prototype.dividedBy=function(c){if(c!==0){return new Point(this.x/c,this.y/c);}
+var e=new Mb_exception("Point.dividedBy: Division by zero");return false;};Geometry.Point.prototype.times=function(c){return new Point(this.x*c,this.y*c);};Geometry.Point.prototype.round=function(numOfDigits){return new Point(roundToDigits(this.x,numOfDigits),roundToDigits(this.y,numOfDigits));};Geometry.Point.prototype.toString=function(){return"("+this.x+", "+this.y+")";};function Wfs_element(){this.count=function(){return name.length;};this.getName=function(i){if(isValidElementIndex(i)){return name[i];}
+name[i]=aName;value[i]=aValue;};var isValidElementIndex=function(i){if(i>=0&&i<name.length){return true;}
+Wfs_element.prototype.getElementIndexByName=function(elementName){for(var j=0;j<this.count();j++){if(this.getName(j)==elementName){return j;}}
+return this.getValue(i);};function Canvas(aMapframe,aTagName,aStyle,aLineWidth){this.drawGeometry=function(t,g,col){var mapObjInd=getMapObjIndexByName(mapframe);width=mb_mapObj[mapObjInd].width;height=mb_mapObj[mapObjInd].height;for(var i=0;i<g.count();i++){if(t==geomType.point){var p=realToMap(mapframe,g.get(i).get(0));if(p.x+diameter<mb_mapObj[mapObjInd].width&&p.x-diameter>0&&p.y+diameter<mb_mapObj[mapObjInd].height&&p.y-diameter>0){drawCircle(p.x-1,p.y-1,diameter,col);}}
+else if(t==geomType.line||t==geomType.polygon){for(var j=0;j<g.get(i).count()-1;j++){var pq=calculateVisibleDash(realToMap(mapframe,g.get(i).get(j)),realToMap(mapframe,g.get(i).get(j+1)),width,height);if(pq){drawLine([pq[0].x-1,pq[1].x-1],[pq[0].y-1,pq[1].y-1],col);}}}
+else{var e=new Mb_exception("class Canvas: function drawGeometry: unknown geomType "+t);}}};this.isTooSmall=function(g){var tmp=g.getBBox();var min=realToMap(mapframe,tmp[0]);var max=realToMap(mapframe,tmp[1]);if((Math.abs(max.x-min.x)<minWidth)&&(Math.abs(max.y-min.y)<minWidth)){return true;}
+return false;};this.getCanvas=function(){return canvas;};var drawCircle=function(x,y,diameter,color){canvas.setColor(color);canvas.drawEllipse(x-diameter/2,y-diameter/2,diameter,diameter);};var drawLine=function(x_array,y_array,color){canvas.setColor(color);canvas.drawPolyline(x_array,y_array);};this.canvasDivTag=new DivTag(aTagName,aMapframe,aStyle);var that=this;var diameter=8;var minWidth=8;var lineWidth=aLineWidth;var mapframe=aMapframe;var style=aStyle;var canvas=new jsGraphics(aTagName,window.frames[mapframe]);canvas.setStroke(lineWidth);mb_registerPanSubElement(aTagName);}
+this.paint();};this.add=function(m,color){gA.addCopy(m);if(typeof(color)!='undefined'){gA.get(-1).color=color;}
+this.paint();};this.clean=function(){if(gA.count()>0){gA=new GeometryArray();this.paint();}};this.paint=function(){for(var i=0;i<canvas.length;i++){if(typeof(canvas[i])=="object"){canvas[i].clean();}}
+canvas[i].paint(gA);}};var lineWidth=aLineWidth;var tagname='mod_gaz_draw'+aTagName;var style=aStyle;var targets=aTargetArray;var canvas=[];var gA=new GeometryArray();var lineColor="#ff0000";this.paint();}
+function Snapping(aTarget,aTolerance,aColor,aZIndex){this.draw=function(center,radius){mG=new MultiGeometry(geomType.point);mG.addGeometry();mG.get(-1).addPoint(center);highlight.add(mG);};this.getTolerance=function(){return tolerance;};this.getTarget=function(){return target;};this.cleanHighlight=function(){return highlight.clean();};this.addPoint=function(aPoint){coord.push(aPoint);};this.getPointCount=function(){return coord.length;};this.getPoint=function(i){return coord[i];};this.resetPoints=function(){coord=[];};this.getNearestNeighbour=function(){if(min_i!=-1){return this.getPoint(min_i);}
+return false;};this.setIndexOfNearestNeighbour=function(i){min_i=i;};this.resetIndexOfNearestNeighbour=function(){min_i=-1;};var tolerance=(typeof(aTolerance)=='undefined')?10:aTolerance;var zIndex=(typeof(aZIndex)=='undefined')?50:aZIndex;var coord=[];var min_i=-1;var target=aTarget;var lineWidth=2;var style={"position":"absolute","top":"0px","left":"0px","z-index":zIndex};var highlight=new Highlight([target],"snapping"+Math.round(Math.random()*Math.pow(10,10)),style,lineWidth);}
+else{p=p0;}
+else{q=p1;}}
+else{z+=attr+" "+b+"\n";alert(attr+" "+b);}}
+return z;}
Modified: tags/2.5_min/http/javascripts/jsTree.js
--- branches/2.5/http/javascripts/jsTree.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/jsTree.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,697 +1,253 @@
-# $Id$
-*  http://www.mapbender.org/index.php/Mod_treefolder2.php
-*  Copyright notice
-*  (c) 2003-2004 Tobias Bender (tobias at phpXplorer.org)
-*  All rights reserved
-*  This script is part of the jsTree project. The jsTree project is
-*  free software; you can redistribute it and/or modify
-*  it under the terms of the GNU General Public License as published by
-*  the Free Software Foundation; either version 2 of the License, or
-*  (at your option) any later version.
-*  The GNU General Public License can be found at
-*  http://www.gnu.org/copyleft/gpl.html.
-*  A copy is found in the textfile GPL.txt distributed with these scripts.
-*  This script is distributed in the hope that it will be useful,
-*  but WITHOUT ANY WARRANTY; without even the implied warranty of
-*  MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
-*  GNU General Public License for more details.
-*  This copyright notice MUST APPEAR in all copies of the script!
-var jst_cm
-var jst_cmT
-var jst_activeNode
-var jst_reload_strData = ""
-var jst_reload_ctlImage
-var jst_reload_halt = false
-var jst_any_expanded
-var jst_expandAll_int
-var jst_loaded = false
-var jst_state_paths = new Array()
-var jst_delimiter = ["|", "<|>"]
-var jst_id = "jsTree"
-var jst_container = "document.body"
-var jst_data = "arrNodes"
-var jst_expandAll_warning = "Expanding all nodes can take a while depending on your hardware! Continue?"
-var jst_target
-var jst_context_menu
-var jst_display_root = true
-var jst_highlight = true
-var jst_highlight_color = "white"
-var jst_highlight_bg = "navy"
-var jst_highlight_padding = "1px"
-var jst_image_folder = "./images"
-var jst_reloading = false
-var jst_reload_frame = "reLoader"
-var jst_reload_script = "tree_jsTree_reload.php"
-var jst_reloading_status = "loading tree nodes ..."
-function absTop(nd){
-	return nd.offsetParent ? nd.offsetTop + absTop(nd.offsetParent) : nd.offsetTop
-function nodeClick(nd){
-	if(jst_highlight){
-		if(jst_activeNode){
-			jst_activeNode.style.color = ""
-			jst_activeNode.style.backgroundColor = ""
-			nd.style.padding = ""
-		nd.style.color = jst_highlight_color
-		nd.style.backgroundColor = jst_highlight_bg
-		nd.style.padding = jst_highlight_padding
-		jst_activeNode = nd
-//	if(childExists(nd.parentNode.parentNode))
-//		window.scrollTo(0, absTop(nd) - 5)
-function _getDefinition(data, depth){
-	var d = new Array()
-	if(!data)
-		return ""
-	var sD = ""
-	for(var i = 0; i < depth; i++)
-		sD += '\t'
-	if(data != eval(jst_data))
-		d.push(",")
-	d.push("\n" + sD + "[")
-	var nodes = new Array()
-	for(var n1 in data){
-		var infos = new Array()
-		for(var i = 0; i < 5; i++)
-			infos.push(data[n1][1][i] ? "'" + data[n1][1][i].replace(/\n/g, '\\' + 'n') + "'" : null)
-		infos.push(null);
-		if(data[n1][1][6]){
-			infos.push("'"+data[n1][1][6]+"'");
-//TODO checked and disabled state
-		}else{
-			infos.push(null);
-		for(var i = 6; i > 0; i--)
-			if(!infos[i]){
-				infos.pop()
-			}else{
-				break
-		nodes.push("\n" + sD + "\t['" + data[n1][0].replace(/\'/g, '\\' + "'") + "', [" + infos.join(",") + "]" + _getDefinition(data[n1][2], depth + 1) + "]")
-	d.push(nodes.join(",") + "\n" + sD + "]")
-	return d.join("")
-function getDefinition(){
-	return jst_data + "=" + _getDefinition(eval(jst_data), 0)
-function getDomNode(path){
-	var parts = path.split(jst_delimiter[0]);
-	var tr = document.getElementById(parts[parts.length-1]);
-	if(tr)
-		return tr;
-	var tBody = get1stTBody()
-	for(var p = 0; p < parts.length; p++){
-		for(var c = 0; c < tBody.childNodes.length; c++){
-			var tr = tBody.childNodes[c]
-			if(tr.id == parts[p]){
-				if(p == parts.length - 1){
-					return tr
-				}else{
-					if(!childExists(tr))
-						return null;
-					tBody = tBody.childNodes[c + 1].childNodes[1].firstChild.firstChild
-					if(!tBody)
-						return null
-				break
-	return null
-function delArrItem(a, p){
-	var b = a.slice(0, p)
-	var e = a.slice(p + 1)
-	return b.concat(e)
-function addArrItem(a, p, v){
-	var e=a.slice(p)
-	b[b.length] = v
-function _editDataNode(action, path, nd){
-	var ps = jst_data
-		var arrData = eval(ps)
-	  for(var d = 0; d < arrData.length; d++)
-			if(parts[p] == arrData[d][0]){
-					switch(action){
-						case "d":
-							if(ps != jst_data)
-								eval(ps + "=delArrItem(" + ps + "," + d + ")")
-						break;
-						case "a":
-							if(!eval(ps)[d][2])
-								eval(ps)[d].push(new Array())
-							eval(ps)[d][2].push(nd)
-						break;
-						case "u":
-							eval(ps)[d][2].unshift(nd)
-						break;
-					return true
-				}else{
-					ps = ps + "[" + d + "][2]"
-				break
-	return false
-function addNode(path, nd, sel, refresh, begining){
-	if(_editDataNode((begining?"u":"a"), path, nd)){
-		if(refresh){
-			rebuildNode(path, true)
-			rebuildNode(path)
-		if(sel)
-			nodeClick(getDomNode(path + jst_delimiter[0] + nd[0]).childNodes[1].childNodes[1])
-function deleteNode(path){
-	if(_editDataNode("d", path))
-function _getState(tBody, path){
-	var hasSub = false
-		if(childExists(tr) && isExpanded(tr)){
-			_getState(tBody.childNodes[c + 1].childNodes[1].firstChild.firstChild, path + (path != "" ? jst_delimiter[0] : "") + tr.id)
-			hasSub = true
-	if(!hasSub)
-		jst_state_paths.push(path)
-function getState(){
-	jst_state_paths = new Array()
-	_getState(get1stTBody(), "")
-	return jst_state_paths.join(jst_delimiter[1])
-function setState(data){
-	jst_state_paths = data.split(jst_delimiter[1])
-	for(var p in jst_state_paths){
-		var path="";
-		var pathElements = jst_state_paths[p].split(jst_delimiter[0]);
-		for(i in pathElements){
-			path += pathElements[i];
-			var tr = getDomNode(path)
-			if(tr){
-				var f1 = tr.firstChild
-				if(f1){
-					var f2 = f1.firstChild
-					if(!isExpanded(tr) && f2)
-						if(f2.onclick)
-							f2.onclick()
-			path+=jst_delimiter[0];
-function rebuildNode(path, parent){
-	if(parent){
-		var arrPath = path.split(jst_delimiter[0])
-		arrPath.pop()
-		path = arrPath.join(jst_delimiter[0])
-	if(path.split(jst_delimiter[0]).length<=1){
-		renderTree()
-	}else{
-		var nd = getDomNode(path)
-		if(nd){
-			var nn = nd.nextSibling
-			if(nn){
-				var nCh = nn.childNodes[1].firstChild
-				if(nCh.nodeName == "TABLE")
-					nd.parentNode.parentNode.deleteRow(nn.rowIndex)
-			if(nd.firstChild.firstChild.onclick)
-				nd.firstChild.firstChild.onclick()
-function setNodeColor(path, color){
-	if(nd){
-		nd.childNodes[1].childNodes[nd.childNodes[1].childNodes.length-1].style.color=color;
-function setNodeImage(path, Img){
-	var ps = jst_data;
-	var arrData = null;
-		arrData = eval(ps);
-		for(var d = 0; d < arrData.length; d++){
-					eval(ps)[d][1][3]=Img;
-					var nd = getDomNode(path);
-					if(nd){
-						var cb = nd.childNodes[1].childNodes[0];
-						if(cb && cb.nodeName=="IMG"){
-							if(Img)
-								cb.src=jst_image_folder+"/"+Img;
-							else if(eval(ps)[d][2]){
-								if(childExists(nd)){
-									var s = nd.nextSibling.style
-									if(s.display == ""){
-										cb.src = jst_image_folder + "/expanded_folder.png";
-									}else{
-										cb.src = jst_image_folder + "/closed_folder.png";
-								}else{
-							else
-								rebuildNode(path, true);
-						else
-					return true
-				}else{
-				break;
-	return false
-function selectNode(path){
-	if(nd){
-		nodeClick(nd.childNodes[1].childNodes[nd.childNodes[1].childNodes.length-1])
-		return true
-	}else{
-		return false
-function IsChecked(path, ctrlNr){
-	if(nd){
-		var fc = nd.childNodes[1].firstChild;
-		if(fc && fc.nodeName=="IMG")ctrlNr++;
-		var cb = nd.childNodes[1].childNodes[ctrlNr];
-		if(cb && cb.nodeName=="INPUT"){
-			return cb.checked;
-	return false;
-//getChildrenCheckState returns:
-//	1:if each child with checkbox ctrlNr is checked
-//	0:if none is checked
-// -1:if states are different or ctrlNr is no checkbox or any other error
-function getChildrenCheckState(path, ctrlNr){
-	var state = -1;
-	var plus=0;
-	if(!nd)return -1;
-	if(!childExists(nd))return -1;
-	var tBody = nd.nextSibling.childNodes[1].firstChild.firstChild;
-	if(!tBody)return -1;
-	for(var i = 0;i < tBody.childNodes.length; i++){
-		var fc = tBody.childNodes[i].childNodes[1].firstChild;
-		plus=0;
-		if(fc && fc.nodeName=="IMG")plus++;
-		var cb = tBody.childNodes[i].childNodes[1].childNodes[ctrlNr+plus];
-			if(state == -1)
-				state = cb.checked?1:0;
-			else{
-				if(state != cb.checked?1:0)
-					return -1;
-	return state;
-function checkChildren(path, ctrlNr, bChk){
-	var plus;
-	if(!nd)return false;
-	if(!childExists(nd))return false;
-	if(!tBody)return false;
-		plus=0;
-		if(cb && cb.nodeName=="INPUT"&&!cb.disabled){
-			cb.checked = bChk;
-			if(cb.onclick){cb.onclick();}
-	return true;
-function checkNode(path, ctrlNr, bChk){
-	if(nd){
-			if(cb.onclick)cb.onclick();
-//TODO DataNode anpassen
-			return true;
-	return false;
-function enableCheckbox(path, ctrlNr, pEnabled){
-	if(nd){
-			cb.disabled = !pEnabled;
-			return true;
-	return false;
-function get1stTBody(){
-	return eval(jst_container).firstChild.firstChild.childNodes[1].childNodes[1].firstChild.firstChild
-function __switchAll(tBody, expand){
-	if(!tBody)
-		return false
-		var img = tr.firstChild.firstChild
-		if(img)
-			if(img.onclick){
-				if((expand && !childExists(tr)) || ((expand && !isExpanded(tr)) || (!expand && isExpanded(tr)))){
-					if(img.id != "rootImage")
-						img.onclick()
-					jst_any_expanded = true
-				if(tBody.childNodes[c + 1])
-					__switchAll(tBody.childNodes[c + 1].childNodes[1].firstChild.firstChild, expand)
-function _switchAll(expand){
-	if(jst_reload_halt)
-		return
-	__switchAll(get1stTBody(), expand)
-	if(jst_reloading){
-		if(!jst_any_expanded)
-			cancelExpandAll()
-		jst_any_expanded = null
-function expandAll(){
-	if(jst_expandAll_warning ? confirm(jst_expandAll_warning) : true)
-			jst_expandAll_int = window.setInterval("if(!jst_reload_halt)_switchAll(true)", 100)
-		}else{
-			_switchAll(true)
-function cancelExpandAll(){
-	if(jst_expandAll_int)
-		window.clearInterval(jst_expandAll_int)
-function closeAll(){
-	_switchAll(false)
-function isExpanded(tr){
-	return childExists(tr) ? tr.nextSibling.style.display != "none" : false
-function childExists(tr){
-	try{
-		return tr.nextSibling.childNodes[1].firstChild.nodeName == "TABLE"
-	}catch(e){
-		return false
-function getPath(strData){
-	if(strData.indexOf("[") > 0){
-		var sub3 = strData.substr(0, strData.lastIndexOf("["))
-		var sub6 = sub3.substr(0, sub3.lastIndexOf("["))
-		return (getPath(sub6) != "" ? getPath(sub6) + jst_delimiter[0] : "") + eval(sub3 + "[0]")
-	}else{
-		return ""
-function reloadCallback(){
-	eval(jst_reload_strData + "=window.frames['" + jst_reload_frame + "']." + jst_data)
-	renderNode(jst_reload_strData, jst_reload_ctlImage, null, true)
-	window.status = ""
-	jst_reload_halt = false
-	jst_reload_strData = ""
-	jst_reload_ctlImage = null
-function renderNode(strData, ctlImg, event, reload){
-	if(event)
-		event.cancelBubble = true
-	if(jst_reload_halt && !reload)
-		return
-	jst_loaded = false
-	if(jst_reloading && !reload && eval(strData).length == 0){
-		jst_reload_strData = strData
-		jst_reload_ctlImage = ctlImg
-		jst_reload_halt = true
-		if(jst_reloading_status)
-			window.status = jst_reloading_status
-		window.frames[jst_reload_frame].document.location.href = "./" + jst_reload_script + (jst_reload_script.indexOf("?") > -1 ? "&" : "?") + "path=" + getPath(strData)
-		return
-	var tr = ctlImg.parentNode.parentNode
-	if(ctlImg.id != "rootFolder"){
-		var fldImg = tr.childNodes[1].firstChild
-		if(childExists(tr)){
-			var s = tr.nextSibling.style
-			var img1 = jst_image_folder + "/" + (tr.nextSibling.nextSibling ? "" : "last_")
-				s.display = "none"
-				ctlImg.src = img1 + "closed.png"
-				if(eval(strData.substr(0, strData.length-3)+"[1][3]"))
-					fldImg.src = jst_image_folder + "/" + eval(strData.substr(0, strData.length-3)+"[1][3]");
-				else
-					fldImg.src = jst_image_folder + "/closed_folder.png";
-			}else{
-				s.display = ""
-				ctlImg.src = img1 + "expanded.png"
-				else
-					fldImg.src = jst_image_folder + "/expanded_folder.png";
-			return
-		}else{
-			ctlImg.src = jst_image_folder + "/" + (tr.nextSibling ? "" : "last_") + "closed.png"
-			else
-	var newTr = tr.parentNode.insertRow((tr.rowIndex?tr.rowIndex:0) + 1)
-		newTr.style.display = "none";
-	newTr.appendChild(document.createElement('td'))
-	if(newTr.nextSibling)
-		newTr.firstChild.setAttribute("background", jst_image_folder + "/branch.png", "false")
-	newTr.childNodes[1].innerHTML = renderChildren(strData)
-	var nodes = eval(strData)
-	var ndWithChildren = 0;
-	for(var n in nodes){
-		var n0 = nodes[n]
-		var n1 = n0[2]
-		if(n1){
-			renderNode(strData + "[" + n + "][2]" ,newTr.childNodes[1].firstChild.firstChild.childNodes[parseInt(n)+ndWithChildren].firstChild.firstChild);
-			ndWithChildren++;
-	jst_loaded = true
-function renderChildren(strData, tblCls, menu){
-	var code = Array()
-	code.push('<table cellspacing="0" cellpadding="0" border="0" class="' + tblCls + '">')
-		var n0 = nodes[n]
-		var n1 = n0[2]
-		code.push('<tr id="' + n0[0] + '"><td><img' + (strData == jst_data ? ' style="display:none" id="rootImage"' : '') + ' src="' + jst_image_folder + '/')
-		if(n1){
-			code.push((n == nodes.length - 1 ? "last_closed" : "closed") + '.png" onClick="renderNode(' + "'" + strData + "[" + n + "][2]" + "'" + ',this,event)" class="action"')
-		}else{
-			code.push((n == nodes.length - 1 ? "last_leaf" : "leaf") + '.png"')
-		if(jst_context_menu && !n0[1][5] && !menu)
-			n0[1][5] = jst_context_menu
-		code.push(' alt=""></td><td nowrap>'+((n1||n0[1][3])?'<img'  + (((strData == jst_data)&&!jst_display_root) ? ' style="display:none"' : '') +  (n0[1][5] ? ' class="action" onClick="showMenu(\'' + strData + '[' + n + ']\', this, event)"' : '') + ' src="' + jst_image_folder + '/' + (n1 ? (n0[1][3]?n0[1][3]:"closed_folder.png") : n0[1][3] ? n0[1][3] : "node.png") + '" alt="">':'')+((n0[1][6]&&((strData != jst_data)||jst_display_root))?n0[1][6]:'')+'<a class="node"'  + (((strData == jst_data)&&!jst_display_root) ? ' style="display:none"' : '')+ (n0[1][4] ? ' title="' + n0[1][4] + '"' : '') + ' onClick="nodeClick(this)" href=' + "'" + (menu ? String(n0[1][1]).replace(/{@strData}/g, strData) : n0[1][1] ) + "'" + (n0[1][2] ? ' target="' + n0[1][2] + '"' : jst_target ? ' target="' + jst_target + '"' : '') + '>' + n0[1][0]  + '</a></td></tr>')
-	code.push('</table>')
-	return code.join("")
-function showMenu(strData, img, event){
-	var o = window.pageYOffset
-	var offY = o ? o : document.body.scrollTop
-	var offX = o ? window.pageXOffset : document.body.scrollLeft
-	jst_cm.innerHTML = renderChildren(strData + "[1][5]", "menu", true)
-	jst_cm.style.top = offY + event.clientY
-	jst_cm.style.left = offX + event.clientX
-	jst_cm.style.visibility = ""
-function hideMenu(){
-	jst_cm.style.visibility = "hidden"
-function renderTree(){
-//	TestDate = new Date();TestStartZeit=TestDate.getTime();
-	eval(jst_container).innerHTML = '<table cellspacing="0" cellpadding="0" border="0"><tr id="'+eval(jst_data + "[0][0]")+'"><td colspan="2"><span id="rootFolder"></span></td></tr></table><div style="position:absolute;top:-100;left:-100" id="contextMenu"></div>'
-	renderNode(jst_data, document.getElementById("rootFolder"))
-	renderNode(jst_data + "[0][2]", document.getElementById("rootImage"))
-	jst_cm = document.getElementById("contextMenu")
-	document.body.onclick = hideMenu
-	jst_loaded = true
-//	TestDate=new Date();TestStopZeit=TestDate.getTime();alert(TestStopZeit-TestStartZeit);
+var jst_cm
+var jst_cmT
+var jst_activeNode
+var jst_reload_strData=""
+var jst_reload_ctlImage
+var jst_reload_halt=false
+var jst_any_expanded
+var jst_expandAll_int
+var jst_loaded=false
+var jst_state_paths=new Array()
+var jst_delimiter=["|","<|>"]
+var jst_id="jsTree"
+var jst_container="document.body"
+var jst_data="arrNodes"
+var jst_expandAll_warning="Expanding all nodes can take a while depending on your hardware! Continue?"
+var jst_target
+var jst_context_menu
+var jst_display_root=true
+var jst_highlight=true
+var jst_highlight_color="white"
+var jst_highlight_bg="navy"
+var jst_highlight_padding="1px"
+var jst_image_folder="./images"
+var jst_reloading=false
+var jst_reload_frame="reLoader"
+var jst_reload_script="tree_jsTree_reload.php"
+var jst_reloading_status="loading tree nodes ..."
+function absTop(nd){return nd.offsetParent?nd.offsetTop+absTop(nd.offsetParent):nd.offsetTop}
+function nodeClick(nd){if(jst_highlight){if(jst_activeNode){jst_activeNode.style.color=""
+jst_activeNode.style.backgroundColor=""
+nd.style.padding=""}
+nd.style.color=jst_highlight_color
+nd.style.backgroundColor=jst_highlight_bg
+nd.style.padding=jst_highlight_padding
+jst_activeNode=nd}}
+function _getDefinition(data,depth){var d=new Array()
+if(!data)
+return""
+var sD=""
+for(var i=0;i<depth;i++)
+sD+='\t'
+if(data!=eval(jst_data))
+d.push(",")
+d.push("\n"+sD+"[")
+var nodes=new Array()
+for(var n1 in data){var infos=new Array()
+for(var i=0;i<5;i++)
+infos.push(data[n1][1][i]?"'"+data[n1][1][i].replace(/\n/g,'\\'+'n')+"'":null)
+infos.push(null);if(data[n1][1][6]){infos.push("'"+data[n1][1][6]+"'");}else{infos.push(null);}
+for(var i=6;i>0;i--)
+if(!infos[i]){infos.pop()}else{break}
+nodes.push("\n"+sD+"\t['"+data[n1][0].replace(/\'/g,'\\'+"'")+"', ["+infos.join(",")+"]"+_getDefinition(data[n1][2],depth+1)+"]")}
+d.push(nodes.join(",")+"\n"+sD+"]")
+return d.join("")}
+function getDefinition(){return jst_data+"="+_getDefinition(eval(jst_data),0)}
+function getDomNode(path){var parts=path.split(jst_delimiter[0]);var tr=document.getElementById(parts[parts.length-1]);if(tr)
+return tr;var tBody=get1stTBody()
+for(var p=0;p<parts.length;p++){for(var c=0;c<tBody.childNodes.length;c++){var tr=tBody.childNodes[c]
+if(tr.id==parts[p]){if(p==parts.length-1){return tr}else{if(!childExists(tr))
+return null;tBody=tBody.childNodes[c+1].childNodes[1].firstChild.firstChild
+if(!tBody)
+return null}
+break}}}
+return null}
+function delArrItem(a,p){var b=a.slice(0,p)
+var e=a.slice(p+1)
+return b.concat(e)}
+function addArrItem(a,p,v){var b=a.slice(0,p)
+var e=a.slice(p)
+b[b.length]=v
+function _editDataNode(action,path,nd){var ps=jst_data
+var parts=path.split(jst_delimiter[0])
+for(var p=0;p<parts.length;p++){var arrData=eval(ps)
+for(var d=0;d<arrData.length;d++)
+if(parts[p]==arrData[d][0]){if(p==parts.length-1){switch(action){case"d":if(ps!=jst_data)
+eval(ps+"=delArrItem("+ps+","+d+")")
+break;case"a":if(!eval(ps)[d][2])
+eval(ps)[d].push(new Array())
+eval(ps)[d][2].push(nd)
+break;case"u":if(!eval(ps)[d][2])
+eval(ps)[d][2].unshift(nd)
+break;}
+return true}else{ps=ps+"["+d+"][2]"}
+break}}
+return false}
+function addNode(path,nd,sel,refresh,begining){if(_editDataNode((begining?"u":"a"),path,nd)){if(refresh){rebuildNode(path,true)
+rebuildNode(path)}
+if(sel)
+nodeClick(getDomNode(path+jst_delimiter[0]+nd[0]).childNodes[1].childNodes[1])}}
+function deleteNode(path){if(_editDataNode("d",path))
+rebuildNode(path,true)}
+function _getState(tBody,path){var hasSub=false
+for(var c=0;c<tBody.childNodes.length;c++){var tr=tBody.childNodes[c]
+if(childExists(tr)&&isExpanded(tr)){_getState(tBody.childNodes[c+1].childNodes[1].firstChild.firstChild,path+(path!=""?jst_delimiter[0]:"")+tr.id)
+hasSub=true}}
+if(!hasSub)
+jst_state_paths.push(path)}
+function getState(){jst_state_paths=new Array()
+_getState(get1stTBody(),"")
+return jst_state_paths.join(jst_delimiter[1])}
+function setState(data){jst_state_paths=data.split(jst_delimiter[1])
+for(var p in jst_state_paths){var path="";var pathElements=jst_state_paths[p].split(jst_delimiter[0]);for(i in pathElements){path+=pathElements[i];var tr=getDomNode(path)
+if(tr){var f1=tr.firstChild
+if(f1){var f2=f1.firstChild
+if(!isExpanded(tr)&&f2)
+if(f2.onclick)
+f2.onclick()}}
+path+=jst_delimiter[0];}}}
+function rebuildNode(path,parent){if(parent){var arrPath=path.split(jst_delimiter[0])
+arrPath.pop()
+path=arrPath.join(jst_delimiter[0])}
+if(path.split(jst_delimiter[0]).length<=1){renderTree()}else{var nd=getDomNode(path)
+if(nd){var nn=nd.nextSibling
+if(nn){var nCh=nn.childNodes[1].firstChild
+if(nCh.nodeName=="TABLE")
+nd.parentNode.parentNode.deleteRow(nn.rowIndex)}
+if(nd.firstChild.firstChild.onclick)
+nd.firstChild.firstChild.onclick()}}}
+function setNodeColor(path,color){var nd=getDomNode(path)
+if(nd){nd.childNodes[1].childNodes[nd.childNodes[1].childNodes.length-1].style.color=color;}}
+function setNodeImage(path,Img){var ps=jst_data;var parts=path.split(jst_delimiter[0])
+var arrData=null;for(var p=0;p<parts.length;p++){arrData=eval(ps);for(var d=0;d<arrData.length;d++){if(parts[p]==arrData[d][0]){if(p==parts.length-1){eval(ps)[d][1][3]=Img;var nd=getDomNode(path);if(nd){var cb=nd.childNodes[1].childNodes[0];if(cb&&cb.nodeName=="IMG"){if(Img)
+cb.src=jst_image_folder+"/"+Img;else if(eval(ps)[d][2]){if(childExists(nd)){var s=nd.nextSibling.style
+if(s.display==""){cb.src=jst_image_folder+"/expanded_folder.png";}else{cb.src=jst_image_folder+"/closed_folder.png";}}else{cb.src=jst_image_folder+"/expanded_folder.png";}}
+else
+rebuildNode(path,true);}
+else
+break;}}}
+return false}
+function selectNode(path){var nd=getDomNode(path)
+if(nd){nodeClick(nd.childNodes[1].childNodes[nd.childNodes[1].childNodes.length-1])
+return true}else{return false}}
+function IsChecked(path,ctrlNr){var nd=getDomNode(path)
+if(nd){var fc=nd.childNodes[1].firstChild;if(fc&&fc.nodeName=="IMG")ctrlNr++;var cb=nd.childNodes[1].childNodes[ctrlNr];if(cb&&cb.nodeName=="INPUT"){return cb.checked;}}
+return false;}
+function getChildrenCheckState(path,ctrlNr){var state=-1;var plus=0;var nd=getDomNode(path);if(!nd)return-1;if(!childExists(nd))return-1;var tBody=nd.nextSibling.childNodes[1].firstChild.firstChild;if(!tBody)return-1;for(var i=0;i<tBody.childNodes.length;i++){var fc=tBody.childNodes[i].childNodes[1].firstChild;plus=0;if(fc&&fc.nodeName=="IMG")plus++;var cb=tBody.childNodes[i].childNodes[1].childNodes[ctrlNr+plus];if(cb&&cb.nodeName=="INPUT"){if(state==-1)
+state=cb.checked?1:0;else{if(state!=cb.checked?1:0)
+return-1;}}}
+return state;}
+function checkChildren(path,ctrlNr,bChk){var nd=getDomNode(path);var plus;if(!nd)return false;if(!childExists(nd))return false;var tBody=nd.nextSibling.childNodes[1].firstChild.firstChild;if(!tBody)return false;for(var i=0;i<tBody.childNodes.length;i++){var fc=tBody.childNodes[i].childNodes[1].firstChild;plus=0;if(fc&&fc.nodeName=="IMG")plus++;var cb=tBody.childNodes[i].childNodes[1].childNodes[ctrlNr+plus];if(cb&&cb.nodeName=="INPUT"&&!cb.disabled){cb.checked=bChk;if(cb.onclick){cb.onclick();}}}
+return true;}
+function checkNode(path,ctrlNr,bChk){var nd=getDomNode(path)
+if(nd){var fc=nd.childNodes[1].firstChild;if(fc&&fc.nodeName=="IMG")ctrlNr++;var cb=nd.childNodes[1].childNodes[ctrlNr];if(cb&&cb.nodeName=="INPUT"){cb.checked=bChk;if(cb.onclick)cb.onclick();return true;}}
+return false;}
+function enableCheckbox(path,ctrlNr,pEnabled){var nd=getDomNode(path)
+if(nd){var fc=nd.childNodes[1].firstChild;if(fc&&fc.nodeName=="IMG")ctrlNr++;var cb=nd.childNodes[1].childNodes[ctrlNr];if(cb&&cb.nodeName=="INPUT"){cb.disabled=!pEnabled;return true;}}
+return false;}
+function get1stTBody(){return eval(jst_container).firstChild.firstChild.childNodes[1].childNodes[1].firstChild.firstChild}
+function __switchAll(tBody,expand){if(!tBody)
+return false
+var img=tr.firstChild.firstChild
+if(img)
+if(img.onclick){if((expand&&!childExists(tr))||((expand&&!isExpanded(tr))||(!expand&&isExpanded(tr)))){if(img.id!="rootImage")
+img.onclick()
+jst_any_expanded=true}
+if(tBody.childNodes[c+1])
+__switchAll(tBody.childNodes[c+1].childNodes[1].firstChild.firstChild,expand)}}}
+function _switchAll(expand){if(jst_reload_halt)
+return
+__switchAll(get1stTBody(),expand)
+if(jst_reloading){if(!jst_any_expanded)
+cancelExpandAll()
+jst_any_expanded=null}}
+function expandAll(){if(jst_expandAll_warning?confirm(jst_expandAll_warning):true)
+if(jst_reloading){jst_expandAll_int=window.setInterval("if(!jst_reload_halt)_switchAll(true)",100)}else{_switchAll(true)}}
+function cancelExpandAll(){if(jst_expandAll_int)
+window.clearInterval(jst_expandAll_int)}
+function closeAll(){_switchAll(false)}
+function isExpanded(tr){return childExists(tr)?tr.nextSibling.style.display!="none":false}
+function childExists(tr){try{return tr.nextSibling.childNodes[1].firstChild.nodeName=="TABLE"}catch(e){return false}}
+function getPath(strData){if(strData.indexOf("[")>0){var sub3=strData.substr(0,strData.lastIndexOf("["))
+var sub6=sub3.substr(0,sub3.lastIndexOf("["))
+return(getPath(sub6)!=""?getPath(sub6)+jst_delimiter[0]:"")+eval(sub3+"[0]")}else{return""}}
+function reloadCallback(){eval(jst_reload_strData+"=window.frames['"+jst_reload_frame+"']."+jst_data)
+renderNode(jst_reload_strData,jst_reload_ctlImage,null,true)
+window.status=""
+jst_reload_halt=false
+jst_reload_strData=""
+jst_reload_ctlImage=null}
+function renderNode(strData,ctlImg,event,reload){if(event)
+event.cancelBubble=true
+if(jst_reload_halt&&!reload)
+return
+jst_loaded=false
+if(jst_reloading&&!reload&&eval(strData).length==0){jst_reload_strData=strData
+jst_reload_ctlImage=ctlImg
+jst_reload_halt=true
+if(jst_reloading_status)
+window.status=jst_reloading_status
+window.frames[jst_reload_frame].document.location.href="./"+jst_reload_script+(jst_reload_script.indexOf("?")>-1?"&":"?")+"path="+getPath(strData)
+return}
+var tr=ctlImg.parentNode.parentNode
+if(ctlImg.id!="rootFolder"){var fldImg=tr.childNodes[1].firstChild
+if(childExists(tr)){var s=tr.nextSibling.style
+var img1=jst_image_folder+"/"+(tr.nextSibling.nextSibling?"":"last_")
+if(s.display==""){s.display="none"
+ctlImg.src=img1+"closed.png"
+if(eval(strData.substr(0,strData.length-3)+"[1][3]"))
+fldImg.src=jst_image_folder+"/"+eval(strData.substr(0,strData.length-3)+"[1][3]");else
+fldImg.src=jst_image_folder+"/closed_folder.png";}else{s.display=""
+ctlImg.src=img1+"expanded.png"
+fldImg.src=jst_image_folder+"/expanded_folder.png";}
+return}else{ctlImg.src=jst_image_folder+"/"+(tr.nextSibling?"":"last_")+"closed.png"
+fldImg.src=jst_image_folder+"/closed_folder.png";}}
+var newTr=tr.parentNode.insertRow((tr.rowIndex?tr.rowIndex:0)+1)
+if(ctlImg.id!="rootFolder"){newTr.style.display="none";}
+newTr.appendChild(document.createElement('td'))
+if(newTr.nextSibling)
+newTr.firstChild.setAttribute("background",jst_image_folder+"/branch.png","false")
+newTr.childNodes[1].innerHTML=renderChildren(strData)
+var nodes=eval(strData)
+var ndWithChildren=0;for(var n in nodes){var n0=nodes[n]
+var n1=n0[2]
+if(n1){renderNode(strData+"["+n+"][2]",newTr.childNodes[1].firstChild.firstChild.childNodes[parseInt(n)+ndWithChildren].firstChild.firstChild);ndWithChildren++;}}
+jst_loaded=true}
+function renderChildren(strData,tblCls,menu){var code=Array()
+code.push('<table cellspacing="0" cellpadding="0" border="0" class="'+tblCls+'">')
+for(var n in nodes){var n0=nodes[n]
+var n1=n0[2]
+code.push('<tr id="'+n0[0]+'"><td><img'+(strData==jst_data?' style="display:none" id="rootImage"':'')+' src="'+jst_image_folder+'/')
+if(n1){code.push((n==nodes.length-1?"last_closed":"closed")+'.png" onClick="renderNode('+"'"+strData+"["+n+"][2]"+"'"+',this,event)" class="action"')}else{code.push((n==nodes.length-1?"last_leaf":"leaf")+'.png"')}
+if(jst_context_menu&&!n0[1][5]&&!menu)
+n0[1][5]=jst_context_menu
+code.push(' alt=""></td><td nowrap>'+((n1||n0[1][3])?'<img'+(((strData==jst_data)&&!jst_display_root)?' style="display:none"':'')+(n0[1][5]?' class="action" onClick="showMenu(\''+strData+'['+n+']\', this, event)"':'')+' src="'+jst_image_folder+'/'+(n1?(n0[1][3]?n0[1][3]:"closed_folder.png"):n0[1][3]?n0[1][3]:"node.png")+'" alt="">':'')+((n0[1][6]&&((strData!=jst_data)||jst_display_root))?n0[1][6]:'')+'<a class="node"'+(((strData==jst_data)&&!jst_display_root)?' style="display:none"':'')+(n0[1][4]?' title="'+n0[1][4]+'"':'')+' onClick="nodeClick(this)" href='+"'"+(menu?String(n0[1][1]).replace(/{@strData}/g,strData):n0[1][1])+"'"+(n0[1][2]?' target="'+n0[1][2]+'"':jst_target?' target="'+jst_target+'"':'')+'>'+n0[1][0]+'</a></td></tr>')}
+code.push('</table>')
+return code.join("")}
+function showMenu(strData,img,event){var o=window.pageYOffset
+var offY=o?o:document.body.scrollTop
+var offX=o?window.pageXOffset:document.body.scrollLeft
+jst_cm.innerHTML=renderChildren(strData+"[1][5]","menu",true)
+jst_cm.style.top=offY+event.clientY
+jst_cm.style.left=offX+event.clientX
+jst_cm.style.visibility=""
+event.cancelBubble=true}
+function hideMenu(){jst_cm.style.visibility="hidden"}
+function renderTree(){eval(jst_container).innerHTML='<table cellspacing="0" cellpadding="0" border="0"><tr id="'+eval(jst_data+"[0][0]")+'"><td colspan="2"><span id="rootFolder"></span></td></tr></table><div style="position:absolute;top:-100;left:-100" id="contextMenu"></div>'
+renderNode(jst_data,document.getElementById("rootFolder"))
+renderNode(jst_data+"[0][2]",document.getElementById("rootImage"))
+jst_cm=document.getElementById("contextMenu")
+document.body.onclick=hideMenu
+jst_loaded=true}
Modified: tags/2.5_min/http/javascripts/map.js
--- branches/2.5/http/javascripts/map.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/map.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,2169 +1,253 @@
-var ie = document.all?1:0;
-var n6 = document.getElementById&&!document.all?1:0;
-var n4 = document.layers?1:0;
-var mb_mapObj = [];
-var mb_fiWin = null;
-var mb_panActive = false;
-var clickX;
-var clickY;
-var mb_start_x = 0;
-var mb_start_y = 0;
-var mb_end_x = 0;
-var mb_end_y = 0;
-var mb_offset_top = 0;
-var mb_offset_right = 0;
-var mb_offset_bottom = 0;
-var mb_offset_left = 0;
-var mb_log = null;
-function mb_removeFunctionFromArray(arrayname,stringFunction){
-	var length = eval(arrayname+".length");
-	for(var i=0; i<length; i++){
-		if(eval(arrayname+"["+i+"]") == stringFunction){
-			var newArray1 = eval(arrayname+".slice(0, "+(i-1)+")");
-			var newArray2 = eval(arrayname+".slice("+(i+1)+", "+length+")");
-			eval(arrayname + " = newArray1.concat(newArray2)");
-			i--;
-			length--;
-function localize() {
-	eventLocalize.trigger();
-	for(var i=0; i<mb_l10nFunctions.length; i++){
-		eval(mb_l10nFunctions[i]);
-function mb_execloadWmsSubFunctions(){
-	eventAfterLoadWMS.trigger();
-	for(var i=0; i<mb_loadWmsSubFunctions.length; i++){
-		eval(mb_loadWmsSubFunctions[i]);
-function mb_execWfsReadSubFunctions(geom) {
-	for(var i=0; i<mb_WfsReadSubFunctions.length; i++){
-		mb_WfsReadSubFunctions[i](geom);
-function mb_execWfsWriteSubFunctions() {
-	for(var i=0; i<mb_WfsWriteSubFunctions.length; i++){
-		mb_WfsWriteSubFunctions[i]();
-function mb_setWmcExtensionData(anArray) {
-	for (var i in anArray) {
-		if (typeof(anArray[i]) != "undefined") {
-			currentWmcExtensionData[i] = anArray[i];
-function mb_getWmcExtensionData(arrayKey) {
-	for (var i in restoredWmcExtensionData) {
-		if (arrayKey == i) {
-			return restoredWmcExtensionData[i];
-	var e = new Mb_warning("mb_getWmcExtensionData: "+arrayKey+" not found. Maybe this GUI does not allow loading or saving WMC documents from/to the session");
-	return null;
-var mb_security_proxy = "http://wms1.ccgis.de/mapbender/tools/security_proxy.php?mb_ows_security_proxy=";
-var mb_trans = new Image();
-mb_trans.src = "../img/transparent.gif";
-/*END OF GLOBALS*/
-function init() {
-	eventInitMap.trigger();
-	eventInit.trigger();
-	for(var i=0; i<mb_InitFunctions.length; i++){
-		eval(mb_InitFunctions[i]);
-	for(var i=0; i<mb_mapObj.length; i++){
-		setMapRequest(mb_mapObj[i].frameName);
-function deleteWmsObject() {
-	wms = [];
-	wms_layer_count = 0;
-function deleteMapObj() {
-	mb_mapObj = [];
-function mb_registerMapObj(frameName, elementName,wms_index,width, height){
-	mb_mapObj[mb_mapObj.length] = new mb_mapObj_const(frameName, elementName, width, height, wms_index);
-function mb_mapObj_const(frameName, elementName, width, height, wms_index){
-	this.width = width;
-	this.height = height;
-	this.frameName = frameName;
-	this.elementName = elementName;
-	this.layers = [];
-	this.styles = [];
-	this.querylayers = [];
-	this.geom = "";
-	this.gml = "";
-	if (wms_index !== null){
-		this.wms = [];
-		this.wms[0] = wms[wms_index];
-		this.wms[0].mapURL = false;
-		var cnt_layers = 0;
-		var cnt_querylayers = 0;
-		var styles = "";
-		var layers = "";
-		var querylayers = "";
-		for (var ii=0; ii<this.wms[0].objLayer.length; ii++){
-			if (this.wms[0].objLayer[ii].gui_layer_visible == 1 && ii>0){
-				if (cnt_layers > 0) {
-					layers += ","; styles += ",";
-				layers += this.wms[0].objLayer[ii].layer_name;
-				styles += "";
-				cnt_layers++;
-			if (this.wms[0].objLayer[ii].gui_layer_querylayer == 1 && ii>0) {
-				if (cnt_querylayers > 0) {
-					querylayers += ",";
-				querylayers += this.wms[0].objLayer[ii].layer_name;
-				cnt_querylayers++;
-		this.layers[0] = layers;
-		this.styles[0] = styles;
-		this.querylayers[0] = querylayers;
-	else {
-		this.wms = [];
-		for(var i=0; i<wms.length; i++){
-			this.wms[i] = wms[i];
-			this.wms[i].mapURL = false;
-		for(i=0; i< this.wms.length; i++){
-			var styles = "";
-			var layers = "";
-			for(var ii=0; ii<this.wms[i].objLayer.length; ii++){
-				if(this.wms[i].objLayer[ii].gui_layer_visible == 1 && ii>0){
-					if(cnt_layers > 0){
-					layers += wms[i].objLayer[ii].layer_name;
-					styles += "";
-					cnt_layers++;
-				if(this.wms[i].objLayer[ii].gui_layer_querylayer == 1 && ii>0){
-					if(cnt_querylayers > 0){
-					querylayers += wms[i].objLayer[ii].layer_name;
-			this.layers[i] = layers;
-			this.styles[i] = styles;
-			this.querylayers[i] = querylayers;
-   this.epsg = wms[0].gui_wms_epsg;
-   this.extent = setExtent(this.width,this.height,this.epsg);
-   this.mapURL = [];
-	 * get the width of the mapObj
-	 * @member mb_mapObj_const
-	 * @return width of the mapObj
-	 * @type integer
-	this.getWidth = function(){
-		return parseInt(this.width, 10);
-	 * set the width of the mapObj
-	 * @param {integer} widht the width of the mapObj
-	this.setWidth = function(width){
-		this.width = parseInt(width, 10);
-	 * get the height of the mapObj
-	 * @type integer
-	this.getHeight = function(){
-		return parseInt(this.height, 10);
-	 * set the height of the mapObj
-	 * @param {integer} height the height of the mapObj
-	this.setHeight = function(height){
-		this.height = parseInt(height, 10);
-	 * get the extent of the mapObj
-	 * @return extent of the mapObj as commaseparated minx,minx,maxx,maxy
-	 * @type string
-	this.getExtent = function(){
-		return this.extent;
-	 * get the extent as minx, maxx, miny, maxy
-	 * @return extent and additional informations of the mapObj
-	 * @type Object
-	this.getExtentInfos = function(){
-		var c = this.getExtent().split(",");
-		var ext = new Extent(c[0],c[1],c[2],c[3]);
-		return ext;
-	 * converts the extent of the mapobject so that the maximum	extent will be displayed
-	this.calculateExtent = function(ext){
-		var relation_px_x = this.getWidth() / this.getHeight();
-		var relation_px_y = this.getHeight() / this.getWidth();
-		var relation_bbox_x = ext.extentx / ext.extenty;
-		if(relation_bbox_x <= relation_px_x){
-			ext.minx = ext.centerx - relation_px_x * ext.extenty / 2;
-			ext.maxx = ext.centerx + relation_px_x * ext.extenty / 2;
-		if(relation_bbox_x > relation_px_x){
-			ext.miny = ext.centery - relation_px_y * ext.extentx / 2;
-			ext.maxy = ext.centery + relation_px_y * ext.extentx / 2;
-		this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);
-	 * zoom the map with a zoomfactor and optional to x,y coords
-	 * @param {boolean} in_ in = true, out = false
-	 * @param {float} factor the zoomfactor 1 equals 100%
-	 * @param {float} x center to x-position
-	 * @param {float} y center to y-position
-	 this.zoom = function(in_, factor, x, y){
-		factor = parseFloat(factor);
-		if (!in_) {
-			factor = 1 / factor;
-		var extent = this.getExtentInfos();
-		var distx = extent.maxx - extent.minx;
-		var disty =  extent.maxy - extent.miny;
-		if(x && y){
-			var centerx = parseFloat(x);
-			var centery = parseFloat(y);
-		else{
-			var centerx = extent.minx + distx/2;
-			var centery = extent.miny + disty/2;
-		var new_distx = distx / factor;
-		var new_disty = disty / factor;
-		var minx = centerx - new_distx / 2;
-		var miny = centery - new_disty / 2;
-		var maxx = centerx + new_distx / 2;
-		var maxy = centery + new_disty / 2;
-		this.setExtent(minx,miny,maxx,maxy);
-		//Todo:
-		//setMapRequest!
-	 * set the extent of the wms
-	 this.setExtent = function(minx,miny,maxx,maxy){
-	 	this.extent = String(minx)+","+String(miny)+","+String(maxx)+","+String(maxy);
-	 * get the srs of the mapObj
-	 * @return srs as epsg:number
-	 * @type string
-	this.getSRS = function(){
-		return this.epsg;
-	 * get all mapRequests
-	 * @return array of mapRequests of this map object
-	 * @type string[]
-	this.getMapRequests = function(){
-		var allRequests = [];
-		//loop through all wms to get the mapRequests
-		for(var i=0; i<this.wms.length; i++){
-			var currentRequest = this.wms[i].getMapRequest(this);
-			if(currentRequest){
-				allRequests.push(currentRequest);
-		if(allRequests.length > 0){
-			return allRequests;
-		return false;
-	 * get all MapRequests
-	 * @return array of all mapRequests of this map-object
-	 * @type string[]
-		//loop through all wms to get the MapRequests
-		return false;
-	 * get all featureInfoRequests
-	 * @param float x the x-value of the click position in pixel
-	 * @param float y the y-value of the click position in pixel
-	 * @return array of all featureInfoRequests of this map object
-	 * @type string[]
-	this.getFeatureInfoRequests = function(clickPoint){
-		//loop through all wms to get the FeatureInfoRequests
-			var currentRequest = this.wms[i].getFeatureInfoRequest(this, clickPoint);
-		return false;
-	 * calculation of the mapscale
-	 * @return scale
-	 * @type integer
-	this.getScale = function(){
-		var scale;
-		var bbox = this.extent.split(",");
-		var xtenty;
-		if(this.epsg=="EPSG:4326"){
-			var pxLenx = (parseFloat(bbox[2])-parseFloat(bbox[0]))/this.width;
-			var pxLeny = (parseFloat(bbox[3])-parseFloat(bbox[1]))/this.height;
-			var lat_from = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2)*Math.PI)/180;
-			var lat_to = ((parseFloat(bbox[3])-parseFloat(bbox[1])/2+pxLeny)*Math.PI)/180;
-			var lon_from = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2)*Math.PI)/180;
-			var lon_to = ((parseFloat(bbox[2])-parseFloat(bbox[0])/2+pxLeny)*Math.PI)/180;
-			var dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));
-			scale = (dist/Math.SQRT2) * (mb_resolution * 100);
-		}else{
-			xtenty =  parseFloat(bbox[3]) - parseFloat(bbox[1]);
-			scale = (xtenty / this.height) * (mb_resolution * 100);
-		return Math.round(scale);
-	 * move a wms or layer
-	 * @param int wms_id id of wms to move
-	 * @param int layer_id id of layer to move
-	 * @return true of successful
-	 * @type boolean
-	this.move = function(wms_id, layer_id, moveUp){
-		var i,j;
-		for(i=0;i<this.wms.length;i++){
-			if (wms_id == this.wms[i].wms_id) {
-				break;
-		//check if only one wms is affected?
-		if (layer_id && layer_id != this.wms[i].objLayer[0].layer_id) {
-			return this.wms[i].moveLayer(layer_id, moveUp);
-		//else swap wms
-		j = i + (moveUp?-1:1);
-		if (!(i != j && i >= 0 && i < this.wms.length && j >= 0 && j < this.wms.length)) {
-			return false;
-		upper = this.wms[i];
-		this.wms[i] = this.wms[j];
-		this.wms[j] = upper;
-		var upperLayers = this.layers[i];
-		var upperStyles = this.styles[i];
-		var upperQuerylayers = this.querylayers[i];
-		this.layers[i] = this.layers[j];
-		this.styles[i] = this.styles[j];
-		this.querylayers[i] = this.querylayers[j];
-		this.layers[j] = upperLayers;
-		this.styles[j] = upperStyles;
-		this.querylayers[j] = upperQuerylayers;
-		return true;
-	eventAfterMapObjectConstruction.trigger();
- * get the conjunction character of an URL
- * @param {String} onlineresource
- * @return the character & or ?
- * @type String
-function mb_getConjunctionCharacter(onlineresource){
-	var conChar;
-	if(onlineresource.indexOf("?") > -1){
-		if(onlineresource.charAt(onlineresource.length-1) == "?"){
-			conChar = "";
-		}else if(onlineresource.charAt(onlineresource.length-1) == "&"){
-			conChar = "";
-		}else{
-			conChar = "&";
-	if(onlineresource.indexOf("?") == -1){
-		conChar = "?";
-	return conChar;
-function mb_moveWmsById (mapObj_ind, wms_id, toIndex) {
-	return mb_wmsMoveByIndex(mapObj_ind, getWMSIndexById(mapObj_ind, wms_id), toIndex);
-function mb_wmsMoveByIndex(mapObj_ind, fromIndex, toIndex) {
-	if (fromIndex != toIndex && fromIndex >= 0 && fromIndex < mb_mapObj[mapObj_ind].wms.length && toIndex >= 0 && toIndex < mb_mapObj[mapObj_ind].wms.length) {
-		var changed = false;
-		if (fromIndex > toIndex) {
-			for (var i = fromIndex; i > toIndex ; i--) {
-				var result = mb_swapWmsByIndex(mapObj_ind, i-1, i);
-				if (result === true) {
-					changed = true;
-		else {
-			for (var i = fromIndex; i < toIndex ; i++) {
-				var result = mb_swapWmsByIndex(mapObj_ind, i, i+1);
-					changed = true;
-		return changed;
-	else {
-		return false;
-function mb_swapWmsById(mapObj_ind, wms1_id, wms2_id) {
-	return mb_swapWmsByIndex(mapObj_ind, getWMSIndexById(mapObj_ind, wms1_id), getWMSIndexById(mapObj_ind, wms2_id));
-function mb_swapWmsByIndex(mapObj_ind, indexA, indexB) {
-	if (indexA != indexB && indexA >= 0 && indexA < mb_mapObj[mapObj_ind].wms.length && indexB >= 0 && indexB < mb_mapObj[mapObj_ind].wms.length) {
-		upper = mb_mapObj[mapObj_ind].wms[indexA];
-		mb_mapObj[mapObj_ind].wms[indexA] = mb_mapObj[mapObj_ind].wms[indexB];
-		mb_mapObj[mapObj_ind].wms[indexB] = upper;
-		var upperLayers = mb_mapObj[mapObj_ind].layers[indexA];
-		var upperStyles = mb_mapObj[mapObj_ind].styles[indexA];
-		var upperQuerylayers = mb_mapObj[mapObj_ind].querylayers[indexA];
-		mb_mapObj[mapObj_ind].layers[indexA] = mb_mapObj[mapObj_ind].layers[indexB];
-		mb_mapObj[mapObj_ind].styles[indexA] = mb_mapObj[mapObj_ind].styles[indexB];
-		mb_mapObj[mapObj_ind].querylayers[indexA] = mb_mapObj[mapObj_ind].querylayers[indexB];
-		mb_mapObj[mapObj_ind].layers[indexB] = upperLayers;
-		mb_mapObj[mapObj_ind].styles[indexB] = upperStyles;
-		mb_mapObj[mapObj_ind].querylayers[indexB] = upperQuerylayers;
-		return true;
-	else {
-		return false;
-function mb_moveUpWmsByIndex(mapObj_ind, index) {
-	if (index > 0 && index < wms.length) {
-		return mb_swapWmsByIndex(mapObj_ind, index-1, index);
-	else {
-		return false;
-function mb_moveDownWmsByIndex(mapObj_ind, index) {
-	if (index >= 0 && index < wms.length-1) {
-		return mb_swapWmsByIndex(mapObj_ind, index, index+1);
-	else {
-		return false;
-function mb_mapObjaddWMS(obj){
-	var styles = "";
-	var layers = "";
-	var ind = getMapObjIndexByName(obj);
-	//is the id valid?
-	for( var i=0; i<(wms.length-1); i++){
-		if(parseInt(wms[i].wms_id, 10) >= parseInt(wms[wms.length-1].wms_id, 10)){
-			wms[wms.length-1].wms_id = parseInt(mb_mapObj[ind].wms[i].wms_id, 10) + 1;
-	mb_mapObj[ind].wms[mb_mapObj[ind].wms.length] = wms[wms.length-1];
-	mb_mapObj[ind].layers[mb_mapObj[ind].layers.length] = layers;
-	mb_mapObj[ind].styles[mb_mapObj[ind].styles.length] = styles;
-	mb_mapObj[ind].querylayers[mb_mapObj[ind].querylayers.length] = querylayers;
-	mb_execloadWmsSubFunctions();
-	return true;
-//CB
-function mb_mapObjaddWMSwithLayers(obj,layers,querylayers){
-	var styles = "";
-function mb_mapObjremoveWMS(objind,wmsind){
-	var wms_ID = null;
-	var new_wmsarray = [];
-	var new_layerarray = [];
-	var new_querylayerarray = [];
-	var new_stylesarray = [];
-	var new_mapURLarray = [];
-	for	(var i=0;i<mb_mapObj[objind].wms.length; i++){
-		if(i != wmsind){
-			new_wmsarray[new_wmsarray.length] = mb_mapObj[objind].wms[i];
-			new_layerarray[new_layerarray.length] = mb_mapObj[objind].layers[i];
-			new_querylayerarray[new_querylayerarray.length] = mb_mapObj[objind].querylayers[i];
-			new_stylesarray[new_stylesarray.length] = mb_mapObj[objind].styles[i];
-			new_mapURLarray[new_mapURLarray.length] = mb_mapObj[objind].mapURL[i];
-		else {
-			wms_ID = mb_mapObj[objind].wms[i].wms_id;
-	mb_mapObj[objind].wms = new_wmsarray;
-	mb_mapObj[objind].layers = new_layerarray;
-	mb_mapObj[objind].querylayers = new_querylayerarray;
-	mb_mapObj[objind].styles = new_stylesarray;
-	mb_mapObj[objind].mapURL = new_mapURLarray;
-	var another_new_wmsarray = [];
-	for	(var i=0;i<wms.length; i++){
-		if(wms[i].wms_id != wms_ID){
-			another_new_wmsarray[another_new_wmsarray.length] = wms[i];
-	wms = another_new_wmsarray;
-function setExtent(width,height,epsg){
-   for(var i=0; i < wms[0].gui_epsg.length; i++){
-      if(wms[0].gui_epsg[i] == epsg){
-         var bbox_minx = parseFloat(wms[0].gui_minx[i]);
-         var bbox_miny = parseFloat(wms[0].gui_miny[i]);
-         var bbox_maxx = parseFloat(wms[0].gui_maxx[i]);
-         var bbox_maxy = parseFloat(wms[0].gui_maxy[i]);
-         var extenty = bbox_maxy - bbox_miny;
-         var extentx = bbox_maxx - bbox_minx;
-         var relation_px_x = width / height;
-         var relation_px_y = height / width;
-         var relation_bbox_x = extentx / extenty;
-         var centerx = bbox_minx + (extentx/2);
-         var centery = bbox_miny + (extenty/2);
-                bbox_minx = centerx - relation_px_x * extenty / 2;
-                bbox_maxx = centerx + relation_px_x * extenty / 2;
-                bbox_miny = centery - relation_px_y * extentx / 2;
-                bbox_maxy = centery + relation_px_y * extentx / 2;
-        return bbox_minx  +","+ bbox_miny +","+ bbox_maxx  +","+ bbox_maxy;
-function setMapRequest(frameName){
-	var functionName = 'setMapRequest';
-	var ts = mb_timestamp();
-	var ret = eventBeforeMapRequest.trigger({frameName:frameName}, "AND");
-	if (ret === false) {
-		return true;
-	for(var i=0; i<mb_MapRequestPreFunctions.length; i++){
-		var ret = eval(mb_MapRequestPreFunctions[i]);
-		if(ret == false){
-			return true;
-		var newMapRequest = "";
-		if(mb_mapObj[i].frameName == frameName){
-			for(var ii=0; ii<mb_mapObj[i].wms.length; ii++){
-				if(mb_mapObj[i].wms[ii].gui_wms_visible > 0){
-					var myDivId = "div_" + ii;
-					var myMapId = "map_" + ii;
-					//disable Layer which are out of scale
-					var validLayers = mb_checkScale(frameName,i,ii);
-					var layerNames = validLayers.toString();
-					if(mb_mapObj[i].layers[ii] !== "" && layerNames !== ''){
-						var newMapURL = "";
-						if (mb_mapObj[i].wms[ii].gui_wms_mapopacity != 1) {
- 							var cadenaOpacity = "opacity:"+mb_mapObj[i].wms[ii].gui_wms_mapopacity+"; Filter: Alpha(Opacity="+mb_mapObj[i].wms[ii].gui_wms_mapopacity*100+"); -moz-opacity:"+mb_mapObj[i].wms[ii].gui_wms_mapopacity+" ; -khtml-opacity:"+mb_mapObj[i].wms[ii].gui_wms_mapopacity;
-	 						newMapRequest += "<div id='"+myDivId+"' style=\"position:absolute; top:0px; left:0px; z-index:"+ii+";"+cadenaOpacity+"\">";
-						// IE problem: layers that are already transparent (defined in map file)
-						// are sabotaged by the Mapbender opacity setting...
-						// this solution helps to display these layers correctly if no opacity
-						// manipulation is taking place in Mapbender
-						// solution needed for both WMS and Mapbender transparency in IE
-						// see:
-						else {
-							newMapRequest += "<div id='"+myDivId+"' style='position:absolute; top:0px; left:0px; z-index:"+ii+"'>";
-						newMapRequest += "<img id='"+myMapId+"' name='mapimage' src='";
-						newMapURL += mb_mapObj[i].wms[ii].wms_getmap;
-						newMapURL += mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getmap);
-						if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){newMapURL += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=map&";}
-						if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){newMapURL += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetMap&SERVICE=WMS&";}
-						newMapURL += "LAYERS="+layerNames+"&";
-						newMapURL += "STYLES=";
-						var layer = layerNames.split(",");
-						for(var j=0; j<layer.length; j++){
-							if(j>0){
-								newMapURL  += ",";
-							if(mb_mapObj[i].wms[ii].getCurrentStyleByLayerName(layer[j]) === false){
-								newMapURL  += "";
-							else{
-								newMapURL  += mb_mapObj[i].wms[ii].getCurrentStyleByLayerName(layer[j]);
-						newMapURL += "&";
-						newMapURL += "SRS="+mb_mapObj[i].epsg+"&";
-						newMapURL += "BBOX="+mb_mapObj[i].extent+"&";
-						newMapURL += "WIDTH="+mb_mapObj[i].width+"&";
-						newMapURL += "HEIGHT="+mb_mapObj[i].height+"&";
-						newMapURL += "FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";
-						newMapURL += "BGCOLOR=0xffffff&";
-						if(mb_mapObj[i].wms[ii].gui_wms_mapformat.search(/gif/i)>-1 || mb_mapObj[i].wms[ii].gui_wms_mapformat.search(/png/i)>-1){
-							newMapURL += "TRANSPARENT=TRUE&";
-						newMapURL += "EXCEPTIONS="+mb_mapObj[i].wms[ii].gui_wms_exceptionformat;
-						// add vendor-specifics
-						for(var v=0; v < mb_vendorSpecific.length; v++){
-							var vendorSpecificString = eval(mb_vendorSpecific[v]);
-							// if eval doesn't evaluate a function, the result is undefined.
-							// Sometimes it is necessary not to evaluate a function, for
-							// example if you want to change a variable from the current
-							// scope (see mod_addSLD.php)
-							if (typeof(vendorSpecificString) != "undefined") {
-								newMapURL += "&" + vendorSpecificString;
-						// add Filter
-						if(mb_mapObj[i].wms[ii].wms_filter){
-							var tmp = mb_mapObj[i].wms[ii].wms_filter +"?id="+ mb_styleID;
-							var temp = "&SLD=" + tmp+ "&";
-							newMapURL += temp;
-						// add sld
-						if(mb_mapObj[i].wms[ii].gui_wms_sldurl){
-							//alert(mb_mapObj[i].wms[ii].gui_wms_sldurl);
-							var temp = "&SLD=" + escape(mb_mapObj[i].wms[ii].gui_wms_sldurl) + "&";
-						if(mb_log){
-							var tmp = eval(mb_log + "('" + newMapURL + "','" + ts + "')");
-						newMapRequest += newMapURL;
-						mb_mapObj[i].mapURL[ii] = newMapURL;
-						mb_mapObj[i].wms[ii].mapURL = newMapURL;
-						newMapRequest += "' width='"+mb_mapObj[i].width+"' height='"+mb_mapObj[i].height+"' border='0'></div>";
-					else{
-						mb_mapObj[i].mapURL[ii] = false;
-						mb_mapObj[i].wms[ii].mapURL = false;
-						newMapRequest += "<div id='" + myDivId + "' style='position:absolute; top:0px; left:0px; z-index:" + ii + "'>";
-						newMapRequest += "<img id='"+myMapId+"' name='mapimage' src='" + mb_trans.src;
-						newMapRequest += "' width='"+mb_mapObj[i].width+"' height='"+mb_mapObj[i].height+"' border='0'>";
-						newMapRequest +="</div>";
-			//prompt("",newMapRequest);
-			writeTag(mb_mapObj[i].frameName,mb_mapObj[i].elementName,newMapRequest);
-	eventAfterMapRequest.trigger({"frameName":frameName, "myMapId":myMapId});
-	for(var i=0; i<mb_MapRequestSubFunctions.length; i++){
-		eval(mb_MapRequestSubFunctions[i]);
-function setSingleMapRequest(frameName,wms_id){
-	var functionName = 'setSingleMapRequest';
-	eventBeforeMapRequest.trigger({frameName:frameName});
-		eval(mb_MapRequestPreFunctions[i]);
-	for(i=0; i<mb_mapObj.length; i++){
-				if(mb_mapObj[i].wms[ii].wms_id == wms_id){
-						if(j>0){
-							newMapURL  += ",";
-						if(mb_mapObj[i].wms[ii].getCurrentStyleByLayerName(layer[j])===false){
-							newMapURL  += "";
-						else{
-					newMapURL += "&";
-					for (var v = 0; v < mb_vendorSpecific.length; v++) {
-					// add Filter
-						//prompt("",tmp);;
-					// add sld
-					//prompt("",newMapURL);
-					if(mb_mapObj[i].layers[ii] !== "" && layerNames!==''){
-					else{
-						newMapRequest = "<img id='"+myMapId+"' name='mapimage' src='" + mb_trans.src;
-					if(mb_log){
-					writeTag(mb_mapObj[i].frameName,myDivId,newMapRequest);
-function mb_restateLayers(frameName,wms_id){
-	//alert(frameName + " / " + wms_id);
-	var ind = getMapObjIndexByName(frameName);
-	for(var i=0; i<mb_mapObj[ind].wms.length; i++){
-		if(mb_mapObj[ind].wms[i].wms_id == wms_id){
-			var layers = "";
-			var styles = "";
-			for(var ii=0; ii<mb_mapObj[ind].wms[i].objLayer.length; ii++){
-				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
-					if(cnt_layers > 0){layers += ","; styles += ","; }
-					layers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
-					//alert(mb_mapObj[ind].wms[i].objLayer[ii].layer_name);
-					styles += "";
-					cnt_layers++;
-				if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer == 1 && !mb_mapObj[ind].wms[i].objLayer[ii].has_childs){
-					if(cnt_querylayers > 0){querylayers += ",";}
-					querylayers += mb_mapObj[ind].wms[i].objLayer[ii].layer_name;
-			mb_mapObj[ind].layers[i] = layers;
-			mb_mapObj[ind].querylayers[i] = querylayers;
-			mb_mapObj[ind].styles[i] = styles;
-function mb_checkScale(frameName,mObj,wmsObj){
-	var thisLayer = mb_mapObj[mObj].layers[wmsObj].split(",");
-	var thisScale = mb_getScale(frameName);
-	var str_layer = "";
-	var cnt_layer = 0;
-	for(var i=0; i<mb_mapObj[mObj].wms[wmsObj].objLayer.length; i++){
-		var myLayername = mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_name;
-		var myMinscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_minscale;
-		var myMaxscale = mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_maxscale;
-		for(var ii=0; ii<thisLayer.length; ii++){
-			var minscaleOK = false;
-			var maxscaleOK = false;
-			if(thisLayer[ii] == myLayername){
-				if(myMinscale === 0 || thisScale >= myMinscale){minscaleOK = true;}
-				if(myMaxscale === 0 || thisScale <= myMaxscale){maxscaleOK = true;}
-				if(maxscaleOK === true && minscaleOK === true  && !mb_mapObj[mObj].wms[wmsObj].objLayer[i].has_childs){
-					if(cnt_layer > 0){str_layer += ","; }//str_styles += ","; str_titles += ",";str_parent += ","; str_legendurls += ",";}
-					str_layer += thisLayer[ii];
-					cnt_layer++;
-	var str_layerstyles = [];
-	str_layerstyles[0] = str_layer;
-	return str_layerstyles;
-function setFeatureInfoRequest(fName,x,y, path) {
-	var functionName = 'setFeatureInfoRequest';
-	eventBeforeFeatureInfo.trigger({"fName":fName});
-	for(var i=0; i<mb_FeatureInfoPreFunctions.length; i++){
-		eval(mb_FeatureInfoPreFunctions[i]);
-	var cnt_fi = 0;
-		if(mb_mapObj[i].frameName == fName){
-				var newfeatureInfoRequest = "";
-				var requestParams = "";
-				var validation = false;
-				newfeatureInfoRequest += mb_mapObj[i].wms[ii].wms_getfeatureinfo;
-            	newfeatureInfoRequest += mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getfeatureinfo);
-				if(mb_mapObj[i].wms[ii].wms_version == "1.0.0"){requestParams += "WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=feature_info&";}
-				if(mb_mapObj[i].wms[ii].wms_version != "1.0.0"){requestParams += "VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS&";}
-				requestParams += "SRS="+mb_mapObj[i].epsg+"&";
-				requestParams += "BBOX="+mb_mapObj[i].extent+"&";
-				requestParams += "WIDTH="+mb_mapObj[i].width+"&";
-				requestParams += "HEIGHT="+mb_mapObj[i].height+"&";
-				requestParams += "LAYERS="+mb_mapObj[i].layers[ii]+"&";
-				requestParams += "STYLES="+mb_mapObj[i].styles[ii]+"&";
-				requestParams += "FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";
-				requestParams += "INFO_FORMAT="+mb_mapObj[i].wms[ii].gui_wms_featureinfoformat+"&";
-				requestParams += "EXCEPTIONS=application/vnd.ogc.se_xml&";
-				if(mb_feature_count > 0){
-					requestParams += "FEATURE_COUNT="+mb_feature_count+"&";
-				requestParams += "QUERY_LAYERS="+mb_mapObj[i].querylayers[ii]+"&";
-				requestParams += "X=" + x  + "&";
-				requestParams += "Y=" + y;
-				if(mb_mapObj[i].querylayers[ii] !== "" && mb_mapObj[i].layers[ii] !== ""){
-					validation = true;
-				//add vendor-specific
-					requestParams += "&" + vendorSpecificString;
-				if(mb_log && validation){
-					var tmp = eval(mb_log + "('" + newfeatureInfoRequest + requestParams + "','" + ts + "')");
-				if(document.getElementById("FeatureInfoRedirect") && validation){
-					newfeatureInfoRequest += requestParams;
-					if(path){
-						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = path + "?url=" + escape(newfeatureInfoRequest)+"&"+mb_nr;
-					else{
-						window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src = newfeatureInfoRequest;
-					cnt_fi++;
-				else if(path && validation){
-					(function () {
-						var currentRequest = newfeatureInfoRequest;
-						mb_ajax_post(path, {'url':currentRequest},function(js_code,status){
-							if(js_code){
-								try{
-									var p = new mb_popup({
-										title:"Feature Info",
-										url:path + "?url=" + escape(currentRequest)+"&"+mb_nr,
-										width:600,
-										height:500,
-										top:200,
-										left:600
-									p.show();
-								}catch(e){
-									window.open(path + "?url=" + escape(currentRequest)+"&"+mb_nr, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
-							else{
-								var e = new Mb_exception("No featureInfo results.");
-					cnt_fi++;
-				else if(validation){
-					try{
-							url:newfeatureInfoRequest,
-							width:600,
-							height:500,
-							top:200,
-							left:600
-						p.show();
-					catch(e){
-						window.open(newfeatureInfoRequest, "" , "width=300,height=400,scrollbars=yes,resizable=yes");
-					cnt_fi++;
-   	if(cnt_fi === 0){
-		alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));
- * global function to zoom a mapobject
- * use: mb_mapObj.zoom() {@link mb_mapObj_const#zoom}
- * @deprecated
-function zoom(frameName,in_, factor,x,y) {
-	var obj = getMapObjByName(frameName);
-	if(x && y){
-		obj.zoom(in_, factor, x, y);
-	else{
-		obj.zoom(in_, factor, false, false);
-	setMapRequest(frameName);
-function mb_panMap(frameName,dir){
-   var arrayBBox = mb_mapObj[ind].extent.split(",");
-   var minx = parseFloat(arrayBBox[0]);
-   var miny = parseFloat(arrayBBox[1]);
-   var maxx = parseFloat(arrayBBox[2]);
-   var maxy = parseFloat(arrayBBox[3]);
-   var xtentx = parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]);
-   var xtenty =  parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]);
-   if(dir == "NW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "N"){miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "NE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny + (xtenty/2); maxy = maxy + (xtenty/2);}
-   if(dir == "W"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2);}
-   if(dir == "E"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2);}
-   if(dir == "SW"){minx = minx - (xtentx/2); maxx = maxx - (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-   if(dir == "S"){miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-   if(dir == "SE"){minx = minx + (xtentx/2); maxx = maxx + (xtentx/2); miny = miny - (xtenty/2); maxy = maxy - (xtenty/2);}
-  mb_mapObj[ind].extent = minx + "," + miny + "," + maxx + "," + maxy;
-function handleSelectedLayer (frameName, wms_title, layerName, type, status) {
-//	alert(frameName + " , " +wms_title + " , " +layerName + " , " +type + " , " +status);
-//	type = {visible || querylayer] status = {0 || 1}
-	for (var i=0; i < mb_mapObj.length; i++) {
-		if (mb_mapObj[i].frameName == frameName) {
-			var myMapObj = i;
-			for (var ii = 0; ii < mb_mapObj[i].wms.length; ii++) {
-				if (mb_mapObj[i].wms[ii].wms_title == wms_title) { //ii is true
-					var myWMS = ii;
-					if (type == "visible") {
-						var arrayLayer = mb_mapObj[i].layers[ii].split(",");
-					if (type == "querylayer") {
-						var arrayLayer = mb_mapObj[i].querylayers[ii].split(",");
-					for (var iii = 1; iii < mb_mapObj[i].wms[ii].objLayer.length; iii++) {
-						var layer_name = mb_mapObj[i].wms[ii].objLayer[iii].layer_name;
-							if (layer_name == layerName && status == 1 && mb_mapObj[i].wms[ii].objLayer[iii].layer_queryable == 1){
-								if (cnt_layer > 0) {
-									str_layer += ",";
-								str_layer += layer_name;
-								cnt_layer++;
-						else if (type == "visible") {
-							if (layer_name == layerName && status == 1) {
-									str_layer += ",";
-								cnt_layer++;
-						for (var iiii = 0; iiii < arrayLayer.length; iiii++) {
-							if (layer_name == arrayLayer[iiii] && layer_name != layerName) {
-									str_layer += ",";
-								cnt_layer++;
-		mb_mapObj[myMapObj].layers[myWMS] = str_layer;
-		var array_str_layer = str_layer.split(",");
-		var str_styles = "";
-		for (var cnt=0; cnt < array_str_layer.length; cnt++) {
-			if (cnt > 0) {
-				str_styles += ",";
-			str_styles += "";
-		mb_mapObj[myMapObj].styles[myWMS] = str_styles;
-		mb_mapObj[myMapObj].querylayers[myWMS] = str_layer;
-	if(type == 'visible'){
-		setSingleMapRequest(frameName,wms_title);
-function handleSelectedLayer_array(mapObj, array_wms, array_layer, type, status){
-	//alert(mapObj+" / "+array_wms[0]+" / "+ array_layer[0]+" / "+ type+" / "+ status);
-	var ind = getMapObjIndexByName(mapObj);
-	for(var j=0; j<array_wms.length; j++){
-			if(mb_mapObj[ind].wms[i].wms_id == array_wms[j]){
-				var check = false;
-					if(mb_mapObj[ind].wms[i].wms_id == array_wms[j] && mb_mapObj[ind].wms[i].objLayer[ii].layer_name == array_layer[j]){
-						if(type == "visible"){
-							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible = parseInt(status, 10);
-							check = true;
-                        if(type == "querylayer" && (mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == "1" || mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable == 1)){
-							mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer = parseInt(status, 10);
-                mb_restateLayers(mapObj, array_wms[j]);
-                //alert('restate');
-                * hier noch checken, welche wms sich geaendert haben und disctinct eine singleRequest aufrufen:
-                if(check === true){
-                    if(mb_mapObj[ind].wms[i].gui_wms_visible == 1){
-						setSingleMapRequest(mapObj,mb_mapObj[ind].wms[i].wms_id);
-                        //alert('sSMR');
-function makeClickPos2RealWorldPos(frameName, myClickX, myClickY) {
-	var width = parseInt(mb_mapObj[ind].width, 10);
-	var height = parseInt(mb_mapObj[ind].height, 10);
-	var minX = parseFloat(arrayBBox[0]);
-	var minY = parseFloat(arrayBBox[1]);
-	var maxX = parseFloat(arrayBBox[2]);
-	var maxY = parseFloat(arrayBBox[3]);
-	var deltaX = (maxX - minX)/width;
-	var deltaY = (maxY - minY)/height;
-	if(deltaX > 0){
-		var roundx = 1/Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
-	else{
-		var roundx =  Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));
-	if(deltaY > 0){
-		var roundy = 1/Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
-	else{
-		var roundy =  Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));
-	var xtentx = maxX - minX;
-	var xtenty =  maxY - minY;
-	var posX = parseFloat(minX + (myClickX / width) * xtentx);
-	var posY = parseFloat(maxY - (myClickY / height) * xtenty);
-	posX = Math.round(posX * roundx)/roundx;
-	posY = Math.round(posY * roundy)/roundy;
-	return [posX, posY];
-function makeRealWorld2mapPos(frameName,rw_posx, rw_posy){
-   var mpObj = mb_mapObj[ind];
-   var arrayBBox = mpObj.extent.split(",");
-   return [Math.round((rw_posx - minX)*mpObj.width/(maxX - minX)), Math.round((maxY - rw_posy)*mpObj.height/(maxY - minY))];
-function mb_arrangeElement(frameName, elName, left, top) {
-   if(frameName !== ""){
-      window.frames[frameName].document.getElementById(elName).style.top = top;
-      window.frames[frameName].document.getElementById(elName).style.left = left;
-   else{
-      document.getElementById(elName).style.top = top;
-      document.getElementById(elName).style.left = left;
-/***********************Drag & Drop***********************/
-function mb_getMousePos(e,fName){
-if(fName){
-     if(ie){
-        clickX = window.frames[fName].event.clientX;
-        clickY = window.frames[fName].event.clientY;
-     else{
-        clickX = e.pageX;
-        clickY = e.pageY;
-  else{
-       if(ie){
-        clickX = event.clientX;
-        clickY = event.clientY;
-     else{
-        clickX = e.pageX;
-        clickY = e.pageY;
-  var pos = [clickX,clickY];
-  return pos;
-// function for object-identification
-function getMapObjIndexByName(frameName){
-			return i;
-function getMapObjByName(frameName){
-			return mb_mapObj[i];
-	return false;
-function mb_getLayerTitleByName(map_index, wms_index, myLayer_name){
-	for(var i=0; i<mb_mapObj[map_index].wms[wms_index].objLayer.length; i++){
-		if(mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_name == myLayer_name){
-			return mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_title;
-function getWMSIDByTitle(frameName,wms_title){
-   for(var i=0; i< mb_mapObj[ind].wms.length; i++){
-      if(mb_mapObj[ind].wms[i].wms_title == wms_title){
-         //return i;
-         return mb_mapObj[ind].wms[i].wms_id;
-function getWMSIndexByTitle(frameName,wms_title){
-         return i;
-function getWMSIndexById(frameName,wms_id){
-         return i;
-//scale
-function mb_getScale(frameName) {
-	var myScale = eventBeforeGetScale.trigger({"frameName":frameName});
-   for(var i=0; i<mb_GetScalePreFunctions.length; i++){
-		var myScale = eval(mb_GetScalePreFunctions[i]);
-   if(typeof(myScale) == "number"){
-      var Y_str = myScale;
-   else{
-      var scaleY = (xtenty / mb_mapObj[ind].height) *(mb_resolution * 100);
-      if (scaleY<1){
-      	var Y_str = scaleY;
-      }else{
-      	var Y_str = Math.round(scaleY);
-   return Y_str;
-function mb_repaintScale(frameName, x, y, scale){
-   if(x === null && y === null){
-      x = parseFloat(arrayBBox[0]) + ((parseFloat(arrayBBox[2]) - parseFloat(arrayBBox[0]))/2);
-      y = parseFloat(arrayBBox[1]) + ((parseFloat(arrayBBox[3]) - parseFloat(arrayBBox[1]))/2);
-   var minx = parseFloat(x) - (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
-   var miny = parseFloat(y) -  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
-   var maxx = parseFloat(x) + (mb_mapObj[ind].width / (mb_resolution * 100 *2) * scale);
-   var maxy = parseFloat(y) +  (mb_mapObj[ind].height / (mb_resolution * 100 *2) * scale);
-   mb_repaint(frameName,minx, miny, maxx, maxy);
-function mb_repaint(frameName,minx,miny,maxx,maxy){
- * converts the extent of the mapobject so that the maximum	extent will be displayed {@link mb_mapObj_const#calculateExtent}
- * use: mb_mapObj.calculateExtent
- * @deprecated
-function mb_calculateExtent(frameName,minx,miny,maxx,maxy){
-  var map = getMapObjByName(frameName);
-  var extent = new Extent(minx,miny,maxx,maxy);
-  map.calculateExtent(extent);
- * @class extent
- * @param {float} minx
- * @param {float} miny
- * @param {float} maxx
- * @param {float} maxy
- * @return the extent as object
- * @type Object
-function Extent(minx,miny,maxx,maxy){
-	this.minx = parseFloat(minx);
-	this.miny = parseFloat(miny);
-	this.maxx = parseFloat(maxx);
-	this.maxy = parseFloat(maxy);
-	this.extentx = this.maxx - this.minx;
-	this.extenty = this.maxy - this.miny;
-	this.centerx = this.minx + this.extentx/2;
-	this.centery = this.miny + this.extenty/2;
-	return this;
-function mb_showHighlight(frameName,x,y){
-   var pos = makeRealWorld2mapPos(frameName,x, y);
-   mb_arrangeElement(frameName,"highlight",pos[0]-7, pos[1]-7);
-   window.frames[frameName].document.getElementById("highlight").style.visibility = 'visible';
-function mb_hideHighlight(frameName){
-   mb_arrangeElement(frameName,"highlight",-20, -20);
-   window.frames[frameName].document.getElementById("highlight").style.visibility = 'hidden';
-function mb_permanentHighlight(frameName,x,y){
-   mb_arrangeElement(frameName,"permanent",pos[0]-7, pos[1]-7);
-   window.frames[frameName].document.getElementById("permanent").style.visibility = 'visible';
-// framename, commaseparated coordinates, commaseparated rgb values (color)
-//new: coords is array!
-function mb_markResult(frameName,geom,col){
-	var x = "";
-	var y = "";
-	var tmp = [];
-	for(var i=0; i < geom.length; i++){
-		if(i > 0){
-			x += ":";
-			y += ":";
-		tmp = geom[i].split(",");
-		for(var ii=0; ii < tmp.length; ii+=2){
-			var pos = makeRealWorld2mapPos(frameName,tmp[ii], tmp[ii+1]);
-			if(ii>0){
-				x += ",";
-				y += ",";
-			x += pos[0];
-			y += pos[1];
-	var source = "<img src='../extensions/markResult.php?x=" + x + "&y=" + y + "&width=" + mb_mapObj[ind].width + "&height=" + mb_mapObj[ind].height + "&color="+col+"'>";
-	//prompt("",source);
-	writeTag(frameName,"markResult",source);
-function mb_disableResult(frameName){
-   writeTag(frameName,"markResult","");
-function mb_registerGML(frameName,obj){
-	mb_mapObj[ind].geom = obj;
-function mb_timestamp(){
-	var d = new Date();
-	var ts = Math.round(Date.parse(d)/1000);
-	return ts;
-function mb_getlayerposbyname(objInd,wmsInd,lname){
-	var t = mb_mapObj[objInd].wms[wmsInd];
-	for(var i=0; i < t.objLayer.length; i++){
-		if(t.objLayer[i].layer_name == lname){
-			return t.objLayer[i].layer_pos;
-function mb_getLayerObjByName(fname,wms_id,layer_name){
-	var ind = getMapObjIndexByName(fname);
-	var wmsInd = getWMSIndexById(fname,wms_id);
-	var t = mb_mapObj[ind].wms[wmsInd];
-		if(t.objLayer[i].layer_name == layer_name){
-			return t.objLayer[i];
-function mb_getchildsbyname(objInd,wmsInd,lname){
-	var pos = mb_getlayerposbyname(objInd, wmsInd,lname);
-	var l = [];
-	l.name = [];
-	l.title = [];
-	l.legendurl = [];
-		if(t.objLayer[i].layer_parent == pos){
-			l.name[l.name.length] = t.objLayer[i].layer_name;
-			l.title[l.title.length] = t.objLayer[i].layer_title;
-			if(t.objLayer[i].layer_style.length>0){
-				l.legendurl[l.legendurl.length] = t.objLayer[i].layer_style[0].legendurl;
-			}else{
-				l.legendurl[l.legendurl.length] = 0 ;
-	if(l.name.length > 0){
-		return l;
-	else{
-		return false;
- *   div tag
- * @class Represents a div tag. May be located in any frame of Mapbender.
- * @constructor
- * @param aTagName {String} the name of the tag
- * @param aFrameName {String} the name of frame where the div tag is being created
- * @param aStyle {Object} an object containing a set of name value pairs, like
- *                        {position:absolute,top:30,z-Index:30}
-function DivTag (aTagName, aFrameName, aStyle) {
-	 * @ignore
-	this.exists = function () {
-		return (rootNode.getElementById(tagName)) ? true : false;
-	 * @ignore
-	this.getTag = function() {
-		return rootNode.getElementById(tagName);
-	 * @private
-	var determineRootNode = function () {
-		node = document;
-		if (frameName !== "") {
-			if (checkFrame()) {node = window.frames[frameName].document;}
-			else {var e = new Mb_exception("frame "+frameName+" doesn't exist.");}
-		return node;
-	 * @private
-	var toCamelCase = function(aString) {
-		var newString = "";
-		for (var i = 0; i < aString.length; i++) {
-			if (aString.substr(i,1) != "-") {
-				newString += aString.substr(i,1);
-			else {
-				i++;
-				newString += aString.substr(i,1).toUpperCase();
-		return newString;
-	this.getRootNode = function () {
-		return rootNode;
-	 * @private
-	var setStyle = function () {
-		if (that.exists()) {
-			var node = rootNode.getElementById(tagName);
-			node.setAttribute("style", "");
-			for (var attr in tagStyle) {
-				if (typeof(tagStyle[attr]) != "function" && typeof(tagStyle[attr]) != "object") {
-					var evalString = "node.style."+toCamelCase(attr)+" = \"" + tagStyle[attr] + "\";";
-					eval(evalString);
-	 * @private
-	var create = function () {
-		if (!that.exists()) {
-			var divTag = rootNode.createElement("div");
-			var divTagAppended = rootNode.getElementsByTagName("body")[0].appendChild(divTag);
-			divTagAppended.id = tagName;
-		else {
-			that.clean();
-		setStyle();
-	 * @private
-	var checkFrame = function () {
-			return (typeof(window.frames[frameName]) != 'undefined');
-		return true;
-	var that = this;
-	var tagName = aTagName;
-	var frameName = aFrameName;
-	var rootNode = determineRootNode();
-	var tagStyle = aStyle;
-	create();
- * Writes a text into the div tag, while removing existing content.
- * @param {String} someText the text that is inserted into the tag.
-DivTag.prototype.write = function (someText) {
-	if (this.exists()) {
-		this.getTag().innerHTML = someText;
- * Deletes the div tag content.
-DivTag.prototype.clean = function () {
-	this.write("");
- *   Javascript exception handling
- * @class An abstract class, logs JavaScript events like errors, warnings etc.
- * @constructor
-var Mb_log = function() {
-	var that = this;
-	var levelArray = global_log_levels.split(",");
-	var log_level = global_mb_log_level;
-	var log_js = global_mb_log_js;
-	var indexOfLevel = function(aLevel) {
-		for (var i = 0; i < levelArray.length; i++) {
-			if (aLevel == levelArray[i])  {
-				return i;
-		return false;
-	var isValidLevel = function(aLevel) {
-		var isNotOff = typeof(log_js) != 'undefined' && log_js != "off";
-		var levelIndex = indexOfLevel(aLevel);
-		var isAppropriate = (typeof(levelIndex)=='number' && levelIndex < indexOfLevel(log_level));
-		return (isNotOff && isAppropriate);
-	this.throwException = function (message, level) {
-		if (isValidLevel(level)) {
-			if (log_js == "on") {
-				try {
-					mb_ajax_post('../php/mb_js_exception.php', {level:level,text:message});
-				catch(e) {
-					alert(e + ": " + message);
-			else if (log_js == "alert") {
-				alert(message);
-			else if (log_js == "console") {
-				if (level == "warning") {
-					console.warn("%s", message);
-				else if (level == "error") {
-					console.error("%s", message);
-				else {
-					console.log("%s", message);
- *  class for exception logging
- * @extends {@link Mb_log}
- * @param message the message that is being logged
-function Mb_exception(message) {
-	 var level = "error";
-	this.throwException(message, level);
-Mb_exception.prototype = new Mb_log();
- *  class for warning logging
-function Mb_warning(message) {
-	var level = "warning";
-Mb_warning.prototype = new Mb_log();
- *  class for notice logging
-function Mb_notice(message) {
-	var level = "notice";
-Mb_notice.prototype = new Mb_log();
- *   AJAX wrapper functions
- * A wrapper for an AJAX request via GET
- * @param {String} url the URL of a (presumably a server side) script.
- * @param {Object} param An object containing parameters, f.e. {name1:value1, name2:value2}
- * @param {Function} callback A function that is called when the server side script has been processed. The function is called with two parameters, result and status. Result is the output of the server side script (XML, HTML, whatever), status is a {String}, either "success" or "error".
-function mb_ajax_get(url, param, callback) {
-	try {
-//		$.ajaxSetup({async:false});
-		$.get(url, param, callback);
-	catch(e) {
-		var error = new Mb_exception('map.php: mb_ajax_get:'+e);
- * A wrapper for an AJAX request via POST
-function mb_ajax_post(url, param, callback) {
-	try {
-		$.post(url, param, callback);
-	catch(e) {
-		var error = new Mb_exception('map.php: mb_ajax_post:'+e);
- * @param {Function} callback A function that is called when the server side script has been processed. The function is called with two parameters, result and status. Result is the output of the server side script (a JavaScript Object, not a String!), status is a {String}, either "success" or "error".
-function mb_ajax_json(url, param, callback) {
-	try {
-//		window.frames['ajax'].$.ajaxSetup({async:false}); //TODO: find out why async doesn't work sometimes
-		$.getJSON(url, param, callback);
-	catch(e) {
-		var error = new Mb_exception('map.php: mb_ajax_json:'+e);
- *   button handling
-var mb_button = [];
-function mb_regButton_frame(wii, frameName, param){
-	var ind = mb_button.length;
-	mb_button[ind] = new mb_conButton(wii, ind);
-	if (frameName === null) {
-		if (param === null) {
-			eval(wii+"("+ind+")");
-		else {
-			eval(wii+"("+ind+", "+param+")");
-	else if (param === null) {
-		eval("window.frames['" + frameName + "']."+wii+"("+ind+")");
-	else {
-		eval("window.frames['" + frameName + "']."+wii+"("+ind+", "+param+")");
-	mb_button[ind].prev = mb_button[ind].src;
-	mb_button[ind].src = mb_button[ind].img_off;
-	mb_button[ind].onmouseover = function () {
-		mb_button_over(ind);
-	mb_button[ind].onmouseout = function(){
-		mb_button_out(ind);
-	mb_button[ind].onclick = function(){
-		mb_button_click(ind);
-		mb_button[ind].frameName = "";
-	else {
-		mb_button[ind].frameName = frameName;
-function mb_regButton(wii){
-	mb_regButton_frame(wii, null, null);
-function mb_conButton(wii, ind){
-   this.wii = wii;
-   return true;
-function mb_button_over(ind){
-   if(mb_button[ind].status === 0){
-      mb_button[ind].src = mb_button[ind].img_over;
-function mb_button_out(ind){
-function mb_button_click(ind){
-   var mbStatus = mb_button[ind].status;
-   if(mbStatus === 0){
-      mb_disableButton(mb_button[ind].elName);
-      mb_button[ind].prev = mb_button[ind].img_on;
-      mb_button[ind].src = mb_button[ind].img_on;
-      mb_button[ind].status = 1;
-      if (mb_button[ind].frameName !== "") {
-          window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).go();
-      else {
-	      document.getElementById(mb_button[ind].elName).go();
-   else{
-      mb_button[ind].prev = mb_button[ind].img_off;
-      mb_button[ind].status = 0;
-          window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).stop();
-      else {
-	      document.getElementById(mb_button[ind].elName).stop();
-function mb_disableButton(elName){
-   for(var i=0; i<mb_button.length; i++){
-      if(mb_button[i].elName != elName && mb_button[i].status == 1){
-            mb_button[i].status = 0;
-		      if (mb_button[i].frameName !== "") {
-    	        window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
-	            window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).stop();
-		      else {
-    	        document.getElementById(mb_button[i].elName).src = mb_button[i].img_off;
-	            document.getElementById(mb_button[i].elName).stop();
-            return true;
-function mb_disableThisButton(elName){
-      if(mb_button[i].elName == elName && mb_button[i].status == 1){
-      		//alert(mb_button[i].elName);
-		      else {
-            return true;
-function updateButtonTooltips(obj) {
- * the buttons are only initialized on mouseover!
- * So when localizing, not all buttons may have been registered
-//		console.log("button %i", i);
-		for(var j=0; j<obj.length; j++){
-			if (mb_button[i].elName == obj[j].id) {
-//			console.log("%s %s", mb_button[i].elName, obj[j].id);
-					window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).title = obj[j].title;
-				else {
-					document.getElementById(mb_button[i].elName).title = obj[j].title;
-	// an alternative, fixes above error,
-	// but this one only changes those in the main frame
-	var imageArray = document.getElementsByTagName("img");
-	for (var i = 0; i < imageArray.length; i++) {
-			if (imageArray[i].id == obj[j].id) {
-				document.getElementById(imageArray[i].id).title = obj[j].title;
-function mb_localizeButtons(){
-	mb_ajax_json("../php/mod_button_tooltips.php", function(obj, status){
-		updateButtonTooltips(obj);
-eventLocalize.register(function () {
-	mb_localizeButtons();
-eventInit.register(function () {
- *   miscellaneous functions
-function cloneObject(obj) {
-    if (typeof obj !== 'object' || obj === null) {
-        return obj;
-    var c = obj instanceof Array ? [] : {};
-    for (var i in obj) {
-        var prop = obj[i];
-        if (typeof prop == 'object') {
-           if (prop instanceof Array) {
-               c[i] = [];
-               for (var j = 0; j < prop.length; j++) {
-                   if (typeof prop[j] != 'object') {
-                       c[i].push(prop[j]);
-                   } else {
-                       c[i].push(cloneObject(prop[j]));
-           } else {
-               c[i] = cloneObject(prop);
-        } else {
-           c[i] = prop;
-    return c;
- * @class A List object is an array of arbitrary objects with additional methods.
- * @constructor
-var List = function() {
-	 * gets the number of elements in this {@link List}
-	 * @returns number of elements in this {@link List}
-	 * @type Integer
-	this.count = function() {
-		return this.list.length;
-	 * deletes the object at index i; -1 refers to the last object in this {@link List}
-	 * @param {Integer} i index
-	this.del = function(i){
-		i = this.getIndex(i);
-		if (i !== false) {
-			for(var z = i; z < this.count() - 1; z++){
-				this.list[z] = this.list[z+1];
-			this.list.length -= 1;
-			return true;
-		return false;
-	 * empties this {@link List}
-	this.empty = function() {
-		while (this.list !== null && this.count() > 0) {
-			this.list.pop();
-	 * @returns the object at index i; -1 refers to the last object in this {@link List}
-	 * @type Integer or false
-	this.get = function(i) {
-		if (i !== false) {return this.list[i];}
-		return false;
-	 * adds a reference to item to this {@link List}.
-	 * @param {Object} item an object
-	this.add = function(item) {
-		var i = this.list.length;
-		this.list[i] = item;
-	 * adds a copy of item to this {@link List}.
-	this.addCopy = function(item) {
-		this.add(cloneObject(item));
-	 * attaches the {@link List} aList to this {@link List}
-	 * @param {List} aList another list
-	this.union = function(aList) {
-		for (var i=0; i < aList.count(); i++) {this.addCopy(aList.get(i));}
-	 * checks if the index is valid and returns it if it is; if i == -1, the correct index is retrieved.
-	 * @private
-	 * @return Integer or false
-	 * @type Integer
-	this.getIndex = function(i){
-		var len = this.list.length;
-		if (i<0 && len + i > -1) {
-			return len + i;
-		else if (i > -1 && i < len){
-			return i;
-		var e = new Mb_exception("class List: function getIndex: member index " + i + " is not valid");
-		return false;
-	 * @returns a {String} representation of this List
-	 * @type String
-	this.toString = function(){
-		var str = "";
-		for (var i =0 ; i < this.count() ; i++){
-			str += this.get(i).toString();
-		return str;
-	this.list = null;
- *   deprecated functions
-// only used in mod_perimeter.php
-// previously used in mod_initWmc.php, mod_digitize_tab.php, mod_geometryArray.js
-function mb_checkTag(frameName, tagName, elementId, appendAtTagName, attributes){
-	var oldElement;
-	var newElement;
-	var prefix;
-	if(frameName && frameName !== ""){
-		prefix = window.frames[frameName].document;
-	else if(!frameName || frameName === ""){
-		prefix = document;
-	oldElement = prefix.getElementById(elementId);
-	if (oldElement === null) {
-		newElement = prefix.createElement(tagName);
-		newElement = prefix.getElementsByTagName(appendAtTagName)[0].appendChild(newElement);
-	else {
-		if (oldElement.nodeName.toLowerCase() == tagName.toLowerCase()) {
-			for (var i=0; i<attributes.length; i++) {
-				oldElement.setAttribute(attributes[i][0], attributes[i][1]);
-			return oldElement;
-		else {
-			return false;
-	var newElementAttributeNode = document.createAttribute("id");
-	newElementAttributeNode.value = elementId;
-	newElement.setAttributeNode(newElementAttributeNode);
-		newElement.setAttribute(attributes[i][0], attributes[i][1]);
-	return newElement;
+var ie=document.all?1:0;var n6=document.getElementById&&!document.all?1:0;var n4=document.layers?1:0;var mb_mapObj=[];var mb_fiWin=null;var mb_panActive=false;var clickX;var clickY;var mb_start_x=0;var mb_start_y=0;var mb_end_x=0;var mb_end_y=0;var mb_offset_top=0;var mb_offset_right=0;var mb_offset_bottom=0;var mb_offset_left=0;var mb_log=null;function mb_removeFunctionFromArray(arrayname,stringFunction){var length=eval(arrayname+".length");for(var i=0;i<length;i++){if(eval(arrayname+"["+i+"]")==stringFunction){var newArray1=eval(arrayname+".slice(0, "+(i-1)+")");var newArray2=eval(arrayname+".slice("+(i+1)+", "+length+")");eval(arrayname+" = newArray1.concat(newArray2)");i--;length--;}}}
+function localize(){eventLocalize.trigger();}
+function mb_execloadWmsSubFunctions(){eventAfterLoadWMS.trigger();}
+function mb_execWfsReadSubFunctions(geom){for(var i=0;i<mb_WfsReadSubFunctions.length;i++){mb_WfsReadSubFunctions[i](geom);}}
+function mb_execWfsWriteSubFunctions(){for(var i=0;i<mb_WfsWriteSubFunctions.length;i++){mb_WfsWriteSubFunctions[i]();}}
+function mb_setWmcExtensionData(anArray){for(var i in anArray){if(typeof(anArray[i])!="undefined"){currentWmcExtensionData[i]=anArray[i];}}}
+function mb_getWmcExtensionData(arrayKey){for(var i in restoredWmcExtensionData){if(arrayKey==i){return restoredWmcExtensionData[i];}}
+var e=new Mb_warning("mb_getWmcExtensionData: "+arrayKey+" not found. Maybe this GUI does not allow loading or saving WMC documents from/to the session");return null;}
+var mb_security_proxy="http://wms1.ccgis.de/mapbender/tools/security_proxy.php?mb_ows_security_proxy=";var mb_trans=new Image();mb_trans.src="../img/transparent.gif";function init(){eventInitMap.trigger();eventInit.trigger();for(var i=0;i<mb_mapObj.length;i++){setMapRequest(mb_mapObj[i].frameName);}}
+function deleteWmsObject(){wms=[];wms_layer_count=0;}
+function deleteMapObj(){mb_mapObj=[];}
+function mb_registerMapObj(frameName,elementName,wms_index,width,height){mb_mapObj[mb_mapObj.length]=new mb_mapObj_const(frameName,elementName,width,height,wms_index);}
+function mb_mapObj_const(frameName,elementName,width,height,wms_index){this.width=width;this.height=height;this.frameName=frameName;this.elementName=elementName;this.layers=[];this.styles=[];this.querylayers=[];this.geom="";this.gml="";if(wms_index!==null){this.wms=[];this.wms[0]=wms[wms_index];this.wms[0].mapURL=false;var cnt_layers=0;var cnt_querylayers=0;var styles="";var layers="";var querylayers="";for(var ii=0;ii<this.wms[0].objLayer.length;ii++){if(this.wms[0].objLayer[ii].gui_layer_visible==1&&ii>0){if(cnt_layers>0){layers+=",";styles+=",";}
+layers+=this.wms[0].objLayer[ii].layer_name;styles+="";cnt_layers++;}
+if(this.wms[0].objLayer[ii].gui_layer_querylayer==1&&ii>0){if(cnt_querylayers>0){querylayers+=",";}
+querylayers+=this.wms[0].objLayer[ii].layer_name;cnt_querylayers++;}}
+this.layers[0]=layers;this.styles[0]=styles;this.querylayers[0]=querylayers;}
+else{this.wms=[];for(var i=0;i<wms.length;i++){this.wms[i]=wms[i];this.wms[i].mapURL=false;}
+for(i=0;i<this.wms.length;i++){var cnt_layers=0;var cnt_querylayers=0;var styles="";var layers="";var querylayers="";for(var ii=0;ii<this.wms[i].objLayer.length;ii++){if(this.wms[i].objLayer[ii].gui_layer_visible==1&&ii>0){if(cnt_layers>0){layers+=",";styles+=",";}
+layers+=wms[i].objLayer[ii].layer_name;styles+="";cnt_layers++;}
+if(this.wms[i].objLayer[ii].gui_layer_querylayer==1&&ii>0){if(cnt_querylayers>0){querylayers+=",";}
+querylayers+=wms[i].objLayer[ii].layer_name;cnt_querylayers++;}}
+this.layers[i]=layers;this.styles[i]=styles;this.querylayers[i]=querylayers;}}
+this.epsg=wms[0].gui_wms_epsg;this.extent=setExtent(this.width,this.height,this.epsg);this.mapURL=[];this.getWidth=function(){return parseInt(this.width,10);};this.setWidth=function(width){this.width=parseInt(width,10);};this.getHeight=function(){return parseInt(this.height,10);};this.setHeight=function(height){this.height=parseInt(height,10);};this.getExtent=function(){return this.extent;};this.getExtentInfos=function(){var c=this.getExtent().split(",");var ext=new Extent(c[0],c[1],c[2],c[3]);return ext;};this.calculateExtent=function(ext){var relation_px_x=this.getWidth()/this.getHeight();var relation_px_y=this.getHeight()/this.getWidth();var relation_bbox_x=ext.extentx/ext.extenty;if(relation_bbox_x<=relation_px_x){ext.minx=ext.centerx-relation_px_x*ext.extenty/2;ext.maxx=ext.centerx+relation_px_x*ext.extenty/2;}
+if(relation_bbox_x>relation_px_x){ext.miny=ext.centery-relation_px_y*ext.extentx/2;ext.maxy=ext.centery+relation_px_y*ext.extentx/2;}
+this.setExtent(ext.minx,ext.miny,ext.maxx,ext.maxy);};this.zoom=function(in_,factor,x,y){factor=parseFloat(factor);if(!in_){factor=1/factor;}
+var extent=this.getExtentInfos();var distx=extent.maxx-extent.minx;var disty=extent.maxy-extent.miny;if(x&&y){var centerx=parseFloat(x);var centery=parseFloat(y);}
+else{var centerx=extent.minx+distx/2;var centery=extent.miny+disty/2;}
+var new_distx=distx/factor;var new_disty=disty/factor;var minx=centerx-new_distx/2;var miny=centery-new_disty/2;var maxx=centerx+new_distx/2;var maxy=centery+new_disty/2;this.setExtent(minx,miny,maxx,maxy);};this.setExtent=function(minx,miny,maxx,maxy){this.extent=String(minx)+","+String(miny)+","+String(maxx)+","+String(maxy);};this.getSRS=function(){return this.epsg;};this.getMapRequests=function(){var allRequests=[];for(var i=0;i<this.wms.length;i++){var currentRequest=this.wms[i].getMapRequest(this);if(currentRequest){allRequests.push(currentRequest);}}
+if(allRequests.length>0){return allRequests;}
+return false;};this.getMapRequests=function(){var allRequests=[];for(var i=0;i<this.wms.length;i++){var currentRequest=this.wms[i].getMapRequest(this);if(currentRequest){allRequests.push(currentRequest);}}
+return false;};this.getFeatureInfoRequests=function(clickPoint){var allRequests=[];for(var i=0;i<this.wms.length;i++){var currentRequest=this.wms[i].getFeatureInfoRequest(this,clickPoint);if(currentRequest){allRequests.push(currentRequest);}}
+return false;};this.getScale=function(){var scale;var bbox=this.extent.split(",");var xtenty;if(this.epsg=="EPSG:4326"){var pxLenx=(parseFloat(bbox[2])-parseFloat(bbox[0]))/this.width;var pxLeny=(parseFloat(bbox[3])-parseFloat(bbox[1]))/this.height;var lat_from=((parseFloat(bbox[3])-parseFloat(bbox[1])/2)*Math.PI)/180;var lat_to=((parseFloat(bbox[3])-parseFloat(bbox[1])/2+pxLeny)*Math.PI)/180;var lon_from=((parseFloat(bbox[2])-parseFloat(bbox[0])/2)*Math.PI)/180;var lon_to=((parseFloat(bbox[2])-parseFloat(bbox[0])/2+pxLeny)*Math.PI)/180;var dist=6371229*Math.acos(Math.sin(lat_from)*Math.sin(lat_to)+Math.cos(lat_from)*Math.cos(lat_to)*Math.cos(lon_from-lon_to));scale=(dist/Math.SQRT2)*(mb_resolution*100);}else{xtenty=parseFloat(bbox[3])-parseFloat(bbox[1]);scale=(xtenty/this.height)*(mb_resolution*100);}
+return Math.round(scale);};this.move=function(wms_id,layer_id,moveUp){var i,j;for(i=0;i<this.wms.length;i++){if(wms_id==this.wms[i].wms_id){break;}}
+if(layer_id&&layer_id!=this.wms[i].objLayer[0].layer_id){return this.wms[i].moveLayer(layer_id,moveUp);}
+j=i+(moveUp?-1:1);if(!(i!=j&&i>=0&&i<this.wms.length&&j>=0&&j<this.wms.length)){return false;}
+upper=this.wms[i];this.wms[i]=this.wms[j];this.wms[j]=upper;var upperLayers=this.layers[i];var upperStyles=this.styles[i];var upperQuerylayers=this.querylayers[i];this.layers[i]=this.layers[j];this.styles[i]=this.styles[j];this.querylayers[i]=this.querylayers[j];this.layers[j]=upperLayers;this.styles[j]=upperStyles;this.querylayers[j]=upperQuerylayers;return true;};eventAfterMapObjectConstruction.trigger();}
+function mb_getConjunctionCharacter(onlineresource){var conChar;if(onlineresource.indexOf("?")>-1){if(onlineresource.charAt(onlineresource.length-1)=="?"){conChar="";}else if(onlineresource.charAt(onlineresource.length-1)=="&"){conChar="";}else{conChar="&";}}
+if(onlineresource.indexOf("?")==-1){conChar="?";}
+return conChar;}
+function mb_moveWmsById(mapObj_ind,wms_id,toIndex){return mb_wmsMoveByIndex(mapObj_ind,getWMSIndexById(mapObj_ind,wms_id),toIndex);}
+function mb_wmsMoveByIndex(mapObj_ind,fromIndex,toIndex){if(fromIndex!=toIndex&&fromIndex>=0&&fromIndex<mb_mapObj[mapObj_ind].wms.length&&toIndex>=0&&toIndex<mb_mapObj[mapObj_ind].wms.length){var changed=false;if(fromIndex>toIndex){for(var i=fromIndex;i>toIndex;i--){var result=mb_swapWmsByIndex(mapObj_ind,i-1,i);if(result===true){changed=true;}}}
+else{for(var i=fromIndex;i<toIndex;i++){var result=mb_swapWmsByIndex(mapObj_ind,i,i+1);if(result===true){changed=true;}}}
+return changed;}
+else{return false;}}
+function mb_swapWmsById(mapObj_ind,wms1_id,wms2_id){return mb_swapWmsByIndex(mapObj_ind,getWMSIndexById(mapObj_ind,wms1_id),getWMSIndexById(mapObj_ind,wms2_id));}
+function mb_swapWmsByIndex(mapObj_ind,indexA,indexB){if(indexA!=indexB&&indexA>=0&&indexA<mb_mapObj[mapObj_ind].wms.length&&indexB>=0&&indexB<mb_mapObj[mapObj_ind].wms.length){upper=mb_mapObj[mapObj_ind].wms[indexA];mb_mapObj[mapObj_ind].wms[indexA]=mb_mapObj[mapObj_ind].wms[indexB];mb_mapObj[mapObj_ind].wms[indexB]=upper;var upperLayers=mb_mapObj[mapObj_ind].layers[indexA];var upperStyles=mb_mapObj[mapObj_ind].styles[indexA];var upperQuerylayers=mb_mapObj[mapObj_ind].querylayers[indexA];mb_mapObj[mapObj_ind].layers[indexA]=mb_mapObj[mapObj_ind].layers[indexB];mb_mapObj[mapObj_ind].styles[indexA]=mb_mapObj[mapObj_ind].styles[indexB];mb_mapObj[mapObj_ind].querylayers[indexA]=mb_mapObj[mapObj_ind].querylayers[indexB];mb_mapObj[mapObj_ind].layers[indexB]=upperLayers;mb_mapObj[mapObj_ind].styles[indexB]=upperStyles;mb_mapObj[mapObj_ind].querylayers[indexB]=upperQuerylayers;return true;}
+function mb_moveUpWmsByIndex(mapObj_ind,index){if(index>0&&index<wms.length){return mb_swapWmsByIndex(mapObj_ind,index-1,index);}
+function mb_moveDownWmsByIndex(mapObj_ind,index){if(index>=0&&index<wms.length-1){return mb_swapWmsByIndex(mapObj_ind,index,index+1);}
+function mb_mapObjaddWMS(obj){var cnt_layers=0;var cnt_querylayers=0;var styles="";var layers="";var querylayers="";var ind=getMapObjIndexByName(obj);for(var i=0;i<(wms.length-1);i++){if(parseInt(wms[i].wms_id,10)>=parseInt(wms[wms.length-1].wms_id,10)){wms[wms.length-1].wms_id=parseInt(mb_mapObj[ind].wms[i].wms_id,10)+1;}}
+mb_mapObj[ind].wms[mb_mapObj[ind].wms.length]=wms[wms.length-1];mb_mapObj[ind].layers[mb_mapObj[ind].layers.length]=layers;mb_mapObj[ind].styles[mb_mapObj[ind].styles.length]=styles;mb_mapObj[ind].querylayers[mb_mapObj[ind].querylayers.length]=querylayers;mb_execloadWmsSubFunctions();return true;}
+function mb_mapObjaddWMSwithLayers(obj,layers,querylayers){var cnt_layers=0;var cnt_querylayers=0;var styles="";var ind=getMapObjIndexByName(obj);mb_mapObj[ind].wms[mb_mapObj[ind].wms.length]=wms[wms.length-1];mb_mapObj[ind].layers[mb_mapObj[ind].layers.length]=layers;mb_mapObj[ind].styles[mb_mapObj[ind].styles.length]=styles;mb_mapObj[ind].querylayers[mb_mapObj[ind].querylayers.length]=querylayers;}
+function mb_mapObjremoveWMS(objind,wmsind){var wms_ID=null;var new_wmsarray=[];var new_layerarray=[];var new_querylayerarray=[];var new_stylesarray=[];var new_mapURLarray=[];for(var i=0;i<mb_mapObj[objind].wms.length;i++){if(i!=wmsind){new_wmsarray[new_wmsarray.length]=mb_mapObj[objind].wms[i];new_layerarray[new_layerarray.length]=mb_mapObj[objind].layers[i];new_querylayerarray[new_querylayerarray.length]=mb_mapObj[objind].querylayers[i];new_stylesarray[new_stylesarray.length]=mb_mapObj[objind].styles[i];new_mapURLarray[new_mapURLarray.length]=mb_mapObj[objind].mapURL[i];}
+else{wms_ID=mb_mapObj[objind].wms[i].wms_id;}}
+mb_mapObj[objind].wms=new_wmsarray;mb_mapObj[objind].layers=new_layerarray;mb_mapObj[objind].querylayers=new_querylayerarray;mb_mapObj[objind].styles=new_stylesarray;mb_mapObj[objind].mapURL=new_mapURLarray;var another_new_wmsarray=[];for(var i=0;i<wms.length;i++){if(wms[i].wms_id!=wms_ID){another_new_wmsarray[another_new_wmsarray.length]=wms[i];}}
+wms=another_new_wmsarray;}
+function setExtent(width,height,epsg){for(var i=0;i<wms[0].gui_epsg.length;i++){if(wms[0].gui_epsg[i]==epsg){var bbox_minx=parseFloat(wms[0].gui_minx[i]);var bbox_miny=parseFloat(wms[0].gui_miny[i]);var bbox_maxx=parseFloat(wms[0].gui_maxx[i]);var bbox_maxy=parseFloat(wms[0].gui_maxy[i]);var extenty=bbox_maxy-bbox_miny;var extentx=bbox_maxx-bbox_minx;var relation_px_x=width/height;var relation_px_y=height/width;var relation_bbox_x=extentx/extenty;var centerx=bbox_minx+(extentx/2);var centery=bbox_miny+(extenty/2);if(relation_bbox_x<=relation_px_x){bbox_minx=centerx-relation_px_x*extenty/2;bbox_maxx=centerx+relation_px_x*extenty/2;}
+if(relation_bbox_x>relation_px_x){bbox_miny=centery-relation_px_y*extentx/2;bbox_maxy=centery+relation_px_y*extentx/2;}
+return bbox_minx+","+bbox_miny+","+bbox_maxx+","+bbox_maxy;}}}
+function setMapRequest(frameName){var functionName='setMapRequest';var ts=mb_timestamp();var ret=eventBeforeMapRequest.trigger({frameName:frameName},"AND");if(ret===false){return true;}
+for(var i=0;i<mb_mapObj.length;i++){var newMapRequest="";if(mb_mapObj[i].frameName==frameName){for(var ii=0;ii<mb_mapObj[i].wms.length;ii++){if(mb_mapObj[i].wms[ii].gui_wms_visible>0){var myDivId="div_"+ii;var myMapId="map_"+ii;var validLayers=mb_checkScale(frameName,i,ii);var layerNames=validLayers.toString();if(mb_mapObj[i].layers[ii]!==""&&layerNames!==''){var newMapURL="";if(mb_mapObj[i].wms[ii].gui_wms_mapopacity!=1){var cadenaOpacity="opacity:"+mb_mapObj[i].wms[ii].gui_wms_mapopacity+"; Filter: Alpha(Opacity="+mb_mapObj[i].wms[ii].gui_wms_mapopacity*100+"); -moz-opacity:"+mb_mapObj[i].wms[ii].gui_wms_mapopacity+" ; -khtml-opacity:"+mb_mapObj[i].wms[ii].gui_wms_mapopacity;newMapRequest+="<div id='"+myDivId+"' style=\"position:absolute; top:0px; left:0px; z-index:"+ii+";"+cadenaOpacity+"\">";}
+else{newMapRequest+="<div id='"+myDivId+"' style='position:absolute; top:0px; left:0px; z-index:"+ii+"'>";}
+newMapRequest+="<img id='"+myMapId+"' name='mapimage' src='";newMapURL+=mb_mapObj[i].wms[ii].wms_getmap;newMapURL+=mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getmap);if(mb_mapObj[i].wms[ii].wms_version=="1.0.0"){newMapURL+="WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=map&";}
+if(mb_mapObj[i].wms[ii].wms_version!="1.0.0"){newMapURL+="VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetMap&SERVICE=WMS&";}
+newMapURL+="LAYERS="+layerNames+"&";newMapURL+="STYLES=";var layer=layerNames.split(",");for(var j=0;j<layer.length;j++){if(j>0){newMapURL+=",";}
+if(mb_mapObj[i].wms[ii].getCurrentStyleByLayerName(layer[j])===false){newMapURL+="";}
+else{newMapURL+=mb_mapObj[i].wms[ii].getCurrentStyleByLayerName(layer[j]);}}
+newMapURL+="&";newMapURL+="SRS="+mb_mapObj[i].epsg+"&";newMapURL+="BBOX="+mb_mapObj[i].extent+"&";newMapURL+="WIDTH="+mb_mapObj[i].width+"&";newMapURL+="HEIGHT="+mb_mapObj[i].height+"&";newMapURL+="FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";newMapURL+="BGCOLOR=0xffffff&";if(mb_mapObj[i].wms[ii].gui_wms_mapformat.search(/gif/i)>-1||mb_mapObj[i].wms[ii].gui_wms_mapformat.search(/png/i)>-1){newMapURL+="TRANSPARENT=TRUE&";}
+newMapURL+="EXCEPTIONS="+mb_mapObj[i].wms[ii].gui_wms_exceptionformat;for(var v=0;v<mb_vendorSpecific.length;v++){var vendorSpecificString=eval(mb_vendorSpecific[v]);if(typeof(vendorSpecificString)!="undefined"){newMapURL+="&"+vendorSpecificString;}}
+if(mb_mapObj[i].wms[ii].wms_filter){var tmp=mb_mapObj[i].wms[ii].wms_filter+"?id="+mb_styleID;var temp="&SLD="+tmp+"&";newMapURL+=temp;}
+if(mb_mapObj[i].wms[ii].gui_wms_sldurl){var temp="&SLD="+escape(mb_mapObj[i].wms[ii].gui_wms_sldurl)+"&";newMapURL+=temp;}
+if(mb_log){var tmp=eval(mb_log+"('"+newMapURL+"','"+ts+"')");}
+newMapRequest+=newMapURL;mb_mapObj[i].mapURL[ii]=newMapURL;mb_mapObj[i].wms[ii].mapURL=newMapURL;newMapRequest+="' width='"+mb_mapObj[i].width+"' height='"+mb_mapObj[i].height+"' border='0'></div>";}
+else{mb_mapObj[i].mapURL[ii]=false;mb_mapObj[i].wms[ii].mapURL=false;newMapRequest+="<div id='"+myDivId+"' style='position:absolute; top:0px; left:0px; z-index:"+ii+"'>";newMapRequest+="<img id='"+myMapId+"' name='mapimage' src='"+mb_trans.src;newMapRequest+="' width='"+mb_mapObj[i].width+"' height='"+mb_mapObj[i].height+"' border='0'>";newMapRequest+="</div>";}}}
+writeTag(mb_mapObj[i].frameName,mb_mapObj[i].elementName,newMapRequest);}}
+eventAfterMapRequest.trigger({"frameName":frameName,"myMapId":myMapId});}
+function setSingleMapRequest(frameName,wms_id){var functionName='setSingleMapRequest';var ts=mb_timestamp();eventBeforeMapRequest.trigger({frameName:frameName});for(i=0;i<mb_mapObj.length;i++){var newMapRequest="";if(mb_mapObj[i].frameName==frameName){for(var ii=0;ii<mb_mapObj[i].wms.length;ii++){var myDivId="div_"+ii;var myMapId="map_"+ii;var validLayers=mb_checkScale(frameName,i,ii);var layerNames=validLayers.toString();if(mb_mapObj[i].wms[ii].wms_id==wms_id){var newMapURL="";newMapRequest+="<img id='"+myMapId+"' name='mapimage' src='";newMapURL+=mb_mapObj[i].wms[ii].wms_getmap;newMapURL+=mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getmap);if(mb_mapObj[i].wms[ii].wms_version=="1.0.0"){newMapURL+="WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=map&";}
+newMapURL+="LAYERS="+layerNames+"&";var layer=layerNames.split(",");newMapURL+="STYLES=";for(var j=0;j<layer.length;j++){if(j>0){newMapURL+=",";}
+if(mb_mapObj[i].layers[ii]!==""&&layerNames!==''){newMapRequest+=newMapURL;mb_mapObj[i].mapURL[ii]=newMapURL;mb_mapObj[i].wms[ii].mapURL=newMapURL;newMapRequest+="' width='"+mb_mapObj[i].width+"' height='"+mb_mapObj[i].height+"' border='0'>";}
+else{mb_mapObj[i].mapURL[ii]=false;mb_mapObj[i].wms[ii].mapURL=false;newMapRequest="<img id='"+myMapId+"' name='mapimage' src='"+mb_trans.src;newMapRequest+="' width='"+mb_mapObj[i].width+"' height='"+mb_mapObj[i].height+"' border='0'>";}
+writeTag(mb_mapObj[i].frameName,myDivId,newMapRequest);}}}}
+function mb_restateLayers(frameName,wms_id){var ind=getMapObjIndexByName(frameName);for(var i=0;i<mb_mapObj[ind].wms.length;i++){if(mb_mapObj[ind].wms[i].wms_id==wms_id){var cnt_layers=0;var cnt_querylayers=0;var layers="";var styles="";var querylayers="";for(var ii=0;ii<mb_mapObj[ind].wms[i].objLayer.length;ii++){if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible==1&&!mb_mapObj[ind].wms[i].objLayer[ii].has_childs){if(cnt_layers>0){layers+=",";styles+=",";}
+layers+=mb_mapObj[ind].wms[i].objLayer[ii].layer_name;styles+="";cnt_layers++;}
+if(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer==1&&!mb_mapObj[ind].wms[i].objLayer[ii].has_childs){if(cnt_querylayers>0){querylayers+=",";}
+querylayers+=mb_mapObj[ind].wms[i].objLayer[ii].layer_name;cnt_querylayers++;}}
+mb_mapObj[ind].layers[i]=layers;mb_mapObj[ind].querylayers[i]=querylayers;mb_mapObj[ind].styles[i]=styles;}}}
+function mb_checkScale(frameName,mObj,wmsObj){var thisLayer=mb_mapObj[mObj].layers[wmsObj].split(",");var thisScale=mb_getScale(frameName);var str_layer="";var cnt_layer=0;for(var i=0;i<mb_mapObj[mObj].wms[wmsObj].objLayer.length;i++){var myLayername=mb_mapObj[mObj].wms[wmsObj].objLayer[i].layer_name;var myMinscale=mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_minscale;var myMaxscale=mb_mapObj[mObj].wms[wmsObj].objLayer[i].gui_layer_maxscale;for(var ii=0;ii<thisLayer.length;ii++){var minscaleOK=false;var maxscaleOK=false;if(thisLayer[ii]==myLayername){if(myMinscale===0||thisScale>=myMinscale){minscaleOK=true;}
+if(myMaxscale===0||thisScale<=myMaxscale){maxscaleOK=true;}
+if(maxscaleOK===true&&minscaleOK===true&&!mb_mapObj[mObj].wms[wmsObj].objLayer[i].has_childs){if(cnt_layer>0){str_layer+=",";}
+str_layer+=thisLayer[ii];cnt_layer++;}}}}
+var str_layerstyles=[];str_layerstyles[0]=str_layer;return str_layerstyles;}
+function setFeatureInfoRequest(fName,x,y,path){var functionName='setFeatureInfoRequest';var ts=mb_timestamp();eventBeforeFeatureInfo.trigger({"fName":fName});var cnt_fi=0;for(i=0;i<mb_mapObj.length;i++){if(mb_mapObj[i].frameName==fName){for(var ii=0;ii<mb_mapObj[i].wms.length;ii++){var newfeatureInfoRequest="";var requestParams="";var validation=false;newfeatureInfoRequest+=mb_mapObj[i].wms[ii].wms_getfeatureinfo;newfeatureInfoRequest+=mb_getConjunctionCharacter(mb_mapObj[i].wms[ii].wms_getfeatureinfo);if(mb_mapObj[i].wms[ii].wms_version=="1.0.0"){requestParams+="WMTVER="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=feature_info&";}
+if(mb_mapObj[i].wms[ii].wms_version!="1.0.0"){requestParams+="VERSION="+mb_mapObj[i].wms[ii].wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS&";}
+requestParams+="SRS="+mb_mapObj[i].epsg+"&";requestParams+="BBOX="+mb_mapObj[i].extent+"&";requestParams+="WIDTH="+mb_mapObj[i].width+"&";requestParams+="HEIGHT="+mb_mapObj[i].height+"&";requestParams+="LAYERS="+mb_mapObj[i].layers[ii]+"&";requestParams+="STYLES="+mb_mapObj[i].styles[ii]+"&";requestParams+="FORMAT="+mb_mapObj[i].wms[ii].gui_wms_mapformat+"&";requestParams+="INFO_FORMAT="+mb_mapObj[i].wms[ii].gui_wms_featureinfoformat+"&";requestParams+="EXCEPTIONS=application/vnd.ogc.se_xml&";if(mb_feature_count>0){requestParams+="FEATURE_COUNT="+mb_feature_count+"&";}
+requestParams+="QUERY_LAYERS="+mb_mapObj[i].querylayers[ii]+"&";requestParams+="X="+x+"&";requestParams+="Y="+y;if(mb_mapObj[i].querylayers[ii]!==""&&mb_mapObj[i].layers[ii]!==""){validation=true;}
+for(var v=0;v<mb_vendorSpecific.length;v++){var vendorSpecificString=eval(mb_vendorSpecific[v]);requestParams+="&"+vendorSpecificString;}
+if(mb_log&&validation){var tmp=eval(mb_log+"('"+newfeatureInfoRequest+requestParams+"','"+ts+"')");}
+if(document.getElementById("FeatureInfoRedirect")&&validation){newfeatureInfoRequest+=requestParams;if(path){window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src=path+"?url="+escape(newfeatureInfoRequest)+"&"+mb_nr;}
+else{window.frames.FeatureInfoRedirect.document.getElementById(mb_mapObj[i].wms[ii].wms_id).src=newfeatureInfoRequest;}
+cnt_fi++;}
+else if(path&&validation){newfeatureInfoRequest+=requestParams;(function(){var currentRequest=newfeatureInfoRequest;mb_ajax_post(path,{'url':currentRequest},function(js_code,status){if(js_code){try{var p=new mb_popup({title:"Feature Info",url:path+"?url="+escape(currentRequest)+"&"+mb_nr,width:600,height:500,top:200,left:600});p.show();}catch(e){window.open(path+"?url="+escape(currentRequest)+"&"+mb_nr,"","width=300,height=400,scrollbars=yes,resizable=yes");}}
+else{var e=new Mb_exception("No featureInfo results.");}});}());cnt_fi++;}
+else if(validation){newfeatureInfoRequest+=requestParams;try{var p=new mb_popup({title:"Feature Info",url:newfeatureInfoRequest,width:600,height:500,top:200,left:600});p.show();}
+catch(e){window.open(newfeatureInfoRequest,"","width=300,height=400,scrollbars=yes,resizable=yes");}
+cnt_fi++;}}}}
+if(cnt_fi===0){alert(unescape("Please select a layer! \n Bitte waehlen Sie eine Ebene zur Abfrage aus!"));}}
+function zoom(frameName,in_,factor,x,y){var obj=getMapObjByName(frameName);if(x&&y){obj.zoom(in_,factor,x,y);}
+else{obj.zoom(in_,factor,false,false);}
+setMapRequest(frameName);}
+function mb_panMap(frameName,dir){var ind=getMapObjIndexByName(frameName);var arrayBBox=mb_mapObj[ind].extent.split(",");var minx=parseFloat(arrayBBox[0]);var miny=parseFloat(arrayBBox[1]);var maxx=parseFloat(arrayBBox[2]);var maxy=parseFloat(arrayBBox[3]);var xtentx=parseFloat(arrayBBox[2])-parseFloat(arrayBBox[0]);var xtenty=parseFloat(arrayBBox[3])-parseFloat(arrayBBox[1]);if(dir=="NW"){minx=minx-(xtentx/2);maxx=maxx-(xtentx/2);miny=miny+(xtenty/2);maxy=maxy+(xtenty/2);}
+if(dir=="N"){miny=miny+(xtenty/2);maxy=maxy+(xtenty/2);}
+if(dir=="NE"){minx=minx+(xtentx/2);maxx=maxx+(xtentx/2);miny=miny+(xtenty/2);maxy=maxy+(xtenty/2);}
+if(dir=="W"){minx=minx-(xtentx/2);maxx=maxx-(xtentx/2);}
+if(dir=="E"){minx=minx+(xtentx/2);maxx=maxx+(xtentx/2);}
+if(dir=="SW"){minx=minx-(xtentx/2);maxx=maxx-(xtentx/2);miny=miny-(xtenty/2);maxy=maxy-(xtenty/2);}
+if(dir=="S"){miny=miny-(xtenty/2);maxy=maxy-(xtenty/2);}
+if(dir=="SE"){minx=minx+(xtentx/2);maxx=maxx+(xtentx/2);miny=miny-(xtenty/2);maxy=maxy-(xtenty/2);}
+mb_mapObj[ind].extent=minx+","+miny+","+maxx+","+maxy;setMapRequest(frameName);}
+function handleSelectedLayer(frameName,wms_title,layerName,type,status){for(var i=0;i<mb_mapObj.length;i++){if(mb_mapObj[i].frameName==frameName){var cnt_layer=0;var str_layer="";var myMapObj=i;for(var ii=0;ii<mb_mapObj[i].wms.length;ii++){if(mb_mapObj[i].wms[ii].wms_title==wms_title){var myWMS=ii;if(type=="visible"){var arrayLayer=mb_mapObj[i].layers[ii].split(",");}
+if(type=="querylayer"){var arrayLayer=mb_mapObj[i].querylayers[ii].split(",");}
+for(var iii=1;iii<mb_mapObj[i].wms[ii].objLayer.length;iii++){var layer_name=mb_mapObj[i].wms[ii].objLayer[iii].layer_name;if(type=="querylayer"){if(layer_name==layerName&&status==1&&mb_mapObj[i].wms[ii].objLayer[iii].layer_queryable==1){if(cnt_layer>0){str_layer+=",";}
+str_layer+=layer_name;cnt_layer++;}}
+else if(type=="visible"){if(layer_name==layerName&&status==1){if(cnt_layer>0){str_layer+=",";}
+for(var iiii=0;iiii<arrayLayer.length;iiii++){if(layer_name==arrayLayer[iiii]&&layer_name!=layerName){if(cnt_layer>0){str_layer+=",";}
+str_layer+=layer_name;cnt_layer++;}}}}}}}
+if(type=="visible"){mb_mapObj[myMapObj].layers[myWMS]=str_layer;var array_str_layer=str_layer.split(",");var str_styles="";for(var cnt=0;cnt<array_str_layer.length;cnt++){if(cnt>0){str_styles+=",";}
+str_styles+="";}
+mb_mapObj[myMapObj].styles[myWMS]=str_styles;}
+if(type=="querylayer"){mb_mapObj[myMapObj].querylayers[myWMS]=str_layer;}}
+function handleSelectedLayer_array(mapObj,array_wms,array_layer,type,status){var ind=getMapObjIndexByName(mapObj);for(var j=0;j<array_wms.length;j++){for(var i=0;i<mb_mapObj[ind].wms.length;i++){if(mb_mapObj[ind].wms[i].wms_id==array_wms[j]){var check=false;for(var ii=0;ii<mb_mapObj[ind].wms[i].objLayer.length;ii++){if(mb_mapObj[ind].wms[i].wms_id==array_wms[j]&&mb_mapObj[ind].wms[i].objLayer[ii].layer_name==array_layer[j]){if(type=="visible"){mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_visible=parseInt(status,10);check=true;}
+if(type=="querylayer"&&(mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable=="1"||mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_queryable==1)){mb_mapObj[ind].wms[i].objLayer[ii].gui_layer_querylayer=parseInt(status,10);}}}
+mb_restateLayers(mapObj,array_wms[j]);if(check===true){if(mb_mapObj[ind].wms[i].gui_wms_visible==1){setSingleMapRequest(mapObj,mb_mapObj[ind].wms[i].wms_id);}}}}}}
+function makeClickPos2RealWorldPos(frameName,myClickX,myClickY){var ind=getMapObjIndexByName(frameName);var width=parseInt(mb_mapObj[ind].width,10);var height=parseInt(mb_mapObj[ind].height,10);var arrayBBox=mb_mapObj[ind].extent.split(",");var minX=parseFloat(arrayBBox[0]);var minY=parseFloat(arrayBBox[1]);var maxX=parseFloat(arrayBBox[2]);var maxY=parseFloat(arrayBBox[3]);var deltaX=(maxX-minX)/width;var deltaY=(maxY-minY)/height;if(deltaX>0){var roundx=1/Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));}
+else{var roundx=Math.pow(10,(Math.round(Math.log(deltaX)/Math.log(10))));}
+if(deltaY>0){var roundy=1/Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));}
+else{var roundy=Math.pow(10,(Math.round(Math.log(deltaY)/Math.log(10))));}
+var xtentx=maxX-minX;var xtenty=maxY-minY;var posX=parseFloat(minX+(myClickX/width)*xtentx);var posY=parseFloat(maxY-(myClickY/height)*xtenty);posX=Math.round(posX*roundx)/roundx;posY=Math.round(posY*roundy)/roundy;return[posX,posY];}
+function makeRealWorld2mapPos(frameName,rw_posx,rw_posy){var ind=getMapObjIndexByName(frameName);var mpObj=mb_mapObj[ind];var arrayBBox=mpObj.extent.split(",");var minX=parseFloat(arrayBBox[0]);var minY=parseFloat(arrayBBox[1]);var maxX=parseFloat(arrayBBox[2]);var maxY=parseFloat(arrayBBox[3]);return[Math.round((rw_posx-minX)*mpObj.width/(maxX-minX)),Math.round((maxY-rw_posy)*mpObj.height/(maxY-minY))];}
+function mb_arrangeElement(frameName,elName,left,top){if(frameName!==""){window.frames[frameName].document.getElementById(elName).style.top=top;window.frames[frameName].document.getElementById(elName).style.left=left;}
+else{document.getElementById(elName).style.top=top;document.getElementById(elName).style.left=left;}}
+function mb_getMousePos(e,fName){if(fName){if(ie){clickX=window.frames[fName].event.clientX;clickY=window.frames[fName].event.clientY;}
+else{clickX=e.pageX;clickY=e.pageY;}}
+else{if(ie){clickX=event.clientX;clickY=event.clientY;}
+var pos=[clickX,clickY];return pos;}
+function getMapObjIndexByName(frameName){for(var i=0;i<mb_mapObj.length;i++){if(mb_mapObj[i].frameName==frameName){return i;}}}
+function getMapObjByName(frameName){for(var i=0;i<mb_mapObj.length;i++){if(mb_mapObj[i].frameName==frameName){return mb_mapObj[i];}}
+return false;}
+function mb_getLayerTitleByName(map_index,wms_index,myLayer_name){for(var i=0;i<mb_mapObj[map_index].wms[wms_index].objLayer.length;i++){if(mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_name==myLayer_name){return mb_mapObj[map_index].wms[wms_index].objLayer[i].layer_title;}}}
+function getWMSIDByTitle(frameName,wms_title){var ind=getMapObjIndexByName(frameName);for(var i=0;i<mb_mapObj[ind].wms.length;i++){if(mb_mapObj[ind].wms[i].wms_title==wms_title){return mb_mapObj[ind].wms[i].wms_id;}}}
+function getWMSIndexByTitle(frameName,wms_title){var ind=getMapObjIndexByName(frameName);for(var i=0;i<mb_mapObj[ind].wms.length;i++){if(mb_mapObj[ind].wms[i].wms_title==wms_title){return i;}}}
+function getWMSIndexById(frameName,wms_id){var ind=getMapObjIndexByName(frameName);for(var i=0;i<mb_mapObj[ind].wms.length;i++){if(mb_mapObj[ind].wms[i].wms_id==wms_id){return i;}}}
+function mb_getScale(frameName){var myScale=eventBeforeGetScale.trigger({"frameName":frameName});if(typeof(myScale)=="number"){var Y_str=myScale;}
+else{var ind=getMapObjIndexByName(frameName);var arrayBBox=mb_mapObj[ind].extent.split(",");var xtenty=parseFloat(arrayBBox[3])-parseFloat(arrayBBox[1]);var scaleY=(xtenty/mb_mapObj[ind].height)*(mb_resolution*100);if(scaleY<1){var Y_str=scaleY;}else{var Y_str=Math.round(scaleY);}}
+return Y_str;}
+function mb_repaintScale(frameName,x,y,scale){var ind=getMapObjIndexByName(frameName);if(x===null&&y===null){var arrayBBox=mb_mapObj[ind].extent.split(",");x=parseFloat(arrayBBox[0])+((parseFloat(arrayBBox[2])-parseFloat(arrayBBox[0]))/2);y=parseFloat(arrayBBox[1])+((parseFloat(arrayBBox[3])-parseFloat(arrayBBox[1]))/2);}
+var minx=parseFloat(x)-(mb_mapObj[ind].width/(mb_resolution*100*2)*scale);var miny=parseFloat(y)-(mb_mapObj[ind].height/(mb_resolution*100*2)*scale);var maxx=parseFloat(x)+(mb_mapObj[ind].width/(mb_resolution*100*2)*scale);var maxy=parseFloat(y)+(mb_mapObj[ind].height/(mb_resolution*100*2)*scale);mb_repaint(frameName,minx,miny,maxx,maxy);}
+function mb_repaint(frameName,minx,miny,maxx,maxy){var ind=getMapObjIndexByName(frameName);mb_mapObj[ind].extent=minx+","+miny+","+maxx+","+maxy;setMapRequest(frameName);}
+function mb_calculateExtent(frameName,minx,miny,maxx,maxy){var map=getMapObjByName(frameName);var extent=new Extent(minx,miny,maxx,maxy);map.calculateExtent(extent);}
+function Extent(minx,miny,maxx,maxy){this.minx=parseFloat(minx);this.miny=parseFloat(miny);this.maxx=parseFloat(maxx);this.maxy=parseFloat(maxy);this.extentx=this.maxx-this.minx;this.extenty=this.maxy-this.miny;this.centerx=this.minx+this.extentx/2;this.centery=this.miny+this.extenty/2;return this;}
+function mb_showHighlight(frameName,x,y){var pos=makeRealWorld2mapPos(frameName,x,y);mb_arrangeElement(frameName,"highlight",pos[0]-7,pos[1]-7);window.frames[frameName].document.getElementById("highlight").style.visibility='visible';}
+function mb_hideHighlight(frameName){mb_arrangeElement(frameName,"highlight",-20,-20);mb_arrangeElement(frameName,"highlight",-20,-20);window.frames[frameName].document.getElementById("highlight").style.visibility='hidden';}
+function mb_permanentHighlight(frameName,x,y){var pos=makeRealWorld2mapPos(frameName,x,y);mb_arrangeElement(frameName,"permanent",pos[0]-7,pos[1]-7);window.frames[frameName].document.getElementById("permanent").style.visibility='visible';}
+function mb_markResult(frameName,geom,col){var x="";var y="";var tmp=[];var ind=getMapObjIndexByName(frameName);for(var i=0;i<geom.length;i++){if(i>0){x+=":";y+=":";}
+tmp=geom[i].split(",");for(var ii=0;ii<tmp.length;ii+=2){var pos=makeRealWorld2mapPos(frameName,tmp[ii],tmp[ii+1]);if(ii>0){x+=",";y+=",";}
+x+=pos[0];y+=pos[1];}}
+var source="<img src='../extensions/markResult.php?x="+x+"&y="+y+"&width="+mb_mapObj[ind].width+"&height="+mb_mapObj[ind].height+"&color="+col+"'>";writeTag(frameName,"markResult",source);}
+function mb_disableResult(frameName){writeTag(frameName,"markResult","");}
+function mb_registerGML(frameName,obj){var ind=getMapObjIndexByName(frameName);mb_mapObj[ind].geom=obj;}
+function mb_timestamp(){var d=new Date();var ts=Math.round(Date.parse(d)/1000);return ts;}
+function mb_getlayerposbyname(objInd,wmsInd,lname){var t=mb_mapObj[objInd].wms[wmsInd];for(var i=0;i<t.objLayer.length;i++){if(t.objLayer[i].layer_name==lname){return t.objLayer[i].layer_pos;}}}
+function mb_getLayerObjByName(fname,wms_id,layer_name){var ind=getMapObjIndexByName(fname);var wmsInd=getWMSIndexById(fname,wms_id);var t=mb_mapObj[ind].wms[wmsInd];for(var i=0;i<t.objLayer.length;i++){if(t.objLayer[i].layer_name==layer_name){return t.objLayer[i];}}}
+function mb_getchildsbyname(objInd,wmsInd,lname){var t=mb_mapObj[objInd].wms[wmsInd];var pos=mb_getlayerposbyname(objInd,wmsInd,lname);var l=[];l.name=[];l.title=[];l.legendurl=[];for(var i=0;i<t.objLayer.length;i++){if(t.objLayer[i].layer_parent==pos){l.name[l.name.length]=t.objLayer[i].layer_name;l.title[l.title.length]=t.objLayer[i].layer_title;if(t.objLayer[i].layer_style.length>0){l.legendurl[l.legendurl.length]=t.objLayer[i].layer_style[0].legendurl;}else{l.legendurl[l.legendurl.length]=0;}}}
+if(l.name.length>0){return l;}
+function DivTag(aTagName,aFrameName,aStyle){this.exists=function(){return(rootNode.getElementById(tagName))?true:false;};this.getTag=function(){return rootNode.getElementById(tagName);};var determineRootNode=function(){node=document;if(frameName!==""){if(checkFrame()){node=window.frames[frameName].document;}
+else{var e=new Mb_exception("frame "+frameName+" doesn't exist.");}}
+return node;};var toCamelCase=function(aString){var newString="";for(var i=0;i<aString.length;i++){if(aString.substr(i,1)!="-"){newString+=aString.substr(i,1);}
+else{i++;newString+=aString.substr(i,1).toUpperCase();}}
+return newString;};this.getRootNode=function(){return rootNode;};var setStyle=function(){if(that.exists()){var node=rootNode.getElementById(tagName);node.setAttribute("style","");for(var attr in tagStyle){if(typeof(tagStyle[attr])!="function"&&typeof(tagStyle[attr])!="object"){var evalString="node.style."+toCamelCase(attr)+" = \""+tagStyle[attr]+"\";";eval(evalString);}}}};var create=function(){if(!that.exists()){var divTag=rootNode.createElement("div");var divTagAppended=rootNode.getElementsByTagName("body")[0].appendChild(divTag);divTagAppended.id=tagName;}
+else{that.clean();}
+setStyle();};var checkFrame=function(){if(frameName!==""){return(typeof(window.frames[frameName])!='undefined');}
+return true;};var that=this;var tagName=aTagName;var frameName=aFrameName;var rootNode=determineRootNode();var tagStyle=aStyle;create();}
+DivTag.prototype.write=function(someText){if(this.exists()){this.getTag().innerHTML=someText;}};DivTag.prototype.clean=function(){this.write("");};var Mb_log=function(){var that=this;var levelArray=global_log_levels.split(",");var log_level=global_mb_log_level;var log_js=global_mb_log_js;var indexOfLevel=function(aLevel){for(var i=0;i<levelArray.length;i++){if(aLevel==levelArray[i]){return i;}}
+return false;};var isValidLevel=function(aLevel){var isNotOff=typeof(log_js)!='undefined'&&log_js!="off";var levelIndex=indexOfLevel(aLevel);var isAppropriate=(typeof(levelIndex)=='number'&&levelIndex<indexOfLevel(log_level));return(isNotOff&&isAppropriate);};this.throwException=function(message,level){if(isValidLevel(level)){if(log_js=="on"){try{mb_ajax_post('../php/mb_js_exception.php',{level:level,text:message});}
+catch(e){alert(e+": "+message);}}
+else if(log_js=="alert"){alert(message);}
+else if(log_js=="console"){if(level=="warning"){console.warn("%s",message);}
+else if(level=="error"){console.error("%s",message);}
+else{console.log("%s",message);}}}};};function Mb_exception(message){var level="error";this.throwException(message,level);}
+Mb_exception.prototype=new Mb_log();function Mb_warning(message){var level="warning";this.throwException(message,level);}
+Mb_warning.prototype=new Mb_log();function Mb_notice(message){var level="notice";this.throwException(message,level);}
+Mb_notice.prototype=new Mb_log();function mb_ajax_get(url,param,callback){try{$.get(url,param,callback);}
+catch(e){var error=new Mb_exception('map.php: mb_ajax_get:'+e);}}
+function mb_ajax_post(url,param,callback){try{$.post(url,param,callback);}
+catch(e){var error=new Mb_exception('map.php: mb_ajax_post:'+e);}}
+function mb_ajax_json(url,param,callback){try{$.getJSON(url,param,callback);}
+catch(e){var error=new Mb_exception('map.php: mb_ajax_json:'+e);}}
+var mb_button=[];function mb_regButton_frame(wii,frameName,param){var ind=mb_button.length;mb_button[ind]=new mb_conButton(wii,ind);if(frameName===null){if(param===null){eval(wii+"("+ind+")");}
+else{eval(wii+"("+ind+", "+param+")");}}
+else if(param===null){eval("window.frames['"+frameName+"']."+wii+"("+ind+")");}
+else{eval("window.frames['"+frameName+"']."+wii+"("+ind+", "+param+")");}
+mb_button[ind].prev=mb_button[ind].src;mb_button[ind].src=mb_button[ind].img_off;mb_button[ind].onmouseover=function(){mb_button_over(ind);};mb_button[ind].onmouseout=function(){mb_button_out(ind);};mb_button[ind].onclick=function(){mb_button_click(ind);};if(frameName===null){mb_button[ind].frameName="";}
+else{mb_button[ind].frameName=frameName;}}
+function mb_regButton(wii){mb_regButton_frame(wii,null,null);}
+function mb_conButton(wii,ind){this.wii=wii;return true;}
+function mb_button_over(ind){if(mb_button[ind].status===0){mb_button[ind].prev=mb_button[ind].src;mb_button[ind].src=mb_button[ind].img_over;}}
+function mb_button_out(ind){if(mb_button[ind].status===0){mb_button[ind].src=mb_button[ind].img_off;}}
+function mb_button_click(ind){var mbStatus=mb_button[ind].status;if(mbStatus===0){mb_disableButton(mb_button[ind].elName);mb_button[ind].prev=mb_button[ind].img_on;mb_button[ind].src=mb_button[ind].img_on;mb_button[ind].status=1;if(mb_button[ind].frameName!==""){window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).go();}
+else{document.getElementById(mb_button[ind].elName).go();}}
+else{mb_button[ind].prev=mb_button[ind].img_off;mb_button[ind].src=mb_button[ind].img_off;mb_button[ind].status=0;if(mb_button[ind].frameName!==""){window.frames[mb_button[ind].frameName].document.getElementById(mb_button[ind].elName).stop();}
+else{document.getElementById(mb_button[ind].elName).stop();}}}
+function mb_disableButton(elName){for(var i=0;i<mb_button.length;i++){if(mb_button[i].elName!=elName&&mb_button[i].status==1){mb_button[i].status=0;if(mb_button[i].frameName!==""){window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).src=mb_button[i].img_off;window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).stop();}
+else{document.getElementById(mb_button[i].elName).src=mb_button[i].img_off;document.getElementById(mb_button[i].elName).stop();}
+return true;}}}
+function mb_disableThisButton(elName){for(var i=0;i<mb_button.length;i++){if(mb_button[i].elName==elName&&mb_button[i].status==1){mb_button[i].status=0;if(mb_button[i].frameName!==""){window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).src=mb_button[i].img_off;window.frames[mb_button[i].frameName].document.getElementById(mb_button[i].elName).stop();}
+return true;}}}
+function updateButtonTooltips(obj){var imageArray=document.getElementsByTagName("img");for(var i=0;i<imageArray.length;i++){for(var j=0;j<obj.length;j++){if(imageArray[i].id==obj[j].id){document.getElementById(imageArray[i].id).title=obj[j].title;}}}}
+function mb_localizeButtons(){mb_ajax_json("../php/mod_button_tooltips.php",function(obj,status){updateButtonTooltips(obj);});}
+eventLocalize.register(function(){mb_localizeButtons();});eventInit.register(function(){eventLocalize.trigger();});function cloneObject(obj){if(typeof obj!=='object'||obj===null){return obj;}
+var c=obj instanceof Array?[]:{};for(var i in obj){var prop=obj[i];if(typeof prop=='object'){if(prop instanceof Array){c[i]=[];for(var j=0;j<prop.length;j++){if(typeof prop[j]!='object'){c[i].push(prop[j]);}else{c[i].push(cloneObject(prop[j]));}}}else{c[i]=cloneObject(prop);}}else{c[i]=prop;}}
+return c;}
+var List=function(){this.count=function(){return this.list.length;};this.del=function(i){i=this.getIndex(i);if(i!==false){for(var z=i;z<this.count()-1;z++){this.list[z]=this.list[z+1];}
+this.list.length-=1;return true;}
+return false;};this.empty=function(){while(this.list!==null&&this.count()>0){this.list.pop();}};this.get=function(i){i=this.getIndex(i);if(i!==false){return this.list[i];}
+return false;};this.add=function(item){var i=this.list.length;this.list[i]=item;};this.addCopy=function(item){this.add(cloneObject(item));};this.union=function(aList){for(var i=0;i<aList.count();i++){this.addCopy(aList.get(i));}};this.getIndex=function(i){var len=this.list.length;if(i<0&&len+i>-1){return len+i;}
+else if(i>-1&&i<len){return i;}
+var e=new Mb_exception("class List: function getIndex: member index "+i+" is not valid");return false;};this.toString=function(){var str="";for(var i=0;i<this.count();i++){str+=this.get(i).toString();}
+return str;};this.list=null;};function mb_checkTag(frameName,tagName,elementId,appendAtTagName,attributes){var oldElement;var newElement;var prefix;if(frameName&&frameName!==""){prefix=window.frames[frameName].document;}
+else if(!frameName||frameName===""){prefix=document;}
+oldElement=prefix.getElementById(elementId);if(oldElement===null){newElement=prefix.createElement(tagName);newElement=prefix.getElementsByTagName(appendAtTagName)[0].appendChild(newElement);}
+else{if(oldElement.nodeName.toLowerCase()==tagName.toLowerCase()){for(var i=0;i<attributes.length;i++){oldElement.setAttribute(attributes[i][0],attributes[i][1]);}
+return oldElement;}
+var newElementAttributeNode=document.createAttribute("id");newElementAttributeNode.value=elementId;newElement.setAttributeNode(newElementAttributeNode);for(var i=0;i<attributes.length;i++){newElement.setAttribute(attributes[i][0],attributes[i][1]);}
+return newElement;}
\ No newline at end of file
Modified: tags/2.5_min/http/javascripts/map_obj.js
--- branches/2.5/http/javascripts/map_obj.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/map_obj.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,781 +1,62 @@
-* $Id$
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-//global variables
-var wms = [];
-var wms_layer_count = 0;
- * global function to add wms to the wms-object
- * @param {String} wms_id the unique id of the wms
- * @param {String} wms_version the version assumed from capabilities
- * @param {String} wms_title the title of the wms
- * @param {String} wms_abstract the abstract of the wms
- * @param {String} wms_getmap the url for map requests
- * @param {String} wms_getfeatureinfo the url for featureInof requests
- * @param {String} wms_getlegendurl the url for legend requests
- * @param {String} wms_filter a filter (deprecated)
- * @param {String} gui_wms_mapformat the image-format in the actual gui
- * @param {String} gui_wms_featureinfoformat the current format for featureInfos
- * @param {String} gui_wms_exceptionformat the exceptionformat for map requests
- * @param {String} gui_wms_epsg the current srs
- * @param {Integer} gui_wms_visible the visibility of this service
- * @param {Integer} gui_wms_opacity the initial display opacity in percent
- * @param {String} gui_wms_sldurl url to an actual sld
-function add_wms(
-			wms_id,
-			wms_version,
-			wms_title,
-			wms_abstract,
-			wms_getmap,
-			wms_getfeatureinfo,
-			wms_getlegendurl,
-			wms_filter,
-			gui_wms_mapformat,
-			gui_wms_featureinfoformat,
-			gui_wms_exceptionformat,
-			gui_wms_epsg,
-			gui_wms_visible,
-			gui_wms_opacity,
-			gui_wms_sldurl){
-					wms[wms.length] = new wms_const(
-					wms_id,
-					wms_version,
-					wms_title,
-					wms_abstract,
-					wms_getmap,
-					wms_getlegendurl,
-					wms_filter,
-					gui_wms_epsg,
-					parseInt(gui_wms_visible, 10),
-					parseInt(gui_wms_opacity),
-					gui_wms_sldurl);
-					wms_layer[wms.length - 1] = [];
- * @class A class representing the wms
- * @constructor
- * @param {String} gui_wms_visible the visibility of this service
-function wms_const(
-			wms_id,
-			wms_version,
-			wms_title,
-			wms_abstract,
-			wms_getmap,
-		    wms_getlegendurl,
-			wms_filter,
-			gui_wms_epsg,
-			gui_wms_visible,
-			gui_wms_opacity,
-			gui_wms_sldurl){
-	if (!wms_id) {
-		var id_ok = false;
-		while (id_ok === false) {
-			wms_id = "a"+Math.round(10000*Math.random());
-			id_ok = true;
-			for (var i=0; i < wms.length && id_ok === true; i++) {
-				if (wms_id == wms[i].wms_id) {
-					id_ok = false;
-	this.wms_id = wms_id;
-	this.wms_version = wms_version;
-	this.wms_title = wms_title;
-	this.wms_abstract = wms_abstract;
-	this.wms_getmap = wms_getmap;
-	this.wms_getfeatureinfo = wms_getfeatureinfo;
-	this.wms_getlegendurl = wms_getlegendurl;
-	this.wms_filter = wms_filter;
-	this.data_type = [];
-	this.data_format = [];
-	this.objLayer = [];
-	this.gui_wms_mapformat = gui_wms_mapformat;
-	this.gui_wms_featureinfoformat = gui_wms_featureinfoformat;
-	this.gui_wms_exceptionformat = gui_wms_exceptionformat;
-	this.gui_wms_epsg = gui_wms_epsg;
-	this.gui_wms_visible = gui_wms_visible;
-	this.gui_epsg = [];
-	this.gui_minx = [];
-	this.gui_miny = [];
-	this.gui_maxx = [];
-	this.gui_maxy = [];
-	// opacity version
-	this.gui_wms_mapopacity = gui_wms_opacity/100;
-	// sld version
-	this.gui_wms_sldurl = gui_wms_sldurl;
- * rephrases the mapRequest
- * @param {Object} mapObj the mapbender mapObject of the wms
- * @return mapRequest, i.e. onlineresource + params
- * @type String
-wms_const.prototype.getMapRequest = function(mapObj){
-	//check visible layers first
-	var layers = this.getLayers(mapObj);
-	if(!layers){
-		return false;
-	var rq = this.wms_getmap;
-	rq += mb_getConjunctionCharacter(this.wms_getmap);
-	if(this.wms_version === "1.0.0"){
-		rq += "WMTVER=" + this.wms_version + "&REQUEST=map";
-	else{
-		rq += "VERSION=" + this.wms_version + "&REQUEST=getMap&SERVICE=WMS";
-	rq += "&LAYERS=" + layers.join(",");
-	rq += "&WIDTH=" + mapObj.getWidth();
-	rq += "&HEIGHT=" + mapObj.getHeight();
-	rq += "&SRS=" + mapObj.getSRS();
-	rq += "&BBOX=" + mapObj.getExtent();
-	rq += "&STYLES=" + this.getLayerstyles(mapObj).join(",");
-	rq += "&FORMAT=" + this.gui_wms_mapformat;
-	rq += "&EXCEPTIONS=" + this.gui_wms_exceptionformat;
-	//Todo: error occurs:
-	//var throwNotice = new Mb_notice("getMapRequest: " + rq);
-	//window.console.log("getMapRequest: " + rq);
-	return rq;
- * rephrases the featureInfoRequest
- * @param {Point} clickPoint map-click position {@link Point}
- * @return featureInfoRequest, onlineresource + params
- * @type string
-wms_const.prototype.getFeatureInfoRequest = function(mapObj, clickPoint){
-	//check layers and querylayers first
-	var querylayers = this.getQuerylayers(mapObj);
-	if(!layers || !querylayers){
-		return false;
-	var rq = this.wms_getfeatureinfo;
-	rq += mb_getConjunctionCharacter(this.wms_getfeatureinfo);
-		rq += "WMTVER=" + this.wms_version + "&REQUEST=feature_info";
-	else{
-		rq += "VERSION=" + this.wms_version + "&REQUEST=GetFeatureInfo&SERVICE=WMS";
-	if(mb_feature_count > 0){
-		rq += "&FEATURE_COUNT="+mb_feature_count;
-	rq += "&QUERY_LAYERS=" + querylayers.join(",");
-	rq += "&INFO_FORMAT=" + this.gui_wms_featureinfoformat;
-	rq += "&EXCEPTIONS=application/vnd.ogc.se_xml";
-	rq += "&X=" + clickPoint.x;
-	rq += "&Y=" + clickPoint.y;
-	//console.log(rq);
-	return rq;
- * sets Opacity of WMS
- * @param {Integer} new opacity percentage value
-wms_const.prototype.setOpacity = function(opacity){
-	//calc new opacity
-	this.gui_wms_mapopacity = parseInt(opacity)/100;
-	if(this.gui_wms_mapopacity>1||isNaN(this.gui_wms_mapopacity))
-		this.gui_wms_mapopacity=1;
-	if(this.gui_wms_mapopacity<0)
-		this.gui_wms_mapopacity=0;
-	if (this.gui_wms_visible > 0) {
-		//get div id
-		var divId = null;
-		for (var i=0; i < wms.length; i++) {
-			if (this.wms_id == wms[i].wms_id) {
-				var divId = 'div_'+i;
-				break;
-		if(!divId)
-			return;
-		//TODO: check if mapframe1 is the right mapframe
-		wmsImage = parent.mapframe1.document.getElementById(divId);
-		if (wmsImage != null) {
-			wmsImage.style.opacity = this.gui_wms_mapopacity;
-			wmsImage.style.MozOpacity = this.gui_wms_mapopacity;
-			wmsImage.style.KhtmlOpacity = this.gui_wms_mapopacity;
-			wmsImage.style.filter = "alpha(opacity=" + this.gui_wms_mapopacity*100 + ")";
- * get all visible layers
- * @return array of layernames
- * @type string[]
-wms_const.prototype.getLayers = function(mapObj){
-	try {
-	//visibility of the wms
-	var wmsIsVisible = (this.gui_wms_visible > 0);
-	if(!wmsIsVisible){
-		return false;
-	visibleLayers = [];
-	for(var i=0; i< this.objLayer.length; i++){
-		var isVisible = (this.objLayer[i].gui_layer_visible === 1);
-		var hasNoChildren = (!this.objLayer[i].has_childs);
-		if (isVisible && hasNoChildren){
-			if(this.objLayer[i].checkScale(mapObj)){
-				//console.log("checkLayer: " + this.objLayer[i].layer_name);
-				visibleLayers.push(this.objLayer[i].layer_name);
-	if(visibleLayers.length === 0){
-		return false;
-	return visibleLayers;
-	catch (e) {
-		alert(e);
- * get the actual style of all visible layers
- * @return commaseparated list of actual layerstyles
- * @type string
-wms_const.prototype.getLayerstyles = function(mapObj){
-	var layerstyles = '';
-	var styles = [];
-	if(layers){
-		for(i = 0; i < layers.length; i++){
-			var style = this.getCurrentStyleByLayerName(layers[i]);
-			if(!style){
-				style = '';
-			styles.push(style);
-		return styles;
-	return false;
- * check if layer is parentLayer
- * @param layername
- * @return the parent value of the given layer
- * @type integer
-wms_const.prototype.checkLayerParentByLayerName = function(layername){
-		if(this.objLayer[i].layer_name == layername){
-			return this.objLayer[i].layer_parent;
- * get the title of the current layer
- * @return the title of the given layer
- * @type string
-wms_const.prototype.getTitleByLayerName = function(layername){
-			return this.objLayer[i].layer_title;
- * get the current style of the layer
- * @return the stylename of the given layer
- * @type string
-wms_const.prototype.getCurrentStyleByLayerName = function(layername){
-			if(this.objLayer[i].gui_layer_style === '' || this.objLayer[i].gui_layer_style === null){
-				return false;
-			else{
-				return this.objLayer[i].gui_layer_style;
- * get the legendurl of the gui layer style
- * @param stylename
- * @return the legendurl of the given style
- * @type string
-wms_const.prototype.getLegendUrlByGuiLayerStyle = function(layername,guiLayerStyle){
-			if(this.objLayer[i].layer_style.length === 0){
-				return false;
-			for(var k=0; k< this.objLayer[i].layer_style.length; k++){
-				if(this.objLayer[i].layer_style[k].name == guiLayerStyle){
-					var legendUrl = this.objLayer[i].layer_style[k].legendurl;
-					if (this.gui_wms_sldurl !== "") {
-					 		legendUrl += "&SLD="+escape(this.gui_wms_sldurl);
-					if(legendUrl !=='' && legendUrl !== null && typeof(legendUrl) != 'undefined'){
-						return legendUrl;
-					else {
-						return false;
-	return false;
- * get all querylayers
- * @type string[]
-wms_const.prototype.getQuerylayers = function(mapObj){
-	queryLayers = [];
-		if(this.objLayer[i].gui_layer_querylayer === 1 && ! this.objLayer[i].has_childs ){
-				queryLayers.push(this.objLayer[i].layer_name);
-	if(queryLayers.length === 0){
-		return false;
-	return queryLayers;
- * get a layer Object by layer_pos
- * @param int payer_pos layer_pos of layer you want to get
- * @return object layer
-wms_const.prototype.getLayerByLayerPos = function(layer_pos){
-	for(var i=0;i<this.objLayer.length;i++){
-		if(this.objLayer[i].layer_pos == layer_pos) {
-			return this.objLayer[i];
-	return null;
- * get the state of sublayers from a specified layer
- * @param int layer_id of the parent layer
- * @param String type "visible" or "querylayer"
- * @return int -1 if state differs else the state
-wms_const.prototype.getSublayerState = function(layer_id, type){
-	var i;
-	var state=-1,value;
-	for(i = 0; i < this.objLayer.length; i++){
-		if(this.objLayer[i].layer_id==layer_id) {
-			break;
-	//go throught sublayers
-	for(var j = i+1; j < this.objLayer.length; j++){
-		if(this.objLayer[i].parent_layer == this.objLayer[j].parent_layer) {
-			break;
-		if(type == "visible") {
-			value = this.objLayer[j].gui_layer_visible;
-		else if(type == "querylayer") {
-			value = this.objLayer[j].gui_layer_querylayer;
-		if(state == -1) {
-			state = value;
-		if(state != value) {
-			return -1;
-	return state;
- * handle change of visibility / quaryability of a layer
- * @param string layer_name of layer to handle
- * @param string type of change ("visible" or "querylayer")
- * @param int value of the change
-wms_const.prototype.handleLayer = function(layer_name, type, value){
-	var i;
-		if(this.objLayer[i].layer_name==layer_name) {
-			break;
-	//Set visibility/queryability of Layer and Sublayers
-	for(var j = i; j < this.objLayer.length; j++){
-		if (i != j && this.objLayer[i].layer_parent >= this.objLayer[j].layer_parent) {
-			break;
-			this.objLayer[j].gui_layer_visible = parseInt(value, 10);
-		else if(type=="querylayer" && this.objLayer[j].gui_layer_queryable) {
-			this.objLayer[j].gui_layer_querylayer = parseInt(value, 10);
-	//Update visibility/queryability of parent layer
-	var parentLayer = this.getLayerByLayerPos(this.objLayer[i].layer_parent);
-	if(parentLayer){
-		var state = this.getSublayerState(parentLayer.layer_id, type);
-		if(state!=-1){
-				this.objLayer[j].gui_layer_visible = state;
-				this.objLayer[j].gui_layer_querylayer = state;
- * move a layer (with his sublayers) up or down
- * @param int layerId layer_id of layer to move
- * @param boolean moveUp true to move up or false to move down
- * @return boolean success
-wms_const.prototype.moveLayer = function(layerId, moveUp){
-	var iLayer=-1;
-	var i;
-	//find layer to move
-	for(i=0;i<this.objLayer.length;i++){
-		if(this.objLayer[i].layer_id==layerId){
-			iLayer=i;
-			break;
-	if(iLayer==-1) {
-		return false;
-	var upperLayer = -1;
-	var lowerLayer = -1;
-	//find layer to swap position with
-	var parentLayer = this.objLayer[iLayer].layer_parent;
-	if(moveUp){
-		lowerLayer = iLayer;
-		//find previous layer on same level
-		for(i=iLayer-1;i>0;i--){
-			if(parentLayer == this.objLayer[i].layer_parent){
-				upperLayer = i;
-				break;
-		if(upperLayer == -1){
-			//alert("The Layer you selected is already on top of parent Layer/WMS");
-			return false;
-	else{
-		upperLayer = iLayer;
-		//find next layer on same level
-		for(i=iLayer+1;i<this.objLayer.length;i++){
-				lowerLayer = i;
-				break;
-		if(lowerLayer == -1){
-			//alert("The Layer you selected is already on bottom of parent Layer/WMS");
-			return false;
-	//calc number of layers to move down
-	var layersDown = lowerLayer - upperLayer;
-	//get number of layers to move up
-	for(i=lowerLayer+1; i<this.objLayer.length; i++){
-			break;
-	var layersUp = i - lowerLayer;
-	//do moving
-	var temp = [];
-	for(i=0;i<layersDown+layersUp;i++){
-		temp[temp.length]=this.objLayer[upperLayer+i];
-	for(i=0;i<layersUp;i++){
-		this.objLayer[upperLayer+i]=temp[i+layersDown];
-	for(i=0;i<layersDown;i++){
-		this.objLayer[upperLayer+layersUp+i]=temp[i];
-	return true;
-function wms_add_data_type_format(datatype,dataformat){
-	var insertDataFormat = true;
-	for (var i = 0 ; i < wms[wms.length-1].data_type.length ; i ++) {
-		if (wms[wms.length-1].data_type[i] == datatype && wms[wms.length-1].data_format[i] == dataformat) {
-			insertDataFormat = false;
-	if (insertDataFormat === true) {
-		wms[wms.length-1].data_type[wms[wms.length-1].data_type.length] = datatype;
-		wms[wms.length-1].data_format[wms[wms.length-1].data_format.length] = dataformat;
-function wms_addSRS(epsg,minx,miny,maxx,maxy){
-	wms[wms.length-1].gui_epsg[wms[wms.length-1].gui_epsg.length] = epsg;
-	wms[wms.length-1].gui_minx[wms[wms.length-1].gui_minx.length] = minx;
-	wms[wms.length-1].gui_miny[wms[wms.length-1].gui_miny.length] = miny;
-	wms[wms.length-1].gui_maxx[wms[wms.length-1].gui_maxx.length] = maxx;
-	wms[wms.length-1].gui_maxy[wms[wms.length-1].gui_maxy.length] = maxy;
-function wms_addLayerStyle(styleName, styleTitle, count, layerCount, styleLegendUrl, styleLegendUrlFormat){
-	var currentLayer = wms[wms.length-1].objLayer[layerCount];
-	if (currentLayer) {
-		currentLayer.layer_style[count] = {};
-		currentLayer.layer_style[count].name = styleName;
-		currentLayer.layer_style[count].title = styleTitle;
-		currentLayer.layer_style[count].legendurl = styleLegendUrl;
-		currentLayer.layer_style[count].legendurlformat = styleLegendUrlFormat;
-//TODO: add layerstyle handling....
-//layer
-function wms_add_layer(
-			layer_parent,
-			layer_uid,
-			layer_name,
-			layer_title,
-			layer_dataurl_href,
-			layer_pos,
-			layer_queryable,
-			layer_minscale,
-			layer_maxscale,
-			layer_metadataurl,
-			gui_layer_wms_id,
-			gui_layer_status,
-			gui_layer_style,
-			gui_layer_selectable,
-			gui_layer_visible,
-			gui_layer_queryable,
-			gui_layer_querylayer,
-			gui_layer_minscale,
-			gui_layer_maxscale,
-			gui_layer_wfs_featuretype){
-	wms[wms.length-1].objLayer[wms[wms.length-1].objLayer.length] = new wms_layer(
-											layer_parent,
-											layer_uid,
-											layer_name,
-											layer_title,
-											layer_pos,
-											layer_queryable,
-											layer_minscale,
-											layer_maxscale,
-											gui_layer_wms_id,
-											gui_layer_status,
-											gui_layer_style,
-											parseInt(gui_layer_selectable, 10),
-											parseInt(gui_layer_visible, 10),
-											parseInt(gui_layer_queryable, 10),
-											parseInt(gui_layer_querylayer, 10),
-											parseInt(gui_layer_minscale, 10),
-											parseInt(gui_layer_maxscale, 10),
-											gui_layer_wfs_featuretype );
-	var parentLayer = wms[wms.length-1].getLayerByLayerPos(parseInt(layer_parent, 10));
-	if(parentLayer) {
-		parentLayer.has_childs = true;
-function layer_addEpsg(epsg,minx,miny,maxx,maxy){
-	var j = wms[wms.length-1].objLayer.length-1;
-	var k = wms[wms.length-1].objLayer[j].layer_epsg.length;
-	var currentLayer = wms[wms.length-1].objLayer[j];
-	currentLayer.layer_epsg[k]={};
-	currentLayer.layer_epsg[k].epsg = epsg;
-	currentLayer.layer_epsg[k].minx = minx;
-	currentLayer.layer_epsg[k].miny = miny;
-	currentLayer.layer_epsg[k].maxx = maxx;
-	currentLayer.layer_epsg[k].maxy = maxy;
-function wms_layer(
-			layer_parent,
-			wms_layer_uid,
-			layer_name,
-			layer_title,
-			layer_pos,
-			layer_queryable,
-			layer_minscale,
-			layer_maxscale,
-			gui_layer_wms_id,
-			gui_layer_status,
-			gui_layer_style,
-	this.layer_id = wms_layer_count;
-	this.layer_uid = wms_layer_uid;
-	this.layer_parent = layer_parent;
-	this.layer_name = layer_name;
-	this.layer_title = layer_title;
-	this.layer_dataurl_href = layer_dataurl_href;
-	this.layer_pos = layer_pos;
-	this.layer_queryable = layer_queryable;
-	this.layer_minscale = layer_minscale;
-	this.layer_maxscale = layer_maxscale;
-	this.layer_metadataurl = layer_metadataurl;
-	this.layer_epsg = [];
-	this.gui_layer_wms_id = gui_layer_wms_id;
-	this.gui_layer_status = gui_layer_status;
-	this.gui_layer_selectable = gui_layer_selectable;
-	this.gui_layer_visible = gui_layer_visible;
-	this.gui_layer_queryable = gui_layer_queryable;
-	this.gui_layer_querylayer = gui_layer_querylayer;
-	this.gui_layer_minscale = gui_layer_minscale;
-	this.gui_layer_maxscale = gui_layer_maxscale;
-	this.gui_layer_style = gui_layer_style;
-	this.gui_layer_wfs_featuretype = gui_layer_wfs_featuretype;
-	this.gui_layer_style = null;
-	this.has_childs = false;
-	this.layer_style = [];
-	wms_layer_count++;
- * check the scale of the layer
- * @param Object mapObj the mapbender mapObject of the layer
- * @return boolean if the layer is in scale or not
- * @type boolean
-wms_layer.prototype.checkScale = function(mapObj){
-	var minScale = parseInt(this.gui_layer_minscale, 10);
-	var maxScale = parseInt(this.gui_layer_maxscale, 10);
-	var currentScale = parseInt(mapObj.getScale(), 10);
-	if(minScale === 0 && maxScale === 0){
-		return true;
-	if(minScale > currentScale || (maxScale !== 0 && maxScale < currentScale)) {
-		return false;
-	return true;
- * set visibility of the layer
- * @param boolean visible visibility on/off
-wms_layer.prototype.setVisible = function(visible){
-	this.gui_layer_visible = parseInt(visible, 10);
-	//console.log("setVisible(%i) for Layer %s",visible, this.layer_name);
- * set queryability of the layer
- * @param boolean queryable queryability on/off
-wms_layer.prototype.setQueryable = function(queryable){
-	this.gui_layer_querylayer = parseInt(queryable, 10);
-	//console.log("setQueryable(%i) for Layer %s",queryable, this.layer_name);
+var wms=[];var wms_layer_count=0;function add_wms(wms_id,wms_version,wms_title,wms_abstract,wms_getmap,wms_getfeatureinfo,wms_getlegendurl,wms_filter,gui_wms_mapformat,gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible,gui_wms_opacity,gui_wms_sldurl){wms[wms.length]=new wms_const(wms_id,wms_version,wms_title,wms_abstract,wms_getmap,wms_getfeatureinfo,wms_getlegendurl,wms_filter,gui_wms_mapformat,gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,parseInt(gui_wms_visible,10),parseInt(gui_wms_opacity),gui_wms_sldurl);wms_layer[wms.length-1]=[];}
+function wms_const(wms_id,wms_version,wms_title,wms_abstract,wms_getmap,wms_getfeatureinfo,wms_getlegendurl,wms_filter,gui_wms_mapformat,gui_wms_featureinfoformat,gui_wms_exceptionformat,gui_wms_epsg,gui_wms_visible,gui_wms_opacity,gui_wms_sldurl){if(!wms_id){var id_ok=false;while(id_ok===false){wms_id="a"+Math.round(10000*Math.random());id_ok=true;for(var i=0;i<wms.length&&id_ok===true;i++){if(wms_id==wms[i].wms_id){id_ok=false;}}}}
+this.wms_id=wms_id;this.wms_version=wms_version;this.wms_title=wms_title;this.wms_abstract=wms_abstract;this.wms_getmap=wms_getmap;this.wms_getfeatureinfo=wms_getfeatureinfo;this.wms_getlegendurl=wms_getlegendurl;this.wms_filter=wms_filter;this.data_type=[];this.data_format=[];this.objLayer=[];this.gui_wms_mapformat=gui_wms_mapformat;this.gui_wms_featureinfoformat=gui_wms_featureinfoformat;this.gui_wms_exceptionformat=gui_wms_exceptionformat;this.gui_wms_epsg=gui_wms_epsg;this.gui_wms_visible=gui_wms_visible;this.gui_epsg=[];this.gui_minx=[];this.gui_miny=[];this.gui_maxx=[];this.gui_maxy=[];this.gui_wms_mapopacity=gui_wms_opacity/100;this.gui_wms_sldurl=gui_wms_sldurl;}
+wms_const.prototype.getMapRequest=function(mapObj){var layers=this.getLayers(mapObj);if(!layers){return false;}
+var rq=this.wms_getmap;rq+=mb_getConjunctionCharacter(this.wms_getmap);if(this.wms_version==="1.0.0"){rq+="WMTVER="+this.wms_version+"&REQUEST=map";}
+else{rq+="VERSION="+this.wms_version+"&REQUEST=getMap&SERVICE=WMS";}
+rq+="&LAYERS="+layers.join(",");rq+="&WIDTH="+mapObj.getWidth();rq+="&HEIGHT="+mapObj.getHeight();rq+="&SRS="+mapObj.getSRS();rq+="&BBOX="+mapObj.getExtent();rq+="&STYLES="+this.getLayerstyles(mapObj).join(",");rq+="&FORMAT="+this.gui_wms_mapformat;rq+="&EXCEPTIONS="+this.gui_wms_exceptionformat;return rq;};wms_const.prototype.getFeatureInfoRequest=function(mapObj,clickPoint){var layers=this.getLayers(mapObj);var querylayers=this.getQuerylayers(mapObj);if(!layers||!querylayers){return false;}
+var rq=this.wms_getfeatureinfo;rq+=mb_getConjunctionCharacter(this.wms_getfeatureinfo);if(this.wms_version==="1.0.0"){rq+="WMTVER="+this.wms_version+"&REQUEST=feature_info";}
+else{rq+="VERSION="+this.wms_version+"&REQUEST=GetFeatureInfo&SERVICE=WMS";}
+rq+="&LAYERS="+layers.join(",");if(mb_feature_count>0){rq+="&FEATURE_COUNT="+mb_feature_count;}
+rq+="&QUERY_LAYERS="+querylayers.join(",");rq+="&WIDTH="+mapObj.getWidth();rq+="&HEIGHT="+mapObj.getHeight();rq+="&SRS="+mapObj.getSRS();rq+="&BBOX="+mapObj.getExtent();rq+="&STYLES="+this.getLayerstyles(mapObj).join(",");rq+="&FORMAT="+this.gui_wms_mapformat;rq+="&INFO_FORMAT="+this.gui_wms_featureinfoformat;rq+="&EXCEPTIONS=application/vnd.ogc.se_xml";rq+="&X="+clickPoint.x;rq+="&Y="+clickPoint.y;return rq;};wms_const.prototype.setOpacity=function(opacity){this.gui_wms_mapopacity=parseInt(opacity)/100;if(this.gui_wms_mapopacity>1||isNaN(this.gui_wms_mapopacity))
+this.gui_wms_mapopacity=1;if(this.gui_wms_mapopacity<0)
+this.gui_wms_mapopacity=0;if(this.gui_wms_visible>0){var divId=null;for(var i=0;i<wms.length;i++){if(this.wms_id==wms[i].wms_id){var divId='div_'+i;break;}}
+if(!divId)
+return;wmsImage=parent.mapframe1.document.getElementById(divId);if(wmsImage!=null){wmsImage.style.opacity=this.gui_wms_mapopacity;wmsImage.style.MozOpacity=this.gui_wms_mapopacity;wmsImage.style.KhtmlOpacity=this.gui_wms_mapopacity;wmsImage.style.filter="alpha(opacity="+this.gui_wms_mapopacity*100+")";}}}
+wms_const.prototype.getLayers=function(mapObj){try{var wmsIsVisible=(this.gui_wms_visible>0);if(!wmsIsVisible){return false;}
+visibleLayers=[];for(var i=0;i<this.objLayer.length;i++){var isVisible=(this.objLayer[i].gui_layer_visible===1);var hasNoChildren=(!this.objLayer[i].has_childs);if(isVisible&&hasNoChildren){if(this.objLayer[i].checkScale(mapObj)){visibleLayers.push(this.objLayer[i].layer_name);}}}
+if(visibleLayers.length===0){return false;}
+return visibleLayers;}
+catch(e){alert(e);}};wms_const.prototype.getLayerstyles=function(mapObj){var layers=this.getLayers(mapObj);var layerstyles='';var styles=[];if(layers){for(i=0;i<layers.length;i++){var style=this.getCurrentStyleByLayerName(layers[i]);if(!style){style='';}
+styles.push(style);}
+return styles;}
+return false;};wms_const.prototype.checkLayerParentByLayerName=function(layername){for(var i=0;i<this.objLayer.length;i++){if(this.objLayer[i].layer_name==layername){return this.objLayer[i].layer_parent;}}};wms_const.prototype.getTitleByLayerName=function(layername){for(var i=0;i<this.objLayer.length;i++){if(this.objLayer[i].layer_name==layername){return this.objLayer[i].layer_title;}}};wms_const.prototype.getCurrentStyleByLayerName=function(layername){for(var i=0;i<this.objLayer.length;i++){if(this.objLayer[i].layer_name==layername){if(this.objLayer[i].gui_layer_style===''||this.objLayer[i].gui_layer_style===null){return false;}
+else{return this.objLayer[i].gui_layer_style;}}}};wms_const.prototype.getLegendUrlByGuiLayerStyle=function(layername,guiLayerStyle){for(var i=0;i<this.objLayer.length;i++){if(this.objLayer[i].layer_name==layername){if(this.objLayer[i].layer_style.length===0){return false;}
+for(var k=0;k<this.objLayer[i].layer_style.length;k++){if(this.objLayer[i].layer_style[k].name==guiLayerStyle){var legendUrl=this.objLayer[i].layer_style[k].legendurl;if(this.gui_wms_sldurl!==""){legendUrl+="&SLD="+escape(this.gui_wms_sldurl);}
+if(legendUrl!==''&&legendUrl!==null&&typeof(legendUrl)!='undefined'){return legendUrl;}
+else{return false;}}}}}
+return false;};wms_const.prototype.getQuerylayers=function(mapObj){queryLayers=[];for(var i=0;i<this.objLayer.length;i++){if(this.objLayer[i].gui_layer_querylayer===1&&!this.objLayer[i].has_childs){if(this.objLayer[i].checkScale(mapObj)){queryLayers.push(this.objLayer[i].layer_name);}}}
+if(queryLayers.length===0){return false;}
+return queryLayers;};wms_const.prototype.getLayerByLayerPos=function(layer_pos){for(var i=0;i<this.objLayer.length;i++){if(this.objLayer[i].layer_pos==layer_pos){return this.objLayer[i];}}
+return null;};wms_const.prototype.getSublayerState=function(layer_id,type){var i;var state=-1,value;for(i=0;i<this.objLayer.length;i++){if(this.objLayer[i].layer_id==layer_id){break;}}
+for(var j=i+1;j<this.objLayer.length;j++){if(this.objLayer[i].parent_layer==this.objLayer[j].parent_layer){break;}
+if(type=="visible"){value=this.objLayer[j].gui_layer_visible;}
+else if(type=="querylayer"){value=this.objLayer[j].gui_layer_querylayer;}
+if(state==-1){state=value;}
+if(state!=value){return-1;}}
+return state;};wms_const.prototype.handleLayer=function(layer_name,type,value){var i;for(i=0;i<this.objLayer.length;i++){if(this.objLayer[i].layer_name==layer_name){break;}}
+for(var j=i;j<this.objLayer.length;j++){if(i!=j&&this.objLayer[i].layer_parent>=this.objLayer[j].layer_parent){break;}
+if(type=="visible"){this.objLayer[j].gui_layer_visible=parseInt(value,10);}
+else if(type=="querylayer"&&this.objLayer[j].gui_layer_queryable){this.objLayer[j].gui_layer_querylayer=parseInt(value,10);}}
+var parentLayer=this.getLayerByLayerPos(this.objLayer[i].layer_parent);if(parentLayer){var state=this.getSublayerState(parentLayer.layer_id,type);if(state!=-1){if(type=="visible"){this.objLayer[j].gui_layer_visible=state;}
+else if(type=="querylayer"&&this.objLayer[j].gui_layer_queryable){this.objLayer[j].gui_layer_querylayer=state;}}}};wms_const.prototype.moveLayer=function(layerId,moveUp){var iLayer=-1;var i;for(i=0;i<this.objLayer.length;i++){if(this.objLayer[i].layer_id==layerId){iLayer=i;break;}}
+if(iLayer==-1){return false;}
+var upperLayer=-1;var lowerLayer=-1;var parentLayer=this.objLayer[iLayer].layer_parent;if(moveUp){lowerLayer=iLayer;for(i=iLayer-1;i>0;i--){if(parentLayer==this.objLayer[i].layer_parent){upperLayer=i;break;}}
+if(upperLayer==-1){return false;}}
+else{upperLayer=iLayer;for(i=iLayer+1;i<this.objLayer.length;i++){if(parentLayer==this.objLayer[i].layer_parent){lowerLayer=i;break;}}
+if(lowerLayer==-1){return false;}}
+var layersDown=lowerLayer-upperLayer;for(i=lowerLayer+1;i<this.objLayer.length;i++){if(parentLayer==this.objLayer[i].layer_parent){break;}}
+var layersUp=i-lowerLayer;var temp=[];for(i=0;i<layersDown+layersUp;i++){temp[temp.length]=this.objLayer[upperLayer+i];}
+for(i=0;i<layersUp;i++){this.objLayer[upperLayer+i]=temp[i+layersDown];}
+for(i=0;i<layersDown;i++){this.objLayer[upperLayer+layersUp+i]=temp[i];}
+return true;};function wms_add_data_type_format(datatype,dataformat){var insertDataFormat=true;for(var i=0;i<wms[wms.length-1].data_type.length;i++){if(wms[wms.length-1].data_type[i]==datatype&&wms[wms.length-1].data_format[i]==dataformat){insertDataFormat=false;}}
+if(insertDataFormat===true){wms[wms.length-1].data_type[wms[wms.length-1].data_type.length]=datatype;wms[wms.length-1].data_format[wms[wms.length-1].data_format.length]=dataformat;}}
+function wms_addSRS(epsg,minx,miny,maxx,maxy){wms[wms.length-1].gui_epsg[wms[wms.length-1].gui_epsg.length]=epsg;wms[wms.length-1].gui_minx[wms[wms.length-1].gui_minx.length]=minx;wms[wms.length-1].gui_miny[wms[wms.length-1].gui_miny.length]=miny;wms[wms.length-1].gui_maxx[wms[wms.length-1].gui_maxx.length]=maxx;wms[wms.length-1].gui_maxy[wms[wms.length-1].gui_maxy.length]=maxy;}
+function wms_addLayerStyle(styleName,styleTitle,count,layerCount,styleLegendUrl,styleLegendUrlFormat){var currentLayer=wms[wms.length-1].objLayer[layerCount];if(currentLayer){currentLayer.layer_style[count]={};currentLayer.layer_style[count].name=styleName;currentLayer.layer_style[count].title=styleTitle;currentLayer.layer_style[count].legendurl=styleLegendUrl;currentLayer.layer_style[count].legendurlformat=styleLegendUrlFormat;}}
+function wms_add_layer(layer_parent,layer_uid,layer_name,layer_title,layer_dataurl_href,layer_pos,layer_queryable,layer_minscale,layer_maxscale,layer_metadataurl,gui_layer_wms_id,gui_layer_status,gui_layer_style,gui_layer_selectable,gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,gui_layer_wfs_featuretype){wms[wms.length-1].objLayer[wms[wms.length-1].objLayer.length]=new wms_layer(layer_parent,layer_uid,layer_name,layer_title,layer_dataurl_href,layer_pos,layer_queryable,layer_minscale,layer_maxscale,layer_metadataurl,gui_layer_wms_id,gui_layer_status,gui_layer_style,parseInt(gui_layer_selectable,10),parseInt(gui_layer_visible,10),parseInt(gui_layer_queryable,10),parseInt(gui_layer_querylayer,10),parseInt(gui_layer_minscale,10),parseInt(gui_layer_maxscale,10),gui_layer_wfs_featuretype);var parentLayer=wms[wms.length-1].getLayerByLayerPos(parseInt(layer_parent,10));if(parentLayer){parentLayer.has_childs=true;}}
+function layer_addEpsg(epsg,minx,miny,maxx,maxy){var j=wms[wms.length-1].objLayer.length-1;var k=wms[wms.length-1].objLayer[j].layer_epsg.length;var currentLayer=wms[wms.length-1].objLayer[j];currentLayer.layer_epsg[k]={};currentLayer.layer_epsg[k].epsg=epsg;currentLayer.layer_epsg[k].minx=minx;currentLayer.layer_epsg[k].miny=miny;currentLayer.layer_epsg[k].maxx=maxx;currentLayer.layer_epsg[k].maxy=maxy;}
+function wms_layer(layer_parent,wms_layer_uid,layer_name,layer_title,layer_dataurl_href,layer_pos,layer_queryable,layer_minscale,layer_maxscale,layer_metadataurl,gui_layer_wms_id,gui_layer_status,gui_layer_style,gui_layer_selectable,gui_layer_visible,gui_layer_queryable,gui_layer_querylayer,gui_layer_minscale,gui_layer_maxscale,gui_layer_wfs_featuretype){this.layer_id=wms_layer_count;this.layer_uid=wms_layer_uid;this.layer_parent=layer_parent;this.layer_name=layer_name;this.layer_title=layer_title;this.layer_dataurl_href=layer_dataurl_href;this.layer_pos=layer_pos;this.layer_queryable=layer_queryable;this.layer_minscale=layer_minscale;this.layer_maxscale=layer_maxscale;this.layer_metadataurl=layer_metadataurl;this.layer_epsg=[];this.gui_layer_wms_id=gui_layer_wms_id;this.gui_layer_status=gui_layer_status;this.gui_layer_selectable=gui_layer_selectable;this.gui_layer_visible=gui_layer_visible;this.gui_layer_queryable=gui_layer_queryable;this.gui_layer_querylayer=gui_layer_querylayer;this.gui_layer_minscale=gui_layer_minscale;this.gui_layer_maxscale=gui_layer_maxscale;this.gui_layer_style=gui_layer_style;this.gui_layer_wfs_featuretype=gui_layer_wfs_featuretype;this.gui_layer_style=null;this.has_childs=false;this.layer_style=[];wms_layer_count++;}
+wms_layer.prototype.checkScale=function(mapObj){var minScale=parseInt(this.gui_layer_minscale,10);var maxScale=parseInt(this.gui_layer_maxscale,10);var currentScale=parseInt(mapObj.getScale(),10);if(minScale===0&&maxScale===0){return true;}
+if(minScale>currentScale||(maxScale!==0&&maxScale<currentScale)){return false;}
+return true;};wms_layer.prototype.setVisible=function(visible){this.gui_layer_visible=parseInt(visible,10);};wms_layer.prototype.setQueryable=function(queryable){this.gui_layer_querylayer=parseInt(queryable,10);};
Modified: tags/2.5_min/http/javascripts/mod_addWMSgeneralFunctions.js
--- branches/2.5/http/javascripts/mod_addWMSgeneralFunctions.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_addWMSgeneralFunctions.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,17 +1,6 @@
-function mod_addWMS_load(caps){
-	window.frames['loadData'].document.location.href = "../php/mod_createJSObjFromXML.php?caps=" + encodeURIComponent(caps);
-function mod_addLayer_load(caps,layer_name){
-	var url = "../php/mod_createJSLayerObjFromXML.php?caps=" + encodeURIComponent(caps) + "&layer_name=" + encodeURIComponent(layer_name);
-	window.frames['loadData'].document.location.href = url;
-function mod_addWMSById_load(gui_id, wms_id){
-	window.frames['loadData'].document.location.href = "../php/mod_createJSObjFromDBByWMS.php?wms_id=" + wms_id + "&gui_id=" + gui_id;
-function mod_addWMS_refresh(){
-	mb_mapObjaddWMS('mapframe1')
-	zoom('mapframe1', true, 0.999);
+function mod_addWMS_load(caps){window.frames['loadData'].document.location.href="../php/mod_createJSObjFromXML.php?caps="+encodeURIComponent(caps);}
+function mod_addLayer_load(caps,layer_name){var url="../php/mod_createJSLayerObjFromXML.php?caps="+encodeURIComponent(caps)+"&layer_name="+encodeURIComponent(layer_name);window.frames['loadData'].document.location.href=url;}
+function mod_addWMSById_load(gui_id,wms_id){window.frames['loadData'].document.location.href="../php/mod_createJSObjFromDBByWMS.php?wms_id="+wms_id+"&gui_id="+gui_id;}
+function mod_addWMS_refresh(){mb_mapObjaddWMS('mapframe1')
+zoom('mapframe1',true,0.999);}
Modified: tags/2.5_min/http/javascripts/mod_adminNavigation.js
--- branches/2.5/http/javascripts/mod_adminNavigation.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_adminNavigation.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,12 +1,4 @@
-function mod_adminNavigation_init(){
-	eventInit.trigger();
-	for (var i=0; i< document.getElementsByTagName("a").length; i++){
-		document.getElementsByTagName("a")[i].onclick = new Function("mod_adminNavigation(this)");
-function mod_adminNavigation(obj){
-		document.getElementsByTagName("a")[i].style.color = "#808080";
-	obj.style.color = "#0000ff";
+function mod_adminNavigation_init(){eventInit.trigger();for(var i=0;i<document.getElementsByTagName("a").length;i++){document.getElementsByTagName("a")[i].onclick=new Function("mod_adminNavigation(this)");}}
+function mod_adminNavigation(obj){for(var i=0;i<document.getElementsByTagName("a").length;i++){document.getElementsByTagName("a")[i].style.color="#808080";}
+obj.style.color="#0000ff";}
Modified: tags/2.5_min/http/javascripts/mod_box1.js
--- branches/2.5/http/javascripts/mod_box1.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_box1.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,138 +1,23 @@
-* $Id$
-var mb_isActive = false;
-var mb_isBF = false;
-var mb_zF = false;
-function  mod_box_start(e){
-	mb_isActive = true;
-	mb_getMousePos(e,mb_isBF);
-	mb_start_x = clickX;
-	mb_start_y = clickY;
-	mb_end_x = mb_start_x+1;
-	mb_end_y = mb_start_y+1;
-	mb_offset_left = mb_start_x;
-	mb_offset_top = mb_start_y;
-	mb_offset_bottom = mb_start_y;
-	mb_offset_right = mb_start_x;
-	mb_drawBox(mb_start_x,mb_start_y,mb_end_x,mb_end_y);
-	return false;
-function mod_box_run(e){
-	if(mb_isActive){
-		for(var i=0; i<mb_mapObj.length; i++){
-			if(mb_mapObj[i].frameName == mb_isBF){
-				var width = mb_mapObj[i].width;
-				var height = mb_mapObj[i].height;
-		if (((clickX>width) || (clickY>height) || (clickX<=0) ||(clickY<=0))){
-			isActive = false;
-			mod_box_stop(e);
-		else{
-			mb_end_x=clickX;
-			mb_end_y=clickY;
-			evalExtent();
-		return false;
-function mod_box_stop(e){
-	mb_hideElement("l_top");
-	mb_hideElement("l_left");
-	mb_hideElement("l_right");
-	mb_hideElement("l_bottom");
-	if(mb_isActive){
-		mb_isActive = false;
-		return mb_setMapExtent(mb_start_x,mb_start_y,mb_end_x,mb_end_y);
-function mb_drawBox(left,top,right,bottom){
-	mb_arrangeBox("l_top",left,top,right,top+2);
-	mb_arrangeBox("l_left",left,top,left+2,bottom);
-	mb_arrangeBox("l_right",right-2,top,right,bottom);
-	mb_arrangeBox("l_bottom",left,bottom-2,right,bottom);
-	mb_displayElement("l_top");
-	mb_displayElement("l_left");
-	mb_displayElement("l_right");
-	mb_displayElement("l_bottom");
-function mb_arrangeBox(name, left, top, right, bottom){
-	var el = window.frames[mb_isBF].document.getElementById(name).style;
-	el.height = Math.abs(bottom - top);
-	el.width = Math.abs(right - left);
-	el.top = top + "px";
-	el.left = left + "px";
-function mb_displayElement(name){
-	window.frames[mb_isBF].document.getElementById(name).style.visibility = "visible";
-function mb_hideElement(name) {
-	window.frames[mb_isBF].document.getElementById(name).style.visibility = "hidden";
-function evalExtent(){
-	if(mb_start_x>mb_end_x){
-		mb_offset_right=mb_start_x;
-		mb_offset_left=mb_end_x;
-	else{
-		mb_offset_left=mb_start_x;
-		mb_offset_right=mb_end_x;
-	if(mb_start_y>mb_end_y){
-		mb_offset_bottom=mb_start_y;
-		mb_offset_top=mb_end_y;
-	else{
-		mb_offset_top=mb_start_y;
-		mb_offset_bottom=mb_end_y;
-	if((mb_start_x != mb_end_x)&&(mb_start_y != mb_end_y)){
-		mb_drawBox(mb_offset_left,mb_offset_top,mb_offset_right,mb_offset_bottom);
-function mb_setMapExtent(x1,y1,x2,y2){
-	if(x1 < x2){
-		var minx = x1;
-		var maxx = x2;
-	else{
-		var minx = x2;
-		var maxx = x1;
-	if(y1 < y2){
-		var miny = y2;
-		var maxy = y1;
-	else{
-		var miny = y1;
-		var maxy = y2;
-   // area or clickpoint ?
-	var ret = [];
-	if((maxx - minx) > 3 && (miny - maxy) > 3){
-		var posMin = makeClickPos2RealWorldPos(mb_isBF,minx,miny);
-		var posMax = makeClickPos2RealWorldPos(mb_isBF,maxx,maxy);
-		ret[0] = posMin[0];
-		ret[1] = posMin[1];
-		ret[2] = posMax[0];
-		ret[3] = posMax[1];
-		return ret;
-	// mb_setValidClipping(posMin[0],posMin[1],posMax[0], posMax[1]);
-	else{
-		return ret;
-		//zoom(mb_zF,true,1.0,pos[0], pos[1]);
+var mb_isActive=false;var mb_isBF=false;var mb_zF=false;function mod_box_start(e){mb_isActive=true;mb_getMousePos(e,mb_isBF);mb_start_x=clickX;mb_start_y=clickY;mb_end_x=mb_start_x+1;mb_end_y=mb_start_y+1;mb_offset_left=mb_start_x;mb_offset_top=mb_start_y;mb_offset_bottom=mb_start_y;mb_offset_right=mb_start_x;mb_drawBox(mb_start_x,mb_start_y,mb_end_x,mb_end_y);return false;}
+function mod_box_run(e){if(mb_isActive){mb_getMousePos(e,mb_isBF);for(var i=0;i<mb_mapObj.length;i++){if(mb_mapObj[i].frameName==mb_isBF){var width=mb_mapObj[i].width;var height=mb_mapObj[i].height;}}
+if(((clickX>width)||(clickY>height)||(clickX<=0)||(clickY<=0))){isActive=false;mod_box_stop(e);}
+else{mb_end_x=clickX;mb_end_y=clickY;evalExtent();}
+return false;}}
+function mod_box_stop(e){mb_hideElement("l_top");mb_hideElement("l_left");mb_hideElement("l_right");mb_hideElement("l_bottom");if(mb_isActive){mb_isActive=false;return mb_setMapExtent(mb_start_x,mb_start_y,mb_end_x,mb_end_y);}
+mb_isActive=false;}
+function mb_drawBox(left,top,right,bottom){mb_arrangeBox("l_top",left,top,right,top+2);mb_arrangeBox("l_left",left,top,left+2,bottom);mb_arrangeBox("l_right",right-2,top,right,bottom);mb_arrangeBox("l_bottom",left,bottom-2,right,bottom);mb_displayElement("l_top");mb_displayElement("l_left");mb_displayElement("l_right");mb_displayElement("l_bottom");}
+function mb_arrangeBox(name,left,top,right,bottom){var el=window.frames[mb_isBF].document.getElementById(name).style;el.height=Math.abs(bottom-top);el.width=Math.abs(right-left);el.top=top+"px";el.left=left+"px";}
+function mb_displayElement(name){window.frames[mb_isBF].document.getElementById(name).style.visibility="visible";}
+function mb_hideElement(name){window.frames[mb_isBF].document.getElementById(name).style.visibility="hidden";}
+function evalExtent(){if(mb_start_x>mb_end_x){mb_offset_right=mb_start_x;mb_offset_left=mb_end_x;}
+else{mb_offset_left=mb_start_x;mb_offset_right=mb_end_x;}
+if(mb_start_y>mb_end_y){mb_offset_bottom=mb_start_y;mb_offset_top=mb_end_y;}
+else{mb_offset_top=mb_start_y;mb_offset_bottom=mb_end_y;}
+if((mb_start_x!=mb_end_x)&&(mb_start_y!=mb_end_y)){mb_drawBox(mb_offset_left,mb_offset_top,mb_offset_right,mb_offset_bottom);}}
+function mb_setMapExtent(x1,y1,x2,y2){if(x1<x2){var minx=x1;var maxx=x2;}
+else{var minx=x2;var maxx=x1;}
+if(y1<y2){var miny=y2;var maxy=y1;}
+else{var miny=y1;var maxy=y2;}
+var ret=[];if((maxx-minx)>3&&(miny-maxy)>3){var posMin=makeClickPos2RealWorldPos(mb_isBF,minx,miny);var posMax=makeClickPos2RealWorldPos(mb_isBF,maxx,maxy);ret[0]=posMin[0];ret[1]=posMin[1];ret[2]=posMax[0];ret[3]=posMax[1];return ret;}
+else{var posMin=makeClickPos2RealWorldPos(mb_isBF,minx,miny);ret[0]=posMin[0];ret[1]=posMin[1];return ret;}}
Modified: tags/2.5_min/http/javascripts/mod_cardindex.js
--- branches/2.5/http/javascripts/mod_cardindex.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_cardindex.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,49 +1,6 @@
-/*********configuration:****************************************************************/
-var mod_cardindex_indexes	= new Array("tab1 ","tab2 ","tab3 ","tab4 ");
-var mod_cardindex_id		= new Array("iframe1","iframe2", "iframe3","iframe4");
-var mod_cardindex_dim		= new Array();
-var mod_cardindex_icolor	= "#7BA5D6";	//background active tabs
-var mod_cardindex_ficolor	= "#ff0000";	//font activ tabs
-var mod_cardindex_bcolor	= "#ffffff";	//background inactive tabs
-mb_registerInitFunctions("mod_cardindex_init()");
-function mod_cardindex_init(){
-	mod_cardindex_dim["width"] = document.getElementById(mod_cardindex_id[0]).style.width;
-	mod_cardindex_dim["height"] = document.getElementById(mod_cardindex_id[0]).style.height;
-	var str = "<span  style='font-family: Arial, Helvetica, sans-serif;font-size:10px;cursor:pointer'>";
-	for(var i=0; i<mod_cardindex_indexes.length; i++){
-		str += "<span id='mod_cardindex"+i+"'onclick='mod_cardindex("+i+")' style='color:black'>"+mod_cardindex_indexes[i]+"</span>&nbsp;";
-	str += "</span>";
-	writeTag("","cardindex",str);
-		if(i == 0){
-			document.getElementById("mod_cardindex" + i).style.color = mod_cardindex_ficolor;
-			document.getElementById("mod_cardindex" + i).style.backgroundColor = mod_cardindex_icolor;
-		else{
-			document.getElementById(mod_cardindex_id[i]).style.visibility = 'hidden';
-			document.getElementById(mod_cardindex_id[i]).style.width = "1px";
-			document.getElementById(mod_cardindex_id[i]).style.height = "1px";
-function mod_cardindex(obj){
-		if(obj != i){
-			document.getElementById("mod_cardindex" + i).style.color = 'black';
-			document.getElementById("mod_cardindex" + i).style.backgroundColor = mod_cardindex_bcolor;
-		else if(obj == i){
-			document.getElementById(mod_cardindex_id[i]).style.visibility = 'visible';
-			document.getElementById(mod_cardindex_id[i]).style.width = mod_cardindex_dim["width"];
-			document.getElementById(mod_cardindex_id[i]).style.height = mod_cardindex_dim["height"];
+var mod_cardindex_indexes=new Array("tab1 ","tab2 ","tab3 ","tab4 ");var mod_cardindex_id=new Array("iframe1","iframe2","iframe3","iframe4");var mod_cardindex_dim=new Array();var mod_cardindex_icolor="#7BA5D6";var mod_cardindex_ficolor="#ff0000";var mod_cardindex_bcolor="#ffffff";mb_registerInitFunctions("mod_cardindex_init()");function mod_cardindex_init(){mod_cardindex_dim["width"]=document.getElementById(mod_cardindex_id[0]).style.width;mod_cardindex_dim["height"]=document.getElementById(mod_cardindex_id[0]).style.height;var str="<span  style='font-family: Arial, Helvetica, sans-serif;font-size:10px;cursor:pointer'>";for(var i=0;i<mod_cardindex_indexes.length;i++){str+="<span id='mod_cardindex"+i+"'onclick='mod_cardindex("+i+")' style='color:black'>"+mod_cardindex_indexes[i]+"</span>&nbsp;";}
+str+="</span>";writeTag("","cardindex",str);for(var i=0;i<mod_cardindex_indexes.length;i++){if(i==0){document.getElementById("mod_cardindex"+i).style.color=mod_cardindex_ficolor;document.getElementById("mod_cardindex"+i).style.backgroundColor=mod_cardindex_icolor;}
+else{document.getElementById(mod_cardindex_id[i]).style.visibility='hidden';document.getElementById(mod_cardindex_id[i]).style.width="1px";document.getElementById(mod_cardindex_id[i]).style.height="1px";}}}
+function mod_cardindex(obj){for(var i=0;i<mod_cardindex_indexes.length;i++){if(obj!=i){document.getElementById("mod_cardindex"+i).style.color='black';document.getElementById("mod_cardindex"+i).style.backgroundColor=mod_cardindex_bcolor;document.getElementById(mod_cardindex_id[i]).style.visibility='hidden';document.getElementById(mod_cardindex_id[i]).style.width="1px";document.getElementById(mod_cardindex_id[i]).style.height="1px";}
+else if(obj==i){document.getElementById("mod_cardindex"+i).style.color=mod_cardindex_ficolor;document.getElementById("mod_cardindex"+i).style.backgroundColor=mod_cardindex_icolor;document.getElementById(mod_cardindex_id[i]).style.visibility='visible';document.getElementById(mod_cardindex_id[i]).style.width=mod_cardindex_dim["width"];document.getElementById(mod_cardindex_id[i]).style.height=mod_cardindex_dim["height"];}}}
Modified: tags/2.5_min/http/javascripts/mod_closePolygon.js
--- branches/2.5/http/javascripts/mod_closePolygon.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_closePolygon.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,11 +1,3 @@
-var mod_closePolygon_img = new Image();
-mod_closePolygon_img.src = "../img/button_gray/closePolygon_off.gif";
-register_measureSubFunctions("mod_closePolygon()");
-function mod_closePolygon(){
-	var str =  "<div style='position:absolute;top:25px' onmouseup='parent.mod_closePolygon_go()' ";
-	str += "onmouseover='parent.mod_measure_timeout()' onmouseout='parent.mod_measure_disableTimeout()'><img src='"+mod_closePolygon_img.src+"'></div>";
-	return str;
-function mod_closePolygon_go(){
-	mod_measure_close();
+var mod_closePolygon_img=new Image();mod_closePolygon_img.src="../img/button_gray/closePolygon_off.gif";register_measureSubFunctions("mod_closePolygon()");function mod_closePolygon(){var str="<div style='position:absolute;top:25px' onmouseup='parent.mod_closePolygon_go()' ";str+="onmouseover='parent.mod_measure_timeout()' onmouseout='parent.mod_measure_disableTimeout()'><img src='"+mod_closePolygon_img.src+"'></div>";return str;}
+function mod_closePolygon_go(){mod_measure_close();}
Modified: tags/2.5_min/http/javascripts/mod_closePolygonExt.js
--- branches/2.5/http/javascripts/mod_closePolygonExt.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_closePolygonExt.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,17 +1,6 @@
-var mod_closePolygonExt_img = new Image();
-mod_closePolygonExt_img.src = "../img/button_gray/closePolygon_off.gif";
-try {register_setExtRequestSubFunctions("mod_closePolygonExt()");}
-catch(e) {
-	try {parent.register_setExtRequestSubFunctions("mod_closePolygonExt()");}
-	catch(e) {
-		alert("exception (mod_closePolygonExt.js): register_setExtRequestSubFunctions not found");
-function mod_closePolygonExt(){
-	var str =  "<div style='position:absolute;top:25px' onmouseup='parent.mod_wfs_spatialRequest_close()' ";
-	str += "onmouseover='parent.mod_wfs_spatialRequest_timeout()' onmouseout='parent.mod_wfs_spatialRequest_disableTimeout()'><img src='"+mod_closePolygonExt_img.src+"'></div>";
-	return str;
-function mod_closePolygonExt_go(){
-	mod_setExtRequest_close();
+var mod_closePolygonExt_img=new Image();mod_closePolygonExt_img.src="../img/button_gray/closePolygon_off.gif";try{register_setExtRequestSubFunctions("mod_closePolygonExt()");}
+catch(e){try{parent.register_setExtRequestSubFunctions("mod_closePolygonExt()");}
+catch(e){alert("exception (mod_closePolygonExt.js): register_setExtRequestSubFunctions not found");}}
+function mod_closePolygonExt(){var str="<div style='position:absolute;top:25px' onmouseup='parent.mod_wfs_spatialRequest_close()' ";str+="onmouseover='parent.mod_wfs_spatialRequest_timeout()' onmouseout='parent.mod_wfs_spatialRequest_disableTimeout()'><img src='"+mod_closePolygonExt_img.src+"'></div>";return str;}
+function mod_closePolygonExt_go(){mod_setExtRequest_close();}
Modified: tags/2.5_min/http/javascripts/mod_displayObj.js
--- branches/2.5/http/javascripts/mod_displayObj.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_displayObj.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,156 +1,13 @@
-function mod_displayObj(){
-	var tg = "";
-	tg +="<head>";
-	tg += "<title>Mapbender Info</title>";
-	tg += "<style type='text/css'>";
-	tg +="<!-- body{font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;font-size:10pt}";
-	tg +="hr{color:blue;}";
-	tg +="table{border-width:1;font-size:10pt}";
-	tg +="th{background-color:#F08080;text-align:left;}";
-	tg +="tr{background-color:white;}";
-	tg +=".tr_head{font-weight:bold;background-color:silver;}";
-	tg +=".th_wfs{font-weight:bold;background-color:#BDBAF7;text-align:left;}";
-	tg +="--></style></head>";
-	var myWin = null;
-	tg += "<body><h3 >Mapbender Metadata</h3>";
-	tg += "<h4 >active maps</h4>";
-		tg += "<h4 >frame: "+ mb_mapObj[i].frameName+"</h4>";
-		tg += "<table border='1' width='98%' rules='rows'><tr>";
-		tg += "<th width='200'>wms:</th><th>request</th></tr>";
-		for(var ii=0; ii<mb_mapObj[i].wms.length; ii++){
-			tg +="<tr><td width='200'>"+mb_mapObj[i].wms[ii].wms_title+"</td><td>";
-			// if the mapURL is not defined or false, don't add a link
-			if (mb_mapObj[i].mapURL[ii] == false || typeof(mb_mapObj[i].mapURL[ii]) == 'undefined' ){
-				tg += mb_mapObj[i].mapURL[ii];
-			else{
-				tg += "<a href='"+ mb_mapObj[i].mapURL[ii]+"' target='_blank'>"+ mb_mapObj[i].mapURL[ii]+"</a>";
-			tg +="</td></tr>";
-		tg += "</table><br>";
-	tg += "<hr>";
-	for(var j=0; j<mb_mapObj.length; j++){
-		for(var cnt=0; cnt<mb_mapObj[j].wms.length;cnt++){
-			tg += "<h4 >"+ mb_mapObj[j].frameName+" WMS: "+ cnt+ ": "+mb_mapObj[j].wms[cnt].wms_title+" ("+mb_mapObj[j].wms[cnt].wms_abstract+") </h4>";
-			tg += "<table border='1' rules='rows'><tr>";
-			tg += "<th >WMS nr:</th><th>" + cnt+ "</th></tr>";
-			tg += "<tr><td>wms_id:</td><td>" + mb_mapObj[j].wms[cnt].wms_id + "</td></tr>";
-			tg += "<tr><td>wms_version:</td><td>" + mb_mapObj[j].wms[cnt].wms_version + "</td></tr>";
-			tg += "<tr><td>wms_title: </td><td>" + mb_mapObj[j].wms[cnt].wms_title + "</td></tr>";
-			tg += "<tr><td>wms_abstract:</td><td>" + mb_mapObj[j].wms[cnt].wms_abstract + "</td></tr>";
-			tg += "<tr><td>wms_getmap: </td><td>" + mb_mapObj[j].wms[cnt].wms_getmap + "</td></tr>";
-			tg += "<tr><td>wms_getfeatureinfo: </td><td>" + mb_mapObj[j].wms[cnt].wms_getfeatureinfo + "</td></tr>";
-			tg += "<tr><td>wms_getlegendurl: </td><td>" + mb_mapObj[j].wms[cnt].wms_getlegendurl + "</td></tr>";
-			tg += "<tr><td>gui_wms_mapformat: </td><td>" + mb_mapObj[j].wms[cnt].gui_wms_mapformat + "</td></tr>";
-			tg += "<tr><td>gui_wms_featureinfoformat: </td><td>" + mb_mapObj[j].wms[cnt].gui_wms_featureinfoformat + "</td></tr>";
-			tg += "<tr><td>gui_wms_exceptionformat: </td><td>" + mb_mapObj[j].wms[cnt].gui_wms_exceptionformat + "</td></tr>";
-			tg += "<tr><td>gui_wms_epsg: </td><td>" + mb_mapObj[j].wms[cnt].gui_wms_epsg + "</td></tr>";
-			tg += "<tr><td>gui_wms_visible: </td><td>" + mb_mapObj[j].wms[cnt].gui_wms_visible + "</td></tr>" ;
-			tg += "<tr class='tr_head'><td>Data: </td><td>.</td></tr>";
-			for(var i=0; i<mb_mapObj[j].wms[cnt].data_type.length; i++){
-				tg += "<tr><td>" + mb_mapObj[j].wms[cnt].data_type[i] + "</td><td>" + mb_mapObj[j].wms[cnt].data_format[i] + "</td></tr>" ;
-			for(var i=0; i<mb_mapObj[j].wms[cnt].gui_epsg.length; i++){
-				tg += "<tr class='tr_head'><td>epsg : </td><td>" + mb_mapObj[j].wms[cnt].gui_epsg[i] + "</td></tr>" ;
-				tg += "<tr><td>minx : </td><td>" + mb_mapObj[j].wms[cnt].gui_minx[i] + "</td></tr>" ;
-				tg += "<tr><td>miny : </td><td>" + mb_mapObj[j].wms[cnt].gui_miny[i] + "</td></tr>" ;
-				tg += "<tr><td>maxx : </td><td>" + mb_mapObj[j].wms[cnt].gui_maxx[i] + "</td></tr>" ;
-				tg += "<tr><td>maxy : </td><td>" + mb_mapObj[j].wms[cnt].gui_maxy[i]+"</td></tr>" ;
-			tg += "<table border='1' rules='rows'><tr class='tr_head'>";
-			tg += "<td>layer_id</td>";
-			tg += "<td>layer_uid</td>";
-			tg += "<td>layer_pos</td>";
-			tg += "<td>layer_parent</td>";
-			tg += "<td>layer_name</td>";
-			tg += "<td>layer_title</td>";
-			tg += "<td>layer_dataurl</td>";
-			tg += "<td>layer_queryable</td>";
-			tg += "<td>layer_minscale</td>";
-			tg += "<td>layer_maxscale</td>";
-			tg += "<td>gui_layer_wms_id</td>";
-			tg += "<td>gui_layer_status</td>";
-			tg += "<td>gui_layer_selectable</td>";
-			tg += "<td>gui_layer_visible</td>";
-			tg += "<td>gui_layer_queryable</td>";
-			tg += "<td>gui_layer_querylayer</td>";
-			tg += "<td>gui_layer_minscale</td>";
-			tg += "<td>gui_layer_maxscale</td>";
-			tg += "<td>gui_layer_wfs_featuretype</td>";
-			tg += "</tr>";
-			for(var i=0; i<mb_mapObj[j].wms[cnt].objLayer.length; i++){
-				tg += "<tr>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_id + "</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_uid + "</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_pos + "</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_parent+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_name+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_title+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_dataurl_href+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_queryable+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_minscale+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_maxscale+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_wms_id+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_status+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_selectable+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_visible+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_queryable+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_querylayer+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_minscale+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_maxscale+"</td>";
-				tg += "<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_wfs_featuretype+"</td>";
-				tg += "</tr>";
-			tg += "</table><br><br>";
-		tg += "<hr>";
-	if(wfs){
-		for(var cnt=0; cnt<wfs.length;cnt++){
-			tg += "<br><h4 style='font-color:blue'>WFS: "+ cnt+ ": "+wfs[cnt].wfs_title+" ("+wfs[cnt].wfs_abstract+") </h4>";
-			tg+="<table border='1' rules='rows'><tr>";
-			tg += "<th class='th_wfs' width='200'>WFS nr: </th><th class='th_wfs'>" + cnt+ "</th></tr>";
-			tg += "<tr><td>wfs_id:</td><td> " + wfs[cnt].wfs_id + "</td></tr>";
-			tg += "<tr><td>wfs_version: </td><td>" + wfs[cnt].wfs_version + "</td></tr>";
-			tg += "<tr><td>wfs_title: </td><td>" + wfs[cnt].wfs_title + "</td></tr>";
-			tg += "<tr><td>wfs_abstract:</td><td>" + wfs[cnt].wfs_abstract + "</td></tr>";
-			tg += "<tr><td>wfs_getcapabilities: </td><td><a href='"+ wfs[cnt].wfs_getcapabilities + "&VERSION=1.0.0&request=getcapabilities' target='_blank'>" + wfs[cnt].wfs_getcapabilities + "</a></td></tr>";
-			tg += "<tr><td>wfs_describefeaturetype:</td><td>" + wfs[cnt].wfs_describefeaturetype +  "</td></tr>";
-			tg += "<table border='1' rules='rows' ><tr class='tr_head'>";
-			tg += "<td width='200'>wfs_featuretype</td>";
-			tg += "<td>featuretype_name</td></tr>";
-			for(var i=0; i<wfs[cnt].wfs_featuretype.length; i++){
-				tg += "<tr><td>"+i+"</td>";
-				tg += "<td>" + wfs[cnt].wfs_featuretype[i].featuretype_name + "</td>";
-				tg += "<tr>";
-	tg += "<BR></body>";
-	myWin = window.open("","myWin","");
-	myWin.document.open("text/html");
-	myWin.document.write(tg);
-	myWin.document.close();
-	myWin.focus();
+function mod_displayObj(){var tg="";tg+="<head>";tg+="<title>Mapbender Info</title>";tg+="<style type='text/css'>";tg+="<!-- body{font-family:Verdana, Geneva, Arial, Helvetica, sans-serif;font-size:10pt}";tg+="hr{color:blue;}";tg+="table{border-width:1;font-size:10pt}";tg+="th{background-color:#F08080;text-align:left;}";tg+="tr{background-color:white;}";tg+=".tr_head{font-weight:bold;background-color:silver;}";tg+=".th_wfs{font-weight:bold;background-color:#BDBAF7;text-align:left;}";tg+="--></style></head>";var myWin=null;tg+="<body><h3 >Mapbender Metadata</h3>";tg+="<h4 >active maps</h4>";for(var i=0;i<mb_mapObj.length;i++){tg+="<h4 >frame: "+mb_mapObj[i].frameName+"</h4>";tg+="<table border='1' width='98%' rules='rows'><tr>";tg+="<th width='200'>wms:</th><th>request</th></tr>";for(var ii=0;ii<mb_mapObj[i].wms.length;ii++){tg+="<tr><td width='200'>"+mb_mapObj[i].wms[ii].wms_title+"</td><td>";if(mb_mapObj[i].mapURL[ii]==false||typeof(mb_mapObj[i].mapURL[ii])=='undefined'){tg+=mb_mapObj[i].mapURL[ii];}
+else{tg+="<a href='"+mb_mapObj[i].mapURL[ii]+"' target='_blank'>"+mb_mapObj[i].mapURL[ii]+"</a>";}
+tg+="</td></tr>";}
+tg+="</table><br>";}
+tg+="<hr>";for(var j=0;j<mb_mapObj.length;j++){for(var cnt=0;cnt<mb_mapObj[j].wms.length;cnt++){tg+="<h4 >"+mb_mapObj[j].frameName+" WMS: "+cnt+": "+mb_mapObj[j].wms[cnt].wms_title+" ("+mb_mapObj[j].wms[cnt].wms_abstract+") </h4>";tg+="<table border='1' rules='rows'><tr>";tg+="<th >WMS nr:</th><th>"+cnt+"</th></tr>";tg+="<tr><td>wms_id:</td><td>"+mb_mapObj[j].wms[cnt].wms_id+"</td></tr>";tg+="<tr><td>wms_version:</td><td>"+mb_mapObj[j].wms[cnt].wms_version+"</td></tr>";tg+="<tr><td>wms_title: </td><td>"+mb_mapObj[j].wms[cnt].wms_title+"</td></tr>";tg+="<tr><td>wms_abstract:</td><td>"+mb_mapObj[j].wms[cnt].wms_abstract+"</td></tr>";tg+="<tr><td>wms_getmap: </td><td>"+mb_mapObj[j].wms[cnt].wms_getmap+"</td></tr>";tg+="<tr><td>wms_getfeatureinfo: </td><td>"+mb_mapObj[j].wms[cnt].wms_getfeatureinfo+"</td></tr>";tg+="<tr><td>wms_getlegendurl: </td><td>"+mb_mapObj[j].wms[cnt].wms_getlegendurl+"</td></tr>";tg+="<tr><td>gui_wms_mapformat: </td><td>"+mb_mapObj[j].wms[cnt].gui_wms_mapformat+"</td></tr>";tg+="<tr><td>gui_wms_featureinfoformat: </td><td>"+mb_mapObj[j].wms[cnt].gui_wms_featureinfoformat+"</td></tr>";tg+="<tr><td>gui_wms_exceptionformat: </td><td>"+mb_mapObj[j].wms[cnt].gui_wms_exceptionformat+"</td></tr>";tg+="<tr><td>gui_wms_epsg: </td><td>"+mb_mapObj[j].wms[cnt].gui_wms_epsg+"</td></tr>";tg+="<tr><td>gui_wms_visible: </td><td>"+mb_mapObj[j].wms[cnt].gui_wms_visible+"</td></tr>";tg+="<tr class='tr_head'><td>Data: </td><td>.</td></tr>";for(var i=0;i<mb_mapObj[j].wms[cnt].data_type.length;i++){tg+="<tr><td>"+mb_mapObj[j].wms[cnt].data_type[i]+"</td><td>"+mb_mapObj[j].wms[cnt].data_format[i]+"</td></tr>";}
+for(var i=0;i<mb_mapObj[j].wms[cnt].gui_epsg.length;i++){tg+="<tr class='tr_head'><td>epsg : </td><td>"+mb_mapObj[j].wms[cnt].gui_epsg[i]+"</td></tr>";tg+="<tr><td>minx : </td><td>"+mb_mapObj[j].wms[cnt].gui_minx[i]+"</td></tr>";tg+="<tr><td>miny : </td><td>"+mb_mapObj[j].wms[cnt].gui_miny[i]+"</td></tr>";tg+="<tr><td>maxx : </td><td>"+mb_mapObj[j].wms[cnt].gui_maxx[i]+"</td></tr>";tg+="<tr><td>maxy : </td><td>"+mb_mapObj[j].wms[cnt].gui_maxy[i]+"</td></tr>";}
+tg+="</table><br>";tg+="<table border='1' rules='rows'><tr class='tr_head'>";tg+="<td>layer_id</td>";tg+="<td>layer_uid</td>";tg+="<td>layer_pos</td>";tg+="<td>layer_parent</td>";tg+="<td>layer_name</td>";tg+="<td>layer_title</td>";tg+="<td>layer_dataurl</td>";tg+="<td>layer_queryable</td>";tg+="<td>layer_minscale</td>";tg+="<td>layer_maxscale</td>";tg+="<td>gui_layer_wms_id</td>";tg+="<td>gui_layer_status</td>";tg+="<td>gui_layer_selectable</td>";tg+="<td>gui_layer_visible</td>";tg+="<td>gui_layer_queryable</td>";tg+="<td>gui_layer_querylayer</td>";tg+="<td>gui_layer_minscale</td>";tg+="<td>gui_layer_maxscale</td>";tg+="<td>gui_layer_wfs_featuretype</td>";tg+="</tr>";for(var i=0;i<mb_mapObj[j].wms[cnt].objLayer.length;i++){tg+="<tr>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_id+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_uid+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_pos+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_parent+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_name+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_title+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_dataurl_href+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_queryable+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_minscale+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].layer_maxscale+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_wms_id+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_status+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_selectable+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_visible+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_queryable+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_querylayer+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_minscale+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_maxscale+"</td>";tg+="<td>"+mb_mapObj[j].wms[cnt].objLayer[i].gui_layer_wfs_featuretype+"</td>";tg+="</tr>";}
+tg+="</table><br><br>";}
+tg+="<hr>";}
+if(wfs){for(var cnt=0;cnt<wfs.length;cnt++){tg+="<br><h4 style='font-color:blue'>WFS: "+cnt+": "+wfs[cnt].wfs_title+" ("+wfs[cnt].wfs_abstract+") </h4>";tg+="<table border='1' rules='rows'><tr>";tg+="<th class='th_wfs' width='200'>WFS nr: </th><th class='th_wfs'>"+cnt+"</th></tr>";tg+="<tr><td>wfs_id:</td><td> "+wfs[cnt].wfs_id+"</td></tr>";tg+="<tr><td>wfs_version: </td><td>"+wfs[cnt].wfs_version+"</td></tr>";tg+="<tr><td>wfs_title: </td><td>"+wfs[cnt].wfs_title+"</td></tr>";tg+="<tr><td>wfs_abstract:</td><td>"+wfs[cnt].wfs_abstract+"</td></tr>";tg+="<tr><td>wfs_getcapabilities: </td><td><a href='"+wfs[cnt].wfs_getcapabilities+"&VERSION=1.0.0&request=getcapabilities' target='_blank'>"+wfs[cnt].wfs_getcapabilities+"</a></td></tr>";tg+="<tr><td>wfs_describefeaturetype:</td><td>"+wfs[cnt].wfs_describefeaturetype+"</td></tr>";tg+="</table><br>";tg+="<table border='1' rules='rows' ><tr class='tr_head'>";tg+="<td width='200'>wfs_featuretype</td>";tg+="<td>featuretype_name</td></tr>";for(var i=0;i<wfs[cnt].wfs_featuretype.length;i++){tg+="<tr><td>"+i+"</td>";tg+="<td>"+wfs[cnt].wfs_featuretype[i].featuretype_name+"</td>";tg+="<tr>";}
+tg+="</table><br>";}}
+tg+="<BR></body>";myWin=window.open("","myWin","");myWin.document.open("text/html");myWin.document.write(tg);myWin.document.close();myWin.focus();}
\ No newline at end of file
Modified: tags/2.5_min/http/javascripts/mod_horizTabs.js
--- branches/2.5/http/javascripts/mod_horizTabs.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_horizTabs.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,90 +1,8 @@
-* $Id:$
-* COPYRIGHT: (C) 2001 by ccgis. This program is free software under the GNU General Public
-* License (>=v2). Read the file gpl.txt that comes with Mapbender for details.
-(function($){
- * turns a div tag into a tab control
- * @return jQuery
-	$.fn.tabControl = function(options){
-		defaults = {tab:true};
-		return this.each(function(){
-			this._tabSettings = $.extend(defaults, options)
-			this.tabs = [];
-			this.activeTab = false;
-			//append div for tab buttons
-			$(this).append("<div />")
- * adds a tab to a tab control
- * @return jQuery
-	$.fn.addTab = function(options){
-			//ensure function is called on a tabControl
-			if(!this._tabSettings)
-				return;
-			//Add tab
-			this.tabs.push(options);
-			//add access button	for this tab and update height
-			this.tab_height = parseInt($("div",this)
-				.append("<span class=\"tabButton\" id=\"tabButton_"+options.id+"\">"+options.title+"</span> ")
-				.height());
-			 //bind click event to activate the tab
-			 $("#tabButton_"+options.id,this)
-			 	.bind("click",{i:this.tabs.length-1},function(event){
-					$(this.parentNode.parentNode).activateTab(event.data.i);
-			//set element to right position
-			$("#"+options.id).css({position:"absolute",
-				left:parseInt(this.style.left),
-				top:parseInt(this.style.top)+this.tab_height,
-				width:$(this).width(),
-				height:$(this).height()-this.tab_height,
-				zIndex:parseInt(this.style.zIndex+1)})
-			//and hide it
-			.hide();
- * activate tab i of the tab control
- * @param integer i number of tab to activate (0 to number of tabs -1)
- * @return jQuery
-	$.fn.activateTab = function(i){
-				return;
-			//hide old tab
-			if(this.activeTab!==false){
-				$("#"+this.tabs[this.activeTab].id).hide();
-				$("#tabButton_"+this.tabs[this.activeTab].id).removeClass("tabButtonActive").addClass("tabButton");
-			//move tab to right position
-			$("#"+this.tabs[i].id).css({position:"absolute",
-					top:parseInt(this.style.top)+this.tab_height,width:$(this).width(),
-					height:$(this).height()-this.tab_height,zIndex:parseInt(this.style.zIndex+1)})
-			//and show it
-			.show();
-			//update button state
-			$("#tabButton_"+this.tabs[i].id).removeClass("tabButton").addClass("tabButtonActive");
-			this.activeTab=i;
-(jQuery);
+(function($){$.fn.tabControl=function(options){defaults={tab:true};return this.each(function(){this._tabSettings=$.extend(defaults,options)
+this.tabs=[];this.activeTab=false;$(this).append("<div />")});};$.fn.addTab=function(options){return this.each(function(){if(!this._tabSettings)
+return;this.tabs.push(options);this.tab_height=parseInt($("div",this).append("<span class=\"tabButton\" id=\"tabButton_"+options.id+"\">"+options.title+"</span> ").height());$("#tabButton_"+options.id,this).bind("click",{i:this.tabs.length-1},function(event){$(this.parentNode.parentNode).activateTab(event.data.i);});$("#"+options.id).css({position:"absolute",left:parseInt(this.style.left),top:parseInt(this.style.top)+this.tab_height,width:$(this).width(),height:$(this).height()-this.tab_height,zIndex:parseInt(this.style.zIndex+1)}).hide();});}
+$.fn.activateTab=function(i){return this.each(function(){if(!this._tabSettings)
+return;if(this.activeTab!==false){$("#"+this.tabs[this.activeTab].id).hide();$("#tabButton_"+this.tabs[this.activeTab].id).removeClass("tabButtonActive").addClass("tabButton");}
+$("#"+this.tabs[i].id).css({position:"absolute",left:parseInt(this.style.left),top:parseInt(this.style.top)+this.tab_height,width:$(this).width(),height:$(this).height()-this.tab_height,zIndex:parseInt(this.style.zIndex+1)}).show();$("#tabButton_"+this.tabs[i].id).removeClass("tabButton").addClass("tabButtonActive");this.activeTab=i;});}})
+(jQuery);
Modified: tags/2.5_min/http/javascripts/mod_permanentHighlight.js
--- branches/2.5/http/javascripts/mod_permanentHighlight.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_permanentHighlight.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,28 +1,3 @@
-var mod_permanentHighlight_target = "mapframe1";
-var mod_permanentHighlight_x = false;
-var mod_permanentHighlight_y = false;
-var mod_permanentHighlight_text = false;
-mb_registerSubFunctions("mod_permanentHighlight_init()");
-mb_registerPanSubElement("permanent");
-function mod_permanentHighlight_init(){
-	if(mod_permanentHighlight_x && mod_permanentHighlight_y){
-		mb_permanentHighlight("mapframe1",parseFloat(mod_permanentHighlight_x),parseFloat(mod_permanentHighlight_y));
-function mb_permanentHighlight(frameName,x,y){
-	var pos = makeRealWorld2mapPos(frameName,x, y);
-	window.frames[frameName].document.getElementById('permanent').style.visibility = 'visible';
-	//3373790 / 5938930
-	if (mod_permanentHighlight_text){
-		var tagSource = "";
-	    tagSource += "<div style='z-index:4;position:absolute;left:"+(pos[0]-7)+"px;top:"+(pos[1]-7)+"px'>";
-	    tagSource += "<img src='../img/redball.gif'>";
-	    tagSource += "<span style='position:absolute;top:+12px;left:+12px;z-index:20;visibility:visible;background-color:white;color:red;font-family:Arial;'><nobr>";
-	    tagSource += mod_permanentHighlight_text +"</nobr><span></div>";
-	    writeTag(frameName, "permanent", tagSource);
-	}else{
-		mb_arrangeElement(frameName,"permanent",pos[0]-7, pos[1]-7);
+var mod_permanentHighlight_target="mapframe1";var mod_permanentHighlight_x=false;var mod_permanentHighlight_y=false;var mod_permanentHighlight_text=false;mb_registerSubFunctions("mod_permanentHighlight_init()");mb_registerPanSubElement("permanent");function mod_permanentHighlight_init(){if(mod_permanentHighlight_x&&mod_permanentHighlight_y){mb_permanentHighlight("mapframe1",parseFloat(mod_permanentHighlight_x),parseFloat(mod_permanentHighlight_y));}}
+function mb_permanentHighlight(frameName,x,y){var pos=makeRealWorld2mapPos(frameName,x,y);window.frames[frameName].document.getElementById('permanent').style.visibility='visible';if(mod_permanentHighlight_text){var tagSource="";tagSource+="<div style='z-index:4;position:absolute;left:"+(pos[0]-7)+"px;top:"+(pos[1]-7)+"px'>";tagSource+="<img src='../img/redball.gif'>";tagSource+="<span style='position:absolute;top:+12px;left:+12px;z-index:20;visibility:visible;background-color:white;color:red;font-family:Arial;'><nobr>";tagSource+=mod_permanentHighlight_text+"</nobr><span></div>";writeTag(frameName,"permanent",tagSource);}else{mb_arrangeElement(frameName,"permanent",pos[0]-7,pos[1]-7);}}
Modified: tags/2.5_min/http/javascripts/mod_rubber.js
--- branches/2.5/http/javascripts/mod_rubber.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_rubber.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,14 +1,3 @@
-//$Id$
-//$Header: /cvsroot/mapbender/mapbender/http/javascripts/mod_rubber.js,v 1.4 2005/09/13 14:38:11 bjoern_heuser Exp $
-var mod_rubber_img = new Image();
-mod_rubber_img.src = "../img/button_gray/rubber_off.gif";
-mod_rubber_img.title = "gemessene Strecke l&ouml;schen";
-register_measureSubFunctions("mod_rubber()");
-function mod_rubber(){
-   var str =  "<div onmouseup='parent.mod_rubber_go()' onmouseover='parent.mod_measure_timeout()' onmouseout='parent.mod_measure_go()'><img src='"+mod_rubber_img.src+"' title='"+mod_rubber_img.title+"'></div>";
-   return str;
-function mod_rubber_go(){
-   mod_measure_delete();
+var mod_rubber_img=new Image();mod_rubber_img.src="../img/button_gray/rubber_off.gif";mod_rubber_img.title="gemessene Strecke l&ouml;schen";register_measureSubFunctions("mod_rubber()");function mod_rubber(){var str="<div onmouseup='parent.mod_rubber_go()' onmouseover='parent.mod_measure_timeout()' onmouseout='parent.mod_measure_go()'><img src='"+mod_rubber_img.src+"' title='"+mod_rubber_img.title+"'></div>";return str;}
+function mod_rubber_go(){mod_measure_delete();}
Modified: tags/2.5_min/http/javascripts/mod_rubberExt.js
--- branches/2.5/http/javascripts/mod_rubberExt.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_rubberExt.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,8 +1,2 @@
-var mod_rubberExt_img = new Image();
-mod_rubberExt_img.src = "../img/button_gray/rubber_off.gif";
-register_setExtRequestSubFunctions("mod_rubberExt()");
-function mod_rubberExt(){
-	var str =  "<div onmouseup='parent.mod_wfs_spatialRequest_delete()' onmouseover='parent.mod_wfs_spatialRequest_timeout()' onmouseout=\"parent.mod_wfs_spatialRequest_digitize_go('polygon')\"><img src='"+mod_rubberExt_img.src+"'></div>";
-	return str;
+var mod_rubberExt_img=new Image();mod_rubberExt_img.src="../img/button_gray/rubber_off.gif";register_setExtRequestSubFunctions("mod_rubberExt()");function mod_rubberExt(){var str="<div onmouseup='parent.mod_wfs_spatialRequest_delete()' onmouseover='parent.mod_wfs_spatialRequest_timeout()' onmouseout=\"parent.mod_wfs_spatialRequest_digitize_go('polygon')\"><img src='"+mod_rubberExt_img.src+"'></div>";return str;}
Modified: tags/2.5_min/http/javascripts/mod_saveWKT.js
--- branches/2.5/http/javascripts/mod_saveWKT.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_saveWKT.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,18 +1,4 @@
-var mod_saveWKT_img = new Image();
-var mod_saveWKT_win = null;
-mod_saveWKT_img.src = "../img/button_gray/save.gif";
-register_measureSubFunctions("mod_saveWKT()");
-function mod_saveWKT(){
-	var str =  "<div style='position:absolute;top:75px' onmouseup='parent.mod_saveWKT_go()' ";
-	str += "onmouseover='parent.mod_measure_timeout()' onmouseout='parent.mod_measure_go()'><img src='"+mod_saveWKT_img.src+"'></div>";
-	return str;
-function mod_saveWKT_go(){
-	if(mod_saveWKT_win == null || mod_saveWKT_win.closed == true){
-		mod_saveWKT_win =  window.open("../php/mod_saveWKT.php","mod_saveWKT_win","width=400, height=400, resizable=yes, dependent=yes");
-	else{
-		mod_saveWKT_win.focus();
+var mod_saveWKT_img=new Image();var mod_saveWKT_win=null;mod_saveWKT_img.src="../img/button_gray/save.gif";register_measureSubFunctions("mod_saveWKT()");function mod_saveWKT(){var str="<div style='position:absolute;top:75px' onmouseup='parent.mod_saveWKT_go()' ";str+="onmouseover='parent.mod_measure_timeout()' onmouseout='parent.mod_measure_go()'><img src='"+mod_saveWKT_img.src+"'></div>";return str;}
+function mod_saveWKT_go(){if(mod_saveWKT_win==null||mod_saveWKT_win.closed==true){mod_saveWKT_win=window.open("../php/mod_saveWKT.php","mod_saveWKT_win","width=400, height=400, resizable=yes, dependent=yes");}
+else{mod_saveWKT_win.focus();}}
Modified: tags/2.5_min/http/javascripts/mod_tab.js
--- branches/2.5/http/javascripts/mod_tab.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_tab.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,496 +1,28 @@
-// check element vars
-try{
-	if (open_tab){
-		open_tab = Number(open_tab);
-		if (isNaN(open_tab)) {
-			var e = new Mb_warning("mod_tab.js: tab_init: open_tab must be a number or an empty string.");
-catch(e){
-	var z = new Mb_warning("mod_tab.js: tab_init: open_tab is not set.");
-	open_tab = "";
-var tabs;
-mb_registerInitFunctions('tab_init()');
-eventLocalize.register(function () {
-	localizeTabs();
-eventInit.register(function () {
-	localizeTabs();
-function localizeTabs() {
-	mb_ajax_json("../php/mod_tab_messages.php", function(obj, status){
-		tabs.setTitles(obj);
-function tab_init(){
-	var obj = document.getElementById("tabs").style;
-	// generate a new tab array
-	tabs = new VerticalTabArray(tab_style);
-	// add the tabs from element vars
-	for (var i = 0; i < tab_ids.length; i++){
-		tabs.addTab(tab_ids[i], tab_prefix + tab_titles[i], tab_frameHeight[i]);
-	if (open_tab !== "") {
-		tabs.openTab(tabs.get(open_tab).module);
-function tab_open(elementName) {
-  // show the desired tab
-	tabs.openTab(elementName);
- * @class A single vertical tab
- * @constructor
- * @param {String} id the ID of the GUI element that will be displayed within the tab
- * @param {String} title the header of the tab
- * @param {Integer} frameHeight the height of the frame containing the GUI element
- * @param {Integer} tabWidth the width of a tab (NOT the frame)
- * @param {Integer} tabHeight the height of a tab (NOT the frame)
- * @param {String} tabStyle A string with a CSS (example: position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;)
- * @param {Integer} number the index of the current tab in a {@link VerticalTabArray}.
-var VerticalTab = function (id, title, frameHeight, tabWidth, tabHeight, tabStyle, number) {
-	 * Sets the attributes of the tabs DOM node.
-	 * @private
-	var setNodeAttributes = function(title, frameHeight, tabWidth, tabHeight, tabStyle, number) {
-		node.id = "tabs_" + that.module;
-		//set css class
-		node.className = "verticalTabs";
-		//mandatory style entries
-		node.style.position = "absolute";
-		node.style.width = tabWidth;
-		node.style.height = tabHeight;
-		node.style.top = number * tabHeight;
-		// open or close on click
-		// see http://www.mapbender.org/index.php/Add_events_via_DOM_in_IE_and_FF
-		if ($.browser.msie) {
-		   node.onclick = function() {
-		      tabs.toggleTab(that.module);
-		else {
-			node.onclick = function(){
-		// tab header
-		node.innerHTML = title;
-	 * Returns the DOM node of this tab.
-	 * @return the DOM node of this tab.
-	 * @type DOMNode
-	this.getNode = function() {
-		return node;
-	 * The ID of the GUI element that will be displayed within the tab.
-	this.module = id;
-	 * The height of the frame containing the GUI element.
-	this.height = frameHeight;
-	 * While a tab is opened or closed, the value is false.
-	this.animationFinished = true;
-	 * The DOM node of this tab.
-	 * @private
-	var node = document.createElement("div");
-	var that = this;
-	setNodeAttributes(title, frameHeight, tabWidth, tabHeight, tabStyle, number);
- * An array of vertical tabs, behaving like an accordion
- * @extends List
- * @param {String} cssString A string with a CSS (example: position:absolute;visibility:visible;border: 1px solid white;font-size:12;color:#343434;background-color:#CFD2D4;cursor:pointer;)
-var VerticalTabArray = function (cssString) {
-	 * Adds a new tab to the Array.
-	 * @param {Integer} height the height of the frame containing the GUI element
-	this.addTab = function(id, title, height) {
-		var tab = new VerticalTab(id, title, height, tabWidth, tabHeight, tabStyle, this.count());
-		this.add(tab);
-		document.getElementById(id).style.visibility = 'hidden';
-		// append the new tab
-		rootNode.appendChild(this.get(-1).getNode());
-	 * Removes a tab from the Array.
-	 * @param {String} id the ID of the GUI element within the tab.
-	this.delTab = function(id) {
-		var index = getIndexById(id);
-		if (index !== null) {
-			// delete the DOM node
-			rootNode.removeChild(this.get(index).getNode());
-			// delete the tab
-			this.del(index);
-			// move the other tabs (below the removed tab) up
-			for (var i = index; i < this.count(); i++) {
-				var currentNode = this.get(i).getNode();
-				// parseInt removes "px"
-				var currentTop = parseInt(currentNode.style.top, 10);
-				currentNode.style.top = currentTop - tabHeight;
-	 * Opens a tab specified by the module Id.
-	this.toggleTab = function(id) {
-		// if no tab is currently opening or closing
-		if (isAnimationFinished()) {
-			for (var i=0; i < this.count(); i++) {
-				hideFrame(this.get(i).module);
-			// if the opened tab is the active tab, close it
-			if (id === activeTabId) {
-				closeTab(activeTabId);
-			//otherwise
-			else {
-		  	activeTabId = id;
-				startAnimation("open");
-		else {
-			var e = new Mb_warning("mod_tab.js: could not activate tab, opening or closing in progress!");
-	 * Sets the titles of each single tab after l10n
-	 * @param {Object} obj an array containing objects with id and title
-	this.setTitles = function (obj) {
-		for (var i = 0; i < this.count(); i++) {
-			for(var j=0; j<obj.length; j++){
-				if (this.get(i).module == obj[j].id) {
-					this.get(i).getNode().innerHTML = tabPrefix + obj[j].title;
-	 * Returns the absolute coordinates of tab by the module ID
-	 * @return {String} String with "left,top,right,bottom"
-	 this.getCoords = function(id) {
-	 	var coords=[];
-	 	//get indixes
-	 	if (activeTabId) {
-			var indexOfOpeningTab = getIndexById(activeTabId);
-	 	//left
-	 	coords[0] = tabLeftOffset;
-	 	//top
-	 	coords[1] = tabTopOffset + index*tabHeight + (activeTabId&&indexOfOpeningTab<index?this.get(indexOfOpeningTab).height:0);
-	 	//right
-	 	coords[2] = coords[0] + tabWidth;
-	 	//bottom
-	 	coords[3] = coords[1] + (id==activeTabId?this.get(indexOfOpeningTab).height+tabHeight:tabHeight);
-	 	return coords.join(",");
-	 * Animated opening and closing of the tab with the given id.
-	 * Needs to be public because it is called via "setInterval".
-	 * @param {String} openOrClose a string with the values "open" or "close".
-	this.animate = function(openOrClose) {
-			if (this.get(i).animationFinished === false) {
-				//The 'top' position of the i-th tab after the animation
-				var currentTabNewTop = i * tabHeight;
-				if (openOrClose == 'open') {
-					// move the lower tabs down by the height of the opening tab
-					if (indexOfOpeningTab !== null && i > indexOfOpeningTab) {
-						currentTabNewTop += this.get(indexOfOpeningTab).height;
-				//The current 'top' position of the i-th tab
-				//(parseInt removes 'px')
-				var currentTabCurrentTop = parseInt(this.get(i).getNode().style.top, 10);
-				// animation is finished
-				if (currentTabCurrentTop == currentTabNewTop) {
-					this.get(i).animationFinished = true;
-				// animation not yet finished, move the tab down
-				else if (currentTabCurrentTop < currentTabNewTop) {
-					var pixel = Math.min(pixelPerIteration, currentTabNewTop - currentTabCurrentTop);
-					this.get(i).getNode().style.top = currentTabCurrentTop + pixel;
-				// animation not yet finished, move the tab up
-				else if (currentTabCurrentTop > currentTabNewTop) {
-					var pixel = Math.min(pixelPerIteration, currentTabCurrentTop - currentTabNewTop);
-					this.get(i).getNode().style.top = currentTabCurrentTop - pixel;
-				else {
-					var e = new Mb_exception("mod_tab.js: animate: unknown state for tab "+ i + " (currentTop: "+currentTabCurrentTop+", newTop:"+currentTabNewTop+")");
-		// check if the animation is finished
-			stopAnimation();
-			if (openOrClose == "open") {
-				showFrame(activeTabId);
-	 * Returns the index of the vertical tab with a given id
-	 * @private
-	var getIndexById = function(id) {
-		for (var i = 0; i < that.count(); i++) {
-			if (that.get(i).module == id) {
-				return i;
-		var e = new Mb_exception("mod_tab.js: getIndexById: ID '"+id+"' not found.");
-		return null;
-	 * Closes a tab.
-	 * @private
-	var closeTab = function(id) {
-		if (id !== null) {
-			hideFrame(id);
-			activeTabId = null;
-			startAnimation("close");
-	 * Opens a tab.
-	 * @public
-	this.openTab = function(id) {
-		if (id !== null && activeTabId != id) {
-      activeTabId = id;
-	 * Hides a frame within a tab (before closing the tab).
-	 * @private
-	var hideFrame = function(id) {
-			var obj = document.getElementById(id);
-			obj.style.visibility = 'hidden';
-			//try to apply for childs of horizontal tabs
-			try{
-				if(obj.tabs)
-					document.getElementById(obj.tabs[obj.activeTab].id).style.visibility = 'hidden';
-			catch(e){}
-	 * Shows a frame within a tab (after opening the tab).
-	 * @private
-	var showFrame = function(id) {
-			var newpos = ((index+1) * tabHeight) + parseInt(tabTopOffset);
-			try{
-				if(obj.tabs){
-					activeTab = document.getElementById(obj.tabs[obj.activeTab].id).style;
-					activeTab.visibility = 'visible';
-					activeTab.top = ((newpos + 1) + obj.tab_height) + "px";
-					activeTab.left = (tabLeftOffset) + "px";
-					activeTab.width = tabWidth;
-					activeTab.height = (parseInt(that.get(index).height) - 2) - obj.tab_height;
-			catch(e){}
-			obj=obj.style;
-			obj.top = (newpos + 1) + "px";
-			obj.left = (tabLeftOffset) + "px";
-			obj.width = tabWidth;
-			obj.height = (parseInt(that.get(index).height, 10) - 2);
-			obj.visibility = 'visible';
-	 * Starts the animation of the opening and closing tabs
-	 * @private
-	var startAnimation = function(openOrClose) {
-			that.get(i).animationFinished = false;
-		tabInterval = setInterval("tabs.animate('"+openOrClose+"')",1);
-	 * Checks if the animation of the opening and closing tabs is finished.
-	 * @private
-	var isAnimationFinished = function() {
-		for (var i = 0; i < that.count(); i ++) {
-			if (that.get(i).animationFinished === false) {
-				return false;
-		return true;
-	 * Stops the animation of the opening and closing tabs
-	 * @private
-	var stopAnimation = function() {
-		clearInterval(tabInterval);
-	this.list = [];
-	var that = this;
-	 * The DOM node of the tab array.
-	var rootNode = document.getElementById("tabs");
-	 * The ID of the currently open tab. If no tab is open, the value is NULL
-	var activeTabId = null;
-	 * Number of pixel that a tab moves while opening or closing.
-	 * @private
-	var pixelPerIteration = 20;
-	 * Used for the 'setInterval' call of 'this.animate'
-	var tabInterval;
-	var tabTopOffset = parseInt(rootNode.style.top, 10);
-	var tabLeftOffset = parseInt(rootNode.style.left, 10);
-	var tabWidth = parseInt(rootNode.style.width, 10);
-	var tabHeight = parseInt(rootNode.style.height, 10);
-	var tabStyle = cssString;
-	var tabPrefix = tab_prefix || '';
-	var styleObj = new StyleTag();
-	styleObj.addClass("verticalTabs", tabStyle);
-VerticalTabArray.prototype = new List();
+try{if(open_tab){open_tab=Number(open_tab);if(isNaN(open_tab)){var e=new Mb_warning("mod_tab.js: tab_init: open_tab must be a number or an empty string.");}}}
+catch(e){var z=new Mb_warning("mod_tab.js: tab_init: open_tab is not set.");open_tab="";}
+var tabs;mb_registerInitFunctions('tab_init()');eventLocalize.register(function(){localizeTabs();});eventInit.register(function(){localizeTabs();});function localizeTabs(){mb_ajax_json("../php/mod_tab_messages.php",function(obj,status){tabs.setTitles(obj);});}
+function tab_init(){var obj=document.getElementById("tabs").style;tabs=new VerticalTabArray(tab_style);for(var i=0;i<tab_ids.length;i++){tabs.addTab(tab_ids[i],tab_prefix+tab_titles[i],tab_frameHeight[i]);}
+if(open_tab!==""){tabs.openTab(tabs.get(open_tab).module);}}
+function tab_open(elementName){tabs.openTab(elementName);}
+var VerticalTab=function(id,title,frameHeight,tabWidth,tabHeight,tabStyle,number){var setNodeAttributes=function(title,frameHeight,tabWidth,tabHeight,tabStyle,number){node.id="tabs_"+that.module;node.className="verticalTabs";node.style.position="absolute";node.style.width=tabWidth;node.style.height=tabHeight;node.style.top=number*tabHeight;if($.browser.msie){node.onclick=function(){tabs.toggleTab(that.module);};}
+else{node.onclick=function(){tabs.toggleTab(that.module);};}
+node.innerHTML=title;};this.getNode=function(){return node;};this.module=id;this.height=frameHeight;this.animationFinished=true;var node=document.createElement("div");var that=this;setNodeAttributes(title,frameHeight,tabWidth,tabHeight,tabStyle,number);};var VerticalTabArray=function(cssString){this.addTab=function(id,title,height){var tab=new VerticalTab(id,title,height,tabWidth,tabHeight,tabStyle,this.count());this.add(tab);document.getElementById(id).style.visibility='hidden';rootNode.appendChild(this.get(-1).getNode());};this.delTab=function(id){var index=getIndexById(id);if(index!==null){rootNode.removeChild(this.get(index).getNode());this.del(index);for(var i=index;i<this.count();i++){var currentNode=this.get(i).getNode();var currentTop=parseInt(currentNode.style.top,10);currentNode.style.top=currentTop-tabHeight;}}};this.toggleTab=function(id){if(isAnimationFinished()){for(var i=0;i<this.count();i++){hideFrame(this.get(i).module);}
+if(id===activeTabId){closeTab(activeTabId);}
+else{activeTabId=id;startAnimation("open");}}
+else{var e=new Mb_warning("mod_tab.js: could not activate tab, opening or closing in progress!");}};this.setTitles=function(obj){for(var i=0;i<this.count();i++){for(var j=0;j<obj.length;j++){if(this.get(i).module==obj[j].id){this.get(i).getNode().innerHTML=tabPrefix+obj[j].title;}}}}
+this.getCoords=function(id){var coords=[];if(activeTabId){var indexOfOpeningTab=getIndexById(activeTabId);}
+var index=getIndexById(id);coords[0]=tabLeftOffset;coords[1]=tabTopOffset+index*tabHeight+(activeTabId&&indexOfOpeningTab<index?this.get(indexOfOpeningTab).height:0);coords[2]=coords[0]+tabWidth;coords[3]=coords[1]+(id==activeTabId?this.get(indexOfOpeningTab).height+tabHeight:tabHeight);return coords.join(",");};this.animate=function(openOrClose){for(var i=0;i<this.count();i++){if(this.get(i).animationFinished===false){var currentTabNewTop=i*tabHeight;if(openOrClose=='open'){var indexOfOpeningTab=getIndexById(activeTabId);if(indexOfOpeningTab!==null&&i>indexOfOpeningTab){currentTabNewTop+=this.get(indexOfOpeningTab).height;}}
+var currentTabCurrentTop=parseInt(this.get(i).getNode().style.top,10);if(currentTabCurrentTop==currentTabNewTop){this.get(i).animationFinished=true;}
+else if(currentTabCurrentTop<currentTabNewTop){var pixel=Math.min(pixelPerIteration,currentTabNewTop-currentTabCurrentTop);this.get(i).getNode().style.top=currentTabCurrentTop+pixel;}
+else if(currentTabCurrentTop>currentTabNewTop){var pixel=Math.min(pixelPerIteration,currentTabCurrentTop-currentTabNewTop);this.get(i).getNode().style.top=currentTabCurrentTop-pixel;}
+else{var e=new Mb_exception("mod_tab.js: animate: unknown state for tab "+i+" (currentTop: "+currentTabCurrentTop+", newTop:"+currentTabNewTop+")");}}}
+if(isAnimationFinished()){stopAnimation();if(openOrClose=="open"){showFrame(activeTabId);}}};var getIndexById=function(id){for(var i=0;i<that.count();i++){if(that.get(i).module==id){return i;}}
+var e=new Mb_exception("mod_tab.js: getIndexById: ID '"+id+"' not found.");return null;};var closeTab=function(id){if(id!==null){hideFrame(id);activeTabId=null;startAnimation("close");}};this.openTab=function(id){if(id!==null&&activeTabId!=id){if(isAnimationFinished()){for(var i=0;i<this.count();i++){hideFrame(this.get(i).module);}}
+activeTabId=id;startAnimation("open");}};var hideFrame=function(id){var index=getIndexById(id);if(index!==null){var obj=document.getElementById(id);obj.style.visibility='hidden';try{if(obj.tabs)
+document.getElementById(obj.tabs[obj.activeTab].id).style.visibility='hidden';}
+catch(e){}}};var showFrame=function(id){var index=getIndexById(id);if(index!==null){var obj=document.getElementById(id);var newpos=((index+1)*tabHeight)+parseInt(tabTopOffset);try{if(obj.tabs){activeTab=document.getElementById(obj.tabs[obj.activeTab].id).style;activeTab.visibility='visible';activeTab.top=((newpos+1)+obj.tab_height)+"px";activeTab.left=(tabLeftOffset)+"px";activeTab.width=tabWidth;activeTab.height=(parseInt(that.get(index).height)-2)-obj.tab_height;}}
+catch(e){}
+obj=obj.style;obj.top=(newpos+1)+"px";obj.left=(tabLeftOffset)+"px";obj.width=tabWidth;obj.height=(parseInt(that.get(index).height,10)-2);obj.visibility='visible';}};var startAnimation=function(openOrClose){for(var i=0;i<that.count();i++){that.get(i).animationFinished=false;}
+tabInterval=setInterval("tabs.animate('"+openOrClose+"')",1);};var isAnimationFinished=function(){for(var i=0;i<that.count();i++){if(that.get(i).animationFinished===false){return false;}}
+return true;};var stopAnimation=function(){clearInterval(tabInterval);};this.list=[];var that=this;var rootNode=document.getElementById("tabs");var activeTabId=null;var pixelPerIteration=20;var tabInterval;var tabTopOffset=parseInt(rootNode.style.top,10);var tabLeftOffset=parseInt(rootNode.style.left,10);var tabWidth=parseInt(rootNode.style.width,10);var tabHeight=parseInt(rootNode.style.height,10);var tabStyle=cssString;var tabPrefix=tab_prefix||'';var styleObj=new StyleTag();styleObj.addClass("verticalTabs",tabStyle);};VerticalTabArray.prototype=new List();
Modified: tags/2.5_min/http/javascripts/mod_treeConf.js
--- branches/2.5/http/javascripts/mod_treeConf.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/mod_treeConf.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1 +1,2 @@
 mb_registerSubFunctions("window.frames['treeConfGDE'].checkLayer()");
Modified: tags/2.5_min/http/javascripts/point.js
--- branches/2.5/http/javascripts/point.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/point.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,192 +1,20 @@
-* $Id$
-//http://www.mapbender.org/index.php/point.js
- * @class A class representing a two-dimensional point.
- * @constructor
- * @param {Float} x x value of the {@link Point}
- * @param {Float} y y value of the {@link Point}
- function Point(x, y, z){
- 	 * x value of the {@link Point}
-	 * @type Float
-//	this.x = parseFloat(x);
-	this.x = x;
- 	 * y value of the {@link Point}
-	 * @type Float
-//	this.y = parseFloat(y);
-	this.y = y;
-	this.z = z;
- * computes the distance between a {@link Point} p and this {@link Point}
- * @param {Point} p the distance between this {@link Point} and the {@link Point} p is computed.
- * @return {Float} the distance between the two {@link Point} objects.
-Point.prototype.dist = function(p){
-	return Math.sqrt(Math.pow(this.y-p.y,2) + Math.pow(this.x-p.x,2)) ;
- * checks if the coordinates of this {@link Point} match the coordinates of a {@link Point} p
- * @return {Boolean} true if the two points are equal; elso false
-Point.prototype.equals = function(p){
-	if (this.x == p.x && this.y == p.y) {return true;}
-	return false;
- * subtracts a {@link Point} p from this {@link Point}
- * @return a new {@link Point} with the difference of the two points
-Point.prototype.minus = function(p){
-	return new Point(this.x-p.x, this.y-p.y);
- * adds this {@link Point} to a {@link Point} p
- * @return a new {@link Point} with the sum of the two points
-Point.prototype.plus = function(p){
-	return new Point(this.x+p.x, this.y+p.y);
- * divides this {@link Point} by a scalar c
- * @param {Float} c divisor
- * @return a new {@link Point} divided by c
-Point.prototype.dividedBy = function(c){
-	if (c !== 0) {
-		return new Point(this.x/c, this.y/c);
-	var e = new Mb_exception("Point.dividedBy: Division by zero");
-	return false;
- * multiplies this {@link Point} by a scalar c
- * @param {Float} c factor
- * @return a new {@link Point} multiplied by c
-Point.prototype.times = function(c){
-	return new Point(this.x*c, this.y*c);
- * rounds the coordinates to numOfDigits digits
- * @param numOfDigits the coordinate will be rounded to numOfDigits digits
- * @return a new {@link Point} rounded to numOfDigits digits
- * @type Point
-Point.prototype.round = function(numOfDigits){
-	return new Point(roundToDigits(this.x, numOfDigits), roundToDigits(this.y, numOfDigits));
- * @returns a {String} representation of this Point
- * @type String
-Point.prototype.toString = function(){
-	if (typeof(this.z == "undefined")) {
-		return "[" + this.x + ", " + this.y + "]";
-	else {
-		return "[" + this.x + ", " + this.y + ", " + this.z + "]";
-// possible improvement: point has flag: map OR real. additional functions: toReal, toMap
- * @ignore
-function mapToReal(frameName, aPoint){
-	var v;
-	if (typeof(mb_mapObj) == 'object') {
-		v = makeClickPos2RealWorldPos(frameName, aPoint.x, aPoint.y);
-	else {
-		if (typeof(parent.mb_mapObj) == 'object') {
-			v = parent.makeClickPos2RealWorldPos(frameName, aPoint.x, aPoint.y);
-		else {
-			alert('where am i?');
-	return new Point(v[0], v[1]);
- * @ignore
-function realToMap(frameName, aPoint) {
-	var v;
-		v = makeRealWorld2mapPos(frameName, aPoint.x, aPoint.y);
-	else if (typeof(parent.mb_mapObj) == 'object') {
-		v = parent.makeRealWorld2mapPos(frameName, aPoint.x, aPoint.y);
-	else {
-		var e = new Mb_exception('Point.realToMap:where am i?');
- * @ignore
-function mb_calcExtent(frameName, min, max) {
-	var ind;
-		ind = getMapObjIndexByName(frameName);
-		ind = parent.getMapObjIndexByName(frameName);
-	else {
-		var e = new Mb_exception('Point.mb_calcExtent: function getMapObjIndexByName not found');
-	var extent = max.minus(min);
-	var center = extent.dividedBy(2).plus(min);
-	var relation_px_x = mb_mapObj[ind].width / mb_mapObj[ind].height;
-	var relation_px_y = mb_mapObj[ind].height / mb_mapObj[ind].width;
-	var relation_bbox_x = extent.x / extent.y;
-	var new_min;
-	var new_max;
-	if(relation_bbox_x <= relation_px_x){
-		new_min = new Point(center.x - relation_px_x * extent.y / 2, min.y);
-		new_max = new Point(center.x + relation_px_x * extent.y / 2, max.y);
-	else if(relation_bbox_x > relation_px_x){
-		new_min = new Point(min.x, center.y - relation_px_y * extent.x / 2);
-		new_max = new Point(max.x, center.y + relation_px_y * extent.x / 2);
-	mb_mapObj[ind].extent = new_min.x +","+ new_min.y +","+ new_max.x  +","+ new_max.y;
- * @ignore
-function roundToDigits(aFloat, numberOfDigits) {
-	return Math.round(aFloat*Math.pow(10, parseInt(numberOfDigits, 10)))/Math.pow(10, parseInt(numberOfDigits, 10));
+function Point(x,y,z){this.x=x;this.y=y;this.z=z;}
+Point.prototype.dist=function(p){return Math.sqrt(Math.pow(this.y-p.y,2)+Math.pow(this.x-p.x,2));};Point.prototype.equals=function(p){if(this.x==p.x&&this.y==p.y){return true;}
+return false;};Point.prototype.minus=function(p){return new Point(this.x-p.x,this.y-p.y);};Point.prototype.plus=function(p){return new Point(this.x+p.x,this.y+p.y);};Point.prototype.dividedBy=function(c){if(c!==0){return new Point(this.x/c,this.y/c);}
+var e=new Mb_exception("Point.dividedBy: Division by zero");return false;};Point.prototype.times=function(c){return new Point(this.x*c,this.y*c);};Point.prototype.round=function(numOfDigits){return new Point(roundToDigits(this.x,numOfDigits),roundToDigits(this.y,numOfDigits));};Point.prototype.toString=function(){if(typeof(this.z=="undefined")){return"["+this.x+", "+this.y+"]";}
+else{return"["+this.x+", "+this.y+", "+this.z+"]";}};function mapToReal(frameName,aPoint){var v;if(typeof(mb_mapObj)=='object'){v=makeClickPos2RealWorldPos(frameName,aPoint.x,aPoint.y);}
+else{if(typeof(parent.mb_mapObj)=='object'){v=parent.makeClickPos2RealWorldPos(frameName,aPoint.x,aPoint.y);}
+else{alert('where am i?');}}
+return new Point(v[0],v[1]);}
+function realToMap(frameName,aPoint){var v;if(typeof(mb_mapObj)=='object'){v=makeRealWorld2mapPos(frameName,aPoint.x,aPoint.y);}
+else if(typeof(parent.mb_mapObj)=='object'){v=parent.makeRealWorld2mapPos(frameName,aPoint.x,aPoint.y);}
+else{var e=new Mb_exception('Point.realToMap:where am i?');}
+function mb_calcExtent(frameName,min,max){var ind;if(typeof(mb_mapObj)=='object'){ind=getMapObjIndexByName(frameName);}
+else if(typeof(parent.mb_mapObj)=='object'){ind=parent.getMapObjIndexByName(frameName);}
+else{var e=new Mb_exception('Point.mb_calcExtent: function getMapObjIndexByName not found');}
+var extent=max.minus(min);var center=extent.dividedBy(2).plus(min);var relation_px_x=mb_mapObj[ind].width/mb_mapObj[ind].height;var relation_px_y=mb_mapObj[ind].height/mb_mapObj[ind].width;var relation_bbox_x=extent.x/extent.y;var new_min;var new_max;if(relation_bbox_x<=relation_px_x){new_min=new Point(center.x-relation_px_x*extent.y/2,min.y);new_max=new Point(center.x+relation_px_x*extent.y/2,max.y);}
+else if(relation_bbox_x>relation_px_x){new_min=new Point(min.x,center.y-relation_px_y*extent.x/2);new_max=new Point(max.x,center.y+relation_px_y*extent.x/2);}
+mb_mapObj[ind].extent=new_min.x+","+new_min.y+","+new_max.x+","+new_max.y;}
+function roundToDigits(aFloat,numberOfDigits){return Math.round(aFloat*Math.pow(10,parseInt(numberOfDigits,10)))/Math.pow(10,parseInt(numberOfDigits,10));}
Modified: tags/2.5_min/http/javascripts/popup.js
--- branches/2.5/http/javascripts/popup.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/popup.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,395 +1,48 @@
-* $Id$
-* COPYRIGHT: (C) 2002 by ccgis. This program is free software under the GNU General Public
-//http://www.mapbender.org/index.php/popup
-var popup_count = 1;
-var popup_top = 150;
- * @class A class representing a popup window
- * @constructor
- * @param {String/Object} title the title text of the popup or Options object
- * Elelemts of the options object (all optional):
- *  left: position left
- *  top: position top
- *  width: popup width
- *  height: popup height
- *  title: popup title
- *  frameName: name of the popups iframe if it loads a frame
- *  opacity: opacity of the frame
- *  moveOpacity: opacity while the user moves or resizes the frame
- *  html:content html of the frame (not parsed if url not false)
- *  url:content url of the frame
- *  minWidth: minimum width of the popup if the user resizes it
- *  maxWidth: maximum width of the popup if the user resizes it
- *  minHeight: minimum height of the popup if the user resizes it
- *  maxHeight: maximum height of the popup if the user resizes it
- *  minTop: minimum top position if the user moves the popup
- *  minLeft: minimum left position if the user moves the popup
- *  maxRight: maximum right position if the user moves/resizes the popup
- *  maxBottom: maximum bottom position if the user moves/resized the popup
- * 	style: additional styles for the popup
- *  destroy: remove dom of popup if user closes it (don't use it for iframes with framename)
- *  closeCallback: function that is called if the user closes the window
- * @param {String} html the "body" of the popup, can also be "url:http://foo.de" to display a website
- * @param {Number} width width of the popup
- * @param {Number} height hight of the popup
- * @param {Number} posx left position of the popup
- * @param {Number} popy top posision of the popup
-function mb_popup(title,html,width,height,posx,posy,fName,opacity) {
-	//get first free place
-	var create_pos=popup_count;
-	for(var i = 0; i < popup_count;i++)
-//		if(!document.getElementById("popup"+String(i))){
-//			create_pos=i;
-//			break;
-	this.id="popup"+String(create_pos);
-//	this.id="popup"+String(popup_top);
-	//Set defaults
-	defaults = {
-		left:25*create_pos,
-		top:25*create_pos,
-		width:300,height:250,
-		title:"Title",
-		frameName:this.id
-	if(typeof(title)!='object'){
-		this.options = defaults;
-		//Set vars
-		if(posx)this.options.left=posx;
-		if(posy)this.options.top=posy;
-		if(width)this.options.width=width;
-		if(height)this.options.height=height;
-		if(title)this.options.title=title;
-		if(fName)this.options.frameName=fName;
-		if(opacity)this.options.opacity;
-		if(html){
-			if(html.indexOf("url:")==0)
-				this.options.url=html.substr(4);
-			else
-				this.options.html=html;
-	else
-		this.options=$.extend(defaults, title);
-	popup_count++;
-	//create dom popup
-	$("body").append("<div style=\"display:none;z-index:"+popup_top+"\" id=\""+this.id+"\"></div>");
-	this.div = $("#"+this.id).mbPopup(this.options);
- * Shows the popup
-mb_popup.prototype.show = function(){
-	if(!document.getElementById(this.id)){
-		//(re)create dom popup
-	if(!this.isVisible())
-		$("#"+this.id).show();
- * Hides the popup
-mb_popup.prototype.hide = function(){
-	$("#"+this.id).hide();
- * Hides the popup
-mb_popup.prototype.destroy = function(){
-	$("#"+this.id).remove();
- * sets the width of the popup window
- * @param {Number} width new width of the popup
-mb_popup.prototype.setWidth = function(width){
-	var div=document.getElementById(this.id);
-	if(div)div.style.width=width;
- * sets the height of the popup window
- * @param {Number} height new height of the popup
-mb_popup.prototype.setHeight = function(height){
-	if(div)div.style.height=height;
- * sets the left position of the popup window
- * @param {Number} left new left position of the popup
-mb_popup.prototype.setLeft = function(left){
-	if(div)div.style.left=left;
- * sets the top position of the popup window
- * @param {Number} top new top position of the popup
-mb_popup.prototype.setTop = function(topp){
-	if(div)div.style.top=topp;
- * sets the opacity of the popup window
- * @param {Number} opacity new opacity value of the popup
-mb_popup.prototype.setOpacity = function(opacityy){
-	if(div)div.style.opacity=opacityy;
- * sets the title of the popup window
- * @param {String} title new title text of the popup
-mb_popup.prototype.setTitle = function(title){
-	$("#"+this.id+" h1").text(title);
- * sets the html content of the popup window
- * @param {String} html new html "body" of the popup
-mb_popup.prototype.setHtml = function(htmll){
-	this.options.url=null;
-	this.options.html=htmll;
-	$("#"+this.id+" .jqmnContent").html(htmll);
- * sets the url of the content
- * @param {String} url new url of the popup
-mb_popup.prototype.setUrl = function(url){
-	this.options.url=url;
-	this.options.html=null;
-	try{
-		eval("window.frames."+this.options.frameName+".location = \""+url+"\"");
-	}catch(e){
-		$("#"+this.id+" .jqmnContent").html('<iframe src="'+url+'"></iframe>');
- * gets the visible state of the popup window
- * @return visible state of the popup
- * @type Boolean
-mb_popup.prototype.isVisible = function(){
-	return $("#"+this.id+":visible").length>0?true:false;
- * get Scroll position
-function getScrollPos() {
-	var scrOf ={X:0,Y:0,wW:$(window).width(),dW:$().width(),wH:$(window).height(),dH:$().height()};
-	if( typeof( window.pageYOffset ) == 'number' ) {
-		//Netscape compliant
-		scrOf.Y = window.pageYOffset;
-		scrOf.X = window.pageXOffset;
-	} else if( document.body && ( document.body.scrollLeft || document.body.scrollTop ) ) {
-		//DOM compliant
-		scrOf.Y = document.body.scrollTop;
-		scrOf.X = document.body.scrollLeft;
-	} else if( document.documentElement && ( document.documentElement.scrollLeft || document.documentElement.scrollTop ) ) {
-		//IE6 standards compliant mode
-		scrOf.Y = document.documentElement.scrollTop;
-		scrOf.X = document.documentElement.scrollLeft;
-	return scrOf;
-(function($){
-	$.fn.mbPopup = function(options){
-		//default settings
-		defaults = {
-			left:0,top:0,
-			title:"",frameName:"",
-			opacity:1.0,moveOpacity:0.8,html:false,url:false,
-			minWidth:false,maxWidth:false,
-			minHeight:false,maxHeight:false,
-			minTop:"document",minLeft:"document",
-			maxRight:false,maxBottom:false,
-			style:null,destroy:true,
-			closeCallback:null
-		//override defaults
-		settings=$.extend(defaults,options)
-		//add Styles
-		this.addClass("jqmNotice");
-		this.css({top:settings.top,
-			left:settings.left,
-			width:settings.width,
-			height:settings.height,
-			opacity:settings.opacity
-		if(settings.style)
-			this.css(settings.style);
-		//Insert content
-		if(settings.url)
-			html = ('<iframe name="'+settings.frameName+'" src="'+settings.url+'"></iframe>');
-		else
-			html = ('<div class="scrollDiv">'+settings.html+'</div>');
-		this.html('<div class="jqmnTitle jqDrag"><h1>'+settings.title+'</h1></div><div class="jqmnContent">'+html+'</div><img src="../img/close_icon.png" class="jqmClose" alt="close" /><div class="jqResize" />');
-		var data = {El:this,fY:settings.minTop,fX:settings.minLeft,tX:settings.maxRight,tY:settings.maxBottom,
-			fW:settings.minWidth,tW:settings.maxWidth,fH:settings.minHeight,tH:settings.maxHeight,
-			destroy:settings.destroy,opacity:settings.opacity,moveOpacity:settings.moveOpacity,close:settings.closeCallback}
-		//Make window Dragable
-		$(".jqDrag", this).bind('mousedown',data,function(event){
-			//set to top
-			event.data.El.css("z-index",popup_top++);
-			event.data.El.css('opacity',event.data.moveOpacity)
-			//create helper div to steal mouse events
-			$("body").append("<div style=\"position:absolute;top:0px;left:0px;width:"+$().width()+"px;height:"+$().height()+"px;z-index:"+(popup_top+2)+($.browser.msie?";background:url(../img/transparent.gif)":"")+"\" id=\"mouse_catcher\"></div>");
-			$("iframe", event.data.El).hide();
-			//Parse setiings of min and max position
-			var data = $.mbPopupFn.parseDimensions(event);
-			//bind mouse events to popup
-			$().bind("mousemove",data,$.mbPopupFn.drag).bind('mouseup',event.data,$.mbPopupFn.stopdrag);
-		//Make Window resizable
-		$(".jqResize", this).bind('mousedown',data,function(event){
-			//set to top
-			event.data.El.css('opacity',0.8)
-			$().bind("mousemove",data,$.mbPopupFn.resize).bind('mouseup',event.data,$.mbPopupFn.stopresize);
-		//closeButton
-		$(".jqmClose", this).bind('click',data, function(event){
-			if(event.data.close)
-				event.data.close();
-			if(event.data.destroy)
-				event.data.El.slideUp('slow', function(){$(this).remove();});
-			else
-				event.data.El.slideUp('slow');
-		//raise on click
-		this.click(function(){this.style.zIndex=popup_top++});
-	//helper functions
-	$.mbPopupFn = {
-		//on drag
-		drag:function(event){
-			//console.log("tesddt");
-			var newPos = {X:event.data.X+event.pageX-event.data.pX,
-				Y:event.data.Y+event.pageY-event.data.pY};
-			if(event.data.fX!==false&&newPos.X<event.data.fX)
-				newPos.X=event.data.fX;
-			if(event.data.fY!==false&&newPos.Y<event.data.fY)
-				newPos.Y=event.data.fY;
-			if(event.data.tX!==false&&newPos.X>event.data.tX-event.data.W)
-				newPos.X=event.data.tX-event.data.W;
-			if(event.data.tY!==false&&newPos.Y>event.data.tY-event.data.H)
-				newPos.Y=event.data.tY-event.data.H;
-			event.data.El.css({left:newPos.X,top:newPos.Y});
-		//on resize
-		resize:function(event){
-			var newDim = {W:Math.max(event.pageX-event.data.pX+event.data.W,0),
-				H:Math.max(event.pageY-event.data.pY+event.data.H,0)};
-			if(event.data.fW!==false&&newDim.W<event.data.fW)
-				newDim.W=event.data.fW;
-			if(event.data.fH!==false&&newDim.H<event.data.fH)
-				newDim.H=event.data.fH;
-			if(event.data.tW!==false&&newDim.W>event.data.tW)
-				newDim.W=event.data.tW;
-			if(event.data.tH!==false&&newDim.H>event.data.tH)
-				newDim.H=event.data.tH;
-			if(event.data.tX!==false&&newDim.W+event.data.X>event.data.tX)
-				newDim.W=event.data.tX-event.data.X;
-			if(event.data.tY!==false&&newDim.H+event.data.Y>event.data.tY)
-				newDim.H=event.data.tY-event.data.Y;
-			event.data.El.css({width:newDim.W,height:newDim.H});
-		stopdrag:function(event){
-			event.data.El.css('opacity',event.data.opacity)
-			$("iframe", event.data.El).show();
-			$().unbind('mousemove',$.mbPopupFn.drag).unbind('mouseup',$.mbPopupFn.stopdrag);
-			$("#mouse_catcher").remove();
-		stopresize:function(event){
-			$().unbind('mousemove',$.mbPopupFn.resize).unbind('mouseup',$.mbPopupFn.stopresize);
-		//parse move and resize dimensions
-		parseDimensions:function(d){
-			var dim = getScrollPos();
-			return {El:d.data.El,
-				fX:(d.data.fX=="window"?dim.X:(d.data.fX=="document"?0:(d.data.fX<0?dim.dW-d.data.fX:d.data.fX))),
-				fY:(d.data.fX=="window"?dim.Y:(d.data.fY=="document"?0:(d.data.fY<0?dim.dH-d.data.fY:d.data.fY))),
-				tX:(d.data.tX=="window"?dim.X+dim.wW:(d.data.tX=="document"?dim.dW:(d.data.tX<0?dim.dW-d.data.tX:d.data.tX))),
-				tY:(d.data.tY=="window"?dim.Y+dim.wH:(d.data.tY=="document"?dim.dH:(d.data.tH<0?dim.dH-d.data.tH:d.data.tY))),
-				fW:(d.data.fW=="window"?dim.wW:(d.data.fW=="document"?dim.dW:(d.data.fW<0?dim.dW-d.data.fW:d.data.fW))),
-				fH:(d.data.fH=="window"?dim.wH:(d.data.fH=="document"?dim.dH:(d.data.fH<0?dim.dH-d.data.fH:d.data.fH))),
-				tW:(d.data.tW=="window"?dim.wW:(d.data.tW=="document"?dim.dW:(d.data.tW<0?dim.dW-d.data.tW:d.data.tW))),
-				tH:(d.data.tH=="window"?dim.wH:(d.data.tH=="document"?dim.dH:(d.data.tH<0?dim.dH-d.data.tH:d.data.tH))),
-				X:parseInt(d.data.El.css("left")),
-				Y:parseInt(d.data.El.css("top")),
-				W:parseInt(d.data.El.css("width")),
-				H:parseInt(d.data.El.css("height")),
-				pX:d.pageX,pY:d.pageY
-(jQuery);
+var popup_count=1;var popup_top=150;function mb_popup(title,html,width,height,posx,posy,fName,opacity){var create_pos=popup_count;for(var i=0;i<popup_count;i++)
+this.id="popup"+String(create_pos);defaults={left:25*create_pos,top:25*create_pos,width:300,height:250,title:"Title",frameName:this.id}
+if(typeof(title)!='object'){this.options=defaults;if(posx)this.options.left=posx;if(posy)this.options.top=posy;if(width)this.options.width=width;if(height)this.options.height=height;if(title)this.options.title=title;if(fName)this.options.frameName=fName;if(opacity)this.options.opacity;if(html){if(html.indexOf("url:")==0)
+this.options.url=html.substr(4);else
+this.options.html=html;}}
+else
+this.options=$.extend(defaults,title);popup_count++;$("body").append("<div style=\"display:none;z-index:"+popup_top+"\" id=\""+this.id+"\"></div>");this.div=$("#"+this.id).mbPopup(this.options);}
+mb_popup.prototype.show=function(){if(!document.getElementById(this.id)){$("body").append("<div style=\"display:none;z-index:"+popup_top+"\" id=\""+this.id+"\"></div>");this.div=$("#"+this.id).mbPopup(this.options);}
+if(!this.isVisible())
+$("#"+this.id).show();}
+mb_popup.prototype.hide=function(){$("#"+this.id).hide();}
+mb_popup.prototype.destroy=function(){$("#"+this.id).remove();}
+mb_popup.prototype.setWidth=function(width){var div=document.getElementById(this.id);if(div)div.style.width=width;}
+mb_popup.prototype.setHeight=function(height){var div=document.getElementById(this.id);if(div)div.style.height=height;}
+mb_popup.prototype.setLeft=function(left){var div=document.getElementById(this.id);if(div)div.style.left=left;}
+mb_popup.prototype.setTop=function(topp){var div=document.getElementById(this.id);if(div)div.style.top=topp;}
+mb_popup.prototype.setOpacity=function(opacityy){var div=document.getElementById(this.id);if(div)div.style.opacity=opacityy;}
+mb_popup.prototype.setTitle=function(title){$("#"+this.id+" h1").text(title);}
+mb_popup.prototype.setHtml=function(htmll){this.options.url=null;this.options.html=htmll;$("#"+this.id+" .jqmnContent").html(htmll);}
+mb_popup.prototype.setUrl=function(url){this.options.url=url;this.options.html=null;try{eval("window.frames."+this.options.frameName+".location = \""+url+"\"");}catch(e){$("#"+this.id+" .jqmnContent").html('<iframe src="'+url+'"></iframe>');}}
+mb_popup.prototype.isVisible=function(){return $("#"+this.id+":visible").length>0?true:false;}
+function getScrollPos(){var scrOf={X:0,Y:0,wW:$(window).width(),dW:$().width(),wH:$(window).height(),dH:$().height()};if(typeof(window.pageYOffset)=='number'){scrOf.Y=window.pageYOffset;scrOf.X=window.pageXOffset;}else if(document.body&&(document.body.scrollLeft||document.body.scrollTop)){scrOf.Y=document.body.scrollTop;scrOf.X=document.body.scrollLeft;}else if(document.documentElement&&(document.documentElement.scrollLeft||document.documentElement.scrollTop)){scrOf.Y=document.documentElement.scrollTop;scrOf.X=document.documentElement.scrollLeft;}
+return scrOf;}
+(function($){$.fn.mbPopup=function(options){defaults={left:0,top:0,width:300,height:250,title:"",frameName:"",opacity:1.0,moveOpacity:0.8,html:false,url:false,minWidth:false,maxWidth:false,minHeight:false,maxHeight:false,minTop:"document",minLeft:"document",maxRight:false,maxBottom:false,style:null,destroy:true,closeCallback:null};settings=$.extend(defaults,options)
+this.addClass("jqmNotice");this.css({top:settings.top,left:settings.left,width:settings.width,height:settings.height,opacity:settings.opacity});if(settings.style)
+this.css(settings.style);if(settings.url)
+html=('<iframe name="'+settings.frameName+'" src="'+settings.url+'"></iframe>');else
+html=('<div class="scrollDiv">'+settings.html+'</div>');this.html('<div class="jqmnTitle jqDrag"><h1>'+settings.title+'</h1></div><div class="jqmnContent">'+html+'</div><img src="../img/close_icon.png" class="jqmClose" alt="close" /><div class="jqResize" />');var data={El:this,fY:settings.minTop,fX:settings.minLeft,tX:settings.maxRight,tY:settings.maxBottom,fW:settings.minWidth,tW:settings.maxWidth,fH:settings.minHeight,tH:settings.maxHeight,destroy:settings.destroy,opacity:settings.opacity,moveOpacity:settings.moveOpacity,close:settings.closeCallback}
+$(".jqDrag",this).bind('mousedown',data,function(event){event.data.El.css("z-index",popup_top++);event.data.El.css('opacity',event.data.moveOpacity)
+$("body").append("<div style=\"position:absolute;top:0px;left:0px;width:"+$().width()+"px;height:"+$().height()+"px;z-index:"+(popup_top+2)+($.browser.msie?";background:url(../img/transparent.gif)":"")+"\" id=\"mouse_catcher\"></div>");$("iframe",event.data.El).hide();var data=$.mbPopupFn.parseDimensions(event);$().bind("mousemove",data,$.mbPopupFn.drag).bind('mouseup',event.data,$.mbPopupFn.stopdrag);});$(".jqResize",this).bind('mousedown',data,function(event){event.data.El.css("z-index",popup_top++);event.data.El.css('opacity',0.8)
+$("body").append("<div style=\"position:absolute;top:0px;left:0px;width:"+$().width()+"px;height:"+$().height()+"px;z-index:"+(popup_top+2)+($.browser.msie?";background:url(../img/transparent.gif)":"")+"\" id=\"mouse_catcher\"></div>");$("iframe",event.data.El).hide();var data=$.mbPopupFn.parseDimensions(event);$().bind("mousemove",data,$.mbPopupFn.resize).bind('mouseup',event.data,$.mbPopupFn.stopresize);});$(".jqmClose",this).bind('click',data,function(event){if(event.data.close)
+event.data.close();if(event.data.destroy)
+event.data.El.slideUp('slow',function(){$(this).remove();});else
+event.data.El.slideUp('slow');});this.click(function(){this.style.zIndex=popup_top++});};$.mbPopupFn={drag:function(event){var newPos={X:event.data.X+event.pageX-event.data.pX,Y:event.data.Y+event.pageY-event.data.pY};if(event.data.fX!==false&&newPos.X<event.data.fX)
+newPos.X=event.data.fX;if(event.data.fY!==false&&newPos.Y<event.data.fY)
+newPos.Y=event.data.fY;if(event.data.tX!==false&&newPos.X>event.data.tX-event.data.W)
+newPos.X=event.data.tX-event.data.W;if(event.data.tY!==false&&newPos.Y>event.data.tY-event.data.H)
+newPos.Y=event.data.tY-event.data.H;event.data.El.css({left:newPos.X,top:newPos.Y});},resize:function(event){var newDim={W:Math.max(event.pageX-event.data.pX+event.data.W,0),H:Math.max(event.pageY-event.data.pY+event.data.H,0)};if(event.data.fW!==false&&newDim.W<event.data.fW)
+newDim.W=event.data.fW;if(event.data.fH!==false&&newDim.H<event.data.fH)
+newDim.H=event.data.fH;if(event.data.tW!==false&&newDim.W>event.data.tW)
+newDim.W=event.data.tW;if(event.data.tH!==false&&newDim.H>event.data.tH)
+newDim.H=event.data.tH;if(event.data.tX!==false&&newDim.W+event.data.X>event.data.tX)
+newDim.W=event.data.tX-event.data.X;if(event.data.tY!==false&&newDim.H+event.data.Y>event.data.tY)
+newDim.H=event.data.tY-event.data.Y;event.data.El.css({width:newDim.W,height:newDim.H});},stopdrag:function(event){event.data.El.css('opacity',event.data.opacity)
+$("iframe",event.data.El).show();$().unbind('mousemove',$.mbPopupFn.drag).unbind('mouseup',$.mbPopupFn.stopdrag);$("#mouse_catcher").remove();},stopresize:function(event){event.data.El.css('opacity',event.data.opacity)
+$("iframe",event.data.El).show();$().unbind('mousemove',$.mbPopupFn.resize).unbind('mouseup',$.mbPopupFn.stopresize);$("#mouse_catcher").remove();},parseDimensions:function(d){var dim=getScrollPos();return{El:d.data.El,fX:(d.data.fX=="window"?dim.X:(d.data.fX=="document"?0:(d.data.fX<0?dim.dW-d.data.fX:d.data.fX))),fY:(d.data.fX=="window"?dim.Y:(d.data.fY=="document"?0:(d.data.fY<0?dim.dH-d.data.fY:d.data.fY))),tX:(d.data.tX=="window"?dim.X+dim.wW:(d.data.tX=="document"?dim.dW:(d.data.tX<0?dim.dW-d.data.tX:d.data.tX))),tY:(d.data.tY=="window"?dim.Y+dim.wH:(d.data.tY=="document"?dim.dH:(d.data.tH<0?dim.dH-d.data.tH:d.data.tY))),fW:(d.data.fW=="window"?dim.wW:(d.data.fW=="document"?dim.dW:(d.data.fW<0?dim.dW-d.data.fW:d.data.fW))),fH:(d.data.fH=="window"?dim.wH:(d.data.fH=="document"?dim.dH:(d.data.fH<0?dim.dH-d.data.fH:d.data.fH))),tW:(d.data.tW=="window"?dim.wW:(d.data.tW=="document"?dim.dW:(d.data.tW<0?dim.dW-d.data.tW:d.data.tW))),tH:(d.data.tH=="window"?dim.wH:(d.data.tH=="document"?dim.dH:(d.data.tH<0?dim.dH-d.data.tH:d.data.tH))),X:parseInt(d.data.El.css("left")),Y:parseInt(d.data.El.css("top")),W:parseInt(d.data.El.css("width")),H:parseInt(d.data.El.css("height")),pX:d.pageX,pY:d.pageY};}};})
+(jQuery);
Modified: tags/2.5_min/http/javascripts/requestGeometryConstructor.js
--- branches/2.5/http/javascripts/requestGeometryConstructor.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/requestGeometryConstructor.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,201 +1,20 @@
-* $Id: requestGeometryConstructor.js 1882 2007-12-03 09:01:24Z verenadiewald $
-//http://www.mapbender.org/index.php/requestGeometryConstructor.js
- * @class A class representing a constructor for a geometry/WFS request.
- * @constructor
- * @param {String} geomType type of the {@link RequestGeometryConstructor}
- * @param {String} geomType target of the {@link RequestGeometryConstructor}
- function RequestGeometryConstructor(geomTarget){
- 	 * geomTarget target of the {@link RequestGeometryConstructor}
-	 * @type String
-	this.geomTarget = geomTarget;
-	this.getGeometry = function(queryType,callbackFunction){
-		var target = this.geomTarget;
-		s = new Snapping(this.geomTarget);
-		callback = callbackFunction;
-	   	var el = window.frames[target].document;
-	   	el.onmouseover = null;
-	   	el.onmousedown = null;
-	   	el.onmouseup = null;
-	   	el.onmousemove = null;
-		if (queryType == "point") {
-			queryGeom = new Geometry(geomType.point);
-			el.onmousedown = function (e) {
-				mb_getMousePos(e,target);
-				realWorldPos = mapToReal(target,new Point(clickX,clickY));
-				queryGeom.addPoint(realWorldPos);
-				callback(target, queryGeom);
-				queryGeom = null;
-		else if (queryType == "polygon") {
-			queryGeom = new Geometry(geomType.polygon);
-			el.onmousedown = wfsSpatialRequestStart;
-			el.onmousemove = wfsSpatialRequestRun;
-		else if (queryType == "rectangle") {
-			queryGeom = new Geometry(geomType.line);
-			el.onmouseover = selAreaExtInit;
-			el.onmousedown = mod_box_start;
-		   	el.onmouseup = selAreaExtGet;
-		   	el.onmousemove = mod_box_run;
-		else if (queryType == "extent") {
-			var ind = getMapObjIndexByName(target);
-			var p0 = mapToReal(target, new Point(0,0));
-			var p1 = mapToReal(target, new Point(mb_mapObj[ind].width,mb_mapObj[ind].height));
-			queryGeom.addPoint(p0);
-			queryGeom.addPoint(p1);
-			queryGeom = null;
-	var s;
-	var callback;
-	var wfsSpatialRequestStart = function(e){
-		var that = this;
-		var realWorldPos;
-		if (s.isSnapped() == true) {
-			realWorldPos = s.getSnappedPoint();
-			s.clean();
-		else {
-			mb_getMousePos(e,that.geomTarget);
-			realWorldPos = mapToReal(that.geomTarget,new Point(clickX,clickY));
-		if (queryGeom.count() == 1) {
-			s.add(queryGeom.get(0));
-		if (s.isSnapped() && queryGeom.count() >= 3 && queryGeom.get(-1).equals(queryGeom.get(0))) {
-			queryGeom.close();
-			callback(that.geomTarget,queryGeom);
-			writeTag(that.geomTarget,"measuring","");
-			writeTag(that.geomTarget,"measure_display","");
-			var el = window.frames[that.geomTarget].document;
-			queryGeom = null;
-			return;
-		drawDashedLineExt();
-	var wfsSpatialRequestRun = function(e){
-		var that = this;
-		if (queryGeom.count() >= 3) {
-			var pos = new Point(clickX,clickY);
-			s.check(pos);
-	var drawDashedLineExt = function(e){
-		var that = this;
-		var ind = getMapObjIndexByName(that.geomTarget);
-		var str_mPoints = "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='"+mb_mapObj[ind].width+"' height='0'></div>";
-		str_mPoints += "<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='0' height='"+mb_mapObj[ind].height+"'></div>";
-		if (queryGeom != null) {
-			for(var i=0; i<queryGeom.count(); i++){
-				var pos = realToMap(that.geomTarget,queryGeom.get(i));
-				str_mPoints += "<div style='font-size:1px;position:absolute;top:"+(pos.y-2)+"px;left:"+(pos.x-2)+"px;width:3px;height:3px;background-color:#ff0000'></div>";
-			if(queryGeom.count()>1){
-				for(var k=1; k<queryGeom.count(); k++){
-					var pos0 = realToMap(that.geomTarget,queryGeom.get(k));
-					var pos1 = realToMap(that.geomTarget,queryGeom.get(k-1));
-					str_mPoints += evaluateDashesExt(pos1,pos0,k);
-		writeTag(that.geomTarget,"measuring",str_mPoints);
-	var evaluateDashesExt = function(p1,p0,count){
-		var that = this;
-		var str_dashedLine = "";
-		var d = p0.dist(p1);
-		var n = Math.round(d);
-		var s =  p0.minus(p1).dividedBy(n);
-		for(var i=1; i<n; i++){
-			var currPoint = p1.plus(s.times(i)).minus(new Point(2,2)).round(0);
-			if(currPoint.x >= 0 && currPoint.x <= mb_mapObj[ind].width && currPoint.y >= 0 && currPoint.y <= mb_mapObj[ind].height){
-				str_dashedLine += "<div style='font-size:1px;position:absolute;top:"+currPoint.y+"px;left:"+currPoint.x+"px;width:3px;height:3px;background-color:#ff0000'></div>";
-		return str_dashedLine;
-	var selAreaExtInit = function(e){
-		var that = this;
-   		mb_isBF = that.geomTarget;
-   		mb_zF = that.geomTarget;
-	var selAreaExtGet = function(e){
-		var that = this;
-		selAreaExtSetValidClipping(mod_box_stop(e));
-	var selAreaExtSetValidClipping = function(coords){
-		var that = this;
-			queryGeom.addPoint(new Point(coords[0],coords[1]));
-			queryGeom.addPoint(new Point(coords[2],coords[3]));
-			if(queryGeom.count() == 2){
-				queryGeom = null;
-			else{
+function RequestGeometryConstructor(geomTarget){this.geomTarget=geomTarget;this.getGeometry=function(queryType,callbackFunction){var target=this.geomTarget;s=new Snapping(this.geomTarget);callback=callbackFunction;var el=window.frames[target].document;el.onmouseover=null;el.onmousedown=null;el.onmouseup=null;el.onmousemove=null;if(queryType=="point"){queryGeom=new Geometry(geomType.point);el.onmousedown=function(e){mb_getMousePos(e,target);realWorldPos=mapToReal(target,new Point(clickX,clickY));queryGeom.addPoint(realWorldPos);callback(target,queryGeom);el.onmouseover=null;el.onmousedown=null;el.onmouseup=null;el.onmousemove=null;queryGeom=null;};}
+else if(queryType=="polygon"){queryGeom=new Geometry(geomType.polygon);el.onmousedown=wfsSpatialRequestStart;el.onmousemove=wfsSpatialRequestRun;}
+else if(queryType=="rectangle"){queryGeom=new Geometry(geomType.line);el.onmouseover=selAreaExtInit;el.onmousedown=mod_box_start;el.onmouseup=selAreaExtGet;el.onmousemove=mod_box_run;}
+else if(queryType=="extent"){queryGeom=new Geometry(geomType.line);var ind=getMapObjIndexByName(target);var p0=mapToReal(target,new Point(0,0));var p1=mapToReal(target,new Point(mb_mapObj[ind].width,mb_mapObj[ind].height));queryGeom.addPoint(p0);queryGeom.addPoint(p1);callback(target,queryGeom);el.onmouseover=null;el.onmousedown=null;el.onmouseup=null;el.onmousemove=null;queryGeom=null;}}
+var s;var callback;var wfsSpatialRequestStart=function(e){this.geomTarget=geomTarget;var that=this;var realWorldPos;if(s.isSnapped()==true){realWorldPos=s.getSnappedPoint();s.clean();}
+else{mb_getMousePos(e,that.geomTarget);realWorldPos=mapToReal(that.geomTarget,new Point(clickX,clickY));}
+queryGeom.addPoint(realWorldPos);if(queryGeom.count()==1){s.add(queryGeom.get(0));}
+if(s.isSnapped()&&queryGeom.count()>=3&&queryGeom.get(-1).equals(queryGeom.get(0))){queryGeom.close();callback(that.geomTarget,queryGeom);writeTag(that.geomTarget,"measuring","");writeTag(that.geomTarget,"measure_display","");var el=window.frames[that.geomTarget].document;el.onmouseover=null;el.onmousedown=null;el.onmouseup=null;el.onmousemove=null;queryGeom=null;return;}
+drawDashedLineExt();}
+var wfsSpatialRequestRun=function(e){this.geomTarget=geomTarget;var that=this;if(queryGeom.count()>=3){mb_getMousePos(e,that.geomTarget);var pos=new Point(clickX,clickY);s.check(pos);}}
+var drawDashedLineExt=function(e){this.geomTarget=geomTarget;var that=this;var ind=getMapObjIndexByName(that.geomTarget);var str_mPoints="<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='"+mb_mapObj[ind].width+"' height='0'></div>";str_mPoints+="<div style='position:absolute;left:0px;top:0px' ><img src='"+mb_trans.src+"' width='0' height='"+mb_mapObj[ind].height+"'></div>";if(queryGeom!=null){for(var i=0;i<queryGeom.count();i++){var pos=realToMap(that.geomTarget,queryGeom.get(i));str_mPoints+="<div style='font-size:1px;position:absolute;top:"+(pos.y-2)+"px;left:"+(pos.x-2)+"px;width:3px;height:3px;background-color:#ff0000'></div>";}
+if(queryGeom.count()>1){for(var k=1;k<queryGeom.count();k++){var pos0=realToMap(that.geomTarget,queryGeom.get(k));var pos1=realToMap(that.geomTarget,queryGeom.get(k-1));str_mPoints+=evaluateDashesExt(pos1,pos0,k);}}}
+writeTag(that.geomTarget,"measuring",str_mPoints);}
+var evaluateDashesExt=function(p1,p0,count){this.geomTarget=geomTarget;var that=this;var ind=getMapObjIndexByName(that.geomTarget);var str_dashedLine="";var d=p0.dist(p1);var n=Math.round(d);var s=p0.minus(p1).dividedBy(n);for(var i=1;i<n;i++){var currPoint=p1.plus(s.times(i)).minus(new Point(2,2)).round(0);if(currPoint.x>=0&&currPoint.x<=mb_mapObj[ind].width&&currPoint.y>=0&&currPoint.y<=mb_mapObj[ind].height){str_dashedLine+="<div style='font-size:1px;position:absolute;top:"+currPoint.y+"px;left:"+currPoint.x+"px;width:3px;height:3px;background-color:#ff0000'></div>";}}
+return str_dashedLine;}
+var selAreaExtInit=function(e){this.geomTarget=geomTarget;var that=this;mb_isBF=that.geomTarget;mb_zF=that.geomTarget;}
+var selAreaExtGet=function(e){this.geomTarget=geomTarget;var that=this;selAreaExtSetValidClipping(mod_box_stop(e));mb_isBF=that.geomTarget;mb_zF=that.geomTarget;}
+var selAreaExtSetValidClipping=function(coords){this.geomTarget=geomTarget;var that=this;if(queryGeom!=null){queryGeom.addPoint(new Point(coords[0],coords[1]));queryGeom.addPoint(new Point(coords[2],coords[3]));if(queryGeom.count()==2){callback(that.geomTarget,queryGeom);var el=window.frames[that.geomTarget].document;el.onmouseover=null;el.onmousedown=null;el.onmouseup=null;el.onmousemove=null;queryGeom=null;}
+else{callback(that.geomTarget,queryGeom);}}}}
\ No newline at end of file
Modified: tags/2.5_min/http/javascripts/style.js
--- branches/2.5/http/javascripts/style.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/style.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,54 +1,4 @@
- * creates a style tag in the head of the document.
-var StyleTag = function() {
-	 * Creates the style tag in the head of the document. Something like a constructor.
-	var createStyleTag = function() {
-		// TODO: Internet Explorer routine seems a little buggy
-			// create a Style Sheet object (IE only)
-			//styleSheetObj=document.createStyleSheet();
-			// get the DOM node of the style sheet object, set the type
-			//styleObj=styleSheetObj.owningElement || styleSheetObj.ownerNode;
-			//styleObj.setAttribute("type","text/css");
-			// alternative way for IE: take existing styleSheet with index 0 instead of creating a new one
-			styleSheetObj=document.styleSheets[0];
-		else {
-			// create the style node, set the style
-			styleObj=document.createElement("style");
-			styleObj.setAttribute("type","text/css");
-			// append the node to the head
-			document.getElementsByTagName("head")[0].appendChild(styleObj);
-	 * Adds a class className with the CSS in cssString
-	this.addClass = function(className,cssString) {
-			//add new style declaration to chosen styleSheet
-			var cssRules = cssString.split(";");
-			for (i=0; i<cssRules.length-1; i++){
-				styleSheetObj.addRule("."+className,cssRules[i]);
-		else {
-			// insert the content via createTextNode
-			styleObj.appendChild(document.createTextNode("."+className+"{\n\t"+cssString+"\n}\n"));
-	var styleObj;
-	var styleSheetObj; //IE only...
-	createStyleTag();
+var StyleTag=function(){var createStyleTag=function(){if($.browser.msie){styleSheetObj=document.styleSheets[0];}
+else{styleObj=document.createElement("style");styleObj.setAttribute("type","text/css");document.getElementsByTagName("head")[0].appendChild(styleObj);}};this.addClass=function(className,cssString){if($.browser.msie){var cssRules=cssString.split(";");for(i=0;i<cssRules.length-1;i++){styleSheetObj.addRule("."+className,cssRules[i]);}}
+else{styleObj.appendChild(document.createTextNode("."+className+"{\n\t"+cssString+"\n}\n"));}};var styleObj;var styleSheetObj;createStyleTag();};
Modified: tags/2.5_min/http/javascripts/wfs.js
--- branches/2.5/http/javascripts/wfs.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/wfs.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,493 +1,71 @@
-// --- usemap (begin) --------------------------------------------------------------------------------------------
-function mod_usemap(wfs_name) {
-	if (wfs_name == "") {
-		usemap = "";
-	var ind = getMapObjIndexByName(mb_wfs_target);
-	var myImg = window.frames[mb_wfs_target].document.getElementById("um_img").style;
-	myImg.width = mb_mapObj[ind].width;
-	myImg.height = mb_mapObj[ind].height;
-	for (var i = 0 ; i < mb_wfs_fetch.count() ; i ++) {
-		if (mb_wfs_fetch.get(i).wfs_conf == wfs_name || wfs_name == "") {
-			if (mb_wfs_fetch.get(i).geomType == geomType.polygon) {
-				usemap += mod_usemap_polygon(i);
-			else if (mb_wfs_fetch.get(i).geomType == geomType.point) {
-				usemap += mod_usemap_circle(i);
-			else if (mb_wfs_fetch.get(i).geomType == geomType.line) {
-				usemap += mod_usemap_line(i);
-	writeUsemap(usemap);
-function mod_usemap_circle(ind){
-	var str = "";
-	var coord = "";
-	var title = "";
-	for (var i = 0 ; i < mb_wfs_fetch.get(ind).e.count(); i++) {
-		if (i>0) title += "&#10;";
-		title += mb_wfs_fetch.get(ind).e.getName(i) + ": " + mb_wfs_fetch.get(ind).e.getValue(i);
-	for (var i = 0 ; i < mb_wfs_fetch.get(ind).count() ; i ++) {
-		var p = mb_wfs_fetch.getPoint(ind, i, 0);
-		var pos = realToMap(mb_wfs_target,p);
-		coord += pos.x + ", " + pos.y;
-		str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
-		str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='circle'  coords='";
-		str += coord + ", " + mod_usemap_radius + "' href='#'>";
-	return str;
-function mod_usemap_line_calculate (aGeometry, j, orientation, cnt) {
-	var coord = "";
-	var p1 = realToMap(mb_wfs_targets[0],aGeometry.get(j));
-	var p2 = realToMap(mb_wfs_targets[0],aGeometry.get(j+orientation));
-	var vec = p2.minus(p1);
-	if (vec.x != 0 || vec.y != 0) {
-		var n_vec;
-		if (vec.x != 0) {
-			if (vec.x > 0) n_vec = new Point((-vec.y)/vec.x, -1);
-			else n_vec = new Point(vec.y/vec.x, 1);
-		else {
-			if (vec.y > 0) n_vec = new Point(1,0);
-			else n_vec = new Point(-1,0);
-		n_vec = n_vec.times(mod_usemap_line_tolerance).dividedBy(n_vec.dist(new Point(0,0)))
-		lp = new Point(p1.x + n_vec.x, p1.y - n_vec.y);
-		if (cnt > 0) coord += ", ";
-		coord += parseInt(lp.x) + ", " + parseInt(lp.y);
-		coord += ", " + parseInt(lp.x+vec.x) + ", " + parseInt(lp.y+vec.y);
-	return coord;
-function mod_usemap_line(ind){
-	var str = "";
-	var title = "";
-		var coord = "";
-		var cnt = 0;
-		for (var j = 0 ; j < mb_wfs_fetch.getGeometry(ind,i).count() - 1  ; j ++) {
-			var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, 1, cnt);
-			if (result != "") {
-				coord += result;
-				cnt++;
-		for (var j = (mb_wfs_fetch.getGeometry(ind,i).count() - 1) ; j > 0 ; j--) {
-			var result = mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i), j, -1, cnt);
-				coord += result;
-				cnt++;
-		if (coord != "") {
-			str += "<AREA title='"+title+"'";
-			str += "onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";
-			str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' ";
-			str += "shape='poly'  coords='";
-			str += coord + "' href='#'>";
-		else {
-			//display circle
-			var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind,i,0));
-			str += "<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";
-	return str;
-function mod_usemap_polygon(ind){
-	var str = "";
-	var coord = "";
-	var title = "";
-		var pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, 0));
-		for (var j = 1 ; j < mb_wfs_fetch.getGeometry(ind,i).count() ; j ++) {
-			pos = realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind, i, j));
-			coord += ", " + pos.x + ", " + pos.y;
-		str += "onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='poly'  coords='";
-	return str;
-function writeUsemap(str) {
-	writeTag(mb_wfs_targets[0], 'um', str);
-// --- usemap (end) ----------------------------------------------------------------------------------------------
-var highlight_tag_id = "wfs_highlight_tag";
-var mb_wfs_fetched = [];
-var mb_wfs_target = "mapframe1";
-var mb_wfs_objwin = null;
-var mb_wfs_objwin_left = 800;
-var mb_wfs_objwin_top = 200;
-var mb_wfs_objwin_width = 200;
-var mb_wfs_objwin_height = 200;
-var mb_wfs_targets = new Array("mapframe1","overview");
-var mb_wfs_fillColor = "#ff0000";
-var usemap = "";
-var mod_usemap_radius = 10;
-var mod_usemap_line_tolerance = 5;
-var useCheckboxForHighlighting = false;
-var mb_wfs_fetch = new GeometryArray();
-var highlight;
-try {if(generalHighlightZIndex){}}catch(e) {generalHighlightZIndex = 90;}
-try {if(generalHighlightLineWidth){}}catch(e) {generalHighlightLineWidth = 2;}
-try {if(useUsemap){}}catch(e) {useUsemap = 0;}
-mb_registerInitFunctions('initHighlight()');
-function initHighlight() {
-	var styleObj = {"position":"absolute", "top":"0px", "left":"0px", "z-index":generalHighlightZIndex};
-	highlight = new Highlight(mb_wfs_targets, highlight_tag_id, styleObj, generalHighlightLineWidth);
-try {if(displayWfsResultList){}}catch(e) {displayWfsResultList = 0;};
-if (displayWfsResultList == 1) {
-	//mb_registerWfsReadSubFunctions(function(geom){mb_wfs_listMember(geom)});
-if (parseInt(useUsemap) == 1) {
-	mb_registerSubFunctions('mod_usemap("")');
-if (useCheckboxForHighlighting) {
-	eventInit.register(function() {
-		mb_registerSubFunctions('highlight.paint()');
-if (useExtentIsSet()) {
-	mb_registerSubFunctions("mb_setwfsrequest_extent()");
-function mb_setwfsrequest_extent() {
-	if (useExtentIsSet()) {
-		var ind = getMapObjIndexByName(mb_wfs_targets[0]);
-		var pos_a = makeClickPos2RealWorldPos(mb_wfs_targets[0],0,0);
-		var pos_b = makeClickPos2RealWorldPos(mb_wfs_targets[0],mb_mapObj[ind].width,mb_mapObj[ind].height);
-		var x = [];
-		var y = [];
-		x[0] = pos_a[0];
-		x[1] = pos_b[0];
-		y[0] = pos_a[1];
-		y[1] = pos_b[1];
-		mb_setwfsrequest(mb_wfs_targets[0],'rectangle',x,y);
-function mb_wfs_listMember(geomArray){
-	mb_wfs_fetch.union(geomArray);
-	var wfs_conf = get_complete_wfs_conf();
-	var str = "<table>";
-	for(var i=0; i<mb_wfs_fetch.count(); i++){
-		var t = wfs_conf[mb_wfs_fetch.get(i).wfs_conf];
-		for(var j=0; j<t['element'].length; j++){
-			if(t['element'][j]['f_show'] > 0){
-				var k = mb_wfs_fetch.get(i).e.getElementIndexByName(t['element'][j]['element_name']);
-				//alert(k);
-				if(k != -1){
-					str += "<tr><td>";
-					if (useCheckboxForHighlighting) {
-						str += "<input type=checkbox id=highlightCheckbox" + i + " onChange='highlightGeometry(" + i + ")'></td><td>";
-					str += "<div";
-					if (!useCheckboxForHighlighting) {
-						str += " onmouseover='mb_wfs_perform(\"over\",mb_wfs_fetch.get("+i+"))' ";
-						str += " onmouseout='mb_wfs_perform(\"out\",mb_wfs_fetch.get("+i+"))' ";
-					str += " onclick='mb_wfs_perform(\"click\",mb_wfs_fetch.get("+i+"))' ";
-					str += ">" + mb_wfs_fetch.get(i).e.getValue(k)+ "</div></td></tr>";
-	str += "</table>";
-	mb_wfs_objwin.innerHTML = str;
-//	if (parseInt(useUsemap) == 1) mod_usemap(wfs_name);
-function mb_wfs_reset(){
-	mb_wfs_fetch = new parent.GeometryArray();
-	usemap = "";
-	if(mb_wfs_objwin == null){
-		var iframe=document.createElement('div');
-		iframe.setAttribute("style","position:absolute;left:"+mb_wfs_objwin_left+"px;top:"+mb_wfs_objwin_top+"px;width:"+mb_wfs_objwin_width+"px;height:"+mb_wfs_objwin_height+"px");
-		mb_wfs_objwin = document.body.appendChild(iframe);
-		mb_wfs_objwin.id = "mb_wfs_objwin";
-		mb_wfs_objwin.name = "mb_wfs_objwin";
-		mb_wfs_objwin.style.position = 'absolute';
-		mb_wfs_objwin.style.left = mb_wfs_objwin_left+"px";
-		mb_wfs_objwin.style.top = mb_wfs_objwin_top+"px";
-		mb_wfs_objwin.style.width = mb_wfs_objwin_width+"px";
-		mb_wfs_objwin.style.height = mb_wfs_objwin_height+"px";
-	for(var i=0; i<mb_wfsreq; i++){
-		if(document.getElementById("mb_wfs_win_"+mb_wfsreq)){
-			document.removeChild("mb_wfs_win_"+mb_wfsreq);
-	mb_wfsreq = 0;
-	return true;
-function get_complete_wfs_conf() {
-	var wfs_conf = window.frames["wfs_conf"].get_wfs_conf();
-	return wfs_conf;
-function highlightGeometry(i) {
-	var id = "highlightCheckbox"+i;
-	if (document.getElementById(id).checked) {
-		highlight.add(mb_wfs_fetch.get(i), '#00ff00');
-		highlight.paint();
-	else {
-		highlight.del(mb_wfs_fetch.get(i), '#00ff00');
-function mb_wfs_perform(type,m){
-	if(type=='over') {
-		highlight.add(m, '#ff0000');
-	else if (type == 'out') {
-		highlight.del(m, '#ff0000');
-	else
-		if (type == 'click') {
-			var tmp = m.getBBox();
-			if (m.geomType == geomType.point) {
-				var b = 1;
-			else {
-				var b = 0;
-			if (typeof(m.wfs_conf) != "undefined") {
-				b = parseFloat(wfs_conf[m.wfs_conf]['g_buffer']);
-			var buffer = new Point(b, b);
-			var bbox_ll = tmp[0].minus(buffer);
-			var bbox_ru = tmp[1].plus(buffer);
-			mb_calcExtent(mb_wfs_targets[0], bbox_ll, bbox_ru);
-			zoom(mb_wfs_targets[0], 'true', 1.0);
-function get_wfs_str(myconf, d, m, type, fid) {
-	<!-- Getting the Namspace for the FeautureType -->
-	var featureTypeArray = myconf['featuretype_name'].split(':')
-	var featureNS = featureTypeArray[0];
-	var str = '<wfs:Transaction version="1.0.0" service="WFS" ';
-	var ns_gml = false;	var ns_ogc = false;	var ns_xsi = false;	var ns_wfs = false;	var ns_featureNS = false;
-	for (var q = 0 ; q < myconf['namespaces'].length ; q++) {
-		if (myconf['namespaces'][q]['name'] == "gml"){
-			 ns_gml = true;
-			 str += 'xmlns:' + myconf['namespaces'][q]['name'] + '="' + myconf['namespaces'][q]['location'] + '" ';
-		} else if (myconf['namespaces'][q]['name'] == "ogc") {
-			ns_ogc = true;
-		} else if (myconf['namespaces'][q]['name'] == "xsi") {
-			ns_xsi = true;
-		} else if (myconf['namespaces'][q]['name'] == "wfs") {
-			ns_wfs = true;
-		} else if (myconf['namespaces'][q]['name'] == featureNS) {
-			ns_featureNS = true;
-			strForSchemaLocation = myconf['namespaces'][q]['location'];
-	if (ns_gml == false) str += 'xmlns:gml="http://www.opengis.net/gml" ';
-	if (ns_ogc == false) str += 'xmlns:ogc="http://www.opengis.net/ogc" ';
-	if (ns_xsi == false) str += 'xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" ';
-	if (ns_featureNS == false) str += 'xmlns:"+featureNS+"="http://www.someserver.com/"+featureNS+"" ';
-	if (ns_wfs == false) str += 'xmlns:wfs="http://www.opengis.net/wfs" ';
-	str += 'xsi:schemaLocation="http://www.opengis.net/wfs';
-	str += ' http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd';
-	str += ' ' + strForSchemaLocation;
-	str += ' '+ myconf['wfs_describefeaturetype'];
-	//str += mb_getConjunctionCharacter(myconf['wfs_describefeaturetype']);
-	//str += 'typename=' + myconf['featuretype_name'];
-	str += '">';
-	// ---------------------------------------- SAVE -------------------------------------------------
-	if (type == "save") {
-		str += '<wfs:Insert><'+ myconf['featuretype_name']+'>';
-		for(var i=0; i<d.get(m).e.count(); i++){
-			if(d.get(m).e.getValue(i) != "" && d.get(m).e.getName(i) != "fid"){
-				var tmp = d.get(m).e.getName(i);
-				str += '<' + tmp  + '>' + d.get(m).e.getValue(i) + '</' + tmp  + '>';
-		for(var j=0; j<myconf['element'].length; j++){
-			if(myconf['element'][j]['f_geom'] == 1){
-				var el_geom = myconf['element'][j]['element_name'];
-		str += '<' + el_geom + '>';
-		if(d.get(m).geomType == geomType.point){
-			str += '<gml:Point srsName="' + myconf['featuretype_srs'] + '">';
-			str += '<gml:coordinates>';
-			str += d.getPoint(m,0,0).x + "," + d.getPoint(m,0,0).y;
-			str += '</gml:coordinates>';
-			str += '</gml:Point>';
-		if(d.get(m).geomType == geomType.line){
-			str += '<gml:MultiLineString srsName="' + myconf['featuretype_srs'] + '">';
-			str += '<gml:lineStringMember><gml:LineString><gml:coordinates>';
-			for(var k=0; k<d.getGeometry(m,0).count(); k++){
-				if(k>0)	str += " ";
-				str += d.getPoint(m,0,k).x + "," + d.getPoint(m,0,k).y;
-			str += '</gml:coordinates></gml:LineString></gml:lineStringMember>';
-			str += '</gml:MultiLineString>';
-		if(d.get(m).geomType == geomType.polygon){
-			str += '<gml:MultiPolygon srsName="' + myconf['featuretype_srs'] + '">';
-			str += '<gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>';
-			str += '</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon>';
-		str += '</' + el_geom + '></'+ myconf['featuretype_name']+'></wfs:Insert>';
-	// --------------------------------------- UPDATE ------------------------------------------------
-	else if (type == "update") {
-		str += '<wfs:Update typeName="'+ myconf['featuretype_name']+'">';
-				str += '<wfs:Property>';
-				str += '<wfs:Name>'+d.get(m).e.getName(i)+'</wfs:Name>';
-				str += '<wfs:Value>'+d.get(m).e.getValue(i)+'</wfs:Value>';
-				str += '</wfs:Property>';
-		str += '<wfs:Property><wfs:Name>' + el_geom + '</wfs:Name><wfs:Value>';
-			str += '<gml:Point srsName="' + myconf['featuretype_srs'] + '"><gml:coordinates>';
-			str += '</gml:coordinates></gml:Point>';
-		str += '</wfs:Value></wfs:Property>';
-		str += '<ogc:Filter><ogc:FeatureId fid="'+fid+'"/></ogc:Filter>';
-		str += '</wfs:Update>';
-	// --------------------------------------- DELETE ------------------------------------------------
-	else if (type == "delete") {
-		str += '<wfs:Delete typeName="'+ myconf['featuretype_name']+'">';
-		str += '</wfs:Delete>';
-	str += '</wfs:Transaction>';
-	return str;
+function mod_usemap(wfs_name){if(wfs_name==""){usemap="";}
+var ind=getMapObjIndexByName(mb_wfs_target);var myImg=window.frames[mb_wfs_target].document.getElementById("um_img").style;myImg.width=mb_mapObj[ind].width;myImg.height=mb_mapObj[ind].height;for(var i=0;i<mb_wfs_fetch.count();i++){if(mb_wfs_fetch.get(i).wfs_conf==wfs_name||wfs_name==""){if(mb_wfs_fetch.get(i).geomType==geomType.polygon){usemap+=mod_usemap_polygon(i);}
+else if(mb_wfs_fetch.get(i).geomType==geomType.point){usemap+=mod_usemap_circle(i);}
+else if(mb_wfs_fetch.get(i).geomType==geomType.line){usemap+=mod_usemap_line(i);}}}
+writeUsemap(usemap);}
+function mod_usemap_circle(ind){var str="";var coord="";var title="";for(var i=0;i<mb_wfs_fetch.get(ind).e.count();i++){if(i>0)title+="&#10;";title+=mb_wfs_fetch.get(ind).e.getName(i)+": "+mb_wfs_fetch.get(ind).e.getValue(i);}
+for(var i=0;i<mb_wfs_fetch.get(ind).count();i++){var p=mb_wfs_fetch.getPoint(ind,i,0);var pos=realToMap(mb_wfs_target,p);coord+=pos.x+", "+pos.y;str+="<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";str+="onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='circle'  coords='";str+=coord+", "+mod_usemap_radius+"' href='#'>";}
+return str;}
+function mod_usemap_line_calculate(aGeometry,j,orientation,cnt){var coord="";var p1=realToMap(mb_wfs_targets[0],aGeometry.get(j));var p2=realToMap(mb_wfs_targets[0],aGeometry.get(j+orientation));var vec=p2.minus(p1);if(vec.x!=0||vec.y!=0){var n_vec;if(vec.x!=0){if(vec.x>0)n_vec=new Point((-vec.y)/vec.x,-1);else n_vec=new Point(vec.y/vec.x,1);}
+else{if(vec.y>0)n_vec=new Point(1,0);else n_vec=new Point(-1,0);}
+n_vec=n_vec.times(mod_usemap_line_tolerance).dividedBy(n_vec.dist(new Point(0,0)))
+lp=new Point(p1.x+n_vec.x,p1.y-n_vec.y);if(cnt>0)coord+=", ";coord+=parseInt(lp.x)+", "+parseInt(lp.y);coord+=", "+parseInt(lp.x+vec.x)+", "+parseInt(lp.y+vec.y);}
+return coord;}
+function mod_usemap_line(ind){var str="";var title="";for(var i=0;i<mb_wfs_fetch.get(ind).e.count();i++){if(i>0)title+="&#10;";title+=mb_wfs_fetch.get(ind).e.getName(i)+": "+mb_wfs_fetch.get(ind).e.getValue(i);}
+for(var i=0;i<mb_wfs_fetch.get(ind).count();i++){var coord="";var cnt=0;for(var j=0;j<mb_wfs_fetch.getGeometry(ind,i).count()-1;j++){var result=mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i),j,1,cnt);if(result!=""){coord+=result;cnt++;}}
+for(var j=(mb_wfs_fetch.getGeometry(ind,i).count()-1);j>0;j--){var result=mod_usemap_line_calculate(mb_wfs_fetch.getGeometry(ind,i),j,-1,cnt);if(result!=""){coord+=result;cnt++;}}
+if(coord!=""){str+="<AREA title='"+title+"'";str+="onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";str+="onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' ";str+="shape='poly'  coords='";str+=coord+"' href='#'>";}
+else{var pos=realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind,i,0));coord+=pos.x+", "+pos.y;str+="<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch["+ind+"])' ";str+="onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='circle'  coords='";str+=coord+", "+mod_usemap_radius+"' href='#'>";}}
+return str;}
+function mod_usemap_polygon(ind){var str="";var coord="";var title="";for(var i=0;i<mb_wfs_fetch.get(ind).e.count();i++){if(i>0)title+="&#10;";title+=mb_wfs_fetch.get(ind).e.getName(i)+": "+mb_wfs_fetch.get(ind).e.getValue(i);}
+for(var i=0;i<mb_wfs_fetch.get(ind).count();i++){var pos=realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind,i,0));coord+=pos.x+", "+pos.y;for(var j=1;j<mb_wfs_fetch.getGeometry(ind,i).count();j++){pos=realToMap(mb_wfs_targets[0],mb_wfs_fetch.getPoint(ind,i,j));coord+=", "+pos.x+", "+pos.y;}
+str+="<AREA title='"+title+"' onmouseover='parent.mb_wfs_perform(\"over\",parent.mb_wfs_fetch.get("+ind+"))' ";str+="onmouseout='parent.mb_wfs_perform(\"out\",parent.mb_wfs_fetch.get("+ind+"))' shape='poly'  coords='";str+=coord+"' href='#'>";}
+return str;}
+function writeUsemap(str){writeTag(mb_wfs_targets[0],'um',str);}
+var highlight_tag_id="wfs_highlight_tag";var mb_wfs_fetched=[];var mb_wfs_target="mapframe1";var mb_wfs_objwin=null;var mb_wfs_objwin_left=800;var mb_wfs_objwin_top=200;var mb_wfs_objwin_width=200;var mb_wfs_objwin_height=200;var mb_wfs_targets=new Array("mapframe1","overview");var mb_wfs_fillColor="#ff0000";var usemap="";var mod_usemap_radius=10;var mod_usemap_line_tolerance=5;var useCheckboxForHighlighting=false;var mb_wfs_fetch=new GeometryArray();var highlight;try{if(generalHighlightZIndex){}}catch(e){generalHighlightZIndex=90;}
+try{if(generalHighlightLineWidth){}}catch(e){generalHighlightLineWidth=2;}
+try{if(useUsemap){}}catch(e){useUsemap=0;}
+mb_registerInitFunctions('initHighlight()');function initHighlight(){var styleObj={"position":"absolute","top":"0px","left":"0px","z-index":generalHighlightZIndex};highlight=new Highlight(mb_wfs_targets,highlight_tag_id,styleObj,generalHighlightLineWidth);}
+try{if(displayWfsResultList){}}catch(e){displayWfsResultList=0;};if(displayWfsResultList==1){}
+if(parseInt(useUsemap)==1){mb_registerSubFunctions('mod_usemap("")');}
+if(useCheckboxForHighlighting){eventInit.register(function(){mb_registerSubFunctions('highlight.paint()');});}
+function mb_wfs_listMember(geomArray){mb_wfs_fetch.union(geomArray);var wfs_conf=get_complete_wfs_conf();var str="<table>";for(var i=0;i<mb_wfs_fetch.count();i++){var t=wfs_conf[mb_wfs_fetch.get(i).wfs_conf];for(var j=0;j<t['element'].length;j++){if(t['element'][j]['f_show']>0){var k=mb_wfs_fetch.get(i).e.getElementIndexByName(t['element'][j]['element_name']);if(k!=-1){str+="<tr><td>";if(useCheckboxForHighlighting){str+="<input type=checkbox id=highlightCheckbox"+i+" onChange='highlightGeometry("+i+")'></td><td>";}
+str+="<div";if(!useCheckboxForHighlighting){str+=" onmouseover='mb_wfs_perform(\"over\",mb_wfs_fetch.get("+i+"))' ";str+=" onmouseout='mb_wfs_perform(\"out\",mb_wfs_fetch.get("+i+"))' ";}
+str+=" onclick='mb_wfs_perform(\"click\",mb_wfs_fetch.get("+i+"))' ";str+=">"+mb_wfs_fetch.get(i).e.getValue(k)+"</div></td></tr>";}}}}
+str+="</table>";mb_wfs_objwin.innerHTML=str;}
+function mb_wfs_reset(){mb_wfs_fetch=new parent.GeometryArray();usemap="";if(mb_wfs_objwin==null){var iframe=document.createElement('div');iframe.setAttribute("style","position:absolute;left:"+mb_wfs_objwin_left+"px;top:"+mb_wfs_objwin_top+"px;width:"+mb_wfs_objwin_width+"px;height:"+mb_wfs_objwin_height+"px");mb_wfs_objwin=document.body.appendChild(iframe);mb_wfs_objwin.id="mb_wfs_objwin";mb_wfs_objwin.name="mb_wfs_objwin";mb_wfs_objwin.style.position='absolute';mb_wfs_objwin.style.left=mb_wfs_objwin_left+"px";mb_wfs_objwin.style.top=mb_wfs_objwin_top+"px";mb_wfs_objwin.style.width=mb_wfs_objwin_width+"px";mb_wfs_objwin.style.height=mb_wfs_objwin_height+"px";}
+for(var i=0;i<mb_wfsreq;i++){if(document.getElementById("mb_wfs_win_"+mb_wfsreq)){document.removeChild("mb_wfs_win_"+mb_wfsreq);}}
+mb_wfsreq=0;return true;}
+function get_complete_wfs_conf(){var wfs_conf=window.frames["wfs_conf"].get_wfs_conf();return wfs_conf;}
+function highlightGeometry(i){var id="highlightCheckbox"+i;if(document.getElementById(id).checked){highlight.add(mb_wfs_fetch.get(i),'#00ff00');highlight.paint();}
+else{highlight.del(mb_wfs_fetch.get(i),'#00ff00');highlight.paint();}}
+function mb_wfs_perform(type,m){var wfs_conf=window.frames["wfs_conf"].get_wfs_conf();if(type=='over'){highlight.add(m,'#ff0000');highlight.paint();}
+else if(type=='out'){highlight.del(m,'#ff0000');highlight.paint();}
+else
+if(type=='click'){var tmp=m.getBBox();if(m.geomType==geomType.point){var b=1;}
+else{var b=0;}
+if(typeof(m.wfs_conf)!="undefined"){b=parseFloat(wfs_conf[m.wfs_conf]['g_buffer']);}
+var buffer=new Point(b,b);var bbox_ll=tmp[0].minus(buffer);var bbox_ru=tmp[1].plus(buffer);mb_calcExtent(mb_wfs_targets[0],bbox_ll,bbox_ru);zoom(mb_wfs_targets[0],'true',1.0);}}
+function get_wfs_str(myconf,d,m,type,fid){<!--Getting the Namspace for the FeautureType-->var featureTypeArray=myconf['featuretype_name'].split(':')
+var featureNS=featureTypeArray[0];var str='<wfs:Transaction version="1.0.0" service="WFS" ';var ns_gml=false;var ns_ogc=false;var ns_xsi=false;var ns_wfs=false;var ns_featureNS=false;for(var q=0;q<myconf['namespaces'].length;q++){if(myconf['namespaces'][q]['name']=="gml"){ns_gml=true;str+='xmlns:'+myconf['namespaces'][q]['name']+'="'+myconf['namespaces'][q]['location']+'" ';}else if(myconf['namespaces'][q]['name']=="ogc"){ns_ogc=true;str+='xmlns:'+myconf['namespaces'][q]['name']+'="'+myconf['namespaces'][q]['location']+'" ';}else if(myconf['namespaces'][q]['name']=="xsi"){ns_xsi=true;str+='xmlns:'+myconf['namespaces'][q]['name']+'="'+myconf['namespaces'][q]['location']+'" ';}else if(myconf['namespaces'][q]['name']=="wfs"){ns_wfs=true;str+='xmlns:'+myconf['namespaces'][q]['name']+'="'+myconf['namespaces'][q]['location']+'" ';}else if(myconf['namespaces'][q]['name']==featureNS){ns_featureNS=true;str+='xmlns:'+myconf['namespaces'][q]['name']+'="'+myconf['namespaces'][q]['location']+'" '
+strForSchemaLocation=myconf['namespaces'][q]['location'];}}
+if(ns_gml==false)str+='xmlns:gml="http://www.opengis.net/gml" ';if(ns_ogc==false)str+='xmlns:ogc="http://www.opengis.net/ogc" ';if(ns_xsi==false)str+='xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" ';if(ns_featureNS==false)str+='xmlns:"+featureNS+"="http://www.someserver.com/"+featureNS+"" ';if(ns_wfs==false)str+='xmlns:wfs="http://www.opengis.net/wfs" ';str+='xsi:schemaLocation="http://www.opengis.net/wfs';str+=' http://schemas.opengis.net/wfs/1.0.0/WFS-transaction.xsd';str+=' '+strForSchemaLocation;str+=' '+myconf['wfs_describefeaturetype'];str+='">';if(type=="save"){str+='<wfs:Insert><'+myconf['featuretype_name']+'>';for(var i=0;i<d.get(m).e.count();i++){if(d.get(m).e.getValue(i)!=""&&d.get(m).e.getName(i)!="fid"){var tmp=d.get(m).e.getName(i);str+='<'+tmp+'>'+d.get(m).e.getValue(i)+'</'+tmp+'>';}}
+for(var j=0;j<myconf['element'].length;j++){if(myconf['element'][j]['f_geom']==1){var el_geom=myconf['element'][j]['element_name'];}}
+str+='<'+el_geom+'>';if(d.get(m).geomType==geomType.point){str+='<gml:Point srsName="'+myconf['featuretype_srs']+'">';str+='<gml:coordinates>';str+=d.getPoint(m,0,0).x+","+d.getPoint(m,0,0).y;str+='</gml:coordinates>';str+='</gml:Point>';}
+if(d.get(m).geomType==geomType.line){str+='<gml:MultiLineString srsName="'+myconf['featuretype_srs']+'">';str+='<gml:lineStringMember><gml:LineString><gml:coordinates>';for(var k=0;k<d.getGeometry(m,0).count();k++){if(k>0)str+=" ";str+=d.getPoint(m,0,k).x+","+d.getPoint(m,0,k).y;}
+str+='</gml:coordinates></gml:LineString></gml:lineStringMember>';str+='</gml:MultiLineString>';}
+if(d.get(m).geomType==geomType.polygon){str+='<gml:MultiPolygon srsName="'+myconf['featuretype_srs']+'">';str+='<gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>';for(var k=0;k<d.getGeometry(m,0).count();k++){if(k>0)str+=" ";str+=d.getPoint(m,0,k).x+","+d.getPoint(m,0,k).y;}
+str+='</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon>';}
+str+='</'+el_geom+'></'+myconf['featuretype_name']+'></wfs:Insert>';}
+else if(type=="update"){str+='<wfs:Update typeName="'+myconf['featuretype_name']+'">';for(var i=0;i<d.get(m).e.count();i++){if(d.get(m).e.getValue(i)!=""&&d.get(m).e.getName(i)!="fid"){str+='<wfs:Property>';str+='<wfs:Name>'+d.get(m).e.getName(i)+'</wfs:Name>';str+='<wfs:Value>'+d.get(m).e.getValue(i)+'</wfs:Value>';str+='</wfs:Property>';}}
+str+='<wfs:Property><wfs:Name>'+el_geom+'</wfs:Name><wfs:Value>';if(d.get(m).geomType==geomType.point){str+='<gml:Point srsName="'+myconf['featuretype_srs']+'"><gml:coordinates>';str+=d.getPoint(m,0,0).x+","+d.getPoint(m,0,0).y;str+='</gml:coordinates></gml:Point>';}
+str+='</wfs:Value></wfs:Property>';str+='<ogc:Filter><ogc:FeatureId fid="'+fid+'"/></ogc:Filter>';str+='</wfs:Update>';}
+else if(type=="delete"){str+='<wfs:Delete typeName="'+myconf['featuretype_name']+'">';for(var j=0;j<myconf['element'].length;j++){if(myconf['element'][j]['f_geom']==1){var el_geom=myconf['element'][j]['element_name'];}}
+str+='<ogc:Filter><ogc:FeatureId fid="'+fid+'"/></ogc:Filter>';str+='</wfs:Delete>';}
+str+='</wfs:Transaction>';return str;}
Modified: tags/2.5_min/http/javascripts/wfs_obj.js
--- branches/2.5/http/javascripts/wfs_obj.js	2008-10-01 08:38:00 UTC (rev 3067)
+++ tags/2.5_min/http/javascripts/wfs_obj.js	2008-10-01 08:39:43 UTC (rev 3069)
@@ -1,75 +1,6 @@
-//$Id$
-//$Header: /cvsroot/mapbender/mapbender/http/javascripts/wfs_obj.js,v 1.3 2005/09/13 14:38:11 bjoern_heuser Exp $
-//global variables
-var wfs = [];
-var wfs_featuretype_count = 0;
-var wfs_element_count = 0;
-//list of all wms-objects
-function add_wfs(
-			wfs_id,
-			wfs_version,
-			wfs_title,
-			wfs_abstract,
-			wfs_getcapabilities,
-			wfs_describefeaturetype){
-					wfs[wfs.length] = new wfs_const(
-					wfs_id,
-			      wfs_version,
-			      wfs_title,
-			      wfs_abstract,
-			      wfs_describefeaturetype);
-					//wfs_featuretype[wfs.length - 1] = [];
-//the wms constructor
-function wfs_const(
-			wfs_id,
-			wfs_version,
-			wfs_title,
-			wfs_abstract,
-	this.wfs_id = wfs_id;
-	this.wfs_version = wfs_version;
-	this.wfs_title = wfs_title;
-	this.wfs_abstract = wfs_abstract;
-	this.wfs_getcapabilities = wfs_getcapabilities;
-	this.wfs_describefeaturetype = wfs_describefeaturetype;
-	this.wfs_featuretype = [];
-   //alert(wfs_id + " , " +wfs_title + " , " +wfs_abstract + " , " +wfs_getcapabilities + " , " +wfs_describefeaturetype);
-//featuretype
-function wfs_add_featuretype(
-			featuretype_name,
-			featuretype_title,
-			featuretype_srs,
-			featuretype_geomtype){
-	      wfs[wfs.length-1].wfs_featuretype[wfs[wfs.length-1].wfs_featuretype.length] = new featuretype(
-											featuretype_name,
-											featuretype_srs,
-											featuretype_geomtype);
-//alert(featuretype_name + " , " +featuretype_title + " , " +featuretype_srs + " , " +featuretype_geomtype);
-function featuretype(
-			featuretype_name,
-			featuretype_srs,
-	this.featuretype_name = featuretype_name;
-	this.featuretype_title = featuretype_title;
-	this.featuretype_srs = featuretype_srs;
-	this.featuretype_geomtype = featuretype_geomtype;
-	this.element = [];
-	wfs_featuretype_count++;
-//elements
-function wfs_add_featuretype_element(element_name, element_type, element_count, featuretype_count){
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count] = [];
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].name = element_name;
-	wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].type = element_type;
-   //alert(element_name +" , "+element_type);
+var wfs=[];var wfs_featuretype_count=0;var wfs_element_count=0;function add_wfs(wfs_id,wfs_version,wfs_title,wfs_abstract,wfs_getcapabilities,wfs_describefeaturetype){wfs[wfs.length]=new wfs_const(wfs_id,wfs_version,wfs_title,wfs_abstract,wfs_getcapabilities,wfs_describefeaturetype);}
+function wfs_const(wfs_id,wfs_version,wfs_title,wfs_abstract,wfs_getcapabilities,wfs_describefeaturetype){this.wfs_id=wfs_id;this.wfs_version=wfs_version;this.wfs_title=wfs_title;this.wfs_abstract=wfs_abstract;this.wfs_getcapabilities=wfs_getcapabilities;this.wfs_describefeaturetype=wfs_describefeaturetype;this.wfs_featuretype=[];}
+function wfs_add_featuretype(featuretype_name,featuretype_title,featuretype_srs,featuretype_geomtype){wfs[wfs.length-1].wfs_featuretype[wfs[wfs.length-1].wfs_featuretype.length]=new featuretype(featuretype_name,featuretype_title,featuretype_srs,featuretype_geomtype);}
+function featuretype(featuretype_name,featuretype_title,featuretype_srs,featuretype_geomtype){this.featuretype_name=featuretype_name;this.featuretype_title=featuretype_title;this.featuretype_srs=featuretype_srs;this.featuretype_geomtype=featuretype_geomtype;this.element=[];wfs_featuretype_count++;}
+function wfs_add_featuretype_element(element_name,element_type,element_count,featuretype_count){wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count]=[];wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].name=element_name;wfs[wfs.length-1].wfs_featuretype[featuretype_count].element[element_count].type=element_type;}
More information about the Mapbender_commits mailing list
